[MOAB-dev] r2871 - MOAB/trunk
kraftche at cae.wisc.edu
Fri May 1 16:38:16 CDT 2009
Author: kraftche
Date: 2009-05-01 16:38:16 -0500 (Fri, 01 May 2009)
New Revision: 2871
Modified:
MOAB/trunk/MBCore.cpp
MOAB/trunk/MBCore.hpp
MOAB/trunk/MBInterface.hpp
MOAB/trunk/MeshSetSequence.cpp
MOAB/trunk/MeshSetSequence.hpp
MOAB/trunk/SequenceManager.hpp
MOAB/trunk/TypeSequenceManager.hpp
Log:
add get_entities_by_type and get_entities_by_dimension that pass back an std::vector<MBEntityHandle>
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp 2009-05-01 21:24:27 UTC (rev 2870)
+++ MOAB/trunk/MBCore.cpp 2009-05-01 21:38:16 UTC (rev 2871)
@@ -1243,6 +1243,35 @@
return result;
+MBErrorCode MBCore::get_entities_by_dimension(const MBEntityHandle meshset,
+ const int dimension,
+ std::vector<MBEntityHandle> &entities,
+ const bool recursive) const
+ MBErrorCode result = MB_SUCCESS;
+ if (meshset) {
+ const EntitySequence* seq;
+ result = sequence_manager()->find( meshset, seq );
+ if (MB_SUCCESS != result)
+ return result;
+ const MeshSetSequence* mseq = reinterpret_cast<const MeshSetSequence*>(seq);
+ result = mseq->get_dimension( sequence_manager(), meshset, dimension, entities, recursive );
+ else if (dimension > 3) {
+ sequence_manager()->get_entities( MBENTITYSET, entities );
+ result = MB_SUCCESS;
+ else {
+ for (MBEntityType this_type = MBCN::TypeDimensionMap[dimension].first;
+ this_type <= MBCN::TypeDimensionMap[dimension].second;
+ this_type++) {
+ sequence_manager()->get_entities( this_type, entities );
+ return result;
MBErrorCode MBCore::get_entities_by_type( const MBEntityHandle meshset,
const MBEntityType type,
MBRange &entities,
@@ -1265,6 +1294,28 @@
return result;
+MBErrorCode MBCore::get_entities_by_type( const MBEntityHandle meshset,
+ const MBEntityType type,
+ if (meshset) {
+ return result;
+ result = mseq->get_type( sequence_manager(), meshset, type, entities, recursive );
+ else {
+ sequence_manager()->get_entities( type, entities );
+ return result;
MBErrorCode MBCore::get_entities_by_type_and_tag(const MBEntityHandle meshset,
const MBTag *tags,
Modified: MOAB/trunk/MBCore.hpp
--- MOAB/trunk/MBCore.hpp 2009-05-01 21:24:27 UTC (rev 2870)
+++ MOAB/trunk/MBCore.hpp 2009-05-01 21:38:16 UTC (rev 2871)
@@ -331,11 +331,16 @@
MBRange entities;
get_entities_by_dimension( dimension, entities ); //get 2D MBEntityHandles in the database
\endcode */
- virtual MBErrorCode get_entities_by_dimension(const MBEntityHandle meshset,
+ virtual MBErrorCode get_entities_by_dimension( const MBEntityHandle meshset,
MBRange &entities,
const bool recursive = false) const;
+ const bool recursive = false) const;
//! Retrieves all entities in the data base of given type.
/** \param type MBEntityType of entities desired (ie, MeshHex, MeshEdge, MeshTri, etc )
\param entities Range in which entities of MBEntityType <em>type</em> are returned.
