[MOAB-dev] r3169 - MOAB/trunk
    kraftche at cae.wisc.edu
    Fri Sep 25 14:30:45 CDT 2009
Author: kraftche
Date: 2009-09-25 14:30:44 -0500 (Fri, 25 Sep 2009)
New Revision: 3169
Added:
   MOAB/trunk/bsp_tree_poly_test.cpp
Log:
forgot this one
Added: MOAB/trunk/bsp_tree_poly_test.cpp
--- MOAB/trunk/bsp_tree_poly_test.cpp	                        (rev 0)
+++ MOAB/trunk/bsp_tree_poly_test.cpp	2009-09-25 19:30:44 UTC (rev 3169)
@@ -0,0 +1,179 @@
+#include "BSPTreePoly.hpp"
+#include "TestUtil.hpp"
+#include "MBCartVect.hpp"
+void test_construct_from_hex();
+void test_cut_with_plane();
+void test_volume();
+int main( )
+  int error_count = 0;
+  error_count += RUN_TEST( test_construct_from_hex );
+  error_count += RUN_TEST( test_cut_with_plane );
+  error_count += RUN_TEST( test_volume );
+  return error_count;
+const int hex_faces[6][4] = { { 0, 1, 5, 4 },
+                              { 1, 2, 6, 5 },
+                              { 2, 3, 7, 6 },
+                              { 3, 0, 4, 7 },
+                              { 3, 2, 1, 0 },
+                              { 4, 5, 6, 7 } };
+static void get_corners( MBCartVect corners[8] )
+  corners[0] = MBCartVect( 1, 1, 0 );
+  corners[1] = MBCartVect( 6, 1, 0 );
+  corners[2] = MBCartVect( 6, 3, 0 );
+  corners[3] = MBCartVect( 1, 3, 0 );
+  corners[4] = MBCartVect( 1, 1, 2 );
+  corners[5] = MBCartVect( 4, 1, 2 );
+  corners[6] = MBCartVect( 4, 3, 2 );
+  corners[7] = MBCartVect( 1, 3, 2 );
+const BSPTreePoly::Face* find_face( const BSPTreePoly& poly,
+                                     const MBCartVect* coords,
+                                     int num_corners,
+                                     const int* face_indices = 0 )
+  std::vector<const BSPTreePoly::Face*>::iterator i;
+  std::vector<const BSPTreePoly::Face*> faces;
+  std::vector<MBCartVect> corners;
+  poly.get_faces( faces );
+  for (i = faces.begin(); i != faces.end(); ++i) {
+    corners.clear();
+    poly.get_vertices( *i, corners );
+    if (corners.size() != (unsigned)num_corners)
+      continue;
+    int j;
+    for (j = 0; j < num_corners; ++j) {
+      int corner = face_indices ? face_indices[j] : j;
+      if ((coords[corner] - corners.front()).length_squared() < 1e-12)
+        break;
+    if (j == num_corners)
+      continue;
+    int k;
+    for (k = 1; k < num_corners; ++k) {
+      int corner = face_indices ? face_indices[(j+k)%num_corners] : (j+k)%num_corners;
+      if ((coords[corner] - corners[k]).length_squared() > 1e-12)
+        break;
+    if (k == num_corners)
+      return *i;
+  return 0;
+  BSPTreePoly::reset_debug_ids();
+  MBCartVect corners[8];
+  get_corners( corners );
+  BSPTreePoly poly( corners );
+  CHECK( poly.is_valid() );
+  CHECK_EQUAL( (size_t)6, faces.size() );
+  CHECK( 0 != find_face( poly, corners, 4, hex_faces[0] ) );
+  CHECK( 0 != find_face( poly, corners, 4, hex_faces[1] ) );
+  CHECK( 0 != find_face( poly, corners, 4, hex_faces[2] ) );
+  CHECK( 0 != find_face( poly, corners, 4, hex_faces[3] ) );
+  CHECK( 0 != find_face( poly, corners, 4, hex_faces[4] ) );
+  CHECK( 0 != find_face( poly, corners, 4, hex_faces[5] ) );
+    // create a hexahedron
+    // check that a plane entirely above the
+    // polyhedron (coincident with one face)
+    // doesn't modify the polyhedron
+  bool r = poly.cut_polyhedron( MBCartVect(0,0,1), -2 );
+  CHECK(!r);
+    // cut in half with Z=1 plane
+  r = poly.cut_polyhedron( MBCartVect(0,0,1), -1 );
+  CHECK(r);
+  for (int i = 0; i < 8; ++i) {
+    if (fabs(corners[i][2] - 2) < 1e-6)
+      corners[i][2] = 1;
+    if (fabs(corners[i][0] - 4) < 1e-6)
+      corners[i][0] = 5;
+  poly.set( corners );
+    // cut off two corners using X=5 plane
+  r = poly.cut_polyhedron( MBCartVect(1,0,0), -5 );
+  CHECK(r);
+  faces.clear();
+  CHECK_EQUAL( (size_t)7, faces.size() );
+  MBCartVect new_vtx1( 5, 1, 1 );
+  MBCartVect new_vtx2( 5, 1, 0 );
+  MBCartVect new_vtx3( 5, 3, 0 );
+  MBCartVect new_vtx4( 5, 3, 1 );
+  MBCartVect face1[5] = { corners[0], new_vtx2, new_vtx1, corners[5], corners[4] };
+  MBCartVect face2[4] = { new_vtx1, new_vtx4, corners[6], corners[5] };
+  MBCartVect face3[5] = { new_vtx4, new_vtx3, corners[3], corners[7], corners[6] };
+  MBCartVect face5[4] = { corners[3], new_vtx3, new_vtx2, corners[0] };
+  MBCartVect face7[4] = { new_vtx1, new_vtx2, new_vtx3, new_vtx4 };
+  CHECK( 0 != find_face( poly, face1, 5 ) );
+  CHECK( 0 != find_face( poly, face2, 4 ) );
+  CHECK( 0 != find_face( poly, face3, 5 ) );
+  CHECK( 0 != find_face( poly, face5, 4 ) );
+  CHECK( 0 != find_face( poly, face7, 4 ) );
+void test_volume()
+  CHECK_REAL_EQUAL( 16.0, poly.volume(), 1e-6 );
