[MOAB-dev] r2870 - in MOAB/branches/parallel_ghosting: . parallel
    tautges at mcs.anl.gov
    Fri May  1 16:24:28 CDT 2009
Author: tautges
Date: 2009-05-01 16:24:27 -0500 (Fri, 01 May 2009)
New Revision: 2870
Modified:
   MOAB/branches/parallel_ghosting/MBParallelConventions.h
   MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp
   MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp
   MOAB/branches/parallel_ghosting/parallel/Makefile.am
   MOAB/branches/parallel_ghosting/parallel/mbparallelcomm_test.cpp
   MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp
   MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp
Log:
Extensive changes to ghost exchange code.  Maybe this one is really it...
Added a PSTATUS_MULTISHARED, which gets rid of need to check sharedp_tag
in some cases.
Modified: MOAB/branches/parallel_ghosting/MBParallelConventions.h
--- MOAB/branches/parallel_ghosting/MBParallelConventions.h	2009-05-01 18:51:00 UTC (rev 2869)
+++ MOAB/branches/parallel_ghosting/MBParallelConventions.h	2009-05-01 21:24:27 UTC (rev 2870)
@@ -73,14 +73,16 @@
  * bit 0: !owned (0=owned, 1=not owned)
  * bit 1: shared (0=not shared, 1=shared)
- * bit 2: interface (0=not interface, 1=interface)
- * bit 3: ghost (0=not ghost, 1=ghost)
+ * bit 2: multishared (shared by > 2 procs; 0=not shared, 1=shared)
+ * bit 3: interface (0=not interface, 1=interface)
+ * bit 4: ghost (0=not ghost, 1=ghost)
 #define PARALLEL_STATUS_TAG_NAME "__PARALLEL_STATUS"
 #define PSTATUS_NOT_OWNED 0x1
 #define PSTATUS_SHARED 0x2
-#define PSTATUS_INTERFACE 0x4
-#define PSTATUS_GHOST 0x8
+#define PSTATUS_MULTISHARED 0x4
+#define PSTATUS_INTERFACE 0x8
+#define PSTATUS_GHOST 0x16
 #endif
Modified: MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp
--- MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp	2009-05-01 18:51:00 UTC (rev 2869)
+++ MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp	2009-05-01 21:24:27 UTC (rev 2870)
@@ -146,7 +146,7 @@
 MBParallelComm::MBParallelComm(MBInterface *impl, MPI_Comm comm, int* id )
         : mbImpl(impl), procConfig(comm),
-          sharedpTag(0), sharedpsTag(0),
+          sharedpTag(0), sharedpsTag(0), tmpifaceTag(0),
           sharedhTag(0), sharedhsTag(0), pstatusTag(0), ifaceSetsTag(0),
           partitionTag(0), globalPartCount(-1), partitioningSet(0)
@@ -175,7 +175,7 @@
                                MPI_Comm comm,
                                int* id)
@@ -315,103 +315,6 @@
   return MB_SUCCESS;
-MBErrorCode MBParallelComm::send_entities(const int to_proc,
-                                          MBRange &orig_ents,
-                                          const bool adjs,
-                                          const bool tags,
-                                          const bool store_remote_handles,
-                                          MBRange &final_ents,
-                                          bool wait_all)
-    // find a spot in the proc buffers vector
-  int index = get_buffers(to_proc);
-    // pack/send the entities to the destination
-  MPI_Request req_vec[2] = {MPI_REQUEST_NULL,  // send req (ownerSBuff)
-                             MPI_REQUEST_NULL}; // recv req (remote handles)
-  MBErrorCode result = pack_send_entities(to_proc, orig_ents,
-                                          adjs, tags, store_remote_handles, false,
-                                          ownerSBuffs[index], ownerRBuffs[index],
-                                          req_vec[0], req_vec[1], final_ents);
-  RRA("Failed to pack-send entities.");
-  MPI_Status statuses[2];
-    // if we're storing remote handles, process the return message
-  if (store_remote_handles) {
-    assert(MPI_REQUEST_NULL != req_vec[1]);
-    MPI_Wait(&req_vec[1], &statuses[1]);
-    MBRange remote_range;
-    unsigned char *buff_ptr = &ownerRBuffs[index][0];
-    UNPACK_RANGE(buff_ptr, remote_range);
-    result = set_remote_data(final_ents, remote_range, to_proc);
-    RRA("Trouble setting remote data range on sent entities.");
-  if (wait_all) {
-      // wait for all to finish
-    int success = MPI_Waitall(2, req_vec, statuses);
-    if (success != MPI_SUCCESS) {
-      result = MB_FAILURE;
-      RRA("Failed in waitall in send_entities.");
-  return MB_SUCCESS;
-MBErrorCode MBParallelComm::recv_entities(const int from_proc,
-                                          bool wait_all)
-  MBErrorCode result;
-  int index = get_buffers(from_proc);
-    // recv/unpack entities from the sender
-  MPI_Request req = MPI_REQUEST_NULL;
-  MPI_Status status;
-  int success = MPI_Recv(&ghostRBuffs[index][0], ghostRBuffs[index].size(),
-                         MPI_UNSIGNED_CHAR, from_proc,
-                         MB_MESG_ANY, procConfig.proc_comm(),
-                         &status);
-  if (MPI_SUCCESS != success) {
-    RRA("Recv failed in recv_ents.");
-    // check type, and if it's just the size, resize buffer and re-call recv
-  if (MB_MESG_SIZE == status.MPI_TAG) {
-    result = recv_size_buff(from_proc,
-                            ghostRBuffs[index],
-                            req, MB_MESG_ANY);
-    RRA("Failed to resize recv buffer.");
-    MPI_Wait(&req, &status);
-    // ok, got the actual entities, now unpack
-  result = recv_unpack_entities(from_proc, store_remote_handles, false,
-                                ghostRBuffs[index], ghostSBuffs[index],
-                                req, final_ents);
-  RRA("Failed to recv-unpack message.");
-  if (wait_all) {
-      // wait for last message to finish
-    int success = MPI_Wait(&req, &status);
-      RRA("Failed in wait in recv_entities.");
-  return result;
 int MBParallelComm::get_buffers(int to_proc, bool *is_new)
   int ind = -1;
@@ -425,7 +328,6 @@
       // allocate these other buffs in case we're storing remote handles
     ownerRBuffs.push_back(std::vector<unsigned char>(INITIAL_BUFF_SIZE));
     ghostSBuffs.push_back(std::vector<unsigned char>(INITIAL_BUFF_SIZE));
-    sharedEnts.push_back(GhostStruct());
     if (is_new) *is_new = true;
   else {
@@ -436,75 +338,6 @@
   return ind;
-MBErrorCode MBParallelComm::pack_send_entities(const int to_proc,
-                                               std::set<int> &addl_procs,
-                                               const bool iface_layer,
-                                               std::vector<unsigned char> &send_buff,
-                                               std::vector<unsigned char> &recv_buff,
-                                               MPI_Request &send_req,
-                                               MPI_Request &recv_req)
-#ifndef USE_MPI
-  return MB_FAILURE;
-#else
-  MBErrorCode result = MB_SUCCESS;
-  MBRange whole_range;
-    // get an estimate of the buffer size
-  int buff_size = estimate_ents_buffer_size(orig_ents, store_remote_handles);
-  send_buff.clear();
-  send_buff.reserve(buff_size);
-  result = pack_buffer(orig_ents, addl_procs,
-                       store_remote_handles, iface_layer, to_proc,
-                       send_buff, buff_size);
-  RRA("Failed to pack buffer in pack_send.");
-    // now that we know how many entities, post a receive for the
-    // remote range, if requested
-  int success;
-  if (store_remote_handles && iface_layer) {
-    recv_buff.resize(final_ents.size()*sizeof(MBEntityHandle) + sizeof(int));
-    success = MPI_Irecv(&recv_buff[0], recv_buff.size(), MPI_UNSIGNED_CHAR, to_proc,
-                        MB_MESG_REMOTE_HANDLES_VECTOR, procConfig.proc_comm(),
-                        &recv_req);
-    if (success != MPI_SUCCESS) return MB_FAILURE;
-  else if (store_remote_handles && !iface_layer) {
-    recv_buff.resize(2*num_subranges(final_ents)*sizeof(MBEntityHandle) + sizeof(int));
-                        MB_MESG_REMOTE_HANDLES_RANGE, procConfig.proc_comm(),
-                        &recv_req);
-    // if the message is large, send a first message to tell how large
-  int success;
-  if (INITIAL_BUFF_SIZE < buff_size) {
-    int tmp_buff_size = -buff_size;
-    success = MPI_Isend(&tmp_buff_size, sizeof(int), MPI_UNSIGNED_CHAR,
-                            to_proc, MB_MESG_SIZE, procConfig.proc_comm(),
-                            &send_req);
-    // send the buffer
-  success = MPI_Isend(&send_buff[0], buff_size, MPI_UNSIGNED_CHAR, to_proc,
-                      MB_MESG_ENTS, procConfig.proc_comm(), &send_req);
-  return result;
-#endif
 MBErrorCode MBParallelComm::send_buffer(const unsigned int to_proc,
                                         const unsigned char *send_buff,
                                         const unsigned int buff_size,
@@ -569,13 +402,11 @@
   std::vector<unsigned char> buff;
   std::vector<int> addl_procs;
   if ((int)procConfig.proc_rank() == from_proc) {
-    MBRange tmp_ents;
     result = add_verts(entities);
     RRA("Failed to add adj vertices.");
-    entities.swap(tmp_ents);
-    result = pack_buffer( entities, addl_procs, adjacencies, tags,
-                          false, -1, tmp_ents, buff, buff_size);
+    result = pack_buffer( entities, adjacencies, tags,
+                          false, -1, buff, buff_size);
     RRA("Failed to compute buffer size in broadcast_entities.");
@@ -598,9 +429,11 @@
   if ((int)procConfig.proc_rank() != from_proc) {
-    std::set<unsigned int> my_addl_procs;
-    result = unpack_buffer(&buff[0], false, from_proc, -1, entities,
-                           NULL, my_addl_procs);
+    std::vector<std::vector<MBEntityHandle> > dum1;
+    std::vector<MBEntityHandle> dum2;
+    std::vector<unsigned int> dum3;
+    result = unpack_buffer(&buff[0], false, from_proc, -1,
+                           dum1, dum2, dum2, dum3, entities);
     RRA("Failed to unpack buffer in broadcast_entities.");
@@ -609,68 +442,18 @@
 MBErrorCode MBParallelComm::pack_buffer(MBRange &orig_ents,
-                                        std::vector<int> &addl_procs,
                                         const bool adjacencies,
                                         const bool tags,
                                         const int to_proc,
-                                        MBRange &owned_shared,
                                         std::vector<unsigned char> &buff,
                                         int &buff_size)
     // pack the buffer with the entity ranges, adjacencies, and tags sections
-    // if do_filter is true, remove already shared entities and add adj vertices
     // Note: new entities used in subsequent connectivity lists, sets, or tags,
     //   are referred to as (MBMAXTYPE + index), where index is into vector
     //   of new entities, 0-based
-    // DATA LAYOUT IN BUFFER:
-    // . w/ handles ? (0-no, 1-yes, range, 2-yes, vector)
-    // OWNING PROC INFO:
-    // . # owning proc tuples
-    // . for each tuple:
-    //   - index in entities in this message
-    //   - proc owning this entity
-    //   - handle on owning proc
-    // ENTITIES:
-    // . for all types:
-    //   - ent_type -- end of data indicated by ent_type == MBMAXTYPE
-    //   - range(ent type) -- #ents = range.size()
-    //   - if (ent_type == MBVERTEX) xxx[#ents], yyy[#ents], zzz[#ents]
-    //   - else {
-    //     . nodes_per_ent
-    //     . connect[#ents * nodes_per_ent]
-    //   - if (handles) range/vector of remote handles
-    // SETS:
-    // . range of set handles -- (#sets = range.size())
-    // . options[#sets] (unsigned int)
-    // . if (unordered) set range
-    // . else if ordered
-    //   - #ents in set
-    //   - handles[#ents]
-    // . #parents
-    // . if (#parents) handles[#parents]
-    // . #children
-    // . if (#children) handles[#children]
-    // ADJACENCIES:
-    // (no adjs for now)
-    // TAGS:
-    // . #tags
