[MOAB-dev] r2842 - MOAB/trunk/tools/iMesh
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Sat Apr 18 09:42:03 CDT 2009
Author: kraftche
Date: 2009-04-18 09:42:02 -0500 (Sat, 18 Apr 2009)
New Revision: 2842
Modified:
   MOAB/trunk/tools/iMesh/testc_cbind.c
Log:
revert unintended checkin
Modified: MOAB/trunk/tools/iMesh/testc_cbind.c
--- MOAB/trunk/tools/iMesh/testc_cbind.c	2009-04-17 21:17:03 UTC (rev 2841)
+++ MOAB/trunk/tools/iMesh/testc_cbind.c	2009-04-18 14:42:02 UTC (rev 2842)
@@ -404,65 +404,6 @@
   return TRUE;
-int adjacent_indices_test(iMesh_Instance mesh)
-  int i, count[5], idxcount[5], err, idxsum = 0;
-  iBase_EntityHandle *ent_arr, *adj_arr;
-  int *off_arr, *idx_arr;
-  int ent_arr_size, adj_arr_size, off_arr_size, idx_arr_size;
-  int junk1, junk2, junk3, junk4;
-  count[4] = 0;
-  for (i = 0; i < 4; ++i) {
-    iMesh_getNumOfType( mesh, 0, i, count+i, &err );
-    count[4] += count[i];
-  for (i = 0; i < 5; ++i) {
-    ent_arr = adj_arr = NULL;
-    off_arr = idx_arr = NULL;
-    junk1 = junk2 = junk3 = junk4 = 0;
-    iMesh_getAdjEntIndices( mesh, 0, i, iMesh_ALL_TOPOLOGIES, iBase_VERTEX,
-                            &ent_arr, &junk1, &ent_arr_size,
-                            &adj_arr, &junk2, &adj_arr_size,
-                            &idx_arr, &junk3, &idx_arr_size,
-                            &off_arr, &junk4, &off_arr_size,
-                            &err );
-    free( ent_arr );
-    free( adj_arr );
-    free( idx_arr );
-    free( off_arr );
-    if (err) {
-      printf( "%s:%d : iMesh_getAdjEntIndices failed with dimension = %d.  Error code = %d\n",
-              __FILE__, __LINE__, i, err );
-      return FALSE;
-    if (count[i] != ent_arr_size) {
-      printf( "%s:%d : Invalid number of source entities returned from iMesh_getAdjEntIndices with dimension = %d.  Expected %d, got %d\n",
-              __FILE__, __LINE__, i, count[i], ent_arr_size );
-      return FALSE;
-    idxcount[i] = idx_arr_size;
-  idxsum = 0;
-  for (i =0; i < 4; ++i)
-    idxsum += idxcount[i];
-  if (idxsum != idxcount[4]) {
-    printf( "%s:%d : Invalid adjacent entity count returned from iMesh_getAdjEntIndices for iBase_ALL_TYPES.  Expected %d (%d + %d + %d + %d), got %d\n",
-            __FILE__, __LINE__, idxsum, idxcount[0], idxcount[1], idxcount[2],
-                                        idxcount[3], idxcount[4] );
-    return FALSE;
-  return TRUE;
 int qsort_comp_handles( const void* h1, const void* h2 )
   return *(char**)h1 - *(char**)h2;
@@ -2180,15 +2121,6 @@
   number_tests++;
   printf("\n");
-    /* adjacent_indices_test */
-  printf("   adjacent_indices_test: ");
-  result = adjacent_indices_test(mesh);
-  handle_error_code(result, &number_tests_failed,
-                    &number_tests_not_implemented,
-                    &number_tests_successful);
-  number_tests++;
-  printf("\n");
     /* entity connectivity test */
   printf("   entity_connectivity_test: ");
   result = entity_connectivity_test(mesh);
