[MOAB-dev] r3055 - MOAB/trunk
    kraftche at cae.wisc.edu
    Thu Jul 23 13:04:20 CDT 2009
Author: kraftche
Date: 2009-07-23 13:04:18 -0500 (Thu, 23 Jul 2009)
New Revision: 3055
Modified:
   MOAB/trunk/AEntityFactory.cpp
   MOAB/trunk/MBCore.cpp
   MOAB/trunk/MBCore.hpp
   MOAB/trunk/MBInterface.hpp
   MOAB/trunk/MBMeshSet.cpp
   MOAB/trunk/MBMeshSet.hpp
   MOAB/trunk/MBTest.cpp
Log:
o Array passed to MBInterface::contains_entities should be const
o Change arguments to MBInterface::replace_entities such that
  a single non-const array is replaced by two const arrays
o Implement MBCore::replace_entities
o Call MBCore::replace_entities from AEntityFactory::merge_adjust_adjacencies
  to update sets such that order is preserved for list-type sets
o Add unit tests for MBInterface::replace_entities
o Update merge unit test such that it expected order to be preserved
  for tracking list sets.
Modified: MOAB/trunk/AEntityFactory.cpp
--- MOAB/trunk/AEntityFactory.cpp	2009-07-22 19:17:40 UTC (rev 3054)
+++ MOAB/trunk/AEntityFactory.cpp	2009-07-23 18:04:18 UTC (rev 3055)
@@ -1341,10 +1341,13 @@
   for (unsigned int i = 0; i < adjs.size(); i++) {
     if (TYPE_FROM_HANDLE(adjs[i]) == MBENTITYSET)
-      result = this->add_adjacency(entity_to_keep, adjs[i]);
-      if(result != MB_SUCCESS) return result;
-      result = thisMB->add_entities(adjs[i], &entity_to_keep, 1);
+      //result = this->add_adjacency(entity_to_keep, adjs[i]);
+      //if(result != MB_SUCCESS) return result;
+      //result = thisMB->add_entities(adjs[i], &entity_to_keep, 1);
+      result = thisMB->replace_entities( adjs[i], &entity_to_remove, &entity_to_keep, 1 );
+      if (MB_SUCCESS != result)
+        return result;
     else if(ent_dim == 0)
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp	2009-07-22 19:17:40 UTC (rev 3054)
+++ MOAB/trunk/MBCore.cpp	2009-07-23 18:04:18 UTC (rev 3055)
@@ -2492,7 +2492,7 @@
     //! return true if all entities are contained in set
 bool MBCore::contains_entities(MBEntityHandle meshset,
-                               MBEntityHandle *entities,
+                               const MBEntityHandle *entities,
                                int num_entities,
                                const int operation_type)
@@ -2503,38 +2503,18 @@
     return false;
-// replace entities in a meshset; entities appear in pairs,
-// old then new entity in each pair
-bool MBCore::replace_entities(MBEntityHandle meshset,
-                              int num_entities)
+// replace entities in a meshset
+MBErrorCode MBCore::replace_entities(MBEntityHandle meshset,
+                                     const MBEntityHandle *old_entities,
+                                     const MBEntityHandle *new_entities,
+                                     int num_entities)
-  return false;
-    // if a regular entity set, we're simply changing contents of this set
-  if (0 != meshset) {
-    MBMeshSet* set = get_mesh_set( sequence_manager(), meshset );
-    if (set)
-      return set->replace_entities( meshset, entities, num_entities, a_entity_factory() );
-    else
-      return false;
-    // otherwise, we're actually changing an entity's handle
-    // in preparation, get all the non-tracking sets
-  MBRange tmp_sets, all_sets;
-  MBErrorCode result = get_entities_by_type(0, MBENTITYSET, tmp_sets);
-  if (MB_SUCCESS != result) return result;
-  unsigned int option;
-  for (MBRange::iterator rit = tmp_sets.begin(); rit != tmp_sets.end(); rit++)
-    if (MB_SUCCESS == get_meshset_options(*rit, option) &&
-        !(option & MESHSET_TRACK_OWNER))
-      all_sets.insert(*rit);
-    // now replace each entity
-  double coords[3];
+  MBMeshSet* set = get_mesh_set( sequence_manager(), meshset );
+  if (set)
+    return set->replace_entities( meshset, old_entities, new_entities,
+                                  num_entities, a_entity_factory());
+  else
+    return MB_ENTITY_NOT_FOUND;
 MBErrorCode MBCore::get_parent_meshsets(const MBEntityHandle meshset,
