[MOAB-dev] r2783 - in MOAB/trunk: . parallel
kraftche at cae.wisc.edu
Mon Mar 30 18:39:05 CDT 2009
Author: kraftche
Date: 2009-03-30 18:39:05 -0500 (Mon, 30 Mar 2009)
New Revision: 2783
Modified:
MOAB/trunk/MBCore.cpp
MOAB/trunk/MBCore.hpp
MOAB/trunk/MBReaderIface.hpp
MOAB/trunk/ReadCGM.cpp
MOAB/trunk/ReadCGM.hpp
MOAB/trunk/ReadGmsh.cpp
MOAB/trunk/ReadGmsh.hpp
MOAB/trunk/ReadHDF5.cpp
MOAB/trunk/ReadHDF5.hpp
MOAB/trunk/ReadIDEAS.cpp
MOAB/trunk/ReadIDEAS.hpp
MOAB/trunk/ReadNCDF.cpp
MOAB/trunk/ReadNCDF.hpp
MOAB/trunk/ReadSTL.cpp
MOAB/trunk/ReadSTL.hpp
MOAB/trunk/ReadSms.cpp
MOAB/trunk/ReadSms.hpp
MOAB/trunk/ReadTetGen.cpp
MOAB/trunk/ReadTetGen.hpp
MOAB/trunk/ReadVtk.cpp
MOAB/trunk/ReadVtk.hpp
MOAB/trunk/Tqdcfr.cpp
MOAB/trunk/Tqdcfr.hpp
MOAB/trunk/cub_file_test.cc
MOAB/trunk/exodus_test.cc
MOAB/trunk/parallel/ReadParallel.cpp
MOAB/trunk/parallel/ReadParallel.hpp
MOAB/trunk/parallel/mbparallelcomm_test.cpp
Log:
o Consolidate code duplication between ReadParallel and MBCore
o Rather than block ID list, pass input {tag_name, tag_value_list}
to readers.
o Make all readers (except Exodus) return MB_UNSUPPORTED_OPERATION if any
input tag_name for subset is specfied. Previously most readers ignored
the input block ID list and read the entire file.
o Make ExodusII reader fail if specified subset tag is anything other
than MATERAIAL_SET_TAG_ID.
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/MBCore.cpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -364,25 +364,9 @@
const int* set_tag_values,
int num_set_tag_values )
- if (num_set_tag_values < 0)
- return MB_INDEX_OUT_OF_RANGE;
FileOptions opts(options);
- file_set = 0;
MBErrorCode rval;
- const MBReaderWriterSet* set = reader_writer_set();
- // convert from to old block-based reader interface
- const int* block_id_list = 0;
- int num_blocks = 0;
- if (set_tag_name) {
- if (strcmp(set_tag_name, MATERIAL_SET_TAG_NAME ))
- return MB_NOT_IMPLEMENTED;
- block_id_list = set_tag_values;
- num_blocks = num_set_tag_values;
// if reading in parallel, call a different reader
std::string parallel_opt;
rval = opts.get_option( "PARALLEL", parallel_opt);
@@ -399,19 +383,42 @@
else if (rval != MB_ENTITY_NOT_FOUND)
return rval;
return ReadParallel(this,pcomm).load_file(file_name, file_set, opts,
- block_id_list, num_blocks);
+ set_tag_name, set_tag_values,
+ num_set_tag_values);
#else
mError->set_last_error( "PARALLEL option not valid, this instance"
" compiled for serial execution.\n" );
#endif
+ else {
+ return serial_load_file( file_name, file_set,
+ opts, set_tag_name,
+ set_tag_values, num_set_tag_values );
+MBErrorCode MBCore::serial_load_file( const char* file_name,
+ MBEntityHandle& file_set,
+ const FileOptions& opts,
+ const char* set_tag_name,
+ const int* set_tag_values,
+ int num_set_tag_values )
+ if (num_set_tag_values < 0)
+ return MB_INDEX_OUT_OF_RANGE;
+ file_set = 0;
+ MBErrorCode rval;
+ const MBReaderWriterSet* set = reader_writer_set();
// otherwise try using the file extension to select a reader
MBReaderIface* reader = set->get_file_extension_reader( file_name );
if (reader)
- rval = reader->load_file( file_name, file_set, opts, block_id_list, num_blocks );
+ rval = reader->load_file( file_name, file_set, opts, set_tag_name,
delete reader;
else
@@ -423,7 +430,8 @@
MBReaderIface* reader = iter->make_reader( this );
if (NULL != reader)
delete reader;
if (MB_SUCCESS == rval)
break;
Modified: MOAB/trunk/MBCore.hpp
--- MOAB/trunk/MBCore.hpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/MBCore.hpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -26,6 +26,7 @@
