[MOAB-dev] r2756 - MOAB/trunk/parallel
kraftche at cae.wisc.edu
Thu Mar 26 10:40:44 CDT 2009
Author: kraftche
Date: 2009-03-26 10:40:44 -0500 (Thu, 26 Mar 2009)
New Revision: 2756
Modified:
MOAB/trunk/parallel/parallel_write_test.cc
Log:
add some additional documentation
Modified: MOAB/trunk/parallel/parallel_write_test.cc
--- MOAB/trunk/parallel/parallel_write_test.cc 2009-03-26 13:51:45 UTC (rev 2755)
+++ MOAB/trunk/parallel/parallel_write_test.cc 2009-03-26 15:40:44 UTC (rev 2756)
@@ -37,9 +37,31 @@
const char args[] = "[-i <intervals>] [-o <filename>] [-g <filename>]";
void help() {
std::cout << "parallel_write_test " << args << std::endl
- << "-i <N> Each processor owns an NxNxN cube of hex elements (default: " << DEFAULT_INTERVALS << ")" << std::endl
- << "-o <name> Retain output file and name it as specified." << std::endl
- << "-g <name> Write local mesh to file name prefixed with MPI rank" << std::endl
+ << " -i <N> Each processor owns an NxNxN cube of hex elements (default: " << DEFAULT_INTERVALS << ")" << std::endl
+ << " -o <name> Retain output file and name it as specified." << std::endl
+ << " -g <name> Write local mesh to file name prefixed with MPI rank" << std::endl
+ << std::endl
+ << "This program creates a (non-strict) subset of a regular hex mesh "
+ "such that the mesh is already partitioned, and then attempts to "
+ "write that mesh using MOAB's parallel HDF5 writer. The mesh size "
+ "will scale with the number of processors and the number of elements "
+ "per processor (the latter is a function of the value specified "
+ "with the '-i' flag.)" << std::endl
+ << std::endl
+ << "Let N = ceil(cbrt(P)), where P is the number of processes. "
+ "The mesh will be some subset of a cube with one corner at the "
+ "origin and the other at (N,N,N). Each processor will own a "
+ "non-overlapping 1x1x1 unit block of mesh within that cube. "
+ "If P is a power of 3, then the entire NxNxN cube will be "
+ "filled with hex elements. Otherwise, some connected subset "
+ "of the cube will be meshed. Each processor is assigned a "
+ "sub-block of the cube by rank where the blocks are enumerated "
+ "sequentally with x increasing most rapidly and z least rapidly." << std::endl
+ << std::endl
+ << "The size of the mesh owned by each processor is controlled by "
+ "the number of intervals along each edge of its block of mesh. "
+ "If each block has N intervals, than each processor will have "
+ "N^3 hex elements." << std::endl
<< std::endl;
