[MOAB-dev] MOAB check for *x86* failed.
Nightly Test kraftche at cae.wisc.edu
Sat Apr 18 03:52:25 CDT 2009
Making check in mhdf
make[1]: Entering directory `/home/jason/moab/test/x86/mhdf'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/jason/moab/test/x86/mhdf'
Making check in .
make[1]: Entering directory `/home/jason/moab/test/x86'
make  moab_test homxform_test scdseq_test tqdcfr test_adj seq_man_test geom_util_test xform_test obb_test vtk_test adaptive_kd_tree_tests bsp_tree_test file_options_test kd_tree_test var_len_test var_len_test_no_template tag_test mesh_set_test cub_file_test exodus_test mbcn_test kd_tree_tool kd_tree_time
make[2]: Entering directory `/home/jason/moab/test/x86'
c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -I/opt/netcdf-3.6.1-32-c2/include  -I/opt/hdf5-1.6.5-32-c2/include -isystem /opt/hdf5-1.6.5-32-c2/include  -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -DSRCDIR=../src  -Wall -pipe -pedantic -g -m32 -MT MBTest.o -MD -MP -MF .deps/MBTest.Tpo -c -o MBTest.o ../src/MBTest.cpp
mv -f .deps/MBTest.Tpo .deps/MBTest.Po
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o moab_test MBTest.o ./libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o moab_test MBTest.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
/bin/sh ./libtool --tag=CXX   --mode=link c++ -DTEST -Wall -pipe -pedantic -g -m32 -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o homxform_test homxform_test-HomXform.o ./libMOAB.la  -lm
c++ -DTEST -Wall -pipe -pedantic -g -m32 -Wall -pipe -pedantic -g -m32 -o homxform_test homxform_test-HomXform.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o scdseq_test scdseq_test.o ./libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o scdseq_test scdseq_test.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -I/opt/netcdf-3.6.1-32-c2/include  -I/opt/hdf5-1.6.5-32-c2/include -isystem /opt/hdf5-1.6.5-32-c2/include  -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -DSRCDIR=../src -DTEST_TQDCFR -Wall -pipe -pedantic -g -m32 -Wall -pipe -pedantic -g -m32 -MT tqdcfr-Tqdcfr.o -MD -MP -MF .deps/tqdcfr-Tqdcfr.Tpo -c -o tqdcfr-Tqdcfr.o `test -f 'Tqdcfr.cpp' || echo '../src/'`Tqdcfr.cpp
mv -f .deps/tqdcfr-Tqdcfr.Tpo .deps/tqdcfr-Tqdcfr.Po
/bin/sh ./libtool --tag=CXX   --mode=link c++ -DTEST_TQDCFR -Wall -pipe -pedantic -g -m32 -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o tqdcfr tqdcfr-Tqdcfr.o ./libMOAB.la  -lm
c++ -DTEST_TQDCFR -Wall -pipe -pedantic -g -m32 -Wall -pipe -pedantic -g -m32 -o tqdcfr tqdcfr-Tqdcfr.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o test_adj test_adj.o ./libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o test_adj test_adj.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o seq_man_test TestTypeSequenceManager.o ./libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o seq_man_test TestTypeSequenceManager.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -I/opt/netcdf-3.6.1-32-c2/include  -I/opt/hdf5-1.6.5-32-c2/include -isystem /opt/hdf5-1.6.5-32-c2/include  -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -DSRCDIR=../src  -Wall -pipe -pedantic -g -m32 -MT GeomUtilTests.o -MD -MP -MF .deps/GeomUtilTests.Tpo -c -o GeomUtilTests.o ../src/GeomUtilTests.cpp
mv -f .deps/GeomUtilTests.Tpo .deps/GeomUtilTests.Po
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o geom_util_test GeomUtilTests.o ./libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o geom_util_test GeomUtilTests.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
/bin/sh ./libtool --tag=CXX   --mode=link c++ -DTEST -Wall -pipe -pedantic -g -m32 -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o xform_test xform_test-MBAffineXform.o ./libMOAB.la  -lm
c++ -DTEST -Wall -pipe -pedantic -g -m32 -Wall -pipe -pedantic -g -m32 -o xform_test xform_test-MBAffineXform.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o obb_test OBBTest.o ./libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o obb_test OBBTest.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o vtk_test VtkTest.o ./libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o vtk_test VtkTest.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -I/opt/netcdf-3.6.1-32-c2/include  -I/opt/hdf5-1.6.5-32-c2/include -isystem /opt/hdf5-1.6.5-32-c2/include  -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -DSRCDIR=../src  -Wall -pipe -pedantic -g -m32 -MT adaptive_kd_tree_tests.o -MD -MP -MF .deps/adaptive_kd_tree_tests.Tpo -c -o adaptive_kd_tree_tests.o ../src/adaptive_kd_tree_tests.cpp
../src/adaptive_kd_tree_tests.cpp: In function ‘bool create_simple_2d_tree(MBAdaptiveKDTree&, MBEntityHandle&, MBEntityHandle*)’:
../src/adaptive_kd_tree_tests.cpp:416: warning: unused variable ‘mb’
mv -f .deps/adaptive_kd_tree_tests.Tpo .deps/adaptive_kd_tree_tests.Po
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o adaptive_kd_tree_tests adaptive_kd_tree_tests.o ./libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o adaptive_kd_tree_tests adaptive_kd_tree_tests.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o bsp_tree_test bsp_tree_test.o ./libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o bsp_tree_test bsp_tree_test.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
make[2]: `file_options_test' is up to date.
c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -I/opt/netcdf-3.6.1-32-c2/include  -I/opt/hdf5-1.6.5-32-c2/include -isystem /opt/hdf5-1.6.5-32-c2/include  -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -DSRCDIR=../src  -Wall -pipe -pedantic -g -m32 -MT kd_tree_test.o -MD -MP -MF .deps/kd_tree_test.Tpo -c -o kd_tree_test.o ../src/kd_tree_test.cpp
mv -f .deps/kd_tree_test.Tpo .deps/kd_tree_test.Po
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o kd_tree_test kd_tree_test.o ./libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o kd_tree_test kd_tree_test.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o var_len_test VarLenTagTest.o ./libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o var_len_test VarLenTagTest.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o var_len_test_no_template var_len_test_no_template-VarLenTagTest.o ./libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o var_len_test_no_template var_len_test_no_template-VarLenTagTest.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o tag_test TagTest.o ./libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o tag_test TagTest.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o mesh_set_test Test_MBMeshSet.o ./libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o mesh_set_test Test_MBMeshSet.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o cub_file_test cub_file_test.o ./libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o cub_file_test cub_file_test.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o exodus_test exodus_test.o ./libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o exodus_test exodus_test.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
make[2]: `mbcn_test' is up to date.
c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -I/opt/netcdf-3.6.1-32-c2/include  -I/opt/hdf5-1.6.5-32-c2/include -isystem /opt/hdf5-1.6.5-32-c2/include  -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -DSRCDIR=../src  -Wall -pipe -pedantic -g -m32 -MT kd_tree_tool.o -MD -MP -MF .deps/kd_tree_tool.Tpo -c -o kd_tree_tool.o ../src/kd_tree_tool.cpp
mv -f .deps/kd_tree_tool.Tpo .deps/kd_tree_tool.Po
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o kd_tree_tool kd_tree_tool.o ./libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o kd_tree_tool kd_tree_tool.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -I/opt/netcdf-3.6.1-32-c2/include  -I/opt/hdf5-1.6.5-32-c2/include -isystem /opt/hdf5-1.6.5-32-c2/include  -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -DSRCDIR=../src  -Wall -pipe -pedantic -g -m32 -MT kd_tree_time.o -MD -MP -MF .deps/kd_tree_time.Tpo -c -o kd_tree_time.o ../src/kd_tree_time.cpp
mv -f .deps/kd_tree_time.Tpo .deps/kd_tree_time.Po
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o kd_tree_time kd_tree_time.o ./libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o kd_tree_time kd_tree_time.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
make[2]: Leaving directory `/home/jason/moab/test/x86'
make  check-TESTS
Size of mConnMap = 10512
Size of mUpConnMap = 59904
Size of MBCN = 1
MB TEST PROGRAM:
   mb_adjacent_vertex_test: Success
   mb_adjacencies_test: Success
   mb_upward_adjacencies_test: Success
   mb_vertex_coordinate_test: Success
   mb_vertex_tag_test: Success
   mb_bar_connectivity_test: Success
   mb_tri_connectivity_test: Success
   mb_quad_connectivity_test: Success
   mb_tet_connectivity_test: Success
   mb_temporary_test: Success
   mb_hex_connectivity_test: Success
   mb_mesh_sets_set_test: Success
   mb_mesh_sets_list_test: Success
   mb_mesh_set_parent_child_test: Success
   mb_mesh_set_set_appends: Success
   mb_mesh_set_list_appends: Success
   mb_mesh_set_root_appends: Success
   mb_tags_test: Success
   mb_dense_tag_test: Success
   mb_sparse_tag_test: Success
   mb_write_mesh_test: Success
   mb_delete_mesh_test: Success
   mb_meshset_tracking_test: Success
   mb_higher_order_test: Success
   mb_bit_tags_test: Success
   mb_entity_conversion_test: Success
   mb_forced_adjacencies_test: Success
   mb_canon_number_test: Success
   mb_poly_test: Success
   mb_range_test: Success
   mb_topo_util_test: Success
   mb_split_test: Success
   mb_range_seq_intersect_test: Success
   mb_poly_adjacency_test: Success
   mb_memory_use_test: Success
   mb_merge_test: ---Starting Merge Tests---
---Testing:"test/cell1.gen"---
Loaded test/cell1.gen
---Testing:"test/cell2.gen"---
Loaded test/cell2.gen
num hexes = 28
fl = 68 rl = 0
nodes.size() = 72
---Success---
coin_nodes.size() = 13
TIME: 1232.42 seconds.
Success
   mb_stress_test:     Beginning Stress Test . . .
        Reading elements
        Read 256000 entities in 8.69 seconds
        at 29459.2 elements per second.
        Transforming and copying elements
        Transformed and created 256000 entities in 78.12 seconds
        Creating meshset
        Created meshset with 512000 entities in 0 seconds
        Writing 512K element file . . .
        Wrote file with 512000 entities in 79.51 seconds
        Total time: 166.33 seconds.
Success
MB TEST SUMMARY:
   Number Tests:           37
   Number Successful:      37
   Number Failed:          0
PASS: moab_test
All tests passed.
PASS: homxform_test
All tests passed.
PASS: scdseq_test
Usage: tqdcfr <cub_file_name>
Success.
Success.
PASS: tqdcfr
PASS: test_adj
Running test_basic ...
Running test_lower_bound ...
Running test_upper_bound ...
Running test_find ...
Running test_get_entities ...
Running test_insert_sequence_merge ...
Running test_insert_sequence_nomerge ...
Running test_remove_sequence ...
Running test_replace_subsequence ...
Running test_erase ...
Running test_find_free_handle ...
Running test_find_free_sequence ...
Running test_is_free_sequence ...
Running regression_svn1952 ...
Running regression_svn1958 ...
Running regression_svn1960 ...
ALL TESTS PASSED
PASS: seq_man_test
Running test_box_plane_overlap ...
Running test_box_linear_elem_overlap_tri ...
Running test_box_linear_elem_overlap_tet ...
Running test_box_linear_elem_overlap_hex ...
Running test_box_tri_overlap ...
Running test_box_tet_overlap ...
Running test_box_hex_overlap ...
Running test_ray_tri_intersect ...
Running test_closest_location_on_tri ...
Running test_closest_location_on_polygon ...
Running test_segment_box_intersect ...
Running test_closest_location_on_box ...
PASS: geom_util_test
PASS: xform_test
PASS: obb_test
Testing edge2...
Testing edge3...
Testing tri3...
Testing tri6...
Testing quad4...
Testing quad8...
Testing polygon...
Testing tet4...
Testing tet10...
Testing hex8...
Testing hex20...
Testing wedge...
Testing pyramid...
Testing structured_points_2d...
Testing structured_grid_2d...
Testing rectilinear_grid_2d...
Testing structured_points_3d...
Testing structured_grid_3d...
Testing rectilinear_grid_3d...
Testing scalar_attrib_1_bit...
Testing scalar_attrib_1_uchar...
Testing scalar_attrib_1_char...
Testing scalar_attrib_1_ushort...
Testing scalar_attrib_1_short...
Testing scalar_attrib_1_uint...
Testing scalar_attrib_1_int...
Testing scalar_attrib_1_ulong...
Testing scalar_attrib_1_long...
Testing scalar_attrib_1_float...
Testing scalar_attrib_1_double...
Testing scalar_attrib_4_bit...
Testing scalar_attrib_4_uchar...
Testing scalar_attrib_4_char...
Testing scalar_attrib_4_ushort...
Testing scalar_attrib_4_short...
Testing scalar_attrib_4_uint...
Testing scalar_attrib_4_int...
Testing scalar_attrib_4_ulong...
Testing scalar_attrib_4_long...
Testing scalar_attrib_4_float...
Testing scalar_attrib_4_double...
Testing vector_attrib_bit...
Testing vector_attrib_uchar...
Testing vector_attrib_char...
Testing vector_attrib_ushort...
Testing vector_attrib_short...
Testing vector_attrib_uint...
Testing vector_attrib_int...
Testing vector_attrib_ulong...
Testing vector_attrib_long...
Testing vector_attrib_float...
Testing vector_attrib_double...
Testing tensor_attrib_uchar...
Testing tensor_attrib_char...
Testing tensor_attrib_ushort...
Testing tensor_attrib_short...
Testing tensor_attrib_uint...
Testing tensor_attrib_int...
Testing tensor_attrib_ulong...
Testing tensor_attrib_long...
Testing tensor_attrib_float...
Testing tensor_attrib_double...
Testing subset...
63 tests passed
PASS: vtk_test
PASS: adaptive_kd_tree_tests
Running test_iterator ...
Running test_box_iterator ...
Running test_tree_create ...
Running test_box_tree_create ...
Running test_leaf_containing_point_bounded_tree ...
Running test_leaf_containing_point_unbounded_tree ...
Running test_merge_leaf ...
PASS: bsp_tree_test
PASS: file_options_test
HDF5-DIAG: Error detected in HDF5 library version: 1.6.5 thread 0.  Back trace follows.
  #000: H5D.c line 1146 in H5Dopen(): not found
    major(15): Dataset interface
    minor(48): Object not found
  #001: H5G.c line 2296 in H5G_find(): object not found
    major(10): Symbol table layer
  #002: H5G.c line 1495 in H5G_namei(): component not found
  #003: H5Gstab.c line 164 in H5G_stab_find(): not found
  #004: H5Gnode.c line 975 in H5G_node_found(): not found
PASS: kd_tree_test
Running test_valid_struct ...
Running test_inline ...
Running test_non_inline ...
Running test_resize_ii ...
Running test_resize_in ...
Running test_resize_ni ...
Running test_resize_nn ...
PASS: var_len_test
PASS: var_len_test_no_template
Running test_create_tag ...
Running test_invalid_tag_size ...
Running test_get_set_sparse_int ...
Running test_get_set_dense_int ...
Running test_get_set_dense_double ...
Running test_get_set_bit ...
Running test_get_by_tag ...
Running test_get_by_tag_value ...
Running test_mesh_value ...
Running test_get_pointers_sparse ...
Running test_get_pointers_dense ...
Running test_set_pointers_sparse ...
Running test_set_pointers_dense ...
Running test_get_entity_tags ...
Running test_delete_sparse_tag ...
Running test_delete_dense_tag ...
Running test_delete_mesh_tag ...
Running test_delete_sparse_data ...
Running test_delete_dense_data ...
Running test_delete_bit_data ...
Running test_create_variable_length_tag ...
Running test_get_set_variable_length_sparse ...
Running test_get_set_variable_length_dense ...
Running test_get_set_variable_length_mesh ...
Running regression_one_entity_by_var_tag ...
Running regression_tag_on_nonexistent_entity ...
PASS: tag_test
Running test_add_entities_ordered ...
Running test_add_entities_set ...
Running test_add_entities_ordered_tracking ...
Running test_add_entities_set_tracking ...
Running test_remove_entities_ordered ...
Running test_remove_entities_set ...
Running test_remove_entities_ordered_tracking ...
Running test_remove_entities_set_tracking ...
Running test_entities_by_type_ordered ...
Running test_entities_by_type_set ...
Running test_entities_by_dim_ordered ...
Running test_entities_by_dim_set ...
Running test_subtract_set_set ...
Running test_subtract_set_ordered ...
Running test_subtract_ordered_set ...
Running test_subtract_ordered_ordered ...
Running test_subtract_set_set_tracking ...
Running test_subtract_set_ordered_tracking ...
Running test_subtract_ordered_set_tracking ...
Running test_subtract_ordered_ordered_tracking ...
Running test_itersect_set_set ...
Running test_itersect_set_ordered ...
Running test_itersect_ordered_set ...
Running test_itersect_ordered_ordered ...
Running test_itersect_set_set_tracking ...
Running test_itersect_set_ordered_tracking ...
Running test_itersect_ordered_set_tracking ...
Running test_itersect_ordered_ordered_tracking ...
Running test_unite_set_set ...
Running test_unite_set_ordered ...
Running test_unite_ordered_set ...
Running test_unite_ordered_ordered ...
Running test_unite_set_set_tracking ...
Running test_unite_set_ordered_tracking ...
Running test_unite_ordered_set_tracking ...
Running test_unite_ordered_ordered_tracking ...
Running test_contains_entities_ordered ...
Running test_contains_entities_set ...
Running test_clear_ordered ...
Running test_clear_set ...
Running test_clear_ordered_tracking ...
Running test_clear_set_tracking ...
ALL TESTS PASSED
PASS: mesh_set_test
Running test_vertices ...
Running test_edges ...
Running test_quads ...
Running test_hexes ...
Running test_geometric_topology ...
Running test_geometric_sets ...
Running test_blocks ...
Running test_side_sets ...
Running test_node_sets ...
Running test_file_set ...
Running test_tri6 ...
Running test_tri7 ...
Running test_quad5 ...
Running test_quad8 ...
Running test_quad9 ...
Running test_tet8 ...
Running test_tet10 ...
Running test_tet14 ...
Running test_hex9 ...
Running test_hex20 ...
Running test_hex27 ...
Running test_multiple_files ...
PASS: cub_file_test
PASS: exodus_test
Running test_dimension_pair ...
Running test_type_names ...
Running test_dimension ...
Running test_vertices_per_entity ...
Running test_num_sub_entities ...
Running test_sub_entity_type_vtx ...
Running test_sub_entity_type_edge ...
Running test_sub_entity_type_tri ...
Running test_sub_entity_type_quad ...
Running test_sub_entity_type_tet ...
Running test_sub_entity_type_pyr ...
Running test_sub_entity_type_pri ...
Running test_sub_entity_type_knife ...
Running test_sub_entity_type_hex ...
Running test_sub_entity_indices_vtx ...
Running test_sub_entity_indices_edge ...
Running test_sub_entity_indices_tri ...
Running test_sub_entity_indices_quad ...
Running test_sub_entity_indices_tet ...
Running test_sub_entity_indices_pyr ...
Running test_sub_entity_indices_pri ...
Running test_sub_entity_indices_hex ...
Running test_side_number_tri ...
Running test_side_number_quad ...
Running test_side_number_tet ...
Running test_side_number_pyr ...
Running test_side_number_pri ...
Running test_side_number_hex ...
Running test_opposite_side_tri ...
Running test_opposite_side_quad ...
Running test_opposite_side_tet ...
Running test_opposite_side_hex ...
Running test_has_mid_nodes_edge ...
Running test_has_mid_nodes_tri ...
Running test_has_mid_nodes_quad ...
Running test_has_mid_nodes_tet ...
Running test_has_mid_nodes_pyr ...
Running test_has_mid_nodes_pri ...
Running test_has_mid_nodes_knife ...
Running test_has_mid_nodes_hex ...
Running test_sub_entity_nodes_tri_edges ...
Running test_sub_entity_nodes_quad_edges ...
Running test_sub_entity_nodes_tet_edges ...
Running test_sub_entity_nodes_tet_faces ...
Running test_sub_entity_nodes_pyr_edges ...
Running test_sub_entity_nodes_pyr_faces ...
Running test_sub_entity_nodes_pri_edges ...
Running test_sub_entity_nodes_pri_faces ...
Running test_sub_entity_nodes_kni_edges ...
Running test_sub_entity_nodes_kni_faces ...
Running test_sub_entity_nodes_hex_edges ...
Running test_sub_entity_nodes_hex_faces ...
Running test_ho_node_parent ...
Running test_ho_node_index ...
PASS: mbcn_test
All 21 tests passed
make[1]: Leaving directory `/home/jason/moab/test/x86'
Making check in test
make[1]: Entering directory `/home/jason/moab/test/x86/test'
Making check in dual
make[2]: Entering directory `/home/jason/moab/test/x86/test/dual'
make  dual_test
make[3]: Entering directory `/home/jason/moab/test/x86/test/dual'
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o dual_test dual_test.o ../../libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o dual_test dual_test.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
make[3]: Leaving directory `/home/jason/moab/test/x86/test/dual'
make  check-TESTS
Usage: dual_test <mesh_file_name>
PASS: dual_test
All 1 tests passed
make[2]: Leaving directory `/home/jason/moab/test/x86/test/dual'
Making check in h5file
make[2]: Entering directory `/home/jason/moab/test/x86/test/h5file'
make  h5test h5legacy h5varlen h5sets_test h5regression
make[3]: Entering directory `/home/jason/moab/test/x86/test/h5file'
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o h5test h5file_test.o ../../libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o h5test h5file_test.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/test/h5file -I../.. -I../../../src -I../../../src/mhdf/include -I../.. -I/opt/netcdf-3.6.1-32-c2/include  -I/opt/hdf5-1.6.5-32-c2/include -isystem /opt/hdf5-1.6.5-32-c2/include  -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -g -m32 -MT h5legacy.o -MD -MP -MF .deps/h5legacy.Tpo -c -o h5legacy.o ../../../src/test/h5file/h5legacy.cpp
mv -f .deps/h5legacy.Tpo .deps/h5legacy.Po
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o h5legacy h5legacy.o ../../libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o h5legacy h5legacy.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o h5varlen h5varlen.o ../../libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o h5varlen h5varlen.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/test/h5file -I../.. -I../../../src -I../../../src/mhdf/include -I../.. -I/opt/netcdf-3.6.1-32-c2/include  -I/opt/hdf5-1.6.5-32-c2/include -isystem /opt/hdf5-1.6.5-32-c2/include  -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -g -m32 -MT h5sets_test.o -MD -MP -MF .deps/h5sets_test.Tpo -c -o h5sets_test.o ../../../src/test/h5file/h5sets_test.cpp
mv -f .deps/h5sets_test.Tpo .deps/h5sets_test.Po
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o h5sets_test h5sets_test.o ../../libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o h5sets_test h5sets_test.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/test/h5file -I../.. -I../../../src -I../../../src/mhdf/include -I../.. -I/opt/netcdf-3.6.1-32-c2/include  -I/opt/hdf5-1.6.5-32-c2/include -isystem /opt/hdf5-1.6.5-32-c2/include  -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -g -m32 -MT h5regression.o -MD -MP -MF .deps/h5regression.Tpo -c -o h5regression.o ../../../src/test/h5file/h5regression.cpp
mv -f .deps/h5regression.Tpo .deps/h5regression.Po
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o h5regression h5regression.o ../../libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o h5regression h5regression.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
make[3]: Leaving directory `/home/jason/moab/test/x86/test/h5file'
make  check-TESTS
creating... writing... reading... comparing... success!
writing... clearing db... reading... comparing... success!
cleaning up... done.
PASS: h5test
Running test_moab_v3_poly_format ...
PASS: h5legacy
Running test_var_length_no_data ...
Running test_var_length_data ...
Running test_var_length_big_data ...
Running test_var_length_opaque ...
Running test_var_length_mesh_data ...
Running test_var_length_default_data ...
Running test_var_length_mesh_opaque ...
Running test_var_length_default_opaque ...
Running test_var_length_handle_tag ...
Running test_var_length_data_big ...
PASS: h5varlen
Running test_ranged_set_with_holes ...
PASS: h5sets_test
Running test_write_invalid_elem ...
PASS: h5regression
All 5 tests passed
make[2]: Leaving directory `/home/jason/moab/test/x86/test/h5file'
Making check in obb
make[2]: Entering directory `/home/jason/moab/test/x86/test/obb'
make  obb_test obb_time obb_tree_tool
make[3]: Entering directory `/home/jason/moab/test/x86/test/obb'
c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/test/obb -I../.. -I../../../src -I../.. -I/opt/netcdf-3.6.1-32-c2/include  -I/opt/hdf5-1.6.5-32-c2/include -isystem /opt/hdf5-1.6.5-32-c2/include  -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -g -m32 -MT obb_test.o -MD -MP -MF .deps/obb_test.Tpo -c -o obb_test.o ../../../src/test/obb/obb_test.cpp
mv -f .deps/obb_test.Tpo .deps/obb_test.Po
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o obb_test obb_test.o ../../libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o obb_test obb_test.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o obb_time obb_time.o ../../libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o obb_time obb_time.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o obb_tree_tool obb_tree_tool.o ../../libMOAB.la  -lm
c++ -Wall -pipe -pedantic -g -m32 -o obb_tree_tool obb_tree_tool.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
make[3]: Leaving directory `/home/jason/moab/test/x86/test/obb'
make  check-TESTS
MOAB 3.99 (Alpha)
No file(s) specified.
Using default file "../../../src/test/3k-tri-sphere.vtk"
Using default file "../../../src/test/3k-tri-cube.h5m"
Building tree from 2970 2D elements
No errors detected.
Building tree from 6 surfaces
Built tree from 6 surfaces (2934 elements)
No errors detected.
