[MOAB-dev] more than 64 porcessors
    Tim Tautges
    tautges at mcs.anl.gov
    Tue Oct  6 10:45:36 CDT 2009
Jed's answer is correct, that parameter is the max # procs sharing with a given proc (actually, one less, since the
local proc # is also in that list).
- tim
Jed Brown wrote:
> On Tue, Oct 6, 2009 at 11:17, Lukasz Kaczmarczyk <likask at civil.gla.ac.uk> wrote:
>> Hello
>> If I like to run program for more than 64 processors, only variable which I
>> have to change is
>> <MBParallelCom.hpp>
>> #define MAX_SHARING_PROCS 64
>> That is true?
> I'm pretty sure you don't have to change this unless you have a really
> pathological mesh (where an entity is actually shared by that many
> processes).
> Jed
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