-    // . for each tag
-    //   - tag size
-    //   - tag type
-    //   - data type
-    //   - if (default value)
-    //     . 1
-    //     . default value
-    //   - else
-    //     . 0
-    //   - name (null-terminated string, in char[64])
-    //   - range (size = #ents)
-    //   - tag_vals[#ents]
   MBErrorCode result;
   MBRange set_range;
@@ -691,7 +474,7 @@
     // entities
   result = pack_entities(orig_ents, buff, buff_ptr,
-                         store_remote_handles, to_proc, true, owned_shared);
+                         store_remote_handles, to_proc, false);
   RRA("Packing entities failed.");
     // sets
@@ -716,9 +499,11 @@
                                           const int ind,
-                                          MBRange *nonowned_ghosts,
-                                          std::set<unsigned int> &my_addl_procs)
+                                          std::vector<std::vector<MBEntityHandle> > &L1h,
+                                          std::vector<MBEntityHandle> &L2hloc,
+                                          std::vector<MBEntityHandle> &L2hrem,
+                                          std::vector<unsigned int> &L2p,
+                                          MBRange &new_ents)
   if (myBuffer.capacity() == 0) return MB_FAILURE;
@@ -727,21 +512,19 @@
 #endif
     MBErrorCode result;
     result = unpack_entities(buff_ptr, store_remote_handles,
-                             from_proc, ind, final_ents, nonowned_ghosts, my_addl_procs);
+                             ind, false, L1h, L2hloc, L2hrem, L2p, new_ents);
   RRA("Unpacking entities failed.");
 #ifdef DEBUG_PACKING
     std::cerr << "unpack_entities buffer space: " << buff_ptr - tmp_buff << " bytes." << std::endl;
     tmp_buff = buff_ptr;
 #endif
-  result = unpack_sets(buff_ptr, final_ents, store_remote_handles,
-                       from_proc);
+  result = unpack_sets(buff_ptr, new_ents, store_remote_handles, from_proc);
   RRA("Unpacking sets failed.");
     std::cerr << "unpack_sets buffer space: " << buff_ptr - tmp_buff << " bytes." << std::endl;
 #endif
-  result = unpack_tags(buff_ptr, final_ents, store_remote_handles,
-                       from_proc);
+  result = unpack_tags(buff_ptr, new_ents, store_remote_handles, from_proc);
   RRA("Unpacking tags failed.");
     std::cerr << "unpack_tags buffer space: " << buff_ptr - tmp_buff << " bytes." << std::endl;
@@ -856,92 +639,131 @@
                                           unsigned char *&buff_ptr,
                                           const int to_proc,
-                                          const bool is_ghost,
-                                          MBRange &owned_shared)
+                                          const bool is_iface,
+                                          std::vector<std::set<unsigned int> > *entprocs)
-    // pack a range of entities into a message, appending to buffer;
-    // buffer contains:
-    // . # non-owned (by sender) entities
-    // . for each NO entity: index in new ents, owning proc
-    // . for each NO entity: handle on owner
-    // . repeat:
-    //   - ent type
-    //   - # ents
-    //   - if type == vertex, xxx[#ents], yyy[#ents], zzz[#ents]
-    //   - else
-    //     . # nodes per entity
-    // . until type == MBMAXTYPE
-    // . if (store_remote_handles) range of local handles on sending proc
+    // packed information:
+    // 1. # entities = E
+    // 2. for e in E
+    //   a. # procs sharing e, incl. sender and receiver = P
+    //   b. for p in P (procs sharing e)
+    //   c. for p in P (handle for e on p) (Note1)
+    // 3. vertex/entity info
   MBWriteUtilIface *wu;
   MBErrorCode result = mbImpl->query_interface(std::string("MBWriteUtilIface"),
                                                reinterpret_cast<void**>(&wu));
   RRA("Couldn't get MBWriteUtilIface.");
-    // non-owned entities don't matter if remote handles aren't stored
-    // or if passing interface layer
-  if (store_remote_handles && is_ghost) {
-      // get owned, non-owned ents
-    MBRange owned_ents, nonowned_ents;
-    result = filter_owned_shared(entities,
-                                 true, true, false, false,
-                                 -1, &owned_ents);
-    RRA("Failed to get owned entities.");
-    if (owned_ents.size() != entities.size())
-      nonowned_ents = entities.subtract(owned_ents);
-      // pack index, proc, handle for nonowned ents
-    CHECK_BUFF_SPACE(buff, buff_ptr,
-                     sizeof(int) + (2*sizeof(int) +
-                                    sizeof(MBEntityHandle))*nonowned_ents.size());
+  unsigned int num_ents;
-    PACK_INT(buff_ptr, nonowned_ents.size());
-    if (!nonowned_ents.empty()) {
-      int proc;
-      std::vector<MBEntityHandle> handles;
-      handles.reserve(nonowned_ents.size());
-      MBEntityHandle handle;
-      for (MBRange::const_iterator rit = nonowned_ents.begin();
-           rit != nonowned_ents.end(); rit++) {
-        int idx = entities.index(*rit);
-        assert(-1 != idx);
-        result = get_owner_handle(*rit, proc, handle);
-        RRA("Failed to get owner and handle for entity.");
-        assert(proc != (int) procConfig.proc_rank() &&
-               to_proc != proc && 0 != handle);
-        PACK_INT(buff_ptr, idx);
-        PACK_INT(buff_ptr, proc);
-        handles.push_back(handle);
-      PACK_EH(buff_ptr, &handles[0], nonowned_ents.size());
+    // first pack procs/handles sharing this ent, not including this dest but including
+    // others (with zero handles)
+  if (store_remote_handles) {
-      // put owned shared in sharedEnts list
-    owned_shared.merge(owned_ents);
+      // buff space is at least proc+handle for each entity
+    CHECK_BUFF_SPACE(buff, buff_ptr,
+                     sizeof(int) + (sizeof(int) + sizeof(MBEntityHandle))*entities.size());
-    // else if we're sending interface ents, add all the entities
-    // to the ownedShared list
-  else if (!is_ghost)
-    owned_shared.merge(entities);
+    PACK_INT(buff_ptr, entities.size());
+    MBRange::iterator rit;
+      // pre-fetch sharedp and pstatus
+    std::vector<int> sharedp_vals(entities.size());
+    result = mbImpl->tag_get_data(sharedp_tag(), entities, &sharedp_vals[0]);
+    RRA("Failed to get sharedp_tag.");
+    std::vector<char> pstatus_vals(entities.size());
+    result = mbImpl->tag_get_data(pstatus_tag(), entities, &pstatus_vals[0]);
+    unsigned int i, j;
+    unsigned char *buff_tmp;
+    std::vector<std::set<unsigned int> >::iterator vit;
+    int tmp_procs[MAX_SHARING_PROCS];
+    MBEntityHandle zeroh = 0, tmp_handles[MAX_SHARING_PROCS];
-      // pack the local handles
-    int tmp_space = RANGE_SIZE(entities);
-    CHECK_BUFF_SPACE(buff, buff_ptr, tmp_space);
-    PACK_RANGE(buff_ptr, entities);
+      // 2. for e in E
+    for (rit = entities.begin(), i = 0;
+         rit != entities.end(); rit++, i++) {
+        // number of entities starts with # others (besides to_proc) being sent
+        // this entity in this message exchange, but only if not iface exchange
+      if (!is_iface && entprocs) num_ents = entprocs[i].size()-1;
+      else num_ents = 0;
+        // add number of procs/handles in shared handle list
+      if (!(pstatus_vals[i] & PSTATUS_SHARED))
+          // just sender and receiver
+        num_ents += 2;
+      else if (-1 != sharedp_vals[i])
+          // sender, receiver, and one other
+        num_ents += 3;
+      else {
+          // variable # already-sharing procs
+        buff_tmp = buff_ptr + sizeof(int);
+        result = mbImpl->tag_get_data(sharedps_tag(), entities, tmp_procs);
+        RRA("Failed to get sharedps tag.");
+        result = mbImpl->tag_get_data(sharedhs_tag(), entities, tmp_handles);
+        RRA("Failed to get sharedhs tag.");
+        j = 0;
+          // scan forward to first unoccupied shared proc or end of shared proc tag
+        while (j < MAX_SHARING_PROCS && tmp_procs[j] != -1)
+          j++;
+        num_ents += j;
+        assert(num_ents < MAX_SHARING_PROCS);
+                       num_ents*(sizeof(int)+sizeof(MBEntityHandle)) + sizeof(int));
+      PACK_INT(buff_ptr, num_ents);
+      buff_tmp = buff_ptr + num_ents*sizeof(int);
+        // pack procs/handles on sender/receiver first
+      PACK_INT(buff_ptr, procConfig.proc_rank());
+      PACK_EH(buff_tmp, &(*rit), 1);
+      PACK_INT(buff_ptr, to_proc);
+      PACK_EH(buff_tmp, &zeroh, 1);
+        // now other procs to which this ent is being sent, with zero handle for now,
+        // only if not on iface
+      if (!is_iface && entprocs) {
+        for (std::set<unsigned int>::iterator sit = (*entprocs)[i].begin();
+             sit != (*entprocs)[i].end(); sit++) {
+          if (to_proc == (int)*sit) continue;
+          PACK_INT(buff_ptr, *sit);
+        // now other sharing procs, again only if not iface
+      if (!is_iface) {
+        num_ents -= 2;
+        if (entprocs) num_ents -= entprocs[i].size();
+      for (j = 0; j < num_ents; j++) {
+          // only need to test for sending proc here, receiving proc
+          // won't be in that list, by def (otherwise we wouldn't be sending
+          // the entity there)
+        if (tmp_procs[j] == (int)procConfig.proc_rank()) continue;
+        assert(-1 != tmp_procs[j] && 0 != tmp_handles[j]);
+        PACK_INT(buff_ptr, tmp_procs[j]);
+        PACK_EH(buff_ptr, tmp_handles+j, 1);
     // pack vertices
   MBRange these_ents = entities.subset_by_type(MBVERTEX);
-  int num_ents = these_ents.size();
+  num_ents = these_ents.size();
   int buff_size;
-    // if iface, shouldn't be any vertices here
-  assert(is_ghost || num_ents == 0);
   if (num_ents) {
     buff_size = 2*sizeof(int) + 3*num_ents*sizeof(double);
     CHECK_BUFF_SPACE(buff, buff_ptr, buff_size);
@@ -1027,36 +849,6 @@
   return MB_SUCCESS;
-MBErrorCode MBParallelComm::pack_addl_procs(std::set<unsigned int> &addl_procs,
-                                            std::vector<unsigned char> &buff,
-                                            unsigned char *&buff_ptr)
-  int buff_size = (1 + addl_procs.size())*sizeof(int);
-  CHECK_BUFF_SPACE(buff, buff_ptr, buff_size);
-    // pack extra procs to_proc must communicate with
-  PACK_INT(buff_ptr, addl_procs.size());
-  for (std::set<unsigned int>::iterator sit = addl_procs.begin();
-       sit != addl_procs.end(); sit++)
-    PACK_INT(buff_ptr, *sit);
-MBErrorCode MBParallelComm::unpack_addl_procs(unsigned char *&buff_ptr,
-                                              std::set<unsigned int> &addl_procs)
-  int num_addl, tmp_addl;
-  UNPACK_INT(buff_ptr, num_addl);
-  for (int i = 0; i < num_addl; i++) {
-    UNPACK_INT(buff_ptr, tmp_addl);
-    addl_procs.insert(tmp_addl);
 MBErrorCode MBParallelComm::pack_entity_seq(const int nodes_per_entity,
                                             const int to_proc,
@@ -1289,123 +1081,178 @@
 MBErrorCode MBParallelComm::unpack_entities(unsigned char *&buff_ptr,
-                                            const unsigned int from_proc,
                                             const int from_ind,
-                                            MBRange &entities,
+    // general algorithm:
+    // - unpack # entities
+    // - save start of remote handle info, then scan forward to entity definition data
+    // - for all vertices or entities w/ same # verts:
+    //   . get entity type, num ents, and (if !vert) # verts
+    //   . for each ent:
+    //      o get # procs/handles in remote handle info
+    //      o if # procs/handles > 2, check for already-created entity:
+    //        x get index of owner proc (1st in proc list), resize L1 list if nec
+    //        x look for already-arrived entity in L2 by owner handle
