[MOAB-dev] r3194 - MOAB/trunk/parallel
tautges at mcs.anl.gov tautges at mcs.anl.gov
Thu Oct 8 15:58:23 CDT 2009
Author: tautges
Date: 2009-10-08 15:58:23 -0500 (Thu, 08 Oct 2009)
New Revision: 3194
Modified:
   MOAB/trunk/parallel/MBParallelComm.cpp
Log:
Correcting code which produced lots of warnings about string literals.
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp	2009-10-08 19:40:38 UTC (rev 3193)
+++ MOAB/trunk/parallel/MBParallelComm.cpp	2009-10-08 20:58:23 UTC (rev 3194)
@@ -131,13 +131,13 @@
 #define RRA(a) if (MB_SUCCESS != result) {\
       std::string tmp_str; mbImpl->get_last_error(tmp_str);\
       tmp_str.append("\n"); tmp_str.append(a);\
-      dynamic_cast<MBCore*>(mbImpl)->get_error_handler()->set_last_error(tmp_str.c_str()); \
+      dynamic_cast<MBCore*>(mbImpl)->get_error_handler()->set_last_error(tmp_str); \
       return result;}
 #define RRAI(i, a) if (MB_SUCCESS != result) {                \
       std::string tmp_str; i->get_last_error(tmp_str);\
-      dynamic_cast<MBCore*>(i)->get_error_handler()->set_last_error(tmp_str.c_str()); \
+      dynamic_cast<MBCore*>(i)->get_error_handler()->set_last_error(tmp_str); \
       return result;}
 /** Name of tag used to store MBParallelComm Index on mesh paritioning sets */
@@ -4448,7 +4448,7 @@
     // ok, now wait
-  MPI_Status status[MAX_SHARING_PROCS];
+//  MPI_Status status[MAX_SHARING_PROCS];
   success = MPI_Barrier(procConfig.proc_comm());
 //  success = MPI_Waitall(2*buffProcs.size(), &sendReqs[0], status);
   if (MPI_SUCCESS != success) {
