[MOAB-dev] MOAB check for *AMD64* failed.
    Nightly Test
    kraftche at cae.wisc.edu
    Sun May 17 02:04:00 CDT 2009
Making check in mhdf
make[1]: Entering directory `/home/jason/moab/test/AMD64/mhdf'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/jason/moab/test/AMD64/mhdf'
Making check in .
make[1]: Entering directory `/home/jason/moab/test/AMD64'
make  moab_test homxform_test scdseq_test tqdcfr test_adj seq_man_test geom_util_test xform_test obb_test vtk_test adaptive_kd_tree_tests bsp_tree_test file_options_test kd_tree_test var_len_test var_len_test_no_template tag_test mesh_set_test cub_file_test exodus_test mbcn_test kd_tree_tool kd_tree_time
make[2]: Entering directory `/home/jason/moab/test/AMD64'
c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DCGM -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS  -I/home/jason/cgm/test/cubit/../trunk -I/home/jason/cgm/test/cubit/../trunk/util -I/home/jason/cgm/test/cubit/util -I/home/jason/cgm/test/cubit/../trunk/init -I/home/jason/cgm/test/cubit/init -I/home/jason/cgm/test/cubit/../trunk/geom -I/home/jason/cgm/test/cubit/geom -I/home/jason/cgm/test/cubit/../trunk/geom/ACIS -I/home/jason/cgm/test/cubit/../trunk/geom/virtual -I/home/jason/cgm/test/cubit/../trunk/geom/facet -I/home/jason/cgm/test/cubit/../trunk/geom/facetbool -I/home/jason/cgm/test/cubit/../trunk/geom/Cholla  -DCGM  -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MBTest.o -MD -MP -MF .deps/MBTest.Tpo -c -o MBTest.o ../src/MBTest.cpp
mv -f .deps/MBTest.Tpo .deps/MBTest.Po
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -R/home/jason/cgm/test/cubit/.libs  -R/opt/cubit-10.2-amd64/bin     -L/home/jason/cgm/test/cubit/.libs  -L/opt/cubit-10.2-amd64/bin  -o moab_test MBTest.o ./libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o moab_test MBTest.o  -L/home/jason/cgm/test/cubit/.libs -L/opt/cubit-10.2-amd64/bin ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz /home/jason/cgm/test/cubit/.libs/libcgm.a -lcubiti19 -lm   -Wl,--rpath -Wl,/home/jason/cgm/test/cubit/.libs -Wl,--rpath -Wl,/opt/cubit-10.2-amd64/bin
/usr/bin/ld: warning: libstdc++.so.5, needed by /opt/cubit-10.2-amd64/bin/libcubiti19.so, may conflict with libstdc++.so.6
/bin/sh ./libtool --tag=CXX   --mode=link c++ -DTEST -Wall -pipe -pedantic -g -Wall -pipe -pedantic -g -R/home/jason/cgm/test/cubit/.libs  -R/opt/cubit-10.2-amd64/bin     -L/home/jason/cgm/test/cubit/.libs  -L/opt/cubit-10.2-amd64/bin  -o homxform_test homxform_test-HomXform.o ./libMOAB.la -lm
c++ -DTEST -Wall -pipe -pedantic -g -Wall -pipe -pedantic -g -o homxform_test homxform_test-HomXform.o  -L/home/jason/cgm/test/cubit/.libs -L/opt/cubit-10.2-amd64/bin ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz /home/jason/cgm/test/cubit/.libs/libcgm.a -lcubiti19 -lm   -Wl,--rpath -Wl,/home/jason/cgm/test/cubit/.libs -Wl,--rpath -Wl,/opt/cubit-10.2-amd64/bin
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -R/home/jason/cgm/test/cubit/.libs  -R/opt/cubit-10.2-amd64/bin     -L/home/jason/cgm/test/cubit/.libs  -L/opt/cubit-10.2-amd64/bin  -o scdseq_test scdseq_test.o ./libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o scdseq_test scdseq_test.o  -L/home/jason/cgm/test/cubit/.libs -L/opt/cubit-10.2-amd64/bin ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz /home/jason/cgm/test/cubit/.libs/libcgm.a -lcubiti19 -lm   -Wl,--rpath -Wl,/home/jason/cgm/test/cubit/.libs -Wl,--rpath -Wl,/opt/cubit-10.2-amd64/bin
/bin/sh ./libtool --tag=CXX   --mode=link c++ -DTEST_TQDCFR -Wall -pipe -pedantic -g -Wall -pipe -pedantic -g -R/home/jason/cgm/test/cubit/.libs  -R/opt/cubit-10.2-amd64/bin     -L/home/jason/cgm/test/cubit/.libs  -L/opt/cubit-10.2-amd64/bin  -o tqdcfr tqdcfr-Tqdcfr.o ./libMOAB.la -lm