PASS: obb_test
All 1 tests passed
make[2]: Leaving directory `/home/jason/moab/test/x86/test/obb'
Making check in perf
make[2]: Entering directory `/home/jason/moab/test/x86/test/perf'
/bin/sh ../../libtool --tag=CC   --mode=link cc  -Wall -pipe -pedantic -g -m32 -L/opt/netcdf-3.6.1-32-c2/lib   -L/opt/hdf5-1.6.5-32-c2/lib   -o point_in_elem point_in_elem.o ../../libMOAB.la  -lm
cc -Wall -pipe -pedantic -g -m32 -o point_in_elem point_in_elem.o  -L/opt/netcdf-3.6.1-32-c2/lib -L/opt/hdf5-1.6.5-32-c2/lib ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /opt/hdf5-1.6.5-32-c2/lib/libhdf5.so -lm   -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib -Wl,--rpath -Wl,/opt/hdf5-1.6.5-32-c2/lib
point_in_elem.o: In function `__static_initialization_and_destruction_0':
/usr/include/c++/4.3/iostream:77: undefined reference to `std::ios_base::Init::Init()'
/usr/include/c++/4.3/iostream:77: undefined reference to `std::ios_base::Init::~Init()'
point_in_elem.o: In function `usage(char*, bool)':
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:32: undefined reference to `std::cerr'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:32: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:32: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:32: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:33: undefined reference to `std::cerr'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:33: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:33: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:33: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:44: undefined reference to `std::cout'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:44: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:44: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:44: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:44: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(long)'
point_in_elem.o: In function `fail(MBErrorCode, char const*, int)':
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:187: undefined reference to `std::cerr'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:187: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:187: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:187: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:187: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
point_in_elem.o: In function `random_point_in_hex(MBInterface&, unsigned int)':
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:211: undefined reference to `std::cerr'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:211: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:211: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:211: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
point_in_elem.o: In function `generate_random_points(MBInterface&, unsigned int, std::vector<MBCartVect, std::allocator<MBCartVect> >&, std::vector<unsigned int, std::allocator<unsigned int> >&)':
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:238: undefined reference to `std::cerr'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:238: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:238: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:238: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:244: undefined reference to `std::cerr'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:244: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:244: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:244: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
point_in_elem.o: In function `main':
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:78: undefined reference to `std::cerr'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:78: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:78: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:78: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:92: undefined reference to `std::cerr'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:92: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:92: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:92: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:101: undefined reference to `std::cerr'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:101: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:101: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:101: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:106: undefined reference to `std::cerr'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:106: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:106: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:106: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:110: undefined reference to `std::cerr'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:110: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:110: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:110: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:120: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:124: undefined reference to `std::cerr'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:124: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:124: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:124: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:127: undefined reference to `std::cerr'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:127: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:127: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char>, std::allocator<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:127: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:127: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:165: undefined reference to `std::cout'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:165: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:165: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:165: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:170: undefined reference to `std::cout'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:170: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:170: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(long)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:170: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:170: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:171: undefined reference to `std::cout'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:171: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:171: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(double)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:171: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:171: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:172: undefined reference to `std::cout'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:172: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:172: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(double)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:172: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:172: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:173: undefined reference to `std::cout'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:173: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:173: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(double)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:173: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:173: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:174: undefined reference to `std::cout'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:174: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:174: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:174: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:174: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:176: undefined reference to `std::cout'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:176: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:176: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(double)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:176: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:176: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:177: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:177: undefined reference to `std::cout'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:177: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:178: undefined reference to `std::cout'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:178: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:178: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned long)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:178: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:178: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:179: undefined reference to `std::cout'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:179: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:179: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned long)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:179: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:179: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:180: undefined reference to `std::cout'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:180: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:180: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned long)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:180: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:180: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/test/perf/../../../src/test/perf/point_in_elem.cpp:181: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
point_in_elem.o: In function `std::basic_string<char, std::char_traits<char>, std::allocator<char> > std::operator+<char, std::char_traits<char>, std::allocator<char> >(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
/usr/include/c++/4.3/bits/basic_string.h:2086: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/usr/include/c++/4.3/bits/basic_string.h:2087: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::append(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/usr/include/c++/4.3/bits/basic_string.h:2088: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
point_in_elem.o: In function `MBInterface::api_version(std::basic_string<char, std::char_traits<char>, std::allocator<char> >*)':
/home/jason/moab/test/x86/test/perf/../../../src/MBInterface.hpp:1695: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/test/perf/../../../src/MBInterface.hpp:1695: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/test/perf/../../../src/MBInterface.hpp:1695: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/test/perf/../../../src/MBInterface.hpp:1695: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/test/perf/../../../src/MBInterface.hpp:1695: undefined reference to `std::allocator<char>::~allocator()'
point_in_elem.o: In function `~MBUnknownInterface':
/home/jason/moab/test/x86/test/perf/../../../src/MBUnknownInterface.hpp:96: undefined reference to `operator delete(void*)'
point_in_elem.o: In function `~MBInterface':
/home/jason/moab/test/x86/test/perf/../../../src/MBInterface.hpp:83: undefined reference to `operator delete(void*)'
point_in_elem.o:/usr/include/c++/4.3/ext/new_allocator.h:98: more undefined references to `operator delete(void*)' follow
point_in_elem.o: In function `std::vector<unsigned int, std::allocator<unsigned int> >::_M_check_len(unsigned int, char const*) const':
/usr/include/c++/4.3/bits/stl_vector.h:1078: undefined reference to `std::__throw_length_error(char const*)'
point_in_elem.o: In function `std::vector<MBCartVect, std::allocator<MBCartVect> >::_M_check_len(unsigned int, char const*) const':
point_in_elem.o: In function `__gnu_cxx::new_allocator<unsigned int>::allocate(unsigned int, void const*)':
/usr/include/c++/4.3/ext/new_allocator.h:90: undefined reference to `std::__throw_bad_alloc()'
/usr/include/c++/4.3/ext/new_allocator.h:92: undefined reference to `operator new(unsigned int)'
point_in_elem.o: In function `__gnu_cxx::new_allocator<MBCartVect>::allocate(unsigned int, void const*)':
point_in_elem.o: In function `__gnu_cxx::__enable_if<std::__is_char<char>::__value, bool>::__type std::operator==<char>(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
/usr/include/c++/4.3/bits/basic_string.h:2165: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::size() const'
/usr/include/c++/4.3/bits/basic_string.h:2165: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::data() const'
point_in_elem.o:(.rodata._ZTV11MBInterface[vtable for MBInterface]+0x8): undefined reference to `__cxa_pure_virtual'
point_in_elem.o:(.rodata._ZTV11MBInterface[vtable for MBInterface]+0x14): undefined reference to `__cxa_pure_virtual'
point_in_elem.o:(.rodata._ZTV11MBInterface[vtable for MBInterface]+0x18): undefined reference to `__cxa_pure_virtual'
point_in_elem.o:(.rodata._ZTV11MBInterface[vtable for MBInterface]+0x1c): undefined reference to `__cxa_pure_virtual'
point_in_elem.o:(.rodata._ZTV11MBInterface[vtable for MBInterface]+0x24): undefined reference to `__cxa_pure_virtual'
point_in_elem.o:(.rodata._ZTV11MBInterface[vtable for MBInterface]+0x28): more undefined references to `__cxa_pure_virtual' follow
point_in_elem.o:(.rodata._ZTI11MBInterface[typeinfo for MBInterface]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
point_in_elem.o:(.rodata._ZTI18MBUnknownInterface[typeinfo for MBUnknownInterface]+0x0): undefined reference to `vtable for __cxxabiv1::__class_type_info'
point_in_elem.o:(.rodata._ZTV18MBUnknownInterface[vtable for MBUnknownInterface]+0x8): undefined reference to `__cxa_pure_virtual'
point_in_elem.o:(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(MBAdaptiveKDTree.o): In function `make_tag':
/home/jason/moab/test/x86/../src/MBAdaptiveKDTree.cpp:98: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/MBAdaptiveKDTree.cpp:108: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
../../.libs/libMOAB.a(MBAdaptiveKDTree.o): In function `MBAdaptiveKDTree::init(char const*)':
/home/jason/moab/test/x86/../src/MBAdaptiveKDTree.cpp:142: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/MBAdaptiveKDTree.cpp:142: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/MBAdaptiveKDTree.cpp:142: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/MBAdaptiveKDTree.cpp:142: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/MBAdaptiveKDTree.cpp:162: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/MBAdaptiveKDTree.cpp:162: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/MBAdaptiveKDTree.cpp:162: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/MBAdaptiveKDTree.cpp:163: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator+=(char const*)'
/home/jason/moab/test/x86/../src/MBAdaptiveKDTree.cpp:164: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/MBAdaptiveKDTree.cpp:164: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(MBAdaptiveKDTree.o): In function `__gnu_cxx::new_allocator<MBAdaptiveKDTreeIter::StackObj>::deallocate(MBAdaptiveKDTreeIter::StackObj*, unsigned int)':
/usr/include/c++/4.3/ext/new_allocator.h:98: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(MBAdaptiveKDTree.o): In function `__gnu_cxx::new_allocator<double>::deallocate(double*, unsigned int)':
../../.libs/libMOAB.a(MBAdaptiveKDTree.o): In function `__gnu_cxx::new_allocator<NodeSeg>::deallocate(NodeSeg*, unsigned int)':
../../.libs/libMOAB.a(MBAdaptiveKDTree.o): In function `__gnu_cxx::new_allocator<NodeDistance>::deallocate(NodeDistance*, unsigned int)':
../../.libs/libMOAB.a(MBAdaptiveKDTree.o): In function `__gnu_cxx::new_allocator<MBAdaptiveKDTreeIter>::deallocate(MBAdaptiveKDTreeIter*, unsigned int)':
../../.libs/libMOAB.a(MBAdaptiveKDTree.o):/usr/include/c++/4.3/ext/new_allocator.h:98: more undefined references to `operator delete(void*)' follow
../../.libs/libMOAB.a(MBAdaptiveKDTree.o): In function `__gnu_cxx::new_allocator<double>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(MBAdaptiveKDTree.o): In function `__gnu_cxx::new_allocator<NodeSeg>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(MBAdaptiveKDTree.o): In function `__gnu_cxx::new_allocator<NodeDistance>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(MBAdaptiveKDTree.o): In function `__gnu_cxx::new_allocator<MBAdaptiveKDTreeIter::StackObj>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(MBAdaptiveKDTree.o): In function `__gnu_cxx::new_allocator<MBAdaptiveKDTreeIter>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(MBAdaptiveKDTree.o): In function `__gnu_cxx::new_allocator<void**>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(MBAdaptiveKDTree.o): In function `MBAdaptiveKDTreeIter* std::__uninitialized_copy<false>::uninitialized_copy<MBAdaptiveKDTreeIter*, MBAdaptiveKDTreeIter*>(MBAdaptiveKDTreeIter*, MBAdaptiveKDTreeIter*, MBAdaptiveKDTreeIter*)':
/usr/include/c++/4.3/bits/stl_uninitialized.h:83: undefined reference to `__cxa_begin_catch'
/usr/include/c++/4.3/bits/stl_uninitialized.h:86: undefined reference to `__cxa_rethrow'
/usr/include/c++/4.3/bits/stl_uninitialized.h:83: undefined reference to `__cxa_end_catch'
../../.libs/libMOAB.a(MBAdaptiveKDTree.o): In function `std::vector<double, std::allocator<double> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(MBAdaptiveKDTree.o): In function `std::vector<NodeSeg, std::allocator<NodeSeg> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(MBAdaptiveKDTree.o): In function `std::vector<unsigned int, std::allocator<unsigned int> >::reserve(unsigned int)':
/usr/include/c++/4.3/bits/vector.tcc:73: undefined reference to `std::__throw_length_error(char const*)'
../../.libs/libMOAB.a(MBAdaptiveKDTree.o): In function `std::vector<NodeDistance, std::allocator<NodeDistance> >::reserve(unsigned int)':
../../.libs/libMOAB.a(MBAdaptiveKDTree.o): In function `std::vector<NodeDistance, std::allocator<NodeDistance> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(MBAdaptiveKDTree.o):/usr/include/c++/4.3/bits/stl_vector.h:1078: more undefined references to `std::__throw_length_error(char const*)' follow
../../.libs/libMOAB.a(MBAdaptiveKDTree.o): In function `std::vector<MBAdaptiveKDTreeIter, std::allocator<MBAdaptiveKDTreeIter> >::_M_insert_aux(__gnu_cxx::__normal_iterator<MBAdaptiveKDTreeIter*, std::vector<MBAdaptiveKDTreeIter, std::allocator<MBAdaptiveKDTreeIter> > >, MBAdaptiveKDTreeIter const&)':
/usr/include/c++/4.3/bits/vector.tcc:330: undefined reference to `__cxa_begin_catch'
/usr/include/c++/4.3/bits/vector.tcc:334: undefined reference to `__cxa_rethrow'
/usr/include/c++/4.3/bits/vector.tcc:330: undefined reference to `__cxa_end_catch'
../../.libs/libMOAB.a(MBAdaptiveKDTree.o): In function `std::vector<void**, std::allocator<void**> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(MBAdaptiveKDTree.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(MBCore.o): In function `MBCore::tag_get_name(void**, std::basic_string<char, std::char_traits<char>, std::allocator<char> >&) const':
/home/jason/moab/test/x86/../src/MBCore.cpp:1651: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
../../.libs/libMOAB.a(MBCore.o): In function `MBCore::impl_version(std::basic_string<char, std::char_traits<char>, std::allocator<char> >*)':
/home/jason/moab/test/x86/../src/MBCore.cpp:314: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(char const*)'
../../.libs/libMOAB.a(MBCore.o): In function `MBCore::get_error_string(MBErrorCode) const':
/home/jason/moab/test/x86/../src/MBCore.cpp:2673: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/MBCore.cpp:2673: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2673: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(MBCore.o): In function `__static_initialization_and_destruction_0':
../../.libs/libMOAB.a(MBCore.o): In function `MBCore::print_database() const':
/home/jason/moab/test/x86/../src/MBCore.cpp:3153: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/MBCore.cpp:3153: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(MBCore.o): In function `MBCore::list_entities(MBRange const&) const':
/home/jason/moab/test/x86/../src/MBCore.cpp:1995: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:1995: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:1995: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:1995: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:1995: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(MBCore.o): In function `MBCore::check_adjacencies(unsigned int const*, int)':
/home/jason/moab/test/x86/../src/MBCore.cpp:2794: undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream(std::_Ios_Openmode)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2798: undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream(std::_Ios_Openmode)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2800: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2800: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2805: undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str() const'
/home/jason/moab/test/x86/../src/MBCore.cpp:2805: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/MBCore.cpp:2805: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char>, std::allocator<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2805: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2805: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2805: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2805: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/MBCore.cpp:2819: undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str() const'
/home/jason/moab/test/x86/../src/MBCore.cpp:2819: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char>, std::allocator<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2819: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2819: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2819: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2819: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2819: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/MBCore.cpp:2823: undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str() const'
/home/jason/moab/test/x86/../src/MBCore.cpp:2823: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::empty() const'
/home/jason/moab/test/x86/../src/MBCore.cpp:2823: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/MBCore.cpp:2824: undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str() const'
/home/jason/moab/test/x86/../src/MBCore.cpp:2824: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/MBCore.cpp:2824: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char>, std::allocator<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2824: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/MBCore.cpp:2825: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/MBCore.cpp:2825: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2825: undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2825: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/MBCore.cpp:2825: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/MBCore.cpp:2835: undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str() const'
/home/jason/moab/test/x86/../src/MBCore.cpp:2835: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char>, std::allocator<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2835: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2835: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2835: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2835: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2835: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/MBCore.cpp:2845: undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str() const'
/home/jason/moab/test/x86/../src/MBCore.cpp:2845: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char>, std::allocator<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2845: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2845: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2845: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/MBCore.cpp:2847: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2847: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2847: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2848: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2848: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2848: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2848: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2855: undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str() const'
/home/jason/moab/test/x86/../src/MBCore.cpp:2855: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char>, std::allocator<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2855: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2855: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2855: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2855: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2855: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/MBCore.cpp:2859: undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str() const'
/home/jason/moab/test/x86/../src/MBCore.cpp:2859: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::empty() const'
/home/jason/moab/test/x86/../src/MBCore.cpp:2859: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/MBCore.cpp:2860: undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str() const'
/home/jason/moab/test/x86/../src/MBCore.cpp:2860: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/MBCore.cpp:2860: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char>, std::allocator<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2860: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/MBCore.cpp:2861: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/MBCore.cpp:2861: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2861: undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2861: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/MBCore.cpp:2861: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/MBCore.cpp:2796: undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::~basic_ostringstream()'
/home/jason/moab/test/x86/../src/MBCore.cpp:2867: undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::~basic_ostringstream()'
../../.libs/libMOAB.a(MBCore.o): In function `MBCore::print(unsigned int, char const*, bool) const':
/home/jason/moab/test/x86/../src/MBCore.cpp:2686: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2686: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2686: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2686: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2686: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2694: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2694: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2694: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2694: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2697: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/MBCore.cpp:2697: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2697: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/MBCore.cpp:2698: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator+=(char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2699: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/MBCore.cpp:2706: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2706: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2707: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2707: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2707: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2707: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2710: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2710: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2711: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2711: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2713: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2713: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2713: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2718: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2718: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2719: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2719: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2719: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2719: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2722: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2722: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2723: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2723: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2725: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2725: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2725: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2731: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2731: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char>, std::allocator<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2731: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2731: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2731: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2732: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator+=(char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2748: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/MBCore.cpp:2755: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2755: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char>, std::allocator<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2755: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2755: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2755: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2755: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2760: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2760: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char>, std::allocator<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2760: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2760: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(double)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2760: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2760: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2765: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2765: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char>, std::allocator<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2765: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2765: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2765: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2765: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2734: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/MBCore.cpp:2771: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(MBCore.o): In function `MBCore::list_entity(unsigned int) const':
/home/jason/moab/test/x86/../src/MBCore.cpp:2010: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2010: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2010: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2010: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2018: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2018: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2018: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2018: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2018: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2028: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2028: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2028: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(double)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2028: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2028: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2033: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2033: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2033: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2033: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2044: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2044: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2045: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2045: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2046: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2046: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2046: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2049: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2049: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2049: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2055: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2055: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2055: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2055: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2060: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2060: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2062: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2062: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2064: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2064: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2064: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2066: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2066: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2066: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2069: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2069: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2069: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2069: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2069: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:2071: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:2071: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:2071: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(MBCore.o): In function `MBCore::list_entities(unsigned int const*, int) const':
/home/jason/moab/test/x86/../src/MBCore.cpp:1940: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:1940: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:1940: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:1941: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:1941: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:1941: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:1941: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:1944: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:1944: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:1944: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:1944: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:1944: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:1946: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:1946: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:1946: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:1956: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:1956: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:1956: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:1956: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:1956: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:1966: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:1966: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:1966: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBCore.cpp:1979: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/MBCore.cpp:1979: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:1979: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:1979: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:1979: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(MBCore.o): In function `MBCore::create_vertices(double const*, int, MBRange&)':
/home/jason/moab/test/x86/../src/MBCore.cpp:1799: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/MBCore.cpp:1799: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:1799: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/MBCore.cpp:1799: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(MBCore.o): In function `MBCore::delete_mesh()':
/home/jason/moab/test/x86/../src/MBCore.cpp:533: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:534: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:534: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(MBCore.o): In function `MBCore::write_file(char const*, char const*, char const*, MBRange const&, void** const*, int)':
/home/jason/moab/test/x86/../src/MBCore.cpp:498: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/MBCore.cpp:498: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:498: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/MBCore.cpp:498: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/MBCore.cpp:499: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/MBCore.cpp:504: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:504: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(MBCore.o): In function `MBCore::serial_load_file(char const*, unsigned int&, FileOptions const&, char const*, int const*, int)':
/home/jason/moab/test/x86/../src/MBCore.cpp:418: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/MBCore.cpp:418: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:418: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/MBCore.cpp:418: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(MBCore.o): In function `MBCore::load_file(char const*, unsigned int&, char const*, char const*, int const*, int)':
/home/jason/moab/test/x86/../src/MBCore.cpp:372: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/MBCore.cpp:399: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(MBCore.o): In function `MBCore::query_interface(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, void**)':
/home/jason/moab/test/x86/../src/MBCore.cpp:241: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:241: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:249: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:249: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:259: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(MBCore.o): In function `MBCore::deinitialize()':
/home/jason/moab/test/x86/../src/MBCore.cpp:212: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:222: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:226: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:230: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(MBCore.o): In function `~MBCore':
/home/jason/moab/test/x86/../src/MBCore.cpp:158: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(MBCore.o):/home/jason/moab/test/x86/../src/MBCore.cpp:158: more undefined references to `operator delete(void*)' follow
../../.libs/libMOAB.a(MBCore.o): In function `MBCore::initialize()':
/home/jason/moab/test/x86/../src/MBCore.cpp:170: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:174: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:174: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:178: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:178: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:182: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:191: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/MBCore.cpp:182: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:191: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(MBCore.o): In function `MBCore':
/home/jason/moab/test/x86/../src/MBCore.cpp:133: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/MBCore.cpp:133: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBCore.cpp:133: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBCore.cpp:133: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(MBCore.o): In function `~MBError':
/home/jason/moab/test/x86/../src/MBError.hpp:59: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(MBCore.o): In function `MBError::get_last_error(std::basic_string<char, std::char_traits<char>, std::allocator<char> >&) const':
/home/jason/moab/test/x86/../src/MBError.hpp:83: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
../../.libs/libMOAB.a(MBCore.o): In function `MBError':
/home/jason/moab/test/x86/../src/MBError.hpp:58: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
../../.libs/libMOAB.a(MBCore.o): In function `~_Vector_impl':
/usr/include/c++/4.3/bits/stl_vector.h:79: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(MBCore.o): In function `_Vector_impl':
/usr/include/c++/4.3/bits/stl_vector.h:89: undefined reference to `std::allocator<char>::allocator(std::allocator<char> const&)'
../../.libs/libMOAB.a(MBCore.o): In function `void std::_Destroy<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >(std::basic_string<char, std::char_traits<char>, std::allocator<char> >*)':
/usr/include/c++/4.3/bits/stl_construct.h:88: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(MBCore.o): In function `__gnu_cxx::new_allocator<char>::deallocate(char*, unsigned int)':
../../.libs/libMOAB.a(MBCore.o): In function `~EntitySequence':
/home/jason/moab/test/x86/../src/EntitySequence.hpp:41: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(MBCore.o): In function `~DummySequence':
/home/jason/moab/test/x86/../src/TypeSequenceManager.hpp:30: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(MBCore.o): In function `__gnu_cxx::new_allocator<int>::deallocate(int*, unsigned int)':
../../.libs/libMOAB.a(MBCore.o):/usr/include/c++/4.3/ext/new_allocator.h:98: more undefined references to `operator delete(void*)' follow
../../.libs/libMOAB.a(MBCore.o): In function `__gnu_cxx::new_allocator<char>::allocate(unsigned int, void const*)':
/usr/include/c++/4.3/ext/new_allocator.h:90: undefined reference to `std::__throw_bad_alloc()'
/usr/include/c++/4.3/ext/new_allocator.h:92: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(MBCore.o): In function `std::vector<char, std::allocator<char> >::_M_check_len(unsigned int, char const*) const':
/usr/include/c++/4.3/bits/stl_vector.h:1078: undefined reference to `std::__throw_length_error(char const*)'
../../.libs/libMOAB.a(MBCore.o): In function `std::_Rb_tree_const_iterator<EntitySequence*>::operator++()':
/usr/include/c++/4.3/bits/stl_tree.h:257: undefined reference to `std::_Rb_tree_increment(std::_Rb_tree_node_base const*)'
../../.libs/libMOAB.a(MBCore.o): In function `MBError::set_last_error(char const*, char*)':
/home/jason/moab/test/x86/../src/MBError.hpp:77: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(char const*)'
../../.libs/libMOAB.a(MBCore.o): In function `bool std::operator==<char, std::char_traits<char>, std::allocator<char> >(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char const*)':
/usr/include/c++/4.3/bits/basic_string.h:2189: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::compare(char const*) const'
../../.libs/libMOAB.a(MBCore.o):(.rodata._ZTI6MBCore[typeinfo for MBCore]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(MBCore.o):(.rodata._ZTIN19TypeSequenceManager13DummySequenceE[typeinfo for TypeSequenceManager::DummySequence]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(MBCore.o):(.rodata._ZTI9ExoIIUtil[typeinfo for ExoIIUtil]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(MBCore.o):(.rodata._ZTI14ExoIIInterface[typeinfo for ExoIIInterface]+0x0): undefined reference to `vtable for __cxxabiv1::__class_type_info'
../../.libs/libMOAB.a(MBCore.o):(.rodata._ZTV14ExoIIInterface[vtable for ExoIIInterface]+0x10): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(MBCore.o):(.rodata._ZTV14ExoIIInterface[vtable for ExoIIInterface]+0x14): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(MBCore.o):(.rodata._ZTV14ExoIIInterface[vtable for ExoIIInterface]+0x18): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(MBCore.o):(.rodata._ZTV14ExoIIInterface[vtable for ExoIIInterface]+0x1c): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(MBCore.o):(.rodata._ZTV14ExoIIInterface[vtable for ExoIIInterface]+0x20): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(MBCore.o):(.rodata._ZTV14ExoIIInterface[vtable for ExoIIInterface]+0x24): more undefined references to `__cxa_pure_virtual' follow
../../.libs/libMOAB.a(MBCore.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(MBGeomUtil.o): In function `__static_initialization_and_destruction_0':
/usr/include/c++/4.3/iostream:77: undefined reference to `std::ios_base::Init::Init()'
/usr/include/c++/4.3/iostream:77: undefined reference to `std::ios_base::Init::~Init()'
../../.libs/libMOAB.a(MBGeomUtil.o):(.rodata._ZTIN10MBGeomUtil12LinearHexMapE[typeinfo for MBGeomUtil::LinearHexMap]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(MBGeomUtil.o):(.rodata._ZTIN10MBGeomUtil6VolMapE[typeinfo for MBGeomUtil::VolMap]+0x0): undefined reference to `vtable for __cxxabiv1::__class_type_info'
../../.libs/libMOAB.a(MBGeomUtil.o):(.rodata._ZTVN10MBGeomUtil6VolMapE[vtable for MBGeomUtil::VolMap]+0x8): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(MBGeomUtil.o):(.rodata._ZTVN10MBGeomUtil6VolMapE[vtable for MBGeomUtil::VolMap]+0xc): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(MBGeomUtil.o):(.rodata._ZTVN10MBGeomUtil6VolMapE[vtable for MBGeomUtil::VolMap]+0x10): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(MBGeomUtil.o):(.eh_frame+0x11): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(MBMeshSet.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(MBRange.o): In function `__static_initialization_and_destruction_0':
../../.libs/libMOAB.a(MBRange.o): In function `alloc_pair':
/home/jason/moab/test/x86/../src/MBRange.cpp:52: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(MBRange.o): In function `free_pair':
/home/jason/moab/test/x86/../src/MBRange.cpp:54: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(MBRange.o): In function `MBRange::print(std::basic_ostream<char, std::char_traits<char> >&, char const*) const':
/home/jason/moab/test/x86/../src/MBRange.cpp:552: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/MBRange.cpp:553: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator+=(char const*)'
/home/jason/moab/test/x86/../src/MBRange.cpp:556: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char>, std::allocator<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/MBRange.cpp:556: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBRange.cpp:556: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBRange.cpp:556: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBRange.cpp:565: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char>, std::allocator<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/MBRange.cpp:565: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBRange.cpp:565: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/MBRange.cpp:567: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBRange.cpp:569: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/MBRange.cpp:570: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/MBRange.cpp:572: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/MBRange.cpp:572: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/MBRange.cpp:573: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(MBRange.o): In function `MBRange::print(char const*) const':
/home/jason/moab/test/x86/../src/MBRange.cpp:547: undefined reference to `std::cout'
../../.libs/libMOAB.a(MBRange.o): In function `__gnu_cxx::new_allocator<MBRange::PairNode const*>::deallocate(MBRange::PairNode const**, unsigned int)':
/usr/include/c++/4.3/ext/new_allocator.h:98: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(MBRange.o): In function `std::vector<MBRange::PairNode const*, std::allocator<MBRange::PairNode const*> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(MBRange.o): In function `__gnu_cxx::new_allocator<MBRange::PairNode const*>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(MBRange.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(MBReadUtil.o): In function `MBError::set_last_error(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
MBReadUtil.cpp:(.text._ZN7MBError14set_last_errorERKSs[MBError::set_last_error(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)]+0x14): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
../../.libs/libMOAB.a(MBReadUtil.o): In function `MBReadUtilIface::~MBReadUtilIface()':
MBReadUtil.cpp:(.text._ZN15MBReadUtilIfaceD2Ev[MBReadUtilIface::~MBReadUtilIface()]+0x1f): undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(MBReadUtil.o): In function `MBReadUtil::~MBReadUtil()':
MBReadUtil.cpp:(.text._ZN10MBReadUtilD0Ev[MBReadUtil::~MBReadUtil()]+0x2a): undefined reference to `operator delete(void*)'
MBReadUtil.cpp:(.text._ZN15MBReadUtilIfaceD0Ev[MBReadUtilIface::~MBReadUtilIface()]+0x1f): undefined reference to `operator delete(void*)'
MBReadUtil.cpp:(.text._ZN15MBReadUtilIfaceD1Ev[MBReadUtilIface::~MBReadUtilIface()]+0x1f): undefined reference to `operator delete(void*)'
MBReadUtil.cpp:(.text._ZN10MBReadUtilD1Ev[MBReadUtil::~MBReadUtil()]+0x2a): undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(MBReadUtil.o): In function `std::vector<double*, std::allocator<double*> >::_M_check_len(unsigned int, char const*) const':
MBReadUtil.cpp:(.text._ZNKSt6vectorIPdSaIS0_EE12_M_check_lenEjPKc[std::vector<double*, std::allocator<double*> >::_M_check_len(unsigned int, char const*) const]+0x36): undefined reference to `std::__throw_length_error(char const*)'
../../.libs/libMOAB.a(MBReadUtil.o): In function `__gnu_cxx::new_allocator<double*>::allocate(unsigned int, void const*)':
MBReadUtil.cpp:(.text._ZN9__gnu_cxx13new_allocatorIPdE8allocateEjPKv[__gnu_cxx::new_allocator<double*>::allocate(unsigned int, void const*)]+0x24): undefined reference to `std::__throw_bad_alloc()'
MBReadUtil.cpp:(.text._ZN9__gnu_cxx13new_allocatorIPdE8allocateEjPKv[__gnu_cxx::new_allocator<double*>::allocate(unsigned int, void const*)]+0x32): undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(MBReadUtil.o):(.rodata._ZTI10MBReadUtil[typeinfo for MBReadUtil]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(MBReadUtil.o):(.rodata._ZTI15MBReadUtilIface[typeinfo for MBReadUtilIface]+0x0): undefined reference to `vtable for __cxxabiv1::__class_type_info'
../../.libs/libMOAB.a(MBReadUtil.o):(.rodata._ZTV15MBReadUtilIface[vtable for MBReadUtilIface]+0x10): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(MBReadUtil.o):(.rodata._ZTV15MBReadUtilIface[vtable for MBReadUtilIface]+0x14): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(MBReadUtil.o):(.rodata._ZTV15MBReadUtilIface[vtable for MBReadUtilIface]+0x18): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(MBReadUtil.o):(.rodata._ZTV15MBReadUtilIface[vtable for MBReadUtilIface]+0x1c): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(MBReadUtil.o):(.rodata._ZTV15MBReadUtilIface[vtable for MBReadUtilIface]+0x20): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(MBReadUtil.o):(.rodata._ZTV15MBReadUtilIface[vtable for MBReadUtilIface]+0x24): more undefined references to `__cxa_pure_virtual' follow
../../.libs/libMOAB.a(MBReadUtil.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(MBReaderWriterSet.o): In function `MBReaderWriterSet::extension_from_filename(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:177: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::find_last_of(char const*, unsigned int) const'
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:179: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:179: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:179: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:181: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::substr(unsigned int, unsigned int) const'
../../.libs/libMOAB.a(MBReaderWriterSet.o): In function `__static_initialization_and_destruction_0':
../../.libs/libMOAB.a(MBReaderWriterSet.o): In function `MBReaderWriterSet::Handler::operator==(char const*) const':
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:244: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::begin() const'
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:246: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::end() const'
../../.libs/libMOAB.a(MBReaderWriterSet.o): In function `MBReaderWriterSet::handler_from_extension(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool, bool) const':
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:228: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
../../.libs/libMOAB.a(MBReaderWriterSet.o): In function `MBReaderWriterSet::get_file_extension_writer(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) const':
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:171: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(MBReaderWriterSet.o): In function `MBReaderWriterSet::get_file_extension_reader(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) const':
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:163: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(MBReaderWriterSet.o): In function `Handler':
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:190: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:190: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:190: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:190: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:190: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:193: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(char const*)'
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:194: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(MBReaderWriterSet.o): In function `MBReaderWriterSet::register_factory(MBReaderIface* (*)(MBInterface*), MBWriterIface* (*)(MBInterface*), char const*, char const* const*, char const*)':
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:130: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:130: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:130: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:130: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:136: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/MBReaderWriterSet.cpp:140: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
../../.libs/libMOAB.a(MBReaderWriterSet.o): In function `void std::_Construct<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::basic_string<char, std::char_traits<char>, std::allocator<char> > >(std::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
/usr/include/c++/4.3/bits/stl_construct.h:79: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
../../.libs/libMOAB.a(MBReaderWriterSet.o): In function `~Handler':
/home/jason/moab/test/x86/../src/MBReaderWriterSet.hpp:104: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(MBReaderWriterSet.o): In function `__gnu_cxx::new_allocator<std::_List_node<MBReaderWriterSet::Handler> >::deallocate(std::_List_node<MBReaderWriterSet::Handler>*, unsigned int)':
../../.libs/libMOAB.a(MBReaderWriterSet.o): In function `__gnu_cxx::new_allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(MBReaderWriterSet.o): In function `__gnu_cxx::new_allocator<std::_List_node<MBReaderWriterSet::Handler> >::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(MBReaderWriterSet.o): In function `void std::__uninitialized_fill_n<false>::uninitialized_fill_n<std::basic_string<char, std::char_traits<char>, std::allocator<char> >*, unsigned int, std::basic_string<char, std::char_traits<char>, std::allocator<char> > >(std::basic_string<char, std::char_traits<char>, std::allocator<char> >*, unsigned int, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
/usr/include/c++/4.3/bits/stl_uninitialized.h:194: undefined reference to `__cxa_begin_catch'
/usr/include/c++/4.3/bits/stl_uninitialized.h:197: undefined reference to `__cxa_rethrow'
/usr/include/c++/4.3/bits/stl_uninitialized.h:194: undefined reference to `__cxa_end_catch'
../../.libs/libMOAB.a(MBReaderWriterSet.o): In function `std::basic_string<char, std::char_traits<char>, std::allocator<char> >* std::__uninitialized_copy<false>::uninitialized_copy<__gnu_cxx::__normal_iterator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const*, std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, std::basic_string<char, std::char_traits<char>, std::allocator<char> >*>(__gnu_cxx::__normal_iterator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const*, std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, __gnu_cxx::__normal_iterator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const*, std::vector<std::basic_string<char, std::char_traits<cha!
