[MOAB-dev] r3322 - MOAB/trunk
    bmsmith6 at wisc.edu
    Tue Nov 10 14:02:09 CST 2009
Author: bmsmith
Date: 2009-11-10 14:02:09 -0600 (Tue, 10 Nov 2009)
New Revision: 3322
Modified:
   MOAB/trunk/ReadCGM.cpp
   MOAB/trunk/ReadCGM.hpp
Log:
-Populate the file_set with the file's contents.
-Tag the file_set with the faceting_tol.
Modified: MOAB/trunk/ReadCGM.cpp
--- MOAB/trunk/ReadCGM.cpp	2009-11-10 00:05:13 UTC (rev 3321)
+++ MOAB/trunk/ReadCGM.cpp	2009-11-10 20:02:09 UTC (rev 3322)
@@ -58,7 +58,7 @@
 { return new ReadCGM( iface ); }
 ReadCGM::ReadCGM(MBInterface *impl)
-    : geom_tag(0), id_tag(0), name_tag(0), category_tag(0)
+  : geom_tag(0), id_tag(0), name_tag(0), category_tag(0), faceting_tol_tag(0)
   assert(NULL != impl);
   mdbImpl = impl;
@@ -84,6 +84,9 @@
   rval = mdbImpl->tag_create( CATEGORY_TAG_NAME, CATEGORY_TAG_SIZE,
                             MB_TAG_SPARSE, MB_TYPE_OPAQUE, category_tag, 0, true );
   assert(!rval);
+  rval = mdbImpl->tag_create("FACETING_TOL", sizeof(double), MB_TAG_SPARSE,
+			     MB_TYPE_DOUBLE, faceting_tol_tag, 0, true );
+  assert(!rval);
 ReadCGM::~ReadCGM()
@@ -108,7 +111,7 @@
 // copy geometry into mesh database
 MBErrorCode ReadCGM::load_file(const char *cgm_file_name,
-                      MBEntityHandle,
+                      MBEntityHandle file_set,
                       const FileOptions& opts,
                       const MBReaderIface::IDTag* subset_list,
                       int subset_list_length,
@@ -141,6 +144,10 @@
   if(MB_SUCCESS == opts.match_option(name,value))
     act_att = false;
+  // tag the file_set with the faceting_tol
+  rval = mdbImpl->tag_set_data( faceting_tol_tag, &file_set, 1, &faceting_tol );
+  if(MB_SUCCESS != rval) return rval;
   // CGM data
   std::map<RefEntity*,MBEntityHandle> entmap[5]; // one for each dim, and one for groups
   std::map<RefEntity*,MBEntityHandle>::iterator ci;
@@ -194,6 +201,9 @@
       if (MB_SUCCESS != rval)
         return rval;
+      rval = mdbImpl->add_entities( file_set, &handle, 1 );
       entmap[dim][ent] = handle;
       rval = mdbImpl->tag_set_data( geom_tag, &handle, 1, &dim );
@@ -287,6 +297,9 @@
     rval = mdbImpl->create_meshset( MESHSET_SET, h );
       return rval;
+    rval = mdbImpl->add_entities( file_set, &h, 1 );
     char namebuf[NAME_TAG_SIZE];
     memset( namebuf, '\0', NAME_TAG_SIZE );
@@ -530,6 +543,7 @@
         type = MBTRI;
       else {
         std::cerr << "Warning: non-triangle facet in surface " << face->id() << std::endl;
+	std::cerr << "  entity has " << *facet << " edges" << std::endl;
         if (*facet == 4)
           type = MBQUAD;
         else
@@ -555,7 +569,7 @@
       return MB_FAILURE;
   return MB_SUCCESS;
Modified: MOAB/trunk/ReadCGM.hpp
--- MOAB/trunk/ReadCGM.hpp	2009-11-10 00:05:13 UTC (rev 3321)
+++ MOAB/trunk/ReadCGM.hpp	2009-11-10 20:02:09 UTC (rev 3322)
@@ -97,7 +97,7 @@
     //! interface instance
   MBInterface* mdbImpl;
-  MBTag geom_tag, id_tag, name_tag, category_tag;
+  MBTag geom_tag, id_tag, name_tag, category_tag, faceting_tol_tag;
 #endif