@@ -345,11 +350,16 @@
MBRange entities;
get_entities_by_dimension( type, entities ); //get MeshTet type MBEntityHandles in the database
\endcode */
- virtual MBErrorCode get_entities_by_type(const MBEntityHandle meshset,
+ virtual MBErrorCode get_entities_by_type( const MBEntityHandle meshset,
MBRange &entities,
virtual MBErrorCode get_entities_by_type_and_tag(const MBEntityHandle meshset,
const MBTag *tag_handles,
Modified: MOAB/trunk/MBInterface.hpp
--- MOAB/trunk/MBInterface.hpp 2009-05-01 21:24:27 UTC (rev 2870)
+++ MOAB/trunk/MBInterface.hpp 2009-05-01 21:38:16 UTC (rev 2871)
@@ -609,6 +609,11 @@
MBRange &entities,
const bool recursive = false) const = 0;
+ virtual MBErrorCode get_entities_by_dimension(const MBEntityHandle meshset,
+ const bool recursive = false) const = 0;
//! Retrieve all entities of a given type in the database or meshset.
/** Appends entities to list passed in.
\param meshset Meshset whose entities are being queried (zero if query is for entire mesh).
@@ -630,6 +635,11 @@
MBRange &entities,
+ virtual MBErrorCode get_entities_by_type(const MBEntityHandle meshset,
//! Retrieve entities in the database or meshset which have any or all of the tag(s) and (optionally)
//! value(s) specified.
/** \param meshset Meshset whose entities are being queried (zero if query is for entire mesh).
Modified: MOAB/trunk/MeshSetSequence.cpp
--- MOAB/trunk/MeshSetSequence.cpp 2009-05-01 21:24:27 UTC (rev 2870)
+++ MOAB/trunk/MeshSetSequence.cpp 2009-05-01 21:38:16 UTC (rev 2871)
@@ -172,6 +172,25 @@
MBErrorCode MeshSetSequence::get_dimension( const SequenceManager* seqman,
MBEntityHandle handle,
int dimension,
+ std::vector<MBEntityHandle>& entities,
+ bool recursive ) const
+ if (!recursive) {
+ get_set(handle)->get_entities_by_dimension( dimension, entities );
+ return MB_SUCCESS;
+ else {
+ std::vector<const MBMeshSet*> list;
+ MBErrorCode rval = recursive_get_sets( handle, seqman, &list );
+ for (std::vector<const MBMeshSet*>::iterator i = list.begin(); i != list.end(); ++i)
+ (*i)->get_entities_by_dimension( dimension, entities );
+ return rval;
+MBErrorCode MeshSetSequence::get_dimension( const SequenceManager* seqman,
+ MBEntityHandle handle,
+ int dimension,
MBRange& entities,
@@ -191,6 +210,28 @@
MBErrorCode MeshSetSequence::get_type( const SequenceManager* seqman,
MBEntityType type,
+ if (!recursive) {
+ get_set(handle)->get_entities_by_type( type, entities );
+ else if (type == MBENTITYSET) {
+ return recursive_get_sets( handle, seqman, 0, 0, &entities );
+ else {
+ (*i)->get_entities_by_type( type, entities );
+ return rval;
+MBErrorCode MeshSetSequence::get_type( const SequenceManager* seqman,
+ MBEntityType type,
MBRange& entities,
@@ -266,7 +307,8 @@
MBErrorCode MeshSetSequence::recursive_get_sets( MBEntityHandle start_set,
const SequenceManager* seq_sets,
std::vector<const MBMeshSet*>* sets,
- MBRange* set_handles )
+ MBRange* set_handles,
+ std::vector<MBEntityHandle>* set_vector )
std::set<MBEntityHandle> visited;
std::vector<MBEntityHandle> stack;
@@ -305,6 +347,12 @@
for (it = visited.begin(); it != visited.end(); ++it)
hint = set_handles->insert( hint, *it, *it );
+ if (set_vector) {
+ if (remove_start_set)
+ visited.erase( start_set );
+ std::copy( visited.begin(), visited.end(), std::back_inserter(*set_vector) );
return MB_SUCCESS;
