[MOAB-dev] r3168 - MOAB/trunk
    kraftche at cae.wisc.edu
    Fri Sep 25 10:34:25 CDT 2009
Author: kraftche
Date: 2009-09-25 10:34:25 -0500 (Fri, 25 Sep 2009)
New Revision: 3168
Added:
   MOAB/trunk/BSPTreePoly.cpp
   MOAB/trunk/BSPTreePoly.hpp
Modified:
   MOAB/trunk/MBAdaptiveKDTree.cpp
   MOAB/trunk/MBAdaptiveKDTree.hpp
   MOAB/trunk/MBBSPTree.cpp
   MOAB/trunk/MBBSPTree.hpp
   MOAB/trunk/MBGeomUtil.cpp
   MOAB/trunk/MBGeomUtil.hpp
   MOAB/trunk/Makefile.am
   MOAB/trunk/adaptive_kd_tree_tests.cpp
   MOAB/trunk/bsp_tree_test.cpp
Log:
o Add function to test for intersection between a ray and a kD-tree leaf,
  and return the points at which it enters and exits the leaf.
o Add function to test for intersection between a ray and a BSP-tree leaf,
o Add fast version of BSP-tree ray/leaf intersect for tree where all
  leaves are boxes.
o Add a class for calculating the polyhedron representing the boundary
  of a leaf of a general BSP-tree.
o Add function to calculate the volume of a leaf of a general BSP-tree
  by first calculating the bounding polyhedron.
o Add unit tests for the above
Added: MOAB/trunk/BSPTreePoly.cpp
--- MOAB/trunk/BSPTreePoly.cpp	                        (rev 0)
+++ MOAB/trunk/BSPTreePoly.cpp	2009-09-25 15:34:25 UTC (rev 3168)
@@ -0,0 +1,823 @@
+#include "MBCartVect.hpp"
+#include "BSPTreePoly.hpp"
+#include <assert.h>
+#include <stdlib.h>
+#include <set>
+#undef DEBUG_IDS
+struct BSPTreePoly::Vertex : public MBCartVect {
+  Vertex( const MBCartVect& v ) : MBCartVect(v), usePtr(0)
+#ifdef DEBUG_IDS
+  , id(nextID++)
+#endif
+  ~Vertex() { assert(!usePtr); }
+  BSPTreePoly::VertexUse* usePtr;
+  int markVal;
+#ifdef DEBUG_IDS
+  int id;
+  static int nextID;
+#endif
+struct BSPTreePoly::VertexUse {
+  VertexUse( Edge* edge, Vertex* vtx );
+  ~VertexUse();
+  void set_vertex( BSPTreePoly::Vertex* vtx_ptr );
+  BSPTreePoly::VertexUse *nextPtr, *prevPtr;
+  BSPTreePoly::Vertex* vtxPtr;
+  BSPTreePoly::Edge* edgePtr;
+struct BSPTreePoly::EdgeUse {
+  EdgeUse( Edge* edge );
+  EdgeUse( Edge* edge, Face* face );
+  ~EdgeUse();
+  BSPTreePoly::EdgeUse *prevPtr, *nextPtr;
+  BSPTreePoly::Face* facePtr;
+  inline BSPTreePoly::Vertex* start() const;
+  inline BSPTreePoly::Vertex* end() const;
+  int sense() const;
+  void insert_after( BSPTreePoly::EdgeUse* prev );
+  void insert_before( BSPTreePoly::EdgeUse* next );
+struct BSPTreePoly::Edge {
+  BSPTreePoly::VertexUse *startPtr, *endPtr;
+  BSPTreePoly::EdgeUse *forwardPtr, *reversePtr;
+#ifdef DEBUG_IDS
+  int id;
+#endif
+  Edge( Vertex* start, Vertex* end )
+    : forwardPtr(0), reversePtr(0)
+#ifdef DEBUG_IDS
+  , id(nextID++)
+#endif
+    startPtr = new VertexUse( this, start );
+    endPtr = new VertexUse( this, end );
+  ~Edge();
+  BSPTreePoly::Vertex* start() const
+    { return startPtr->vtxPtr; }
+  BSPTreePoly::Vertex* end() const
+    { return endPtr->vtxPtr; }
+  BSPTreePoly::Face* forward() const
+    { return forwardPtr ? forwardPtr->facePtr : 0; }
+  BSPTreePoly::Face* reverse() const
+    { return reversePtr ? reversePtr->facePtr : 0; }
+  BSPTreePoly::VertexUse* use( BSPTreePoly::Vertex* vtx ) const
+    { return (vtx == startPtr->vtxPtr) ? startPtr : (vtx == endPtr->vtxPtr) ? endPtr : 0; }
+  BSPTreePoly::Edge* next( BSPTreePoly::Vertex* about ) const
+    { return use(about)->nextPtr->edgePtr; }
+  BSPTreePoly::Edge* prev( BSPTreePoly::Vertex* about ) const
+    { return use(about)->prevPtr->edgePtr; }
+  BSPTreePoly::EdgeUse* use( BSPTreePoly::Face* face ) const
+    { return (face == forwardPtr->facePtr) ? forwardPtr : (face == reversePtr->facePtr) ? reversePtr : 0; }
+  BSPTreePoly::Edge* next( BSPTreePoly::Face* about ) const
+  BSPTreePoly::Edge* prev( BSPTreePoly::Face* about ) const
+  BSPTreePoly::VertexUse* other( BSPTreePoly::VertexUse* use ) const
+    { return use == startPtr ? endPtr : use == endPtr ? startPtr : 0; }
+  BSPTreePoly::EdgeUse* other( BSPTreePoly::EdgeUse* use ) const
+    { return use == forwardPtr ? reversePtr : use == reversePtr ? forwardPtr : 0; }
+  BSPTreePoly::Vertex* other( BSPTreePoly::Vertex* vtx ) const
+    { return vtx == startPtr->vtxPtr ?   endPtr->vtxPtr :
+             vtx ==   endPtr->vtxPtr ? startPtr->vtxPtr : 0; }
+  BSPTreePoly::Vertex* common( BSPTreePoly::Edge* other ) const
+    { return start() == other->start() || start() == other->end() ? start() :
+               end() == other->start() ||   end() == other->end() ?   end() : 0; }
+  int sense( BSPTreePoly::Face* face ) const;
+  void remove_from_vertex( BSPTreePoly::Vertex*& vtx_ptr );
+  void remove_from_face( BSPTreePoly::Face*& face_ptr );
+  void add_to_vertex( BSPTreePoly::Vertex* vtx_ptr );
+struct BSPTreePoly::Face {
+  Face(Face* next) : usePtr(0), nextPtr(next)
+#ifdef DEBUG_IDS
+    , id(nextID++)
+#endif
+  Face() : usePtr(0), nextPtr(0)
+#ifdef DEBUG_IDS
+    , id(nextID++)
+#endif
+  ~Face();
+  BSPTreePoly::EdgeUse* usePtr;
+  BSPTreePoly::Face* nextPtr;
+#ifdef DEBUG_IDS
+  int id;
+#endif
+  double signed_volume() const;
+#ifdef DEBUG_IDS
+int BSPTreePoly::Vertex::nextID = 1;
+int BSPTreePoly::Edge::nextID = 1;
+int BSPTreePoly::Face::nextID = 1;
+#endif
+void BSPTreePoly::reset_debug_ids() {
+#ifdef DEBUG_IDS
+  BSPTreePoly::Vertex::nextID = 1;
+  BSPTreePoly::Edge::nextID = 1;
+  BSPTreePoly::Face::nextID = 1;
+#endif
+static void merge_edges( BSPTreePoly::Edge* keep_edge,
+                         BSPTreePoly::Edge* dead_edge );
+static BSPTreePoly::Edge* split_edge( BSPTreePoly::Vertex* new_vtx,
+                                       BSPTreePoly::Edge* into_edge );
+BSPTreePoly::VertexUse::VertexUse( BSPTreePoly::Edge* edge, BSPTreePoly::Vertex* vtx )
+  : vtxPtr(vtx), edgePtr(edge)
+  if (!vtx->usePtr) {
+    vtx->usePtr = prevPtr = nextPtr = this;
+    return;
+  nextPtr = vtx->usePtr;
+  prevPtr = nextPtr->prevPtr;
+  assert( prevPtr->nextPtr == nextPtr );
+  nextPtr->prevPtr = this;
+  prevPtr->nextPtr = this;
+BSPTreePoly::VertexUse::~VertexUse()
+  if (nextPtr == this) {
+    assert(prevPtr == this);
+    assert(vtxPtr->usePtr == this);
+    vtxPtr->usePtr = 0;
+    delete vtxPtr;
+  else if (vtxPtr->usePtr == this)
+    vtxPtr->usePtr = nextPtr;
+  nextPtr->prevPtr = prevPtr;
+  prevPtr->nextPtr = nextPtr;
+  nextPtr = prevPtr = 0;
+void BSPTreePoly::VertexUse::set_vertex( BSPTreePoly::Vertex* vtx )
+  if (vtxPtr) {
+    if (nextPtr == prevPtr) {