+    //      o if no existing entity:
+    //        x if iface, look for existing entity with same connect & type
+    //        x if none found, create vertex or element
+    //        x if !iface & multi-shared, save on L2
+    //        x if !iface, put new entity on new_ents list
+    //      o update proc/handle, pstatus tags, adjusting to put owner first if iface
+    //      o if !iface, save new handle on L1 for all sharing procs
+    // lists of handles/procs to return to sending/other procs
+    // L1h[p]: handle pairs [h, h'], where h is the sending proc handle
+    //         and h' is the receiving proc handle; this list only for
+    //         entities shared only between 2 procs, i.e. new shared entities
+    // L2hloc, L2hrem: local/remote handles for entities shared by > 2 procs;
+    //         remote handles are on owning proc
+    // L2p: owning procs for handles in L2hrem
   MBErrorCode result;
   bool done = false;
   MBReadUtilIface *ru = NULL;
   result = mbImpl->query_interface(std::string("MBReadUtilIface"),
                                    reinterpret_cast<void**>(&ru));
   RRA("Failed to get MBReadUtilIface.");
+    // procs the sending proc is telling me I'll be receiving from
+  std::set<unsigned int> comm_procs;
+  int num_ents;
+  unsigned char *buff_save = buff_ptr;
+  int i, j;
+  unsigned int k;
-    // unpack any nonowned entities
-  int no_size = 0;
-  std::vector<unsigned int> no_indices, no_procs, o_indices;
-  std::vector<MBEntityHandle> no_handles, no_local_handles,
-      o_local_handles, o_handles;
-    UNPACK_INT(buff_ptr, no_size);
-    no_indices.resize(no_size);
-    no_procs.resize(no_size);
-    no_handles.resize(no_size);
-      // no_local_handles[i] = local entity equivalent to new entity i in
-      //     this message
-    for (int i = 0; i < no_size; i++) {
-      UNPACK_INT(buff_ptr, no_indices[i]);
-      UNPACK_INT(buff_ptr, no_procs[i]);
-      UNPACK_EH(buff_ptr, &no_handles[i], 1);
+    UNPACK_INT(buff_ptr, num_ents);
+      // save place where remote handle info starts, then scan forward to ents
+    for (i = 0; i < num_ents; i++) {
+      UNPACK_INT(buff_ptr, j);
+      buff_ptr += j * (sizeof(int)+sizeof(MBEntityHandle));
-      // unpack source handles; will be processed later
-    no_local_handles.resize(remote_range.size(), 0);
-      no_local_handles[no_indices[i]] =
-          find_ghost_entity(no_handles[i], no_procs[i]);
-      // look for existing ghost entities from nonowned procs
-    if (!sharedEnts[from_ind].noHandles.empty()) {
-      MBRange tmp_range = sharedEnts[from_ind].noHandles.intersect(remote_range);
-      for (MBRange::iterator rit = tmp_range.begin();
-           rit != tmp_range.end(); rit++) {
-        int idx = remote_range.index(*rit);
-        no_local_handles[idx] = find_ghost_entity(*rit, from_proc);
-  MBRange new_ents;
   while (!done) {
     MBEntityType this_type = MBMAXTYPE;
-    MBEntityHandle actual_start;
     UNPACK_INT(buff_ptr, this_type);
     assert(this_type >= MBVERTEX &&
            (this_type == MBMAXTYPE || this_type < MBENTITYSET));
       // MBMAXTYPE signifies end of entities data
     if (MBMAXTYPE == this_type) break;
+    assert(!is_iface || this_type != MBVERTEX);
       // get the number of ents
-    int num_ents;
-    UNPACK_INT(buff_ptr, num_ents);
+    int num_ents2, verts_per_entity;
+    UNPACK_INT(buff_ptr, num_ents2);
-    if (MBVERTEX == this_type) {
-        // unpack coords
-      if (num_ents) {
-        std::vector<double*> coords(3);
-        result = ru->get_node_arrays(3, num_ents, 0,
-                                     actual_start, coords);
-        RRA("Failed to allocate node arrays.");
+      // unpack the nodes per entity
+    if (MBVERTEX != this_type) {
+      UNPACK_INT(buff_ptr, verts_per_entity);
+    for (int e = 0; e < num_ents2; e++) {
+        // check for existing entity, otherwise make new one
+      MBEntityHandle new_h = 0;
-        new_ents.insert(actual_start, actual_start+num_ents-1);
+      MBEntityHandle *connect;
+      if (this_type != MBVERTEX) connect = (MBEntityHandle*) buff_ptr;
+      int num_ps;
+      int *ps;
+      MBEntityHandle *hs;
-          // unpack the buffer data directly into coords
-        for (int i = 0; i < 3; i++)
-          memcpy(coords[i], buff_ptr+i*num_ents*sizeof(double),
-                 num_ents*sizeof(double));
-        buff_ptr += 3*num_ents * sizeof(double);
-        UPC(3*num_ents, " doubles");
+          // pointers to other procs/handles
+        num_ps = *((int*)buff_save);
+        ps = (int*)(buff_save + sizeof(int));
+        hs = (MBEntityHandle*)(buff_save + num_ps*sizeof(int));
+        buff_save += sizeof(int) + num_ps * (sizeof(int) + sizeof(MBEntityHandle));
-    else {
-      int verts_per_entity;
+          // if multi-shared entity, need to see if we have received it from
+          // another proc already; look up by owner proc and handle in L2 lists
+        if (num_ps > 2) {
+          int idx = get_buffers(ps[0]);
+          if (idx == (int)L1h.size()) L1h.resize(idx+1);
+          for (k = 0; k < L2hrem.size(); k++) {
+            if (L2hrem[k] == hs[0] && ps[0] == (int) L2p[k])
+              new_h = L2hloc[k];
-        // unpack the nodes per entity
-      UNPACK_INT(buff_ptr, verts_per_entity);
-      MBEntityHandle *connect;
-      result = ru->get_element_array(num_ents, verts_per_entity, this_type,
-                                     0, actual_start,
-                                     connect);
-      RRA("Failed to allocate element arrays.");
+      if (!new_h) {
+        if (is_iface)
+          new_h = find_existing_entity(connect, verts_per_entity,
+                                       this_type);
+        if (!new_h && MBVERTEX == this_type) {
+            // make new vertex
+          double xyz[3];
+          for (k = 0; k < 3; k++) xyz[k] = ((double*)buff_ptr)[k*num_ents2];
+          result = mbImpl->create_vertex(xyz, new_h);
+          RRA("Couldn't make new vertex.");
+          buff_ptr += sizeof(double);
+        else if (!new_h) {
+            // update connectivity to local handles
+          result = get_local_handles(connect, verts_per_entity, new_ents);
+          RRA("Couldn't get local handles.");
+            // create the element
+          result = mbImpl->create_element(this_type, connect, verts_per_entity, new_h);
-        // unpack the connectivity
-      UNPACK_EH(buff_ptr, connect, (num_ents*verts_per_entity));
+            // update adjacencies
+          result = ru->update_adjacencies(new_h, num_ents,
+                                          verts_per_entity, connect);
+          RRA("Failed to update adjacencies.");
-        // convert to local handles
-      result = get_local_handles(connect, num_ents*verts_per_entity,
-                                 new_ents, &no_local_handles);
-      RRA("Couldn't get local handles.");
+          buff_ptr += verts_per_entity * sizeof(MBEntityHandle);
-        // update adjacencies
-      result = ru->update_adjacencies(actual_start, num_ents,
-                                      verts_per_entity, connect);
-      RRA("Failed to update adjacencies.");
+          // if a new multi-shared entity, save owner for subsequent lookup in L2 lists
+        if (store_remote_handles && !is_iface && num_ps > 2) {
+          L2hrem.push_back(hs[0]);
+          L2hloc.push_back(new_h);
+          L2p.push_back(ps[0]);
+        if (!is_iface) {
+          assert(is_iface || new_h > *new_ents.rbegin());
+          new_ents.insert(new_h);
+          // update sharing data and pstatus, adjusting order if iface
+        result = update_remote_data(new_h, ps, hs, num_ps, is_iface);
+        RRA("");
+          // need to send this new handle to all sharing procs
+        if (!is_iface) {
+          for (j = 0; j < num_ps; j++) {
+            int idx = get_buffers(ps[j]);
+            L1h[idx].push_back(hs[j]);
+            L1h[idx].push_back(new_h);
+    if (MBVERTEX == this_type) buff_ptr += 2*num_ents2*sizeof(double);
       std::cerr << "Unpacked " << num_ents << " ents of type "
@@ -1414,48 +1261,6 @@
-    result = set_remote_data(new_ents, remote_range, from_proc);
-    RRA("Couldn't set sharing data");
-      // account for entities which existed before (i.e. delete duplicate
-      // new ones) then save remaining new ones in appropriate list
-      // find ones to delete (existing nonowned and owned entities)
-    MBRange to_delete;
-    for (unsigned int i = 0; i < no_local_handles.size(); i++)
-      if (no_local_handles[i]) to_delete.insert(new_ents[i]);
-      // put non-existing non-owned entities on noHandles and localHandles list
-    int ind = -1;
-      if (!no_local_handles[no_indices[i]]) {
-        if (-1 == ind || no_procs[i] != buffProcs[ind])
-          ind = get_buffers(no_procs[i]);
-        sharedEnts[ind].noHandles.insert(no_handles[i]);
-        sharedEnts[ind].localHandles.insert(new_ents[no_indices[i]]);
-          // remove remote handles for these entities; leaves
-          // remote handles for only new owned entities in remote range
-        remote_range.erase(new_ents[no_indices[i]]);
-    result = mbImpl->delete_entities(to_delete);
-    RRA("Failed to delete non-owned duplicate entities.");
-    entities = new_ents.subtract(to_delete);
-      // put new ents on local and remote handles list for from_proc
-    sharedEnts[from_ind].localHandles.merge(entities);
-    sharedEnts[from_ind].remoteHandles.merge(remote_range);
-    result = set_pstatus_entities(entities, PSTATUS_NOT_OWNED, false, false);
-    RRA("Couldn't set pstatus values for received entities.");
-  else
-    entities.swap(new_ents);
   std::cerr << std::endl << "Done unpacking entities." << std::endl;
 #endif
@@ -1463,98 +1268,140 @@
   return MB_SUCCESS;
-MBErrorCode MBParallelComm::unpack_iface_entities(unsigned char *&buff_ptr,
-                                                  const int from_proc,
-                                                  const int ind,
-                                                  std::vector<MBEntityHandle> &recd_ents)
+MBErrorCode MBParallelComm::update_remote_data(MBEntityHandle new_h,
+                                               int *ps,
+                                               MBEntityHandle *hs,
+                                               int num_ps,
+                                               const bool is_iface)
-    // for all the entities in the received buffer, save
-    // entities in this instance which match connectivity, or zero if none found
-  bool done = false;
-  std::vector<MBEntityHandle> connect;
-  unsigned int num_zero = 0;
+  std::vector<MBEntityHandle> tmp_hs(MAX_SHARING_PROCS, 0);
+  std::vector<int> tmp_ps(MAX_SHARING_PROCS, -1);
+  unsigned char pstat;
+    // get initial sharing data
+  MBErrorCode result = get_sharing_data(new_h, &tmp_ps[0], &tmp_hs[0], pstat);
+  RRA("");
+    // add any new sharing data
+  int num_exist = std::find(tmp_ps.begin(), tmp_ps.end(), -1) - tmp_ps.begin();
+  bool changed = false;
+  int idx;
+  for (int i = 0; i < num_ps; i++) {
+    idx = std::find(&tmp_ps[0], &tmp_ps[num_exist], ps[i]) - &tmp_ps[0];
+    if (idx == num_exist) {
+      tmp_ps[num_exist] = ps[i];
+      tmp_hs[num_exist] = hs[i];
+      num_exist++;
+      changed = true;
+    else if (0 == tmp_hs[idx]) {
+      tmp_hs[idx] = hs[i];
+      changed = true;
+    else {
+      assert(hs[i] == tmp_hs[idx]);
-  while (!done) {
-    MBEntityType this_type;
-    UNPACK_INT(buff_ptr, this_type);
-    assert(this_type > MBVERTEX &&
-           (this_type == MBMAXTYPE || this_type < MBENTITYSET));
-      // MBMAXTYPE signifies end of entities data
