[MOAB-dev] iMesh_getEntSetsByTagsRec fails for recursive
Jason Kraftcheck kraftche at cae.wisc.edu
Fri May 1 09:47:34 CDT 2009
Jed Brown wrote:
> MBErrorCode MBCore::get_entities_by_type_and_tag(const MBEntityHandle meshset,
>                                                    const MBEntityType type,
>                                                    const MBTag *tags,
>                                                    const void* const* values,
>                                                    const int num_tags,
>                                                    MBRange &entities,
>                                                    const int condition,
>                                                    const bool recursive) const
>   if (recursive && type == MBENTITYSET)  // will never return anything
>     return MB_TYPE_OUT_OF_RANGE;
> Why can't we get sets recursively?  Is the operation somehow
> ill-defined?
No, it just wasn't implemented (algorithm is slightly different for that
case.)  It is now.
> If so, why that name for the function in iMesh_extensions?
I'm not familiar enough with iMesh_extentions to know what function you are
referring too.  Which means I probably wouldn't know the answer to your
question anyway.
> A related pathological case just occured to me.  Will the recursive
> stuff in MOAB work correctly if set A contains set B and B contains A?
Yes, the implementation will correctly handle that scenario.
- jason