 r>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, std::basic_string<char, std::char_traits<char>, std::allocator<char> >*)':
/usr/include/c++/4.3/bits/stl_uninitialized.h:79: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/usr/include/c++/4.3/bits/stl_uninitialized.h:83: undefined reference to `__cxa_begin_catch'
/usr/include/c++/4.3/bits/stl_uninitialized.h:86: undefined reference to `__cxa_rethrow'
/usr/include/c++/4.3/bits/stl_uninitialized.h:83: undefined reference to `__cxa_end_catch'
/home/jason/moab/test/x86/../src/MBReaderWriterSet.hpp:104: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
../../.libs/libMOAB.a(MBReaderWriterSet.o): In function `std::list<MBReaderWriterSet::Handler, std::allocator<MBReaderWriterSet::Handler> >::_M_create_node(MBReaderWriterSet::Handler const&)':
/usr/include/c++/4.3/bits/stl_list.h:465: undefined reference to `__cxa_begin_catch'
/usr/include/c++/4.3/bits/stl_list.h:468: undefined reference to `__cxa_rethrow'
/usr/include/c++/4.3/bits/stl_list.h:465: undefined reference to `__cxa_end_catch'
../../.libs/libMOAB.a(MBReaderWriterSet.o): In function `std::list<MBReaderWriterSet::Handler, std::allocator<MBReaderWriterSet::Handler> >::_M_insert(std::_List_iterator<MBReaderWriterSet::Handler>, MBReaderWriterSet::Handler const&)':
/usr/include/c++/4.3/bits/stl_list.h:1342: undefined reference to `std::_List_node_base::hook(std::_List_node_base*)'
../../.libs/libMOAB.a(MBReaderWriterSet.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(MBWriteUtil.o): In function `MBWriteUtil::get_tag_list(std::vector<void**, std::allocator<void**> >&, void** const*, int, bool)':
/home/jason/moab/test/x86/../src/MBWriteUtil.cpp:737: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/MBWriteUtil.cpp:744: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::empty() const'
/home/jason/moab/test/x86/../src/MBWriteUtil.cpp:752: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/MBWriteUtil.cpp:736: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/MBWriteUtil.cpp:772: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/MBWriteUtil.cpp:780: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::empty() const'
/home/jason/moab/test/x86/../src/MBWriteUtil.cpp:784: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::size() const'
/home/jason/moab/test/x86/../src/MBWriteUtil.cpp:784: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator[](unsigned int)'
/home/jason/moab/test/x86/../src/MBWriteUtil.cpp:771: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(MBWriteUtil.o): In function `~MBWriteUtilIface':
/home/jason/moab/test/x86/../src/MBWriteUtilIface.hpp:33: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(MBWriteUtil.o): In function `~MBWriteUtil':
/home/jason/moab/test/x86/../src/MBWriteUtil.hpp:41: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(MBWriteUtil.o): In function `std::vector<int, std::allocator<int> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(MBWriteUtil.o): In function `__gnu_cxx::new_allocator<int>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(MBWriteUtil.o): In function `std::vector<void**, std::allocator<void**> >::reserve(unsigned int)':
/usr/include/c++/4.3/bits/vector.tcc:73: undefined reference to `std::__throw_length_error(char const*)'
../../.libs/libMOAB.a(MBWriteUtil.o): In function `std::_Rb_tree_const_iterator<EntitySequence*>::operator++(int)':
/usr/include/c++/4.3/bits/stl_tree.h:265: undefined reference to `std::_Rb_tree_increment(std::_Rb_tree_node_base const*)'
../../.libs/libMOAB.a(MBWriteUtil.o):(.rodata._ZTI11MBWriteUtil[typeinfo for MBWriteUtil]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(MBWriteUtil.o):(.rodata._ZTI16MBWriteUtilIface[typeinfo for MBWriteUtilIface]+0x0): undefined reference to `vtable for __cxxabiv1::__class_type_info'
../../.libs/libMOAB.a(MBWriteUtil.o):(.rodata._ZTV16MBWriteUtilIface[vtable for MBWriteUtilIface]+0x10): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(MBWriteUtil.o):(.rodata._ZTV16MBWriteUtilIface[vtable for MBWriteUtilIface]+0x14): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(MBWriteUtil.o):(.rodata._ZTV16MBWriteUtilIface[vtable for MBWriteUtilIface]+0x18): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(MBWriteUtil.o):(.rodata._ZTV16MBWriteUtilIface[vtable for MBWriteUtilIface]+0x1c): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(MBWriteUtil.o):(.rodata._ZTV16MBWriteUtilIface[vtable for MBWriteUtilIface]+0x20): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(MBWriteUtil.o):(.rodata._ZTV16MBWriteUtilIface[vtable for MBWriteUtilIface]+0x24): more undefined references to `__cxa_pure_virtual' follow
../../.libs/libMOAB.a(MBWriteUtil.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(MeshSetSequence.o): In function `MeshSetSequence::split(unsigned int)':
/home/jason/moab/test/x86/../src/MeshSetSequence.cpp:82: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(MeshSetSequence.o): In function `~MeshSetSequence':
/home/jason/moab/test/x86/../src/MeshSetSequence.cpp:78: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(MeshSetSequence.o): In function `MeshSetSequence':
/home/jason/moab/test/x86/../src/MeshSetSequence.cpp:56: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/MeshSetSequence.cpp:47: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(MeshSetSequence.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<unsigned int> >::deallocate(std::_Rb_tree_node<unsigned int>*, unsigned int)':
../../.libs/libMOAB.a(MeshSetSequence.o): In function `__gnu_cxx::new_allocator<MBMeshSet*>::deallocate(MBMeshSet**, unsigned int)':
../../.libs/libMOAB.a(MeshSetSequence.o): In function `__gnu_cxx::new_allocator<MBMeshSet const*>::deallocate(MBMeshSet const**, unsigned int)':
../../.libs/libMOAB.a(MeshSetSequence.o): In function `std::vector<MBMeshSet*, std::allocator<MBMeshSet*> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(MeshSetSequence.o): In function `std::vector<MBMeshSet const*, std::allocator<MBMeshSet const*> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(MeshSetSequence.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<unsigned int> >::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(MeshSetSequence.o): In function `__gnu_cxx::new_allocator<MBMeshSet*>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(MeshSetSequence.o): In function `__gnu_cxx::new_allocator<MBMeshSet const*>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(MeshSetSequence.o): In function `std::_Rb_tree_iterator<unsigned int>::operator--()':
/usr/include/c++/4.3/bits/stl_tree.h:197: undefined reference to `std::_Rb_tree_decrement(std::_Rb_tree_node_base*)'
../../.libs/libMOAB.a(MeshSetSequence.o): In function `std::_Rb_tree<unsigned int, unsigned int, std::_Identity<unsigned int>, std::less<unsigned int>, std::allocator<unsigned int> >::_M_insert_(std::_Rb_tree_node_base const*, std::_Rb_tree_node_base const*, unsigned int const&)':
/usr/include/c++/4.3/bits/stl_tree.h:854: undefined reference to `std::_Rb_tree_insert_and_rebalance(bool, std::_Rb_tree_node_base*, std::_Rb_tree_node_base*, std::_Rb_tree_node_base&)'
../../.libs/libMOAB.a(MeshSetSequence.o):(.rodata._ZTI15MeshSetSequence[typeinfo for MeshSetSequence]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(MeshSetSequence.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(ReadGmsh.o): In function `~ReadGmsh':
/home/jason/moab/test/x86/../src/ReadGmsh.cpp:51: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadGmsh.cpp:51: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadGmsh.cpp:51: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadGmsh.cpp:51: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/ReadGmsh.cpp:54: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(ReadGmsh.o): In function `ReadGmsh':
/home/jason/moab/test/x86/../src/ReadGmsh.cpp:44: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadGmsh.cpp:44: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadGmsh.cpp:44: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadGmsh.cpp:44: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(ReadGmsh.o): In function `ReadGmsh::factory(MBInterface*)':
/home/jason/moab/test/x86/../src/ReadGmsh.cpp:38: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/ReadGmsh.cpp:38: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(ReadGmsh.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<int> >::deallocate(std::_Rb_tree_node<int>*, unsigned int)':
../../.libs/libMOAB.a(ReadGmsh.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<std::pair<long const, unsigned int> > >::deallocate(std::_Rb_tree_node<std::pair<long const, unsigned int> >*, unsigned int)':
../../.libs/libMOAB.a(ReadGmsh.o): In function `__gnu_cxx::new_allocator<long>::deallocate(long*, unsigned int)':
../../.libs/libMOAB.a(ReadGmsh.o): In function `~MBReaderIface':
/home/jason/moab/test/x86/../src/MBReaderIface.hpp:35: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(ReadGmsh.o):/home/jason/moab/test/x86/../src/MBReaderIface.hpp:35: more undefined references to `operator delete(void*)' follow
../../.libs/libMOAB.a(ReadGmsh.o): In function `std::_Rb_tree_iterator<int>::operator--()':
../../.libs/libMOAB.a(ReadGmsh.o): In function `std::_Rb_tree_iterator<std::pair<long const, unsigned int> >::operator--()':
../../.libs/libMOAB.a(ReadGmsh.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<int> >::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(ReadGmsh.o): In function `std::_Rb_tree<int, int, std::_Identity<int>, std::less<int>, std::allocator<int> >::_M_insert_(std::_Rb_tree_node_base const*, std::_Rb_tree_node_base const*, int const&)':
../../.libs/libMOAB.a(ReadGmsh.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<std::pair<long const, unsigned int> > >::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(ReadGmsh.o): In function `std::_Rb_tree<long, std::pair<long const, unsigned int>, std::_Select1st<std::pair<long const, unsigned int> >, std::less<long>, std::allocator<std::pair<long const, unsigned int> > >::_M_insert_(std::_Rb_tree_node_base const*, std::_Rb_tree_node_base const*, std::pair<long const, unsigned int> const&)':
../../.libs/libMOAB.a(ReadGmsh.o): In function `__gnu_cxx::new_allocator<long>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(ReadGmsh.o): In function `std::_Rb_tree_const_iterator<int>::operator++()':
../../.libs/libMOAB.a(ReadGmsh.o): In function `std::_Rb_tree_iterator<std::pair<long const, unsigned int> >::operator++()':
/usr/include/c++/4.3/bits/stl_tree.h:182: undefined reference to `std::_Rb_tree_increment(std::_Rb_tree_node_base*)'
../../.libs/libMOAB.a(ReadGmsh.o): In function `std::vector<long, std::allocator<long> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(ReadGmsh.o):(.rodata._ZTI8ReadGmsh[typeinfo for ReadGmsh]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(ReadGmsh.o):(.rodata._ZTI13MBReaderIface[typeinfo for MBReaderIface]+0x0): undefined reference to `vtable for __cxxabiv1::__class_type_info'
../../.libs/libMOAB.a(ReadGmsh.o):(.rodata._ZTV13MBReaderIface[vtable for MBReaderIface]+0x10): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(ReadGmsh.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(ReadSms.o): In function `ReadSms':
/home/jason/moab/test/x86/../src/ReadSms.cpp:51: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadSms.cpp:51: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:51: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadSms.cpp:51: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(ReadSms.o): In function `~ReadSms':
/home/jason/moab/test/x86/../src/ReadSms.cpp:58: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadSms.cpp:58: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:58: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadSms.cpp:58: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/ReadSms.cpp:61: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(ReadSms.o): In function `__static_initialization_and_destruction_0':
../../.libs/libMOAB.a(ReadSms.o): In function `ReadSms::factory(MBInterface*)':
/home/jason/moab/test/x86/../src/ReadSms.cpp:45: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:45: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(ReadSms.o): In function `ReadSms::load_file_impl(char const*)':
/home/jason/moab/test/x86/../src/ReadSms.cpp:101: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:101: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:101: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:101: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:110: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:110: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:110: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:110: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:121: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:121: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:121: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:121: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:139: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:139: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:139: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:139: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:151: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:151: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:151: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:151: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:172: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:172: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:172: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:172: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:180: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:180: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:180: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:180: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:187: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:187: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:187: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:187: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:203: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:203: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:203: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:203: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:216: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/ReadSms.cpp:216: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:216: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:216: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:221: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:221: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:221: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:221: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:225: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:225: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:225: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:225: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:235: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:235: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:235: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:235: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:242: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:242: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:242: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:242: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:269: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:269: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:269: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:269: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:284: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:284: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:284: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:284: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:294: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:294: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:294: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:294: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:298: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:298: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:298: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:298: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:309: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:309: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:309: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:309: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:316: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:316: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:316: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:316: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:338: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:338: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:338: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:338: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:352: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:352: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:352: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:352: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:357: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:357: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:357: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:357: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/ReadSms.cpp:361: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/ReadSms.cpp:361: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:361: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/ReadSms.cpp:361: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(ReadSms.o):(.rodata._ZTI7ReadSms[typeinfo for ReadSms]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(ReadSms.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(ReadSTL.o): In function `ReadSTL':
/home/jason/moab/test/x86/../src/ReadSTL.cpp:58: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadSTL.cpp:58: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadSTL.cpp:58: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadSTL.cpp:58: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(ReadSTL.o): In function `~ReadSTL':
/home/jason/moab/test/x86/../src/ReadSTL.cpp:65: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadSTL.cpp:65: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadSTL.cpp:65: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadSTL.cpp:65: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/ReadSTL.cpp:68: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(ReadSTL.o): In function `ReadSTL::factory(MBInterface*)':
/home/jason/moab/test/x86/../src/ReadSTL.cpp:403: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/ReadSTL.cpp:403: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(ReadSTL.o): In function `__gnu_cxx::new_allocator<ReadSTL::Triangle>::deallocate(ReadSTL::Triangle*, unsigned int)':
../../.libs/libMOAB.a(ReadSTL.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<std::pair<ReadSTL::Point const, unsigned int> > >::deallocate(std::_Rb_tree_node<std::pair<ReadSTL::Point const, unsigned int> >*, unsigned int)':
../../.libs/libMOAB.a(ReadSTL.o): In function `std::vector<ReadSTL::Triangle, std::allocator<ReadSTL::Triangle> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(ReadSTL.o): In function `__gnu_cxx::new_allocator<ReadSTL::Triangle>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(ReadSTL.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<std::pair<ReadSTL::Point const, unsigned int> > >::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(ReadSTL.o): In function `std::_Rb_tree_iterator<std::pair<ReadSTL::Point const, unsigned int> >::operator++()':
../../.libs/libMOAB.a(ReadSTL.o): In function `std::_Rb_tree_const_iterator<std::pair<ReadSTL::Point const, unsigned int> >::operator--()':
/usr/include/c++/4.3/bits/stl_tree.h:272: undefined reference to `std::_Rb_tree_decrement(std::_Rb_tree_node_base const*)'
../../.libs/libMOAB.a(ReadSTL.o): In function `std::_Rb_tree_const_iterator<std::pair<ReadSTL::Point const, unsigned int> >::operator++()':
../../.libs/libMOAB.a(ReadSTL.o): In function `std::_Rb_tree<ReadSTL::Point, std::pair<ReadSTL::Point const, unsigned int>, std::_Select1st<std::pair<ReadSTL::Point const, unsigned int> >, std::less<ReadSTL::Point>, std::allocator<std::pair<ReadSTL::Point const, unsigned int> > >::_M_insert_(std::_Rb_tree_node_base const*, std::_Rb_tree_node_base const*, std::pair<ReadSTL::Point const, unsigned int> const&)':
../../.libs/libMOAB.a(ReadSTL.o): In function `std::_Rb_tree_iterator<std::pair<ReadSTL::Point const, unsigned int> >::operator--()':
../../.libs/libMOAB.a(ReadSTL.o):(.rodata._ZTI7ReadSTL[typeinfo for ReadSTL]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(ReadSTL.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(ReadVtk.o): In function `ReadVtk':
/home/jason/moab/test/x86/../src/ReadVtk.cpp:143: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:143: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:143: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:146: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:146: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:146: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:146: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:148: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadVtk.o): In function `~ReadVtk':
/home/jason/moab/test/x86/../src/ReadVtk.cpp:153: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:153: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:153: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:153: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:156: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:156: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(ReadVtk.o): In function `ReadVtk::factory(MBInterface*)':
/home/jason/moab/test/x86/../src/ReadVtk.cpp:140: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:140: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(ReadVtk.o): In function `ReadVtk::vtk_read_tag_data(FileTokenizer&, int, unsigned int, std::vector<MBRange, std::allocator<MBRange> >&, char const*)':
/home/jason/moab/test/x86/../src/ReadVtk.cpp:1025: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:1025: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:1029: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::empty() const'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:1029: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:1081: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:1084: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:1102: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:1106: undefined reference to `operator delete[](void*)'
../../.libs/libMOAB.a(ReadVtk.o): In function `ReadVtk::vtk_read_field_attrib(FileTokenizer&, std::vector<MBRange, std::allocator<MBRange> >&, char const*)':
/home/jason/moab/test/x86/../src/ReadVtk.cpp:1257: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:1257: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:1257: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:1272: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:1276: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:1251: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadVtk.o): In function `ReadVtk::vtk_read_attrib_data(FileTokenizer&, std::vector<MBRange, std::allocator<MBRange> >&)':
/home/jason/moab/test/x86/../src/ReadVtk.cpp:972: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:972: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:972: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:973: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:987: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadVtk.o): In function `ReadVtk::load_file(char const*, unsigned int&, FileOptions const&, char const*, int const*, int)':
/home/jason/moab/test/x86/../src/ReadVtk.cpp:194: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:197: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/ReadVtk.cpp:320: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadVtk.o): In function `__gnu_cxx::new_allocator<unsigned char>::deallocate(unsigned char*, unsigned int)':
../../.libs/libMOAB.a(ReadVtk.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<std::pair<MBHash const, unsigned int> > >::deallocate(std::_Rb_tree_node<std::pair<MBHash const, unsigned int> >*, unsigned int)':
../../.libs/libMOAB.a(ReadVtk.o): In function `__gnu_cxx::new_allocator<MBRange>::deallocate(MBRange*, unsigned int)':
../../.libs/libMOAB.a(ReadVtk.o): In function `std::vector<unsigned char, std::allocator<unsigned char> >::_M_check_len(unsigned int, char const*) const':
/usr/include/c++/4.3/bits/stl_vector.h:1078: undefined reference to `std::__throw_length_error(char const*)'
../../.libs/libMOAB.a(ReadVtk.o): In function `std::vector<MBRange, std::allocator<MBRange> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(ReadVtk.o): In function `__gnu_cxx::new_allocator<unsigned char>::allocate(unsigned int, void const*)':
/usr/include/c++/4.3/ext/new_allocator.h:90: undefined reference to `std::__throw_bad_alloc()'
/usr/include/c++/4.3/ext/new_allocator.h:92: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(ReadVtk.o): In function `MBModulator':
/home/jason/moab/test/x86/../src/ReadVtk.cpp:92: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
../../.libs/libMOAB.a(ReadVtk.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<std::pair<MBHash const, unsigned int> > >::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(ReadVtk.o): In function `__gnu_cxx::new_allocator<MBRange>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(ReadVtk.o): In function `std::_Rb_tree_const_iterator<std::pair<MBHash const, unsigned int> >::operator--()':
../../.libs/libMOAB.a(ReadVtk.o): In function `std::_Rb_tree_const_iterator<std::pair<MBHash const, unsigned int> >::operator++()':
/usr/include/c++/4.3/bits/stl_tree.h:257: undefined reference to `std::_Rb_tree_increment(std::_Rb_tree_node_base const*)'
../../.libs/libMOAB.a(ReadVtk.o): In function `std::_Rb_tree<MBHash, std::pair<MBHash const, unsigned int>, std::_Select1st<std::pair<MBHash const, unsigned int> >, std::less<MBHash>, std::allocator<std::pair<MBHash const, unsigned int> > >::_M_insert_(std::_Rb_tree_node_base const*, std::_Rb_tree_node_base const*, std::pair<MBHash const, unsigned int> const&)':
../../.libs/libMOAB.a(ReadVtk.o): In function `std::_Rb_tree_iterator<std::pair<MBHash const, unsigned int> >::operator--()':
../../.libs/libMOAB.a(ReadVtk.o): In function `MBRange* std::__uninitialized_copy<false>::uninitialized_copy<MBRange*, MBRange*>(MBRange*, MBRange*, MBRange*)':
../../.libs/libMOAB.a(ReadVtk.o): In function `void std::__uninitialized_fill_n<false>::uninitialized_fill_n<MBRange*, unsigned int, MBRange>(MBRange*, unsigned int, MBRange const&)':
../../.libs/libMOAB.a(ReadVtk.o): In function `std::vector<MBRange, std::allocator<MBRange> >::_M_insert_aux(__gnu_cxx::__normal_iterator<MBRange*, std::vector<MBRange, std::allocator<MBRange> > >, MBRange const&)':
/usr/include/c++/4.3/bits/vector.tcc:330: undefined reference to `__cxa_begin_catch'
/usr/include/c++/4.3/bits/vector.tcc:334: undefined reference to `__cxa_rethrow'
/usr/include/c++/4.3/bits/vector.tcc:330: undefined reference to `__cxa_end_catch'
../../.libs/libMOAB.a(ReadVtk.o):(.rodata._ZTI7ReadVtk[typeinfo for ReadVtk]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(ReadVtk.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(ReadIDEAS.o): In function `ReadIDEAS':
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:18: undefined reference to `std::basic_ifstream<char, std::char_traits<char> >::basic_ifstream()'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:20: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:20: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:20: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:20: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:21: undefined reference to `std::basic_ifstream<char, std::char_traits<char> >::~basic_ifstream()'
../../.libs/libMOAB.a(ReadIDEAS.o): In function `__static_initialization_and_destruction_0':
/usr/include/c++/4.3/iostream:77: undefined reference to `std::ios_base::Init::Init()'
/usr/include/c++/4.3/iostream:77: undefined reference to `std::ios_base::Init::~Init()'
../../.libs/libMOAB.a(ReadIDEAS.o): In function `ReadIDEAS::skip_header()':
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:76: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:83: undefined reference to `std::basic_istream<char, std::char_traits<char> >::getline(char*, int)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:87: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(char const*)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:88: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::empty() const'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:82: undefined reference to `std::basic_ios<char, std::char_traits<char> >::eof() const'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:94: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadIDEAS.o): In function `ReadIDEAS::create_tetrahedral_elements()':
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:164: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:179: undefined reference to `std::basic_istream<char, std::char_traits<char> >::getline(char*, int)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:180: undefined reference to `std::basic_istream<char, std::char_traits<char> >::getline(char*, int)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:186: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(char const*)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:187: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(char const*)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:188: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::empty() const'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:177: undefined reference to `std::basic_ios<char, std::char_traits<char> >::eof() const'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:214: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadIDEAS.o): In function `ReadIDEAS::create_vertices()':
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:107: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:111: undefined reference to `std::basic_istream<char, std::char_traits<char> >::tellg()'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:116: undefined reference to `std::basic_istream<char, std::char_traits<char> >::getline(char*, int)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:117: undefined reference to `std::basic_istream<char, std::char_traits<char> >::getline(char*, int)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:123: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(char const*)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:124: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(char const*)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:125: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::empty() const'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:114: undefined reference to `std::basic_ios<char, std::char_traits<char> >::eof() const'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:130: undefined reference to `std::basic_istream<char, std::char_traits<char> >::seekg(std::fpos<__mbstate_t>)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:131: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:135: undefined reference to `std::basic_istream<char, std::char_traits<char> >::getline(char*, int)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:136: undefined reference to `std::basic_istream<char, std::char_traits<char> >::getline(char*, int)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:152: undefined reference to `std::basic_istream<char, std::char_traits<char> >::getline(char*, int)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:153: undefined reference to `std::basic_istream<char, std::char_traits<char> >::getline(char*, int)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:153: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadIDEAS.o): In function `ReadIDEAS::load_file(char const*, unsigned int&, FileOptions const&, char const*, int const*, int)':
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:34: undefined reference to `std::basic_ifstream<char, std::char_traits<char> >::open(char const*, std::_Ios_Openmode)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:42: undefined reference to `std::basic_istream<char, std::char_traits<char> >::getline(char*, int)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:43: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:43: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:43: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:44: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::find(char const*, unsigned int) const'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:44: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::length() const'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:47: undefined reference to `std::basic_istream<char, std::char_traits<char> >::getline(char*, int)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:48: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(char const*)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:46: undefined reference to `std::basic_ios<char, std::char_traits<char> >::eof() const'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:66: undefined reference to `std::basic_ifstream<char, std::char_traits<char> >::close()'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:67: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadIDEAS.o): In function `ReadIDEAS::factory(MBInterface*)':
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:15: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/ReadIDEAS.cpp:15: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(ReadIDEAS.o): In function `~ReadIDEAS':
/home/jason/moab/test/x86/../src/ReadIDEAS.hpp:34: undefined reference to `std::basic_ifstream<char, std::char_traits<char> >::~basic_ifstream()'
/home/jason/moab/test/x86/../src/ReadIDEAS.hpp:34: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(ReadIDEAS.o):(.rodata._ZTI9ReadIDEAS[typeinfo for ReadIDEAS]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(ReadIDEAS.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(ReadTetGen.o): In function `ReadTetGen':
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:20: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:20: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:20: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:20: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(ReadTetGen.o): In function `~ReadTetGen':
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:28: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:28: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:28: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:28: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:29: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(ReadTetGen.o): In function `__static_initialization_and_destruction_0':
../../.libs/libMOAB.a(ReadTetGen.o): In function `ReadTetGen::factory(MBInterface*)':
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:14: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:14: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(ReadTetGen.o): In function `ReadTetGen::read_line(std::basic_istream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> >&, int&)':
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:209: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::clear()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:210: undefined reference to `std::basic_istream<char, std::char_traits<char> >& std::getline<char, std::char_traits<char>, std::allocator<char> >(std::basic_istream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> >&)'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:210: undefined reference to `std::basic_ios<char, std::char_traits<char> >::operator!() const'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:214: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::find_first_of(char, unsigned int) const'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:216: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::substr(unsigned int, unsigned int) const'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:216: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:216: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:218: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::length() const'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:218: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator[](unsigned int)'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:219: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::length() const'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:220: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::clear()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:222: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::substr(unsigned int, unsigned int) const'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:222: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:222: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:207: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::empty() const'
../../.libs/libMOAB.a(ReadTetGen.o): In function `ReadTetGen::read_line(std::basic_istream<char, std::char_traits<char> >&, double*, int, int&)':
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:234: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:240: undefined reference to `std::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >::basic_stringstream(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::_Ios_Openmode)'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:243: undefined reference to `std::basic_istream<char, std::char_traits<char> >::operator>>(double&)'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:243: undefined reference to `std::basic_ios<char, std::char_traits<char> >::operator!() const'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:252: undefined reference to `std::basic_istream<char, std::char_traits<char> >::operator>>(int&)'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:252: undefined reference to `std::basic_ios<char, std::char_traits<char> >::operator void*() const'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:252: undefined reference to `std::basic_ios<char, std::char_traits<char> >::eof() const'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:257: undefined reference to `std::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >::~basic_stringstream()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:257: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadTetGen.o): In function `ReadTetGen::read_elem_file(MBEntityType, std::basic_istream<char, std::char_traits<char> >&, std::vector<unsigned int, std::allocator<unsigned int> > const&, MBRange&)':
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:372: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:475: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadTetGen.o): In function `ReadTetGen::read_node_file(std::basic_istream<char, std::char_traits<char> >&, void** const*, int const*, int, std::vector<unsigned int, std::allocator<unsigned int> >&)':
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:267: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:362: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadTetGen.o): In function `ReadTetGen::parse_attr_list(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<void**, std::allocator<void**> >&, std::vector<int, std::allocator<int> >&, char const*)':
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:167: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::find_first_of(char, unsigned int) const'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:168: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::substr(unsigned int, unsigned int) const'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:168: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:193: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
../../.libs/libMOAB.a(ReadTetGen.o): In function `ReadTetGen::open_file(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char const*, char const*, FileOptions const&, std::basic_ifstream<char, std::char_traits<char> >&, bool)':
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:40: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:42: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::empty() const'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:46: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:49: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:50: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator+=(char const*)'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:51: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator+=(char const*)'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:55: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::empty() const'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:56: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:56: undefined reference to `std::basic_ifstream<char, std::char_traits<char> >::open(char const*, std::_Ios_Openmode)'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:57: undefined reference to `std::basic_ifstream<char, std::char_traits<char> >::is_open()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:58: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:61: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadTetGen.o): In function `ReadTetGen::load_file(char const*, unsigned int&, FileOptions const&, char const*, int const*, int)':
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:70: undefined reference to `std::basic_ifstream<char, std::char_traits<char> >::basic_ifstream()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:78: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:78: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:78: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:78: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:79: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::find_last_of(char, unsigned int) const'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:81: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:84: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::substr(unsigned int, unsigned int) const'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:84: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:84: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:86: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator[](unsigned int)'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:85: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::length() const'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:88: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::substr(unsigned int, unsigned int) const'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:88: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:88: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:91: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:92: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::clear()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:114: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:113: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:128: undefined reference to `std::basic_ifstream<char, std::char_traits<char> >::is_open()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:130: undefined reference to `std::basic_ifstream<char, std::char_traits<char> >::is_open()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:132: undefined reference to `std::basic_ifstream<char, std::char_traits<char> >::is_open()'
