[MOAB-dev] Problems with MOAB not finding hdf5
    Tim Tautges
    tautges at mcs.anl.gov
    Thu Apr 16 14:30:31 CDT 2009
Hi John,
   I wasn't aware that the build was breaking with pre-compiled versions
of hdf5 on 64 bit.  I'm passing that along to Jason to test.
- tim
John H Magerlein wrote:
> Tim,
> I was able to get this to work today, but it took a lot of effort. When
> I compile this on my 64-bit system, I obviously need the 64-bit HDF5
> libraries. I loaded the latest pre-compiled HDF5 64-bit libraries, but
> your configure code to detect working HDF libraries seems to fail for
> this latest release of HDF. Eventually I got some older HDF5 code
> (release 1.6.4), but I had to compile this from sources to get a 64-bit
> version. This was a lot of trouble and I'm not sure it is completely
> right. In any case, using this older HDF5 code with MOAB/iMesh does seem
> to all work now.
> In summary, can you modify your code so it is compatible with the
> current release of HDF5?
> John Magerlein
> IBM T. J. Watson Research Center
> 914-945-2726  (Tieline 862-2726)
> From: 	John H Magerlein/Watson/IBM
> To: 	tautges at mcs.anl.gov
> Date: 	04/10/2009 05:34 PM
> Subject: 	Problems with MOAB not finding hdf5
> Tim,
> I recently moved to a new machine which has 64-bit Red Hat Enterprise
> Linux 5.3 and downloaded a new copy of MOAB. In trying to build this, I
> seem to have a new set of problems. I don't know if this is due to my
> different operating environment or to changes you might have made. The
> autoreconf -fi works fine, but configure can't find hdf5 even though
> I've pointed it at the libraries:
> ./configure --with-hdf5=/usr/lib/salome/hdf-1.6.4 --prefix=/usr/lib/moab
> The messages are:
> checking if HDF5 support is enabled... yes
> checking hdf5.h usability... yes
> checking hdf5.h presence... yes
> checking for hdf5.h... yes
> checking for H5Fopen in -lhdf5... no
> configure: error: HDF5 library not found or not usable.
> I also tried installing the current version of hdf5 64-bit directly on
> the machine and pointed configure to that, but got the same results. Any
> suggestions?
> John Magerlein
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
