[MOAB-dev] Creation of parallel tags
Jed Brown jed at 59A2.org
Mon Mar 2 10:29:19 CST 2009
On Mon, Mar 2, 2009 at 16:19, Jason Kraftcheck <kraftche at cae.wisc.edu> wrote:
> A few comments about your patches.
> mhdf.h:
> The change from C++ to C-style comments shouldn't be necessary within the
> '#ifdef __cplusplus' blocks.  But it obviously doesn't hurt anything either.
>  Are there some compiler warnings or some such thing that motivated this change?
Yes, gcc-4.3.3 was giving warnings when compiling ANSI C source.  (I
know it is protected, but maybe the parser is removing comments before
the prepocessor?)
> iMesh_MOAB.cpp:
> The change to the allowable length of the returned string isn't quite the
> right way to fix that bug.  The ITAPS interfaces to not guarantee
> null-terminated strings.  It is the "descr[len] = '\0';" statement that is
> incorrect and should be removed.
I didn't know that about returning non-terminated strings.  I agree
that there are better ways to fix it anyway, but what was there could
obviously write beyond the array.
> Why to you change the default storage order?
Because interleaved is the native storage order. (I don't query the
interface that way, but I believe my change is what was intended.)
Jed