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:156: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadTetGen.o):/home/jason/moab/test/x86/../src/ReadTetGen.cpp:156: more undefined references to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()' follow
/home/jason/moab/test/x86/../src/ReadTetGen.cpp:156: undefined reference to `std::basic_ifstream<char, std::char_traits<char> >::~basic_ifstream()'
../../.libs/libMOAB.a(ReadTetGen.o):/home/jason/moab/test/x86/../src/ReadTetGen.cpp:156: more undefined references to `std::basic_ifstream<char, std::char_traits<char> >::~basic_ifstream()' follow
../../.libs/libMOAB.a(ReadTetGen.o): In function `~pair':
/usr/include/c++/4.3/bits/stl_pair.h:73: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadTetGen.o): In function `bool std::operator< <char, std::char_traits<char>, std::allocator<char> >(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
/usr/include/c++/4.3/bits/basic_string.h:2239: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::compare(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) const'
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::basic_string<char, std::char_traits<char>, std::allocator<char> >* std::__copy_move_backward<false, false, std::random_access_iterator_tag>::__copy_move_b<std::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::basic_string<char, std::char_traits<char>, std::allocator<char> >*>(std::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::basic_string<char, std::char_traits<char>, std::allocator<char> >*)':
/usr/include/c++/4.3/bits/stl_algobase.h:543: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
../../.libs/libMOAB.a(ReadTetGen.o): In function `__gnu_cxx::new_allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >::construct(std::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
/usr/include/c++/4.3/ext/new_allocator.h:108: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
../../.libs/libMOAB.a(ReadTetGen.o): In function `pair':
/usr/include/c++/4.3/bits/stl_pair.h:89: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/usr/include/c++/4.3/bits/stl_pair.h:73: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
../../.libs/libMOAB.a(ReadTetGen.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<std::pair<double const, unsigned int> > >::deallocate(std::_Rb_tree_node<std::pair<double const, unsigned int> >*, unsigned int)':
/usr/include/c++/4.3/ext/new_allocator.h:98: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(ReadTetGen.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<std::pair<void** const, std::vector<double, std::allocator<double> > > > >::deallocate(std::_Rb_tree_node<std::pair<void** const, std::vector<double, std::allocator<double> > > >*, unsigned int)':
../../.libs/libMOAB.a(ReadTetGen.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<std::pair<void** const, int> > >::deallocate(std::_Rb_tree_node<std::pair<void** const, int> >*, unsigned int)':
../../.libs/libMOAB.a(ReadTetGen.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, int> > >::deallocate(std::_Rb_tree_node<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, int> >*, unsigned int)':
../../.libs/libMOAB.a(ReadTetGen.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<std::pair<double const, unsigned int> > >::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(ReadTetGen.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<std::pair<void** const, std::vector<double, std::allocator<double> > > > >::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(ReadTetGen.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<std::pair<void** const, int> > >::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(ReadTetGen.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, int> > >::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::_Rb_tree_const_iterator<std::pair<double const, unsigned int> >::operator--()':
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::_Rb_tree_const_iterator<std::pair<void** const, std::vector<double, std::allocator<double> > > >::operator--()':
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::_Rb_tree_const_iterator<std::pair<void** const, int> >::operator--()':
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::_Rb_tree_const_iterator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, int> >::operator--()':
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::_Rb_tree_const_iterator<std::pair<double const, unsigned int> >::operator++()':
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::_Rb_tree_const_iterator<std::pair<void** const, std::vector<double, std::allocator<double> > > >::operator++()':
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::_Rb_tree_const_iterator<std::pair<void** const, int> >::operator++()':
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::_Rb_tree_const_iterator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, int> >::operator++()':
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::_Rb_tree<double, std::pair<double const, unsigned int>, std::_Select1st<std::pair<double const, unsigned int> >, std::less<double>, std::allocator<std::pair<double const, unsigned int> > >::_M_insert_(std::_Rb_tree_node_base const*, std::_Rb_tree_node_base const*, std::pair<double const, unsigned int> const&)':
/usr/include/c++/4.3/bits/stl_tree.h:854: undefined reference to `std::_Rb_tree_insert_and_rebalance(bool, std::_Rb_tree_node_base*, std::_Rb_tree_node_base*, std::_Rb_tree_node_base&)'
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::_Rb_tree<void**, std::pair<void** const, int>, std::_Select1st<std::pair<void** const, int> >, std::less<void**>, std::allocator<std::pair<void** const, int> > >::_M_insert_(std::_Rb_tree_node_base const*, std::_Rb_tree_node_base const*, std::pair<void** const, int> const&)':
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::basic_string<char, std::char_traits<char>, std::allocator<char> >* std::__uninitialized_copy<false>::uninitialized_copy<std::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::basic_string<char, std::char_traits<char>, std::allocator<char> >*>(std::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::basic_string<char, std::char_traits<char>, std::allocator<char> >*)':
/usr/include/c++/4.3/bits/stl_uninitialized.h:79: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/usr/include/c++/4.3/bits/stl_uninitialized.h:83: undefined reference to `__cxa_begin_catch'
/usr/include/c++/4.3/bits/stl_uninitialized.h:86: undefined reference to `__cxa_rethrow'
/usr/include/c++/4.3/bits/stl_uninitialized.h:83: undefined reference to `__cxa_end_catch'
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::_Rb_tree<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, int>, std::_Select1st<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, int> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, int> > >::_M_create_node(std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, int> const&)':
/usr/include/c++/4.3/bits/stl_tree.h:369: undefined reference to `__cxa_begin_catch'
/usr/include/c++/4.3/bits/stl_tree.h:372: undefined reference to `__cxa_rethrow'
/usr/include/c++/4.3/bits/stl_tree.h:369: undefined reference to `__cxa_end_catch'
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::_Rb_tree<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, int>, std::_Select1st<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, int> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, int> > >::_M_insert_(std::_Rb_tree_node_base const*, std::_Rb_tree_node_base const*, std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, int> const&)':
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::_Rb_tree_iterator<std::pair<double const, unsigned int> >::operator--()':
/usr/include/c++/4.3/bits/stl_tree.h:197: undefined reference to `std::_Rb_tree_decrement(std::_Rb_tree_node_base*)'
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::_Rb_tree_iterator<std::pair<void** const, std::vector<double, std::allocator<double> > > >::operator--()':
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::_Rb_tree_iterator<std::pair<void** const, int> >::operator--()':
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::_Rb_tree_iterator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, int> >::operator--()':
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::_Rb_tree<void**, std::pair<void** const, std::vector<double, std::allocator<double> > >, std::_Select1st<std::pair<void** const, std::vector<double, std::allocator<double> > > >, std::less<void**>, std::allocator<std::pair<void** const, std::vector<double, std::allocator<double> > > > >::_M_create_node(std::pair<void** const, std::vector<double, std::allocator<double> > > const&)':
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::_Rb_tree<void**, std::pair<void** const, std::vector<double, std::allocator<double> > >, std::_Select1st<std::pair<void** const, std::vector<double, std::allocator<double> > > >, std::less<void**>, std::allocator<std::pair<void** const, std::vector<double, std::allocator<double> > > > >::_M_insert_(std::_Rb_tree_node_base const*, std::_Rb_tree_node_base const*, std::pair<void** const, std::vector<double, std::allocator<double> > > const&)':
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >::_M_insert_aux(__gnu_cxx::__normal_iterator<std::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
/usr/include/c++/4.3/bits/vector.tcc:293: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/usr/include/c++/4.3/bits/vector.tcc:299: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/usr/include/c++/4.3/bits/vector.tcc:299: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadTetGen.o): In function `std::_Rb_tree_iterator<std::pair<void** const, std::vector<double, std::allocator<double> > > >::operator++()':
/usr/include/c++/4.3/bits/stl_tree.h:182: undefined reference to `std::_Rb_tree_increment(std::_Rb_tree_node_base*)'
../../.libs/libMOAB.a(ReadTetGen.o):(.rodata._ZTI10ReadTetGen[typeinfo for ReadTetGen]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(ReadTetGen.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(SequenceData.o): In function `SequenceData::subset(unsigned int, unsigned int, int const*) const':
/home/jason/moab/test/x86/../src/SequenceData.cpp:83: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(SequenceData.o): In function `~SequenceData':
/home/jason/moab/test/x86/../src/SequenceData.cpp:12: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(SequenceData.o):(.rodata._ZTI12SequenceData[typeinfo for SequenceData]+0x0): undefined reference to `vtable for __cxxabiv1::__class_type_info'
../../.libs/libMOAB.a(SequenceData.o):(.eh_frame+0x11): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(SequenceManager.o): In function `__static_initialization_and_destruction_0':
../../.libs/libMOAB.a(SequenceManager.o): In function `operator<<(std::basic_ostream<char, std::char_traits<char> >&, TypeSequenceManager const&)':
/home/jason/moab/test/x86/../src/SequenceManager.cpp:1591: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:1591: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:1591: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:1591: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:1598: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:1598: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:1598: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:1598: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(SequenceManager.o): In function `print_sequences(TypeSequenceManager const&)':
/home/jason/moab/test/x86/../src/SequenceManager.cpp:1620: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:1620: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:1620: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(SequenceManager.o): In function `operator<<(std::basic_ostream<char, std::char_traits<char> >&, SequenceManager const&)':
/home/jason/moab/test/x86/../src/SequenceManager.cpp:1609: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:1609: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:1609: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
../../.libs/libMOAB.a(SequenceManager.o): In function `print_sequences(SequenceManager const&)':
/home/jason/moab/test/x86/../src/SequenceManager.cpp:1615: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:1615: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:1615: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(SequenceManager.o): In function `SequenceManager::add_vsequence(EntitySequence*, EntitySequence*, HomCoord const&, HomCoord const&, HomCoord const&, HomCoord const&, HomCoord const&, HomCoord const&, bool, HomCoord const*, HomCoord const*)':
/home/jason/moab/test/x86/../src/SequenceManager.cpp:774: undefined reference to `__dynamic_cast'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:777: undefined reference to `__dynamic_cast'
../../.libs/libMOAB.a(SequenceManager.o): In function `SequenceManager::create_sweep_sequence(int, int, int, int, int, int, int*, MBEntityType, int, unsigned int&, EntitySequence*&)':
/home/jason/moab/test/x86/../src/SequenceManager.cpp:724: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:725: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:724: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:730: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:730: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(SequenceManager.o): In function `SequenceManager::create_scd_sequence(int, int, int, int, int, int, MBEntityType, int, unsigned int&, EntitySequence*&)':
/home/jason/moab/test/x86/../src/SequenceManager.cpp:652: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:653: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:652: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:658: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:658: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(SequenceManager.o): In function `SequenceManager::create_meshset_sequence(int, int, unsigned int, unsigned int&, EntitySequence*&)':
/home/jason/moab/test/x86/../src/SequenceManager.cpp:597: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:597: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:599: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:599: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(SequenceManager.o): In function `SequenceManager::create_meshset_sequence(int, int, unsigned int const*, unsigned int&, EntitySequence*&)':
/home/jason/moab/test/x86/../src/SequenceManager.cpp:563: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:563: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:565: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:565: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(SequenceManager.o): In function `SequenceManager::create_entity_sequence(MBEntityType, int, int, int, unsigned int&, EntitySequence*&)':
/home/jason/moab/test/x86/../src/SequenceManager.cpp:493: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:498: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:498: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:508: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:508: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:513: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:513: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:522: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:522: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:527: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:527: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(SequenceManager.o): In function `SequenceManager::allocate_mesh_set(unsigned int, unsigned int)':
/home/jason/moab/test/x86/../src/SequenceManager.cpp:391: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:391: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:396: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:396: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(SequenceManager.o): In function `SequenceManager::create_mesh_set(unsigned int, unsigned int&)':
/home/jason/moab/test/x86/../src/SequenceManager.cpp:324: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:324: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:326: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:326: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(SequenceManager.o): In function `SequenceManager::create_element(MBEntityType, unsigned int const*, unsigned int, unsigned int&)':
/home/jason/moab/test/x86/../src/SequenceManager.cpp:267: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:267: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:269: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:269: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:273: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:273: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:275: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:275: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(SequenceManager.o): In function `SequenceManager::create_vertex(double const*, unsigned int&)':
/home/jason/moab/test/x86/../src/SequenceManager.cpp:208: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:210: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SequenceManager.cpp:210: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(SequenceManager.o): In function `__gnu_cxx::new_allocator<ScdElementData::VertexDataRef>::deallocate(ScdElementData::VertexDataRef*, unsigned int)':
../../.libs/libMOAB.a(SequenceManager.o): In function `std::vector<ScdElementData::VertexDataRef, std::allocator<ScdElementData::VertexDataRef> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(SequenceManager.o): In function `__gnu_cxx::new_allocator<ScdElementData::VertexDataRef>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(SequenceManager.o): In function `VertexSequence':
/home/jason/moab/test/x86/../src/VertexSequence.hpp:20: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(SequenceManager.o):(.rodata._ZTI13ScdVertexData[typeinfo for ScdVertexData]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(SequenceManager.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(StructuredElementSeq.o): In function `~StructuredElementSeq':
/home/jason/moab/test/x86/../src/StructuredElementSeq.cpp:41: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(StructuredElementSeq.o): In function `StructuredElementSeq::split(unsigned int)':
/home/jason/moab/test/x86/../src/StructuredElementSeq.cpp:91: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(StructuredElementSeq.o): In function `StructuredElementSeq':
/home/jason/moab/test/x86/../src/StructuredElementSeq.cpp:35: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/StructuredElementSeq.cpp:35: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(StructuredElementSeq.o): In function `~ElementSequence':
/home/jason/moab/test/x86/../src/ElementSequence.hpp:20: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(StructuredElementSeq.o):(.rodata._ZTI20StructuredElementSeq[typeinfo for StructuredElementSeq]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(StructuredElementSeq.o):(.rodata._ZTI15ElementSequence[typeinfo for ElementSequence]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(StructuredElementSeq.o):(.rodata._ZTV15ElementSequence[vtable for ElementSequence]+0x14): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(StructuredElementSeq.o):(.rodata._ZTV15ElementSequence[vtable for ElementSequence]+0x24): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(StructuredElementSeq.o):(.rodata._ZTV15ElementSequence[vtable for ElementSequence]+0x28): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(StructuredElementSeq.o):(.rodata._ZTV15ElementSequence[vtable for ElementSequence]+0x30): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(StructuredElementSeq.o):(.rodata._ZTV15ElementSequence[vtable for ElementSequence]+0x34): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(StructuredElementSeq.o):(.rodata._ZTV15ElementSequence[vtable for ElementSequence]+0x38): more undefined references to `__cxa_pure_virtual' follow
../../.libs/libMOAB.a(StructuredElementSeq.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(SweptElementSeq.o): In function `~SweptElementSeq':
/home/jason/moab/test/x86/../src/SweptElementSeq.cpp:43: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(SweptElementSeq.o): In function `SweptElementSeq::split(unsigned int)':
/home/jason/moab/test/x86/../src/SweptElementSeq.cpp:93: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(SweptElementSeq.o): In function `SweptElementSeq':
/home/jason/moab/test/x86/../src/SweptElementSeq.cpp:37: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SweptElementSeq.cpp:37: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(SweptElementSeq.o):(.rodata._ZTI15SweptElementSeq[typeinfo for SweptElementSeq]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(SweptElementSeq.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(TagServer.o): In function `TagServer::get_memory_use(void**, unsigned long&, unsigned long&) const':
/home/jason/moab/test/x86/../src/TagServer.cpp:1060: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::size() const'
../../.libs/libMOAB.a(TagServer.o): In function `TagServer::get_memory_use(void**) const':
/home/jason/moab/test/x86/../src/TagServer.cpp:1029: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::size() const'
../../.libs/libMOAB.a(TagServer.o): In function `TagServer':
/home/jason/moab/test/x86/../src/TagServer.cpp:66: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/TagServer.cpp:67: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(TagServer.o): In function `~TagServer':
/home/jason/moab/test/x86/../src/TagServer.cpp:74: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/TagServer.cpp:75: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(TagServer.o):/home/jason/moab/test/x86/../src/TagServer.cpp:75: more undefined references to `operator delete(void*)' follow
../../.libs/libMOAB.a(TagServer.o): In function `std::vector<MBBitPage*, std::allocator<MBBitPage*> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(TagServer.o): In function `std::vector<TagInfo, std::allocator<TagInfo> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(TagServer.o): In function `__gnu_cxx::new_allocator<MBBitPage*>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(TagServer.o): In function `__gnu_cxx::new_allocator<TagInfo>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(TagServer.o): In function `MBBitPage::set_bits(int, int, unsigned char, unsigned char const*)':
/home/jason/moab/test/x86/../src/MBBits.hpp:249: undefined reference to `operator new[](unsigned int)'
../../.libs/libMOAB.a(TagServer.o): In function `MBBitPageGroup::set_bits(unsigned int, unsigned char, unsigned char const*)':
/home/jason/moab/test/x86/../src/MBBits.hpp:429: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(TagServer.o): In function `TagInfo':
/home/jason/moab/test/x86/../src/TagInfo.hpp:126: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/TagInfo.hpp:126: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/TagInfo.hpp:126: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(TagServer.o): In function `~TagInfo':
/home/jason/moab/test/x86/../src/TagInfo.hpp:140: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(TagServer.o): In function `TagInfo* std::__uninitialized_copy<false>::uninitialized_copy<TagInfo*, TagInfo*>(TagInfo*, TagInfo*, TagInfo*)':
../../.libs/libMOAB.a(TagServer.o): In function `std::vector<TagInfo, std::allocator<TagInfo> >::_M_insert_aux(__gnu_cxx::__normal_iterator<TagInfo*, std::vector<TagInfo, std::allocator<TagInfo> > >, TagInfo const&)':
../../.libs/libMOAB.a(TagServer.o): In function `~MBBitPage':
/home/jason/moab/test/x86/../src/MBBits.hpp:178: undefined reference to `operator delete[](void*)'
../../.libs/libMOAB.a(TagServer.o): In function `~MBBitPageGroup':
/home/jason/moab/test/x86/../src/MBBits.hpp:327: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(TagServer.o): In function `~MBBitServer':
/home/jason/moab/test/x86/../src/MBBits.hpp:493: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(TagServer.o):(.rodata._ZTI9TagServer[typeinfo for TagServer]+0x0): undefined reference to `vtable for __cxxabiv1::__class_type_info'
../../.libs/libMOAB.a(TagServer.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::ModelEntry::print()':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2552: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2552: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2552: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2552: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2552: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::SidesetHeader::print()':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2478: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2478: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2478: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2478: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2478: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2479: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2479: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2479: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2479: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2479: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2480: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2480: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2480: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2480: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2480: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2481: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2481: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2481: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2481: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2481: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2482: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2482: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2482: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2482: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2482: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2483: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2483: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2483: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2483: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2483: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2484: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2484: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2484: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2484: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2484: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2485: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2485: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2485: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2485: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2485: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2486: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2486: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2486: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2486: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2486: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::NodesetHeader::print()':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2461: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2461: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2461: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2461: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2461: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2462: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2462: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2462: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2462: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2462: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2463: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2463: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2463: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2463: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2463: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2464: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2464: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2464: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2464: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2464: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2465: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2465: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2465: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2465: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2465: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2466: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2466: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2466: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2466: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2466: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2467: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2467: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2467: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2467: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2467: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2468: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2468: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2468: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2468: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2468: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::GroupHeader::print()':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2421: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2421: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2421: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2421: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2421: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2422: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2422: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2422: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2422: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2422: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2423: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2423: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2423: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2423: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2423: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2424: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2424: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2424: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2424: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2424: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2425: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2425: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2425: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2425: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2425: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2426: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2426: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2426: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2426: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2426: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2427: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2427: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2427: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2427: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2427: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::GeomHeader::print()':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2404: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2404: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2404: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2404: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2404: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2405: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2405: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2405: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2405: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2405: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2406: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2406: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2406: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2406: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2406: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2407: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2407: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2407: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2407: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2407: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2408: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2408: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2408: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2408: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2408: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2409: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2409: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2409: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2409: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2409: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2410: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2410: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2410: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2410: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2410: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2411: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2411: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2411: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2411: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2411: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::FEModelHeader::ArrayInfo::print()':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2375: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2375: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2375: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2375: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2375: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::FEModelHeader::print()':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2386: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2386: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2386: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2386: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2386: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2388: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2388: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2389: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2389: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2390: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2390: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2391: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2391: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2392: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2392: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2393: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2393: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2394: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2394: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::FileTOC::print()':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2361: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2361: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2364: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2364: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2364: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2364: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2364: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::MetaDataContainer::MetaDataEntry::print()':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2498: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2498: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2498: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2498: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char>, std::allocator<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2498: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(double)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2501: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2501: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2501: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2501: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2501: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2503: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2503: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2503: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2506: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2506: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2506: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2506: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2506: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(double)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2508: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2508: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2508: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(double)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2510: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2510: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2510: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::MetaDataContainer::print()':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2516: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2516: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2516: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2516: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2516: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(Tqdcfr.o): In function `MetaDataEntry':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2491: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2491: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2491: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2492: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(Tqdcfr.o): In function `__static_initialization_and_destruction_0':
/usr/include/c++/4.3/iostream:77: undefined reference to `std::ios_base::Init::Init()'
/usr/include/c++/4.3/iostream:77: undefined reference to `std::ios_base::Init::~Init()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:93: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:93: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:93: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:93: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:94: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:94: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:94: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:94: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(Tqdcfr.o): In function `~ModelEntry':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2543: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2544: undefined reference to `operator delete[](void*)'
../../.libs/libMOAB.a(Tqdcfr.o):/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2543: more undefined references to `operator delete[](void*)' follow
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::BlockHeader::print()':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2438: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2438: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2438: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2438: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2438: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2439: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2439: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2439: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2439: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2439: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2440: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2440: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2440: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2440: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2440: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2441: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2441: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2441: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2441: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2441: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2442: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2442: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2442: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2442: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2442: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2443: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2443: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2443: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2443: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2443: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2444: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2444: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2444: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2444: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2444: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2445: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2445: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2445: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2445: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2445: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2446: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2446: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2446: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2446: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2446: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2447: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2447: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2447: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2447: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2447: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2448: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2448: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2448: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2448: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2448: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2449: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2449: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2449: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2449: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2449: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2450: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2450: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2450: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2450: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2450: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2451: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2451: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2451: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2451: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2451: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::process_record(Tqdcfr::AcisRecord&)':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2255: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2259: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2277: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2284: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2284: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2284: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2285: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2285: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2290: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2294: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2298: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
