[MOAB-dev] r2713 - MOAB/trunk/tools/iMesh
kraftche at cae.wisc.edu
Fri Mar 13 09:11:45 CDT 2009
Author: kraftche
Date: 2009-03-13 09:11:45 -0500 (Fri, 13 Mar 2009)
New Revision: 2713
Modified:
MOAB/trunk/tools/iMesh/testc_cbind.c
Log:
update for iMesh changes
Modified: MOAB/trunk/tools/iMesh/testc_cbind.c
--- MOAB/trunk/tools/iMesh/testc_cbind.c 2009-03-12 22:06:20 UTC (rev 2712)
+++ MOAB/trunk/tools/iMesh/testc_cbind.c 2009-03-13 14:11:45 UTC (rev 2713)
@@ -515,7 +515,7 @@
offsets_alloc = 0;
entities = NULL;
entities_alloc = 0;
iMesh_getAdjEntities(mesh, root_set, type,
iMesh_ALL_TOPOLOGIES, iBase_VERTEX,
&entities, &entities_alloc, &entities_size,
@@ -534,6 +534,7 @@
free(offsets);
free(entities);
return TRUE;
@@ -1025,32 +1026,31 @@
+ /* get all hexes and get faces of that hexes */
+ hexes = NULL;
+ hexes_alloc = 0;
+ iMesh_getEntities(mesh, root_set, iBase_ALL_TYPES,
+ iMesh_HEXAHEDRON, &hexes, &hexes_alloc, &hexes_size, &result);
+ if (iBase_SUCCESS != result) {
+ printf("Failed to get hexes in entity_sets_test.\n");
+ return FALSE;
/* get adjacent face of hexes */
adj_faces = NULL;
adj_faces_alloc = 0;
face_offsets = NULL;
face_offsets_alloc = 0;
- iMesh_getAdjEntities(mesh, root_set, iBase_ALL_TYPES,
- iMesh_HEXAHEDRON, iBase_FACE,
- &adj_faces, &adj_faces_alloc, &adj_faces_size,
- &face_offsets, &face_offsets_alloc, &face_offsets_size,
+ iMesh_getEntArrAdj( mesh, hexes, hexes_size, iBase_FACE,
+ &adj_faces, &adj_faces_alloc, &adj_faces_size,
+ &face_offsets, &face_offsets_alloc, &face_offsets_size,
&result);
printf("Problem to get adjacent entities in entitysets_test.\n");
return FALSE;
- /* get all hexes and get faces of that hexes */
- hexes = NULL;
- hexes_alloc = 0;
- iMesh_getEntities(mesh, root_set, iBase_ALL_TYPES,
- iMesh_HEXAHEDRON, &hexes, &hexes_alloc, &hexes_size, &result);
- if (iBase_SUCCESS != result) {
- printf("Failed to get hexes in entity_sets_test.\n");
- return FALSE;
iMesh_createEntSet(mesh, FALSE, &hex_set, &result);
@@ -1070,7 +1070,7 @@
adj_faces1_alloc = 0;
face_offsets1 = NULL;
face_offsets1_alloc = 0;
iMesh_getAdjEntities(mesh, hex_set,
iBase_ALL_TYPES,
@@ -1081,14 +1081,15 @@
printf("Failed to get faces from hexes in entityset_test.\n");
return FALSE;
/* compare number of faces */
if (adj_faces_size != adj_faces1_size ||
face_offsets_size != face_offsets1_size)
return FALSE;
if (!check_esets(mesh, n_whole_mesh + num_type + 6)) return FALSE;
free(temp_entities1);
free(temp_entities2);
free(edges);
@@ -1161,7 +1162,7 @@
/* check storage order */
int result;
- int this_order = iBase_UNDETERMINED;
+ int this_order;
iMesh_getDfltStorage(mesh, &this_order, &result);
printf("failed to get preferred storage order in vertex_coordinates_test.\n");
@@ -1183,7 +1184,7 @@
vert_coords = NULL;
vert_coords_alloc = 0;
- iMesh_getVtxArrCoords(mesh, verts, verts_size, &this_order,
+ iMesh_getVtxArrCoords(mesh, verts, verts_size, iBase_INTERLEAVED,
&vert_coords, &vert_coords_alloc, &vert_coords_size, &result);
printf("failed to get vertex cooridinate of entities in vertex_coordinates_test.\n");
