[MOAB-dev] r2905 - in MOAB/trunk/tools/iMesh/python: . tools
    jvporter at wisc.edu
    Thu May 21 17:41:38 CDT 2009
Author: jvporter
Date: 2009-05-21 17:41:37 -0500 (Thu, 21 May 2009)
New Revision: 2905
Added:
   MOAB/trunk/tools/iMesh/python/tools/
   MOAB/trunk/tools/iMesh/python/tools/volume.py
Log:
Add basic version of volume comparison tool
Added: MOAB/trunk/tools/iMesh/python/tools/volume.py
--- MOAB/trunk/tools/iMesh/python/tools/volume.py	                        (rev 0)
+++ MOAB/trunk/tools/iMesh/python/tools/volume.py	2009-05-21 22:41:37 UTC (rev 2905)
@@ -0,0 +1,67 @@
+from numpy import *
+from numpy.linalg import *
+from itaps import *
+import sys
+from pylab import *
+def distance(v):
+    return sqrt(v[0]**2 + v[1]**2 + v[2]**2)
+def tet_volume(coords):
+    return abs(det( [coords[0]-coords[1],
+                     coords[1]-coords[2],
+                     coords[2]-coords[3]] )) / 6
+def hex_volume(coords):
+    # assumes not-quite logical vertex ordering
+    def subvolume(a,b,c,d,e):
+        base = ( distance(cross(b-a,d-a)) +
+                 distance(cross(c-a,d-a)) ) / 2
+        norm = cross(b-a,c-a)
+        norm = norm / distance(norm)
+        height = abs(dot(norm,e-a))
+        return base*height / 3
+    return subvolume(coords[0],coords[1],coords[3],coords[2],coords[7]) + \
+           subvolume(coords[0],coords[1],coords[4],coords[5],coords[7]) + \
+           subvolume(coords[1],coords[2],coords[5],coords[6],coords[7])
+def calc_volume(filename):
+    mesh = iMesh()
+    mesh.load(mesh.rootSet, filename)
+    volume = ndarray(mesh.getNumOfType(mesh.rootSet, iBase.type.region), float_)
+    x=0
+    for i in mesh.rootSet.iterate(iBase.type.region, iMesh.topology.all):
+        topo = mesh.getEntTopo(i)
+        curr = mesh.getVtxCoords( mesh.getEntAdj(i, iBase.type.vertex),
+                                  iBase.storageOrder.interleaved )
+        if topo == iMesh.topology.tetrahedron:
+            volume[x] = tet_volume(curr)
+        elif topo == iMesh.topology.hexahedron:
+            volume[x] = hex_volume(curr)
+        else:
+            assert(False)
+        x+=1
+    return volume
+if(len(sys.argv) != 3):
+    print "Usage: python volume.py file1 file2"
+    exit(1)
+volume_pre  = calc_volume(sys.argv[1])
+volume_post = calc_volume(sys.argv[2])
+r = arange(len(volume_pre))
+print volume_pre
+plot(r, volume_pre,  linewidth=1)
+plot(r, volume_post, linewidth=1)
+xlabel('polyhedron index')
+ylabel('volume')
+title('Volume comparison pre- and post-deformation')
+show()
