[MOAB-dev] r2762 - in MOAB/branches/parallel_ghosting: . parallel tools/mbcoupler
tautges at mcs.anl.gov tautges at mcs.anl.gov
Thu Mar 26 16:54:59 CDT 2009
Author: tautges
Date: 2009-03-26 16:54:59 -0500 (Thu, 26 Mar 2009)
New Revision: 2762
Modified:
   MOAB/branches/parallel_ghosting/MBEntityType.h
   MOAB/branches/parallel_ghosting/MBTypes.h
   MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp
   MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp
   MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp
   MOAB/branches/parallel_ghosting/tools/mbcoupler/mbcoupler_test.cpp
Log:
- Added checks so that parallel_unit_test fails if ghosting tests fail
- added MBParallelComm::check_all_shared_handles(), which calls
  exchange_all_shared_handles and checks results
- Fixed a couple of bugs in MBParallelComm::exchange_ghost_cells,
  mostly with populating the sharedEnts structure.
Modified: MOAB/branches/parallel_ghosting/MBEntityType.h
--- MOAB/branches/parallel_ghosting/MBEntityType.h	2009-03-26 21:42:37 UTC (rev 2761)
+++ MOAB/branches/parallel_ghosting/MBEntityType.h	2009-03-26 21:54:59 UTC (rev 2762)
@@ -44,16 +44,16 @@
 #ifdef __cplusplus
-} // extern "C"
+} /* extern "C" */
-//! prefix increment operator for MBEntityType
+/* prefix increment operator for MBEntityType */
 inline MBEntityType & operator++(MBEntityType &type)
   return type = static_cast<MBEntityType>(type+1);
-//! postfix increment operator for MBEntityType
+/* postfix increment operator for MBEntityType */
 inline MBEntityType operator++(MBEntityType &type, int)
   MBEntityType oldval = type;
@@ -61,13 +61,13 @@
   return oldval;
 inline MBEntityType & operator--(MBEntityType &type)
   return type = static_cast<MBEntityType>(type-1);
 inline MBEntityType operator--(MBEntityType &type, int)
Modified: MOAB/branches/parallel_ghosting/MBTypes.h
--- MOAB/branches/parallel_ghosting/MBTypes.h	2009-03-26 21:42:37 UTC (rev 2761)
+++ MOAB/branches/parallel_ghosting/MBTypes.h	2009-03-26 21:54:59 UTC (rev 2762)
@@ -93,7 +93,7 @@
 #ifdef __cplusplus
-} // extern "C"
+} /* extern "C" */
 #endif
Modified: MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp
--- MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp	2009-03-26 21:42:37 UTC (rev 2761)
+++ MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp	2009-03-26 21:54:59 UTC (rev 2762)
@@ -921,6 +921,12 @@
     owned_shared.merge(owned_ents);
+    // else if we're sending interface ents, add all the entities
+    // to the ownedShared list
+  else if (!is_ghost)
+    owned_shared.merge(entities);
   if (store_remote_handles) {
       // pack the local handles
     int tmp_space = RANGE_SIZE(entities);
@@ -3132,7 +3138,7 @@
     if (sharing_procs[0] < (int)procConfig.proc_rank()) {
       for (unsigned int j = 0; j < sharing_procs.size() && sharing_procs[j] != -1; j++) {
         if (sharing_procs[j] == (int)procConfig.proc_rank()) continue;
-        int ind = get_buffers(sharing_procs[j]);
+        get_buffers(sharing_procs[j]);
         sharedEnts2.insert(this_ent);
@@ -3142,7 +3148,7 @@
         assert(sharing_procs[j] > (int)procConfig.proc_rank());
@@ -4999,6 +5005,144 @@
   return 0;
+MBErrorCode MBParallelComm::exchange_all_shared_handles( shared_entity_map& result )
+  MBErrorCode rval;
+  int ierr;
+  const int tag = 0x4A41534E;
+  const MPI_Comm comm = procConfig.proc_comm();
+  std::set<unsigned int> exch_procs;
+  rval = get_comm_procs(exch_procs);
+  if (MB_SUCCESS != rval)
+    return rval;
+  const int num_proc = exch_procs.size();
+  std::vector<MPI_Request> send_req(num_proc), recv_req(num_proc);
+  const std::vector<int> procs( exch_procs.begin(), exch_procs.end() );
+    // get all shared entities
+  MBRange all_shared;
+  MBTag pstatus = pstatus_tag();
+  for (MBEntityType type = MBVERTEX; type < MBENTITYSET; ++type) {
+    rval = get_moab()->get_entities_by_type_and_tag( 0, type, &pstatus, 0, 1, all_shared,
+                                                     MBInterface::UNION);
+      return rval;
+    // build up send buffers
+  shared_entity_map send_data;
+  int ent_procs[MAX_SHARING_PROCS];
+  MBEntityHandle handles[MAX_SHARING_PROCS];
+  int num_sharing;
+  SharedEntityData tmp;
+  for (MBRange::iterator i = all_shared.begin(); i != all_shared.end(); ++i) {
+    tmp.remote = *i; // swap local/remote so they're correct on the remote proc.
