[MOAB-dev] r3011 - MOAB/trunk
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Tue Jul 14 17:10:40 CDT 2009
Author: kraftche
Date: 2009-07-14 17:10:40 -0500 (Tue, 14 Jul 2009)
New Revision: 3011
Modified:
   MOAB/trunk/ReadHDF5.cpp
   MOAB/trunk/ReadHDF5.hpp
Log:
o Fix old USE_MPIO option for parallel read & delete
o use HDF5 MPIO for true parallel read
Modified: MOAB/trunk/ReadHDF5.cpp
--- MOAB/trunk/ReadHDF5.cpp	2009-07-14 22:08:53 UTC (rev 3010)
+++ MOAB/trunk/ReadHDF5.cpp	2009-07-14 22:10:40 UTC (rev 3011)
@@ -16,10 +16,8 @@
 // Filename      : ReadHDF5.cpp
-// Purpose       : TSTT HDF5 Writer
+// Purpose       : HDF5 Writer
-// Special Notes : WriteSLAC used as template for this
 // Creator       : Jason Kraftcheck
 // Creation Date : 04/18/04
@@ -94,7 +92,8 @@
     fileInfo( 0 ),
     readUtil( 0 ),
     handleType( 0 ),
-    ioProp( H5P_DEFAULT )
+    indepIO( H5P_DEFAULT ),
+    collIO( H5P_DEFAULT )
@@ -105,7 +104,7 @@
   if (readUtil)
     return MB_SUCCESS;
-  ioProp = H5P_DEFAULT;
+  indepIO = collIO = H5P_DEFAULT;
   //WriteHDF5::register_known_tag_types( iFace );
   handleType = H5Tcopy( H5T_NATIVE_ULONG );
@@ -152,29 +151,20 @@
   MBErrorCode rval;
   mhdf_Status status;
   if (MB_SUCCESS != init())
     return error(MB_FAILURE);
+    // Handle parallel options
+  std::string junk;
   bool use_mpio = (MB_SUCCESS == opts.get_null_option("USE_MPIO"));
-  if (use_mpio) {
-#ifndef HDF5_PARALLEL
-    return error(MB_NOT_IMPLEMENTED);
-#else
-    int parallel_mode;
-    rval = opts.match_option( "PARALLEL",
-                              ReadParallel::parallelOptsNames,
-                              parallel_mode );
-    if (MB_FAILURE == rval) {
-      readUtil->report_error("Unexpected value for 'PARALLEL' option\n");
-      return error(MB_FAILURE);
-    else if (MB_SUCCESS != rval ||
-             parallel_mode != ReadParallel::POPT_READ_DELETE) {
-      use_mpio = false;
-#endif
+  rval = opts.match_option("PARALLEL", "NATIVE");
+  bool parallel = (rval != MB_ENTITY_NOT_FOUND);
+  bool native_parallel = (rval == MB_SUCCESS);
+  if (use_mpio && !parallel) {
+    readUtil->report_error( "'USE_MPIO' option specified w/out 'PARALLEL' option" );
+    return MB_NOT_IMPLEMENTED;
   // This option is intended for testing purposes only, and thus
@@ -199,18 +189,22 @@
     return error(rval);
-    // Open the file
   hid_t file_prop = H5P_DEFAULT;
-#ifdef HDF5_PARALLEL
-  if (use_mpio) {
+  if (use_mpio || native_parallel) {
+#ifndef HDF5_PARALLEL
+    readUtil->report_error("MOAB not configured with parallel HDF5 support");
+    free(dataBuffer);
+#else
     file_prop = H5Pcreate(H5P_FILE_ACCESS);
     H5Pset_fapl_mpio(file_prop, MPI_COMM_WORLD, MPI_INFO_NULL);
-    ioProp = H5Pcreate(H5P_DATASET_XFER);
-    H5Pset_dxpl_mpio(ioProp, H5FD_MPIO_COLLECTIVE);
+    collIO = H5Pcreate(H5P_DATASET_XFER);
+    H5Pset_dxpl_mpio(collIO, H5FD_MPIO_COLLECTIVE);
+    indepIO = native_parallel ? H5P_DEFAULT : collIO;
+#endif
-#endif
+    // Open the file
   filePtr = mhdf_openFileWithOpt( filename, 0, NULL, file_prop, &status );
   if (file_prop != H5P_DEFAULT)
     H5Pclose( file_prop );
@@ -218,8 +212,10 @@
     readUtil->report_error( mhdf_message( &status ));
     free( dataBuffer );
-    if (ioProp != H5P_DEFAULT)
-      H5Pclose( ioProp );
+    if (indepIO != H5P_DEFAULT)
+      H5Pclose( indepIO );
+    if (collIO != indepIO)
+      H5Pclose( collIO );
     iFace->delete_entities( &file_set, 1 );
@@ -228,8 +224,10 @@
   fileInfo = mhdf_getFileSummary( filePtr, handleType, &status );
   if (is_error(status)) {
     free( dataBuffer );
     mhdf_closeFile( filePtr, &status );