class TagServer;
class MBError;
class MBReaderWriterSet;
+class FileOptions;
#ifdef XPCOM_MB
@@ -97,6 +98,14 @@
const char* set_tag_name = 0,
const int* set_tag_values = 0,
int num_set_tag_values = 0 );
+ /**Load or import a file. */
+ virtual MBErrorCode serial_load_file( const char* file_name,
+ const char* set_tag_name = 0,
+ const int* set_tag_values = 0,
+ int num_set_tag_values = 0 );
virtual MBErrorCode write_mesh(const char *file_name,
const MBEntityHandle *output_list = NULL,
Modified: MOAB/trunk/MBReaderIface.hpp
--- MOAB/trunk/MBReaderIface.hpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/MBReaderIface.hpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -49,8 +49,9 @@
virtual MBErrorCode load_file( const char* file_name,
- const int* material_set_list,
- int material_set_list_len ) = 0;
+ int num_set_tag_values = 0 ) = 0;
Modified: MOAB/trunk/ReadCGM.cpp
--- MOAB/trunk/ReadCGM.cpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/ReadCGM.cpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -98,13 +98,18 @@
MBErrorCode ReadCGM::load_file(const char *cgm_file_name,
- const int* blocks_to_load,
- const int num_blocks)
+ const char* name,
+ const int*, const int)
// blocks_to_load and num_blocks are ignored.
MBErrorCode rval;
file_set = 0;
+ if (name) {
+ readUtilIface->report_error( "Reading subset of files not supported for CGM data." );
+ return MB_UNSUPPORTED_OPERATION;
std::string filename( cgm_file_name );
cgmFile = filename;
Modified: MOAB/trunk/ReadCGM.hpp
--- MOAB/trunk/ReadCGM.hpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/ReadCGM.hpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -53,8 +53,9 @@
MBErrorCode load_file(const char *cgm_file_name,
- const int num_blocks);
+ int num_set_tag_values );
//! Constructor
ReadCGM(MBInterface* impl = NULL);
Modified: MOAB/trunk/ReadGmsh.cpp
--- MOAB/trunk/ReadGmsh.cpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/ReadGmsh.cpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -83,9 +83,14 @@
MBErrorCode ReadGmsh::load_file( const char* filename,
const FileOptions& ,
- const int* blocks,
- const int num_blocks )
+ const int* blocks, const int num_blocks )
+ if (!strcmp( set_tag_name, MATERIAL_SET_TAG_NAME )) {
+ readMeshIface->report_error( "GMsh supports subset read only by material ID." );
mCurrentMeshHandle = 0;
const MBErrorCode result = load_file_impl( filename, blocks, num_blocks );
Modified: MOAB/trunk/ReadGmsh.hpp
--- MOAB/trunk/ReadGmsh.hpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/ReadGmsh.hpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -41,8 +41,9 @@
MBErrorCode load_file(const char *file_name,
- int num_material_sets );
//! Constructor
ReadGmsh(MBInterface* impl = NULL);
Modified: MOAB/trunk/ReadHDF5.cpp
--- MOAB/trunk/ReadHDF5.cpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/ReadHDF5.cpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -122,13 +122,18 @@
MBErrorCode ReadHDF5::load_file( const char* filename,
- const int* p,
+ const char* name,
+ const int*, const int )
MBErrorCode rval;
mhdf_Status status;
ioProp = H5P_DEFAULT;
+ if (name) {
+ readUtil->report_error( "Reading subset of files not supported for HDF5." );
if (MB_SUCCESS != init())
return MB_FAILURE;
@@ -188,7 +193,7 @@
- rval = load_file_impl( file_set, p, num_blocks, use_mpio );
+ rval = load_file_impl( file_set, use_mpio );
mhdf_closeFile( filePtr, &status );
filePtr = 0;
if (ioProp != H5P_DEFAULT)
@@ -221,8 +226,6 @@