+      assert(nextPtr == this);
+      delete vtx;
+    else {
+      if (vtxPtr->usePtr == this)
+  vtxPtr = vtx;
+  nextPtr = vtxPtr->usePtr->nextPtr;
+  prevPtr = vtxPtr->usePtr;
+  vtxPtr->usePtr->nextPtr = this;
+BSPTreePoly::EdgeUse::EdgeUse( BSPTreePoly::Edge* edge )
+  : prevPtr(0), nextPtr(0), edgePtr(edge), facePtr(0)
+BSPTreePoly::EdgeUse::EdgeUse( BSPTreePoly::Edge* edge,
+                                BSPTreePoly::Face* face )
+  : edgePtr(edge), facePtr(face)
+  assert(!face->usePtr);
+  face->usePtr = prevPtr = nextPtr = this;
+  if (!face->usePtr) {
+    return;
+  nextPtr = face->usePtr;
+void BSPTreePoly::EdgeUse::insert_after( BSPTreePoly::EdgeUse* prev )
+    // shouldn't aready be in a face
+  assert(!facePtr);
+    // adjacent edges should share vertices
+  assert( start() == prev->end() );
+  facePtr = prev->facePtr;
+  nextPtr = prev->nextPtr;
+  prevPtr = prev;
+void BSPTreePoly::EdgeUse::insert_before( BSPTreePoly::EdgeUse* next )
+  assert(!facePtr);
+  assert( end() == next->start() );
+  facePtr = next->facePtr;
+  prevPtr = next->prevPtr;
+  nextPtr = next;
+BSPTreePoly::EdgeUse::~EdgeUse()
+  if (facePtr->usePtr == this)
+    facePtr->usePtr = (nextPtr == this) ? 0 : nextPtr;
+  if (edgePtr->forwardPtr == this)
+    edgePtr->forwardPtr = 0;
+  if (edgePtr->reversePtr == this)
+    edgePtr->reversePtr = 0;
+  if (!edgePtr->forwardPtr && !edgePtr->reversePtr)
+    delete edgePtr;
+int BSPTreePoly::EdgeUse::sense() const
+    return 1;
+  else if (edgePtr->reversePtr == this)
+    return -1;
+  else
+    return 0;
+BSPTreePoly::Vertex* BSPTreePoly::EdgeUse::start() const
+    return edgePtr->start();
+    return edgePtr->end();
+  else
+    return 0;
+BSPTreePoly::Vertex* BSPTreePoly::EdgeUse::end() const
+  else
+    return 0;
+BSPTreePoly::Edge::~Edge()
+  delete startPtr;
+  delete endPtr;
+  delete forwardPtr;
+  delete reversePtr;
+int BSPTreePoly::Edge::sense( BSPTreePoly::Face* face ) const
+  if (forwardPtr && forwardPtr->facePtr == face)
+    return 1;
+  else if (reversePtr && reversePtr->facePtr == face)
+    return -1;
+  else
+    return 0;
+BSPTreePoly::Face::~Face()
+  while (usePtr)
+    delete usePtr;
+void BSPTreePoly::clear() {
+  while (faceList) {
+    Face* face = faceList;
+    faceList = faceList->nextPtr;
+    delete face;
+MBErrorCode BSPTreePoly::set( const MBCartVect hex_corners[8] )
+  clear();
+  Vertex* vertices[8];
+  for (int i = 0; i < 8; ++i)
+    vertices[i] = new Vertex(hex_corners[i]);
+  Edge* edges[12];
+#ifdef DEBUG_IDS
+  int start_id = Edge::nextID;
+#endif
+  for (int i = 0; i < 4; ++i) {
+    int j= (i+1)%4;
+    edges[i  ] = new Edge( vertices[i  ], vertices[j  ] );
+    edges[i+4] = new Edge( vertices[i  ], vertices[i+4] );
+    edges[i+8] = new Edge( vertices[i+4], vertices[j+4] );
+#ifdef DEBUG_IDS
+  for (int i = 0; i < 12; ++i)
+    edges[i]->id = start_id++;
+#endif
+  static const int face_conn[6][4] = { {  0,  5,  -8, -4 },
+                                       {  1,  6,  -9, -5 },
+                                       {  2,  7, -10, -6 },
+                                       {  3,  4, -11, -7 },
+                                       { -3, -2,  -1,-12 },
+                                       {  8,  9,  10, 11 } };
+  for (int i = 0; i < 6; ++i) {
+    faceList = new Face(faceList);
+    EdgeUse* prev = 0;
+    for (int j = 0; j < 4; ++j) {
+      int e = face_conn[i][j];
+      if (e < 0) {
+        e = (-e) % 12;
+        assert(!edges[e]->reversePtr);
+        if (!prev) {
+          edges[e]->reversePtr = new EdgeUse( edges[e], faceList );
+        else {
+          edges[e]->reversePtr = new EdgeUse( edges[e] );
+          edges[e]->reversePtr->insert_after( prev );
+        prev = edges[e]->reversePtr;
+      else {
+        assert(!edges[e]->forwardPtr);
+        if (!prev) {
+          edges[e]->forwardPtr = new EdgeUse( edges[e], faceList );
+        else {
+          edges[e]->forwardPtr = new EdgeUse( edges[e] );
+          edges[e]->forwardPtr->insert_after( prev );
+        prev = edges[e]->forwardPtr;
+  return MB_SUCCESS;
+void BSPTreePoly::get_faces( std::vector<const Face*>& face_list ) const
+  face_list.clear();
+  for (Face* face = faceList; face; face = face->nextPtr)
+    face_list.push_back( face );
+void BSPTreePoly::get_vertices( const Face* face,
+                                 std::vector<MBCartVect>& vertices ) const
+  vertices.clear();
+  if (!face || !face->usePtr)
+    return;
+  EdgeUse* coedge = face->usePtr;
+  do {
+    vertices.push_back( *coedge->end() );
+    coedge = coedge->nextPtr;
+  } while (coedge != face->usePtr);
+double BSPTreePoly::Face::signed_volume() const
+  MBCartVect sum(0.0);
+  const MBCartVect* base = usePtr->start();
+  MBCartVect d1 = (*usePtr->end() - *base);
+  for (EdgeUse* coedge = usePtr->nextPtr; coedge != usePtr; coedge = coedge->nextPtr) {
+    MBCartVect d2 = (*coedge->end() - *base);
+    sum += d1 * d2;
+    d1 = d2;
+  return (1.0/6.0) * (sum % *base);
+double BSPTreePoly::volume() const
+  double result = 0;
+  for (Face* ptr = faceList; ptr; ptr = ptr->nextPtr)
+    result += ptr->signed_volume();
+  return result;
+void BSPTreePoly::set_vertex_marks( int value )
+  for (Face* face = faceList; face; face = face->nextPtr) {
+    EdgeUse* edge = face->usePtr;
+    do {
+      edge->edgePtr->start()->markVal = value;
+      edge->edgePtr->end()->markVal = value;
+      edge = edge->nextPtr;
+    } while (edge && edge != face->usePtr);
+  // edges must share a vertex
+  BSPTreePoly::Vertex* dead_vtx = keep_edge->common(dead_edge);
+  assert(dead_vtx);
+   // vertex may have only two adjacent edges
+  BSPTreePoly::VertexUse* dead_vtxuse = dead_edge->use(dead_vtx);
+  assert(dead_vtxuse);
+  BSPTreePoly::VertexUse* keep_vtxuse = dead_vtxuse->nextPtr;
+  assert(keep_vtxuse);
+  assert(keep_vtxuse->edgePtr == keep_edge);
+  assert(keep_vtxuse->nextPtr == dead_vtxuse);
+  assert(keep_vtxuse->prevPtr == dead_vtxuse);
+  assert(dead_vtxuse->prevPtr == keep_vtxuse);
+  // kept edge now ends with the kept vertex on the dead edge
+  keep_vtxuse->set_vertex( dead_edge->other(dead_vtx) );
+  // destructors should take care of everything else
+  // (including removing dead edge from face loops)
+  delete dead_edge;
+    // split edge, creating new edge