@@ -241,8 +239,10 @@
     rval = load_file_impl( file_set, opts );
   filePtr = 0;
   if (MB_SUCCESS == rval && is_error(status))
     rval = MB_FAILURE;
@@ -694,7 +694,7 @@
   while (remaining) {
       // Get a block of tag values
     size_t count = std::min( chunk_size, remaining );
-    mhdf_readDenseTag( tag_table, offset, count, H5T_NATIVE_UINT, buffer, &status );
+    mhdf_readDenseTagWithOpt( tag_table, offset, count, H5T_NATIVE_UINT, buffer, collIO, &status );
@@ -753,7 +753,7 @@
     long count = p->second - p->first + 1;
     long offset = p->first - fileInfo->nodes.start_id;
     for (int i = 0; i < dim; ++i) {
-      mhdf_readNodeCoord( data_id, offset, count, i, arrays[i], &status );
+      mhdf_readNodeCoordWithOpt( data_id, offset, count, i, arrays[i], indepIO, &status );
         mhdf_closeData( filePtr, data_id, &status );
@@ -834,7 +834,7 @@
     if (ins == idMap.end())
       { rval = MB_FAILURE; break; }
-    mhdf_readConnectivityWithOpt( data_id, p->first - first_id, count, handleType, array, ioProp, &status );
+    mhdf_readConnectivityWithOpt( data_id, p->first - first_id, count, handleType, array, indepIO, &status );
       break;
@@ -892,7 +892,7 @@
   while (remaining) {
       // read a block of connectivity data
     const long count = std::min( remaining, buffer_size );
-    mhdf_readConnectivity( table_handle, offset, count, H5T_NATIVE_LONG, buffer, &status );
+    mhdf_readConnectivityWithOpt( table_handle, offset, count, H5T_NATIVE_LONG, buffer, collIO, &status );
     offset += count;
@@ -988,7 +988,7 @@
     elements.erase( elements.begin(), elements.begin()+count );
       // read element connectivity
-    mhdf_readConnectivity( table, offset, count, handleType, buffer, &status );
+    mhdf_readConnectivityWithOpt( table, offset, count, handleType, buffer, indepIO, &status );
       mhdf_closeData( filePtr, table, &status );
@@ -1205,8 +1205,8 @@
     // Read the subset of the explicitly sepecified elements that are of the
     // largest dimension.   We could read all explicitly specified elements,
-    // but then the lower-dimension elements will be read a second when reading
-    // node-adjacent elements.
+    // but then the lower-dimension elements will be read a second time when
+    // reading node-adjacent elements.
   for (int i = 0; i < fileInfo->num_elem_desc; ++i) {
     type = MBCN::EntityTypeFromName( fileInfo->elems[i].type );
     if (MBCN::Dimension(type) == max_dim) {
@@ -1227,9 +1227,9 @@
     // get MBRange of all explicitly specified elements, grouped by dimension
   MBRange explicit_elems[4];
   MBRange::iterator hints[4] = { explicit_elems[0].begin(),
-                                explicit_elems[1].begin(),
-                                explicit_elems[2].begin(),
-                                explicit_elems[3].begin() };
+                                 explicit_elems[1].begin(),
+                                 explicit_elems[2].begin(),
+                                 explicit_elems[3].begin() };
   RangeMap<long, MBEntityHandle>::iterator rit;
   while (!elem_ids.empty()) {
     long start = elem_ids.front();
@@ -1571,7 +1571,7 @@
     mhdf_readSetFlags( meta_handle, offset, count, H5T_NATIVE_USHORT, flag_buffer, &status );
-    mhdf_readSetContentEndIndices( meta_handle, offset, count, H5T_NATIVE_LONG, offset_buffer, &status );
+    mhdf_readSetContentEndIndicesWithOpt( meta_handle, offset, count, H5T_NATIVE_LONG, offset_buffer, collIO, &status );
@@ -1589,9 +1589,9 @@
         while (content_remaining) {
           long content_count = content_len < content_remaining ?