+    rval = get_owner( *i, tmp.owner );
+      return rval;
+    rval = get_sharing_parts( *i, ent_procs, num_sharing, handles );
+    for (int j = 0; j < num_sharing; ++j) {
+      if (ent_procs[j] == (int)proc_config().proc_rank())
+        continue;
+      tmp.local = handles[j];
+      send_data[ent_procs[j]].push_back( tmp );
+    // set up to receive sizes
+  std::vector<int> sizes_send(num_proc), sizes_recv(num_proc);
+  for (int i = 0; i < num_proc; ++i) {
+    ierr = MPI_Irecv( &sizes_recv[i], 1, MPI_INT, procs[i], tag, comm, &recv_req[i] );
+    if (ierr)
+      return MB_FILE_WRITE_ERROR;
+    // send sizes
+    sizes_send[i] = send_data[procs[i]].size();
+    ierr = MPI_Isend( &sizes_send[i], 1, MPI_INT, procs[i], tag, comm, &send_req[i] );
+    if (ierr)
+    // receive sizes
+  std::vector<MPI_Status> stat(num_proc);
+  ierr = MPI_Waitall( num_proc, &recv_req[0], &stat[0] );
+  if (ierr)
+    // wait until all sizes are sent (clean up pending req's)
+  ierr = MPI_Waitall( num_proc, &send_req[0], &stat[0] );
+  if (ierr)
+    // set up to receive data
+    result[procs[i]].resize( sizes_recv[i] );
+    ierr = MPI_Irecv( &result[procs[i]][0],
+                      sizeof(SharedEntityData)*sizes_recv[i],
+                      MPI_UNSIGNED_CHAR,
+                      procs[i], tag, comm, &recv_req[i] );
+    if (ierr)
+    // send data
+    ierr = MPI_Isend( &send_data[procs[i]][0],
+                      sizeof(SharedEntityData)*sizes_send[i],
+                      procs[i], tag, comm, &send_req[i] );
+    if (ierr)
+    // receive data
+  if (ierr)
+    // wait until everything is sent to release send buffers
+  if (ierr)
+  return MB_SUCCESS;
+MBErrorCode MBParallelComm::check_all_shared_handles()
+    // get all shared ent data from other procs
+  shared_entity_map shents;
+  MBErrorCode result;
+  result = exchange_all_shared_handles(shents);
+  if (MB_SUCCESS != result)
+    return result;
+  else if (shents.empty())
+    // now check against what I think data should be
+  MBRange dum_range, bad_ents, local_shared;
+  for (shared_entity_map::iterator mit = shents.begin(); mit != shents.end(); mit++) {
+    int other_proc = (*mit).first;
+    int ind = get_buffers(other_proc);
+    if (-1 == ind) return MB_FAILURE;
+    local_shared = shared_ents()[ind].ownedShared;
+    shared_entity_vec &shvec = (*mit).second;
+    for (shared_entity_vec::iterator vit = shvec.begin(); vit != shvec.end(); vit++) {
+      MBEntityHandle localh = vit->local, remoteh = vit->remote, dumh;
+      local_shared.erase(localh);
+      result = get_remote_handles(true, &localh, &dumh, 1, other_proc, dum_range);
+      if (MB_SUCCESS != result || dumh != remoteh)
+        bad_ents.insert(localh);
+  if (!bad_ents.empty() || !local_shared.empty()) return MB_FAILURE;
+  else return MB_SUCCESS;
 #ifdef TEST_PARALLELCOMM
 #include <iostream>
Modified: MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp
--- MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp	2009-03-26 21:42:37 UTC (rev 2761)
+++ MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp	2009-03-26 21:54:59 UTC (rev 2762)
@@ -778,6 +778,30 @@
     //! add vertices adjacent to entities in this list
   MBErrorCode add_verts(MBRange &sent_ents);
+  struct SharedEntityData {
+    MBEntityHandle local;
+    MBEntityHandle remote;
+    int owner;
+  typedef std::vector< SharedEntityData > shared_entity_vec;
+  //! Map indexed by processor ID and containing, for each processor ID,
+  //! a list of <local,remote> handle pairs, where the local handle is
+  //! the handle on this processor and the remove handle is the handle on
+  //! the processor ID indicated by the map index.