-    if (MBMAXTYPE == this_type) break;
+    // adjust for interface layer if necessary
+  if (is_iface) {
+    idx = std::min_element(tmp_ps.begin(), tmp_ps.end()) - tmp_ps.begin();
+    if (idx) {
+      int tmp_proc = tmp_ps[idx];
+      tmp_ps[idx] = tmp_ps[0];
+      tmp_ps[0] = tmp_proc;
+      MBEntityHandle tmp_h = tmp_hs[idx];
+      tmp_hs[idx] = tmp_hs[0];
+      tmp_hs[0] = tmp_h;
+      changed = true;
+      if (tmp_ps[0] != (int)procConfig.proc_rank()) pstat |= PSTATUS_NOT_OWNED;
-      // get the number of ents
-    int num_ents;
-      // unpack the verts per entity
-    connect.resize(verts_per_entity * num_ents);
-    UNPACK_EH(buff_ptr, &connect[0], (num_ents*verts_per_entity));
-    MBRange tmp_range;
-      // save matching local entities, or 0 if none found
-    for (int i = 0; i < num_ents; i++) {
-        // test for existing entity
-      result = mbImpl->get_adjacencies(&connect[0]+i*verts_per_entity, verts_per_entity,
-                                       MBCN::Dimension(this_type), false, tmp_range);
-      if (MB_MULTIPLE_ENTITIES_FOUND == result) {
-        RRA("Multiple entities found.");
-      if (!tmp_range.empty()) {
-          // found a corresponding entity - save target
-        assert(1 == tmp_range.size());
-        recd_ents.push_back(*tmp_range.begin());
-        tmp_range.clear();
-      else {
-        recd_ents.push_back(0);
-        num_zero++;
+  if (changed) {
+    int tmp_p;
+    MBEntityHandle tmp_h;
+    if (num_exist > 2 && !(pstat & PSTATUS_MULTISHARED) &&
+        (pstat & PSTATUS_SHARED)) {
+        // must remove sharedp/h first, which really means set to default value
+      tmp_p = -1;
+      result = mbImpl->tag_set_data(sharedp_tag(), &new_h, 1, &tmp_p);
+      RRA("Couldn't set sharedp tag.");
+      tmp_h = 0;
+      result = mbImpl->tag_set_data(sharedh_tag(), &new_h, 1, &tmp_h);
+      RRA("Couldn't set sharedh tag.");
+    if (num_exist > 2) {
+      result = mbImpl->tag_set_data(sharedps_tag(), &new_h, 1, &tmp_ps[0]);
+      RRA("Couldn't set sharedps tag.");
+      result = mbImpl->tag_set_data(sharedhs_tag(), &new_h, 1, &tmp_hs[0]);
+      RRA("Couldn't set sharedhs tag.");
+      pstat |= PSTATUS_MULTISHARED;
+    else if (num_exist == 2) {
+      tmp_p = (tmp_ps[0] == (int) procConfig.proc_rank() ? tmp_ps[1] : tmp_ps[0]);
+      tmp_h = (tmp_ps[0] == (int) procConfig.proc_rank() ? tmp_hs[1] : tmp_hs[0]);
+      pstat |= PSTATUS_SHARED;
-#ifdef DEBUG_PACKING
-    std::cerr << "Unpacked " << num_ents << " ents of type "
-              << MBCN::EntityTypeName(this_type) << std::endl;
-#endif
+    if (!is_iface && num_exist > 1)
+      pstat |= PSTATUS_INTERFACE;
+      // now set new pstatus
+    result = mbImpl->tag_set_data(pstatus_tag(), &new_h, 1, &pstat);
+    RRA("Couldn't set pstatus tag.");
-  if (num_zero) {
-    RRA("Didn't find an iface entity.");
+  return MB_SUCCESS;
+MBErrorCode MBParallelComm::get_sharing_data(MBEntityHandle entity,
+                                             int *ps,
+                                             unsigned char &pstat)
+  MBErrorCode result = mbImpl->tag_get_data(pstatus_tag(), &entity, 1, &pstat);
+  RRA("Couldn't get pstatus tag.");
+  if (pstat & PSTATUS_MULTISHARED) {
+    result = mbImpl->tag_get_data(sharedps_tag(), &entity, 1, ps);
+    RRA("Couldn't get sharedps tag.");
+    result = mbImpl->tag_get_data(sharedhs_tag(), &entity, 1, hs);
+    RRA("Couldn't get sharedhs tag.");
-  std::vector<MBEntityHandle> tmp_remote;
-  tmp_remote.reserve(recd_ents.size());
-  std::copy(remote_range.begin(), remote_range.end(),
-            std::back_inserter(tmp_remote));
-  result = set_remote_data(&recd_ents[0], &tmp_remote[0], recd_ents.size(),
-                           from_proc);
-  RRA("Failed to set remote handles for iface entities.");
+  else if (pstat & PSTATUS_SHARED) {
+    result = mbImpl->tag_get_data(sharedp_tag(), &entity, 1, ps);
+    RRA("Couldn't get sharedp tag.");
+    result = mbImpl->tag_get_data(sharedh_tag(), &entity, 1, hs);
+    RRA("Couldn't get sharedh tag.");
+      // initialize past end of data
+    ps[1] = -1;
+    hs[1] = 0;
-    // add iface entities to sharedEnts list; since they were sent to us, assume we
-    // don't own them
-  std::copy(recd_ents.begin(), recd_ents.end(),
-            mb_range_inserter(sharedEnts[ind].localHandles));
-  sharedEnts[ind].remoteHandles.merge(remote_range);
-  std::cerr << std::endl << "Done unpacking iface entities." << std::endl;
-#endif
   return MB_SUCCESS;
+MBEntityHandle MBParallelComm::find_existing_entity(const MBEntityHandle *connect,
+                                                    const int num_connect,
+                                                    const MBEntityType this_type)
+  MBRange tmp_range;
+  MBErrorCode result = mbImpl->get_adjacencies(connect, num_connect,
+                                               MBCN::Dimension(this_type), false,
+                                               tmp_range);
+  if (MB_MULTIPLE_ENTITIES_FOUND == result) {
+    std::cerr << "Multiple entities found.";
+    return 0;
+  if (!tmp_range.empty())
+      // found a corresponding entity - return target
+    return *tmp_range.begin();
+  else return 0;
 MBErrorCode MBParallelComm::get_local_handles(const MBRange &remote_handles,
                                               MBRange &local_handles,
@@ -1644,131 +1491,73 @@
   return MB_SUCCESS;
-MBErrorCode MBParallelComm::set_remote_data(MBEntityHandle *local_ents,
-                                            MBEntityHandle *remote_ents,
-                                            int num_ents,
-                                            int other_proc)
+MBErrorCode MBParallelComm::add_remote_data(MBEntityHandle this_h,
+                                            int other_proc,
+                                            MBEntityHandle other_h)
-  if (0 == num_ents)
-    // NOTE: THIS IMPLEMENTATION IS JUST LIKE THE RANGE-BASED VERSION, NO REUSE
-    // AT THIS TIME, SO IF YOU FIX A BUG IN THIS VERSION, IT MAY BE IN THE
-    // OTHER VERSION TOO!!!
   MBTag sharedp_tag, sharedps_tag, sharedh_tag, sharedhs_tag, pstatus_tag;
   MBErrorCode result = get_shared_proc_tags(sharedp_tag, sharedps_tag,
                                             sharedh_tag, sharedhs_tag, pstatus_tag);
     // get remote procs tag, if any
-  std::vector<int> remote_proc(num_ents);
+  int remote_proc;
   int remote_procs[MAX_SHARING_PROCS];
-  std::vector<MBEntityHandle> remote_handle(num_ents);
+  MBEntityHandle remote_handle;
   MBEntityHandle remote_handles[MAX_SHARING_PROCS];
-  std::vector<unsigned char> pstatus_vals(num_ents);
-  result = mbImpl->tag_get_data(sharedp_tag, local_ents, num_ents,
-                                &remote_proc[0]);
-  RRA("Couldn't get sharedp tag (vector)");
-  result = mbImpl->tag_get_data(sharedh_tag, local_ents, num_ents,
-                                &remote_handle[0]);
-  RRA("Couldn't get sharedh tag (vector)");
-  result = mbImpl->tag_get_data(pstatus_tag, local_ents, num_ents,
-                                &pstatus_vals[0]);
+  unsigned char pstatus_val;
+  result = mbImpl->tag_get_data(sharedp_tag, &this_h, 1, &remote_proc);
+  RRA("Couldn't get sharedp tag");
+  result = mbImpl->tag_get_data(sharedh_tag, &this_h, 1, &remote_handle);
+  RRA("Couldn't get sharedh tag");
+  result = mbImpl->tag_get_data(pstatus_tag, &this_h, 1, &pstatus_val);
+  RRA("Couldn't get pstatus tag");
-    // for each local/remote handle pair
-  for (int i = 0; i != num_ents; i++) {
-      // get existing remote proc(s), handle(s) for this local handle
-    if (!(pstatus_vals[i] & PSTATUS_SHARED)) {
-      std::fill(remote_procs, remote_procs+MAX_SHARING_PROCS, -1);
-      std::fill(remote_handles, remote_handles+MAX_SHARING_PROCS, 0);
-    else if (-1 != remote_proc[i]) {
-      remote_procs[0] = remote_proc[i];
-      remote_handles[0] = remote_handle[i];
-      std::fill(remote_procs+1, remote_procs+MAX_SHARING_PROCS-1, -1);
-      std::fill(remote_handles+1, remote_handles+MAX_SHARING_PROCS-1, 0);
-    else {
-      result = mbImpl->tag_get_data(sharedps_tag, local_ents+i, 1,
-                                    remote_procs);
-      RRA("Couldn't get sharedps tag (vector)");
+    // get existing remote proc(s), handle(s) for this local handle
+  if (!(pstatus_val & PSTATUS_SHARED)) {
+    std::fill(remote_procs, remote_procs+MAX_SHARING_PROCS, -1);
+    std::fill(remote_handles, remote_handles+MAX_SHARING_PROCS, 0);
+  else if (-1 != remote_proc) {
+    remote_procs[0] = remote_proc;
+    remote_handles[0] = remote_handle;
+    std::fill(remote_procs+1, remote_procs+MAX_SHARING_PROCS-1, -1);
+    std::fill(remote_handles+1, remote_handles+MAX_SHARING_PROCS-1, 0);
+  else {
+    result = mbImpl->tag_get_data(sharedps_tag, &this_h, 1, remote_procs);
+    RRA("Couldn't get sharedps tag");
-      result = mbImpl->tag_get_data(sharedhs_tag, local_ents+i, 1,
-                                    remote_handles);
-      RRA("Couldn't get sharedhs tag (vector)");
+    result = mbImpl->tag_get_data(sharedhs_tag, &this_h, 1, remote_handles);
+    RRA("Couldn't get sharedhs tag");
-      // now either insert other_proc, handle into these, or remove if
-      // remote handle is 0
-    if (0 == remote_ents[i]) {
-      result = rmv_remote_proc(local_ents[i], remote_procs, remote_handles,
-                               other_proc);
-      RRA(" ");
-    else {
-      result = add_remote_proc(local_ents[i], remote_procs, remote_handles,
-                               other_proc, remote_ents[i]);
-      RRA(" ");
+    // now either insert other_proc, handle into these, or remove if
+    // remote handle is 0
+  int *this_idx = std::find(remote_procs, remote_procs+MAX_SHARING_PROCS,
+                            other_proc);
+  if (this_idx != remote_procs+MAX_SHARING_PROCS) {
+    int idx = this_idx-remote_procs;
+    remote_handles[idx] = this_h;
+    if (!idx && remote_procs[1] == -1)
+      result = mbImpl->tag_set_data(sharedh_tag, &this_h, 1, remote_handles);
+    else
+      result = mbImpl->tag_set_data(sharedhs_tag, &this_h, 1, remote_handles);
+  else {
+    result = add_remote_proc(this_h, remote_procs, remote_handles,
+                             other_proc, other_h);
+    RRA(" ");
     // also update shared flag for these ents
-  result = set_pstatus_entities(local_ents, num_ents, PSTATUS_SHARED,
+  result = set_pstatus_entities(&this_h, 1, PSTATUS_SHARED,
                                 false, false);
   RRA("Couldn't set pstatus tag (range)");
   return MB_SUCCESS;
-MBErrorCode MBParallelComm::rmv_remote_proc(MBEntityHandle ent,
-                                            int *remote_procs,
-                                            MBEntityHandle *remote_hs,
-                                            int remote_proc)
-  int i = std::find(remote_procs, remote_procs+MAX_SHARING_PROCS, -1) - remote_procs;
-  int j = std::find(remote_procs, remote_procs+i, remote_proc) - remote_procs;
-    // remote_proc must be in this list
-  assert(j != i);
-  for (; j != i; j++) {
-    remote_procs[j] = remote_procs[j+1];
-    remote_hs[j] = remote_hs[j+1];
-  if (i == 1) {
-      // only had one proc, and now have none; have to set the values,
-      // since they're sparse tags
-    result = mbImpl->tag_set_data(sharedp_tag(), &ent, 1, remote_procs);
-    result = mbImpl->tag_set_data(sharedh_tag(), &ent, 1, remote_hs);
-      // if it's not shared, it's also not a ghost, interface, or !owned entity
-    unsigned char not_shared = 0;
-    result = mbImpl->tag_set_data(pstatus_tag(), &ent, 1, ¬_shared);
-  else if (i == 2) {
-      // went from 2 to 1, need to unset 1 and set the other
-    RRA("Couldn't set sharedp tag");
