[MOAB-dev] r2904 - in MOAB/trunk/tools/iMesh/python: . doc
jvporter at wisc.edu
Thu May 21 16:22:28 CDT 2009
Author: jvporter
Date: 2009-05-21 16:22:28 -0500 (Thu, 21 May 2009)
New Revision: 2904
Added:
MOAB/trunk/tools/iMesh/python/doc/
MOAB/trunk/tools/iMesh/python/doc/index.rst
Modified:
MOAB/trunk/tools/iMesh/python/setup.py
Log:
Begin some basic documentation for Python interface
Added: MOAB/trunk/tools/iMesh/python/doc/index.rst
--- MOAB/trunk/tools/iMesh/python/doc/index.rst (rev 0)
+++ MOAB/trunk/tools/iMesh/python/doc/index.rst 2009-05-21 21:22:28 UTC (rev 2904)
@@ -0,0 +1,25 @@
+ PyTAPS
+About PyTAPS
+PyTAPS is a Python package designed to interface with ITAPS, focusing on the
+iMesh interface.
+Building PyTAPS
+Like most Python packages, PyTAPS uses Distutils for installation, so in general
+setup consists simply of typing ``python setup.py install`` at the root
+directory for PyTAPS. However, certain iMesh interfaces may require some
+additional setup.
+With MOAB
+Since Python modules are loaded as shared libraries, MOAB's iMesh library needs
+to be built with position-independent code. When configuring MOAB, specify
+``--with-pic`` on the command line.
Modified: MOAB/trunk/tools/iMesh/python/setup.py
--- MOAB/trunk/tools/iMesh/python/setup.py 2009-05-21 18:05:53 UTC (rev 2903)
+++ MOAB/trunk/tools/iMesh/python/setup.py 2009-05-21 21:22:28 UTC (rev 2904)
@@ -18,6 +18,8 @@
setup(name = 'PyTAPS',
version = '0.1',
description = 'Python bindings for iBase and iMesh interfaces',
+ author = 'Jim Porter',
+ author_email = 'jvporter at wisc.edu',
packages = ['itaps'],
ext_modules = [iBase, iMesh]