../../.libs/libMOAB.a(Tqdcfr.o):/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2298: more undefined references to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const' follow
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2337: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2337: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2337: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2337: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::reset_record(Tqdcfr::AcisRecord&)':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2239: undefined reference to `__cxa_guard_acquire'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2239: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2239: undefined reference to `__cxa_guard_release'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2239: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2239: undefined reference to `__cxa_guard_abort'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2240: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::put_into_set(unsigned int, std::vector<unsigned int, std::allocator<unsigned int> >&, std::vector<unsigned int, std::allocator<unsigned int> >&)':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:890: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::parse_acis_attribs(unsigned int, std::vector<Tqdcfr::AcisRecord, std::allocator<Tqdcfr::AcisRecord> >&)':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2109: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::length() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2109: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2119: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::length() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2119: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2122: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2125: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2127: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2131: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2134: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2138: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2144: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2151: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2151: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2151: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2151: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2151: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2151: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2154: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2156: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2160: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2212: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2229: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `~Tqdcfr':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:185: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:185: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:185: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:188: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:188: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:190: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:168: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:168: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:168: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:168: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::factory(MBInterface*)':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:158: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:158: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::get_mesh_entities(unsigned int, int*, unsigned int, std::vector<unsigned int, std::allocator<unsigned int> >&, std::vector<unsigned int, std::allocator<unsigned int> >&)':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:994: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:994: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:994: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:994: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:994: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::convert_nodesets_sidesets()':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:400: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:408: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::read_md_string(std::basic_string<char, std::char_traits<char>, std::allocator<char> >&)':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:1475: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(char const*)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::read_acis_records(char const*)':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2021: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::append(char const*, unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:2034: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::append(char const*, unsigned int)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::SidesetHeader::read_info_header(unsigned int, Tqdcfr::FEModelHeader::ArrayInfo const&, Tqdcfr*, Tqdcfr::SidesetHeader*&)':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:1749: undefined reference to `operator new[](unsigned int)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::NodesetHeader::read_info_header(unsigned int, Tqdcfr::FEModelHeader::ArrayInfo const&, Tqdcfr*, Tqdcfr::NodesetHeader*&)':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:1699: undefined reference to `operator new[](unsigned int)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::BlockHeader::read_info_header(double, unsigned int, Tqdcfr::FEModelHeader::ArrayInfo const&, Tqdcfr*, Tqdcfr::BlockHeader*&)':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:1617: undefined reference to `operator new[](unsigned int)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::GroupHeader::read_info_header(unsigned int, Tqdcfr::FEModelHeader::ArrayInfo const&, Tqdcfr*, Tqdcfr::GroupHeader*&)':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:1567: undefined reference to `operator new[](unsigned int)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::GeomHeader::read_info_header(unsigned int, Tqdcfr::FEModelHeader::ArrayInfo const&, Tqdcfr*, Tqdcfr::GeomHeader*&)':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:1493: undefined reference to `operator new[](unsigned int)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::read_elements(Tqdcfr::ModelEntry*, Tqdcfr::GeomHeader*)':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:1217: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:1217: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:1217: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:1217: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::read_nodes(unsigned int, Tqdcfr::ModelEntry*, Tqdcfr::GeomHeader*)':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:1073: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:1073: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:1144: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:1144: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:1144: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:1144: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::read_group(unsigned int, Tqdcfr::ModelEntry*, Tqdcfr::GroupHeader*)':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:830: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:830: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:830: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:830: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:842: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::length() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:844: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:847: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:847: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:847: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:847: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:854: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:854: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:854: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:854: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:859: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::length() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:866: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::read_block(double, Tqdcfr::ModelEntry*, Tqdcfr::BlockHeader*)':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:796: undefined reference to `__dynamic_cast'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::load_file(char const*, unsigned int&, FileOptions const&, char const*, int const*, int)':
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:252: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:252: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:252: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:252: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:300: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:302: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::clear()'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:303: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::empty() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:303: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/Tqdcfr.cpp:389: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(Tqdcfr.o): In function `~AcisRecord':
/home/jason/moab/test/x86/../src/Tqdcfr.hpp:262: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(Tqdcfr.o): In function `AcisRecord':
/home/jason/moab/test/x86/../src/Tqdcfr.hpp:262: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::AcisRecord::operator=(Tqdcfr::AcisRecord const&)':
/home/jason/moab/test/x86/../src/Tqdcfr.hpp:262: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `_Vector_impl':
/usr/include/c++/4.3/bits/stl_vector.h:85: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/Tqdcfr.hpp:262: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `~MetaDataEntry':
/home/jason/moab/test/x86/../src/Tqdcfr.hpp:98: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(Tqdcfr.o): In function `__gnu_cxx::new_allocator<Tqdcfr::MetaDataContainer::MetaDataEntry>::deallocate(Tqdcfr::MetaDataContainer::MetaDataEntry*, unsigned int)':
/usr/include/c++/4.3/ext/new_allocator.h:98: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<std::pair<int const, unsigned int> > >::deallocate(std::_Rb_tree_node<std::pair<int const, unsigned int> >*, unsigned int)':
../../.libs/libMOAB.a(Tqdcfr.o): In function `__gnu_cxx::new_allocator<Tqdcfr::AcisRecord>::deallocate(Tqdcfr::AcisRecord*, unsigned int)':
../../.libs/libMOAB.a(Tqdcfr.o): In function `__gnu_cxx::new_allocator<Tqdcfr::ModelEntry>::deallocate(Tqdcfr::ModelEntry*, unsigned int)':
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::AcisRecord* std::__uninitialized_copy<false>::uninitialized_copy<Tqdcfr::AcisRecord*, Tqdcfr::AcisRecord*>(Tqdcfr::AcisRecord*, Tqdcfr::AcisRecord*, Tqdcfr::AcisRecord*)':
/usr/include/c++/4.3/bits/stl_uninitialized.h:83: undefined reference to `__cxa_begin_catch'
/usr/include/c++/4.3/bits/stl_uninitialized.h:86: undefined reference to `__cxa_rethrow'
/usr/include/c++/4.3/bits/stl_uninitialized.h:83: undefined reference to `__cxa_end_catch'
../../.libs/libMOAB.a(Tqdcfr.o): In function `std::vector<Tqdcfr::AcisRecord, std::allocator<Tqdcfr::AcisRecord> >::_M_check_len(unsigned int, char const*) const':
/usr/include/c++/4.3/bits/stl_vector.h:1078: undefined reference to `std::__throw_length_error(char const*)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `std::vector<Tqdcfr::MetaDataContainer::MetaDataEntry, std::allocator<Tqdcfr::MetaDataContainer::MetaDataEntry> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(Tqdcfr.o): In function `std::vector<Tqdcfr::ModelEntry, std::allocator<Tqdcfr::ModelEntry> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(Tqdcfr.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<std::pair<int const, unsigned int> > >::allocate(unsigned int, void const*)':
/usr/include/c++/4.3/ext/new_allocator.h:90: undefined reference to `std::__throw_bad_alloc()'
/usr/include/c++/4.3/ext/new_allocator.h:92: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `__gnu_cxx::new_allocator<Tqdcfr::AcisRecord>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(Tqdcfr.o): In function `std::vector<Tqdcfr::AcisRecord, std::allocator<Tqdcfr::AcisRecord> >::_M_insert_aux(__gnu_cxx::__normal_iterator<Tqdcfr::AcisRecord*, std::vector<Tqdcfr::AcisRecord, std::allocator<Tqdcfr::AcisRecord> > >, Tqdcfr::AcisRecord const&)':
/usr/include/c++/4.3/bits/vector.tcc:330: undefined reference to `__cxa_begin_catch'
/usr/include/c++/4.3/bits/vector.tcc:334: undefined reference to `__cxa_rethrow'
/usr/include/c++/4.3/bits/vector.tcc:330: undefined reference to `__cxa_end_catch'
../../.libs/libMOAB.a(Tqdcfr.o): In function `__gnu_cxx::new_allocator<Tqdcfr::MetaDataContainer::MetaDataEntry>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(Tqdcfr.o): In function `__gnu_cxx::new_allocator<Tqdcfr::ModelEntry>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(Tqdcfr.o): In function `std::_Rb_tree_const_iterator<std::pair<int const, unsigned int> >::operator--()':
/usr/include/c++/4.3/bits/stl_tree.h:272: undefined reference to `std::_Rb_tree_decrement(std::_Rb_tree_node_base const*)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `std::_Rb_tree_const_iterator<std::pair<int const, unsigned int> >::operator++()':
/usr/include/c++/4.3/bits/stl_tree.h:257: undefined reference to `std::_Rb_tree_increment(std::_Rb_tree_node_base const*)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `std::_Rb_tree<int, std::pair<int const, unsigned int>, std::_Select1st<std::pair<int const, unsigned int> >, std::less<int>, std::allocator<std::pair<int const, unsigned int> > >::_M_insert_(std::_Rb_tree_node_base const*, std::_Rb_tree_node_base const*, std::pair<int const, unsigned int> const&)':
/usr/include/c++/4.3/bits/stl_tree.h:854: undefined reference to `std::_Rb_tree_insert_and_rebalance(bool, std::_Rb_tree_node_base*, std::_Rb_tree_node_base*, std::_Rb_tree_node_base&)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `std::_Rb_tree_iterator<std::pair<int const, unsigned int> >::operator--()':
/usr/include/c++/4.3/bits/stl_tree.h:197: undefined reference to `std::_Rb_tree_decrement(std::_Rb_tree_node_base*)'
/home/jason/moab/test/x86/../src/Tqdcfr.hpp:98: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `void std::__uninitialized_fill_n<false>::uninitialized_fill_n<Tqdcfr::MetaDataContainer::MetaDataEntry*, unsigned int, Tqdcfr::MetaDataContainer::MetaDataEntry>(Tqdcfr::MetaDataContainer::MetaDataEntry*, unsigned int, Tqdcfr::MetaDataContainer::MetaDataEntry const&)':
/usr/include/c++/4.3/bits/stl_uninitialized.h:194: undefined reference to `__cxa_begin_catch'
/usr/include/c++/4.3/bits/stl_uninitialized.h:197: undefined reference to `__cxa_rethrow'
/usr/include/c++/4.3/bits/stl_uninitialized.h:194: undefined reference to `__cxa_end_catch'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::MetaDataContainer::MetaDataEntry* std::__uninitialized_copy<false>::uninitialized_copy<Tqdcfr::MetaDataContainer::MetaDataEntry*, Tqdcfr::MetaDataContainer::MetaDataEntry*>(Tqdcfr::MetaDataContainer::MetaDataEntry*, Tqdcfr::MetaDataContainer::MetaDataEntry*, Tqdcfr::MetaDataContainer::MetaDataEntry*)':
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::MetaDataContainer::MetaDataEntry* std::__uninitialized_copy<false>::uninitialized_copy<__gnu_cxx::__normal_iterator<Tqdcfr::MetaDataContainer::MetaDataEntry const*, std::vector<Tqdcfr::MetaDataContainer::MetaDataEntry, std::allocator<Tqdcfr::MetaDataContainer::MetaDataEntry> > >, Tqdcfr::MetaDataContainer::MetaDataEntry*>(__gnu_cxx::__normal_iterator<Tqdcfr::MetaDataContainer::MetaDataEntry const*, std::vector<Tqdcfr::MetaDataContainer::MetaDataEntry, std::allocator<Tqdcfr::MetaDataContainer::MetaDataEntry> > >, __gnu_cxx::__normal_iterator<Tqdcfr::MetaDataContainer::MetaDataEntry const*, std::vector<Tqdcfr::MetaDataContainer::MetaDataEntry, std::allocator<Tqdcfr::MetaDataContainer::MetaDataEntry> > >, Tqdcfr::MetaDataContainer::MetaDataEntry*)':
../../.libs/libMOAB.a(Tqdcfr.o): In function `void std::__uninitialized_fill_n<false>::uninitialized_fill_n<Tqdcfr::ModelEntry*, unsigned int, Tqdcfr::ModelEntry>(Tqdcfr::ModelEntry*, unsigned int, Tqdcfr::ModelEntry const&)':
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::ModelEntry* std::__uninitialized_copy<false>::uninitialized_copy<Tqdcfr::ModelEntry*, Tqdcfr::ModelEntry*>(Tqdcfr::ModelEntry*, Tqdcfr::ModelEntry*, Tqdcfr::ModelEntry*)':
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::MetaDataContainer::MetaDataEntry* std::vector<Tqdcfr::MetaDataContainer::MetaDataEntry, std::allocator<Tqdcfr::MetaDataContainer::MetaDataEntry> >::_M_allocate_and_copy<__gnu_cxx::__normal_iterator<Tqdcfr::MetaDataContainer::MetaDataEntry const*, std::vector<Tqdcfr::MetaDataContainer::MetaDataEntry, std::allocator<Tqdcfr::MetaDataContainer::MetaDataEntry> > > >(unsigned int, __gnu_cxx::__normal_iterator<Tqdcfr::MetaDataContainer::MetaDataEntry const*, std::vector<Tqdcfr::MetaDataContainer::MetaDataEntry, std::allocator<Tqdcfr::MetaDataContainer::MetaDataEntry> > >, __gnu_cxx::__normal_iterator<Tqdcfr::MetaDataContainer::MetaDataEntry const*, std::vector<Tqdcfr::MetaDataContainer::MetaDataEntry, std::allocator<Tqdcfr::MetaDataContainer::MetaDataEntry> > >)':
/usr/include/c++/4.3/bits/stl_vector.h:911: undefined reference to `__cxa_begin_catch'
/usr/include/c++/4.3/bits/stl_vector.h:914: undefined reference to `__cxa_rethrow'
/usr/include/c++/4.3/bits/stl_vector.h:911: undefined reference to `__cxa_end_catch'
../../.libs/libMOAB.a(Tqdcfr.o): In function `Tqdcfr::MetaDataContainer::MetaDataEntry::operator=(Tqdcfr::MetaDataContainer::MetaDataEntry const&)':
/home/jason/moab/test/x86/../src/Tqdcfr.hpp:98: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
../../.libs/libMOAB.a(Tqdcfr.o): In function `std::vector<Tqdcfr::MetaDataContainer::MetaDataEntry, std::allocator<Tqdcfr::MetaDataContainer::MetaDataEntry> >::_M_fill_insert(__gnu_cxx::__normal_iterator<Tqdcfr::MetaDataContainer::MetaDataEntry*, std::vector<Tqdcfr::MetaDataContainer::MetaDataEntry, std::allocator<Tqdcfr::MetaDataContainer::MetaDataEntry> > >, unsigned int, Tqdcfr::MetaDataContainer::MetaDataEntry const&)':
/usr/include/c++/4.3/bits/vector.tcc:417: undefined reference to `__cxa_begin_catch'
/usr/include/c++/4.3/bits/vector.tcc:422: undefined reference to `__cxa_rethrow'
/usr/include/c++/4.3/bits/vector.tcc:417: undefined reference to `__cxa_end_catch'
../../.libs/libMOAB.a(Tqdcfr.o): In function `std::vector<Tqdcfr::ModelEntry, std::allocator<Tqdcfr::ModelEntry> >::_M_fill_insert(__gnu_cxx::__normal_iterator<Tqdcfr::ModelEntry*, std::vector<Tqdcfr::ModelEntry, std::allocator<Tqdcfr::ModelEntry> > >, unsigned int, Tqdcfr::ModelEntry const&)':
../../.libs/libMOAB.a(Tqdcfr.o):(.rodata._ZTI6Tqdcfr[typeinfo for Tqdcfr]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(Tqdcfr.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(TypeSequenceManager.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<SequenceData*> >::deallocate(std::_Rb_tree_node<SequenceData*>*, unsigned int)':
TypeSequenceManager.cpp:(.text._ZN9__gnu_cxx13new_allocatorISt13_Rb_tree_nodeIP12SequenceDataEE10deallocateEPS4_j[__gnu_cxx::new_allocator<std::_Rb_tree_node<SequenceData*> >::deallocate(std::_Rb_tree_node<SequenceData*>*, unsigned int)]+0xd): undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(TypeSequenceManager.o): In function `std::_Rb_tree_const_iterator<EntitySequence*>::operator--()':
TypeSequenceManager.cpp:(.text._ZNSt23_Rb_tree_const_iteratorIP14EntitySequenceEmmEv[std::_Rb_tree_const_iterator<EntitySequence*>::operator--()]+0xf): undefined reference to `std::_Rb_tree_decrement(std::_Rb_tree_node_base const*)'
../../.libs/libMOAB.a(TypeSequenceManager.o): In function `std::_Rb_tree_const_iterator<SequenceData*>::operator++()':
TypeSequenceManager.cpp:(.text._ZNSt23_Rb_tree_const_iteratorIP12SequenceDataEppEv[std::_Rb_tree_const_iterator<SequenceData*>::operator++()]+0xf): undefined reference to `std::_Rb_tree_increment(std::_Rb_tree_node_base const*)'
../../.libs/libMOAB.a(TypeSequenceManager.o): In function `std::_Rb_tree_iterator<SequenceData*>::operator++(int)':
TypeSequenceManager.cpp:(.text._ZNSt17_Rb_tree_iteratorIP12SequenceDataEppEi[std::_Rb_tree_iterator<SequenceData*>::operator++(int)]+0x1a): undefined reference to `std::_Rb_tree_increment(std::_Rb_tree_node_base*)'
../../.libs/libMOAB.a(TypeSequenceManager.o): In function `std::_Rb_tree<SequenceData*, SequenceData*, std::_Identity<SequenceData*>, std::less<SequenceData*>, std::allocator<SequenceData*> >::erase(std::_Rb_tree_iterator<SequenceData*>)':
TypeSequenceManager.cpp:(.text._ZNSt8_Rb_treeIP12SequenceDataS1_St9_IdentityIS1_ESt4lessIS1_ESaIS1_EE5eraseESt17_Rb_tree_iteratorIS1_E[std::_Rb_tree<SequenceData*, SequenceData*, std::_Identity<SequenceData*>, std::less<SequenceData*>, std::allocator<SequenceData*> >::erase(std::_Rb_tree_iterator<SequenceData*>)]+0x17): undefined reference to `std::_Rb_tree_rebalance_for_erase(std::_Rb_tree_node_base*, std::_Rb_tree_node_base&)'
../../.libs/libMOAB.a(TypeSequenceManager.o): In function `std::_Rb_tree<EntitySequence*, EntitySequence*, std::_Identity<EntitySequence*>, TypeSequenceManager::SequenceCompare, std::allocator<EntitySequence*> >::erase(std::_Rb_tree_const_iterator<EntitySequence*>)':
TypeSequenceManager.cpp:(.text._ZNSt8_Rb_treeIP14EntitySequenceS1_St9_IdentityIS1_EN19TypeSequenceManager15SequenceCompareESaIS1_EE5eraseESt23_Rb_tree_const_iteratorIS1_E[std::_Rb_tree<EntitySequence*, EntitySequence*, std::_Identity<EntitySequence*>, TypeSequenceManager::SequenceCompare, std::allocator<EntitySequence*> >::erase(std::_Rb_tree_const_iterator<EntitySequence*>)]+0x17): undefined reference to `std::_Rb_tree_rebalance_for_erase(std::_Rb_tree_node_base*, std::_Rb_tree_node_base&)'
../../.libs/libMOAB.a(TypeSequenceManager.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<EntitySequence*> >::allocate(unsigned int, void const*)':
TypeSequenceManager.cpp:(.text._ZN9__gnu_cxx13new_allocatorISt13_Rb_tree_nodeIP14EntitySequenceEE8allocateEjPKv[__gnu_cxx::new_allocator<std::_Rb_tree_node<EntitySequence*> >::allocate(unsigned int, void const*)]+0x24): undefined reference to `std::__throw_bad_alloc()'
TypeSequenceManager.cpp:(.text._ZN9__gnu_cxx13new_allocatorISt13_Rb_tree_nodeIP14EntitySequenceEE8allocateEjPKv[__gnu_cxx::new_allocator<std::_Rb_tree_node<EntitySequence*> >::allocate(unsigned int, void const*)]+0x39): undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(TypeSequenceManager.o): In function `std::_Rb_tree<EntitySequence*, EntitySequence*, std::_Identity<EntitySequence*>, TypeSequenceManager::SequenceCompare, std::allocator<EntitySequence*> >::_M_insert_(std::_Rb_tree_node_base const*, std::_Rb_tree_node_base const*, EntitySequence* const&)':
TypeSequenceManager.cpp:(.text._ZNSt8_Rb_treeIP14EntitySequenceS1_St9_IdentityIS1_EN19TypeSequenceManager15SequenceCompareESaIS1_EE10_M_insert_EPKSt18_Rb_tree_node_baseSA_RKS1_[std::_Rb_tree<EntitySequence*, EntitySequence*, std::_Identity<EntitySequence*>, TypeSequenceManager::SequenceCompare, std::allocator<EntitySequence*> >::_M_insert_(std::_Rb_tree_node_base const*, std::_Rb_tree_node_base const*, EntitySequence* const&)]+0x9b): undefined reference to `std::_Rb_tree_insert_and_rebalance(bool, std::_Rb_tree_node_base*, std::_Rb_tree_node_base*, std::_Rb_tree_node_base&)'
../../.libs/libMOAB.a(TypeSequenceManager.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<SequenceData*> >::allocate(unsigned int, void const*)':
TypeSequenceManager.cpp:(.text._ZN9__gnu_cxx13new_allocatorISt13_Rb_tree_nodeIP12SequenceDataEE8allocateEjPKv[__gnu_cxx::new_allocator<std::_Rb_tree_node<SequenceData*> >::allocate(unsigned int, void const*)]+0x24): undefined reference to `std::__throw_bad_alloc()'
TypeSequenceManager.cpp:(.text._ZN9__gnu_cxx13new_allocatorISt13_Rb_tree_nodeIP12SequenceDataEE8allocateEjPKv[__gnu_cxx::new_allocator<std::_Rb_tree_node<SequenceData*> >::allocate(unsigned int, void const*)]+0x39): undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(TypeSequenceManager.o): In function `std::_Rb_tree<SequenceData*, SequenceData*, std::_Identity<SequenceData*>, std::less<SequenceData*>, std::allocator<SequenceData*> >::_M_insert_(std::_Rb_tree_node_base const*, std::_Rb_tree_node_base const*, SequenceData* const&)':
TypeSequenceManager.cpp:(.text._ZNSt8_Rb_treeIP12SequenceDataS1_St9_IdentityIS1_ESt4lessIS1_ESaIS1_EE10_M_insert_EPKSt18_Rb_tree_node_baseSA_RKS1_[std::_Rb_tree<SequenceData*, SequenceData*, std::_Identity<SequenceData*>, std::less<SequenceData*>, std::allocator<SequenceData*> >::_M_insert_(std::_Rb_tree_node_base const*, std::_Rb_tree_node_base const*, SequenceData* const&)]+0x99): undefined reference to `std::_Rb_tree_insert_and_rebalance(bool, std::_Rb_tree_node_base*, std::_Rb_tree_node_base*, std::_Rb_tree_node_base&)'
../../.libs/libMOAB.a(TypeSequenceManager.o): In function `std::_Rb_tree_iterator<EntitySequence*>::operator--()':
TypeSequenceManager.cpp:(.text._ZNSt17_Rb_tree_iteratorIP14EntitySequenceEmmEv[std::_Rb_tree_iterator<EntitySequence*>::operator--()]+0xf): undefined reference to `std::_Rb_tree_decrement(std::_Rb_tree_node_base*)'
../../.libs/libMOAB.a(TypeSequenceManager.o): In function `std::_Rb_tree_iterator<SequenceData*>::operator--()':
TypeSequenceManager.cpp:(.text._ZNSt17_Rb_tree_iteratorIP12SequenceDataEmmEv[std::_Rb_tree_iterator<SequenceData*>::operator--()]+0xf): undefined reference to `std::_Rb_tree_decrement(std::_Rb_tree_node_base*)'
../../.libs/libMOAB.a(TypeSequenceManager.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(UnstructuredElemSeq.o): In function `UnstructuredElemSeq::split(unsigned int)':
/home/jason/moab/test/x86/../src/UnstructuredElemSeq.cpp:38: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(UnstructuredElemSeq.o): In function `~UnstructuredElemSeq':
/home/jason/moab/test/x86/../src/UnstructuredElemSeq.cpp:25: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(UnstructuredElemSeq.o): In function `UnstructuredElemSeq':
/home/jason/moab/test/x86/../src/UnstructuredElemSeq.cpp:18: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(UnstructuredElemSeq.o):(.rodata._ZTI19UnstructuredElemSeq[typeinfo for UnstructuredElemSeq]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(UnstructuredElemSeq.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(VertexSequence.o): In function `VertexSequence::split(unsigned int)':
/home/jason/moab/test/x86/../src/VertexSequence.cpp:6: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(VertexSequence.o): In function `~VertexSequence':
/home/jason/moab/test/x86/../src/VertexSequence.cpp:3: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(VertexSequence.o):(.rodata._ZTI14VertexSequence[typeinfo for VertexSequence]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(VertexSequence.o):(.eh_frame+0x11): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(WriteAns.o): In function `~WriteAns':
/home/jason/moab/test/x86/../src/WriteAns.cpp:83: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteAns.cpp:83: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:83: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/WriteAns.cpp:84: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteAns.cpp:86: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteAns.cpp:86: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteAns.o): In function `__static_initialization_and_destruction_0':
../../.libs/libMOAB.a(WriteAns.o): In function `WriteAns':
/home/jason/moab/test/x86/../src/WriteAns.cpp:53: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/WriteAns.cpp:58: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteAns.cpp:58: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:58: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteAns.cpp:58: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/WriteAns.cpp:79: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(WriteAns.o): In function `WriteAns::write_file(char const*, bool, FileOptions const&, unsigned int const*, int, std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, void** const*, int, int)':
/home/jason/moab/test/x86/../src/WriteAns.cpp:115: undefined reference to `std::basic_ofstream<char, std::char_traits<char> >::basic_ofstream()'
/home/jason/moab/test/x86/../src/WriteAns.cpp:116: undefined reference to `std::basic_ofstream<char, std::char_traits<char> >::basic_ofstream()'
/home/jason/moab/test/x86/../src/WriteAns.cpp:117: undefined reference to `std::basic_ofstream<char, std::char_traits<char> >::basic_ofstream()'
/home/jason/moab/test/x86/../src/WriteAns.cpp:120: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/WriteAns.cpp:121: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/WriteAns.cpp:122: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::assign(char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:123: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::find_last_of(char const*, unsigned int) const'
/home/jason/moab/test/x86/../src/WriteAns.cpp:123: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::replace(unsigned int, unsigned int, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:126: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:126: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteAns.cpp:127: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/WriteAns.cpp:127: undefined reference to `std::basic_ofstream<char, std::char_traits<char> >::open(char const*, std::_Ios_Openmode)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:132: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:132: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteAns.cpp:133: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/WriteAns.cpp:133: undefined reference to `std::basic_ofstream<char, std::char_traits<char> >::open(char const*, std::_Ios_Openmode)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:136: undefined reference to `std::basic_ofstream<char, std::char_traits<char> >::open(char const*, std::_Ios_Openmode)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:137: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:137: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:137: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:176: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:178: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(double)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:180: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(double)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:182: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(double)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:182: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:182: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:186: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:186: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char>, std::allocator<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:186: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:186: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:208: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:208: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:208: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:208: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:208: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:211: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:211: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:211: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:211: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:211: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:216: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:216: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:216: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:216: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:244: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/WriteAns.cpp:244: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:249: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:249: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:250: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:250: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:251: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:251: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:252: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:252: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:254: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:254: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:255: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:255: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:256: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:256: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:256: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:257: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:257: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:262: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:262: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:263: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:263: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:264: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:264: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:265: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:265: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:267: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:267: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:268: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:268: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:269: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:269: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:269: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:270: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:270: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:272: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:272: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:273: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:273: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:292: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/WriteAns.cpp:292: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:298: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:298: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:299: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:299: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:300: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:300: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:301: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:301: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:303: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:303: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:304: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:304: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:305: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:305: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:305: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:306: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:306: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:312: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:312: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:313: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:313: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:314: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:314: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:315: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:315: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:317: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:317: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:318: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:318: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:319: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:319: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:319: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:320: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:320: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:322: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:322: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:323: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:323: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:324: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:324: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:325: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:325: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:326: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:326: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:327: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:327: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:328: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:328: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:346: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/WriteAns.cpp:346: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:352: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:352: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:353: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:353: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:354: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:354: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:355: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:355: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:357: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:357: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:358: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:358: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:359: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:359: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:359: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:360: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:360: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:366: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:366: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:366: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:367: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:367: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:367: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:368: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:368: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:368: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:373: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:373: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char>, std::allocator<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:373: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:373: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:400: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:400: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:400: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:400: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:400: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:403: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:403: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:403: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:403: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:403: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:408: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:408: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:408: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:408: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:408: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:414: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:414: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:414: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:414: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:438: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:438: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:438: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:438: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:438: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:440: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:440: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:440: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:440: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:440: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:444: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:444: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:444: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:444: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteAns.cpp:448: undefined reference to `std::basic_ofstream<char, std::char_traits<char> >::close()'
/home/jason/moab/test/x86/../src/WriteAns.cpp:449: undefined reference to `std::basic_ofstream<char, std::char_traits<char> >::close()'
/home/jason/moab/test/x86/../src/WriteAns.cpp:450: undefined reference to `std::basic_ofstream<char, std::char_traits<char> >::close()'
/home/jason/moab/test/x86/../src/WriteAns.cpp:452: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteAns.cpp:452: undefined reference to `std::basic_ofstream<char, std::char_traits<char> >::~basic_ofstream()'
../../.libs/libMOAB.a(WriteAns.o):/home/jason/moab/test/x86/../src/WriteAns.cpp:452: more undefined references to `std::basic_ofstream<char, std::char_traits<char> >::~basic_ofstream()' follow
../../.libs/libMOAB.a(WriteAns.o): In function `WriteAns::factory(MBInterface*)':