-    RRA("Couldn't set sharedh tag");
-    result = mbImpl->tag_delete_data(sharedps_tag(), &ent, 1);
-    RRA("Couldn't remove sharedps tag");
-    result = mbImpl->tag_delete_data(sharedhs_tag(), &ent, 1);
-    RRA("Couldn't remove sharedhs tag");
-  else {
-    result = mbImpl->tag_set_data(sharedps_tag(), &ent, 1, remote_procs);
-    RRA("Couldn't set sharedps tag");
-    result = mbImpl->tag_set_data(sharedhs_tag(), &ent, 1, remote_hs);
-    RRA("Couldn't set sharedhs tag");
 template <typename T> void
 insert_in_array( T* array, size_t array_size, size_t location, T value )
@@ -1784,12 +1573,12 @@
                                             int remote_proc,
                                             MBEntityHandle remote_handle)
+  MBErrorCode result;
   int* ptr = std::find( remote_procs, remote_procs+MAX_SHARING_PROCS, -1 );
   const size_t n = ptr - remote_procs;
   ptr = std::lower_bound( remote_procs, remote_procs+n, remote_proc );
   const size_t i = ptr - remote_procs;
   const int invalid_proc = -1;
   const MBEntityHandle invalid_handle = 0;
   if (i == n || remote_procs[i] != remote_proc) {
@@ -2722,6 +2511,9 @@
   RRA("Trouble creating interface parent/child links.");
   gs_data_free(gsd);
+    // get rid of the temporary data we kept around for interface resolution
+  reset_tmpiface_tag();
     // done
   return result;
@@ -2729,15 +2521,29 @@
 MBErrorCode MBParallelComm::tag_iface_entities()
-  MBRange all_ents, if_ents;
-  for (MBRange::iterator if_it = interfaceSets.begin(); if_it != interfaceSets.end(); if_it++) {
-      // get all ents
-    result = mbImpl->get_entities_by_handle(*if_it, if_ents);
-    RRA("Trouble getting iface entities.");
+  MBErrorCode result = MB_SUCCESS;
+  MBRange iface_ents, tmp_ents, rmv_ents;
+  std::vector<unsigned char> pstat;
+  MBRange::iterator rit2;
+  unsigned int i;
+  for (MBRange::iterator rit = interfaceSets.begin(); rit != interfaceSets.end(); rit++) {
+    iface_ents.clear();
+    result = mbImpl->get_entities_by_handle(*rit, iface_ents);
+    RRA("Couldn't get iface set contents.");
+    pstat.resize(iface_ents.size());
+    result = mbImpl->tag_get_data(pstatus_tag(), iface_ents, &pstat[0]);
+    RRA("Couldn't get pstatus values.");
+    rmv_ents.clear();
+    for (rit2 = iface_ents.begin(), i = 0; rit2 != iface_ents.end(); rit2++, i++) {
+      if (!(pstat[i] & PSTATUS_INTERFACE)) rmv_ents.insert(*rit2);
+    result = mbImpl->remove_entities(*rit, rmv_ents);
+    RRA("Couldn't remove entities from set.");
-  return set_pstatus_entities(if_ents, PSTATUS_INTERFACE, false, false);
 MBErrorCode MBParallelComm::set_pstatus_entities(MBRange &pstatus_ents,
@@ -2856,22 +2662,12 @@
     result = mbImpl->tag_set_data(pstatus_tag, &new_set, 1, &pval);
     RRA("Failed to tag interface set with pstatus.");
-      // tag the entities with the same thing
+      // tag the vertices with the same thing
     pstatus.clear();
-    pstatus.resize(mit->second.size(), pval);
-    result = mbImpl->tag_set_data(pstatus_tag, mit->second, &pstatus[0]);
-    RRA("Failed to tag interface set entities with pstatus.");
-      // finally, if I own this interface, add all the entities to my
-      // sharedEnts.ownedShared for the other procs
-    if ((mit->first)[0] == (int)procConfig.proc_rank()) {
-      std::vector<int>::const_iterator vit = (mit->first).begin();
-      for (++vit; vit != (mit->first).end(); vit++) {
-        int ind = get_buffers(*vit);
-        assert(-1 != ind);
-        sharedEnts2.merge(mit->second);
+    MBRange verts = (mit->second).subset_by_type(MBVERTEX);
+    pstatus.resize(verts.size(), pval);
+    result = mbImpl->tag_set_data(pstatus_tag, verts, &pstatus[0]);
+    RRA("Failed to tag interface set vertices with pstatus.");
   return MB_SUCCESS;
@@ -3033,24 +2829,9 @@
       proc_nranges[sharing_procs].insert(*rit);
-      if (sharing_procs.size() < 2) {
-        result = mbImpl->tag_set_data(sharedp_tag, &(*rit), 1,
-                                      &sharing_procs[0]);
-        RRA("Failed to set sharedp_tag on non-vertex skin entity.");
-      else {
-          // fill extra entries with -1
-        assert(sharing_procs.size() <= MAX_SHARING_PROCS);
-        sharing_procs.resize( MAX_SHARING_PROCS, -1 );
-        result = mbImpl->tag_set_data(sharedps_tag, &(*rit), 1,
-        RRA("Failed to set sharedps_tag on non-vertex skin entity.");
-          // set hs tag as placeholder, will get filled in later
-        static std::vector<MBEntityHandle> sharing_hs(MAX_SHARING_PROCS, 0);
-        result = mbImpl->tag_set_data(sharedhs_tag, &(*rit), 1,
-                                      &sharing_hs[0]);
-        RRA("Failed to set sharedhs_tag on non-vertex skin entity.");
+      sharing_procs.resize(MAX_SHARING_PROCS, -1);
+      result = mbImpl->tag_set_data(tmpiface_tag(), &(*rit), 1, &sharing_procs[0]);
+      RRA("Failed to set tmpiface_tag.");
         // reset sharing proc(s) tags
       sharing_procs.clear();
@@ -3108,12 +2889,15 @@
     proc_nranges[sharing_procs].insert(this_ent);
+    unsigned char share_flag = PSTATUS_SHARED, ms_flag = PSTATUS_MULTISHARED;
     if (sharing_procs.size() == 1) {
       result = mbImpl->tag_set_data(sharedp_tag, &this_ent, 1,
                                     &sharing_procs[0]);
       result = mbImpl->tag_set_data(sharedh_tag, &this_ent, 1,
                                     &sharing_handles[0]);
+      result = mbImpl->tag_set_data(pstatus_tag, &this_ent, 1, &share_flag);
+      RRA("Couldn't set shared tag on shared vertex.");
+      sharedEnts.insert(this_ent);
     else {
         // pad lists
@@ -3124,35 +2908,12 @@
                                     &sharing_procs[0]);
       result = mbImpl->tag_set_data(sharedhs_tag, &this_ent, 1,
+      result = mbImpl->tag_set_data(pstatus_tag, &this_ent, 1, &ms_flag);
+      RRA("Couldn't set multi-shared tag on shared vertex.");
     RRA("Failed setting shared_procs tag on skin vertices.");
-      // tag the entity as shared & interface too (this function only
-      // ever called for interface vertices)
-    unsigned char share_flag = PSTATUS_SHARED;
-    result = mbImpl->tag_set_data(pstatus_tag, &this_ent, 1, &share_flag);
-    RRA("Couldn't set shared tag on shared vertex.");
-      // if this entity isn't owned here, add it to a list of ghosts
-      // by owner
-    if (sharing_procs[0] < (int)procConfig.proc_rank()) {
-      for (unsigned int j = 0; j < sharing_procs.size() && sharing_procs[j] != -1; j++) {
-        if (sharing_procs[j] == (int)procConfig.proc_rank()) continue;
-        get_buffers(sharing_procs[j]);
-        sharedEnts2.insert(this_ent);
-      // otherwise it is owned here and shared with others
-    else {
-        assert(sharing_procs[j] > (int)procConfig.proc_rank());
     sharing_handles.clear();
@@ -3375,56 +3136,6 @@
   return MB_SUCCESS;
-MBErrorCode MBParallelComm::populate_shared_ents()
-    // take sharedEnts2 range and separate into appropriate places in sharedEnts
-  sharedEnts.clear();
-  sharedEnts.resize(buffProcs.size());
-  std::vector<int> sharedp(sharedEnts2.size());
-  std::vector<MBEntityHandle> sharedh(sharedEnts2.size());
-  MBErrorCode result = mbImpl->tag_get_data(sharedp_tag(), sharedEnts2, &sharedp[0]);
-  RRA("Couldn't get sharedp tag.");
-  result = mbImpl->tag_get_data(sharedh_tag(), sharedEnts2, &sharedh[0]);
-  RRA("Couldn't get sharedh tag.");
-  int sharedps[MAX_SHARING_PROCS];
-  MBEntityHandle sharedhs[MAX_SHARING_PROCS];
-  MBRange::iterator rit;
-  unsigned int i, j;
-  int ind;
-  for (i = 0, rit = sharedEnts2.begin(); rit != sharedEnts2.end(); rit++, i++) {
-    if (sharedp[i] != -1) {
-        // just pairwise shared
-      ind = get_buffers(sharedp[i]);
-      sharedEnts[ind].remoteHandles.insert(sharedh[i]);
-      if (sharedp[i] > (int)procConfig.proc_rank())
-        sharedEnts[ind].ownedShared.insert(*rit);
-      else
-        sharedEnts[ind].localHandles.insert(*rit);
-    else {
-      result = mbImpl->tag_get_data(sharedps_tag(), &*rit, 1, sharedps);
-      RRA("Couldn't get sharedps tag.");
-      result = mbImpl->tag_get_data(sharedhs_tag(), sharedEnts2, sharedhs);
-      RRA("Couldn't get sharedhs tag.");
-      for (j = 0; j < MAX_SHARING_PROCS && sharedps[j] != -1; j++) {
-        ind = get_buffers(sharedps[j]);
-        sharedEnts[ind].remoteHandles.insert(sharedhs[j]);
-        if (sharedps[0] == (int)procConfig.proc_rank())
-        else
-      std::fill(sharedps, sharedps+j, -1);
 MBErrorCode MBParallelComm::exchange_ghost_cells(int ghost_dim, int bridge_dim,
                                                  int num_layers,
@@ -3434,14 +3145,13 @@
     // remote handles too
   assert(num_layers > 0 || store_remote_handles);
-    // re-populate the sharedEnts data structure
-  MBErrorCode result = populate_shared_ents();
-  RRA("Unable to populate shared ents during ghost exchange.");
+  const bool is_iface = !num_layers;
     // get the b-dimensional interface(s) with with_proc, where b = bridge_dim
   int success;
   unsigned char *buff_ptr;
     // when this function is called, buffProcs should already have any
     // communicating procs
@@ -3457,7 +3167,7 @@
   for (ind = 0, proc_it = buffProcs.begin();
        proc_it != buffProcs.end(); proc_it++, ind++) {
       // for interface, only get ents from higher-rank procs
-    if (0 == num_layers && procConfig.proc_rank() < *proc_it) continue;
+    if (is_iface && procConfig.proc_rank() < *proc_it) continue;
     success = MPI_Irecv(&ghostRBuffs[ind][0], ghostRBuffs[ind].size(),
                         MPI_UNSIGNED_CHAR, buffProcs[ind],
@@ -3474,34 +3184,37 @@
     // done in a separate loop over procs because sometimes later procs
     // need to add info to earlier procs' messages
-  MBRange sent_ents[MAX_SHARING_PROCS];
-  std::set<unsigned int> addl_procs[MAX_SHARING_PROCS], my_addl_procs;
-  int num_higher = 0;
+  MBRange sent_ents[MAX_SHARING_PROCS], allsent;
-    if (num_layers) {
+    if (!is_iface) {
       result = get_ghosted_entities(bridge_dim, ghost_dim, buffProcs[ind],
-                                    num_layers, sent_ents[ind], addl_procs);
+                                    num_layers, sent_ents[ind]);
       RRA("Failed to get ghost layers.");
-        // if we're exchanging ghosts, remove already-shared entities
-      result = filter_owned_shared(sent_ents[ind],
-                                   false, false, true, false, *proc_it);
-      RRA("Failed to filter already-shared entities in ghost exchange.");
     else {
       result = get_iface_entities(buffProcs[ind], sent_ents[ind]);
       RRA("Failed to get interface layers.");
-        // remove vertices here, for efficiency in the filter
+        // remove vertices, since we know they're already shared
       std::pair<MBRange::const_iterator,MBRange::const_iterator> vert_it =
           sent_ents[ind].equal_range(MBVERTEX);
       sent_ents[ind].erase(vert_it.first, vert_it.second);
+    allsent.merge(sent_ents[ind]);
+    // need to get procs each entity is sent to
+  std::vector<std::set<unsigned int> > entprocs(allsent.size());
+  for (ind = 0, proc_it = buffProcs.begin();
+       proc_it != buffProcs.end(); proc_it++, ind++) {
+    for (rit = sent_ents[ind].begin(); rit != sent_ents[ind].end(); rit++)
+      entprocs[allsent.index(*rit)].insert(*proc_it);
     // pack and send ents from this proc to others
@@ -3509,32 +3222,21 @@
-      // if resolving interface, only send to higher-rank procs
-    if (0 == num_layers && procConfig.proc_rank() > *proc_it) continue;
-    num_higher++;
       // get an estimate of the buffer size & pre-allocate buffer size
     unsigned int buff_size = estimate_ents_buffer_size(sent_ents[ind],
