[MOAB-dev] r3010 - MOAB/trunk/tools/dagmc
kraftche at cae.wisc.edu
Tue Jul 14 17:08:53 CDT 2009
Author: kraftche
Date: 2009-07-14 17:08:53 -0500 (Tue, 14 Jul 2009)
New Revision: 3010
Modified:
MOAB/trunk/tools/dagmc/pt_vol_test.cc
MOAB/trunk/tools/dagmc/ray_fire_test.cc
MOAB/trunk/tools/dagmc/test_geom.cc
Log:
update tests for change to DagMC interface
Modified: MOAB/trunk/tools/dagmc/pt_vol_test.cc
--- MOAB/trunk/tools/dagmc/pt_vol_test.cc 2009-07-14 22:02:12 UTC (rev 3009)
+++ MOAB/trunk/tools/dagmc/pt_vol_test.cc 2009-07-14 22:08:53 UTC (rev 3010)
@@ -64,8 +64,13 @@
DagMC& dagmc = *DagMC::instance();
- rval = dagmc.load_file_and_init( filename, strlen(filename), 0, 0 );
+ rval = dagmc.load_file( filename, 0 );
if (MB_SUCCESS != rval) {
+ std::cerr << "Failed to load file." << std::endl;
+ return 2;
+ rval = dagmc.init_OBBTree( );
+ if (MB_SUCCESS != rval) {
std::cerr << "Failed to initialize DagMC." << std::endl;
return 2;
Modified: MOAB/trunk/tools/dagmc/ray_fire_test.cc
--- MOAB/trunk/tools/dagmc/ray_fire_test.cc 2009-07-14 22:02:12 UTC (rev 3009)
+++ MOAB/trunk/tools/dagmc/ray_fire_test.cc 2009-07-14 22:08:53 UTC (rev 3010)
@@ -87,12 +87,18 @@
if (i < argc) direction_az = atof(argv[i++]) * PI / 180.0;
- rval = dagmc.load_file_and_init( filename, strlen(filename), 0, 0, facet_tol);
+ rval = dagmc.load_file( filename, facet_tol );
+ return 2;
return 2;
MBEntityHandle vol = dagmc.entity_by_index(3, vol_idx);
if (0 == vol) {
std::cerr << "Problem getting first volume." << std::endl;
Modified: MOAB/trunk/tools/dagmc/test_geom.cc
--- MOAB/trunk/tools/dagmc/test_geom.cc 2009-07-14 22:02:12 UTC (rev 3009)
+++ MOAB/trunk/tools/dagmc/test_geom.cc 2009-07-14 22:08:53 UTC (rev 3010)
@@ -173,9 +173,14 @@
remove( filename );
+ return 2;
+ rval = dagmc.init_OBBTree();
return 2;