/home/jason/moab/test/x86/../src/WriteAns.cpp:50: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/WriteAns.cpp:50: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteAns.o): In function `std::basic_string<char, std::char_traits<char>, std::allocator<char> > std::operator+<char, std::char_traits<char>, std::allocator<char> >(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char const*)':
/usr/include/c++/4.3/bits/basic_string.h:2123: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/usr/include/c++/4.3/bits/basic_string.h:2124: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::append(char const*)'
/usr/include/c++/4.3/bits/basic_string.h:2125: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(WriteAns.o): In function `~MBWriterIface':
/home/jason/moab/test/x86/../src/MBWriterIface.hpp:37: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteAns.o):(.rodata._ZTI8WriteAns[typeinfo for WriteAns]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(WriteAns.o):(.rodata._ZTI13MBWriterIface[typeinfo for MBWriterIface]+0x0): undefined reference to `vtable for __cxxabiv1::__class_type_info'
../../.libs/libMOAB.a(WriteAns.o):(.rodata._ZTV13MBWriterIface[vtable for MBWriterIface]+0x10): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(WriteAns.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(WriteGMV.o): In function `~WriteGMV':
/home/jason/moab/test/x86/../src/WriteGMV.cpp:104: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:104: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:104: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:105: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:106: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteGMV.o): In function `WriteGMV::local_write_mesh(char const*, unsigned int, int, bool, bool)':
/home/jason/moab/test/x86/../src/WriteGMV.cpp:166: undefined reference to `std::basic_ofstream<char, std::char_traits<char> >::basic_ofstream()'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:171: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:171: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:171: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:172: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator+=(char const*)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:173: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:173: undefined reference to `std::basic_ofstream<char, std::char_traits<char> >::open(char const*, std::_Ios_Openmode)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:173: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:177: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:177: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:177: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:178: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator+=(char const*)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:179: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:179: undefined reference to `std::basic_ofstream<char, std::char_traits<char> >::open(char const*, std::_Ios_Openmode)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:179: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:182: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:182: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:182: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:210: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:211: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:212: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:227: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:227: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:227: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:227: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:229: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(double)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:229: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:229: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:229: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:234: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:235: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:236: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:246: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:246: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:246: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:246: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:285: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:285: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:285: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:285: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:287: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:287: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:288: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:288: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:311: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:311: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:311: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:311: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:344: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:347: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:347: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:349: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:349: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:353: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:353: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:353: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:355: undefined reference to `std::basic_ofstream<char, std::char_traits<char> >::close()'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:357: undefined reference to `std::basic_ofstream<char, std::char_traits<char> >::~basic_ofstream()'
../../.libs/libMOAB.a(WriteGMV.o): In function `WriteGMV':
/home/jason/moab/test/x86/../src/WriteGMV.cpp:59: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:59: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:59: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:99: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(WriteGMV.o): In function `WriteGMV::factory(MBInterface*)':
/home/jason/moab/test/x86/../src/WriteGMV.cpp:52: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/WriteGMV.cpp:52: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteGMV.o): In function `std::vector<int, std::allocator<int> >::reserve(unsigned int)':
/usr/include/c++/4.3/bits/vector.tcc:73: undefined reference to `std::__throw_length_error(char const*)'
../../.libs/libMOAB.a(WriteGMV.o):(.rodata._ZTI8WriteGMV[typeinfo for WriteGMV]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(WriteGMV.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(WriteGmsh.o): In function `WriteGmsh':
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:23: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:23: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:23: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:23: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(WriteGmsh.o): In function `~WriteGmsh':
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:29: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:29: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:29: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:29: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:30: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteGmsh.o): In function `WriteGmsh::factory(MBInterface*)':
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:17: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:17: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteGmsh.o): In function `WriteGmsh::write_file(char const*, bool, FileOptions const&, unsigned int const*, int, std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, void** const*, int, int)':
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:250: undefined reference to `std::basic_ofstream<char, std::char_traits<char> >::basic_ofstream(char const*, std::_Ios_Openmode)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:251: undefined reference to `std::basic_ios<char, std::char_traits<char> >::operator!() const'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:256: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:256: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:256: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:257: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:257: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:257: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:257: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:258: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:258: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:258: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:268: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:268: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:268: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:269: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:269: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:269: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:277: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:278: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:278: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(double)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:279: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:279: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(double)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:280: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:280: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(double)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:281: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:281: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:283: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:283: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:283: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:290: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:290: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:290: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:291: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:291: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:291: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:300: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:300: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:302: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:302: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:308: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:308: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:313: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:313: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:315: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:315: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:317: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:317: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:317: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteGmsh.cpp:321: undefined reference to `std::basic_ofstream<char, std::char_traits<char> >::~basic_ofstream()'
../../.libs/libMOAB.a(WriteGmsh.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<std::pair<unsigned int const, ElemInfo> > >::deallocate(std::_Rb_tree_node<std::pair<unsigned int const, ElemInfo> >*, unsigned int)':
/usr/include/c++/4.3/ext/new_allocator.h:98: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteGmsh.o): In function `__gnu_cxx::new_allocator<std::_Rb_tree_node<std::pair<unsigned int const, ElemInfo> > >::allocate(unsigned int, void const*)':
/usr/include/c++/4.3/ext/new_allocator.h:90: undefined reference to `std::__throw_bad_alloc()'
/usr/include/c++/4.3/ext/new_allocator.h:92: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(WriteGmsh.o): In function `std::_Rb_tree_iterator<std::pair<unsigned int const, ElemInfo> >::operator--()':
/usr/include/c++/4.3/bits/stl_tree.h:197: undefined reference to `std::_Rb_tree_decrement(std::_Rb_tree_node_base*)'
../../.libs/libMOAB.a(WriteGmsh.o): In function `std::_Rb_tree<unsigned int, std::pair<unsigned int const, ElemInfo>, std::_Select1st<std::pair<unsigned int const, ElemInfo> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, ElemInfo> > >::_M_insert_(std::_Rb_tree_node_base const*, std::_Rb_tree_node_base const*, std::pair<unsigned int const, ElemInfo> const&)':
/usr/include/c++/4.3/bits/stl_tree.h:854: undefined reference to `std::_Rb_tree_insert_and_rebalance(bool, std::_Rb_tree_node_base*, std::_Rb_tree_node_base*, std::_Rb_tree_node_base&)'
../../.libs/libMOAB.a(WriteGmsh.o): In function `std::_Rb_tree_const_iterator<std::pair<unsigned int const, ElemInfo> >::operator--()':
/usr/include/c++/4.3/bits/stl_tree.h:272: undefined reference to `std::_Rb_tree_decrement(std::_Rb_tree_node_base const*)'
../../.libs/libMOAB.a(WriteGmsh.o): In function `std::_Rb_tree_const_iterator<std::pair<unsigned int const, ElemInfo> >::operator++()':
/usr/include/c++/4.3/bits/stl_tree.h:257: undefined reference to `std::_Rb_tree_increment(std::_Rb_tree_node_base const*)'
../../.libs/libMOAB.a(WriteGmsh.o): In function `std::_Rb_tree_iterator<std::pair<unsigned int const, ElemInfo> >::operator++()':
/usr/include/c++/4.3/bits/stl_tree.h:182: undefined reference to `std::_Rb_tree_increment(std::_Rb_tree_node_base*)'
../../.libs/libMOAB.a(WriteGmsh.o):(.rodata._ZTI9WriteGmsh[typeinfo for WriteGmsh]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(WriteGmsh.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(WriteSTL.o): In function `WriteSTL':
/home/jason/moab/test/x86/../src/WriteSTL.cpp:70: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteSTL.cpp:70: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteSTL.cpp:70: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteSTL.cpp:70: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(WriteSTL.o): In function `~WriteSTL':
/home/jason/moab/test/x86/../src/WriteSTL.cpp:76: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteSTL.cpp:76: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteSTL.cpp:76: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteSTL.cpp:76: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/WriteSTL.cpp:77: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteSTL.o): In function `WriteSTL::make_header(char*, std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&)':
/home/jason/moab/test/x86/../src/WriteSTL.cpp:198: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/WriteSTL.cpp:201: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator+=(char const*)'
/home/jason/moab/test/x86/../src/WriteSTL.cpp:202: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator+=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/WriteSTL.cpp:205: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::size() const'
/home/jason/moab/test/x86/../src/WriteSTL.cpp:208: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/WriteSTL.cpp:210: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(WriteSTL.o): In function `WriteSTL::factory(MBInterface*)':
/home/jason/moab/test/x86/../src/WriteSTL.cpp:64: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/WriteSTL.cpp:64: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteSTL.o):(.rodata._ZTI8WriteSTL[typeinfo for WriteSTL]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(WriteSTL.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(WriteVtk.o): In function `WriteVtk::write_header(std::basic_ostream<char, std::char_traits<char> >&)':
/home/jason/moab/test/x86/../src/WriteVtk.cpp:217: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:217: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:217: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:218: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:218: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:218: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:219: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:219: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:219: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:220: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:220: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:220: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(WriteVtk.o): In function `~WriteVtk':
/home/jason/moab/test/x86/../src/WriteVtk.cpp:66: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:66: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:66: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:66: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:67: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteVtk.o): In function `__static_initialization_and_destruction_0':
/usr/include/c++/4.3/iostream:77: undefined reference to `std::ios_base::Init::Init()'
/usr/include/c++/4.3/iostream:77: undefined reference to `std::ios_base::Init::~Init()'
../../.libs/libMOAB.a(WriteVtk.o): In function `WriteVtk::write_nodes(std::basic_ostream<char, std::char_traits<char> >&, MBRange const&)':
/home/jason/moab/test/x86/../src/WriteVtk.cpp:229: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:229: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:229: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:229: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:237: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(double)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:237: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:237: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:237: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(WriteVtk.o): In function `WriteVtk::write_bit_tag(std::basic_ostream<char, std::char_traits<char> >&, void**, MBRange const&, MBRange const&)':
/home/jason/moab/test/x86/../src/WriteVtk.cpp:528: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:535: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:571: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(WriteVtk.o): In function `WriteVtk::write_tag(std::basic_ostream<char, std::char_traits<char> >&, void**, MBRange const&, MBRange const&)':
/home/jason/moab/test/x86/../src/WriteVtk.cpp:579: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:604: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:610: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::begin()'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:610: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::end()'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:616: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:616: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char>, std::allocator<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:616: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:616: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:616: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:618: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:618: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char>, std::allocator<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:618: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:618: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:618: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:621: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:621: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <char, std::char_traits<char>, std::allocator<char> >(std::basic_ostream<char, std::char_traits<char> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:621: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:621: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:621: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:621: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:631: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(WriteVtk.o): In function `WriteVtk::write_tags(std::basic_ostream<char, std::char_traits<char> >&, bool, MBRange const&, void** const*, int)':
/home/jason/moab/test/x86/../src/WriteVtk.cpp:418: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:418: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:418: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:418: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(WriteVtk.o): In function `WriteVtk':
/home/jason/moab/test/x86/../src/WriteVtk.cpp:60: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:60: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:60: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:60: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(WriteVtk.o): In function `WriteVtk::factory(MBInterface*)':
/home/jason/moab/test/x86/../src/WriteVtk.cpp:52: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:52: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteVtk.o): In function `WriteVtk::write_elems(std::basic_ostream<char, std::char_traits<char> >&, MBRange const&, MBRange const&)':
/home/jason/moab/test/x86/../src/WriteVtk.cpp:263: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:263: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned long)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:263: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:263: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:263: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:301: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:304: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:304: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:307: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:307: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:308: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:308: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:312: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:312: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned long)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:312: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:312: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:314: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:314: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:314: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(WriteVtk.o): In function `WriteVtk::write_file(char const*, bool, FileOptions const&, unsigned int const*, int, std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, void** const*, int, int)':
/home/jason/moab/test/x86/../src/WriteVtk.cpp:108: undefined reference to `std::basic_ofstream<char, std::char_traits<char> >::basic_ofstream(char const*, std::_Ios_Openmode)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:109: undefined reference to `std::basic_ios<char, std::char_traits<char> >::operator!() const'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:123: undefined reference to `std::basic_ofstream<char, std::char_traits<char> >::close()'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:128: undefined reference to `std::basic_ofstream<char, std::char_traits<char> >::~basic_ofstream()'
../../.libs/libMOAB.a(WriteVtk.o): In function `void WriteVtk::write_data<unsigned short>(std::basic_ostream<char, std::char_traits<char> >&, std::vector<unsigned short, std::allocator<unsigned short> > const&, unsigned int)':
/home/jason/moab/test/x86/../src/WriteVtk.cpp:446: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned short)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:446: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:448: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:448: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(WriteVtk.o): In function `void WriteVtk::write_data<unsigned char>(std::basic_ostream<char, std::char_traits<char> >&, std::vector<unsigned char, std::allocator<unsigned char> > const&, unsigned int)':
/home/jason/moab/test/x86/../src/WriteVtk.cpp:444: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(unsigned int)'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:444: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char)'
../../.libs/libMOAB.a(WriteVtk.o): In function `void WriteVtk::write_data<double>(std::basic_ostream<char, std::char_traits<char> >&, std::vector<double, std::allocator<double> > const&, unsigned int)':
/home/jason/moab/test/x86/../src/WriteVtk.cpp:446: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(double)'
../../.libs/libMOAB.a(WriteVtk.o): In function `__gnu_cxx::new_allocator<unsigned short>::deallocate(unsigned short*, unsigned int)':
../../.libs/libMOAB.a(WriteVtk.o): In function `std::vector<unsigned short, std::allocator<unsigned short> >::_M_check_len(unsigned int, char const*) const':
/usr/include/c++/4.3/bits/stl_vector.h:1078: undefined reference to `std::__throw_length_error(char const*)'
../../.libs/libMOAB.a(WriteVtk.o): In function `MBErrorCode WriteVtk::write_tag<unsigned char>(std::basic_ostream<char, std::char_traits<char> >&, void**, MBRange const&, MBRange const&, int)':
/home/jason/moab/test/x86/../src/WriteVtk.cpp:480: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:489: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/WriteVtk.cpp:515: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(WriteVtk.o): In function `MBErrorCode WriteVtk::write_tag<double>(std::basic_ostream<char, std::char_traits<char> >&, void**, MBRange const&, MBRange const&, int)':
../../.libs/libMOAB.a(WriteVtk.o): In function `__gnu_cxx::new_allocator<unsigned short>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(WriteVtk.o): In function `void WriteVtk::write_data<int>(std::basic_ostream<char, std::char_traits<char> >&, std::vector<int, std::allocator<int> > const&, unsigned int)':
/home/jason/moab/test/x86/../src/WriteVtk.cpp:446: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
../../.libs/libMOAB.a(WriteVtk.o): In function `MBErrorCode WriteVtk::write_tag<int>(std::basic_ostream<char, std::char_traits<char> >&, void**, MBRange const&, MBRange const&, int)':
../../.libs/libMOAB.a(WriteVtk.o):(.rodata._ZTI8WriteVtk[typeinfo for WriteVtk]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(WriteVtk.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(ReadNCDF.o): In function `__static_initialization_and_destruction_0':
../../.libs/libMOAB.a(ReadNCDF.o): In function `ReadNCDF::tokenize(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >&, char const*)':
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:2150: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::find_first_not_of(char const*, unsigned int) const'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:2151: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::find_first_of(char const*, unsigned int) const'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:2153: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::substr(unsigned int, unsigned int) const'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:2153: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:2154: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::find_first_not_of(char const*, unsigned int) const'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:2155: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::find_first_of(char const*, unsigned int) const'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:2157: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::size() const'
../../.libs/libMOAB.a(ReadNCDF.o): In function `~ReadNCDF':
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:173: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:173: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:173: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:176: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:177: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:177: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(ReadNCDF.o): In function `ReadNCDF::create_ss_elements(int*, int*, int, int, std::vector<unsigned int, std::allocator<unsigned int> >&, std::vector<unsigned int, std::allocator<unsigned int> >&, std::vector<double, std::allocator<double> >&, int)':
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1460: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1460: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(ReadNCDF.o): In function `ReadNCDF':
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:68: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:74: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:74: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:74: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:74: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:148: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadNCDF.o): In function `ReadNCDF::factory(MBInterface*)':
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:65: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:65: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(ReadNCDF.o): In function `ReadNCDF::read_global_ids()':
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:992: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:997: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1003: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1020: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1027: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1035: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1036: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1046: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1057: undefined reference to `operator delete[](void*)'
../../.libs/libMOAB.a(ReadNCDF.o): In function `ReadNCDF::read_elements()':
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:863: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:863: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:896: undefined reference to `operator delete[](void*)'
../../.libs/libMOAB.a(ReadNCDF.o): In function `ReadNCDF::read_qa_information(std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >&)':
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1888: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1888: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1899: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1899: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1899: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1899: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(ReadNCDF.o): In function `ReadNCDF::read_qa_records()':
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1863: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::end()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1863: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::begin()'
../../.libs/libMOAB.a(ReadNCDF.o): In function `ReadNCDF::read_sidesets()':
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1303: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1303: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(ReadNCDF.o): In function `ReadNCDF::read_nodesets()':
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1095: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1095: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(ReadNCDF.o): In function `ReadNCDF::read_block_headers(int const*, int)':
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:714: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:714: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(ReadNCDF.o): In function `ReadNCDF::read_exodus_header(char const*)':
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:533: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:533: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:576: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:581: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:583: undefined reference to `operator delete[](void*)'
../../.libs/libMOAB.a(ReadNCDF.o): In function `ReadNCDF::check_file_status(std::basic_string<char, std::char_traits<char>, std::allocator<char> >&, bool&)':
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:206: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::empty() const'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:214: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::empty() const'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:215: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(char const*)'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:224: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::empty() const'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:229: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:417: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
../../.libs/libMOAB.a(ReadNCDF.o): In function `ReadNCDF::update(char const*, FileOptions const&)':
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1957: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1969: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::empty() const'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1971: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1974: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1974: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1974: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1975: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::empty() const'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1983: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1988: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::empty() const'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1989: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1993: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::empty() const'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:1994: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:2000: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:2000: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:2000: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:2143: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadNCDF.o): In function `ReadNCDF::load_file(char const*, unsigned int&, FileOptions const&, char const*, int const*, int)':
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:453: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:455: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::empty() const'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:461: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:461: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:461: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:462: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/ReadNCDF.cpp:519: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadNCDF.o): In function `__gnu_cxx::new_allocator<std::vector<double, std::allocator<double> > >::deallocate(std::vector<double, std::allocator<double> >*, unsigned int)':
../../.libs/libMOAB.a(ReadNCDF.o): In function `__gnu_cxx::new_allocator<ReadBlockData>::deallocate(ReadBlockData*, unsigned int)':
../../.libs/libMOAB.a(ReadNCDF.o): In function `std::vector<ReadBlockData, std::allocator<ReadBlockData> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(ReadNCDF.o): In function `__gnu_cxx::new_allocator<std::vector<double, std::allocator<double> > >::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(ReadNCDF.o): In function `__gnu_cxx::new_allocator<ReadBlockData>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(ReadNCDF.o): In function `void std::__uninitialized_fill_n<false>::uninitialized_fill_n<std::vector<double, std::allocator<double> >*, unsigned int, std::vector<double, std::allocator<double> > >(std::vector<double, std::allocator<double> >*, unsigned int, std::vector<double, std::allocator<double> > const&)':
/usr/include/c++/4.3/bits/stl_uninitialized.h:194: undefined reference to `__cxa_begin_catch'
/usr/include/c++/4.3/bits/stl_uninitialized.h:197: undefined reference to `__cxa_rethrow'
/usr/include/c++/4.3/bits/stl_uninitialized.h:194: undefined reference to `__cxa_end_catch'
../../.libs/libMOAB.a(ReadNCDF.o): In function `std::vector<double, std::allocator<double> >::reserve(unsigned int)':
../../.libs/libMOAB.a(ReadNCDF.o):(.rodata._ZTI8ReadNCDF[typeinfo for ReadNCDF]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(ReadNCDF.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(WriteNCDF.o): In function `~WriteNCDF':
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:116: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:116: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:116: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:122: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:123: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:123: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteNCDF.o): In function `__static_initialization_and_destruction_0':
../../.libs/libMOAB.a(WriteNCDF.o): In function `WriteNCDF::open_file(char const*)':
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:1871: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:1871: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteNCDF.o): In function `WriteNCDF::write_BCs(std::vector<NeumannSetData, std::allocator<NeumannSetData> >&, std::vector<DirichletSetData, std::allocator<DirichletSetData> >&)':
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:1168: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:1169: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:1248: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:1249: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:1270: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:1271: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:1372: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:1373: undefined reference to `operator delete[](void*)'
../../.libs/libMOAB.a(WriteNCDF.o): In function `WriteNCDF::write_element_order_map(int)':
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:1063: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:1081: undefined reference to `operator delete[](void*)'
../../.libs/libMOAB.a(WriteNCDF.o): In function `WriteNCDF::write_global_element_order_map(int)':
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:1024: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:1046: undefined reference to `operator delete[](void*)'
../../.libs/libMOAB.a(WriteNCDF.o): In function `WriteNCDF::write_global_node_order_map(int, MBRange&)':
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:984: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:1009: undefined reference to `operator delete[](void*)'
../../.libs/libMOAB.a(WriteNCDF.o): In function `WriteNCDF::write_elementblocks(std::vector<MaterialSetData, std::allocator<MaterialSetData> >&)':
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:937: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:944: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:963: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:967: undefined reference to `operator delete[](void*)'
../../.libs/libMOAB.a(WriteNCDF.o): In function `WriteNCDF':
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:57: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:62: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:62: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:62: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:62: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:112: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(WriteNCDF.o): In function `WriteNCDF::factory(MBInterface*)':
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:54: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:54: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteNCDF.o): In function `WriteNCDF::write_nodes(int, MBRange&, int)':
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:788: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:789: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:793: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:798: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:799: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:800: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:854: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:855: undefined reference to `operator delete[](void*)'
../../.libs/libMOAB.a(WriteNCDF.o):/home/jason/moab/test/x86/../src/WriteNCDF.cpp:856: more undefined references to `operator delete[](void*)' follow
../../.libs/libMOAB.a(WriteNCDF.o): In function `WriteNCDF::write_qa_records(std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >&)':
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:715: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
../../.libs/libMOAB.a(WriteNCDF.o): In function `WriteNCDF::gather_mesh_information(WriteNCDF::ExodusMeshInfo&, std::vector<MaterialSetData, std::allocator<MaterialSetData> >&, std::vector<NeumannSetData, std::allocator<NeumannSetData> >&, std::vector<DirichletSetData, std::allocator<DirichletSetData> >&, std::vector<unsigned int, std::allocator<unsigned int> >&, std::vector<unsigned int, std::allocator<unsigned int> >&, std::vector<unsigned int, std::allocator<unsigned int> >&)':
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:467: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:467: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:467: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:467: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(WriteNCDF.o): In function `WriteNCDF::write_header(WriteNCDF::ExodusMeshInfo&, std::vector<MaterialSetData, std::allocator<MaterialSetData> >&, std::vector<NeumannSetData, std::allocator<NeumannSetData> >&, std::vector<DirichletSetData, std::allocator<DirichletSetData> >&, char const*)':
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:875: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:875: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:875: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:876: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::append(char const*)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:877: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::append(char const*)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:878: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::append(char const*)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:879: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::append(char const*)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:880: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::append(char const*)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:881: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::append(char const*)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:883: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::length() const'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:884: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::resize(unsigned int)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:890: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:895: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(WriteNCDF.o): In function `WriteNCDF::write_file(char const*, bool, FileOptions const&, unsigned int const*, int, std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, void** const*, int, int)':
