[MOAB-dev] MOAB distcheck failed.
    Nightly Test
    kraftche at cae.wisc.edu
    Fri Jun 26 02:00:24 CDT 2009
{ test ! -d moab-3.99 || { find moab-3.99 -type d ! -perm -200 -exec chmod u+w {} ';' && rm -fr moab-3.99; }; }
test -d moab-3.99 || mkdir moab-3.99
list='mhdf parallel . test tools doc doxygen'; for subdir in $list; do \
	  if test "$subdir" = .; then :; else \
	    test -d "moab-3.99/$subdir" \
	    || /bin/mkdir -p "moab-3.99/$subdir" \
	    || exit 1; \
	    distdir=`CDPATH="${ZSH_VERSION+.}:" && cd moab-3.99 && pwd`; \
	    top_distdir=`CDPATH="${ZSH_VERSION+.}:" && cd moab-3.99 && pwd`; \
	    (cd $subdir && \
	      make  \
	        top_distdir="$top_distdir" \
	        distdir="$distdir/$subdir" \
		am__remove_distdir=: \
		am__skip_length_check=: \
	        distdir) \
	      || exit 1; \
	  fi; \
	done
make[1]: Entering directory `/home/jason/moab/test/dist/mhdf'
make[1]: Leaving directory `/home/jason/moab/test/dist/mhdf'
make[1]: Entering directory `/home/jason/moab/test/dist/parallel'
list=''; for subdir in $list; do \
	    test -d "/home/jason/moab/test/dist/moab-3.99/parallel/$subdir" \
	    || /bin/mkdir -p "/home/jason/moab/test/dist/moab-3.99/parallel/$subdir" \
	    || exit 1; \
	    distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /home/jason/moab/test/dist/moab-3.99/parallel && pwd`; \
	    top_distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /home/jason/moab/test/dist/moab-3.99 && pwd`; \
	    (cd $subdir && \
	      make  \
	        distdir) \
	      || exit 1; \
	  fi; \
	done
make[1]: Leaving directory `/home/jason/moab/test/dist/parallel'
make[1]: Entering directory `/home/jason/moab/test/dist/test'
make[1]: *** No rule to make target `64bricks_512hex.cub', needed by `distdir'.  Stop.
make[1]: Leaving directory `/home/jason/moab/test/dist/test'
make: *** [distdir] Error 1
