[MOAB-dev] r3195 - MOAB/trunk/parallel
tautges at mcs.anl.gov tautges at mcs.anl.gov
Thu Oct 8 17:33:12 CDT 2009
Author: tautges
Date: 2009-10-08 17:33:12 -0500 (Thu, 08 Oct 2009)
New Revision: 3195
Added:
   MOAB/trunk/parallel/scdtest.cpp
Log:
Adding parallel test from Milad showing issues with shared entity resolution.
Added: MOAB/trunk/parallel/scdtest.cpp
--- MOAB/trunk/parallel/scdtest.cpp	                        (rev 0)
+++ MOAB/trunk/parallel/scdtest.cpp	2009-10-08 22:33:12 UTC (rev 3195)
@@ -0,0 +1,210 @@
+#include <string>
+#include <iomanip>
+#include <iostream>
+#include <cassert>
+#include <MBCore.hpp>
+#include <MBInterface.hpp>
+#include <MBParallelComm.hpp>
+#include <HomXform.hpp>
+#include <MBParallelConventions.h>
+#include <MBTagConventions.hpp>
+using namespace std;
+// Number of cells in each direction:
+const int NC = 4;
+const int MNI = 5;
+const int MNJ = 10;
+const int MNK = 10;
+// Number of processes:
+const int NPROCS = 4;
+// Domain size:
+const double DSIZE = 10.0;
+// MOAB objects:
+MBInterface *mbint = NULL;
+MBParallelComm *mbpc = NULL;
+// Local domain starting and ending hex indexes:
+int is, js, ks;
+int ie, je, ke;
+// Obvious:
+int rank;
+int size;
+void set_local_domain_bounds();
+void create_hexes_and_verts();
+void resolve_and_exchange();
+void error(MBErrorCode err);
+int main(int argc, char *argv[])
+  MPI_Init(&argc, &argv);
+  MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+  MPI_Comm_size(MPI_COMM_WORLD, &size);
+  if(size != 4 && size != 2) {
+    cerr << "Run this with 2 or 4 processes\n";
+    exit(1);
+  mbint = new MBCore();
+  mbpc  = new MBParallelComm(mbint);
+  set_local_domain_bounds();
+  create_hexes_and_verts();
+  resolve_and_exchange();
+  MPI_Finalize();
+  return 0;
+  switch(rank) {
+  case 0:
+    switch (size) {
+    case 2:
+      is = 0; ie = NC/2;
+      js = 0; je = NC;
+      ks = 0; ke = NC;
+      break;
+    case 4:
+      js = 0; je = NC/2;
+      ks = 0; ke = NC;
+      break;
+    break;
+  case 1:
+    switch(size) {
+    case 2:
+      is = NC/2; ie = NC;
+      js = 0; je = NC;
+      ks = 0; ke = NC;
+      break;
+    case 4:
+      ks = 0; ke = NC;
+      break;
+    break;
+  case 2:
+    js = NC/2; je = NC;
+    ks = 0; ke = NC;
+    break;
+  case 3:
+    ks = 0; ke = NC;
+    break;
+  default:
+    cerr << "Run this with 4 processes\n";
+    exit(1);
+  MBCore *mbcore = dynamic_cast<MBCore*>(mbint);
+  HomCoord coord_min(0,0,0);
+  HomCoord coord_max(NC/2, NC, NC);
+  EntitySequence* vertex_seq = NULL;
+  EntitySequence* cell_seq = NULL;
+  MBEntityHandle vs, cs;
+  error(mbcore->create_scd_sequence(coord_min, coord_max, MBVERTEX, 1, vs, vertex_seq));
+  error(mbcore->create_scd_sequence(coord_min, coord_max, MBHEX, 1, cs, cell_seq));
+  HomCoord p1(0,0,0);
+  HomCoord p2(NC/2,0,0);
+  HomCoord p3(0,NC/2,0);
+  error(mbcore->add_vsequence(vertex_seq, cell_seq, p1, p1, p2, p2, p3, p3));
+  // Set global id's:
+  int gid;
+  MBTag global_id_tag;
+  error(mbint->tag_get_handle(GLOBAL_ID_TAG_NAME, global_id_tag));
+  MBEntityHandle handle = vs;
+  int i,j,k;
+  MBErrorCode err;
+  for(i = is; i < ie + 1; i++)
+    for(j = js; j < je + 1; j++)
+      for(k = ks; k < ke + 1; k++) {
+	gid = k + j*(NC+1) + i*(NC+1)*(NC+1) + 1;
+        err = mbint->tag_set_data(global_id_tag, &handle, 1, &gid);
+	if(err != MB_SUCCESS) {
+	  exit(1);
+	handle++;
+  handle = cs;
+  for(i = is; i < ie; i++)
+    for(j = js; j < je; j++)
+      for(k = ks; k < ke; k++) {
+	gid = k + j*NC + i*NC*NC + 1;
+        error(mbint->tag_set_data(global_id_tag, &handle, 1, &gid));
+	handle++;
+  MBEntityHandle entity_set;
+  MBErrorCode err;
+  // Create the entity set:
+  error(mbint->create_meshset(MESHSET_SET, entity_set));
+  // Get a list of hexes:
+  MBRange range;
+  error(mbint->get_entities_by_type(0, MBHEX, range));
+  // Add entities to the entity set:
+  error(mbint->add_entities(entity_set, range));
+  // Add the MATERIAL_SET tag to the entity set:
+  MBTag tag;
+  error(mbint->tag_get_handle(MATERIAL_SET_TAG_NAME, tag));
+  error(mbint->tag_set_data(tag, &entity_set, 1, &rank));
+  // Set up partition sets. This is where MOAB is actually told what
+  // entities each process owns:
+  error(mbint->get_entities_by_type_and_tag(0, MBENTITYSET,
+					    &tag, NULL, 1,
+					    mbpc->partition_sets()));
+  // Finally, determine which entites are shared and exchange the
+  // ghosted entities:
+  error(mbpc->resolve_shared_ents(0, -1, -1));
+  error(mbpc->exchange_ghost_cells(-1, 0, 1, true));
+    cerr << "Error: MOAB function failed\n";
+    assert(0);
