[MOAB-dev] building meshkit
    Tim Tautges
    tautges at mcs.anl.gov
    Wed Sep 23 11:44:47 CDT 2009
Try configuring MOAB with a --prefix=`pwd` option (those are backquotes) then doing a 'make install' after building it.
By default, MOAB uses /usr/local/ as the default prefix for installing MOAB, which you won't typically be able to
install into.  That makes me think that MeshKit's configure should check to make sure MOAB and CGM are actually
installed, in addition to being built.  This might also be due to using a srcdir instead of installdir in the
Makefile.am in MeshKit...
- tim
Rajeev Jain wrote:
> All copymesh.cpp related errors are now gone, changed - #include
> "MBCN.hpp" to #include "MBCN.h"
> Now this error shows up while doing make pin217, make works fine.
> libtool: link: cannot find the library `/usr/local/lib/libMOAB.la' or
> unhandled argument `/usr/local/lib/libMOAB.la'
> Rajeev
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