+  BSPTreePoly::Edge* new_edge = new BSPTreePoly::Edge( new_vtx, into_edge->end() );
+  into_edge->endPtr->set_vertex( new_vtx );
+    // update coedge loops in faces
+  if (into_edge->forwardPtr) {
+    new_edge->forwardPtr = new BSPTreePoly::EdgeUse( new_edge );
+    new_edge->forwardPtr->insert_after( into_edge->forwardPtr );
+  if (into_edge->reversePtr) {
+    new_edge->reversePtr = new BSPTreePoly::EdgeUse( new_edge );
+    new_edge->reversePtr->insert_before( into_edge->reversePtr );
+  return new_edge;
+static BSPTreePoly::Face* split_face( BSPTreePoly::EdgeUse* start,
+                                       BSPTreePoly::EdgeUse* end )
+  BSPTreePoly::Face* face = start->facePtr;
+  assert(face == end->facePtr);
+  BSPTreePoly::Face* new_face = new BSPTreePoly::Face;
+  BSPTreePoly::EdgeUse* keep_start = start->prevPtr;
+  BSPTreePoly::EdgeUse* keep_end = end->nextPtr;
+  for (BSPTreePoly::EdgeUse* ptr = start; ptr != keep_end; ptr = ptr->nextPtr) {
+    if (face->usePtr == ptr)
+      face->usePtr = keep_start;
+    ptr->facePtr = new_face;
+  new_face->usePtr = start;
+  BSPTreePoly::Edge* edge = new BSPTreePoly::Edge( start->start(), end->end() );
+  edge->forwardPtr = new BSPTreePoly::EdgeUse( edge );
+  edge->reversePtr = new BSPTreePoly::EdgeUse( edge );
+  edge->forwardPtr->facePtr = face;
+  edge->forwardPtr->prevPtr = keep_start;
+  keep_start->nextPtr = edge->forwardPtr;
+  edge->forwardPtr->nextPtr = keep_end;
+  keep_end->prevPtr = edge->forwardPtr;
+  edge->reversePtr->facePtr = new_face;
+  edge->reversePtr->nextPtr = start;
+  start->prevPtr = edge->reversePtr;
+  edge->reversePtr->prevPtr = end;
+  end->nextPtr = edge->reversePtr;
+  return new_face;
+bool BSPTreePoly::cut_polyhedron( const MBCartVect& plane_normal,
+                                   double plane_coeff )
+  const double EPSILON = 1e-6; // points this close are considered coincident
+    // scale epsilon rather than normalizing normal vector
+  const double epsilon = EPSILON * (plane_normal % plane_normal);
+    // Classify all points above/below plane and destroy any faces
+    // that have no vertices below the plane.
+  const int UNKNOWN = 0;
+  const int ABOVE = 1;
+  const int ON = 2;
+  const int BELOW = 3;
+  int num_above = 0;
+  set_vertex_marks( UNKNOWN );
+    // split any edge that intersect the plane.
+    do {
+      Vertex* start = edge->edgePtr->start();
+      Vertex* end = edge->edgePtr->end();
+      if (!start->markVal) {
+        double d = plane_normal % *start + plane_coeff;
+        if (d*d <= epsilon)
+          start->markVal = ON;
+        else if (d < 0.0)
+          start->markVal = BELOW;
+        else {
+          start->markVal = ABOVE;
+          ++num_above;
+      if (!end->markVal) {
+        double d = plane_normal % *end + plane_coeff;
+          end->markVal = ON;
+        else if (d < 0.0)
+          end->markVal = BELOW;
+        else {
+          end->markVal = ABOVE;
+          ++num_above;
+      if ((end->markVal == ABOVE && start->markVal == BELOW) ||
+          (end->markVal == BELOW && start->markVal == ABOVE)) {
+        MBCartVect dir = *end - *start;
+        double t = -(plane_normal % *start + plane_coeff) / (dir % plane_normal);
+        Vertex* new_vtx = new Vertex( *start + t*dir );
+        new_vtx->markVal = ON;
+        split_edge( new_vtx, edge->edgePtr );
+        end = new_vtx;
+  if (!num_above)
+    return false;
+    // Split faces
+    EdgeUse *split_start = 0, *split_end = 0, *other_split = 0;
+    do {
+      if (edge->end()->markVal == ON && edge->start()->markVal != ON) {
+        if (!split_start)
+          split_start = edge->nextPtr;
+        else if (!split_end)
+          split_end = edge;
+        else
+          other_split = edge;
+      // If two vertices are on plane (but not every vertex)
+      // then split the face
+    if (split_end && !other_split) {
+      assert(split_start);
+      Face* new_face = split_face( split_start, split_end );
+      new_face->nextPtr = faceList;
+      faceList = new_face;
+    // Destroy all faces that are above the plane
+  Face** lptr = &faceList;
+  while (*lptr) {
+    EdgeUse* edge = (*lptr)->usePtr;
+    bool some_above = false;
+    do {
+      if (edge->start()->markVal == ABOVE) {
+        some_above = true;
+        break;
+    } while (edge && edge != (*lptr)->usePtr);
+    if (some_above) {
+      Face* dead = *lptr;
+      *lptr = (*lptr)->nextPtr;
+      delete dead;
+    else {
+      lptr = &((*lptr)->nextPtr);
+    // Construct a new face in the cut plane
+    // First find an edge to start at
+  Edge* edge_ptr = 0;
+  for (Face* face = faceList; face && !edge_ptr; face = face->nextPtr) {
+    EdgeUse* co_edge = face->usePtr;
+    do {
+      if (0 == co_edge->edgePtr->other(co_edge)) {
+        edge_ptr = co_edge->edgePtr;
+        break;
+      co_edge = co_edge->nextPtr;
+    } while (co_edge && co_edge != face->usePtr);
+    // Constuct new face and first CoEdge
+  faceList = new Face( faceList );
+  Vertex *next_vtx, *start_vtx;
+  EdgeUse* prev_coedge;
+  if (edge_ptr->forwardPtr) {
+    next_vtx = edge_ptr->start();
+    start_vtx = edge_ptr->end();
+    assert(!edge_ptr->reversePtr);
+    prev_coedge = edge_ptr->reversePtr = new EdgeUse( edge_ptr, faceList );
+  else {
+    next_vtx = edge_ptr->end();
+    start_vtx = edge_ptr->start();
+    prev_coedge = edge_ptr->forwardPtr = new EdgeUse( edge_ptr, faceList );
+    // Construct coedges until loop is closed
+  while (next_vtx != start_vtx) {
+      // find next edge adjacent to vertex with only one adjacent face
+    VertexUse* this_use = edge_ptr->use( next_vtx );
+    VertexUse* use = this_use->nextPtr;
+    while (use != this_use) {
+      if (use->edgePtr->forwardPtr == 0) {
+        edge_ptr = use->edgePtr;
+        assert(edge_ptr->start() == next_vtx);
+        edge_ptr->forwardPtr = new EdgeUse( edge_ptr );
+        edge_ptr->forwardPtr->insert_after( prev_coedge );
+        prev_coedge = edge_ptr->forwardPtr;
+        break;
+      else if (use->edgePtr->reversePtr == 0) {
+        assert(edge_ptr->end() == next_vtx);
+        edge_ptr->reversePtr = new EdgeUse( edge_ptr );
+        edge_ptr->reversePtr->insert_after( prev_coedge );
+        prev_coedge = edge_ptr->reversePtr;
+        break;
+      use = use->nextPtr;
+      assert( use != this_use ); // failed to close loop!
