[MOAB-dev] r2969 - MOAB/trunk
    bmsmith6 at wisc.edu
    Fri Jun 26 14:51:04 CDT 2009
Author: bmsmith
Date: 2009-06-26 14:51:04 -0500 (Fri, 26 Jun 2009)
New Revision: 2969
Modified:
   MOAB/trunk/ReadMCNP5.cpp
   MOAB/trunk/ReadMCNP5.hpp
Log:
I was surprised to learn that the meshtal file uses different connectivity ordering, depending upon
cylindrical vs. Cartesian mesh.
Modified: MOAB/trunk/ReadMCNP5.cpp
--- MOAB/trunk/ReadMCNP5.cpp	2009-06-25 02:50:32 UTC (rev 2968)
+++ MOAB/trunk/ReadMCNP5.cpp	2009-06-26 19:51:04 UTC (rev 2969)
@@ -317,7 +317,8 @@
                                 errors,
                                 tally_tag,
                                 error_tag,
-                                tally_meshset );
+                                tally_meshset,
+                                tally_coord_sys );
       if(MB_SUCCESS != result) return result;
       // add this tally's meshset to the output meshset
@@ -780,7 +781,8 @@
                                         double              *errors,
                                         MBTag               tally_tag,
                                         MBTag               error_tag,
-                                        MBEntityHandle      tally_meshset ) {
+                                        MBEntityHandle      tally_meshset,
+                                        coordinate_system   tally_coord_sys ) {
   MBErrorCode result;
   unsigned int index;
   MBEntityHandle start_element = 0;
@@ -798,16 +800,32 @@
       for (unsigned int k=0; k<planes[2].size()-1; k++) {
         index = start_vert + i + j*planes[0].size() + k*planes[0].size()*planes[1].size();
+        // for rectangular mesh, the file prints: x y z
+        // z changes the fastest and x changes the slowest.
+        // This means that the connectivitiy ordering is not consistent between
+        // rectangular and cylindrical mesh.
+        if(CARTESIAN == tally_coord_sys) {
+          connect[0] = index;
+          connect[1] = index + 1;
+          connect[2] = index + 1 + planes[0].size();
+          connect[3] = index +     planes[0].size();
+          connect[4] = index +                        planes[0].size()*planes[1].size();
+          connect[5] = index + 1 +                    planes[0].size()*planes[1].size();
+          connect[6] = index + 1 + planes[0].size() + planes[0].size()*planes[1].size();
+          connect[7] = index +     planes[0].size() + planes[0].size()*planes[1].size();
+        // for cylindrical mesh, the file prints: r z theta
+        // Theta changes the fastest and r changes the slowest.
+        } else if(CYLINDRICAL == tally_coord_sys) {
+          connect[2] = index + 1 +                    planes[0].size()*planes[1].size();
+          connect[3] = index +                        planes[0].size()*planes[1].size();
+          connect[4] = index +     planes[0].size();
+          connect[5] = index + 1 + planes[0].size();
+	} else return MB_NOT_IMPLEMENTED;
-        connect[0] = index;
-        connect[1] = index + 1;
-        connect[2] = index + 1 +                    planes[0].size()*planes[1].size();
-        connect[3] = index +                        planes[0].size()*planes[1].size();
-        connect[4] = index +     planes[0].size();
-        connect[5] = index + 1 + planes[0].size();
-        connect[6] = index + 1 + planes[0].size() + planes[0].size()*planes[1].size();
-        connect[7] = index +     planes[0].size() + planes[0].size()*planes[1].size();
 	connect += 8;
 	counter++;
Modified: MOAB/trunk/ReadMCNP5.hpp
--- MOAB/trunk/ReadMCNP5.hpp	2009-06-25 02:50:32 UTC (rev 2968)
+++ MOAB/trunk/ReadMCNP5.hpp	2009-06-26 19:51:04 UTC (rev 2969)
@@ -132,7 +132,8 @@
                                double              errors[],
                                MBTag               tally_tag,
                                MBTag               error_tag,
-                               MBEntityHandle      tally_meshset );
+                               coordinate_system   tally_coord_sys );
   MBErrorCode average_with_existing_tally( bool              debug,
                                            unsigned long int &new_nps,