MBErrorCode ReadHDF5::load_file_impl(
MBEntityHandle file_set,
- const int*,
- const int num_blocks,
bool use_mpio )
MBErrorCode rval;
@@ -235,9 +238,6 @@
unsigned int i, num_groups;
bool have_nodes = true;
- if (num_blocks)
- return MB_FAILURE;
DEBUGOUT("Reading Nodes.\n");
rval = read_nodes();
Modified: MOAB/trunk/ReadHDF5.hpp
--- MOAB/trunk/ReadHDF5.hpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/ReadHDF5.hpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -49,13 +49,12 @@
MBErrorCode load_file( const char* filename,
- int material_set_count );
protected:
MBErrorCode load_file_impl( MBEntityHandle file_set,
- const int*,
bool use_mpio );
private:
Modified: MOAB/trunk/ReadIDEAS.cpp
--- MOAB/trunk/ReadIDEAS.cpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/ReadIDEAS.cpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -23,9 +23,14 @@
MBErrorCode ReadIDEAS::load_file(const char* fname,
MBEntityHandle& meshset,
const FileOptions& options,
- int num_material_sets ) {
+ const char* name,
+ const int*, const int ) {
+ if (name) {
+ readMeshIface->report_error( "Reading subset of files not supported for IDEAS." );
file.open( fname );
MBErrorCode rval;
Modified: MOAB/trunk/ReadIDEAS.hpp
--- MOAB/trunk/ReadIDEAS.hpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/ReadIDEAS.hpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -23,8 +23,9 @@
MBErrorCode load_file(const char* fname,
const FileOptions&,
//! Constructor
ReadIDEAS(MBInterface* impl = NULL);
Modified: MOAB/trunk/ReadNCDF.cpp
--- MOAB/trunk/ReadNCDF.cpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/ReadNCDF.cpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -432,10 +432,17 @@
MBErrorCode ReadNCDF::load_file(const char *exodus_file_name,
const int *blocks_to_load,
MBErrorCode status;
+ readMeshIface->report_error( "Exodus reader supports subset read only by block ID." );
file_set = 0;
// this function directs the reading of an exoii file, but doesn't do any of
Modified: MOAB/trunk/ReadNCDF.hpp
--- MOAB/trunk/ReadNCDF.hpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/ReadNCDF.hpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -72,6 +72,7 @@
MBErrorCode load_file(const char *exodus_file_name,
Modified: MOAB/trunk/ReadSTL.cpp
--- MOAB/trunk/ReadSTL.cpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/ReadSTL.cpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -77,12 +77,17 @@
MBErrorCode ReadSTL::load_file( const char* filename,
+ const char* name,
- const MBErrorCode result = load_file_impl( filename, opts, blocks, num_blocks );
+ const MBErrorCode result = load_file_impl( filename, opts );
+ if (name) {
+ readMeshIface->report_error( "Reading subset of files not supported for STL." );
// If file read has failed, destroy anything that was
// created during the read.
if (MB_SUCCESS != result && mCurrentMeshHandle)
@@ -102,8 +107,7 @@
// pure-virtual function implemented in subclasses to read
// the data from the file.
MBErrorCode ReadSTL::load_file_impl(const char *filename,
- const FileOptions& opts,
- const int*, const int)
+ const FileOptions& opts )
MBErrorCode result;
Modified: MOAB/trunk/ReadSTL.hpp
--- MOAB/trunk/ReadSTL.hpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/ReadSTL.hpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -74,8 +74,9 @@
//! Constructor
ReadSTL(MBInterface* impl = NULL);
@@ -116,10 +117,7 @@
//! Generic file loading code for both binary and ASCII readers.
//! Calls reader-specific *_read_triangles function to do actual I/O.