+  return true;
+bool BSPTreePoly::is_valid() const
+  std::set<Face*> list_faces;
+  int i = 0;
+  for (Face* ptr = faceList; ptr; ptr = ptr->nextPtr) {
+    if (++i > 10000)
+      return false;
+    if (!list_faces.insert(ptr).second)
+      return false;
+  std::set<Vertex*> vertices;
+    i = 0;
+    do {
+      if (++i > 10000)
+        return false;
+      if (coedge->facePtr != face)
+        return false;
+      Edge* edge = coedge->edgePtr;
+      if (!edge->startPtr || !edge->endPtr)
+        return false;
+      vertices.insert( edge->start() );
+      vertices.insert( edge->end() );
+      EdgeUse* other;
+      if (edge->forwardPtr == coedge)
+        other = edge->reversePtr;
+      else if (edge->reversePtr != coedge)
+        return false;
+      else
+        other = edge->forwardPtr;
+      if (!other)
+        return false;
+      if (list_faces.find( other->facePtr ) == list_faces.end())
+        return false;
+      EdgeUse* next = coedge->nextPtr;
+      if (next->prevPtr != coedge)
+        return false;
+      if (coedge->end() != next->start())
+        return false;
+      coedge = next;
+  for (std::set<Vertex*>::iterator j = vertices.begin(); j != vertices.end(); ++j) {
+    Vertex* vtx = *j;
+    i = 0;
+    VertexUse* use = vtx->usePtr;
+    do {
+      if (++i > 10000)
+        return false;
+      if (use->vtxPtr != vtx)
+        return false;
+      Edge* edge = use->edgePtr;
+      if (!edge)
+        return false;
+      if (edge->startPtr != use && edge->endPtr != use)
+        return false;
+      VertexUse* next = use->nextPtr;
+      if (next->prevPtr != use)
+        return false;
+      use = next;
+    } while (use != vtx->usePtr);
+  return true;
+bool BSPTreePoly::is_point_contained( const MBCartVect& point ) const
+  if (!faceList) // empty (zero-dimension) polyhedron
+    return false;
+    // Test that point is below the plane of each face
+    // NOTE: This will NOT work for polyhedra w/ concavities
+    Vertex *pt1, *pt2, *pt3;
+    pt1 = face->usePtr->start();
+    pt2 = face->usePtr->end();
+    pt3 = face->usePtr->nextPtr->end();
+    if (pt3 == pt1) // degenerate
+      continue;
+    MBCartVect norm = (*pt3 - *pt2) * (*pt1 - *pt2);
+    double coeff = -(norm % *pt2);
+    if (norm % point > -coeff) // if above plane
+      return false;
+  return true;
Added: MOAB/trunk/BSPTreePoly.hpp
--- MOAB/trunk/BSPTreePoly.hpp	                        (rev 0)
+++ MOAB/trunk/BSPTreePoly.hpp	2009-09-25 15:34:25 UTC (rev 3168)
@@ -0,0 +1,75 @@
+#ifndef MB_BSP_TREE_POLY_HPP
+#define MB_BSP_TREE_POLY_HPP
+#include "MBTypes.h"
+#include <vector>
+class MBCartVect;
+/**\brief Convex polyhedron
+ * This class is used to represent the convex polyhedron that bounds
+ * a node in a general plane-based BSP-tree.
+class BSPTreePoly
+  public:
+    struct Vertex;
+    struct VertexUse;
+    struct Edge;
+    struct EdgeUse;
+    struct Face;
+  private:
+    Face* faceList;
+    void set_vertex_marks( int value );
+    BSPTreePoly( const BSPTreePoly& copy ); // not implemented
+    BSPTreePoly& operator=( const BSPTreePoly& copy ); // not implemented
+  public:
+      /**\brief Initialize as a planar-faced hexahedron
+       *\param hex_corners Corner coordinates for a hexahedron, in Exodus/Patran order
+    BSPTreePoly( const MBCartVect hex_corners[8] ) : faceList(0) { set(hex_corners); }
+    BSPTreePoly( ) : faceList(0) { }
+    ~BSPTreePoly() { clear(); }
+    MBErrorCode set( const MBCartVect hex_corners[8] );
+    void clear();
+      /**\brief Get handles for faces */
+    void get_faces( std::vector<const Face*>& face_list ) const;
+      /**\brief Get corner coordinates for a face */
+    void get_vertices( const Face* face,
+                       std::vector<MBCartVect>& vertices ) const;
+      /** Intersect a plane with a polyhedron, retaining
+       * the portion of the polyhedron below the plane.
+       * This will fail if polyhedron is not convex.
+    bool cut_polyhedron( const MBCartVect& plane_normal,
+                         double plane_coeff );
+      /** Test if a point is contained in the polyhedron.
+       *\NOTE algorithm assumes *convex* polyhedron.
+    bool is_point_contained( const MBCartVect& point ) const;
+      //! Assumes planar faces
+    double volume() const;
+      // Check that data structure is consistent and represents
+      // a closed polyhedron
+    bool is_valid() const;
+      /** For debugging, does nothing unless debug feature is enabled */
+    static void reset_debug_ids();
+#endif
Modified: MOAB/trunk/MBAdaptiveKDTree.cpp
--- MOAB/trunk/MBAdaptiveKDTree.cpp	2009-09-25 15:29:09 UTC (rev 3167)
+++ MOAB/trunk/MBAdaptiveKDTree.cpp	2009-09-25 15:34:25 UTC (rev 3168)
@@ -752,6 +752,18 @@
   return childVect[0] == handle();
+bool MBAdaptiveKDTreeIter::intersect_ray( const double ray_point[3],
+                                          const double ray_vect[3],
+                                          double& t_enter,
+                                          double& t_exit ) const
+  return MBGeomUtil::ray_box_intersect( MBCartVect(box_min()),
+                                        MBCartVect(box_max()),
+                                        MBCartVect(ray_point),
+                                        MBCartVect(ray_vect),
+                                        t_enter, t_exit );
 static MBErrorCode intersect_children_with_elems(
                                         MBAdaptiveKDTree* tool,
                                         const MBRange& elems,
Modified: MOAB/trunk/MBAdaptiveKDTree.hpp
--- MOAB/trunk/MBAdaptiveKDTree.hpp	2009-09-25 15:29:09 UTC (rev 3167)
+++ MOAB/trunk/MBAdaptiveKDTree.hpp	2009-09-25 15:34:25 UTC (rev 3168)
@@ -393,6 +393,25 @@
     //! if current node is root or back() will move to the
     //! immediate sibling.
   bool sibling_is_forward( ) const;
+    //! Find range of overlap between ray and leaf.
+    //!\param ray_point Coordinates of start point of ray
+    //!\param ray_vect  Directionion vector for ray such that
+    //!                 the ray is defined by r(t) = ray_point + t * ray_vect
+    //!                 for t > 0.
+    //!\param t_enter   Output: if return value is true, this value
+    //!                 is the parameter location along the ray at which
+    //!                 the ray entered the leaf.  If return value is false,
+    //!                 then this value is undefined.
+    //!\param t_exit    Output: if return value is true, this value
+    //!                 the ray exited the leaf.  If return value is false,
+    //!\return true if ray intersects leaf, false otherwise.