Modified: MOAB/trunk/MeshSetSequence.hpp
--- MOAB/trunk/MeshSetSequence.hpp 2009-05-01 21:24:27 UTC (rev 2870)
+++ MOAB/trunk/MeshSetSequence.hpp 2009-05-01 21:38:16 UTC (rev 2871)
@@ -74,7 +74,9 @@
MBErrorCode get_entities( MBEntityHandle set, std::vector<MBEntityHandle>& entities ) const;
MBErrorCode get_entities( SequenceManager const* seqman, MBEntityHandle set, MBRange& entities, bool recursive ) const;
+ MBErrorCode get_dimension( SequenceManager const* seqman, MBEntityHandle set, int dim, std::vector<MBEntityHandle>& entities, bool recursive ) const;
MBErrorCode get_dimension( SequenceManager const* seqman, MBEntityHandle set, int dim, MBRange& entities, bool recursive ) const;
+ MBErrorCode get_type( SequenceManager const* seqman, MBEntityHandle set, MBEntityType type, std::vector<MBEntityHandle>& entities, bool recursive ) const;
MBErrorCode get_type( SequenceManager const* seqman, MBEntityHandle set, MBEntityType type, MBRange& entities, bool recursive ) const;
MBErrorCode num_entities( SequenceManager const* seqman, MBEntityHandle set, int& count, bool recursive ) const;
@@ -102,7 +104,8 @@
static MBErrorCode recursive_get_sets( MBEntityHandle start_set,
SequenceManager const* set_sequences,
std::vector<const MBMeshSet*>* sets_out = 0,
- MBRange* set_handles_out = 0 );
+ MBRange* set_handles_out = 0,
+ std::vector<MBEntityHandle>* set_handle_vect_out = 0 );
SequenceManager* set_sequences,
std::vector<MBMeshSet*>& sets_out );
Modified: MOAB/trunk/SequenceManager.hpp
--- MOAB/trunk/SequenceManager.hpp 2009-05-01 21:24:27 UTC (rev 2870)
+++ MOAB/trunk/SequenceManager.hpp 2009-05-01 21:38:16 UTC (rev 2871)
@@ -37,6 +37,10 @@
void get_entities( MBEntityType type, MBRange& entities_out ) const
{ typeData[type].get_entities( entities_out ); }
+ /** Get all entities of a given MBEntityType */
+ void get_entities( MBEntityType type, std::vector<MBEntityHandle>& entities_out ) const
+ { typeData[type].get_entities( entities_out ); }
/** Count entities of a given MBEntityType */
MBEntityID get_number_entities( MBEntityType type ) const
{ return typeData[type].get_number_entities(); }
Modified: MOAB/trunk/TypeSequenceManager.hpp
--- MOAB/trunk/TypeSequenceManager.hpp 2009-05-01 21:24:27 UTC (rev 2870)
+++ MOAB/trunk/TypeSequenceManager.hpp 2009-05-01 21:38:16 UTC (rev 2871)
@@ -5,6 +5,7 @@
#include "MBRange.hpp"
#include <set>
+#include <vector>
class TagServer;
/**\brief Maintain data structures organizing EntitySequence instances
@@ -181,6 +182,9 @@
/**\brief Get handles for all entities in all sequences. */
inline void get_entities( MBRange& entities_out ) const;
+ /**\brief Get handles for all entities in all sequences. */
+ inline void get_entities( std::vector<MBEntityHandle>& entities_out ) const;
/**\brief Get number of entities represented by all sequences. */
inline MBEntityID get_number_entities() const;
@@ -422,6 +426,13 @@
in = entities_out.insert( in, (*i)->start_handle(), (*i)->end_handle() );
+inline void TypeSequenceManager::get_entities( std::vector<MBEntityHandle>& entities_out ) const
+ for (const_iterator i = begin(); i != end(); ++i)
+ for (MBEntityHandle j = (*i)->start_handle(); j <= (*i)->end_handle(); ++j)
+ entities_out.push_back( j );
inline MBEntityID TypeSequenceManager::get_number_entities() const
MBEntityID count = 0;