- MBErrorCode load_file_impl(const char *file_name,
- const int num_material_sets );
+ MBErrorCode load_file_impl(const char *file_name, const FileOptions& opts );
//! Meshset Handle for the mesh that is currently being read
MBEntityHandle mCurrentMeshHandle;
Modified: MOAB/trunk/ReadSms.cpp
--- MOAB/trunk/ReadSms.cpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/ReadSms.cpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -61,13 +61,18 @@
MBErrorCode ReadSms::load_file( const char* filename,
- MBEntityHandle& file_set,
- const FileOptions& ,
+ const FileOptions& ,
+ const char* name,
+ if (name) {
+ readMeshIface->report_error( "Reading subset of files not supported for Sms." );
- const MBErrorCode result = load_file_impl( filename, blocks, num_blocks );
+ const MBErrorCode result = load_file_impl( filename );
@@ -84,9 +89,7 @@
return result;
-MBErrorCode ReadSms::load_file_impl( const char* filename,
+MBErrorCode ReadSms::load_file_impl( const char* filename )
bool warned = false;
Modified: MOAB/trunk/ReadSms.hpp
--- MOAB/trunk/ReadSms.hpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/ReadSms.hpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -20,8 +20,9 @@
//! Constructor
ReadSms(MBInterface* impl = NULL);
@@ -31,9 +32,7 @@
private:
- MBErrorCode load_file_impl( const char *file_name,
- const int num_material_sets);
+ MBErrorCode load_file_impl( const char *file_name );
MBErrorCode get_set(std::vector<MBEntityHandle> *sets,
int set_type, int set_id,
Modified: MOAB/trunk/ReadTetGen.cpp
--- MOAB/trunk/ReadTetGen.cpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/ReadTetGen.cpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -64,11 +64,17 @@
MBErrorCode ReadTetGen::load_file( const char* file_name_c,
- const int*, int )
+ const char* name,
std::ifstream node_file, ele_file, face_file, edge_file;
MBErrorCode rval;
+ if (name) {
+ readTool->report_error( "Reading subset of files not supported for TetGen." );
std::string suffix, base, filename(file_name_c);
size_t dot_idx = filename.find_last_of( '.' );
if (dot_idx == std::string::npos) {
Modified: MOAB/trunk/ReadTetGen.hpp
--- MOAB/trunk/ReadTetGen.hpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/ReadTetGen.hpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -39,8 +39,9 @@
const FileOptions&,
//! Constructor
ReadTetGen(MBInterface* impl = NULL);
Modified: MOAB/trunk/ReadVtk.cpp
--- MOAB/trunk/ReadVtk.cpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/ReadVtk.cpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -173,6 +173,7 @@
MBErrorCode ReadVtk::load_file(const char *filename,
+ const char* name,
MBErrorCode result;
@@ -182,6 +183,11 @@
char vendor_string[257];
std::vector<MBRange> element_list;
MBRange vertices;
+ if (name) {
+ readMeshIface->report_error( "Reading subset of files not supported for VTK." );
// Does the caller want a field to be used for partitioning the entities?
// If not, we'll assume any scalar integer field named MATERIAL_SET specifies partitions.
Modified: MOAB/trunk/ReadVtk.hpp
--- MOAB/trunk/ReadVtk.hpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/ReadVtk.hpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -35,8 +35,9 @@
const FileOptions&,
//! Constructor
ReadVtk(MBInterface* impl = NULL);
Modified: MOAB/trunk/Tqdcfr.cpp
--- MOAB/trunk/Tqdcfr.cpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/Tqdcfr.cpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -193,10 +193,16 @@
MBErrorCode Tqdcfr::load_file(const char *file_name,
+ const char* block_tag_name,
MBErrorCode result;
file_set = mFileSet = 0;
+ if (block_tag_name) {
+ readUtilIface->report_error( "Reading subset of files not supported for CUB files." );
// open file
cubFile = fopen(file_name, "rb");
@@ -2577,7 +2583,7 @@
MBEntityHandle file_set;
FileOptions opts(NULL);
- MBErrorCode result = my_tqd->load_file(file, file_set, opts, 0, 0);
+ MBErrorCode result = my_tqd->load_file(file, file_set, opts, 0, 0, 0);
if (MB_SUCCESS == result)
std::cout << "Success." << std::endl;
@@ -2596,7 +2602,7 @@
my_impl = new MBCore;
my_tqd = new Tqdcfr(my_impl);
- result = my_tqd->load_file(file, file_set, opts, 0, 0);
+ result = my_tqd->load_file(file, file_set, opts, 0, 0, 0);
Modified: MOAB/trunk/Tqdcfr.hpp
