[MOAB-dev] r2932 - in MOAB/trunk: . m4
kraftche at cae.wisc.edu
Fri Jun 5 14:03:39 CDT 2009
Author: kraftche
Date: 2009-06-05 14:03:38 -0500 (Fri, 05 Jun 2009)
New Revision: 2932
Modified:
MOAB/trunk/configure.ac
MOAB/trunk/m4/compiler.m4
Log:
do not check for fortran compilers unless iMesh support is enabled
Modified: MOAB/trunk/configure.ac
--- MOAB/trunk/configure.ac 2009-06-05 06:16:36 UTC (rev 2931)
+++ MOAB/trunk/configure.ac 2009-06-05 19:03:38 UTC (rev 2932)
@@ -10,8 +10,43 @@
AC_CHECK_PROG( [SED], [sed], [sed], [true] )
+# iMesh
+CONFIGURE_FORTRAN=no
+AC_ARG_ENABLE( [imesh],
+[AC_HELP_STRING([--enable-imesh(=nofortran)],[Build iMesh interface. If optional
+'nofortran' argument is given, support for FORTRAN name mangling will be disabled.])
+AC_HELP_STRING([--disable-imesh],[Don't build support for iMesh interface.])],
+[DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --enable-imesh=\"${enableval}\""],
+[enableval=yes] )
+case $enableval in
+ yes)
+ ENABLE_imesh=yes
+ CONFIGURE_FORTRAN=yes
+ nofortran|NoFortran|noFORTRAN|NoFORTRAN|Nofortran)
+ ENABLE_imesh=yes
+ no)
+ ENABLE_imesh=no
+ AC_MSG_ERROR([Invalid argument to --enable-imesh : $enableval])
+esac
+AC_MSG_CHECKING([if iMesh support is to be built])
+AC_MSG_RESULT([$ENABLE_imesh])
+AM_CONDITIONAL([ENABLE_imesh],[test "xyes" == "x$ENABLE_imesh"])
+# Compilers
EXTRA_GNU_FLAGS='-Wall -pipe -pedantic'
-SNL_CHECK_COMPILERS
+SNL_CHECK_COMPILERS([yes],[yes],[$CONFIGURE_FORTRAN])
AM_CONDITIONAL(PARALLEL,[test "x$WITH_MPI" != "xno"])
LIBS="-lm"
@@ -277,37 +312,7 @@
MB_OPTIONAL_TOOL([gsets], [yes])
-# iMesh
-AC_ARG_ENABLE( [imesh],
-[AC_HELP_STRING([--enable-imesh(=nofortran)],[Build iMesh interface. If optional
-'nofortran' argument is given, support for FORTRAN name mangling will be disabled.])
-AC_HELP_STRING([--disable-imesh],[Don't build support for iMesh interface.])],
-[DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --enable-imesh=\"${enableval}\""],
-[enableval=yes] )
-case $enableval in
- yes)
- ENABLE_imesh=yes
- nofortran|NoFortran|noFORTRAN|NoFORTRAN|Nofortran)
- ENABLE_imesh=yes
- no)
- ENABLE_imesh=no
- AC_MSG_ERROR([Invalid argument to --enable-imesh : $enableval])
-esac
-AC_MSG_CHECKING([if iMesh support is to be built])
-AC_MSG_RESULT([$ENABLE_imesh])
-AM_CONDITIONAL([ENABLE_imesh],[test "xyes" == "x$ENABLE_imesh"])
# Zoltan
if test $ENABLE_mbzoltan = yes; then
Modified: MOAB/trunk/m4/compiler.m4
--- MOAB/trunk/m4/compiler.m4 2009-06-05 06:16:36 UTC (rev 2931)
+++ MOAB/trunk/m4/compiler.m4 2009-06-05 19:03:38 UTC (rev 2932)
@@ -25,9 +25,23 @@
# CXXFLAGS - C++ compiler flags
# WITH_MPI - 'yes' if parallel support, 'no' otherwise
+# Arguments: three strings that msut be either "yes" or "no".
+# - test for C compiler
+# - test for C++ compiler
+# - test for Fortran compiler
AC_DEFUN([SNL_CHECK_COMPILERS], [
+CHECK_CC="$1"
+CHECK_CXX="$2"
+CHECK_FC="$3"
+# If not specified or invalid value, change to yes.
+test "xno" = "x$CHECK_CC" || CHECK_CC=yes
+test "xno" = "x$CHECK_CXX" || CHECK_CXX=yes
+test "xno" = "x$CHECK_FC" || CHECK_FC=yes
# Save these before calling AC_PROG_CC or AC_PROG_CXX
# because those macros will modify them, and we want
# the original user values, not the autoconf defaults.
@@ -95,17 +109,31 @@
WITH_MPI=yes
esac
-AC_PROG_CC( [$CC_LIST] )
+if test "xno" != "x$CHECK_CC"; then
+ AC_PROG_CC( [$CC_LIST] )
+ SNL_CC_FLAGS
+else
+ CC=
+fi
AC_PROG_CPP
-AC_PROG_CXX( [$CXX_LIST] )
-AC_PROG_CXXCPP
-AC_PROG_FC( [$FC_LIST] )
-AC_PROG_F77( [$F77_LIST] )
+if test "xno" != "x$CHECK_CXX"; then
+ AC_PROG_CXX( [$CXX_LIST] )
+ AC_PROG_CXXCPP
+ SNL_CXX_FLAGS
+else
+ CXX=
+fi
+if test "xno" != "x$CHECK_FC"; then
+ AC_PROG_FC( [$FC_LIST] )
+ AC_PROG_F77( [$F77_LIST] )
+else
+ FC=
+ F77=
+fi
# Try to determine compiler-specific flags. This must be done
# before setting up libtool so that it can override libtool settings.
-SNL_CC_FLAGS
-SNL_CXX_FLAGS
CFLAGS="$USER_CFLAGS $SNL_CC_SPECIAL"
CXXFLAGS="$USER_CXXFLAGS $SNL_CXX_SPECIAL"