+  bool intersect_ray( const double ray_point[3],
+                      double& t_enter, double& t_exit ) const;
 #endif
Modified: MOAB/trunk/MBBSPTree.cpp
--- MOAB/trunk/MBBSPTree.cpp	2009-09-25 15:29:09 UTC (rev 3167)
+++ MOAB/trunk/MBBSPTree.cpp	2009-09-25 15:34:25 UTC (rev 3168)
@@ -22,6 +22,7 @@
 #include "MBGeomUtil.hpp"
 #include "MBRange.hpp"
 #include "MBInternals.hpp"
 #include <assert.h>
 #include <algorithm>
@@ -188,6 +189,12 @@
   return moab()->tag_get_data( rootTag, &root_handle, 1, corners );
+MBErrorCode MBBSPTree::get_tree_box( MBEntityHandle root_handle,
+                                     double corners[24] )
+  return moab()->tag_get_data( rootTag, &root_handle, 1, corners );
 MBErrorCode MBBSPTree::create_tree( MBEntityHandle& root_handle )
   const double min[3] = { -HUGE_VAL, -HUGE_VAL, -HUGE_VAL };
@@ -507,6 +514,13 @@
   return tool()->get_split_plane( parent, plane );
+double MBBSPTreeIter::volume() const
+  BSPTreePoly polyhedron;
+  MBErrorCode rval = calculate_polyhedron( polyhedron );
+  return MB_SUCCESS == rval ? polyhedron.volume() : -1.0;
 bool MBBSPTreeIter::is_sibling( const MBBSPTreeIter& other_leaf ) const
   const size_t s = mStack.size();
@@ -543,6 +557,46 @@
+MBErrorCode MBBSPTreeIter::calculate_polyhedron( BSPTreePoly& poly_out ) const
+  MBErrorCode rval;
+  assert( sizeof(MBCartVect) == 3*sizeof(double) );
+  MBCartVect corners[8];
+  rval = treeTool->get_tree_box( mStack.front(), corners[0].array() );
+  if (MB_SUCCESS != rval)
+    return rval;
+  rval = poly_out.set( corners );
+    return rval;
+  MBBSPTree::Plane plane;
+  std::vector<MBEntityHandle>::const_iterator i = mStack.begin();
+  std::vector<MBEntityHandle>::const_iterator here = mStack.end() - 1;
+  while (i != here) {
+    rval = treeTool->get_split_plane( *i, plane );
+      return rval;
+    childVect.clear();
+    rval = treeTool->moab()->get_child_meshsets( *i, childVect );
+      return rval;
+    if (childVect.size() != 2)
+      return MB_FAILURE;
+    ++i;
+    if (childVect[1] == *i)
+      plane.flip();
+    MBCartVect norm( plane.norm );
+    poly_out.cut_polyhedron( norm, plane.coeff );
 MBErrorCode MBBSPTreeBoxIter::initialize( MBBSPTree* tool_ptr,
                                           MBEntityHandle root,
                                           const double* point )
@@ -1154,6 +1208,11 @@
   return MB_SUCCESS;
+MBErrorCode MBBSPTreeBoxIter::calculate_polyhedron( BSPTreePoly& poly_out ) const
+  return poly_out.set( reinterpret_cast<const MBCartVect*>(leafCoords) );
 MBErrorCode MBBSPTree::leaf_containing_point( MBEntityHandle tree_root,
                                               const double point[3],
                                               MBEntityHandle& leaf_out )
@@ -1205,3 +1264,187 @@
       return rval;
+template <typename PlaneIter> static inline
+bool ray_intersect_halfspaces( const MBCartVect& ray_pt,
+                               const MBCartVect& ray_dir,
+                               const PlaneIter& begin,
+                               const PlaneIter& end,
+                               double& t_enter,
+                               double& t_exit )
+  const double epsilon = 1e-12;
+    // begin with inifinite ray
+  t_enter = 0.0;
+  t_exit  = std::numeric_limits<double>::infinity();
+    // cut ray such that we keep only the portion contained
+    // in each halfspace
+  for (PlaneIter i = begin; i != end; ++i) {
+    MBCartVect norm( i->norm );
+    double coeff = i->coeff;
+    double den = norm % ray_dir;
+    if (fabs(den) < epsilon) { // ray is parallel to plane
+      if (i->above( ray_pt.array() ))
+        return false; // ray entirely outside half-space
+    else {
+      double t_xsect = (-coeff - (norm % ray_pt)) / den;
+        // keep portion of ray/segment below plane
+      if (den > 0) {
+        if (t_xsect < t_exit)
+          t_exit = t_xsect;
+      else {
+        if (t_xsect > t_enter)
+          t_enter = t_xsect;
+  return t_exit >= t_enter;
+class BoxPlaneIter {
+      int faceNum;
+      MBBSPTree::Plane facePlanes[6];
+  public:
+    BoxPlaneIter( const double coords[8][3] );
+    BoxPlaneIter( ) : faceNum(6) {} // initialize to 'end'
+    const MBBSPTree::Plane* operator->() const
+      { return facePlanes + faceNum; }
+    bool operator==( const BoxPlaneIter& other ) const
+      { return faceNum == other.faceNum; }
+    bool operator!=( const BoxPlaneIter& other ) const
+      { return faceNum != other.faceNum; }
+    BoxPlaneIter& operator++()
+      { ++faceNum; return *this; }
+static const int box_face_corners[6][4] = { { 0, 1, 5, 4 },
+                                            { 1, 2, 6, 5 },
+                                            { 2, 3, 7, 6 },
+                                            { 3, 0, 4, 7 },
+                                            { 3, 2, 1, 0 },
+                                            { 4, 5, 6, 7 } };
+BoxPlaneIter::BoxPlaneIter( const double coords[8][3] )
+  : faceNum(0)
+    // NOTE:  In the case of a BSP tree, all sides of the
+    //        leaf will planar.
+  assert( sizeof(MBCartVect) == sizeof(coords[0]) );
+  const MBCartVect* corners = reinterpret_cast<const MBCartVect*>(coords);
+    const int* indices = box_face_corners[i];
+    MBCartVect v1 = corners[indices[1]] - corners[indices[0]];
+    MBCartVect v2 = corners[indices[3]] - corners[indices[0]];
+    MBCartVect n = v1 * v2;
+    facePlanes[i] = MBBSPTree::Plane( n.array(), -(n % corners[indices[2]]) );
+bool MBBSPTreeBoxIter::intersect_ray( const double ray_point[3],
+  BoxPlaneIter iter( this->leafCoords ), end;
+  return ray_intersect_halfspaces( MBCartVect(ray_point),
+                                   iter, end,
+class BSPTreePlaneIter {
+    MBBSPTree* toolPtr;
+    const MBEntityHandle* const pathToRoot;
+    int pathPos;
+    MBBSPTree::Plane tmpPlane;
+    std::vector<MBEntityHandle> tmpChildren;
+  public:
+    BSPTreePlaneIter( MBBSPTree* tool, const MBEntityHandle* path, int path_len )
+      : toolPtr(tool), pathToRoot(path), pathPos(path_len-1)
+      { operator++(); }
+    BSPTreePlaneIter() // initialize to 'end'
+      : toolPtr(0), pathToRoot(0), pathPos(-1) {}
+      { return &tmpPlane; }
+    bool operator==( const BSPTreePlaneIter& other ) const
+      { return pathPos == other.pathPos; }
+    bool operator!=( const BSPTreePlaneIter& other ) const
+      { return pathPos != other.pathPos; }
+    BSPTreePlaneIter& operator++();
+BSPTreePlaneIter& BSPTreePlaneIter::operator++()
+  if (--pathPos < 0)
+    return *this;
+  MBEntityHandle prev = pathToRoot[pathPos+1];
+  MBEntityHandle curr = pathToRoot[pathPos];
+  MBErrorCode rval = toolPtr->get_split_plane( curr, tmpPlane );
+  if (MB_SUCCESS != rval) {
+    assert(false);
+    pathPos = 0;
+    return *this;
+  tmpChildren.clear();
+  rval = toolPtr->moab()->get_child_meshsets( curr, tmpChildren );
+  if (MB_SUCCESS != rval || tmpChildren.size() != 2) {
+    assert(false);
+    pathPos = 0;
+    return *this;
+  if (tmpChildren[1] == prev)
+    tmpPlane.flip();
+  return *this;
+bool MBBSPTreeIter::intersect_ray( const double ray_point[3],
+    // intersect with half-spaces defining tree
+  BSPTreePlaneIter iter1( tool(), &mStack[0], mStack.size() ), end1;
+  if (!ray_intersect_halfspaces( MBCartVect(ray_point),
+                                 iter1, end1,
+                                 t_enter, t_exit ))
+    return false;
+    // itersect with box bounding entire tree
+  double corners[8][3];
+  MBErrorCode rval = tool()->get_tree_box( mStack.front(), corners );
+    assert(false);
+    return false;
+  BoxPlaneIter iter2( corners ), end2;
+  double t2_enter, t2_exit;
+                                 iter2, end2,
+                                 t2_enter, t2_exit ))
+    return false;
+    // if intersect both box and halfspaces, check that
+    // two intersections overlap
+  if (t_enter < t2_enter)
+    t_enter = t2_enter;
+  if (t_exit > t2_exit)
+    t_exit = t2_exit;
+  return t_enter <= t_exit;
Modified: MOAB/trunk/MBBSPTree.hpp
--- MOAB/trunk/MBBSPTree.hpp	2009-09-25 15:29:09 UTC (rev 3167)
+++ MOAB/trunk/MBBSPTree.hpp	2009-09-25 15:34:25 UTC (rev 3168)
@@ -31,6 +31,7 @@
 class MBBSPTreeBoxIter;
 class MBBSPTreeIter;
 class MBRange;
+class BSPTreePoly;
 class MBBSPTree
@@ -134,6 +135,10 @@
   MBErrorCode get_tree_box( MBEntityHandle root_node,
                             double corner_coords[8][3] );
+  //! Get bounding box for entire tree
+  MBErrorCode get_tree_box( MBEntityHandle root_node,
+                            double corner_coords[24] );
   //! Set bounding box for entire tree
   MBErrorCode set_tree_box( MBEntityHandle root_node,
                             const double box_min[3],
@@ -281,6 +286,28 @@
     //! Get split plane that separates this node from its immediate sibling.
   MBErrorCode get_parent_split_plane( MBBSPTree::Plane& plane ) const;
+    //! Get volume of leaf polyhedron
+  virtual double volume() const;
+    //!                 for t > 0.
+  virtual bool intersect_ray( const double ray_point[3],
     //! Return true if thos node and the passed node share the
     //! same immediate parent.
   bool is_sibling( const MBBSPTreeIter& other_leaf ) const;
@@ -294,6 +321,9 @@
+    //! Calculate the convex polyhedron bounding this leaf.
