[MOAB-dev] r3319 - in MOAB/trunk: . test
bmsmith6 at wisc.edu
Mon Nov 9 17:24:09 CST 2009
Author: bmsmith
Date: 2009-11-09 17:24:09 -0600 (Mon, 09 Nov 2009)
New Revision: 3319
Added:
MOAB/trunk/nastran_test.cc
MOAB/trunk/test/test.nas
Modified:
MOAB/trunk/Makefile.am
MOAB/trunk/ReadNASTRAN.cpp
MOAB/trunk/test/Makefile.am
Log:
-Add a test for ReadNASTRAN.
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am 2009-11-09 23:14:43 UTC (rev 3318)
+++ MOAB/trunk/Makefile.am 2009-11-09 23:24:09 UTC (rev 3319)
@@ -40,6 +40,7 @@
cub_file_test \
exodus_test \
gmsh_test \
+ nastran_test \
stl_test \
mbcn_test \
bsp_tree_poly_test
@@ -373,6 +374,9 @@
gmsh_test_SOURCES = TestUtil.hpp gmsh_test.cc
gmsh_test_DEPENDENCIES = $(tag_test_LDADD)
+nastran_test_SOURCES = TestUtil.hpp nastran_test.cc
+nastran_test_DEPENDENCIES = $(tag_test_LDADD)
stl_test_SOURCES = TestUtil.hpp stl_test.cc
stl_test_DEPENDENCIES = $(tag_test_LDADD)
Modified: MOAB/trunk/ReadNASTRAN.cpp
--- MOAB/trunk/ReadNASTRAN.cpp 2009-11-09 23:14:43 UTC (rev 3318)
+++ MOAB/trunk/ReadNASTRAN.cpp 2009-11-09 23:24:09 UTC (rev 3319)
@@ -426,6 +426,7 @@
result = MBI->create_meshset( 0, new_material_set );
if(MB_SUCCESS != result) return result;
result = MBI->add_entities( file_set, &new_material_set, 1 );
+ if(MB_SUCCESS != result) return result;
result = MBI->tag_set_data( material_tag, &new_material_set, 1, &material );
material_set.insert( new_material_set );
Added: MOAB/trunk/nastran_test.cc
--- MOAB/trunk/nastran_test.cc (rev 0)
+++ MOAB/trunk/nastran_test.cc 2009-11-09 23:24:09 UTC (rev 3319)
@@ -0,0 +1,411 @@
+#include "TestUtil.hpp"
+#include "MBCore.hpp"
+#include "MBTagConventions.hpp"
+#include "MBCN.hpp"
+#include "ReadNASTRAN.hpp"
+#include "MBRange.hpp"
+#include "FileOptions.hpp"
+#include <math.h>
+#include <algorithm>
+#ifdef SRCDIR
+static const char example[] = STRINGIFY(SRCDIR) "/test/test.nas";
+#else
+static const char example[] = "test/test.nas";
+#endif
+void read_file( MBInterface& moab, const char* input_file );
+void test_read_nodes();
+void test_read_tets();
+void test_read_prisms();
+void test_read_hexes();
+void test_read_material_set1();
+void test_read_material_set2();
+int main()
+ int result = 0;
+ result += RUN_TEST(test_read_nodes);
+ result += RUN_TEST(test_read_tets);
+ result += RUN_TEST(test_read_prisms);
+ result += RUN_TEST(test_read_hexes);
+ result += RUN_TEST(test_read_material_set1);
+ result += RUN_TEST(test_read_material_set2);
+ return result;
+ MBErrorCode rval;
+ MBEntityHandle set;
+ moab.create_meshset( MESHSET_SET, set );
+ ReadNASTRAN reader( &moab );
+ FileOptions opts("");
+ rval = reader.load_file( input_file, set, opts, 0, 0, 0 );
+ CHECK_ERR(rval);
+ const double eps = 1e-100;
+ MBErrorCode rval;
+ MBCore moab;
+ MBInterface& mb = moab;
+ read_file( moab, example );
+ std::vector<MBEntityHandle> nodes;
+ rval = mb.get_entities_by_type( 0, MBVERTEX, nodes );
+ CHECK_ERR(rval);
+ CHECK_EQUAL( (size_t)19, nodes.size() );
+ MBTag id_tag;
+ rval = mb.tag_get_handle( GLOBAL_ID_TAG_NAME, id_tag );
