[MOAB-dev] r2933 - in MOAB/trunk/tools/iMesh/python: . doc
jvporter at wisc.edu jvporter at wisc.edu
Fri Jun 5 16:37:22 CDT 2009
Author: jvporter
Date: 2009-06-05 16:37:21 -0500 (Fri, 05 Jun 2009)
New Revision: 2933
Modified:
   MOAB/trunk/tools/iMesh/python/doc/build.rst
   MOAB/trunk/tools/iMesh/python/setup.py
Log:
* Add documentation building support for setup.py
* Document documentation building (this is like the chicken and the egg)
Modified: MOAB/trunk/tools/iMesh/python/doc/build.rst
--- MOAB/trunk/tools/iMesh/python/doc/build.rst	2009-06-05 19:03:38 UTC (rev 2932)
+++ MOAB/trunk/tools/iMesh/python/doc/build.rst	2009-06-05 21:37:21 UTC (rev 2933)
@@ -31,6 +31,25 @@
 documentation (you're reading it!), `Sphinx <http://sphinx.pocoo.org/>`_ is
 required.
+Testing
+To run unit/regression tests on the package, you may specify ``test`` as an
+argument to `setup.py`. The test command also accepts a verbosity level (an
+integer), specified with ``-v`` or ``--verbosity``.
+Building Documentation
+The documentation that you're currently reading can be built from `setup.py` by
+specifying ``doc`` as an argument. This command supports the following options:
+| ``--builder=BUILDER`` | ``-b`` | documentation builder (default: html) |
+| ``--target=TARGET``   | ``-t`` | target directory for output           |
 With MOAB
Modified: MOAB/trunk/tools/iMesh/python/setup.py
--- MOAB/trunk/tools/iMesh/python/setup.py	2009-06-05 19:03:38 UTC (rev 2932)
+++ MOAB/trunk/tools/iMesh/python/setup.py	2009-06-05 21:37:21 UTC (rev 2933)
@@ -41,8 +41,8 @@
                              'iMesh_tag.c']
-class test(Command):
-    description = 'Execute tests'
+class TestCommand(Command):
+    description = 'Execute a variety of unit tests'
     user_options = [
         ('verbosity=', 'v', 'verbosity level')
@@ -74,6 +74,33 @@
         os.chdir(old)
+class DocCommand(Command):
+    description = 'Build documentation'
+    user_options = [
+        ('builder=', 'b', 'documentation builder'),
+        ('target=', 't', 'target directory')
+    def initialize_options(self):
+        self.builder = 'html'
+        self.target = None
+        self.root = os.path.normpath(os.path.join(
+                os.path.abspath(sys.argv[0]), '../doc'))
+    def finalize_options(self):
+        if not self.target:
+            self.target = '_build/' + self.builder
+        self.target = os.path.abspath(os.path.join(self.root, self.target))
+    def run(self):
+        old = os.getcwd()
+        os.chdir(self.root)
+        os.system('sphinx-build -b "%s" -d _build/doctrees . "%s"' %
+                  (self.builder, self.target))
+        os.chdir(old)
 setup(name = 'PyTAPS',
       version = '1.0b1',
       description = 'Python bindings for iBase and iMesh interfaces',
@@ -85,5 +112,6 @@
       ext_modules = [iBase, iMesh],
       py_modules = ['itaps.helpers'],
-      cmdclass = {'test' : test}
+      cmdclass = { 'test' : TestCommand,
+                   'doc'  : DocCommand }