Modified: MOAB/trunk/MBCore.hpp
--- MOAB/trunk/MBCore.hpp	2009-07-22 19:17:40 UTC (rev 3054)
+++ MOAB/trunk/MBCore.hpp	2009-07-23 18:04:18 UTC (rev 3055)
@@ -869,14 +869,15 @@
   virtual bool contains_entities(MBEntityHandle meshset,
                                  int num_entities,
                                  const int operation_type = MBInterface::INTERSECT);
     //! replace entities
-  virtual bool replace_entities(MBEntityHandle meshset,
-                                int num_entities);
+  virtual MBErrorCode replace_entities(MBEntityHandle meshset,
+                                       int num_entities);
   //------MeshSet Parent/Child functions------
Modified: MOAB/trunk/MBInterface.hpp
--- MOAB/trunk/MBInterface.hpp	2009-07-22 19:17:40 UTC (rev 3054)
+++ MOAB/trunk/MBInterface.hpp	2009-07-23 18:04:18 UTC (rev 3055)
@@ -1389,21 +1389,39 @@
      * \return bool If true, all entities are contained in set
                                  int num_entities,
                                  const int operation_type = MBInterface::INTERSECT) = 0;
     //! Replace entities in a set with other entities
-    /** Replace entities in a set with other entities; entity list
-     * specified in pairs of (old, new)
+    /** Replace entities in a set with other entities
+     * \note  Behavior is undefined if an entity handle exists in both the
+     *        old_entities and the new_entities arrays or old_entities
+     *        contains multiple copies of an entity.
+     * \note  If an entity occurs multiple times in an ordered set, all
+     *        occurances will be replaced.
+     * \note  For list-based sets, if not all handles in old_entities
+     *        occcur in the set, the corresponding new_entities will not
+     *        be added and  MB_ENTITY_NOT_FOUND will be returned.
+     *        For set-based sets, all entities in new_entities wll be
+     *        added and any contained entities in old_entities will be
+     *        removed, and the return value will be MB_SUCCESS.
      * \param meshset Mesh set being modified
-     * \param entities Pairs of old/new entities
-     * \param num_entities Number of entities \em{total} in entities list
-     * \return bool If true, one or more entities were replaced
+     * \param old_entities Entities to replace
+     * \param new_entities New entities to add
+     * \param num_entities Number of entities in input arrays
+     * \return - MB_SUCCESS : all entities in old_entities replaced
+     *         - MB_ENTITY_NOT_FOUND : one or more entities in new_entities
+     *                        not added to set because corresponding entity
+     *                        in old_entities did not occur in the ordered
+     *                        set.
+     *         - MB_FAILURE : internal error
-                                int num_entities) = 0;
+                                       int num_entities) = 0;
     //! \name MeshSet parent/child functions
Modified: MOAB/trunk/MBMeshSet.cpp
--- MOAB/trunk/MBMeshSet.cpp	2009-07-22 19:17:40 UTC (rev 3054)
+++ MOAB/trunk/MBMeshSet.cpp	2009-07-23 18:04:18 UTC (rev 3055)
@@ -1075,63 +1075,37 @@
-bool MBMeshSet::replace_entities( MBEntityHandle my_handle,
-                                  const MBEntityHandle* entities,
-                                  size_t num_entities,
-                                  AEntityFactory* adjfact )
+MBErrorCode MBMeshSet::replace_entities( MBEntityHandle my_handle,
+                                         const MBEntityHandle* old_entities,
+                                         const MBEntityHandle* new_entities,
+                                         size_t num_entities,
+                                         AEntityFactory* adjfact )
-  assert(0 == num_entities%2);
   if (vector_based()) {
-    bool was_contained = false;
+    MBErrorCode result = MB_SUCCESS;
     size_t count;
     MBEntityHandle* vect = get_contents( count );
     MBEntityHandle* const vect_end = vect+count;
