[MOAB-dev] Hi! This is Hong-Jun
Hong-Jun Kim hongjun at mcs.anl.gov
Thu May 7 11:45:56 CDT 2009
Hi! Folks.
When I install MOAB with HDF5 I have a problem to find libhdf5.so as follows.
> checking if HDF5 support is enabled... yes
> checking hdf5.h usability... yes
> checking hdf5.h presence... yes
> checking for hdf5.h... yes
> checking for H5Fopen in -lhdf5... no
> configure: WARNING: Could not find HDF5 library (-lhdf5)
> configure: WARNING: Support for native HDF5 file format disabled
I used "configure" for installing with following information.
1. configure line
  itaps:~/MOAB_DIR/moab-3.0.0> ./configure --with-hdf5=$HOME/5-1.8.2-linux-x86_64-shared --prefix=$HOME/MOAB
2. top-level hdf5 install directory
  ~/5-1.8.2-linux-x86_64-shared
3. status of libhdf5.so in my computer
 itaps:~/5-1.8.2-linux-x86_64-shared/lib> ls -l
   lrwxrwxrwx 1 hongjun collab      16 2009-05-06 16:00 libhdf5.so -> libhdf5.so.6.0.1
   -rwxr-xr-x 1 hongjun collab 2977705 2008-11-11 12:58 libhdf5.so.6.0.1
Can anybody give me an advice why MOAB "configure" can not find libhdf5.so?
I also attached my config.log file.
Thank you.
Hong-Jun
----- Original Message -----
To: "Hong-Jun Kim" <hongjun at mcs.anl.gov>
Sent: Thursday, May 7, 2009 10:48:08 AM GMT -06:00 US/Canada Central
Subject: Re: Hi! This is Hong-Jun
Hmm, can you send the configure line you used and a listing of the
top-level hdf5 install directory?  Also, send the output of config.log.
  Finally, send these messages to moab-dev at mcs.anl.gov, so other moab
people see them.
- tim
Hong-Jun Kim wrote:
> Dear Tim
> I would like to ask a question about installing MOAB, if you didn't depart from Madison yet?
> When I use "configure" for MOAB, even though I put HDF5 directory path, I got warning signs as follows.
> I think HDF5 directory is assigned correctly, because it can find hdf5.h file, but I don't know why it can not find libhdf5.so in HDF5 lib directory.
> Can you give me an advice for me?
> Thank you and see you soon.
> Hong-Jun
> From: "Tim Tautges" <tautges at mcs.anl.gov>
> Sent: Wednesday, May 6, 2009 3:30:40 PM GMT -06:00 US/Canada Central
> No, but you can now build cgm off of the cubit shared libraries, you
> just need to point the configure script to it (using --with-cubit=
> option).  On harley.mcs.anl.gov, cubit is in /sandbox/tautges/Cubit.
> Or, you can grab /sandbox/tautges/cubit10.2.64bit.tar.gz and install it
> on your desktop machine under your personal space.
> - tim
> Hong-Jun Kim wrote:
>> Dear Tim
>> Is there ACIS library in MCS?
>> Thanks.
>> Hong-Jun
>> Sent: Tuesday, May 5, 2009 3:48:01 PM GMT -06:00 US/Canada Central
>> Welcome!  I will be down the day after tomorrow.  In the mean time,
>> please try installing MOAB and CGM under your space on the machine; you
>> might have to build your own hdf5, not sure if it's in the green build
>> of the OS on your machine.  For instructions, see my ITAPS wiki (just
>> google it).
>> - tim
>> Hong-Jun Kim wrote:
>>> Dear Tim
>>> I finished my 2 day long orientation today and finally my computer is set up correctly.
>>> It is my first e-mail sent from this computer.
>>> I remember you will visit here, argonne this week and I think we can talk about my work at that time.
>>> Otherwise, please let me know to talk to you by e-mail.
>>> Thank you.
>>> Hong-Jun
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20090507/a6d646a2/attachment-0001.obj>
