[MOAB-dev] r2616 - MOAB/branches/parallel_ghosting/parallel
tautges at mcs.anl.gov tautges at mcs.anl.gov
Fri Jan 30 17:48:26 CST 2009
Author: tautges
Date: 2009-01-30 17:48:25 -0600 (Fri, 30 Jan 2009)
New Revision: 2616
Modified:
   MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp
   MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp
   MOAB/branches/parallel_ghosting/parallel/ReadParallel.cpp
   MOAB/branches/parallel_ghosting/parallel/mbparallelcomm_test.cpp
   MOAB/branches/parallel_ghosting/parallel/mhdf_parallel.c
   MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp
Log:
Backing up more changes, almost have reliable interface sharing
working in new code.
Modified: MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp
--- MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp	2009-01-30 21:28:26 UTC (rev 2615)
+++ MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp	2009-01-30 23:48:25 UTC (rev 2616)
@@ -691,7 +691,7 @@
     // entities
   result = pack_entities(orig_ents, buff, buff_ptr,
-                         store_remote_handles, to_proc, owned_shared);
+                         store_remote_handles, to_proc, true, owned_shared);
   RRA("Packing entities failed.");
     // sets
@@ -856,6 +856,7 @@
                                           unsigned char *&buff_ptr,
                                           const bool store_remote_handles,
                                           const int to_proc,
+                                          const bool is_ghost,
                                           MBRange &owned_shared)
     // pack a range of entities into a message, appending to buffer;
@@ -879,7 +880,8 @@
   RRA("Couldn't get MBWriteUtilIface.");
     // non-owned entities don't matter if remote handles aren't stored
-  if (store_remote_handles) {
+    // or if passing interface layer
+  if (store_remote_handles && is_ghost) {
       // get owned, non-owned ents
     MBRange owned_ents, nonowned_ents;
     result = filter_owned_shared(entities,
@@ -915,19 +917,25 @@
       PACK_EH(buff_ptr, &handles[0], nonowned_ents.size());
+      // put owned shared in sharedEnts list
+    owned_shared.merge(owned_ents);
+  if (store_remote_handles) {
       // pack the local handles
     int tmp_space = RANGE_SIZE(entities);
     CHECK_BUFF_SPACE(buff, buff_ptr, tmp_space);
     PACK_RANGE(buff_ptr, entities);
-      // put owned shared in sharedEnts list
-    owned_shared.merge(owned_ents);
     // pack vertices
   MBRange these_ents = entities.subset_by_type(MBVERTEX);
   int num_ents = these_ents.size();
   int buff_size;
+    // if iface, shouldn't be any vertices here
+  assert(is_ghost || num_ents == 0);
   if (num_ents) {
     buff_size = 2*sizeof(int) + 3*num_ents*sizeof(double);
     CHECK_BUFF_SPACE(buff, buff_ptr, buff_size);
@@ -1454,20 +1462,16 @@
                                                   const int ind,
                                                   std::vector<MBEntityHandle> &recd_ents)
-    // for all the entities in the received buffer; for each, save
+    // for all the entities in the received buffer, save
     // entities in this instance which match connectivity, or zero if none found
   MBErrorCode result;
   bool done = false;
   std::vector<MBEntityHandle> connect;
+  unsigned int num_zero = 0;
-    // # non-owned ents should be zero
-  int dum;
-  UNPACK_INT(buff_ptr, dum);
-  assert(0 == dum);
   MBRange remote_range;
   UNPACK_RANGE(buff_ptr, remote_range);
   while (!done) {
     MBEntityType this_type;
     UNPACK_INT(buff_ptr, this_type);
@@ -1508,8 +1512,10 @@
         recd_ents.push_back(*tmp_range.begin());
         tmp_range.clear();
-      else
+      else {
         recd_ents.push_back(0);
+        num_zero++;
