[MOAB-dev] getNumEntSets not working to spec,	at least as I read it
    Jason Kraftcheck
    kraftche at cae.wisc.edu
    Tue May 12 13:52:39 CDT 2009
Mark Miller wrote:
> Hi Jason,
> when I call getNumEntSets with 'num_hops' set to say '1' and then call
> it again with num_hops set to say '2', then I'd expect the result from
> the second call to be at least as large as from the first call. Right?
> In other words, the way I read the spec. is that it returns the number
> of entity sets contained IN the specified set that are up to an
> including num_hops 'sets away' from the contained set. I am not seeing
> this with current version of MOAB. Haven't tested other impls.
Forwarding this to MOAB-dev.