c++ -DTEST_TQDCFR -Wall -pipe -pedantic -g -Wall -pipe -pedantic -g -o tqdcfr tqdcfr-Tqdcfr.o  -L/home/jason/cgm/test/cubit/.libs -L/opt/cubit-10.2-amd64/bin ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz /home/jason/cgm/test/cubit/.libs/libcgm.a -lcubiti19 -lm   -Wl,--rpath -Wl,/home/jason/cgm/test/cubit/.libs -Wl,--rpath -Wl,/opt/cubit-10.2-amd64/bin
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -R/home/jason/cgm/test/cubit/.libs  -R/opt/cubit-10.2-amd64/bin     -L/home/jason/cgm/test/cubit/.libs  -L/opt/cubit-10.2-amd64/bin  -o test_adj test_adj.o ./libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o test_adj test_adj.o  -L/home/jason/cgm/test/cubit/.libs -L/opt/cubit-10.2-amd64/bin ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz /home/jason/cgm/test/cubit/.libs/libcgm.a -lcubiti19 -lm   -Wl,--rpath -Wl,/home/jason/cgm/test/cubit/.libs -Wl,--rpath -Wl,/opt/cubit-10.2-amd64/bin
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -R/home/jason/cgm/test/cubit/.libs  -R/opt/cubit-10.2-amd64/bin     -L/home/jason/cgm/test/cubit/.libs  -L/opt/cubit-10.2-amd64/bin  -o seq_man_test TestTypeSequenceManager.o ./libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o seq_man_test TestTypeSequenceManager.o  -L/home/jason/cgm/test/cubit/.libs -L/opt/cubit-10.2-amd64/bin ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz /home/jason/cgm/test/cubit/.libs/libcgm.a -lcubiti19 -lm   -Wl,--rpath -Wl,/home/jason/cgm/test/cubit/.libs -Wl,--rpath -Wl,/opt/cubit-10.2-amd64/bin
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -R/home/jason/cgm/test/cubit/.libs  -R/opt/cubit-10.2-amd64/bin     -L/home/jason/cgm/test/cubit/.libs  -L/opt/cubit-10.2-amd64/bin  -o geom_util_test GeomUtilTests.o ./libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o geom_util_test GeomUtilTests.o  -L/home/jason/cgm/test/cubit/.libs -L/opt/cubit-10.2-amd64/bin ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz /home/jason/cgm/test/cubit/.libs/libcgm.a -lcubiti19 -lm   -Wl,--rpath -Wl,/home/jason/cgm/test/cubit/.libs -Wl,--rpath -Wl,/opt/cubit-10.2-amd64/bin
/bin/sh ./libtool --tag=CXX   --mode=link c++ -DTEST -Wall -pipe -pedantic -g -Wall -pipe -pedantic -g -R/home/jason/cgm/test/cubit/.libs  -R/opt/cubit-10.2-amd64/bin     -L/home/jason/cgm/test/cubit/.libs  -L/opt/cubit-10.2-amd64/bin  -o xform_test xform_test-MBAffineXform.o ./libMOAB.la -lm
c++ -DTEST -Wall -pipe -pedantic -g -Wall -pipe -pedantic -g -o xform_test xform_test-MBAffineXform.o  -L/home/jason/cgm/test/cubit/.libs -L/opt/cubit-10.2-amd64/bin ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz /home/jason/cgm/test/cubit/.libs/libcgm.a -lcubiti19 -lm   -Wl,--rpath -Wl,/home/jason/cgm/test/cubit/.libs -Wl,--rpath -Wl,/opt/cubit-10.2-amd64/bin
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -R/home/jason/cgm/test/cubit/.libs  -R/opt/cubit-10.2-amd64/bin     -L/home/jason/cgm/test/cubit/.libs  -L/opt/cubit-10.2-amd64/bin  -o obb_test OBBTest.o ./libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o obb_test OBBTest.o  -L/home/jason/cgm/test/cubit/.libs -L/opt/cubit-10.2-amd64/bin ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz /home/jason/cgm/test/cubit/.libs/libcgm.a -lcubiti19 -lm   -Wl,--rpath -Wl,/home/jason/cgm/test/cubit/.libs -Wl,--rpath -Wl,/opt/cubit-10.2-amd64/bin
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -R/home/jason/cgm/test/cubit/.libs  -R/opt/cubit-10.2-amd64/bin     -L/home/jason/cgm/test/cubit/.libs  -L/opt/cubit-10.2-amd64/bin  -o vtk_test VtkTest.o ./libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o vtk_test VtkTest.o  -L/home/jason/cgm/test/cubit/.libs -L/opt/cubit-10.2-amd64/bin ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz /home/jason/cgm/test/cubit/.libs/libcgm.a -lcubiti19 -lm   -Wl,--rpath -Wl,/home/jason/cgm/test/cubit/.libs -Wl,--rpath -Wl,/opt/cubit-10.2-amd64/bin