+  typedef std::map< int, shared_entity_vec > shared_entity_map;
+  //! Every processor sends shared entity handle data to every other processor
+  //! that it shares entities with.  Passed back map is all received data,
+  //! indexed by processor ID. This function is intended to be used for
+  //! debugging.
+  MBErrorCode exchange_all_shared_handles( shared_entity_map& result );
+    //! Call exchange_all_shared_handles, then compare the results with tag data
+    //! on local shared entities.
+  MBErrorCode check_all_shared_handles();
     //! replace handles in from_vec with corresponding handles on
     //! to_proc (by checking shared[p/h]_tag and shared[p/h]s_tag;
     //! if no remote handle and new_ents is non-null, substitute
Modified: MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp
--- MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp	2009-03-26 21:42:37 UTC (rev 2761)
+++ MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp	2009-03-26 21:54:59 UTC (rev 2762)
@@ -593,22 +593,14 @@
     shared_ents.merge(pcomm->shared_ents()[i].localHandles);
-    // over all interfaces, the owned and shared lists should be mutually exclusive
-    // and the interface ents should be contained in one of those
-  if (!(owned_ents.intersect(shared_ents)).empty()) {
-    std::cerr << "Contents of localHandles and ownedShared not consistent on proc "
-              << pcomm->proc_config().proc_rank() << std::endl;
+  rval = pcomm->check_all_shared_handles();
+  if (MB_SUCCESS != rval) {
     my_error = 1;
-  MBRange rem_ents = iface_ents.subtract(shared_ents);
-  rem_ents = rem_ents.subtract(owned_ents);
-  if (!rem_ents.empty()) {
-    std::cerr << "Interface entities inconsistent with sharedEnts on proc "
+    std::cerr << "check_all_shared_handles test failed on proc "
-    my_error = 1;
   PCHECK(!my_error);
     // finally, check adjacencies just to make sure they're consistent
   rval = mb_instance.check_adjacencies();
   if (MB_SUCCESS != rval) my_error = 1;
@@ -939,6 +931,10 @@
                           MPI_INT, pcomm->proc_config().proc_comm() );
   PCHECK(!error);
+  if (MB_SUCCESS != rval) error = 1;
+  PCHECK(!error);
      // for each ghost entity, check owning processor and list of
      // sharing processors.
   int k = 0;
@@ -972,7 +968,8 @@
       break;
+  PCHECK(!error);
     // done
   return MB_SUCCESS;
Modified: MOAB/branches/parallel_ghosting/tools/mbcoupler/mbcoupler_test.cpp
--- MOAB/branches/parallel_ghosting/tools/mbcoupler/mbcoupler_test.cpp	2009-03-26 21:42:37 UTC (rev 2761)
+++ MOAB/branches/parallel_ghosting/tools/mbcoupler/mbcoupler_test.cpp	2009-03-26 21:54:59 UTC (rev 2762)
@@ -151,7 +151,7 @@
     // now figure out which vertices are shared
   for (unsigned int p = 0; p < pcs.size(); p++) {
     for (int i = 0; i < 4; i++) {
-      tmp_result = pcs[p]->get_iface_entities(-1, i, iface_ents[i]);
+      tmp_result = pcs[p]->get_iface_entities(-1, iface_ents[i], i);
       if (MB_SUCCESS != tmp_result) {
         std::cerr << "get_iface_entities returned error on proc "