-    for (size_t i = 0; i < num_entities; i+=2) {
-      for (MBEntityHandle* p = vect; p != vect_end; ++p ) {
-        if (*p == entities[i]) {
-          if (tracking()) {
-            adjfact->remove_adjacency( *p, my_handle );
-            adjfact->add_adjacency( entities[i+1], my_handle, false );
-          *p = entities[i+1];
-          was_contained = true;
+    for (size_t i = 0; i < num_entities; ++i) {
+      MBEntityHandle* p = std::find( vect, vect_end, old_entities[i] );
+      if (p == vect_end) {
+        result = MB_ENTITY_NOT_FOUND;
+      else do {
+        if (tracking()) {
+          adjfact->remove_adjacency( *p, my_handle );
+          adjfact->add_adjacency( new_entities[i], my_handle, false );
+        *p = new_entities[i];
+        p = std::find( p+1, vect_end, old_entities[i] );
+      } while (p != vect_end);
-    return was_contained;
+    return result;
   else {
-    std::vector<MBEntityHandle> swap_list;
-    swap_list.reserve( num_entities / 2 );
-      // get list of handles to remove
-    size_t count;
-    MBEntityHandle* vect = get_contents( count );
-    MBEntityHandle* const vect_end = vect+count;
-      MBEntityHandle* p = std::lower_bound(vect, vect_end, entities[i]);
-      if (p != vect_end && (*p == entities[i] || (p-vect)%2 == 1))
-        swap_list.push_back(entities[i]);
-    if (swap_list.empty())
-      return false;
-      // remove entities
-    remove_entities( &swap_list[0], swap_list.size(), my_handle, adjfact );
-      // get list of handles to add
-    std::vector<MBEntityHandle>::iterator si = swap_list.begin();
-    for (size_t i = 0; i < num_entities; ++i) {
-      if (entities[i] == *si) {
-        *si = entities[i+1];
-        if (++si == swap_list.end())
-          break;
-      // add entities
-    add_entities( &swap_list[0], swap_list.size(), my_handle, adjfact );
-    return true;
+    MBErrorCode r1 = remove_entities( old_entities, num_entities, my_handle, adjfact );
+    MBErrorCode r2 = add_entities( new_entities, num_entities, my_handle, adjfact );
+    return (MB_SUCCESS == r2) ? r1 : r2;
Modified: MOAB/trunk/MBMeshSet.hpp
--- MOAB/trunk/MBMeshSet.hpp	2009-07-22 19:17:40 UTC (rev 3054)
+++ MOAB/trunk/MBMeshSet.hpp	2009-07-23 18:04:18 UTC (rev 3055)
@@ -71,10 +71,11 @@
     //! replace one entity with another in the set (contents and parent/child
     //! lists); returns whether it was replaced or not
-  bool replace_entities(MBEntityHandle my_handle,
-                        const MBEntityHandle *entities,
-                        AEntityFactory* mAdjFact);
+  MBErrorCode replace_entities(MBEntityHandle my_handle,
+                               AEntityFactory* mAdjFact);
     /** Clear *contents* of set (not parents or children) */
   inline MBErrorCode clear( MBEntityHandle myhandle, AEntityFactory* adjacencies );
Modified: MOAB/trunk/MBTest.cpp
--- MOAB/trunk/MBTest.cpp	2009-07-22 19:17:40 UTC (rev 3054)
+++ MOAB/trunk/MBTest.cpp	2009-07-23 18:04:18 UTC (rev 3055)
@@ -57,6 +57,10 @@
 #include "testdir.h"
 string TestDir( TEST_DIR );
+#define CHKERR(A) do { if (MB_SUCCESS != (A)) { \
+  std::cerr << "Failure (error code " << (A) << ") at " __FILE__ ":" \
+            << __LINE__ << std::endl; \
+  return A; } } while(false)
     @test
@@ -2254,6 +2258,115 @@
   return mb_mesh_set_appends( mb, -1 );
+MBErrorCode mb_mesh_set_set_replace_test( MBInterface*  )
+  MBCore moab;
+  MBInterface* mb = &moab;
+  MBErrorCode rval;
+  MBRange r;
+    // create 10 vertices to put in set
+  std::vector<double> coords(30);
+  rval = mb->create_vertices( &coords[0], 10, r );
+  CHKERR(rval);
+  std::vector<MBEntityHandle> verts(r.size());
+  std::copy( r.begin(), r.end(), verts.begin() );
+  r.clear();
+    // create a set
+  MBEntityHandle set;
+  rval = mb->create_meshset( MESHSET_SET, set );
+  CHKERR(rval);
+    // put every other vertex in set
+  for (size_t i = 0; i < 10; i += 2)
+    r.insert( verts[i] );
+  rval = mb->add_entities( set, r );
+  CHKERR(rval);
