[MOAB-dev] failing tests
Tim Tautges
tautges at mcs.anl.gov
Wed Jul 15 11:13:31 CDT 2009
I knew parallel_hdf5_test was failing, but not parallel_unit_tests. Are
you on 64 bit? I haven't tested the parallel stuff there, so that might
be the problem... I'll be looking at it today.
- tim
Jed Brown wrote:
> I don't see the buildbot complaining, but I've got several failing
> tests. Ignore this if you're already aware of them.
> Jed
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
