[MOAB-dev] building meshkit
    Rajeev Jain
    jain at mcs.anl.gov
    Wed Sep 23 12:21:22 CDT 2009
I did and svn update on MOAB and autoreconf -fi and configured MOAB again. That error is now gone.
 Rajeev
To: Rajeev Jain <jain at mcs.anl.gov>; "moab-dev at mcs.anl.gov" <moab-dev at mcs.anl.gov>
Sent: Wednesday, September 23, 2009 11:44:47 AM
Subject: Re: building meshkit
Try configuring MOAB with a --prefix=`pwd` option (those are backquotes) then doing a 'make install' after building it.
By default, MOAB uses /usr/local/ as the default prefix for installing MOAB, which you won't typically be able to install into.  That makes me think that MeshKit's configure should check to make sure MOAB and CGM are actually installed, in addition to being built.  This might also be due to using a srcdir instead of installdir in the Makefile.am in MeshKit...
- tim
Rajeev Jain wrote:
> All copymesh.cpp related errors are now gone, changed - #include "MBCN.hpp" to #include "MBCN.h"
> Now this error shows up while doing make pin217, make works fine.
> libtool: link: cannot find the library `/usr/local/lib/libMOAB.la' or unhandled argument `/usr/local/lib/libMOAB.la'
>  Rajeev
  steadfast, because he trusts in you."               Isaiah 26:3
             Tim Tautges            Argonne National Laboratory
         (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
         phone: (608) 263-8485      1500 Engineering Dr.
           fax: (608) 263-4499      Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20090923/9b73df06/attachment.htm>