 #ifdef DEBUG_PACKING
@@ -1519,8 +1525,6 @@
-  int num_zero = count_if(recd_ents.begin(), recd_ents.end(),
-                          bind2nd(std::equal_to<int>(), 0));
   if (num_zero) {
     result = MB_FAILURE;
     RRA("Didn't find an iface entity.");
@@ -1533,7 +1537,8 @@
                            from_proc);
   RRA("Failed to set remote handles for iface entities.");
-    // add iface entities to sharedEnts list
+    // add iface entities to sharedEnts list; since they were sent to us, assume we
+    // don't own them
   std::copy(recd_ents.begin(), recd_ents.end(),
             mb_range_inserter(sharedEnts[ind].localHandles));
   sharedEnts[ind].remoteHandles.merge(remote_range);
@@ -2858,7 +2863,7 @@
       for (++vit; vit != (mit->first).end(); vit++) {
         int ind = get_buffers(*vit);
         assert(-1 != ind);
-        sharedEnts[ind].ownedShared.merge(mit->second);
+        sharedEnts2.merge(mit->second);
@@ -3128,8 +3133,7 @@
       for (unsigned int j = 0; j < sharing_procs.size() && sharing_procs[j] != -1; j++) {
         if (sharing_procs[j] == (int)procConfig.proc_rank()) continue;
         int ind = get_buffers(sharing_procs[j]);
-        sharedEnts[ind].remoteHandles.insert(sharing_handles[j]);
-        sharedEnts[ind].localHandles.insert(this_ent);
+        sharedEnts2.insert(this_ent);
@@ -3139,7 +3143,7 @@
         assert(sharing_procs[j] > (int)procConfig.proc_rank());
-        sharedEnts[ind].ownedShared.insert(this_ent);
@@ -3152,8 +3156,8 @@
 MBErrorCode MBParallelComm::get_iface_entities(int other_proc,
-                                               int dim,
-                                               MBRange &iface_ents)
+                                               MBRange &iface_ents,
+                                               int dim)
   MBRange iface_sets;
   MBErrorCode result = MB_SUCCESS;
@@ -3365,6 +3369,56 @@
   return MB_SUCCESS;
+MBErrorCode MBParallelComm::populate_shared_ents()
+    // take sharedEnts2 range and separate into appropriate places in sharedEnts
+  sharedEnts.clear();
+  sharedEnts.resize(buffProcs.size());
+  std::vector<int> sharedp(sharedEnts2.size());
+  std::vector<MBEntityHandle> sharedh(sharedEnts2.size());
+  MBErrorCode result = mbImpl->tag_get_data(sharedp_tag(), sharedEnts2, &sharedp[0]);
+  RRA("Couldn't get sharedp tag.");
+  result = mbImpl->tag_get_data(sharedh_tag(), sharedEnts2, &sharedh[0]);
+  RRA("Couldn't get sharedh tag.");
+  int sharedps[MAX_SHARING_PROCS];
+  MBEntityHandle sharedhs[MAX_SHARING_PROCS];
+  MBRange::iterator rit;
+  unsigned int i, j;
+  int ind;
+  for (i = 0, rit = sharedEnts2.begin(); rit != sharedEnts2.end(); rit++, i++) {
+    if (sharedp[i] != -1) {
+        // just pairwise shared
+      ind = get_buffers(sharedp[i]);
+      assert(-1 != ind);
+      sharedEnts[ind].remoteHandles.insert(sharedh[i]);
+      if (sharedp[i] > (int)procConfig.proc_rank())
+        sharedEnts[ind].ownedShared.insert(*rit);
+      else
+        sharedEnts[ind].localHandles.insert(*rit);
+    else {
+      result = mbImpl->tag_get_data(sharedps_tag(), &*rit, 1, sharedps);
+      RRA("Couldn't get sharedps tag.");
+      result = mbImpl->tag_get_data(sharedhs_tag(), sharedEnts2, sharedhs);
+      RRA("Couldn't get sharedhs tag.");
+      for (j = 0; j < MAX_SHARING_PROCS && sharedps[j] != -1; j++) {
+        ind = get_buffers(sharedps[j]);
+        sharedEnts[ind].remoteHandles.insert(sharedhs[j]);
+        if (sharedps[0] == (int)procConfig.proc_rank())
+        else
+      std::fill(sharedps, sharedps+j, -1);
+  return MB_SUCCESS;
 MBErrorCode MBParallelComm::exchange_ghost_cells(int ghost_dim, int bridge_dim,
                                                  int num_layers,
@@ -3374,24 +3428,18 @@