+ CHECK_ERR(rval);
+ std::vector<int> ids(nodes.size());
+ rval = mb.tag_get_data( id_tag, &nodes[0], nodes.size(), &ids[0] );
+ CHECK_ERR(rval);
+ std::vector<int> sorted_ids( ids );
+ std::sort( sorted_ids.begin(), sorted_ids.end() );
+ std::vector<double> coords(3*nodes.size());
+ rval = mb.get_coords( &nodes[0], nodes.size(), &coords[0] );
+ CHECK_ERR(rval);
+ int idx, pos = 0;
+ // shared between 2 tets and 2 prisms
+ CHECK_EQUAL( pos+1, sorted_ids[pos] );
+ idx = std::find( ids.begin(), ids.end(),pos+1 ) - ids.begin();
+ CHECK_REAL_EQUAL( coords[3*idx+0], 0.0, eps );
+ CHECK_REAL_EQUAL( coords[3*idx+1], 1.0, eps );
+ CHECK_REAL_EQUAL( coords[3*idx+2], -2.0, eps );
+ ++pos;
+ CHECK_REAL_EQUAL( coords[3*idx+0], -1.0, eps );
+ CHECK_REAL_EQUAL( coords[3*idx+1], 0.0, eps );
+ CHECK_REAL_EQUAL( coords[3*idx+2], -1.0, eps );
+ ++pos;
+ CHECK_REAL_EQUAL( coords[3*idx+0], 1.0, eps );
+ ++pos;
+ ++pos;
+ CHECK_REAL_EQUAL( coords[3*idx+2], 0.0, eps );
+ ++pos;
+ ++pos;
+ ++pos;
+ CHECK_REAL_EQUAL( coords[3*idx+2], 1.0, eps );
+ ++pos;
+ ++pos;
+ ++pos;
+ CHECK_REAL_EQUAL( coords[3*idx+2], 2.0, eps );
+ // hex element
+ ++pos;
+ CHECK_REAL_EQUAL( coords[3*idx+0], 5.0, eps );
+ CHECK_REAL_EQUAL( coords[3*idx+1], 5.0, eps );
+ CHECK_REAL_EQUAL( coords[3*idx+2], 5.0, eps );
+ ++pos;
+ CHECK_REAL_EQUAL( coords[3*idx+0], 10.0, eps );
+ ++pos;
+ CHECK_REAL_EQUAL( coords[3*idx+1], 10.0, eps );
+ ++pos;
+ ++pos;
+ CHECK_REAL_EQUAL( coords[3*idx+2], 10.0, eps );
+ ++pos;
+ ++pos;
+ ++pos;
+ MBErrorCode rval;
+ MBCore moab;
+ std::vector<MBEntityHandle> tets;
+ rval = mb.get_entities_by_type( 0, MBTET, tets );
+ CHECK_ERR(rval);
+ CHECK_EQUAL( (size_t)2, tets.size() );
+ MBTag id_tag;
+ CHECK_ERR(rval);
+ std::vector<int> ids(tets.size());
+ rval = mb.tag_get_data( id_tag, &tets[0], tets.size(), &ids[0] );
+ CHECK_ERR(rval);
+ if (ids[0] != 1) {
+ std::swap( ids[0], ids[1] );
+ std::swap( tets[0], tets[1] );
+ int vtx_ids[4];
+ const MBEntityHandle* conn;
+ int len;
+ const int conn1[] = { 8, 9, 10, 11 };
+ int pos = 0;
+ CHECK_EQUAL( pos+1, ids[pos] );
+ rval = mb.get_connectivity( tets[pos], conn, len );
+ CHECK_ERR(rval);
+ CHECK_EQUAL( 4, len );
+ rval = mb.tag_get_data( id_tag, conn, len, vtx_ids );
+ CHECK_ERR(rval);
+ CHECK_ARRAYS_EQUAL( conn1, 4, vtx_ids, len );
+ const int conn2[] = { 4, 3, 2, 1 };
+ ++pos;
+ CHECK_ERR(rval);
+ CHECK_ERR(rval);
+ CHECK_ARRAYS_EQUAL( conn2, 4, vtx_ids, len );
+ MBErrorCode rval;
+ MBCore moab;
+ std::vector<MBEntityHandle> prisms;
+ rval = mb.get_entities_by_type( 0, MBPRISM, prisms );
+ CHECK_ERR(rval);
+ CHECK_EQUAL( (size_t)2, prisms.size() );
+ MBTag id_tag;
+ CHECK_ERR(rval);
+ std::vector<int> ids(prisms.size());
+ rval = mb.tag_get_data( id_tag, &prisms[0], prisms.size(), &ids[0] );
+ CHECK_ERR(rval);
+ if (ids[0] != 3) {
+ std::swap( prisms[0], prisms[1] );
+ int vtx_ids[6];
+ int len;
+ const int conn1[] = { 2, 3, 4, 5, 6, 7 };
+ int pos = 0;
+ // Element ids 1 and 2 are the two tet elements.
+ // Element ids 3 and 4 are the two prism elements.