+  virtual MBErrorCode calculate_polyhedron( BSPTreePoly& polyhedron_out ) const;
 class MBBSPTreeBoxIter : public MBBSPTreeIter
@@ -370,6 +400,25 @@
     //! test if a plane intersects the leaf box
   bool intersects( const MBBSPTree::Plane& plane ) const;
+    //!                 for t > 0.
     //! Return the side of the box bounding this tree node
     //! that is shared with the immediately adjacent sibling
     //! (the tree node that shares a common parent node with
@@ -396,6 +445,9 @@
   MBErrorCode get_neighbors( SideBits side,
                              std::vector<MBBSPTreeBoxIter>& results,
                              double epsilon = 0.0 ) const;
+  MBErrorCode calculate_polyhedron( BSPTreePoly& polyhedron_out ) const;
 #endif
Modified: MOAB/trunk/MBGeomUtil.cpp
--- MOAB/trunk/MBGeomUtil.cpp	2009-09-25 15:29:09 UTC (rev 3167)
+++ MOAB/trunk/MBGeomUtil.cpp	2009-09-25 15:34:25 UTC (rev 3168)
@@ -156,6 +156,59 @@
   return true;
+bool ray_box_intersect( const MBCartVect& box_min,
+                        const MBCartVect& box_max,
+                        const MBCartVect& ray_pt,
+  double t1, t2;
+  // Use 'slabs' method from 13.6.1 of Akenine-Moller
+  t_enter = 0.0;
+  // Intersect with each pair of axis-aligned planes bounding
+  // opposite faces of the leaf box
+  bool ray_is_valid = false; // is ray direction vector zero?
+  for (int axis = 0; axis < 3; ++axis) {
+    if (fabs(ray_dir[axis]) < epsilon) { // ray parallel to planes
+      if (ray_pt[axis] >= box_min[axis] &&
+          ray_pt[axis] <= box_max[axis])
+        continue;
+      else
+        return false;
+      // find t values at which ray intersects each plane
+    ray_is_valid = true;
+    t1 = (box_min[axis] - ray_pt[axis]) / ray_dir[axis];
+    t2 = (box_max[axis] - ray_pt[axis]) / ray_dir[axis];
+      // t_enter = max( t_enter_x, t_enter_y, t_enter_z )
+      // t_exit  = min( t_exit_x, t_exit_y, t_exit_z )
+      //   where
+      // t_enter_x = min( t1_x, t2_x );
+      // t_exit_x  = max( t1_x, t2_x )
+    if (t1 < t2) {
+      if (t_enter < t1)
+        t_enter = t1;
+      if (t_exit > t2)
+        t_exit = t2;
+    else {
+      if (t_enter < t2)
+        t_enter = t2;
+      if (t_exit > t1)
+        t_exit = t1;
+  return ray_is_valid && (t_enter <= t_exit);
 bool box_plane_overlap( const MBCartVect& normal,
                         double d,
                         MBCartVect min,
Modified: MOAB/trunk/MBGeomUtil.hpp
--- MOAB/trunk/MBGeomUtil.hpp	2009-09-25 15:29:09 UTC (rev 3167)
+++ MOAB/trunk/MBGeomUtil.hpp	2009-09-25 15:34:25 UTC (rev 3168)
@@ -75,6 +75,30 @@
                         double& t_out,
                         const double* ray_length = 0 );
+    //! Find range of overlap between ray and axis-aligned box.
+    //!\param box_min   Box corner with minimum coordinate values
+    //!\param box_max   Box corner with minimum coordinate values
+    //!\param ray_pt    Coordinates of start point of ray
+    //!\param ray_dir   Directionion vector for ray such that
+    //!                 for t > 0.
+                        double& t_enter, double& t_exit );
 /**\brief Test if plane intersects axis-aligned box
  * Test for intersection between an unbounded plane and
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am	2009-09-25 15:29:09 UTC (rev 3167)
+++ MOAB/trunk/Makefile.am	2009-09-25 15:34:25 UTC (rev 3168)
@@ -39,7 +39,8 @@
 	mesh_set_test \
 	cub_file_test \
 	exodus_test \
-        mbcn_test
+        mbcn_test \
+        bsp_tree_poly_test
 #                 merge_test \         # input files no longer exist?
 #                 test_tag_server \    # fails
@@ -146,6 +147,7 @@
   MBMeshSet.hpp \
   MBOrientedBox.cpp \
   MBOrientedBoxTreeTool.cpp \
+  BSPTreePoly.cpp \
   MBRange.cpp \
   MBRangeSeqIntersectIter.cpp \
   MBRangeSeqIntersectIter.hpp \
@@ -258,6 +260,7 @@
   MBOrientedBox.hpp \
   MBOrientedBoxTreeTool.hpp \
   MBParallelConventions.h \
+  BSPTreePoly.hpp \
   MBRange.hpp \
   MBReadUtilIface.hpp \
   MBReaderIface.hpp \
@@ -368,6 +371,8 @@
 mbcn_test_CPPFLAGS = -DSRCDIR=$(srcdir)  # define anything to work around build issue
 mbcn_test_LDADD =
+bsp_tree_poly_test_SOURCES = bsp_tree_poly_test.cpp
 # Other files to clean up (e.g. output from tests)
 DISTCLEANFILES = MBCN_FCDefs.h
 MOSTLYCLEANFILES = dumped_acis.sat tree.h5m
Modified: MOAB/trunk/adaptive_kd_tree_tests.cpp
--- MOAB/trunk/adaptive_kd_tree_tests.cpp	2009-09-25 15:29:09 UTC (rev 3167)
+++ MOAB/trunk/adaptive_kd_tree_tests.cpp	2009-09-25 15:34:25 UTC (rev 3168)
@@ -1216,6 +1216,77 @@
   CHECK( !iter.intersects( z6 ) );
+#define CHECK_RAY_XSECTS( PT, DIR, T_IN, T_OUT ) do { \
+  CHECK(iter.intersect_ray( (PT), (DIR), t_in, t_out )); \
+  CHECK_REAL_EQUAL( (T_IN), t_in, 1e-6 ); \
+  CHECK_REAL_EQUAL( (T_OUT), t_out, 1e-6 ); \
+  } while(false)
+void test_leaf_intersects_ray()
+  MBErrorCode rval;
+  MBCore moab;
+  MBAdaptiveKDTree tool( &moab );
+  double t_in, t_out;
+  MBEntityHandle root;
+  const double min[3] = { -5, -4, -1 };
+  const double max[3] = {  1,  2,  3 };
+  rval = tool.create_tree( min, max, root );
+  CHECK_ERR(rval);
+  MBAdaptiveKDTreeIter iter;
+  rval = tool.get_tree_iterator( root, iter );
+  CHECK_ERR(rval);
+    // start with point inside box
+  const double pt1[] = { 0, 0, 0 };
+  const double dir1[] = { 0.1, 0.1, 0.1 };
+  CHECK_RAY_XSECTS( pt1, dir1, 0, 10 );
+  const double dir2[] = { 5, 5, 5 };
+  CHECK_RAY_XSECTS( pt1, dir2, 0, 0.2 );
+  const double pxdir[] = { 1, 0, 0 };
+  CHECK_RAY_XSECTS( pt1, pxdir, 0, 1 );
+  const double nxdir[] = { -1, 0, 0 };
+  CHECK_RAY_XSECTS( pt1, nxdir, 0, 5 );
+  const double pydir[] = { 0, 1, 0 };
+  CHECK_RAY_XSECTS( pt1, pydir, 0, 2 );
+  const double nydir[] = { 0, -1, 0 };
+  CHECK_RAY_XSECTS( pt1, nydir, 0, 4 );
+  const double pzdir[] = { 0, 0, 1 };
+  CHECK_RAY_XSECTS( pt1, pzdir, 0, 3 );
+  const double nzdir[] = { 0, 0, -1 };
+  CHECK_RAY_XSECTS( pt1, nzdir, 0, 1 );
+    // point below box
+  const double pt2[] = { 0, 0, -2 };
+  CHECK_RAY_XSECTS( pt2, dir1, 10, 10 );
+  CHECK_RAY_XSECTS( pt2, dir2, 0.2, 0.2 );
+  CHECK(!iter.intersect_ray( pt2, pxdir, t_in, t_out ));
+  CHECK(!iter.intersect_ray( pt2, nxdir, t_in, t_out ));
+  CHECK(!iter.intersect_ray( pt2, pydir, t_in, t_out ));
+  CHECK(!iter.intersect_ray( pt2, nydir, t_in, t_out ));