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -R/home/jason/cgm/test/cubit/.libs  -R/opt/cubit-10.2-amd64/bin     -L/home/jason/cgm/test/cubit/.libs  -L/opt/cubit-10.2-amd64/bin  -o adaptive_kd_tree_tests adaptive_kd_tree_tests.o ./libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o adaptive_kd_tree_tests adaptive_kd_tree_tests.o  -L/home/jason/cgm/test/cubit/.libs -L/opt/cubit-10.2-amd64/bin ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz /home/jason/cgm/test/cubit/.libs/libcgm.a -lcubiti19 -lm   -Wl,--rpath -Wl,/home/jason/cgm/test/cubit/.libs -Wl,--rpath -Wl,/opt/cubit-10.2-amd64/bin
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -R/home/jason/cgm/test/cubit/.libs  -R/opt/cubit-10.2-amd64/bin     -L/home/jason/cgm/test/cubit/.libs  -L/opt/cubit-10.2-amd64/bin  -o bsp_tree_test bsp_tree_test.o ./libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o bsp_tree_test bsp_tree_test.o  -L/home/jason/cgm/test/cubit/.libs -L/opt/cubit-10.2-amd64/bin ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz /home/jason/cgm/test/cubit/.libs/libcgm.a -lcubiti19 -lm   -Wl,--rpath -Wl,/home/jason/cgm/test/cubit/.libs -Wl,--rpath -Wl,/opt/cubit-10.2-amd64/bin
make[2]: `file_options_test' is up to date.
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -R/home/jason/cgm/test/cubit/.libs  -R/opt/cubit-10.2-amd64/bin     -L/home/jason/cgm/test/cubit/.libs  -L/opt/cubit-10.2-amd64/bin  -o kd_tree_test kd_tree_test.o ./libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o kd_tree_test kd_tree_test.o  -L/home/jason/cgm/test/cubit/.libs -L/opt/cubit-10.2-amd64/bin ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz /home/jason/cgm/test/cubit/.libs/libcgm.a -lcubiti19 -lm   -Wl,--rpath -Wl,/home/jason/cgm/test/cubit/.libs -Wl,--rpath -Wl,/opt/cubit-10.2-amd64/bin
c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DCGM -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS  -I/home/jason/cgm/test/cubit/../trunk -I/home/jason/cgm/test/cubit/../trunk/util -I/home/jason/cgm/test/cubit/util -I/home/jason/cgm/test/cubit/../trunk/init -I/home/jason/cgm/test/cubit/init -I/home/jason/cgm/test/cubit/../trunk/geom -I/home/jason/cgm/test/cubit/geom -I/home/jason/cgm/test/cubit/../trunk/geom/ACIS -I/home/jason/cgm/test/cubit/../trunk/geom/virtual -I/home/jason/cgm/test/cubit/../trunk/geom/facet -I/home/jason/cgm/test/cubit/../trunk/geom/facetbool -I/home/jason/cgm/test/cubit/../trunk/geom/Cholla  -DCGM  -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT VarLenTagTest.o -MD -MP -MF .deps/VarLenTagTest.Tpo -c -o VarLenTagTest.o ../src/VarLenTagTest.cpp
In file included from ../src/VarLenTagTest.cpp:1:
../src/TestUtil.hpp:530: error: expected unqualified-id before â<â token
../src/TestUtil.hpp:530: error: expected â,â or â...â before â<â token
../src/TestUtil.hpp: In function âvoid check_equal()â:
../src/TestUtil.hpp:534: error: âAâ was not declared in this scope
../src/TestUtil.hpp:534: error: âBâ was not declared in this scope
../src/TestUtil.hpp:534: error: âsAâ was not declared in this scope
../src/TestUtil.hpp:534: error: âsBâ was not declared in this scope
../src/TestUtil.hpp:534: error: âlineâ was not declared in this scope
../src/TestUtil.hpp:534: error: âfileâ was not declared in this scope
make[2]: *** [VarLenTagTest.o] Error 1
make[2]: Leaving directory `/home/jason/moab/test/AMD64'
make[1]: *** [check-am] Error 2
make[1]: Leaving directory `/home/jason/moab/test/AMD64'
make: *** [check-recursive] Error 1