-    RRA("Failed to estimate buffer size.");
     ownerSBuffs[ind].clear();
     ownerSBuffs[ind].reserve(buff_size);
       // buff_ptr points to the END (one past last occupied byte) of buffer
     buff_ptr = &ownerSBuffs[ind][0];
-      // entities (including info about non-owned ents)
+      // entities
     result = pack_entities(sent_ents[ind], ownerSBuffs[ind], buff_ptr,
-                           store_remote_handles, buffProcs[ind],
-                           num_layers, sharedEnts[ind].ownedShared);
+                           store_remote_handles, buffProcs[ind], is_iface,
+                           &entprocs);
-      // addl procs, only if not iface layer
-    if (num_layers) {
-      result = pack_addl_procs(addl_procs[ind], ownerSBuffs[ind], buff_ptr);
-      RRA("Failed to pack addl procs.");
       // now we're ready to send the buffer
     result = send_buffer(*proc_it, &ownerSBuffs[ind][0],
                          buff_ptr-&ownerSBuffs[ind][0], MB_MESG_ENTS,
@@ -3548,11 +3250,12 @@
     // number of incoming messages for ghosts is the number of procs we
     // communicate with; for iface, it's the number of those with lower rank
   int num_incoming = buffProcs.size();
-  if (!num_layers) num_incoming -= num_higher;
   std::vector<MPI_Status> status(buffProcs.size());
   std::vector<std::vector<MBEntityHandle> > recd_ents(num_incoming);
-  MBRange new_ghosts[MAX_SHARING_PROCS];
+  std::vector<std::vector<MBEntityHandle> > L1h(buffProcs.size());
+  std::vector<MBEntityHandle> L2hloc, L2hrem;
+  std::vector<unsigned int> L2p;
+  MBRange new_ents;
   while (num_incoming) {
       // wait for all recvs of ghost ents before proceeding,
@@ -3582,43 +3285,35 @@
         // incoming ghost entities; unpack; returns entities received
         // both from sending proc and from owning proc (which may be different)
       unsigned char *buff_ptr = &ghostRBuffs[ind][0];
-      if (num_layers) {
-        result = unpack_entities(buff_ptr,
-                                 buffProcs[ind],
-                                 ind,
-                                 new_ghosts[ind], new_ghosts,
-                                 my_addl_procs);
-        RRA("Failed to unpack entities.");
-          // unpack addl procs I need to receive handles from
-        result = unpack_addl_procs(buff_ptr, my_addl_procs);
-        RRA("Failed to unpack addl procs.");
-      else {
-        result = unpack_iface_entities(buff_ptr, buffProcs[ind], ind, recd_ents[ind]);
-        RRA("Failed to unpack iface entities.");
+      result = unpack_entities(buff_ptr,
+                               store_remote_handles, ind, is_iface,
+                               L1h, L2hloc, L2hrem, L2p, new_ents);
+      RRA("Failed to unpack entities.");
-    // allocate buffs for any new entities, then add buffers
-    // for any new addl procs
-  for (std::set<unsigned int>::iterator sit = my_addl_procs.begin();
-       sit != my_addl_procs.end(); sit++) {
-    ind = get_buffers(*sit);
+    // add requests for any new addl procs
+  if (recv_reqs.size() != buffProcs.size()) {
+    recv_reqs.resize(buffProcs.size());
+    send_reqs.resize(buffProcs.size());
-  recv_reqs.resize(buffProcs.size());
-  send_reqs.resize(buffProcs.size());
+  if (is_iface) {
+#ifdef NDEBUG
+    result = check_sent_ents(allsent);
+    RRA("Failed check on shared entities.");
+    result = check_all_shared_handles();
+    RRA("Failed check on all shared handles.");
+#endif
     // post recvs for remote handles of my sent ents
       // skip if iface layer and lower-rank proc
-    if (!num_layers && procConfig.proc_rank() > *proc_it) continue;
@@ -3628,7 +3323,7 @@
       RRA("Failed to post irecv in ghost exchange.");
     // send local handles for new ghosts to owner, then add
     // those to ghost list for that owner
@@ -3636,14 +3331,9 @@
       // skip if iface layer and higher-rank proc
-    if (!num_layers && procConfig.proc_rank() < *proc_it) continue;
     buff_ptr = &ghostSBuffs[ind][0];
-    if (num_layers)
-      result = pack_remote_handles(new_ghosts[ind], *proc_it,
+      result = pack_remote_handles(L1h[ind], *proc_it,
                                    ghostSBuffs[ind], buff_ptr);
-    else
-      result = pack_remote_handles(recd_ents[ind], *proc_it,
-                                   ghostSBuffs[ind], buff_ptr);
     RRA("Failed to pack remote handles.");
     result = send_buffer(buffProcs[ind], &ghostSBuffs[ind][0],
                          buff_ptr - &ghostSBuffs[ind][0],
@@ -3654,8 +3344,7 @@
     // process remote handles of my ghosteds
-  MBRange new_ghosted;
-  num_incoming = (num_layers ? buffProcs.size() : num_higher);
+  num_incoming = buffProcs.size();
     success = MPI_Waitany(buffProcs.size(), &recv_reqs[0], &ind, &status[0]);
@@ -3679,212 +3368,110 @@
     else if (MB_MESG_REMOTE_HANDLES == status[0].MPI_TAG) {
         // incoming remote handles
-      result = unpack_remote_handles(buffProcs[ind], &ghostRBuffs[ind][0], num_layers, ind,
-                                     new_ghosted);
+      result = unpack_remote_handles(buffProcs[ind], &ghostRBuffs[ind][0], is_iface, ind);
       RRA("Failed to unpack remote handles.");
-        // should receive back at least as many handles as entities we sent
-        // (at least 'cuz other procs may have sent ents owned by me to another proc)
-      assert(new_ghosted.size() >= sent_ents[ind].size());
     else assert(false);
+#ifdef NDEBUG
+#endif
   return MB_SUCCESS;
-MBErrorCode MBParallelComm::pack_sharedhps_tag(MBRange &new_ghosted,
-                                               MBRange &ghosted_ents,
-                                               unsigned int to_proc,
+MBErrorCode MBParallelComm::check_sent_ents(MBRange &allsent)
-    // only need to send entities which have neg sharedp tag
-    // use buffer as tmp space to count how many
-  MBRange tmp_range = new_ghosted.intersect(ghosted_ents);
-  std::vector<int> shp_tag(tmp_range.size());
-  MBErrorCode result = mbImpl->tag_get_data(sharedp_tag(), tmp_range,
-                                            &shp_tag[0]);
-  RRA("Failed to get sharedp_tag.");
-  int num_neg = count_if(shp_tag.begin(), shp_tag.end(),
-                         bind2nd(std::equal_to<int>(), -1));
+    // check entities to make sure there are no zero-valued remote handles
+    // where they shouldn't be
+  std::vector<unsigned char> pstat(allsent.size());
+  MBErrorCode result = mbImpl->tag_get_data(pstatus_tag(), allsent, &pstat[0]);
+  RRA("Trouble getting pstatus.");
+  std::vector<MBEntityHandle> handles(allsent.size());
+  result = mbImpl->tag_get_data(sharedh_tag(), allsent, &handles[0]);
+  RRA("Trouble getting shared handles.");
+  std::vector<int> procs(allsent.size());
+  result = mbImpl->tag_get_data(sharedp_tag(), allsent, &procs[0]);
+  RRA("Trouble getting shared procs.");
+  MBRange bad_entities;
-  CHECK_BUFF_SPACE(buff, buff_ptr, sizeof(int) + num_neg*(sizeof(int)+sizeof(MBEntityHandle))*
-                   MAX_SHARING_PROCS);
+  unsigned int i;
+  MBEntityHandle dum_hs[MAX_SHARING_PROCS];
+  int dum_ps[MAX_SHARING_PROCS];
-    // now pack the buffer
-  PACK_INT(buff_ptr, num_neg);
-  MBRange::iterator rit = tmp_range.begin();
-  std::vector<int>::iterator vit = shp_tag.begin();
-  for (; rit != tmp_range.end(); rit++, vit++) {
-      // don't need to send for ents shared only with this proc
-    if (-1 != *vit) continue;
-      // pack directly into buffer, one past start to leave room for
-      // # shared procs/handles
-    int *tmp_sharedps = (int*) (buff_ptr + sizeof(int));
-    result = mbImpl->tag_get_data(sharedps_tag(), &(*rit), 1, tmp_sharedps);
-    assert(MB_SUCCESS == result);
-      // cast to int so we can compare to proc starting point
-    int *tmp_sharedhs = (int*) std::find(tmp_sharedps, tmp_sharedps+MAX_SHARING_PROCS, -1);
-    int num_pr = tmp_sharedhs-tmp_sharedps;
-      // pack # shared handles/procs
-    PACK_INT(buff_ptr, num_pr);
-      // skip past shared procs space, then pack handles directly
-    buff_ptr += num_pr*sizeof(int);
-    result = mbImpl->tag_get_data(sharedhs_tag(), &(*rit), 1, buff_ptr);
-    RRA("Failed to get sharedhs tag.");
-    buff_ptr += num_pr * sizeof(MBEntityHandle);
+  for (rit = allsent.begin(), i = 0; rit != allsent.end(); rit++, i++) {
+    if (-1 != procs[i] && 0 == handles[i]) bad_entities.insert(*rit);
+    else {
+        // might be multi-shared...
+      result = mbImpl->tag_get_data(sharedps_tag(), &(*rit), 1, dum_ps);
+      if (MB_TAG_NOT_FOUND == result) continue;
+      RRA("Trouble getting sharedps.");
+      result = mbImpl->tag_get_data(sharedhs_tag(), &(*rit), 1, dum_hs);
+      RRA("Trouble getting sharedhs.");
-MBErrorCode MBParallelComm::unpack_sharedhps_tag(unsigned int from_proc,
-    // get # entities
-  int num_ents, num_procs;
-  int tmp_sharedps[MAX_SHARING_PROCS];
-  MBEntityHandle tmp_sharedhs[MAX_SHARING_PROCS];
-  num_procs = MAX_SHARING_PROCS;
-      // initialize tmp proc/handle space from last iterate
-    std::fill(tmp_sharedps, tmp_sharedps+num_procs, -1);
-    std::fill(tmp_sharedhs, tmp_sharedhs+num_procs, 0);
-    UNPACK_INT(buff_ptr, num_procs);
-    assert(num_procs <= MAX_SHARING_PROCS && num_procs >= 2);
-    int *proc_ptr = (int*) buff_ptr;
-    int *this_proc = std::find(proc_ptr, proc_ptr+num_procs,
-                               (int)procConfig.proc_rank());
-    assert(this_proc - proc_ptr < num_procs);
-    MBEntityHandle my_handle = (MBEntityHandle)(proc_ptr + num_procs)[this_proc-proc_ptr];
-    memcpy(tmp_sharedps, proc_ptr, num_procs*sizeof(int));
-    memcpy(tmp_sharedhs, proc_ptr+num_procs, num_procs*sizeof(MBEntityHandle));
-    MBErrorCode result = mbImpl->tag_set_data(sharedps_tag(), &my_handle, 1, tmp_sharedps);
-    RRA("Failed to set sharedps tag.");
-    result = mbImpl->tag_set_data(sharedhs_tag(), &my_handle, 1, tmp_sharedhs);
-    RRA("Failed to set sharedhs tag.");
-    buff_ptr += num_procs*(sizeof(int) + sizeof(MBEntityHandle));
+        // find first non-set proc
+      int *ns_proc = std::find(dum_ps, dum_ps+MAX_SHARING_PROCS, -1);
+      int num_procs = ns_proc-dum_ps;
+      assert(num_procs <= MAX_SHARING_PROCS);
+        // now look for zero handles in active part of dum_hs
+      MBEntityHandle *ns_handle = std::find(dum_hs, dum_hs+num_procs, 0);
+      int num_handles = ns_handle-dum_hs;
+      assert(num_handles <= num_procs);
+      if (num_handles != num_procs) bad_entities.insert(*rit);
   return MB_SUCCESS;
-MBErrorCode MBParallelComm::pack_remote_handles(MBRange &entities,
+MBErrorCode MBParallelComm::pack_remote_handles(std::vector<MBEntityHandle> &L1h,
     // 2 vectors of handles
-  CHECK_BUFF_SPACE(buff, buff_ptr, sizeof(int) + 2*entities.size()*sizeof(MBEntityHandle));
+  CHECK_BUFF_SPACE(buff, buff_ptr, sizeof(int) + L1h.size()*sizeof(MBEntityHandle));
-  PACK_INT(buff_ptr, entities.size());
-  MBEntityHandle *local_handles = (MBEntityHandle*)buff_ptr,
-      *remote_handles = local_handles + entities.size();
-  std::copy(entities.begin(), entities.end(), local_handles);
-  MBRange dum_range;
-  MBErrorCode result = get_remote_handles(true, local_handles, remote_handles,
-                                          entities.size(), to_proc, dum_range);
-  RRA("Trouble setting remote data range on sent entities in ghost exchange.");
-  buff_ptr += 2*sizeof(MBEntityHandle)*entities.size();
+    // should be in pairs of handles
+  assert(!(L1h.size()%2));
+  PACK_INT(buff_ptr, L1h.size()/2);
+  PACK_EH(buff_ptr, &L1h[0], L1h.size());
-  return result;
-MBErrorCode MBParallelComm::pack_remote_handles(std::vector<MBEntityHandle> &entities,
-    // IMPLEMENTATION IDENTICAL TO OTHER VERSION; COULD PROBABLY DO WITH TEMPLATES...