--- MOAB/trunk/Tqdcfr.hpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/Tqdcfr.hpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -295,6 +295,7 @@
const int* block_list,
int num_blocks );
MBErrorCode read_nodeset(ModelEntry *model,
Modified: MOAB/trunk/cub_file_test.cc
--- MOAB/trunk/cub_file_test.cc 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/cub_file_test.cc 2009-03-30 23:39:05 UTC (rev 2783)
@@ -181,7 +181,7 @@
MBEntityHandle set;
Tqdcfr reader( &moab );
FileOptions opts("");
- rval = reader.load_file( input_file, set, opts, 0, 0 );
+ rval = reader.load_file( input_file, set, opts, 0, 0, 0 );
if (file_set)
*file_set = set;
CHECK_ERR(rval);
Modified: MOAB/trunk/exodus_test.cc
--- MOAB/trunk/exodus_test.cc 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/exodus_test.cc 2009-03-30 23:39:05 UTC (rev 2783)
@@ -78,7 +78,7 @@
MBEntityHandle set;
ReadNCDF reader( &moab );
CHECK_ERR(rval);
@@ -103,7 +103,7 @@
remove(tmp_file);
CHECK_ERR(rval);
- rval = reader.load_file( tmp_file, set, opts, 0, 0 );
+ rval = reader.load_file( tmp_file, set, opts, 0, 0, 0 );
remove( tmp_file );
CHECK_ERR(rval);
Modified: MOAB/trunk/parallel/ReadParallel.cpp
--- MOAB/trunk/parallel/ReadParallel.cpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/parallel/ReadParallel.cpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -52,8 +52,9 @@
const int num_files,
const FileOptions &opts,
+ const int num_tag_values )
MBError *merror = ((MBCore*)mbImpl)->get_error_handler();
@@ -185,8 +186,9 @@
return load_file(file_names, num_files, file_set, parallel_mode,
partition_tag_name,
- partition_tag_vals, distrib, pa_vec, material_set_list,
- num_material_sets, opts, reader_rank, cputime,
+ partition_tag_vals, distrib, pa_vec, opts,
+ set_tag_name, set_tag_values, num_tag_values,
+ reader_rank, cputime,
resolve_dim, shared_dim,
ghost_dim, bridge_dim, num_layers);
@@ -199,9 +201,10 @@
std::vector<int> &partition_tag_vals,
bool distrib,
std::vector<int> &pa_vec,
- const int num_material_sets,
+ const int num_tag_values,
const int reader_rank,
const bool cputime,
const int resolve_dim,
@@ -217,7 +220,6 @@
MBRange entities;
MBTag file_set_tag = 0;
int other_sets = 0;
- MBReaderIface* reader;
MBReaderWriterSet::iterator iter;
MBRange other_file_sets, file_sets;
MBCore *impl = dynamic_cast<MBCore*>(mbImpl);
@@ -248,33 +250,12 @@
std::cout << "Reading file " << file_names[j] << std::endl;
MBEntityHandle new_file_set = 0;
- reader = impl->reader_writer_set()->
- get_file_extension_reader( file_names[j] );
- if (reader)
- tmp_result = reader->load_file( file_names[j], new_file_set, opts,
- material_set_list, num_material_sets );
- delete reader;
- else
- // Try all the readers
- for (iter = impl->reader_writer_set()->begin();
- iter != impl->reader_writer_set()->end(); ++iter)
- reader = iter->make_reader( mbImpl );
- if (NULL != reader)
- delete reader;
- if (MB_SUCCESS == tmp_result)
- break;
+ tmp_result = impl->serial_load_file( file_names[j],
+ new_file_set,
+ opts,
+ set_tag_name,
+ set_tag_values,
+ num_tag_values );
if (MB_SUCCESS != tmp_result) break;
// put the contents of each file set for the reader into the
Modified: MOAB/trunk/parallel/ReadParallel.hpp
--- MOAB/trunk/parallel/ReadParallel.hpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/parallel/ReadParallel.hpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -20,16 +20,18 @@
+ const int num_tag_values );
//! load multiple files
MBErrorCode load_file(const char **file_names,
//! Constructor
ReadParallel(MBInterface* impl = NULL, MBParallelComm *pc = NULL);
@@ -54,9 +56,10 @@
bool distrib,
const bool cputime,
@@ -81,11 +84,12 @@
inline MBErrorCode ReadParallel::load_file(const char *file_name,
return load_file(&file_name, 1, file_set, opts,
- material_set_list, num_material_sets);
+ set_tag_name, set_tag_values, num_tag_values);
#endif
Modified: MOAB/trunk/parallel/mbparallelcomm_test.cpp
--- MOAB/trunk/parallel/mbparallelcomm_test.cpp 2009-03-30 23:35:24 UTC (rev 2782)
+++ MOAB/trunk/parallel/mbparallelcomm_test.cpp 2009-03-30 23:39:05 UTC (rev 2783)
@@ -339,7 +339,7 @@
rps[i] = new ReadParallel(mbImpl, pcs[i]);
result = rps[i]->load_file(filenames[i].c_str(), filesets[i],
- FileOptions(options.str().c_str()), NULL, 0);
+ FileOptions(options.str().c_str()), 0, 0, 0);
if (MB_SUCCESS != result)
PRINT_LAST_ERROR;
