[MOAB-dev] r3036 - in MOAB/trunk: . tools/iMesh/python
    Tim Tautges
    tautges at mcs.anl.gov
    Tue Jul 21 14:34:19 CDT 2009
Jason, can you put that on your list of things to do when you're bored
working on parallel read?  The Fortran stuff in general is kinda dicey
in our config stuff (e.g. the optimize/debug flags don't work right for
the fortran command).
- tim
Jed Brown wrote:
> jvporter at mcs.anl.gov wrote:
>> Author: jvporter
>> Date: 2009-07-21 13:32:30 -0500 (Tue, 21 Jul 2009)
>> New Revision: 3036
>> Removed:
>>    MOAB/trunk/tools/iMesh/python/setup.cfg.in
>> Modified:
>>    MOAB/trunk/configure.ac
>>    MOAB/trunk/tools/iMesh/python/Makefile.am
>> Log:
>> Improve autotools integration for Python libraries
>> * "install" actually works
>> * "clean" works
>> * More useful options to install, thanks to Jason
> Can you make this work for out-of-source builds?  I keep MOAB compiled a
> few different ways and everything else works fine for out-of-source
> builds, but pytaps assumes in-source paths.
> Unrelated to pytaps, the Fortran compiler is being found incorrectly.
> I'm setting FC=mpif90 F77=mpif77, but autoconf is ignoring these and
> finding gfortran instead.  They happen to be compatible, but you can't
> rely on that, or the fact that I don't use Fortran ;-)
> Sorry I don't have patches, my autotools experience is limited.
> Jed
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