                                2*(content_len/2) : content_remaining;
-          mhdf_readSetData( contents_handle, content_offset,
-                            content_count, H5T_NATIVE_LONG,
-                            content_buffer, &status );
+          mhdf_readSetDataWithOpt( contents_handle, content_offset,
+                                   content_count, H5T_NATIVE_LONG,
+                                   content_buffer, collIO, &status );
           if (set_map_intersect( flag_buffer[sets_offset],
@@ -1608,8 +1608,8 @@
       else if (long read_num = offset_buffer[sets_offset + sets_count - 1] - prev_idx) {
         assert(sets_count > 0);
-        mhdf_readSetData( contents_handle, prev_idx+1, read_num,
-                          H5T_NATIVE_LONG, content_buffer, &status );
+        mhdf_readSetDataWithOpt( contents_handle, prev_idx+1, read_num,
+                                 H5T_NATIVE_LONG, content_buffer, collIO, &status );
@@ -1655,20 +1655,28 @@
     if (!first) {
       range[0] = -1;
-      mhdf_readSetChildEndIndices( meta_handle, first+count-1, 1, H5T_NATIVE_LONG, range+1, &status );
+      mhdf_readSetChildEndIndicesWithOpt( meta_handle, first+count-1, 1,
+                                          H5T_NATIVE_LONG, range+1,
+                                          indepIO, &status );
     else if (count == 1) {
-      mhdf_readSetChildEndIndices( meta_handle, first-1, 2, H5T_NATIVE_LONG, range, &status );
+      mhdf_readSetChildEndIndicesWithOpt( meta_handle, first-1, 2,
+                                          H5T_NATIVE_LONG, range,
     else {
-      mhdf_readSetChildEndIndices( meta_handle, first-1, 1, H5T_NATIVE_LONG, range+1, &status );
+      mhdf_readSetChildEndIndicesWithOpt( meta_handle, first-1, 1,
@@ -1678,7 +1686,9 @@
     while (remaining) {
       count = std::min( buffer_size, remaining );
       remaining -= count;
-      mhdf_readSetParentsChildren( child_handle, offset, count, H5T_NATIVE_LONG, buffer, &status );
+      mhdf_readSetParentsChildrenWithOpt( child_handle, offset, count,
+                                          H5T_NATIVE_LONG, buffer,
       std::sort( buffer, buffer + count );
       count = std::unique( buffer, buffer + count ) - buffer;
@@ -1730,24 +1740,28 @@
       if (!first && !start_idx) { // first set
         range[0] = -1;
-        mhdf_readSetContentEndIndices( meta_handle, first+sets_offset-1, 1,
-                                       H5T_NATIVE_LONG, range+1, &status );
+        mhdf_readSetContentEndIndicesWithOpt( meta_handle, first+sets_offset-1,
+                                              1, H5T_NATIVE_LONG, range+1,
-        mhdf_readSetContentEndIndices( meta_handle, first+start_idx-1, 2,
-                                       H5T_NATIVE_LONG, range, &status );
+        mhdf_readSetContentEndIndicesWithOpt( meta_handle, first+start_idx-1,
+                                              2, H5T_NATIVE_LONG, range,
       else {
-        mhdf_readSetContentEndIndices( meta_handle, first+start_idx-1, 1,
+                                              1, H5T_NATIVE_LONG, range,
@@ -1758,7 +1772,9 @@
         assert( !ranged || !(remaining % 2) );
         long content_count = std::min( buffer_size, remaining );
         remaining -= content_count;
-        mhdf_readSetData( content_handle, offset, content_count, H5T_NATIVE_LONG, content_buffer, &status );
+        mhdf_readSetDataWithOpt( content_handle, offset, content_count,
+                                 H5T_NATIVE_LONG, content_buffer, indepIO,
+                                 &status );
         if (ranged) {
           hint = contained_set_file_ids.begin();
@@ -1821,7 +1837,8 @@
   for (p = file_ids.const_pair_begin(); p != file_ids.const_pair_end(); ++p) {
     long offset = p->first - fileInfo->sets.start_id;
-    mhdf_readSetFlags( meta_handle, offset, count, H5T_NATIVE_UINT, buff_iter, &status );
+    mhdf_readSetFlagsWithOpt( meta_handle, offset, count, H5T_NATIVE_UINT,
+                              buff_iter, indepIO, &status );