+  CHECK_RAY_XSECTS( pt2, pzdir, 1, 5 );
+  CHECK(!iter.intersect_ray( pt2, nzdir, t_in, t_out ));
+    // point right of box
+  const double pt3[] = { 3, 0, 0 };
+  CHECK(!iter.intersect_ray( pt3, dir1, t_in, t_out ));
+  CHECK(!iter.intersect_ray( pt3, dir2, t_in, t_out ));
+  CHECK(!iter.intersect_ray( pt3, pxdir, t_in, t_out ));
+  CHECK_RAY_XSECTS( pt3, nxdir, 2, 8 );
+  CHECK(!iter.intersect_ray( pt3, pydir, t_in, t_out ));
+  CHECK(!iter.intersect_ray( pt3, nydir, t_in, t_out ));
+  CHECK(!iter.intersect_ray( pt3, pzdir, t_in, t_out ));
+  CHECK(!iter.intersect_ray( pt3, nzdir, t_in, t_out ));
+    // a few more complex test cases
+  const double dira[] = { -3, 0, 3 };
+  CHECK_RAY_XSECTS( pt3, dira, 2./3., 1.0 );
+  const double dirb[] = { -2, 0, 3.1 };
+  CHECK(!iter.intersect_ray( pt3, dirb, t_in, t_out ));
 int main()
   int error_count = 0;
@@ -1229,5 +1300,6 @@
   error_count += RUN_TEST(test_leaf_volume);
   error_count += RUN_TEST(test_leaf_sibling);
   error_count += RUN_TEST(test_leaf_intersects_plane);
+  error_count += RUN_TEST(test_leaf_intersects_ray);
   return error_count;
Modified: MOAB/trunk/bsp_tree_test.cpp
--- MOAB/trunk/bsp_tree_test.cpp	2009-09-25 15:29:09 UTC (rev 3167)
+++ MOAB/trunk/bsp_tree_test.cpp	2009-09-25 15:34:25 UTC (rev 3168)
@@ -1,6 +1,9 @@
 #include "MBCore.hpp"
 #include "TestUtil.hpp"
 #include "MBBSPTree.hpp"
+#include "MBRange.hpp"
 void test_set_plane();
@@ -13,8 +16,14 @@
 void test_merge_leaf();
 void test_box_iter_neighbors();
 void test_leaf_sibling();
-void test_leaf_volume();
+void test_leaf_volume( bool box );
+void test_leaf_volume_box() { test_leaf_volume(true); }
+void test_leaf_volume_gen() { test_leaf_volume(false); }
 void test_leaf_splits_intersects();
+void test_leaf_intersects_ray_common( bool box );
+void test_box_leaf_intersects_ray() { test_leaf_intersects_ray_common(true); }
+void test_gen_leaf_intersects_ray() { test_leaf_intersects_ray_common(false); }
+void test_leaf_polyhedron();
 int main()
@@ -30,8 +39,12 @@
   failures += RUN_TEST( test_merge_leaf );
   failures += RUN_TEST( test_box_iter_neighbors );
   failures += RUN_TEST( test_leaf_sibling );
-  failures += RUN_TEST( test_leaf_volume );
+  failures += RUN_TEST( test_leaf_volume_box );
+  failures += RUN_TEST( test_leaf_volume_gen );
   failures += RUN_TEST( test_leaf_splits_intersects );
+  failures += RUN_TEST( test_box_leaf_intersects_ray );
+  failures += RUN_TEST( test_gen_leaf_intersects_ray );
+  failures += RUN_TEST( test_leaf_polyhedron );
   return failures;
@@ -1566,13 +1579,15 @@
   CHECK( !iter1.sibling_is_forward() );
   MBCore moab;
   MBBSPTree tool( &moab );
   MBErrorCode rval;
-  MBBSPTreeBoxIter iter;
+  MBBSPTreeBoxIter b_iter;
+  MBBSPTreeIter g_iter;
+  MBBSPTreeIter& iter = box ? b_iter : g_iter;
 /*  Build Tree
@@ -1701,3 +1716,386 @@
   CHECK( iter.intersects( p ) );
+  } while(false)
+  MBErrorCode rval;
+  MBCore moab;
+  MBBSPTree tool( &moab );
+  /** Start with only root box for initial testing **/
+  /*  (1,5,-3)   (2,5,-3)
+            o----o
+ (1,5,-1)o----o       \
+         |  :  Y \        \
+         |  :  +-->X   \        \ (6,1,-3)
+         |  o./..........\.......o
+         | . L             \    /
+         |. Z                \ /
+         o--------------------o
+  (1,1,-1)                    (6,1,-1)
+  const double corners[][3] = { { 1, 1, -3 },
+                                { 6, 1, -3 },
+                                { 2, 5, -3 },
+                                { 1, 5, -3 },
+                                { 1, 1, -1 },
+                                { 6, 1, -1 },
+                                { 2, 5, -1 },
+                                { 1, 5, -1 } };
+  rval = tool.create_tree( corners, root );
+  CHECK_ERR(rval);
+  MBBSPTreeIter gen_iter;
+  MBBSPTreeBoxIter box_iter;
+  MBBSPTreeIter& iter = box ? static_cast<MBBSPTreeIter&>(box_iter) : gen_iter;
+  CHECK_ERR(rval);
+  const double pt1[] = { 3.5, 3, -2 };
+  CHECK_RAY_XSECTS( pt1, dir1, 0, 2.5 );
+  CHECK_RAY_XSECTS( pt1, dir2, 0, 0.05 );
+  CHECK_RAY_XSECTS( pt1, pxdir, 0, 0.5 );
+  CHECK_RAY_XSECTS( pt1, nxdir, 0, 2.5 );
+  CHECK_RAY_XSECTS( pt1, pydir, 0, 0.5 );
+  CHECK_RAY_XSECTS( pt1, nydir, 0, 2 );
+  CHECK_RAY_XSECTS( pt1, pzdir, 0, 1 );
+  const double pt2[] = { 3.5, 3, -4 };
+  CHECK(!iter.intersect_ray( pt2, dir1, t_in, t_out ));
+  CHECK(!iter.intersect_ray( pt2, dir2, t_in, t_out ));
+  CHECK_RAY_XSECTS( pt2, pzdir, 1, 3 );
+  const double pt3[] = { 7, 3, -2 };
+  CHECK_RAY_XSECTS( pt3, nxdir, 3, 6 );
+  const double dira[] = { -2, -2, 0 };
+  CHECK_RAY_XSECTS( pt3, dira, 0.75, 1.0 );
+  const double dirb[] = { -1, -2.1, 0 };
+  /** Now split twice and test the bottom right corne **/
+  MBBSPTree::Plane Y3( MBBSPTree::Y, 3.0 );
+  rval = tool.split_leaf( iter, Y3 );
+  CHECK_ERR(rval);
+  MBBSPTree::Plane X2( MBBSPTree::X, 2.0 );
+  rval = tool.split_leaf( iter, X2 );
+  CHECK_ERR(rval);
+  rval = iter.step();
+  CHECK_ERR(rval);
+             (2,3,-3)
+                 o--------o (4,3,-3)
+      (2,3,-1)o--------o(4,3,-1)\ (6,1,-3)
+              |  o.......\.......o
+              o---------------o
+         (2,1,-1)             (6,1,-1)
+  const double pt4[] = { 4, 2, -2 };
+  CHECK_RAY_XSECTS( pt4, dir1, 0, 5 );
+  CHECK_RAY_XSECTS( pt4, dir2, 0, 0.1 );
+  CHECK_RAY_XSECTS( pt4, pxdir, 0, 1 );
+  CHECK_RAY_XSECTS( pt4, nxdir, 0, 2 );
+  CHECK_RAY_XSECTS( pt4, pydir, 0, 1 );
+  CHECK_RAY_XSECTS( pt4, nydir, 0, 1 );
+  CHECK_RAY_XSECTS( pt4, pzdir, 0, 1 );
+  CHECK_RAY_XSECTS( pt4, nzdir, 0, 1 );
+  const double pt5[] = { 4, 2, -4 };
+  CHECK(!iter.intersect_ray( pt5, dir1, t_in, t_out ));
+  CHECK(!iter.intersect_ray( pt5, dir2, t_in, t_out ));
+  CHECK(!iter.intersect_ray( pt5, pxdir, t_in, t_out ));
+  CHECK(!iter.intersect_ray( pt5, nxdir, t_in, t_out ));
+  CHECK(!iter.intersect_ray( pt5, pydir, t_in, t_out ));
+  CHECK(!iter.intersect_ray( pt5, nydir, t_in, t_out ));
+  CHECK_RAY_XSECTS( pt5, pzdir, 1, 3 );
+  CHECK(!iter.intersect_ray( pt5, nzdir, t_in, t_out ));
+  const double pt6[] = { 7, 2, -2 };
+  CHECK(!iter.intersect_ray( pt6, dir1, t_in, t_out ));
+  CHECK(!iter.intersect_ray( pt6, dir2, t_in, t_out ));
+  CHECK(!iter.intersect_ray( pt6, pxdir, t_in, t_out ));
+  CHECK_RAY_XSECTS( pt6, nxdir, 2, 5 );
+  CHECK(!iter.intersect_ray( pt6, pydir, t_in, t_out ));