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:233: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:233: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:233: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:233: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:234: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:234: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:234: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:234: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:237: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:237: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:237: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:237: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:238: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:238: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:238: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:238: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:258: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/WriteNCDF.cpp:258: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteNCDF.o): In function `__gnu_cxx::new_allocator<MaterialSetData>::deallocate(MaterialSetData*, unsigned int)':
../../.libs/libMOAB.a(WriteNCDF.o): In function `__gnu_cxx::new_allocator<DirichletSetData>::deallocate(DirichletSetData*, unsigned int)':
../../.libs/libMOAB.a(WriteNCDF.o): In function `__gnu_cxx::new_allocator<NeumannSetData>::deallocate(NeumannSetData*, unsigned int)':
../../.libs/libMOAB.a(WriteNCDF.o): In function `__gnu_cxx::new_allocator<MaterialSetData>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(WriteNCDF.o): In function `__gnu_cxx::new_allocator<DirichletSetData>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(WriteNCDF.o): In function `__gnu_cxx::new_allocator<NeumannSetData>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(WriteNCDF.o): In function `MaterialSetData* std::__uninitialized_copy<false>::uninitialized_copy<MaterialSetData*, MaterialSetData*>(MaterialSetData*, MaterialSetData*, MaterialSetData*)':
/usr/include/c++/4.3/bits/stl_uninitialized.h:83: undefined reference to `__cxa_begin_catch'
/usr/include/c++/4.3/bits/stl_uninitialized.h:86: undefined reference to `__cxa_rethrow'
/usr/include/c++/4.3/bits/stl_uninitialized.h:83: undefined reference to `__cxa_end_catch'
../../.libs/libMOAB.a(WriteNCDF.o): In function `DirichletSetData* std::__uninitialized_copy<false>::uninitialized_copy<DirichletSetData*, DirichletSetData*>(DirichletSetData*, DirichletSetData*, DirichletSetData*)':
../../.libs/libMOAB.a(WriteNCDF.o): In function `NeumannSetData* std::__uninitialized_copy<false>::uninitialized_copy<NeumannSetData*, NeumannSetData*>(NeumannSetData*, NeumannSetData*, NeumannSetData*)':
../../.libs/libMOAB.a(WriteNCDF.o): In function `std::vector<MaterialSetData, std::allocator<MaterialSetData> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(WriteNCDF.o): In function `std::vector<DirichletSetData, std::allocator<DirichletSetData> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(WriteNCDF.o): In function `std::vector<DirichletSetData, std::allocator<DirichletSetData> >::_M_insert_aux(__gnu_cxx::__normal_iterator<DirichletSetData*, std::vector<DirichletSetData, std::allocator<DirichletSetData> > >, DirichletSetData const&)':
/usr/include/c++/4.3/bits/vector.tcc:330: undefined reference to `__cxa_begin_catch'
/usr/include/c++/4.3/bits/vector.tcc:334: undefined reference to `__cxa_rethrow'
/usr/include/c++/4.3/bits/vector.tcc:330: undefined reference to `__cxa_end_catch'
../../.libs/libMOAB.a(WriteNCDF.o): In function `std::vector<NeumannSetData, std::allocator<NeumannSetData> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(WriteNCDF.o): In function `std::vector<NeumannSetData, std::allocator<NeumannSetData> >::_M_insert_aux(__gnu_cxx::__normal_iterator<NeumannSetData*, std::vector<NeumannSetData, std::allocator<NeumannSetData> > >, NeumannSetData const&)':
../../.libs/libMOAB.a(WriteNCDF.o): In function `std::vector<MaterialSetData, std::allocator<MaterialSetData> >::_M_insert_aux(__gnu_cxx::__normal_iterator<MaterialSetData*, std::vector<MaterialSetData, std::allocator<MaterialSetData> > >, MaterialSetData const&)':
../../.libs/libMOAB.a(WriteNCDF.o):(.rodata._ZTI9WriteNCDF[typeinfo for WriteNCDF]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(WriteNCDF.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(WriteSLAC.o): In function `~WriteSLAC':
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:107: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:107: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:107: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:113: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:114: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:114: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteSLAC.o): In function `__static_initialization_and_destruction_0':
../../.libs/libMOAB.a(WriteSLAC.o): In function `WriteSLAC::reset_matset(std::vector<WriteSLAC::MaterialSetData, std::allocator<WriteSLAC::MaterialSetData> >&)':
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:122: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteSLAC.o): In function `WriteSLAC::open_file(char const*)':
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:1007: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:1007: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteSLAC.o): In function `WriteSLAC::gather_interior_exterior(WriteSLAC::MeshInfo&, std::vector<WriteSLAC::MaterialSetData, std::allocator<WriteSLAC::MaterialSetData> >&, std::vector<WriteSLAC::NeumannSetData, std::allocator<WriteSLAC::NeumannSetData> >&)':
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:653: undefined reference to `std::cout'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:653: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:653: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:653: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(WriteSLAC.o): In function `WriteSLAC::write_nodes(int, MBRange const&, int)':
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:547: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:548: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:552: undefined reference to `operator new[](unsigned int)'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:558: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:559: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:560: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:619: undefined reference to `operator delete[](void*)'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:620: undefined reference to `operator delete[](void*)'
../../.libs/libMOAB.a(WriteSLAC.o):/home/jason/moab/test/x86/../src/WriteSLAC.cpp:622: more undefined references to `operator delete[](void*)' follow
../../.libs/libMOAB.a(WriteSLAC.o): In function `WriteSLAC':
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:56: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:61: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:61: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:61: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:61: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:103: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(WriteSLAC.o): In function `WriteSLAC::factory(MBInterface*)':
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:53: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:53: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteSLAC.o): In function `WriteSLAC::gather_mesh_information(WriteSLAC::MeshInfo&, std::vector<WriteSLAC::MaterialSetData, std::allocator<WriteSLAC::MaterialSetData> >&, std::vector<WriteSLAC::NeumannSetData, std::allocator<WriteSLAC::NeumannSetData> >&, std::vector<WriteSLAC::DirichletSetData, std::allocator<WriteSLAC::DirichletSetData> >&, std::vector<unsigned int, std::allocator<unsigned int> >&, std::vector<unsigned int, std::allocator<unsigned int> >&, std::vector<unsigned int, std::allocator<unsigned int> >&)':
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:256: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(WriteSLAC.o): In function `WriteSLAC::write_file(char const*, bool, FileOptions const&, unsigned int const*, int, std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, void** const*, int, int)':
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:146: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(char const*)'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:195: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/WriteSLAC.cpp:195: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteSLAC.o): In function `__gnu_cxx::new_allocator<WriteSLAC::MaterialSetData>::deallocate(WriteSLAC::MaterialSetData*, unsigned int)':
/usr/include/c++/4.3/ext/new_allocator.h:98: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteSLAC.o): In function `__gnu_cxx::new_allocator<WriteSLAC::DirichletSetData>::deallocate(WriteSLAC::DirichletSetData*, unsigned int)':
../../.libs/libMOAB.a(WriteSLAC.o): In function `__gnu_cxx::new_allocator<WriteSLAC::NeumannSetData>::deallocate(WriteSLAC::NeumannSetData*, unsigned int)':
../../.libs/libMOAB.a(WriteSLAC.o): In function `std::vector<WriteSLAC::MaterialSetData, std::allocator<WriteSLAC::MaterialSetData> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(WriteSLAC.o): In function `std::vector<WriteSLAC::DirichletSetData, std::allocator<WriteSLAC::DirichletSetData> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(WriteSLAC.o): In function `std::vector<WriteSLAC::NeumannSetData, std::allocator<WriteSLAC::NeumannSetData> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(WriteSLAC.o): In function `__gnu_cxx::new_allocator<WriteSLAC::MaterialSetData>::allocate(unsigned int, void const*)':
/usr/include/c++/4.3/ext/new_allocator.h:90: undefined reference to `std::__throw_bad_alloc()'
/usr/include/c++/4.3/ext/new_allocator.h:92: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(WriteSLAC.o): In function `__gnu_cxx::new_allocator<WriteSLAC::DirichletSetData>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(WriteSLAC.o): In function `__gnu_cxx::new_allocator<WriteSLAC::NeumannSetData>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(WriteSLAC.o): In function `WriteSLAC::NeumannSetData* std::__uninitialized_copy<false>::uninitialized_copy<WriteSLAC::NeumannSetData*, WriteSLAC::NeumannSetData*>(WriteSLAC::NeumannSetData*, WriteSLAC::NeumannSetData*, WriteSLAC::NeumannSetData*)':
../../.libs/libMOAB.a(WriteSLAC.o): In function `std::vector<WriteSLAC::NeumannSetData, std::allocator<WriteSLAC::NeumannSetData> >::_M_insert_aux(__gnu_cxx::__normal_iterator<WriteSLAC::NeumannSetData*, std::vector<WriteSLAC::NeumannSetData, std::allocator<WriteSLAC::NeumannSetData> > >, WriteSLAC::NeumannSetData const&)':
../../.libs/libMOAB.a(WriteSLAC.o): In function `WriteSLAC::DirichletSetData* std::__uninitialized_copy<false>::uninitialized_copy<WriteSLAC::DirichletSetData*, WriteSLAC::DirichletSetData*>(WriteSLAC::DirichletSetData*, WriteSLAC::DirichletSetData*, WriteSLAC::DirichletSetData*)':
../../.libs/libMOAB.a(WriteSLAC.o): In function `std::vector<WriteSLAC::DirichletSetData, std::allocator<WriteSLAC::DirichletSetData> >::_M_insert_aux(__gnu_cxx::__normal_iterator<WriteSLAC::DirichletSetData*, std::vector<WriteSLAC::DirichletSetData, std::allocator<WriteSLAC::DirichletSetData> > >, WriteSLAC::DirichletSetData const&)':
../../.libs/libMOAB.a(WriteSLAC.o):(.rodata._ZTI9WriteSLAC[typeinfo for WriteSLAC]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(WriteSLAC.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(ReadHDF5.o): In function `ReadHDF5::read_qa(unsigned int)':
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:2094: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:2094: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:2097: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(char const*)'
../../.libs/libMOAB.a(ReadHDF5.o): In function `ReadHDF5::read_var_len_tag(void**, int, bool)':
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:1723: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:1741: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:1826: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:1933: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadHDF5.o): In function `ReadHDF5::read_sparse_tag(void**, int, unsigned int, bool)':
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:1595: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:1610: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:1712: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadHDF5.o): In function `ReadHDF5::factory(MBInterface*)':
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:60: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(ReadHDF5.o): In function `ReadHDF5::read_dense_tag(ReadHDF5::ElemSet&, void**, int, unsigned int, bool)':
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:1510: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:1519: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:1585: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadHDF5.o): In function `ReadHDF5::read_dense_tag(void**, int, unsigned int, bool)':
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:1444: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:1452: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:1467: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:1484: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:1499: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadHDF5.o): In function `~ReadHDF5':
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:118: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:118: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:118: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:118: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:120: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(ReadHDF5.o): In function `ReadHDF5::read_tag(char const*)':
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:1185: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:1288: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(char const*)'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:1289: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator+=(char const*)'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:1290: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:1432: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadHDF5.o): In function `ReadHDF5::load_file_impl(unsigned int, bool)':
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:233: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:346: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(ReadHDF5.o): In function `ReadHDF5::init()':
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:94: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:94: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:94: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:94: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(ReadHDF5.o): In function `__gnu_cxx::__enable_if<!(std::__is_scalar<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >::__value), void>::__type std::__fill_a<std::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::basic_string<char, std::char_traits<char>, std::allocator<char> > >(std::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
/usr/include/c++/4.3/bits/stl_algobase.h:686: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
../../.libs/libMOAB.a(ReadHDF5.o): In function `__gnu_cxx::new_allocator<char*>::deallocate(char**, unsigned int)':
../../.libs/libMOAB.a(ReadHDF5.o): In function `__gnu_cxx::new_allocator<std::_List_node<ReadHDF5::ElemSet> >::deallocate(std::_List_node<ReadHDF5::ElemSet>*, unsigned int)':
../../.libs/libMOAB.a(ReadHDF5.o): In function `std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >::_M_fill_insert(__gnu_cxx::__normal_iterator<std::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, unsigned int, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
/usr/include/c++/4.3/bits/vector.tcc:361: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/usr/include/c++/4.3/bits/vector.tcc:388: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/usr/include/c++/4.3/bits/vector.tcc:417: undefined reference to `__cxa_begin_catch'
/usr/include/c++/4.3/bits/vector.tcc:422: undefined reference to `__cxa_rethrow'
/usr/include/c++/4.3/bits/vector.tcc:417: undefined reference to `__cxa_end_catch'
../../.libs/libMOAB.a(ReadHDF5.o): In function `__gnu_cxx::new_allocator<char*>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(ReadHDF5.o): In function `__gnu_cxx::new_allocator<std::_List_node<ReadHDF5::ElemSet> >::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(ReadHDF5.o): In function `auto_array':
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:605: undefined reference to `operator new[](unsigned int)'
../../.libs/libMOAB.a(ReadHDF5.o): In function `~auto_array':
/home/jason/moab/test/x86/../src/ReadHDF5.cpp:607: undefined reference to `operator delete[](void*)'
../../.libs/libMOAB.a(ReadHDF5.o): In function `std::list<ReadHDF5::ElemSet, std::allocator<ReadHDF5::ElemSet> >::_M_create_node(ReadHDF5::ElemSet const&)':
/usr/include/c++/4.3/bits/stl_list.h:465: undefined reference to `__cxa_begin_catch'
/usr/include/c++/4.3/bits/stl_list.h:468: undefined reference to `__cxa_rethrow'
/usr/include/c++/4.3/bits/stl_list.h:465: undefined reference to `__cxa_end_catch'
../../.libs/libMOAB.a(ReadHDF5.o): In function `std::list<ReadHDF5::ElemSet, std::allocator<ReadHDF5::ElemSet> >::_M_insert(std::_List_iterator<ReadHDF5::ElemSet>, ReadHDF5::ElemSet const&)':
/usr/include/c++/4.3/bits/stl_list.h:1342: undefined reference to `std::_List_node_base::hook(std::_List_node_base*)'
../../.libs/libMOAB.a(ReadHDF5.o):(.rodata._ZTI8ReadHDF5[typeinfo for ReadHDF5]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(ReadHDF5.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(WriteHDF5.o): In function `WriteHDF5::init()':
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:295: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:295: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:295: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:295: undefined reference to `std::allocator<char>::~allocator()'
../../.libs/libMOAB.a(WriteHDF5.o): In function `~WriteHDF5':
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:328: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:328: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:328: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:328: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:329: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(WriteHDF5.o): In function `WriteHDF5::get_tag_size(void**, MBDataType&, int&, int&, int&, mhdf_TagDataType&, int&)':
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:2411: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:2448: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(char const*)'
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:2449: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator+=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:2450: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:2482: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(WriteHDF5.o): In function `WriteHDF5::create_tag(void**, unsigned long, unsigned long)':
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:2550: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:2626: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:2637: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:2651: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:2661: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:2669: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(WriteHDF5.o): In function `WriteHDF5::factory(MBInterface*)':
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:256: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(WriteHDF5.o): In function `WriteHDF5::gather_tags(void** const*, int)':
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:2008: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:2093: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(WriteHDF5.o): In function `WriteHDF5::write_qa(std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&)':
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:1938: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
../../.libs/libMOAB.a(WriteHDF5.o): In function `WriteHDF5::write_var_len_tag(WriteHDF5::SparseTag const&)':
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:1752: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:1789: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:1912: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(WriteHDF5.o): In function `WriteHDF5::write_sparse_tag(WriteHDF5::SparseTag const&)':
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:1612: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:1638: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
/home/jason/moab/test/x86/../src/WriteHDF5.cpp:1744: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(WriteHDF5.o): In function `__gnu_cxx::new_allocator<std::_List_node<WriteHDF5::SparseTag> >::deallocate(std::_List_node<WriteHDF5::SparseTag>*, unsigned int)':
../../.libs/libMOAB.a(WriteHDF5.o): In function `__gnu_cxx::new_allocator<char const*>::deallocate(char const**, unsigned int)':
../../.libs/libMOAB.a(WriteHDF5.o): In function `__gnu_cxx::new_allocator<std::_List_node<WriteHDF5::ExportSet> >::deallocate(std::_List_node<WriteHDF5::ExportSet>*, unsigned int)':
../../.libs/libMOAB.a(WriteHDF5.o): In function `__gnu_cxx::new_allocator<RangeMap<unsigned int, unsigned int, 0u>::Range>::deallocate(RangeMap<unsigned int, unsigned int, 0u>::Range*, unsigned int)':
../../.libs/libMOAB.a(WriteHDF5.o): In function `std::vector<RangeMap<unsigned int, unsigned int, 0u>::Range, std::allocator<RangeMap<unsigned int, unsigned int, 0u>::Range> >::_M_check_len(unsigned int, char const*) const':
/usr/include/c++/4.3/bits/stl_vector.h:1078: undefined reference to `std::__throw_length_error(char const*)'
../../.libs/libMOAB.a(WriteHDF5.o): In function `__gnu_cxx::new_allocator<std::_List_node<WriteHDF5::SparseTag> >::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(WriteHDF5.o): In function `__gnu_cxx::new_allocator<char const*>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(WriteHDF5.o): In function `__gnu_cxx::new_allocator<std::_List_node<WriteHDF5::ExportSet> >::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(WriteHDF5.o): In function `__gnu_cxx::new_allocator<RangeMap<unsigned int, unsigned int, 0u>::Range>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(WriteHDF5.o): In function `std::list<WriteHDF5::SparseTag, std::allocator<WriteHDF5::SparseTag> >::_M_create_node(WriteHDF5::SparseTag const&)':
../../.libs/libMOAB.a(WriteHDF5.o): In function `std::list<WriteHDF5::SparseTag, std::allocator<WriteHDF5::SparseTag> >::_M_insert(std::_List_iterator<WriteHDF5::SparseTag>, WriteHDF5::SparseTag const&)':
../../.libs/libMOAB.a(WriteHDF5.o): In function `std::list<WriteHDF5::ExportSet, std::allocator<WriteHDF5::ExportSet> >::_M_create_node(WriteHDF5::ExportSet const&)':
../../.libs/libMOAB.a(WriteHDF5.o): In function `std::list<WriteHDF5::ExportSet, std::allocator<WriteHDF5::ExportSet> >::_M_insert(std::_List_iterator<WriteHDF5::ExportSet>, WriteHDF5::ExportSet const&)':
../../.libs/libMOAB.a(WriteHDF5.o): In function `std::vector<MBRange, std::allocator<MBRange> >::_M_fill_insert(__gnu_cxx::__normal_iterator<MBRange*, std::vector<MBRange, std::allocator<MBRange> > >, unsigned int, MBRange const&)':
../../.libs/libMOAB.a(WriteHDF5.o):(.rodata._ZTI9WriteHDF5[typeinfo for WriteHDF5]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(WriteHDF5.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(AEntityFactory.o): In function `~AEntityFactory':
/home/jason/moab/test/x86/../src/AEntityFactory.cpp:76: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(AEntityFactory.o): In function `AEntityFactory::set_adjacency_ptr(unsigned int, std::vector<unsigned int, std::allocator<unsigned int> >*)':
/home/jason/moab/test/x86/../src/AEntityFactory.cpp:1486: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(AEntityFactory.o): In function `AEntityFactory::get_adjacencies(unsigned int, std::vector<unsigned int, std::allocator<unsigned int> >*&, bool)':
/home/jason/moab/test/x86/../src/AEntityFactory.cpp:572: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/AEntityFactory.cpp:575: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(AEntityFactory.o): In function `__gnu_cxx::new_allocator<std::vector<unsigned int, std::allocator<unsigned int> > >::deallocate(std::vector<unsigned int, std::allocator<unsigned int> >*, unsigned int)':
../../.libs/libMOAB.a(AEntityFactory.o): In function `void std::__uninitialized_fill_n<false>::uninitialized_fill_n<std::vector<unsigned int, std::allocator<unsigned int> >*, unsigned int, std::vector<unsigned int, std::allocator<unsigned int> > >(std::vector<unsigned int, std::allocator<unsigned int> >*, unsigned int, std::vector<unsigned int, std::allocator<unsigned int> > const&)':
../../.libs/libMOAB.a(AEntityFactory.o): In function `__gnu_cxx::new_allocator<std::vector<unsigned int, std::allocator<unsigned int> > >::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(AEntityFactory.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(EntitySequence.o): In function `EntitySequence::~EntitySequence()':
EntitySequence.cpp:(.text._ZN14EntitySequenceD0Ev[EntitySequence::~EntitySequence()]+0x1f): undefined reference to `operator delete(void*)'
EntitySequence.cpp:(.text._ZN14EntitySequenceD1Ev[EntitySequence::~EntitySequence()]+0x1f): undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(EntitySequence.o):(.rodata._ZTV14EntitySequence[vtable for EntitySequence]+0x14): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(EntitySequence.o):(.rodata._ZTV14EntitySequence[vtable for EntitySequence]+0x24): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(EntitySequence.o):(.rodata._ZTV14EntitySequence[vtable for EntitySequence]+0x28): undefined reference to `__cxa_pure_virtual'
../../.libs/libMOAB.a(EntitySequence.o):(.rodata._ZTI14EntitySequence[typeinfo for EntitySequence]+0x0): undefined reference to `vtable for __cxxabiv1::__class_type_info'
../../.libs/libMOAB.a(ExoIIUtil.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(FileOptions.o): In function `FileOptions::get_options(std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >&) const':
/home/jason/moab/test/x86/../src/FileOptions.cpp:280: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
/home/jason/moab/test/x86/../src/FileOptions.cpp:280: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(FileOptions.o): In function `FileOptions::get_option(char const*, std::basic_string<char, std::char_traits<char>, std::allocator<char> >&) const':
/home/jason/moab/test/x86/../src/FileOptions.cpp:216: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(char const*)'
../../.libs/libMOAB.a(FileOptions.o): In function `FileOptions::get_str_option(char const*, std::basic_string<char, std::char_traits<char>, std::allocator<char> >&) const':
/home/jason/moab/test/x86/../src/FileOptions.cpp:205: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(char const*)'
../../.libs/libMOAB.a(FileOptions.o): In function `std::basic_string<char, std::char_traits<char>, std::allocator<char> >* std::__copy_move<false, false, std::random_access_iterator_tag>::__copy_m<char const* const*, std::basic_string<char, std::char_traits<char>, std::allocator<char> >*>(char const* const*, char const* const*, std::basic_string<char, std::char_traits<char>, std::allocator<char> >*)':
/usr/include/c++/4.3/bits/stl_algobase.h:342: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(char const*)'
../../.libs/libMOAB.a(FileOptions.o): In function `std::vector<char const*, std::allocator<char const*> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(FileOptions.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(FileTokenizer.o): In function `FileTokenizer::match_token(char const* const*, bool)':
/home/jason/moab/test/x86/../src/FileTokenizer.cpp:395: undefined reference to `std::allocator<char>::allocator()'
/home/jason/moab/test/x86/../src/FileTokenizer.cpp:395: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
/home/jason/moab/test/x86/../src/FileTokenizer.cpp:395: undefined reference to `std::allocator<char>::~allocator()'
/home/jason/moab/test/x86/../src/FileTokenizer.cpp:398: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator+=(char const*)'
/home/jason/moab/test/x86/../src/FileTokenizer.cpp:399: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator+=(char const*)'
/home/jason/moab/test/x86/../src/FileTokenizer.cpp:402: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator+=(char const*)'
/home/jason/moab/test/x86/../src/FileTokenizer.cpp:403: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator+=(char const*)'
/home/jason/moab/test/x86/../src/FileTokenizer.cpp:405: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator+=(char const*)'
/home/jason/moab/test/x86/../src/FileTokenizer.cpp:406: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator+=(char const*)'
../../.libs/libMOAB.a(FileTokenizer.o):/home/jason/moab/test/x86/../src/FileTokenizer.cpp:407: more undefined references to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator+=(char const*)' follow
/home/jason/moab/test/x86/../src/FileTokenizer.cpp:409: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
../../.libs/libMOAB.a(FileTokenizer.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(GeomTopoTool.o): In function `__static_initialization_and_destruction_0':
/usr/include/c++/4.3/iostream:77: undefined reference to `std::ios_base::Init::Init()'
/usr/include/c++/4.3/iostream:77: undefined reference to `std::ios_base::Init::~Init()'
../../.libs/libMOAB.a(GeomTopoTool.o): In function `GeomTopoTool::construct_vertex_ranges(MBRange const&, void**)':
/home/jason/moab/test/x86/../src/GeomTopoTool.cpp:253: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(GeomTopoTool.o): In function `GeomTopoTool::restore_topology()':
/home/jason/moab/test/x86/../src/GeomTopoTool.cpp:194: undefined reference to `std::cerr'
/home/jason/moab/test/x86/../src/GeomTopoTool.cpp:194: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/home/jason/moab/test/x86/../src/GeomTopoTool.cpp:194: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
/home/jason/moab/test/x86/../src/GeomTopoTool.cpp:194: undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))'
../../.libs/libMOAB.a(GeomTopoTool.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(HigherOrderFactory.o): In function `HigherOrderFactory::convert_sequence(ElementSequence*, unsigned int, unsigned int, bool, bool, bool)':
/home/jason/moab/test/x86/../src/HigherOrderFactory.cpp:179: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/HigherOrderFactory.cpp:179: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(HigherOrderFactory.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(MBBits.o): In function `MBBitServer::reset_data()':
/home/jason/moab/test/x86/../src/MBBits.cpp:111: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/MBBits.cpp:112: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(MBBits.o): In function `MBBitServer::release_tag_id(unsigned long)':
/home/jason/moab/test/x86/../src/MBBits.cpp:81: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(MBBits.o): In function `MBBitServer::reserve_tag_id(int, unsigned long)':
/home/jason/moab/test/x86/../src/MBBits.cpp:60: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(MBBits.o): In function `std::vector<MBBitPageGroup*, std::allocator<MBBitPageGroup*> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(MBBits.o): In function `__gnu_cxx::new_allocator<MBBitPageGroup*>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(MBBits.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(MBCN.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(MBSysUtil.o): In function `MBSysUtil::filesize(std::basic_ifstream<char, std::char_traits<char> >&)':
/home/jason/moab/test/x86/../src/MBSysUtil.cpp:61: undefined reference to `std::basic_istream<char, std::char_traits<char> >::tellg()'
/home/jason/moab/test/x86/../src/MBSysUtil.cpp:62: undefined reference to `std::basic_istream<char, std::char_traits<char> >::seekg(long long, std::_Ios_Seekdir)'
/home/jason/moab/test/x86/../src/MBSysUtil.cpp:62: undefined reference to `std::basic_ios<char, std::char_traits<char> >::operator!() const'
/home/jason/moab/test/x86/../src/MBSysUtil.cpp:65: undefined reference to `std::basic_istream<char, std::char_traits<char> >::tellg()'
/home/jason/moab/test/x86/../src/MBSysUtil.cpp:66: undefined reference to `std::basic_istream<char, std::char_traits<char> >::seekg(long long, std::_Ios_Seekdir)'
/home/jason/moab/test/x86/../src/MBSysUtil.cpp:66: undefined reference to `std::basic_ios<char, std::char_traits<char> >::operator!() const'
../../.libs/libMOAB.a(MBSysUtil.o):(.eh_frame+0x11): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(MeshTopoUtil.o): In function `__gnu_cxx::new_allocator<unsigned long>::deallocate(unsigned long*, unsigned int)':
MeshTopoUtil.cpp:(.text._ZN9__gnu_cxx13new_allocatorImE10deallocateEPmj[__gnu_cxx::new_allocator<unsigned long>::deallocate(unsigned long*, unsigned int)]+0xd): undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(MeshTopoUtil.o): In function `std::vector<bool, std::allocator<bool> >::_M_check_len(unsigned int, char const*) const':
MeshTopoUtil.cpp:(.text._ZNKSt6vectorIbSaIbEE12_M_check_lenEjPKc[std::vector<bool, std::allocator<bool> >::_M_check_len(unsigned int, char const*) const]+0x36): undefined reference to `std::__throw_length_error(char const*)'
../../.libs/libMOAB.a(MeshTopoUtil.o): In function `std::vector<std::vector<unsigned int, std::allocator<unsigned int> >, std::allocator<std::vector<unsigned int, std::allocator<unsigned int> > > >::_M_check_len(unsigned int, char const*) const':
MeshTopoUtil.cpp:(.text._ZNKSt6vectorIS_IjSaIjEESaIS1_EE12_M_check_lenEjPKc[std::vector<std::vector<unsigned int, std::allocator<unsigned int> >, std::allocator<std::vector<unsigned int, std::allocator<unsigned int> > > >::_M_check_len(unsigned int, char const*) const]+0x36): undefined reference to `std::__throw_length_error(char const*)'
../../.libs/libMOAB.a(MeshTopoUtil.o): In function `std::vector<unsigned int, std::allocator<unsigned int> >* std::__uninitialized_copy<false>::uninitialized_copy<std::vector<unsigned int, std::allocator<unsigned int> >*, std::vector<unsigned int, std::allocator<unsigned int> >*>(std::vector<unsigned int, std::allocator<unsigned int> >*, std::vector<unsigned int, std::allocator<unsigned int> >*, std::vector<unsigned int, std::allocator<unsigned int> >*)':
MeshTopoUtil.cpp:(.text._ZNSt20__uninitialized_copyILb0EE18uninitialized_copyIPSt6vectorIjSaIjEES5_EET0_T_S7_S6_[std::vector<unsigned int, std::allocator<unsigned int> >* std::__uninitialized_copy<false>::uninitialized_copy<std::vector<unsigned int, std::allocator<unsigned int> >*, std::vector<unsigned int, std::allocator<unsigned int> >*>(std::vector<unsigned int, std::allocator<unsigned int> >*, std::vector<unsigned int, std::allocator<unsigned int> >*, std::vector<unsigned int, std::allocator<unsigned int> >*)]+0x74): undefined reference to `__cxa_begin_catch'
MeshTopoUtil.cpp:(.text._ZNSt20__uninitialized_copyILb0EE18uninitialized_copyIPSt6vectorIjSaIjEES5_EET0_T_S7_S6_[std::vector<unsigned int, std::allocator<unsigned int> >* std::__uninitialized_copy<false>::uninitialized_copy<std::vector<unsigned int, std::allocator<unsigned int> >*, std::vector<unsigned int, std::allocator<unsigned int> >*>(std::vector<unsigned int, std::allocator<unsigned int> >*, std::vector<unsigned int, std::allocator<unsigned int> >*, std::vector<unsigned int, std::allocator<unsigned int> >*)]+0x8b): undefined reference to `__cxa_rethrow'
MeshTopoUtil.cpp:(.text._ZNSt20__uninitialized_copyILb0EE18uninitialized_copyIPSt6vectorIjSaIjEES5_EET0_T_S7_S6_[std::vector<unsigned int, std::allocator<unsigned int> >* std::__uninitialized_copy<false>::uninitialized_copy<std::vector<unsigned int, std::allocator<unsigned int> >*, std::vector<unsigned int, std::allocator<unsigned int> >*>(std::vector<unsigned int, std::allocator<unsigned int> >*, std::vector<unsigned int, std::allocator<unsigned int> >*, std::vector<unsigned int, std::allocator<unsigned int> >*)]+0xba): undefined reference to `__cxa_end_catch'
../../.libs/libMOAB.a(MeshTopoUtil.o): In function `__gnu_cxx::new_allocator<unsigned long>::allocate(unsigned int, void const*)':
MeshTopoUtil.cpp:(.text._ZN9__gnu_cxx13new_allocatorImE8allocateEjPKv[__gnu_cxx::new_allocator<unsigned long>::allocate(unsigned int, void const*)]+0x24): undefined reference to `std::__throw_bad_alloc()'
MeshTopoUtil.cpp:(.text._ZN9__gnu_cxx13new_allocatorImE8allocateEjPKv[__gnu_cxx::new_allocator<unsigned long>::allocate(unsigned int, void const*)]+0x32): undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(MeshTopoUtil.o): In function `std::vector<std::vector<unsigned int, std::allocator<unsigned int> >, std::allocator<std::vector<unsigned int, std::allocator<unsigned int> > > >::_M_insert_aux(__gnu_cxx::__normal_iterator<std::vector<unsigned int, std::allocator<unsigned int> >*, std::vector<std::vector<unsigned int, std::allocator<unsigned int> >, std::allocator<std::vector<unsigned int, std::allocator<unsigned int> > > > >, std::vector<unsigned int, std::allocator<unsigned int> > const&)':
MeshTopoUtil.cpp:(.text._ZNSt6vectorIS_IjSaIjEESaIS1_EE13_M_insert_auxEN9__gnu_cxx17__normal_iteratorIPS1_S3_EERKS1_[std::vector<std::vector<unsigned int, std::allocator<unsigned int> >, std::allocator<std::vector<unsigned int, std::allocator<unsigned int> > > >::_M_insert_aux(__gnu_cxx::__normal_iterator<std::vector<unsigned int, std::allocator<unsigned int> >*, std::vector<std::vector<unsigned int, std::allocator<unsigned int> >, std::allocator<std::vector<unsigned int, std::allocator<unsigned int> > > > >, std::vector<unsigned int, std::allocator<unsigned int> > const&)]+0x242): undefined reference to `__cxa_begin_catch'
MeshTopoUtil.cpp:(.text._ZNSt6vectorIS_IjSaIjEESaIS1_EE13_M_insert_auxEN9__gnu_cxx17__normal_iteratorIPS1_S3_EERKS1_[std::vector<std::vector<unsigned int, std::allocator<unsigned int> >, std::allocator<std::vector<unsigned int, std::allocator<unsigned int> > > >::_M_insert_aux(__gnu_cxx::__normal_iterator<std::vector<unsigned int, std::allocator<unsigned int> >*, std::vector<std::vector<unsigned int, std::allocator<unsigned int> >, std::allocator<std::vector<unsigned int, std::allocator<unsigned int> > > > >, std::vector<unsigned int, std::allocator<unsigned int> > const&)]+0x281): undefined reference to `__cxa_rethrow'
MeshTopoUtil.cpp:(.text._ZNSt6vectorIS_IjSaIjEESaIS1_EE13_M_insert_auxEN9__gnu_cxx17__normal_iteratorIPS1_S3_EERKS1_[std::vector<std::vector<unsigned int, std::allocator<unsigned int> >, std::allocator<std::vector<unsigned int, std::allocator<unsigned int> > > >::_M_insert_aux(__gnu_cxx::__normal_iterator<std::vector<unsigned int, std::allocator<unsigned int> >*, std::vector<std::vector<unsigned int, std::allocator<unsigned int> >, std::allocator<std::vector<unsigned int, std::allocator<unsigned int> > > > >, std::vector<unsigned int, std::allocator<unsigned int> > const&)]+0x292): undefined reference to `__cxa_end_catch'
../../.libs/libMOAB.a(MeshTopoUtil.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(PolyElementSeq.o): In function `PolyElementSeq::split(unsigned int)':
/home/jason/moab/test/x86/../src/PolyElementSeq.cpp:6: undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(PolyElementSeq.o): In function `~PolyElementSeq':
/home/jason/moab/test/x86/../src/PolyElementSeq.cpp:3: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(PolyElementSeq.o):(.rodata._ZTI14PolyElementSeq[typeinfo for PolyElementSeq]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(PolyElementSeq.o):(.eh_frame+0x11): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(ScdElementData.o): In function `~ScdElementData':
/home/jason/moab/test/x86/../src/ScdElementData.cpp:64: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(ScdElementData.o):(.rodata._ZTI14ScdElementData[typeinfo for ScdElementData]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(ScdElementData.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(ScdVertexData.o): In function `ScdVertexData::~ScdVertexData()':
ScdVertexData.cpp:(.text._ZN13ScdVertexDataD0Ev[ScdVertexData::~ScdVertexData()]+0x2a): undefined reference to `operator delete(void*)'
ScdVertexData.cpp:(.text._ZN13ScdVertexDataD1Ev[ScdVertexData::~ScdVertexData()]+0x2a): undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(ScdVertexData.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(SparseTagSuperCollection.o): In function `SparseTagSuperCollection::release_tag_id(unsigned long)':
/home/jason/moab/test/x86/../src/SparseTagSuperCollection.cpp:83: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(SparseTagSuperCollection.o): In function `~SparseTagSuperCollection':
/home/jason/moab/test/x86/../src/SparseTagSuperCollection.cpp:45: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/SparseTagSuperCollection.cpp:47: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(SparseTagSuperCollection.o):/home/jason/moab/test/x86/../src/SparseTagSuperCollection.cpp:45: more undefined references to `operator delete(void*)' follow
../../.libs/libMOAB.a(SparseTagSuperCollection.o): In function `SparseTagSuperCollection::reserve_tag_id(int, unsigned long)':
/home/jason/moab/test/x86/../src/SparseTagSuperCollection.cpp:74: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SparseTagSuperCollection.cpp:74: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(SparseTagSuperCollection.o): In function `SparseTagSuperCollection::reset_data()':
/home/jason/moab/test/x86/../src/SparseTagSuperCollection.cpp:56: undefined reference to `operator delete(void*)'
/home/jason/moab/test/x86/../src/SparseTagSuperCollection.cpp:57: undefined reference to `operator new(unsigned int)'
/home/jason/moab/test/x86/../src/SparseTagSuperCollection.cpp:57: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(SparseTagSuperCollection.o): In function `std::vector<SparseTagCollection*, std::allocator<SparseTagCollection*> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(SparseTagSuperCollection.o): In function `__gnu_cxx::new_allocator<SparseTagCollection*>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(SparseTagSuperCollection.o): In function `__gnu_cxx::new_allocator<SparseTagCollection*>::deallocate(SparseTagCollection**, unsigned int)':
../../.libs/libMOAB.a(SparseTagSuperCollection.o):(.rodata._ZTI24SparseTagSuperCollection[typeinfo for SparseTagSuperCollection]+0x0): undefined reference to `vtable for __cxxabiv1::__class_type_info'
../../.libs/libMOAB.a(SparseTagSuperCollection.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(SparseTagCollection.o): In function `__gnu_cxx::new_allocator<std::tr1::__detail::_Hash_node<std::pair<unsigned int const, void*>, false> >::deallocate(std::tr1::__detail::_Hash_node<std::pair<unsigned int const, void*>, false>*, unsigned int)':
SparseTagCollection.cpp:(.text._ZN9__gnu_cxx13new_allocatorINSt3tr18__detail10_Hash_nodeISt4pairIKjPvELb0EEEE10deallocateEPS8_j[__gnu_cxx::new_allocator<std::tr1::__detail::_Hash_node<std::pair<unsigned int const, void*>, false> >::deallocate(std::tr1::__detail::_Hash_node<std::pair<unsigned int const, void*>, false>*, unsigned int)]+0xd): undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(SparseTagCollection.o): In function `__gnu_cxx::new_allocator<std::tr1::__detail::_Hash_node<std::pair<unsigned int const, void*>, false>*>::deallocate(std::tr1::__detail::_Hash_node<std::pair<unsigned int const, void*>, false>**, unsigned int)':