-    // 2 vectors of handles
-  return result;
 MBErrorCode MBParallelComm::unpack_remote_handles(unsigned int from_proc,
-                                                  const int num_layers,
-                                                  const int ind,
-                                                  MBRange &new_ghosted)
+                                                  const int ind)
     // incoming remote handles; use to set remote handles
   int num_eh;
   UNPACK_INT(buff_ptr, num_eh);
-  MBEntityHandle *remote_handles = (MBEntityHandle*)buff_ptr,
-      *local_handles = remote_handles + num_eh;
-  MBErrorCode result = set_remote_data(local_handles, remote_handles, num_eh, from_proc);
-  std::copy(local_handles, local_handles+num_eh, mb_range_inserter(new_ghosted));
-  std::copy(remote_handles, remote_handles+num_eh,
-            mb_range_inserter(sharedEnts[ind].remoteHandles));
-  buff_ptr += 2*num_eh*sizeof(MBEntityHandle);
-MBErrorCode MBParallelComm::get_addl_procs(MBRange &ghosted_ents,
-                                           std::set<unsigned int> *addl_procs)
-    // for all the procs owning entities ghosted here, if I'm sending those
-    // ghosts to 3rd proc, tell the owner it needs to communicate with that 3rd
-    // proc too
-  std::vector<int> tmp_procs(ghosted_ents.size()),
-      tmp_procss(MAX_SHARING_PROCS);
-  MBErrorCode result = mbImpl->tag_get_data(sharedp_tag(), ghosted_ents,
-                                            &tmp_procs[0]);
-  unsigned int i;
-  for (i = 0, rit = ghosted_ents.begin();
-       rit != ghosted_ents.end(); rit++, i++) {
-    if (-1 == tmp_procs[i]) {
-                                    &tmp_procss[0]);
-        // could be it's not yet shared
-      if (MB_TAG_NOT_FOUND == result) continue;
-    else tmp_procss[0] = tmp_procs[i];
-    if (tmp_procss[0] != (int)procConfig.proc_rank() &&
-        tmp_procss[0] != (int) to_proc)
-      addl_procs[tmp_procss[0]].insert(to_proc);
+  MBEntityHandle hpair[2];
+  for (int i = 0; i < num_eh; i++) {
+    UNPACK_EH(buff_ptr, hpair, 2);
+    assert(hpair[0] && hpair[1]);
+    result = add_remote_data(hpair[0], from_proc, hpair[1]);
+    RRA("Trouble setting remote data range on sent entities in ghost exchange.");
   return MB_SUCCESS;
 MBErrorCode MBParallelComm::get_ghosted_entities(int bridge_dim,
                                                  int ghost_dim,
                                                  int to_proc,
                                                  int num_layers,
+                                                 MBRange &ghosted_ents)
     // get bridge ents on interface(s)
   MBRange from_ents;
@@ -3911,12 +3498,6 @@
   result = add_verts(ghosted_ents);
   RRA("Couldn't add verts.");
-  result = filter_owned_shared(ghosted_ents,
-                               false, false, true, false, to_proc);
-  RRA("Trouble filtering.");
-  result = get_addl_procs(ghosted_ents, to_proc, addl_procs);
-  RRA("Failed to get addl procs.");
   return result;
@@ -3994,8 +3575,9 @@
       // also get ghosted entities for this proc
-    if (!sharedEnts[ind].ownedShared.empty())
-      tag_ents.merge(sharedEnts[ind].ownedShared);
+      //if (!sharedEnts[ind].ownedShared.empty())
+      // tag_ents.merge(sharedEnts[ind].ownedShared);
+    assert(false);
       // pack-send; this also posts receives if store_remote_handles is true
     std::vector<MBRange> tag_ranges;
@@ -4456,6 +4038,31 @@
   return pstatusTag;
+  //! return tmpiface tag
+MBTag MBParallelComm::tmpiface_tag()
+  if (!tmpifaceTag) {
+    MBErrorCode result = mbImpl->tag_create(NULL,
+                                            MAX_SHARING_PROCS*sizeof(int),
+                                            MB_TAG_SPARSE,
+                                            MB_TYPE_INTEGER, tmpifaceTag, NULL, true);
+    if (MB_SUCCESS != result && MB_ALREADY_ALLOCATED != result)
+      return 0;
+  return tmpifaceTag;
+  //! reset tmpiface tag
+void MBParallelComm::reset_tmpiface_tag()
+  if (tmpifaceTag) {
+    MBErrorCode result = mbImpl->tag_delete(tmpifaceTag);
+    assert(MB_SUCCESS == result);
+    tmpifaceTag = 0;
   //! return partition set tag
 MBTag MBParallelComm::partition_tag()
@@ -4950,61 +4557,6 @@
   return result;
-  /** \brief Find a local ghost entity corresponding to owning proc and handle
-   * Given the handle on the owner and the proc, find the local handle to
-   * the corresponding entity.  Looks in both the nonowned and owned ghost
-   * lists.
-MBEntityHandle MBParallelComm::find_ghost_entity(MBEntityHandle owner_handle,
-                                                 int owner_proc)
-  int ind = get_buffers(owner_proc);
-  MBRange sub_range;
-  struct GhostStruct &ostruct = sharedEnts[ind];
-  if ((!ostruct.remoteHandles.empty() &&
-      ostruct.remoteHandles.find(owner_handle) != ostruct.remoteHandles.end()) ||
-      (!ostruct.noHandles.empty() &&
-       ostruct.noHandles.find(owner_handle) != ostruct.noHandles.end()))
-    // ok, it's an existing ghost entity; find local handle
-       sub_range = ostruct.localHandles.subset_by_type(
-           TYPE_FROM_HANDLE(owner_handle));
-  if (sub_range.empty()) return 0;
-  std::vector<MBEntityHandle> sharedhs(sub_range.size());
-  std::vector<int> sharedps(sub_range.size());
-  MBErrorCode result = mbImpl->tag_get_data(sharedh_tag(), sub_range,
-                                            &sharedhs[0]);
-  RRA("Failed to get shared handle tag.");
-  result = mbImpl->tag_get_data(sharedp_tag(), sub_range,
-                                &sharedps[0]);
-  RRA("Failed to get shared proc tag.");
-  for (int i = sub_range.size()-1; i >= 0; i--) {
-    if (sharedps[i] == owner_proc && sharedhs[i] == owner_handle)
-      return sub_range[i];
-    // not there; search sharedps/sharedhs tags
-  sharedhs.resize(MAX_SHARING_PROCS);
-  sharedps.resize(MAX_SHARING_PROCS);
-  for (MBRange::iterator rit = sub_range.begin();
-       rit != sub_range.end(); rit++) {
-    result = mbImpl->tag_get_data(sharedhs_tag(), &(*rit), 1, &sharedhs[0]);
-    RRA("Failed to get shared handles tag.");
-    result = mbImpl->tag_get_data(sharedps_tag(), &(*rit), 1, &sharedps[0]);
-    RRA("Failed to get shared procs tag.");
-    for (int i = 0; i < MAX_SHARING_PROCS; i++) {
-      if (sharedhs[i] == owner_handle && sharedps[i] == owner_proc) return *rit;
-      else if (-1 == sharedps[i]) break;
-    // not found
-  return 0;
 MBErrorCode MBParallelComm::exchange_all_shared_handles( shared_entity_map& result )
   MBErrorCode rval;
@@ -5128,7 +4680,8 @@
     int other_proc = (*mit).first;
     int ind = get_buffers(other_proc);
     if (-1 == ind) return MB_FAILURE;
-    local_shared = shared_ents()[ind].ownedShared;
+    assert(false);
+      //local_shared = shared_ents()[ind].ownedShared;
     shared_entity_vec &shvec = (*mit).second;
     for (shared_entity_vec::iterator vit = shvec.begin(); vit != shvec.end(); vit++) {
       MBEntityHandle localh = vit->local, remoteh = vit->remote, dumh;
Modified: MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp
--- MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp	2009-05-01 18:51:00 UTC (rev 2869)
+++ MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp	2009-05-01 21:24:27 UTC (rev 2870)
@@ -285,6 +285,19 @@
   MBErrorCode get_owner_handle(MBEntityHandle entity,
                                int &owner,
                                MBEntityHandle &handle);
+    /** \brief Get the shared processors/handles for an entity
+     * Get the shared processors/handles for an entity.  Arrays must
+     * be large enough to receive data for all sharing procs.