+ CHECK_EQUAL( pos+3, ids[pos] );
+ rval = mb.get_connectivity( prisms[pos], conn, len );
+ CHECK_ERR(rval);
+ CHECK_EQUAL( 6, len );
+ CHECK_ERR(rval);
+ CHECK_ARRAYS_EQUAL( conn1, 6, vtx_ids, len );
+ const int conn2[] = { 5, 6, 7, 8, 9, 10 };
+ ++pos;
+ CHECK_ERR(rval);
+ CHECK_ERR(rval);
+ CHECK_ARRAYS_EQUAL( conn2, 6, vtx_ids, len );
+ MBErrorCode rval;
+ MBCore moab;
+ std::vector<MBEntityHandle> hexes;
+ rval = mb.get_entities_by_type( 0, MBHEX, hexes );
+ CHECK_ERR(rval);
+ CHECK_EQUAL( (size_t)1, hexes.size() );
+ MBTag id_tag;
+ CHECK_ERR(rval);
+ std::vector<int> ids(hexes.size());
+ rval = mb.tag_get_data( id_tag, &hexes[0], hexes.size(), &ids[0] );
+ CHECK_ERR(rval);
+ int vtx_ids[8];
+ int len;
+ const int conn1[] = { 12, 13, 14, 15, 16, 17, 18, 19 };
+ int pos = 0;
+ // Element id 5 is the hex
+ CHECK_EQUAL( pos+5, ids[pos] );
+ rval = mb.get_connectivity( hexes[pos], conn, len );
+ CHECK_ERR(rval);
+ CHECK_EQUAL( 8, len );
+ CHECK_ERR(rval);
+ CHECK_ARRAYS_EQUAL( conn1, 8, vtx_ids, len );
+// The tets are in material set 1.
+ MBErrorCode rval;
+ MBCore moab;
+ MBTag mat_tag;
+ rval = mb.tag_get_handle( MATERIAL_SET_TAG_NAME, mat_tag );
+ CHECK_ERR(rval);
+ MBRange mat_set_one;
+ const int one = 1;
+ const void* const one_val[] = {&one};
+ rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &mat_tag, one_val, 1, mat_set_one );
+ CHECK_ERR(rval);
+ CHECK_EQUAL( 1, (int)mat_set_one.size() );
+ std::vector<MBEntityHandle> tets, contents;
+ CHECK_ERR(rval);
+ rval = mb.get_entities_by_handle( mat_set_one.front(), contents );
+ CHECK_ERR(rval);
+ std::sort( tets.begin(), tets.end() );
+ std::sort( contents.begin(), contents.end() );
+ CHECK_EQUAL( tets, contents );
+// The prisms are in material set 2.
+ MBErrorCode rval;
+ MBCore moab;
+ MBTag mat_tag;
+ CHECK_ERR(rval);
+ MBRange mat_set_two;
+ const int two = 2;
+ const void* const two_val[] = {&two};
+ rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &mat_tag, two_val, 1, mat_set_two );
+ CHECK_ERR(rval);
+ CHECK_EQUAL( 1, (int)mat_set_two.size() );
+ std::vector<MBEntityHandle> prisms, contents;
+ CHECK_ERR(rval);
+ rval = mb.get_entities_by_handle( mat_set_two.front(), contents );
+ CHECK_ERR(rval);
+ std::sort( prisms.begin(), prisms.end() );
+ CHECK_EQUAL( prisms, contents );
Modified: MOAB/trunk/test/Makefile.am
--- MOAB/trunk/test/Makefile.am 2009-11-09 23:14:43 UTC (rev 3318)
+++ MOAB/trunk/test/Makefile.am 2009-11-09 23:24:09 UTC (rev 3319)
@@ -29,7 +29,8 @@
test.cub \
ho_test.cub \
sample.stl \
- gmsh2.msh
+ gmsh2.msh \
+ test.nas
CLEANFILES = mb_big_test.g \
cell1.gen \
Added: MOAB/trunk/test/test.nas
--- MOAB/trunk/test/test.nas (rev 0)
+++ MOAB/trunk/test/test.nas 2009-11-09 23:24:09 UTC (rev 3319)
@@ -0,0 +1,24 @@
+GRID 1 00.0000001.000000-2.00000
+GRID 2 0-1.000000.000000-1.00000
+GRID 3 01.0000000.00000E-1.00000
+GRID 4 00.0000001.00000e-1.00000
+GRID 5 0-1.000000.0000000.000000
+GRID 6 01.0000000.0000000.000000
+GRID 7 00.0000001.0000000.000000
+GRID 8 0-1.000000.0000001.000000
+GRID 9 01.0000000.0000001.000000
+GRID 10 00.0000001.0000001.000000
+GRID 11 00.0000001.0000002.000000
+GRID 12 05.0000005.0000005.000000
+GRID 13 01.0000+15.0000005.000000
+GRID 14 01.0000+11.0000+15.000000
+GRID 15 05.0000001.0000+15.000000
+GRID 16 05.0000005.0000001.0000+1
+GRID 17 01.0000+15.0000001.0000+1
+GRID 18 01.0000+11.000E+11.0000+1
+GRID 19 05.0000001.000e+11.0000+1
+CTETRA 1 1 8 9 10 11
+CTETRA 2 1 4 3 2 1
+CPENTA 3 2 2 3 4 5 6 7
+CPENTA 4 2 5 6 7 8 9 10
+CHEXA 5 3 12 13 14 15 16 17 18 19
\ No newline at end of file