     offset += count;
@@ -2017,19 +2034,27 @@
   class ReadSetContents : public ReadHDF5::ContentReader {
-    const hid_t metaHandle, contentHandle, handleType;
+    const hid_t metaHandle, contentHandle, handleType, ioMode;
     MBInterface *const mb;
     const IDMap& idMap;
   public:
-    ReadSetContents( hid_t meta, hid_t content, hid_t handle_type, MBInterface* iface,
-                    const IDMap& id_map )
+    ReadSetContents( hid_t meta,
+                     hid_t content,
+                     hid_t handle_type,
+                     hid_t io_mode,
+                     MBInterface* iface,
+                     const IDMap& id_map )
                     : metaHandle(meta), contentHandle(content),
-                      handleType(handle_type), mb(iface), idMap(id_map)
+                      handleType(handle_type), ioMode(io_mode),
+                      mb(iface), idMap(id_map)
     void read_indices( long offset, long count, long* buffer, mhdf_Status& status )
-      { mhdf_readSetContentEndIndices( metaHandle, offset, count, H5T_NATIVE_LONG, buffer, &status ); }
+      { mhdf_readSetContentEndIndicesWithOpt( metaHandle, offset, count,
+                                              ioMode, &status ); }
     void read_contents( long offset, long count, MBEntityHandle* buffer, mhdf_Status& status )
-      { mhdf_readSetData( contentHandle, offset, count, handleType, buffer, &status ); }
+      { mhdf_readSetDataWithOpt( contentHandle, offset, count, handleType,
+                                 buffer, ioMode, &status ); }
     MBErrorCode store_data( MBEntityHandle set, long, MBEntityHandle* array, long len, bool ranged )
       if (ranged) {
@@ -2050,7 +2075,7 @@
   ReadSetContents tool( set_meta_data_table, set_contents_table,
-                        handleType, iFace, idMap );
+                        handleType, indepIO, iFace, idMap );
   return read_contents( tool, set_file_ids, fileInfo->sets.start_id, start_handle,
                         fileInfo->sets.count, set_contents_length, ranged_set_file_ids );
@@ -2063,19 +2088,29 @@
                                      long set_contents_length )
   class ReadSetChildren : public ReadHDF5::ContentReader {
     const IDMap& idMap;
   public:
-    ReadSetChildren( hid_t meta, hid_t content, hid_t handle_type, MBInterface* iface,
+    ReadSetChildren( hid_t meta,
+                     hid_t content,
+                     hid_t io_mode,
-      { mhdf_readSetChildEndIndices( metaHandle, offset, count, H5T_NATIVE_LONG, buffer, &status ); }
+      { mhdf_readSetChildEndIndicesWithOpt( metaHandle, offset, count,
-      { mhdf_readSetParentsChildren( contentHandle, offset, count, handleType, buffer, &status ); }
+      { mhdf_readSetParentsChildrenWithOpt( contentHandle, offset, count,
+                                            handleType, buffer, ioMode, &status );
       assert(!ranged);
@@ -2087,7 +2122,7 @@
   MBRange empty;
   ReadSetChildren tool( set_meta_data_table, set_contents_table,
                         fileInfo->sets.count, set_contents_length, empty );
@@ -2099,19 +2134,25 @@
   class ReadSetParents : public ReadHDF5::ContentReader {
     const IDMap& idMap;
   public:
-    ReadSetParents( hid_t meta, hid_t content, hid_t handle_type, MBInterface* iface,
+    ReadSetParents( hid_t meta, hid_t content, hid_t handle_type,
+                    hid_t io_mode, MBInterface* iface, const IDMap& id_map )
-      { mhdf_readSetParentEndIndices( metaHandle, offset, count, H5T_NATIVE_LONG, buffer, &status ); }
+      { mhdf_readSetParentEndIndicesWithOpt( metaHandle, offset, count,
       assert(!ranged);
@@ -2123,7 +2164,7 @@
   MBRange empty;
   ReadSetParents tool( set_meta_data_table, set_contents_table,
@@ -2149,18 +2190,25 @@
 MBErrorCode ReadHDF5::get_set_contents( const MBRange& sets, MBRange& file_ids )
   class GetContentList : public ReadHDF5::ContentReader {
     MBRange *const resultList;
   public:
-    GetContentList( hid_t meta, hid_t content, hid_t handle_type, MBRange* result_set )