+  r.clear();
+    // swap 3 of the vertices
+  MBEntityHandle old_ents[3] = { verts[2], verts[4], verts[6] };
+  MBEntityHandle new_ents[3] = { verts[1], verts[9], verts[5] };
+  rval = mb->replace_entities( set, old_ents, new_ents, 3 );
+  CHKERR(rval);
+    // check new set contents
+  rval = mb->get_entities_by_handle( set, r );
+  CHKERR(rval);
+  MBRange r2;
+  r2.insert( verts[0] );
+  r2.insert( verts[1] );
+  r2.insert( verts[9] );
+  r2.insert( verts[5] );
+  r2.insert( verts[8] );
+  if (r != r2) {
+    std::cerr << "Range does not contain expected values." << std::endl
+              << "  Expected: " << r2 << std::endl
+              << "  Actual  : " << r  << std::endl;
+    return MB_FAILURE;
+  return MB_SUCCESS;
+MBErrorCode mb_mesh_set_list_replace_test( MBInterface*  )
+  MBCore moab;
+  MBErrorCode rval;
+  MBRange r;
+  CHKERR(rval);
+  r.clear();
+    // create a set
+  rval = mb->create_meshset( MESHSET_ORDERED, set );
+  CHKERR(rval);
+    // put all vertices in set, but add the first one a second time
+  std::vector<MBEntityHandle> list( verts );
+  list.push_back( verts.front() );
+  rval = mb->add_entities( set, &list[0], list.size() );
+  CHKERR(rval);
+  std::vector<MBEntityHandle> list2;
+  rval = mb->get_entities_by_handle( set, list2 );
+  CHKERR(rval);
+  list[2] = verts[1];
+  list[4] = verts[9];
+  list[6] = verts[5];
+  if (list != list2) {
+    std::cerr << "Range does not contain expected values." << std::endl;
+    std::cerr << "  Expected: ";
+    std::copy( list.begin(), list.end(), std::ostream_iterator<MBEntityHandle>(std::cerr, " ") );
+    std::cerr << std::endl << "  Actual  : ";
+    std::copy( list2.begin(), list2.end(), std::ostream_iterator<MBEntityHandle>(std::cerr, " ") );
+    std::cerr << std::endl;
+    // now try replacing a repeated value
+  rval = mb->replace_entities( set, &verts[0], &verts[3], 1 );
+  CHKERR(rval);
+  list[0] = list[10] = verts[3];
+  list2.clear();
+  CHKERR(rval);
   // number of entities of type MBVERTEX, MBEDGE, MBDTri, MBQUAD, MBTET, and MBHEX
   // in mbtest1.g  (all other values are 0.
 static const unsigned int num_entities[MBMAXTYPE] = {47,12,18,8,22,8};
@@ -4350,8 +4463,8 @@
     // create two tracking sets containing the vertices
     // and edge of each quad
   MBEntityHandle set1, set2;
-  mb->create_meshset( MESHSET_TRACK_OWNER, set1 );
-  mb->create_meshset( MESHSET_TRACK_OWNER, set2 );
+  mb->create_meshset( MESHSET_TRACK_OWNER|MESHSET_SET, set1 );
+  mb->create_meshset( MESHSET_TRACK_OWNER|MESHSET_ORDERED, set2 );
   mb->add_entities( set1, verts, 4 );
   mb->add_entities( set2, verts+4, 4 );
   mb->add_entities( set1, &edge1, 1 );
@@ -4417,6 +4530,11 @@
   std::sort( act.begin(), act.end() );
   if (exp != act) {
     std::cerr << "Incorrect set contents at " << __FILE__ << ":" << __LINE__ << std::endl;
+    std::copy( exp.begin(), exp.end(), std::ostream_iterator<MBEntityHandle>(std::cerr, " ") );
+    std::copy( act.begin(), act.end(), std::ostream_iterator<MBEntityHandle>(std::cerr, " ") );
     return MB_FAILURE;
@@ -4428,17 +4546,18 @@
   exp[4] = edge1;
   act.clear();
   mb->get_entities_by_handle( set2, act );
-  std::sort( exp.begin(), exp.end() );
-  std::sort( act.begin(), act.end() );
   if (exp != act) {
     return MB_FAILURE;
   return MB_SUCCESS;
 MBErrorCode mb_stress_test(MBInterface *MB)
@@ -6380,6 +6499,8 @@
   RUN_TEST( mb_mesh_set_set_appends );
   RUN_TEST( mb_mesh_set_list_appends );
   RUN_TEST( mb_mesh_set_root_appends );
+  RUN_TEST( mb_mesh_set_set_replace_test );
+  RUN_TEST( mb_mesh_set_list_replace_test );
   RUN_TEST( mb_tags_test );
   RUN_TEST( mb_dense_tag_test );
   RUN_TEST( mb_sparse_tag_test );
@@ -6404,8 +6525,8 @@
   RUN_TEST( mb_skin_surface_adj_test );
   RUN_TEST( mb_skin_volume_test );
   RUN_TEST( mb_skin_volume_adj_test );
+  RUN_TEST( mb_merge_update_test );
   RUN_TEST( mb_merge_test );
-  RUN_TEST( mb_merge_update_test );
   if (stress_test) RUN_TEST( mb_stress_test );
     // summary