     // remote handles too
   assert(num_layers > 0 || store_remote_handles);
+    // re-populate the sharedEnts data structure
+  MBErrorCode result = populate_shared_ents();
+  RRA("Unable to populate shared ents during ghost exchange.");
     // get the b-dimensional interface(s) with with_proc, where b = bridge_dim
-  MBErrorCode result;
   int success;
   unsigned char *buff_ptr;
-    // get all procs communicating with this proc
-  std::set<unsigned int> comm_procs;
-  result = get_comm_procs(comm_procs);
-  RRA("Failed to get iface sets, procs");
+    // when this function is called, buffProcs should already have any
+    // communicating procs
-    // make sure each proc has an associated buffer
-  int ind;
-  for (std::set<unsigned int>::iterator sit = comm_procs.begin();
-       sit != comm_procs.end(); sit++) {
-    ind = get_buffers(*sit);
-    assert(-1 != ind);
     // post ghost irecv's for ghost entities from all communicating procs
@@ -3399,8 +3447,11 @@
   std::vector<MPI_Request> recv_reqs(buffProcs.size(), MPI_REQUEST_NULL),
       send_reqs(buffProcs.size(), MPI_REQUEST_NULL);
   std::vector<unsigned int>::iterator proc_it;
+  int ind;
   for (ind = 0, proc_it = buffProcs.begin();
        proc_it != buffProcs.end(); proc_it++, ind++) {
+      // for interface, only get ents from higher-rank procs
+    if (0 == num_layers && procConfig.proc_rank() < *proc_it) continue;
     success = MPI_Irecv(&ghostRBuffs[ind][0], ghostRBuffs[ind].size(),
                         MPI_UNSIGNED_CHAR, buffProcs[ind],
                         MB_MESG_ANY, procConfig.proc_comm(),
@@ -3412,13 +3463,14 @@
-    // get entities to be ghosted on neighbors
+    // get entities to be sent to neighbors
     // done in a separate loop over procs because sometimes later procs
     // need to add info to earlier procs' messages
   MBRange sent_ents[MAX_SHARING_PROCS];
   std::set<unsigned int> addl_procs[MAX_SHARING_PROCS], my_addl_procs;
+  int num_higher = 0;
@@ -3426,20 +3478,35 @@
       result = get_ghosted_entities(bridge_dim, ghost_dim, buffProcs[ind],
                                     num_layers, sent_ents[ind], addl_procs);
       RRA("Failed to get ghost layers.");
+        // if we're exchanging ghosts, remove already-shared entities
+      result = filter_owned_shared(sent_ents[ind],
+                                   false, false, true, false, *proc_it);
+      RRA("Failed to filter already-shared entities in ghost exchange.");
     else {
-      result = get_iface_sent_entities(buffProcs[ind], sent_ents[ind]);
+      result = get_iface_entities(buffProcs[ind], sent_ents[ind]);
       RRA("Failed to get interface layers.");
+        // remove vertices here, for efficiency in the filter
+      std::pair<MBRange::const_iterator,MBRange::const_iterator> vert_it =
+          sent_ents[ind].equal_range(MBVERTEX);
+      sent_ents[ind].erase(vert_it.first, vert_it.second);
-    // pack and send ghosteds from this proc to others
+    // pack and send ents from this proc to others
     // initialize sendReqs
+      // if resolving interface, only send to higher-rank procs
+    if (0 == num_layers && procConfig.proc_rank() > *proc_it) continue;
+    num_higher++;
       // get an estimate of the buffer size & pre-allocate buffer size
     unsigned int buff_size = estimate_ents_buffer_size(sent_ents[ind],
@@ -3453,12 +3520,14 @@
       // entities (including info about non-owned ents)
     result = pack_entities(sent_ents[ind], ownerSBuffs[ind], buff_ptr,
                            store_remote_handles, buffProcs[ind],
-                           sharedEnts[ind].ownedShared);
+                           num_layers, sharedEnts[ind].ownedShared);
-      // addl procs