+    GetContentList( hid_t meta, hid_t content, hid_t handle_type, hid_t io_mode,
+                    MBRange* result_set )
-                      handleType(handle_type), resultList(result_set)
+                      resultList(result_set)
       if (ranged) {
@@ -2201,7 +2249,7 @@
     return error(rval);
-  GetContentList tool( meta, contents, handleType, &file_ids );
+  GetContentList tool( meta, contents, handleType, indepIO, &file_ids );
   rval = read_contents( tool, sets, fileInfo->sets.start_id, junk,
                         fileInfo->sets.count, content_len, ranged );
   mhdf_closeData( filePtr, meta, &status );
@@ -2227,7 +2275,7 @@
     remaining -= count;
     mhdf_readAdjacencyWithOpt( table, offset, count, handleType, buffer + left_over,
-                               ioProp, &status );
+                               collIO, &status );
@@ -2625,7 +2673,7 @@
     file_ids.erase( file_ids.begin(), file_ids.begin() + (count - 1) );
     mhdf_readDenseTagWithOpt( data, first - start_id, count, hdf_read_type,
-                              dataBuffer, ioProp, &status );
+                              dataBuffer, indepIO, &status );
@@ -2703,8 +2751,8 @@
     long next_offset = offset + count;
     remaining -= count;
-    mhdf_readSparseTagEntitiesWithOpt( id_table, offset, count, handleType, idbuf,
+    mhdf_readSparseTagEntitiesWithOpt( id_table, offset, count, handleType,
+                                       idbuf, collIO, &status );
@@ -2728,16 +2776,22 @@
       while (j < count && 0 != idbuf[j])
         ++j;
-        // if we've reached the end and the chunk is fairly small,
+        // If we've reached the end and the chunk is fairly small,
         // shift to the front of the buffer and read more to avoid
         // small data reads when blocks get split due to the buffer
-        // size
-      if (j == count && 2*i >= count && remaining > count) {
+        // size.
+        // Skip this block if doing true parallel read because it would
+        // otherwise force us to use independent IO for reading the tag
+        // entity list even though we're reading the entire list on every
+        // processor.  For true parallel IO collIO and indepIO will be
+        // different.  For serial IO they will both be independent IO and
+        // for read & delete, they will both be collective IO.
+      if (collIO == indepIO && j == count && 2*i >= count && remaining > count) {
         long keep = j - i;
         memmove( idbuf, idbuf + i, sizeof(MBEntityHandle)*keep );
         long count2 = std::min( remaining - keep, count - keep );
         mhdf_readSparseTagEntitiesWithOpt( id_table, next_offset, count2, handleType,
-                                           idbuf+keep, ioProp, &status );
+                                           idbuf+keep, indepIO, &status );
         offset += i;
@@ -2757,7 +2811,7 @@
         // read tag values
       mhdf_readSparseTagValuesWithOpt( value_table, offset + i, j - i,
                                        hdf_read_type, databuf + i*read_size,
@@ -2868,7 +2922,7 @@
       // read entity IDs
     assert_range( handle_buffer, count * sizeof(MBEntityHandle) );
     mhdf_readSparseTagEntitiesWithOpt( ent_table, offset, count, handleType,
-                                       handle_buffer, ioProp, &status );
+                                       handle_buffer, collIO, &status );
@@ -2897,13 +2951,19 @@
         // size
         long keep = j - i;
         memmove( handle_buffer, handle_buffer + i, sizeof(MBEntityHandle)*keep );
           // read more entity IDs
         mhdf_readSparseTagEntitiesWithOpt( ent_table, next_offset, count2, handleType,
-                                           handle_buffer+keep, ioProp, &status );
+                                           handle_buffer+keep, indepIO, &status );
         offset += i;
@@ -2927,12 +2987,12 @@
         end_idx_buffer[0] = prev_end_idx;
         mhdf_readSparseTagIndicesWithOpt( off_table, offset + i,