+     * \param entity Entity being queried
+     * \param ps Pointer to sharing proc data
+     * \param hs Pointer to shared proc handle data
+     * \param pstat Reference to pstatus data returned from this function
+  MBErrorCode get_sharing_data(MBEntityHandle entity,
+                               int *ps,
+                               unsigned char &pstat);
     /** \brief Get entities on an inter-processor interface and of specified dimension
      * If other_proc is -1, any interface entities are returned.  If dim is -1,
@@ -342,7 +355,13 @@
     //! return pstatus tag
   MBTag pstatus_tag();
+  MBTag tmpiface_tag();
+    //! reset the tmpiface tag
+  void reset_tmpiface_tag();
     //! return pcomm tag; static because might not have a pcomm before going
     //! to look for one on the interface
   static MBTag pcomm_tag(MBInterface *impl,
@@ -405,12 +424,10 @@
   MBErrorCode update_shared_mesh();
   MBErrorCode pack_buffer(MBRange &orig_ents,
                           const bool tags,
                           const bool store_remote_handles,
                           const int to_proc,
                           int &buff_size);
@@ -418,9 +435,11 @@
                             const int ind,
-                            MBRange &final_ents,
-                            std::set<unsigned int> &my_addl_procs);
+                            MBRange &new_ents);
 private:
@@ -439,22 +458,6 @@
     //! whether new buffer was allocated
   int get_buffers(int to_proc, bool *is_new = NULL);
-    //! pack entities (with adjs, tags too) and send to to_proc; also post a recv
-    //! if store_remote_handles is true; pass back MPI_Request objects for these
-    //! messages, along with entities actually sent; this function calls:
-    //! - MPI_Irecv if store_remote_handles is true (posts recv for remote handles)
-    //! - MPI_Send if send buffer is larger than INITIAL_BUFF_SIZE
-    //! - MPI_Isend for sending entities
-  MBErrorCode pack_send_entities(const int to_proc,
-                                 MBRange &orig_ents,
-                                 std::set<int> &addl_procs,
-                                 const bool store_remote_handles,
-                                 const bool iface_layer,
-                                 std::vector<unsigned char> &send_buff,
-                                 std::vector<unsigned char> &recv_buff,
-                                 MPI_Request &send_req,
-                                 MPI_Request &recv_req);
     //! send the indicated buffer, possibly sending size first
   MBErrorCode send_buffer(const unsigned int to_proc,
                           const unsigned char *send_buff,
@@ -478,8 +481,7 @@
-                                   MBRange &recd_ents,
-                                   std::set<int> &my_addl_procs);
+                                   MBRange &recd_ents);
     //! for all the entities in the received buffer; for each, save
     //! entities in this instance which match connectivity, or zero if none found
@@ -494,8 +496,8 @@
                             const int to_proc,
-                            MBRange &owned_shared);
+                            std::vector<std::set<unsigned int> > *entprocs = NULL);
     //! pack a range of entities with equal # verts per entity, along with
     //! the range on the sending proc
   MBErrorCode pack_entity_seq(const int nodes_per_entity,
@@ -506,23 +508,22 @@
                               unsigned char *&buff_ptr);
-    //! pack a set of integer proc ranks into the buffer
-  MBErrorCode pack_addl_procs(std::set<unsigned int> &addl_procs,
-                              unsigned char *&buff_ptr);
-    //! unpack a set of integer proc ranks from the buffer
-  MBErrorCode unpack_addl_procs(unsigned char *&buff_ptr,
-                                std::set<unsigned int> &addl_procs);
+    //! unpack entities in buff_ptr
   MBErrorCode unpack_entities(unsigned char *&buff_ptr,
-                              const int ind,
-                              MBRange *new_ghosts,
+                              const int from_ind,
+    //! given connectivity and type, find an existing entity, if there is one
+  MBEntityHandle find_existing_entity(const MBEntityHandle *connect,
+                                      const MBEntityType this_type);
   MBErrorCode pack_sets(MBRange &entities,
@@ -567,37 +568,16 @@
   MBErrorCode unpack_remote_handles(unsigned int from_proc,
-                                    const int ind,
-                                    MBRange &new_ghosted);
+                                    const int ind);
-    /* \brief Unack message with remote handles (updated buffer ptr not returned)
+    /* \brief Unpack message with remote handles (const pointer to buffer)
                                     const unsigned char *buff_ptr,
-                                    const int ind,
+                                    const int ind);
-    /* \brief Pack message containing sharedhs and sharedps tags
-  MBErrorCode pack_sharedhps_tag(MBRange &new_ghosted,
-    /* \brief Unpack message containing sharedhs and sharedps tags
-  MBErrorCode unpack_sharedhps_tag(unsigned int from_proc,
-     * (does not update buffer ptr)
-                                   const unsigned char *buff_ptr);
   /**\brief Get list of tags for which to exchange data
    * Get tags and entities for which to exchange tag data.  This function
@@ -757,13 +737,6 @@
                                 std::vector<MBEntityHandle> &remote_handles,
                                 int from_proc);
-    //! for a list of entities, if any is non-owned, add destination proc
-    //! to addl_procs list for owner; tells that owner it will receive
-    //! destination handles message from to_proc
-  MBErrorCode get_addl_procs(MBRange &ghosted_ents,
-                             std::set<unsigned int> *addl_procs);
     //! for specified bridge/ghost dimension, to_proc, and number
     //! of layers, get the entities to be ghosted, and info on additional procs
     //! needing to communicate with to_proc
@@ -771,8 +744,7 @@
                                    int ghost_dim,
                                    int to_proc,
                                    int num_layers,
+                                   MBRange &ghosted_ents);
 public:
     //! add vertices adjacent to entities in this list
@@ -830,12 +802,6 @@
   MBInterface* get_moab() const { return mbImpl; }
-    //! struct to store information on ghosted, ghost entities
-  struct GhostStruct {MBRange localHandles, remoteHandles,
-        noHandles, ownedShared;};
-  std::vector<struct MBParallelComm::GhostStruct> &shared_ents();
   std::vector<unsigned int> &buff_procs();
 private:
@@ -868,6 +834,21 @@
                               int remote_proc);
+  MBErrorCode update_remote_data(MBEntityHandle new_h,
+                                 int *ps,
+                                 int num_ps,
+                                 const bool is_iface);
+  MBErrorCode add_remote_data(MBEntityHandle this_h,
+                              int other_proc,
+                              MBEntityHandle other_h);
+    //! add a remote proc, after getting existing sharedp/h tags
+  MBErrorCode add_remote_proc(MBEntityHandle ent,
+                              int remote_proc,
+                              MBEntityHandle remote_handle);
     //! add a remote processor and the entity's handle
                               int *remote_procs,
@@ -875,11 +856,6 @@
                               int remote_proc,
-  MBEntityHandle find_ghost_entity(MBEntityHandle owning_handle,
-                                   int owning_proc);
     /** \brief Set pstatus tag interface bit on entities in sets passed in
   MBErrorCode tag_iface_entities();
@@ -890,8 +866,9 @@
     //! remove a pc from the iface instance tag PARALLEL_COMM
   void remove_pcomm(MBParallelComm *pc);
-    //! reset and populate sharedEnts from sharedEnts2 range
-  MBErrorCode populate_shared_ents();
+    //! check entities to make sure there are no zero-valued remote handles
+    //! where they shouldn't be
+  MBErrorCode check_sent_ents(MBRange &allsent);
     //! MB interface associated with this writer
   MBInterface *mbImpl;
@@ -921,17 +898,12 @@
     //! the partition, interface sets for this comm'n instance
   MBRange partitionSets, interfaceSets;
-    //! ghostStruct storing entities shared with buffProcs[i]
-    //! sharedEnts[i].ownedShared stores locally-owned shared ents
-    //! sharedEnts[i].localHandles stores ghost ents from other proc
-    //! sharedEnts[i].remoteHandles stores ghost ents from other proc,
-    //!    in terms of handles on owning proc
-  std::vector<struct GhostStruct> sharedEnts;
-  MBRange sharedEnts2;
+    //! all local entities shared with others, whether ghost or ghosted
+  MBRange sharedEnts;
     //! tags used to save sharing procs and handles
-  MBTag sharedpTag, sharedpsTag, sharedhTag, sharedhsTag, pstatusTag,
-    ifaceSetsTag, partitionTag;
+  MBTag sharedpTag, sharedpsTag, tmpifaceTag, sharedhTag, sharedhsTag, pstatusTag,
+      ifaceSetsTag, partitionTag;
   int globalPartCount; //!< Cache of global part count
@@ -940,11 +912,6 @@
   int pcommID;
-inline std::vector<struct MBParallelComm::GhostStruct> &MBParallelComm::shared_ents()
-  return sharedEnts;
 inline std::vector<unsigned int> &MBParallelComm::buff_procs()
   return buffProcs;
@@ -995,23 +962,6 @@
   return MB_SUCCESS;
-inline MBErrorCode MBParallelComm::unpack_remote_handles(unsigned int from_proc,
-                                                         const unsigned char *buff_ptr,
-                                                         const int ind,
-  unsigned char *tmp_ptr = const_cast<unsigned char *>(buff_ptr);
-  return unpack_remote_handles(from_proc, tmp_ptr, num_layers, ind, new_ghosted);
-inline MBErrorCode MBParallelComm::unpack_sharedhps_tag(unsigned int from_proc,
-  return unpack_sharedhps_tag(from_proc, tmp_ptr);
 inline MBErrorCode MBParallelComm::get_owner(MBEntityHandle entity,
                                              int &owner)
@@ -1019,4 +969,16 @@
   return get_owner_handle(entity, owner, tmp_handle);
+inline MBErrorCode MBParallelComm::unpack_remote_handles(unsigned int from_proc,
+                                                         const unsigned char *buff_ptr,
+                                                         const bool is_iface,
+                                                         const int ind)
+    // cast away const-ness, we won't be passing back a modified ptr
+  unsigned char *tmp_buff = const_cast<unsigned char*>(buff_ptr);
+  return unpack_remote_handles(from_proc, tmp_buff, is_iface, ind);
 #endif
Modified: MOAB/branches/parallel_ghosting/parallel/Makefile.am
--- MOAB/branches/parallel_ghosting/parallel/Makefile.am	2009-05-01 18:51:00 UTC (rev 2869)
+++ MOAB/branches/parallel_ghosting/parallel/Makefile.am	2009-05-01 21:24:27 UTC (rev 2870)
@@ -45,6 +45,8 @@
      ReadParallel.hpp \
      crystal.h errmem.h types.h
+  MOAB_PARALLEL_TEST += pcomm_unit parallel_unit_tests
 if PARALLEL_HDF5
 #  libMOABpar_la_LIBADD = $(top_builddir)/mhdf/libmhdf.la
   INCLUDES += -I$(top_srcdir)/mhdf/include
@@ -59,7 +61,6 @@
   mbparallelcomm_test_LDADD = $(top_builddir)/libMOAB.la
   mbparallelcomm_test_DEPENDENCIES = $(mbparallelcomm_test_LDADD)
-  MOAB_PARALLEL_TEST += pcomm_unit parallel_unit_tests
 endif
 # The list of source files, and any header files that do not need to be installed
Modified: MOAB/branches/parallel_ghosting/parallel/mbparallelcomm_test.cpp
--- MOAB/branches/parallel_ghosting/parallel/mbparallelcomm_test.cpp	2009-05-01 18:51:00 UTC (rev 2869)
+++ MOAB/branches/parallel_ghosting/parallel/mbparallelcomm_test.cpp	2009-05-01 21:24:27 UTC (rev 2870)
@@ -390,16 +390,16 @@
   MBParallelComm *pcomm = new MBParallelComm(mbImpl);
   std::vector<unsigned char> buff(1024);
   int buff_size;
-  std::set<unsigned int> my_addl_procs;
-  std::vector<int> addl_procs;
-  MBRange nonowned_ghosts[MAX_SHARING_PROCS];
-  result = pcomm->pack_buffer(ents, addl_procs, false, true, false, -1,
-                              nonowned_ghosts[0], buff, buff_size);
+  result = pcomm->pack_buffer(ents, false, true, false, -1,
+                              buff, buff_size);
   RRA("Packing buffer count (non-stored handles) failed.");
-  nonowned_ghosts[0].clear();
-  result = pcomm->unpack_buffer(&buff[0], false, -1, -1, new_ents, nonowned_ghosts,
-                                my_addl_procs);
+  std::vector<std::vector<MBEntityHandle> > L1h;
+  result = pcomm->unpack_buffer(&buff[0], false, -1, -1, L1h, L2hloc,
+                                L2hrem, L2p, new_ents);
   RRA("Unpacking buffer (non-stored handles) failed.");
   return MB_SUCCESS;
Modified: MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp
--- MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp	2009-05-01 18:51:00 UTC (rev 2869)
+++ MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp	2009-05-01 21:24:27 UTC (rev 2870)
@@ -584,15 +584,6 @@
     // test contents of interface sets against sharedEnts structure in pcomm;
   MBParallelComm* pcomm = MBParallelComm::get_pcomm(&moab, 0);
-  MBRange iface_ents, shared_ents, owned_ents;
-  for (unsigned int i = 0; i < pcomm->buff_procs().size(); i++) {
-      // get all the interface entities for this proc and the sharedEnts entities
-    rval = pcomm->get_iface_entities(pcomm->buff_procs()[i], iface_ents);
-    if (MB_SUCCESS != rval) my_error = 1;
-    owned_ents.merge(pcomm->shared_ents()[i].ownedShared);
-    shared_ents.merge(pcomm->shared_ents()[i].localHandles);
   rval = pcomm->check_all_shared_handles();
   if (MB_SUCCESS != rval) {
     my_error = 1;
Modified: MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp
--- MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp	2009-05-01 18:51:00 UTC (rev 2869)
+++ MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp	2009-05-01 21:24:27 UTC (rev 2870)
@@ -81,8 +81,8 @@
   CHECK_ERR(rval);
   MBRange tmp_range;
-  rval = pcomm->pack_buffer( entities, addl_procs, false, true, false,
-                             -1, tmp_range, buff, size);
+  rval = pcomm->pack_buffer( entities, false, true, false,
+                             -1, buff, size);
   CHECK_ERR(rval);
   delete pcomm;
@@ -92,10 +92,11 @@
   pcomm = new MBParallelComm( &moab);
   entities.clear();
-  rval = pcomm->unpack_buffer( &buff[0], false, -1, -1, entities,
-                               nonowned_ghosts, my_addl_procs);
+  rval = pcomm->unpack_buffer( &buff[0], false, -1, -1, L1h, L2hloc,
+                               L2hrem, L2p, entities);
   CHECK_ERR(rval);
   delete pcomm;