+  CHECK(!iter.intersect_ray( pt6, nydir, t_in, t_out ));
+  CHECK(!iter.intersect_ray( pt6, pzdir, t_in, t_out ));
+  CHECK(!iter.intersect_ray( pt6, nzdir, t_in, t_out ));
+  const double dird[] = { -2, -2, 0 };
+  CHECK_RAY_XSECTS( pt6, dird, 0.5, 0.5 );
+  const double dire[] = { -3, -2, 0 };
+  CHECK_RAY_XSECTS( pt6, dire, 0.4, 0.5 );
+  const double dirf[] = { -2, -2.1, 0 };
+  CHECK(!iter.intersect_ray( pt6, dirf, t_in, t_out ));
+static void box( const double pts[], int num_pts, double minpt[3], double maxpt[3] )
+  minpt[0] = maxpt[0] = pts[0];
+  minpt[1] = maxpt[1] = pts[1];
+  minpt[2] = maxpt[2] = pts[2];
+  for (int i = 1; i < num_pts; ++i) {
+    for (int d = 0; d < 3; ++d) {
+      if (pts[3*i+d] < minpt[d])
+        minpt[d] = pts[3*i+d];
+      if (pts[3*i+d] > maxpt[d])
+        maxpt[d] = pts[3*i+d];
+static MBEntityHandle build_tree( const double points[], int num_points, MBBSPTree& tool )
+    // create points
+  MBErrorCode rval;
+  std::vector<MBEntityHandle> pts(num_points);
+  for (int i = 0; i < num_points; ++i) {
+    rval = tool.moab()->create_vertex( points + 3*i, pts[i] );
+    CHECK_ERR(rval);
+    // calculate bounding box of tree
+  double minpt[3], maxpt[3];
+  box( points, num_points, minpt, maxpt );
+    // create initial (1-node) tree
+  rval = tool.create_tree( minpt, maxpt, root );
+  CHECK_ERR(rval);
+  MBBSPTreeIter iter;
+  CHECK_ERR(rval);
+  rval = tool.moab()->add_entities( root, &pts[0], pts.size() );
+  CHECK_ERR(rval);
+    // build tree
+  std::vector<MBEntityHandle> left_pts, right_pts;
+  std::vector<MBCartVect> coords(num_points), tmp_coords;
+  std::vector<double> coeffs;
+  for (; MB_SUCCESS == rval; rval = iter.step()) {
+    pts.clear();
+    rval = tool.moab()->get_entities_by_handle( iter.handle(), pts );
+    CHECK_ERR(rval);
+    while (pts.size() > 1) {
+      coords.resize(pts.size());
+      rval = tool.moab()->get_coords( &pts[0], pts.size(), coords[0].array() );
+      CHECK_ERR(rval);
+        // find two points far apart apart
+      std::vector<MBCartVect>* ptr;
+      if (coords.size() < 10)
+        ptr = &coords;
+      else {
+        tmp_coords.resize(16);
+        MBCartVect pn, px;
+        box( coords[0].array(), coords.size(), pn.array(), px.array() );
+        tmp_coords[8] = pn;
+        tmp_coords[9] = MBCartVect( px[0], pn[1], pn[2] );
+        tmp_coords[10] = MBCartVect( px[0], px[1], pn[2] );
+        tmp_coords[11] = MBCartVect( pn[0], px[1], pn[2] );
+        tmp_coords[12] = MBCartVect( pn[0], pn[1], px[2] );
+        tmp_coords[13] = MBCartVect( px[0], pn[1], px[2] );
+        tmp_coords[14] = px;
+        tmp_coords[15] = MBCartVect( pn[0], px[1], px[2] );
+        for (int i = 0; i < 8; ++i) {
+          tmp_coords[i] = coords[0];
+          for (size_t j = 1; j < coords.size(); ++j)
+            if ((coords[j]-tmp_coords[i+8]).length_squared() <
+                (tmp_coords[i] - tmp_coords[i+8]).length_squared())
+              tmp_coords[i] = coords[j];
+        tmp_coords.resize(8);
+        ptr = &tmp_coords;
+      size_t pt1, pt2;
+      double lsqr = -1;
+      for (size_t i = 0; i < ptr->size(); ++i) {
+        for (size_t j = 0; j < ptr->size();++j) {
+          double ls = ((*ptr)[i] - (*ptr)[j]).length_squared();
+          if (ls > lsqr) {
+            lsqr = ls;
+            pt1 = i;
+            pt2 = j;
+        // if all points are coincident
+      if (lsqr <= 1e-12)
+        break;
+        // define normal orthogonal to line through two points
+      MBCartVect norm = (*ptr)[pt1] - (*ptr)[pt2];
+      norm.normalize();
+        // find mean position for plane
+      double coeff = 0.0;
+      for (size_t i = 0; i < coords.size(); ++i)
+        coeff -= norm % coords[i];
+      coeff /= coords.size();
+        // left/right sort points
+      left_pts.clear();
+      right_pts.clear();
+      for (size_t i = 0; i < coords.size(); ++i) {
+        double d = -(norm % coords[i]);
+        if (d >= coeff)
+          left_pts.push_back( pts[i] );
+        else
+          right_pts.push_back( pts[i] );
+      rval = tool.split_leaf( iter, MBBSPTree::Plane( norm.array(), coeff ), left_pts, right_pts );
+      CHECK_ERR(rval);
+      CHECK( !left_pts.empty() && !right_pts.empty() );
+      pts.swap( left_pts );
+//    printf("Leaf %d contains %d vertices: ", (int)ID_FROM_HANDLE(iter.handle()),
+//                                             (int)(pts.size()) );
+//    for (size_t i = 0; i < pts.size(); ++i)
+//      printf( "%d, ", (int)ID_FROM_HANDLE(pts[i]));
+//    printf("\n");
+  CHECK(rval == MB_ENTITY_NOT_FOUND);
+    // verify that tree is constructed correctly
+    MBCartVect pt( points + 3*i );
+    MBEntityHandle leaf;
+    rval = tool.leaf_containing_point( root, pt.array(), leaf );
+    CHECK_ERR(rval);
+    MBRange ents;
+    rval = tool.moab()->get_entities_by_handle( leaf, ents );
+    CHECK_ERR(rval);
+    bool found = false;
+    for (MBRange::iterator j = ents.begin(); j != ents.end(); ++j) {
+      MBCartVect ent_coords;
+      rval = tool.moab()->get_coords( &*j, 1, ent_coords.array() );
+      CHECK_ERR(rval);
+      if ((pt - ent_coords).length_squared() < 1e-6)
+        found = true;
+    CHECK(found);
+  return root;
+    // array of 20 points used to construct tree
+  static const double points[] = {
+       7, 6, 3,
+       5, 3, 5,
+       9, 2, 6,
+       7, 2, 1,
+       3, 9, 0,
+       6, 0, 6,
+       1, 6, 2,
+       9, 7, 8,
+       2, 0, 2,
+       5, 7, 3,
+       2, 2, 9,
+       7, 9, 8,
+       1, 6, 3,
+       3, 9, 2,
+       4, 9, 1,
+       4, 8, 7,
+       3, 0, 5,
+       0, 1, 6,
+       2, 3, 6,
+       1, 6, 0};
+  const int num_pts = sizeof(points)/(3*sizeof(double));
+  MBErrorCode rval;
+  MBCore moab;
+  MBEntityHandle root = build_tree( points, num_pts, tool );
+  CHECK_ERR(rval);
+  std::vector<MBEntityHandle> pts;
+  std::vector<MBCartVect> coords;
+  for (; rval == MB_SUCCESS; rval = iter.step()) {
+    BSPTreePoly poly;
+    rval = iter.calculate_polyhedron( poly );
+    CHECK_ERR(rval);
+    CHECK( poly.is_valid() );
+    CHECK( poly.volume() > 0.0 );
+    pts.clear();
+    CHECK_ERR(rval);
+    CHECK( !pts.empty() );
+    CHECK_ERR(rval);
+    for (size_t i = 0; i < pts.size(); ++i)
+      CHECK( poly.is_point_contained( coords[i] ) );