                                           remaining_ent, H5T_NATIVE_LONG,
-                                          end_idx_buffer + 1, ioProp, &status );
+                                          end_idx_buffer + 1, indepIO, &status );
       else {
         mhdf_readSparseTagIndicesWithOpt( off_table, offset + i - 1,
                                           remaining_ent + 1, H5T_NATIVE_LONG,
-                                          end_idx_buffer, ioProp, &status );
+                                          end_idx_buffer, indepIO, &status );
@@ -2964,8 +3024,9 @@
           // Read the tag data
-        mhdf_readSparseTagValues( val_table, prev_end_idx + 1,
-                                  val_count, hdf_read_type, memptr, &status );
+        mhdf_readSparseTagValuesWithOpt( val_table, prev_end_idx + 1,
+                                         val_count, hdf_read_type, memptr,
Modified: MOAB/trunk/ReadHDF5.hpp
--- MOAB/trunk/ReadHDF5.hpp	2009-07-14 22:08:53 UTC (rev 3010)
+++ MOAB/trunk/ReadHDF5.hpp	2009-07-14 22:10:40 UTC (rev 3011)
@@ -15,7 +15,7 @@
  * \class  ReadHDF5
- * \brief  Read mesh from TSTT HDF5 file.
+ * \brief  Read mesh from MOAB HDF5 (.h5m) file.
  * \author Jason Kraftcheck
  * \date   18 April 2004
@@ -32,7 +32,7 @@
 #include "MBReaderIface.hpp"
 #include "RangeMap.hpp"
-class MB_DLL_EXPORT ReadHDF5 : public MBReaderIface
+class ReadHDF5 : public MBReaderIface
 public:
@@ -99,7 +99,11 @@
   hid_t handleType;
   //! read/write property handle
-  hid_t ioProp;
+  //! indepIO -> idependent IO during true parallel read
+  //! collIO  -> collective IO during true parallel read
+  //! Both are H5P_DEFAULT for serial IO and collective
+  //! when reading the entire file on all processors.
+  hid_t indepIO, collIO;
   MBErrorCode read_nodes( const MBRange& node_file_ids );
@@ -121,18 +125,23 @@
     // Scan all elements in group.  For each element for which all vertices
     // are contained in idMap (class member), read the element.  All new
     // elements are added to idMap.
+    // NOTE: Collective IO calls in parallel.
   MBErrorCode read_node_adj_elems( const mhdf_ElemDesc& group );
     // Scan all elements in specified file table.  For each element for
     // which all vertices are contained in idMap (class member), read the
     // element.  All new elements are added to idMap.
   MBErrorCode read_node_adj_elems( const mhdf_ElemDesc& group,
                                    hid_t connectivity_handle );
   //! Read poly(gons|hedra)
   MBErrorCode read_poly( const mhdf_ElemDesc& elems, const MBRange& file_ids );
-  //! Read specified elements and any adjacent elemnets of lower dimension
+  //! Read specified elements and any adjacent elements of lower dimension.
+  //! Assumes vertices are already read in.
   MBErrorCode read_elements_and_sides( const MBRange& file_ids );
   //! Read sets
@@ -212,6 +221,8 @@
   /**\brief Search for entities with specified tag values
+   *\NOTE For parallel reads, this function does collective IO.
    *\param tag_index  Index into info->tags specifying which tag to search.
    *\param sorted_values  List of tag values to check for, in ascending sorted
    *                  order.
@@ -225,6 +236,8 @@
    * Search a table of tag values, returning the indices into the table
    * at which matches were found.
    *\param info       Summary of data contained in file.
    *\param tag_table     HDF5/mhdf handle for tag values
    *\param table_size    Number of values in table
@@ -246,8 +259,9 @@
   MBErrorCode get_set_contents( const MBRange& sets, MBRange& file_ids );
-  /** Given a list of file IDs for entity sets, find all child sets
-   *  (at any depth) and append them to the MBRange of file IDs.
+  /** Given a list of file IDs for entity sets, find all contained
+   *  or child sets (at any depth) and append them to the MBRange
+   *  of file IDs.
   MBErrorCode read_set_ids_recursive( MBRange& sets_in_out,
                                       bool containted_sets,