SparseTagCollection.cpp:(.text._ZN9__gnu_cxx13new_allocatorIPNSt3tr18__detail10_Hash_nodeISt4pairIKjPvELb0EEEE10deallocateEPS9_j[__gnu_cxx::new_allocator<std::tr1::__detail::_Hash_node<std::pair<unsigned int const, void*>, false>*>::deallocate(std::tr1::__detail::_Hash_node<std::pair<unsigned int const, void*>, false>**, unsigned int)]+0xd): undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(SparseTagCollection.o): In function `std::tr1::__detail::_Prime_rehash_policy::_M_need_rehash(unsigned int, unsigned int, unsigned int) const':
SparseTagCollection.cpp:(.text._ZNKSt3tr18__detail20_Prime_rehash_policy14_M_need_rehashEjjj[std::tr1::__detail::_Prime_rehash_policy::_M_need_rehash(unsigned int, unsigned int, unsigned int) const]+0xa8): undefined reference to `std::tr1::__detail::__prime_list'
SparseTagCollection.cpp:(.text._ZNKSt3tr18__detail20_Prime_rehash_policy14_M_need_rehashEjjj[std::tr1::__detail::_Prime_rehash_policy::_M_need_rehash(unsigned int, unsigned int, unsigned int) const]+0xaf): undefined reference to `std::tr1::__detail::__prime_list'
../../.libs/libMOAB.a(SparseTagCollection.o): In function `std::tr1::__detail::_Prime_rehash_policy::_M_next_bkt(unsigned int) const':
SparseTagCollection.cpp:(.text._ZNKSt3tr18__detail20_Prime_rehash_policy11_M_next_bktEj[std::tr1::__detail::_Prime_rehash_policy::_M_next_bkt(unsigned int) const]+0x11): undefined reference to `std::tr1::__detail::__prime_list'
SparseTagCollection.cpp:(.text._ZNKSt3tr18__detail20_Prime_rehash_policy11_M_next_bktEj[std::tr1::__detail::_Prime_rehash_policy::_M_next_bkt(unsigned int) const]+0x18): undefined reference to `std::tr1::__detail::__prime_list'
../../.libs/libMOAB.a(SparseTagCollection.o): In function `__gnu_cxx::new_allocator<std::tr1::__detail::_Hash_node<std::pair<unsigned int const, void*>, false> >::allocate(unsigned int, void const*)':
SparseTagCollection.cpp:(.text._ZN9__gnu_cxx13new_allocatorINSt3tr18__detail10_Hash_nodeISt4pairIKjPvELb0EEEE8allocateEjPKv[__gnu_cxx::new_allocator<std::tr1::__detail::_Hash_node<std::pair<unsigned int const, void*>, false> >::allocate(unsigned int, void const*)]+0x24): undefined reference to `std::__throw_bad_alloc()'
SparseTagCollection.cpp:(.text._ZN9__gnu_cxx13new_allocatorINSt3tr18__detail10_Hash_nodeISt4pairIKjPvELb0EEEE8allocateEjPKv[__gnu_cxx::new_allocator<std::tr1::__detail::_Hash_node<std::pair<unsigned int const, void*>, false> >::allocate(unsigned int, void const*)]+0x38): undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(SparseTagCollection.o): In function `__gnu_cxx::new_allocator<std::tr1::__detail::_Hash_node<std::pair<unsigned int const, void*>, false>*>::allocate(unsigned int, void const*)':
SparseTagCollection.cpp:(.text._ZN9__gnu_cxx13new_allocatorIPNSt3tr18__detail10_Hash_nodeISt4pairIKjPvELb0EEEE8allocateEjPKv[__gnu_cxx::new_allocator<std::tr1::__detail::_Hash_node<std::pair<unsigned int const, void*>, false>*>::allocate(unsigned int, void const*)]+0x24): undefined reference to `std::__throw_bad_alloc()'
SparseTagCollection.cpp:(.text._ZN9__gnu_cxx13new_allocatorIPNSt3tr18__detail10_Hash_nodeISt4pairIKjPvELb0EEEE8allocateEjPKv[__gnu_cxx::new_allocator<std::tr1::__detail::_Hash_node<std::pair<unsigned int const, void*>, false>*>::allocate(unsigned int, void const*)]+0x32): undefined reference to `operator new(unsigned int)'
../../.libs/libMOAB.a(SparseTagCollection.o): In function `std::tr1::_Hashtable<unsigned int, std::pair<unsigned int const, void*>, std::allocator<std::pair<unsigned int const, void*> >, std::_Select1st<std::pair<unsigned int const, void*> >, std::equal_to<unsigned int>, std::tr1::hash<unsigned int>, std::tr1::__detail::_Mod_range_hashing, std::tr1::__detail::_Default_ranged_hash, std::tr1::__detail::_Prime_rehash_policy, false, false, true>::_M_insert_bucket(std::pair<unsigned int const, void*> const&, unsigned int, unsigned int)':
SparseTagCollection.cpp:(.text._ZNSt3tr110_HashtableIjSt4pairIKjPvESaIS4_ESt10_Select1stIS4_ESt8equal_toIjENS_4hashIjEENS_8__detail18_Mod_range_hashingENSC_20_Default_ranged_hashENSC_20_Prime_rehash_policyELb0ELb0ELb1EE16_M_insert_bucketERKS4_jj[std::tr1::_Hashtable<unsigned int, std::pair<unsigned int const, void*>, std::allocator<std::pair<unsigned int const, void*> >, std::_Select1st<std::pair<unsigned int const, void*> >, std::equal_to<unsigned int>, std::tr1::hash<unsigned int>, std::tr1::__detail::_Mod_range_hashing, std::tr1::__detail::_Default_ranged_hash, std::tr1::__detail::_Prime_rehash_policy, false, false, true>::_M_insert_bucket(std::pair<unsigned int const, void*> const&, unsigned int, unsigned int)]+0x133): undefined reference to `__cxa_begin_catch'
SparseTagCollection.cpp:(.text._ZNSt3tr110_HashtableIjSt4pairIKjPvESaIS4_ESt10_Select1stIS4_ESt8equal_toIjENS_4hashIjEENS_8__detail18_Mod_range_hashingENSC_20_Default_ranged_hashENSC_20_Prime_rehash_policyELb0ELb0ELb1EE16_M_insert_bucketERKS4_jj[std::tr1::_Hashtable<unsigned int, std::pair<unsigned int const, void*>, std::allocator<std::pair<unsigned int const, void*> >, std::_Select1st<std::pair<unsigned int const, void*> >, std::equal_to<unsigned int>, std::tr1::hash<unsigned int>, std::tr1::__detail::_Mod_range_hashing, std::tr1::__detail::_Default_ranged_hash, std::tr1::__detail::_Prime_rehash_policy, false, false, true>::_M_insert_bucket(std::pair<unsigned int const, void*> const&, unsigned int, unsigned int)]+0x14a): undefined reference to `__cxa_rethrow'
SparseTagCollection.cpp:(.text._ZNSt3tr110_HashtableIjSt4pairIKjPvESaIS4_ESt10_Select1stIS4_ESt8equal_toIjENS_4hashIjEENS_8__detail18_Mod_range_hashingENSC_20_Default_ranged_hashENSC_20_Prime_rehash_policyELb0ELb0ELb1EE16_M_insert_bucketERKS4_jj[std::tr1::_Hashtable<unsigned int, std::pair<unsigned int const, void*>, std::allocator<std::pair<unsigned int const, void*> >, std::_Select1st<std::pair<unsigned int const, void*> >, std::equal_to<unsigned int>, std::tr1::hash<unsigned int>, std::tr1::__detail::_Mod_range_hashing, std::tr1::__detail::_Default_ranged_hash, std::tr1::__detail::_Prime_rehash_policy, false, false, true>::_M_insert_bucket(std::pair<unsigned int const, void*> const&, unsigned int, unsigned int)]+0x15b): undefined reference to `__cxa_end_catch'
../../.libs/libMOAB.a(SparseTagCollection.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(SweptElementData.o): In function `~SweptElementData':
/home/jason/moab/test/x86/../src/SweptElementData.cpp:65: undefined reference to `operator delete(void*)'
../../.libs/libMOAB.a(SweptElementData.o): In function `__gnu_cxx::new_allocator<SweptElementData::VertexDataRef>::deallocate(SweptElementData::VertexDataRef*, unsigned int)':
../../.libs/libMOAB.a(SweptElementData.o): In function `std::vector<SweptElementData::VertexDataRef, std::allocator<SweptElementData::VertexDataRef> >::_M_check_len(unsigned int, char const*) const':
../../.libs/libMOAB.a(SweptElementData.o): In function `__gnu_cxx::new_allocator<SweptElementData::VertexDataRef>::allocate(unsigned int, void const*)':
../../.libs/libMOAB.a(SweptElementData.o):(.rodata._ZTI16SweptElementData[typeinfo for SweptElementData]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../../.libs/libMOAB.a(SweptElementData.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
../../.libs/libMOAB.a(TagInfo.o): In function `TagInfo::invalidate()':
/home/jason/moab/test/x86/../src/TagInfo.cpp:18: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::clear()'
../../.libs/libMOAB.a(TagInfo.o): In function `TagInfo::operator=(TagInfo const&)':
/home/jason/moab/test/x86/../src/TagInfo.cpp:75: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator=(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
../../.libs/libMOAB.a(TagInfo.o): In function `TagInfo':
/home/jason/moab/test/x86/../src/TagInfo.cpp:35: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
../../.libs/libMOAB.a(TagInfo.o):(.eh_frame+0x11): undefined reference to `__gxx_personality_v0'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `__static_initialization_and_destruction_0(int, int)':
netcdf.cpp:(.text+0x48d): undefined reference to `std::ios_base::Init::Init()'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `__tcf_0':
netcdf.cpp:(.text+0x4d6): undefined reference to `std::ios_base::Init::~Init()'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcError::~NcError()':
netcdf.cpp:(.text+0x512): undefined reference to `operator delete(void*)'
netcdf.cpp:(.text+0x54e): undefined reference to `operator delete(void*)'
netcdf.cpp:(.text+0x58a): undefined reference to `operator delete(void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcAtt::~NcAtt()':
netcdf.cpp:(.text+0x7ba): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x7ce): undefined reference to `operator delete(void*)'
netcdf.cpp:(.text+0x7f8): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x80c): undefined reference to `operator delete(void*)'
netcdf.cpp:(.text+0x836): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x84a): undefined reference to `operator delete(void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcVar::~NcVar()':
netcdf.cpp:(.text+0x874): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x88c): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x8a4): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x8b8): undefined reference to `operator delete(void*)'
netcdf.cpp:(.text+0x8e2): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x8fa): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x912): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x926): undefined reference to `operator delete(void*)'
netcdf.cpp:(.text+0x950): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x968): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x980): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x994): undefined reference to `operator delete(void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcDim::~NcDim()':
netcdf.cpp:(.text+0x9be): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x9d2): undefined reference to `operator delete(void*)'
netcdf.cpp:(.text+0x9fc): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0xa10): undefined reference to `operator delete(void*)'
netcdf.cpp:(.text+0xa3a): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0xa4e): undefined reference to `operator delete(void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcVar::init_cur()':
netcdf.cpp:(.text+0xa62): undefined reference to `operator new[](unsigned int)'
netcdf.cpp:(.text+0xa76): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcAtt::NcAtt(NcFile*, char const*)':
netcdf.cpp:(.text+0xb11): undefined reference to `operator new[](unsigned int)'
netcdf.cpp:(.text+0xb85): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcAtt::NcAtt(NcFile*, NcVar const*, char const*)':
netcdf.cpp:(.text+0xbf8): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o):netcdf.cpp:(.text+0xc6c): more undefined references to `operator new[](unsigned int)' follow
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcVar::sync()':
netcdf.cpp:(.text+0xee5): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0xf07): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0xf29): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0xfcc): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcVar::get_att(char const*) const':
netcdf.cpp:(.text+0x10ef): undefined reference to `operator new(unsigned int)'
netcdf.cpp:(.text+0x1149): undefined reference to `operator delete(void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcTypedComponent::get_space(long) const':
netcdf.cpp:(.text+0x121d): undefined reference to `operator new(unsigned int)'
netcdf.cpp:(.text+0x124e): undefined reference to `operator delete(void*)'
netcdf.cpp:(.text+0x1268): undefined reference to `operator new(unsigned int)'
netcdf.cpp:(.text+0x1299): undefined reference to `operator delete(void*)'
netcdf.cpp:(.text+0x12b3): undefined reference to `operator new(unsigned int)'
netcdf.cpp:(.text+0x12e4): undefined reference to `operator delete(void*)'
netcdf.cpp:(.text+0x12fe): undefined reference to `operator new(unsigned int)'
netcdf.cpp:(.text+0x132c): undefined reference to `operator delete(void*)'
netcdf.cpp:(.text+0x1346): undefined reference to `operator new(unsigned int)'
netcdf.cpp:(.text+0x1374): undefined reference to `operator delete(void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcDim::NcDim(NcFile*, char const*, long)':
netcdf.cpp:(.text+0x1409): undefined reference to `operator new[](unsigned int)'
netcdf.cpp:(.text+0x14af): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcDim::NcDim(NcFile*, int)':
netcdf.cpp:(.text+0x1590): undefined reference to `operator new[](unsigned int)'
netcdf.cpp:(.text+0x1678): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcDim::sync()':
netcdf.cpp:(.text+0x16db): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x1766): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcVar::attname(int) const':
netcdf.cpp:(.text+0x1a1d): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcVar::get_att(int) const':
netcdf.cpp:(.text+0x1b44): undefined reference to `operator delete[](void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcVar::edges() const':
netcdf.cpp:(.text+0x225d): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcVar::rec_size(NcDim*)':
netcdf.cpp:(.text+0x2330): undefined reference to `operator delete[](void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcVar::get_rec(NcDim*, long)':
netcdf.cpp:(.text+0x2399): undefined reference to `operator new[](unsigned int)'
netcdf.cpp:(.text+0x23fb): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x24b2): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x24c3): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x24f5): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x2506): undefined reference to `operator delete[](void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcFile::NcFile(char const*, NcFile::FileMode, unsigned int*, unsigned int, NcFile::FileFormat)':
netcdf.cpp:(.text+0x278e): undefined reference to `operator new[](unsigned int)'
netcdf.cpp:(.text+0x27a2): undefined reference to `operator new[](unsigned int)'
netcdf.cpp:(.text+0x27d0): undefined reference to `operator new(unsigned int)'
netcdf.cpp:(.text+0x280a): undefined reference to `operator delete(void*)'
netcdf.cpp:(.text+0x284d): undefined reference to `operator new(unsigned int)'
netcdf.cpp:(.text+0x2887): undefined reference to `operator delete(void*)'
netcdf.cpp:(.text+0x28b0): undefined reference to `operator new(unsigned int)'
netcdf.cpp:(.text+0x28e9): undefined reference to `operator delete(void*)'
netcdf.cpp:(.text+0x2aca): undefined reference to `operator new[](unsigned int)'
netcdf.cpp:(.text+0x2ade): undefined reference to `operator new[](unsigned int)'
netcdf.cpp:(.text+0x2b0c): undefined reference to `operator new(unsigned int)'
netcdf.cpp:(.text+0x2b46): undefined reference to `operator delete(void*)'
netcdf.cpp:(.text+0x2b89): undefined reference to `operator new(unsigned int)'
netcdf.cpp:(.text+0x2bc3): undefined reference to `operator delete(void*)'
netcdf.cpp:(.text+0x2bec): undefined reference to `operator new(unsigned int)'
netcdf.cpp:(.text+0x2c25): undefined reference to `operator delete(void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcVar::put_rec(NcDim*, double const*, long)':
netcdf.cpp:(.text+0x3ca9): undefined reference to `operator new[](unsigned int)'
netcdf.cpp:(.text+0x3d05): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x3d5e): undefined reference to `operator delete[](void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcVar::put_rec(NcDim*, float const*, long)':
netcdf.cpp:(.text+0x3f5b): undefined reference to `operator new[](unsigned int)'
netcdf.cpp:(.text+0x3fb7): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x4010): undefined reference to `operator delete[](void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcVar::put_rec(NcDim*, long const*, long)':
netcdf.cpp:(.text+0x420d): undefined reference to `operator new[](unsigned int)'
netcdf.cpp:(.text+0x4269): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x42c2): undefined reference to `operator delete[](void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcVar::put_rec(NcDim*, int const*, long)':
netcdf.cpp:(.text+0x44bf): undefined reference to `operator new[](unsigned int)'
netcdf.cpp:(.text+0x451b): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x4574): undefined reference to `operator delete[](void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcVar::put_rec(NcDim*, short const*, long)':
netcdf.cpp:(.text+0x4771): undefined reference to `operator new[](unsigned int)'
netcdf.cpp:(.text+0x47cd): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x4826): undefined reference to `operator delete[](void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcVar::put_rec(NcDim*, char const*, long)':
netcdf.cpp:(.text+0x4a23): undefined reference to `operator new[](unsigned int)'
netcdf.cpp:(.text+0x4a7f): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x4ad8): undefined reference to `operator delete[](void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcVar::put_rec(NcDim*, unsigned char const*, long)':
netcdf.cpp:(.text+0x4cd5): undefined reference to `operator new[](unsigned int)'
netcdf.cpp:(.text+0x4d31): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x4d8a): undefined reference to `operator delete[](void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcVar::rename(char const*)':
netcdf.cpp:(.text+0x63ab): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x63cf): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcDim::rename(char const*)':
netcdf.cpp:(.text+0x6f8b): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x6faf): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcFile::add_dim(char const*, long)':
netcdf.cpp:(.text+0x7036): undefined reference to `operator new(unsigned int)'
netcdf.cpp:(.text+0x708b): undefined reference to `operator delete(void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcFile::close()':
netcdf.cpp:(.text+0x71e1): undefined reference to `operator delete[](void*)'
netcdf.cpp:(.text+0x71f9): undefined reference to `operator delete[](void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcFile::~NcFile()':
netcdf.cpp:(.text+0x7279): undefined reference to `operator delete(void*)'
netcdf.cpp:(.text+0x72ab): undefined reference to `operator delete(void*)'
netcdf.cpp:(.text+0x72dd): undefined reference to `operator delete(void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcFile::sync()':
netcdf.cpp:(.text+0x7391): undefined reference to `operator new(unsigned int)'
netcdf.cpp:(.text+0x73c8): undefined reference to `operator delete(void*)'
netcdf.cpp:(.text+0x746d): undefined reference to `operator new(unsigned int)'
netcdf.cpp:(.text+0x74a4): undefined reference to `operator delete(void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcFile::add_var(char const*, NcType, int, NcDim const**)':
netcdf.cpp:(.text+0x75e7): undefined reference to `operator new[](unsigned int)'
netcdf.cpp:(.text+0x7664): undefined reference to `operator new(unsigned int)'
netcdf.cpp:(.text+0x76af): undefined reference to `operator delete(void*)'
netcdf.cpp:(.text+0x76c8): undefined reference to `operator delete[](void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o): In function `NcFile::add_var(char const*, NcType, NcDim const*, NcDim const*, NcDim const*, NcDim const*, NcDim const*)':
netcdf.cpp:(.text+0x77db): undefined reference to `operator new(unsigned int)'
netcdf.cpp:(.text+0x7826): undefined reference to `operator delete(void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o):(.rodata._ZTV16NcTypedComponent[vtable for NcTypedComponent]+0x8): undefined reference to `__cxa_pure_virtual'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o):(.rodata._ZTV16NcTypedComponent[vtable for NcTypedComponent]+0xc): undefined reference to `__cxa_pure_virtual'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o):(.rodata._ZTV16NcTypedComponent[vtable for NcTypedComponent]+0x10): undefined reference to `__cxa_pure_virtual'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o):(.rodata._ZTV16NcTypedComponent[vtable for NcTypedComponent]+0x14): undefined reference to `__cxa_pure_virtual'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o):(.rodata._ZTV16NcTypedComponent[vtable for NcTypedComponent]+0x18): undefined reference to `__cxa_pure_virtual'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o):(.rodata._ZTV16NcTypedComponent[vtable for NcTypedComponent]+0x1c): more undefined references to `__cxa_pure_virtual' follow
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o):(.rodata._ZTI7NcError[typeinfo for NcError]+0x0): undefined reference to `vtable for __cxxabiv1::__class_type_info'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o):(.rodata._ZTI5NcAtt[typeinfo for NcAtt]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o):(.rodata._ZTI5NcVar[typeinfo for NcVar]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o):(.rodata._ZTI16NcTypedComponent[typeinfo for NcTypedComponent]+0x0): undefined reference to `vtable for __cxxabiv1::__class_type_info'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o):(.rodata._ZTI5NcDim[typeinfo for NcDim]+0x0): undefined reference to `vtable for __cxxabiv1::__class_type_info'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o):(.rodata._ZTI6NcFile[typeinfo for NcFile]+0x0): undefined reference to `vtable for __cxxabiv1::__class_type_info'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(netcdf.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `__static_initialization_and_destruction_0(int, int)':
ncvalues.cpp:(.text+0x1125): undefined reference to `std::ios_base::Init::Init()'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `__tcf_0':
ncvalues.cpp:(.text+0x116e): undefined reference to `std::ios_base::Init::~Init()'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_double::print(std::basic_ostream<char, std::char_traits<char> >&) const':
ncvalues.cpp:(.text+0x11da): undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(double)'
ncvalues.cpp:(.text+0x11ea): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
ncvalues.cpp:(.text+0x1229): undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(double)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_float::print(std::basic_ostream<char, std::char_traits<char> >&) const':
ncvalues.cpp:(.text+0x12b6): undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(float)'
ncvalues.cpp:(.text+0x12c6): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
ncvalues.cpp:(.text+0x1305): undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(float)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_char::print(std::basic_ostream<char, std::char_traits<char> >&) const':
ncvalues.cpp:(.text+0x1341): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char)'
ncvalues.cpp:(.text+0x138f): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char)'
ncvalues.cpp:(.text+0x13ad): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_ncbyte::print(std::basic_ostream<char, std::char_traits<char> >&) const':
ncvalues.cpp:(.text+0x13e2): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, unsigned char)'
ncvalues.cpp:(.text+0x13f2): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
ncvalues.cpp:(.text+0x1430): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, unsigned char)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_long::print(std::basic_ostream<char, std::char_traits<char> >&) const':
ncvalues.cpp:(.text+0x1465): undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(long)'
ncvalues.cpp:(.text+0x1475): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
ncvalues.cpp:(.text+0x14b4): undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(long)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_nclong::print(std::basic_ostream<char, std::char_traits<char> >&) const':
ncvalues.cpp:(.text+0x14e9): undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
ncvalues.cpp:(.text+0x14f9): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
ncvalues.cpp:(.text+0x1538): undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_int::print(std::basic_ostream<char, std::char_traits<char> >&) const':
ncvalues.cpp:(.text+0x156d): undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
ncvalues.cpp:(.text+0x157d): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
ncvalues.cpp:(.text+0x15bc): undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_short::print(std::basic_ostream<char, std::char_traits<char> >&) const':
ncvalues.cpp:(.text+0x15f2): undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(short)'
ncvalues.cpp:(.text+0x1602): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
ncvalues.cpp:(.text+0x1642): undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(short)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_double::as_string(long) const':
ncvalues.cpp:(.text+0x165e): undefined reference to `operator new[](unsigned int)'
ncvalues.cpp:(.text+0x1677): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream(std::_Ios_Openmode)'
ncvalues.cpp:(.text+0x169a): undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(double)'
ncvalues.cpp:(.text+0x16af): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str() const'
ncvalues.cpp:(.text+0x16d4): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::copy(char*, unsigned int, unsigned int) const'
ncvalues.cpp:(.text+0x16df): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x16f8): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x1715): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str() const'
ncvalues.cpp:(.text+0x1723): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::length() const'
ncvalues.cpp:(.text+0x1734): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x174d): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x1766): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::~basic_ostringstream()'
ncvalues.cpp:(.text+0x1788): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::~basic_ostringstream()'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_float::as_string(long) const':
ncvalues.cpp:(.text+0x17be): undefined reference to `operator new[](unsigned int)'
ncvalues.cpp:(.text+0x17d7): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream(std::_Ios_Openmode)'
ncvalues.cpp:(.text+0x17fa): undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(float)'
ncvalues.cpp:(.text+0x180f): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str() const'
ncvalues.cpp:(.text+0x1834): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::copy(char*, unsigned int, unsigned int) const'
ncvalues.cpp:(.text+0x183f): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x1858): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x1875): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str() const'
ncvalues.cpp:(.text+0x1883): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::length() const'
ncvalues.cpp:(.text+0x1894): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x18ad): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x18c6): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::~basic_ostringstream()'
ncvalues.cpp:(.text+0x18e8): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::~basic_ostringstream()'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_long::as_string(long) const':
ncvalues.cpp:(.text+0x191e): undefined reference to `operator new[](unsigned int)'
ncvalues.cpp:(.text+0x1937): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream(std::_Ios_Openmode)'
ncvalues.cpp:(.text+0x195a): undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(long)'
ncvalues.cpp:(.text+0x196f): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str() const'
ncvalues.cpp:(.text+0x1994): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::copy(char*, unsigned int, unsigned int) const'
ncvalues.cpp:(.text+0x199f): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x19b8): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x19d5): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str() const'
ncvalues.cpp:(.text+0x19e3): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::length() const'
ncvalues.cpp:(.text+0x19f4): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x1a0d): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x1a26): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::~basic_ostringstream()'
ncvalues.cpp:(.text+0x1a48): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::~basic_ostringstream()'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_nclong::as_string(long) const':
ncvalues.cpp:(.text+0x1a7e): undefined reference to `operator new[](unsigned int)'
ncvalues.cpp:(.text+0x1a97): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream(std::_Ios_Openmode)'
ncvalues.cpp:(.text+0x1aba): undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
ncvalues.cpp:(.text+0x1acf): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str() const'
ncvalues.cpp:(.text+0x1af4): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::copy(char*, unsigned int, unsigned int) const'
ncvalues.cpp:(.text+0x1aff): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x1b18): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x1b35): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str() const'
ncvalues.cpp:(.text+0x1b43): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::length() const'
ncvalues.cpp:(.text+0x1b54): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x1b6d): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x1b86): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::~basic_ostringstream()'
ncvalues.cpp:(.text+0x1ba8): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::~basic_ostringstream()'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_int::as_string(long) const':
ncvalues.cpp:(.text+0x1bde): undefined reference to `operator new[](unsigned int)'
ncvalues.cpp:(.text+0x1bf7): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream(std::_Ios_Openmode)'
ncvalues.cpp:(.text+0x1c1a): undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(int)'
ncvalues.cpp:(.text+0x1c2f): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str() const'
ncvalues.cpp:(.text+0x1c54): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::copy(char*, unsigned int, unsigned int) const'
ncvalues.cpp:(.text+0x1c5f): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x1c78): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x1c95): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str() const'
ncvalues.cpp:(.text+0x1ca3): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::length() const'
ncvalues.cpp:(.text+0x1cb4): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x1ccd): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x1ce6): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::~basic_ostringstream()'
ncvalues.cpp:(.text+0x1d08): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::~basic_ostringstream()'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_short::as_string(long) const':
ncvalues.cpp:(.text+0x1d3e): undefined reference to `operator new[](unsigned int)'
ncvalues.cpp:(.text+0x1d57): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream(std::_Ios_Openmode)'
ncvalues.cpp:(.text+0x1d7b): undefined reference to `std::basic_ostream<char, std::char_traits<char> >::operator<<(short)'
ncvalues.cpp:(.text+0x1d90): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str() const'
ncvalues.cpp:(.text+0x1db5): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::copy(char*, unsigned int, unsigned int) const'
ncvalues.cpp:(.text+0x1dc0): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x1dd9): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x1df6): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::str() const'
ncvalues.cpp:(.text+0x1e04): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::length() const'
ncvalues.cpp:(.text+0x1e15): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x1e2e): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
ncvalues.cpp:(.text+0x1e47): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::~basic_ostringstream()'
ncvalues.cpp:(.text+0x1e69): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::~basic_ostringstream()'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues::~NcValues()':
ncvalues.cpp:(.text+0x1eac): undefined reference to `operator delete(void*)'
ncvalues.cpp:(.text+0x1ed2): undefined reference to `operator delete(void*)'
ncvalues.cpp:(.text+0x1ef8): undefined reference to `operator delete(void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_double::NcValues_double(long)':
ncvalues.cpp:(.text+0x1f33): undefined reference to `operator new[](unsigned int)'
ncvalues.cpp:(.text+0x1f9b): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_double::NcValues_double(long, double const*)':
ncvalues.cpp:(.text+0x2003): undefined reference to `operator new[](unsigned int)'
ncvalues.cpp:(.text+0x209b): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_float::NcValues_float(long)':
ncvalues.cpp:(.text+0x2133): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o):ncvalues.cpp:(.text+0x219b): more undefined references to `operator new[](unsigned int)' follow
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_double::~NcValues_double()':
ncvalues.cpp:(.text+0x2f96): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x2fb5): undefined reference to `operator delete(void*)'
ncvalues.cpp:(.text+0x2fe0): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x2fff): undefined reference to `operator delete(void*)'
ncvalues.cpp:(.text+0x302a): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x3049): undefined reference to `operator delete(void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_double::operator=(NcValues_double const&)':
ncvalues.cpp:(.text+0x3084): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x3095): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_double::NcValues_double(NcValues_double const&)':
ncvalues.cpp:(.text+0x3117): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x3128): undefined reference to `operator new[](unsigned int)'
ncvalues.cpp:(.text+0x31cb): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x31dc): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_float::~NcValues_float()':
ncvalues.cpp:(.text+0x326c): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x328b): undefined reference to `operator delete(void*)'
ncvalues.cpp:(.text+0x32b6): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x32d5): undefined reference to `operator delete(void*)'
ncvalues.cpp:(.text+0x3300): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x331f): undefined reference to `operator delete(void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_float::operator=(NcValues_float const&)':
ncvalues.cpp:(.text+0x335a): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x336b): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_float::NcValues_float(NcValues_float const&)':
ncvalues.cpp:(.text+0x33ed): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x33fe): undefined reference to `operator new[](unsigned int)'
ncvalues.cpp:(.text+0x34a1): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x34b2): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_long::~NcValues_long()':
ncvalues.cpp:(.text+0x3542): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x3561): undefined reference to `operator delete(void*)'
ncvalues.cpp:(.text+0x358c): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x35ab): undefined reference to `operator delete(void*)'
ncvalues.cpp:(.text+0x35d6): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x35f5): undefined reference to `operator delete(void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_long::operator=(NcValues_long const&)':
ncvalues.cpp:(.text+0x3630): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x3641): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_long::NcValues_long(NcValues_long const&)':
ncvalues.cpp:(.text+0x36c3): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x36d4): undefined reference to `operator new[](unsigned int)'
ncvalues.cpp:(.text+0x3777): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x3788): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_nclong::~NcValues_nclong()':
ncvalues.cpp:(.text+0x3818): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x3837): undefined reference to `operator delete(void*)'
ncvalues.cpp:(.text+0x3862): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x3881): undefined reference to `operator delete(void*)'
ncvalues.cpp:(.text+0x38ac): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x38cb): undefined reference to `operator delete(void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_nclong::operator=(NcValues_nclong const&)':
ncvalues.cpp:(.text+0x3906): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x3917): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_nclong::NcValues_nclong(NcValues_nclong const&)':
ncvalues.cpp:(.text+0x3999): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x39aa): undefined reference to `operator new[](unsigned int)'
ncvalues.cpp:(.text+0x3a4d): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x3a5e): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_int::~NcValues_int()':
ncvalues.cpp:(.text+0x3aee): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x3b0d): undefined reference to `operator delete(void*)'
ncvalues.cpp:(.text+0x3b38): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x3b57): undefined reference to `operator delete(void*)'
ncvalues.cpp:(.text+0x3b82): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x3ba1): undefined reference to `operator delete(void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_int::operator=(NcValues_int const&)':
ncvalues.cpp:(.text+0x3bdc): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x3bed): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_int::NcValues_int(NcValues_int const&)':
ncvalues.cpp:(.text+0x3c6f): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x3c80): undefined reference to `operator new[](unsigned int)'
ncvalues.cpp:(.text+0x3d23): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x3d34): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_short::~NcValues_short()':
ncvalues.cpp:(.text+0x3dc4): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x3de3): undefined reference to `operator delete(void*)'
ncvalues.cpp:(.text+0x3e0e): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x3e2d): undefined reference to `operator delete(void*)'
ncvalues.cpp:(.text+0x3e58): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x3e77): undefined reference to `operator delete(void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_short::operator=(NcValues_short const&)':
ncvalues.cpp:(.text+0x3eb2): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x3ec2): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_short::NcValues_short(NcValues_short const&)':
ncvalues.cpp:(.text+0x3f43): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x3f53): undefined reference to `operator new[](unsigned int)'
ncvalues.cpp:(.text+0x3ff7): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x4007): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_char::~NcValues_char()':
ncvalues.cpp:(.text+0x4098): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x40b7): undefined reference to `operator delete(void*)'
ncvalues.cpp:(.text+0x40e2): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x4101): undefined reference to `operator delete(void*)'
ncvalues.cpp:(.text+0x412c): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x414b): undefined reference to `operator delete(void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_char::operator=(NcValues_char const&)':
ncvalues.cpp:(.text+0x4186): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x4194): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_char::NcValues_char(NcValues_char const&)':
ncvalues.cpp:(.text+0x4211): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x421f): undefined reference to `operator new[](unsigned int)'
ncvalues.cpp:(.text+0x42bd): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x42cb): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_ncbyte::~NcValues_ncbyte()':
ncvalues.cpp:(.text+0x4356): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x4375): undefined reference to `operator delete(void*)'
ncvalues.cpp:(.text+0x43a0): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x43bf): undefined reference to `operator delete(void*)'
ncvalues.cpp:(.text+0x43ea): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x4409): undefined reference to `operator delete(void*)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_ncbyte::operator=(NcValues_ncbyte const&)':
ncvalues.cpp:(.text+0x4444): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x4452): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_ncbyte::NcValues_ncbyte(NcValues_ncbyte const&)':
ncvalues.cpp:(.text+0x44cf): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x44dd): undefined reference to `operator new[](unsigned int)'
ncvalues.cpp:(.text+0x457b): undefined reference to `operator delete[](void*)'
ncvalues.cpp:(.text+0x4589): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_ncbyte::as_string(long) const':
ncvalues.cpp:(.text._ZNK15NcValues_ncbyte9as_stringEl[NcValues_ncbyte::as_string(long) const]+0x11): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o): In function `NcValues_char::as_string(long) const':
ncvalues.cpp:(.text._ZNK13NcValues_char9as_stringEl[NcValues_char::as_string(long) const]+0x11): undefined reference to `operator new[](unsigned int)'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o):(.rodata._ZTV8NcValues[vtable for NcValues]+0x14): undefined reference to `__cxa_pure_virtual'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o):(.rodata._ZTV8NcValues[vtable for NcValues]+0x18): undefined reference to `__cxa_pure_virtual'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o):(.rodata._ZTV8NcValues[vtable for NcValues]+0x1c): undefined reference to `__cxa_pure_virtual'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o):(.rodata._ZTV8NcValues[vtable for NcValues]+0x20): undefined reference to `__cxa_pure_virtual'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o):(.rodata._ZTV8NcValues[vtable for NcValues]+0x24): undefined reference to `__cxa_pure_virtual'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o):(.rodata._ZTV8NcValues[vtable for NcValues]+0x28): more undefined references to `__cxa_pure_virtual' follow
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o):(.rodata._ZTI15NcValues_double[typeinfo for NcValues_double]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o):(.rodata._ZTI14NcValues_float[typeinfo for NcValues_float]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o):(.rodata._ZTI13NcValues_long[typeinfo for NcValues_long]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o):(.rodata._ZTI15NcValues_nclong[typeinfo for NcValues_nclong]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o):(.rodata._ZTI12NcValues_int[typeinfo for NcValues_int]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o):(.rodata._ZTI14NcValues_short[typeinfo for NcValues_short]+0x0): more undefined references to `vtable for __cxxabiv1::__si_class_type_info' follow
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o):(.rodata._ZTI8NcValues[typeinfo for NcValues]+0x0): undefined reference to `vtable for __cxxabiv1::__class_type_info'
/opt/netcdf-3.6.1-32-c2/lib/libnetcdf_c++.a(ncvalues.o):(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
collect2: ld returned 1 exit status
make[2]: *** [point_in_elem] Error 1
make[2]: Leaving directory `/home/jason/moab/test/x86/test/perf'
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `/home/jason/moab/test/x86/test'
make: *** [check-recursive] Error 1
