[MOAB-dev] failing tests
    Jed Brown
    jed at 59A2.org
    Wed Jul 15 11:15:29 CDT 2009
Tim Tautges wrote:
> I knew parallel_hdf5_test was failing, but not parallel_unit_tests.  Are
> you on 64 bit?  I haven't tested the parallel stuff there, so that might
> be the problem... I'll be looking at it today.
Yes, I'm on x86_64 with parallel-enabled (MPI-IO) HDF5-1.8.3.
Jed
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20090715/4513be28/attachment.pgp>