-    result = pack_addl_procs(addl_procs[ind], ownerSBuffs[ind], buff_ptr);
-    RRA("Failed to pack addl procs.");
+      // addl procs, only if not iface layer
+    if (num_layers) {
+      result = pack_addl_procs(addl_procs[ind], ownerSBuffs[ind], buff_ptr);
+      RRA("Failed to pack addl procs.");
       // now we're ready to send the buffer
     result = send_buffer(*proc_it, &ownerSBuffs[ind][0],
@@ -3468,10 +3537,13 @@
-    // receive/unpack new ghost entities
+    // receive/unpack new entities
-    // number of incoming messages FOR GHOSTS is the number of procs we communicate with
+    // number of incoming messages for ghosts is the number of procs we
+    // communicate with; for iface, it's the number of those with lower rank
   int num_incoming = buffProcs.size();
+  if (!num_layers) num_incoming -= num_higher;
   std::vector<MPI_Status> status(buffProcs.size());
   std::vector<std::vector<MBEntityHandle> > recd_ents(num_incoming);
   MBRange new_ghosts[MAX_SHARING_PROCS];
@@ -3534,10 +3606,13 @@
   send_reqs.resize(buffProcs.size());
-    // post recvs for remote handles of my ghosteds
+    // post recvs for remote handles of my sent ents
+      // skip if iface layer and lower-rank proc
+    if (!num_layers && procConfig.proc_rank() > *proc_it) continue;
@@ -3554,6 +3629,8 @@
+      // skip if iface layer and higher-rank proc
+    if (!num_layers && procConfig.proc_rank() < *proc_it) continue;
     buff_ptr = &ghostSBuffs[ind][0];
     if (num_layers)
       result = pack_remote_handles(new_ghosts[ind], *proc_it,
@@ -3572,7 +3649,7 @@
     // process remote handles of my ghosteds
   MBRange new_ghosted;
-  num_incoming = buffProcs.size();
+  num_incoming = (num_layers ? buffProcs.size() : num_higher);
   while (num_incoming) {
     success = MPI_Waitany(buffProcs.size(), &recv_reqs[0], &ind, &status[0]);
     if (MPI_SUCCESS != success) {
@@ -3607,71 +3684,6 @@
     else assert(false);
-    // post recvs for sharedh/p tag
-  std::fill(recv_reqs.begin(), recv_reqs.end(), MPI_REQUEST_NULL);
-  for (ind = 0, proc_it = buffProcs.begin();
-       proc_it != buffProcs.end(); proc_it++, ind++) {
-    success = MPI_Irecv(&ghostRBuffs[ind][0], ghostRBuffs[ind].size(),
-                        MPI_UNSIGNED_CHAR, buffProcs[ind],
-                        MB_MESG_ANY, procConfig.proc_comm(),
-                        &recv_reqs[ind]);
-    if (success != MPI_SUCCESS) {
-      result = MB_FAILURE;
-      RRA("Failed to post irecv in ghost exchange.");
-    // send complete sharedh/p tag to sharing procs for entities I own
-    buff_ptr = &ghostSBuffs[ind][0];
-    result = pack_sharedhps_tag(new_ghosted, sharedEnts[ind].ownedShared,
-                                *proc_it,
-                                ghostSBuffs[ind], buff_ptr);
-    RRA("Failed to pack sharedhs tag.");
-    result = send_buffer(buffProcs[ind], &ghostSBuffs[ind][0],
-                         buff_ptr - &ghostSBuffs[ind][0],
-                         MB_MESG_SHAREDHPS, send_reqs[ind]);
-    RRA("Failed to send remote handles.");
-    // process sharedhp tags for my ghosts
-  while (num_incoming) {
-    success = MPI_Waitany(buffProcs.size(), &recv_reqs[0], &ind, &status[0]);
-    if (MPI_SUCCESS != success) {
-      RRA("Failed in waitany in ghost exchange.");
-      // ok, received something; decrement incoming counter
-    num_incoming--;
-      // branch on message type
-    if (MB_MESG_SIZE == status[0].MPI_TAG) {
-        // incoming message just has size; resize buffer and re-call recv,
-        // then re-increment incoming count
-      int new_size = *((int*)&ghostRBuffs[ind][0]);
-      assert(0 > new_size);
-      result = recv_size_buff(buffProcs[ind], ghostRBuffs[ind], recv_reqs[ind],
-                              MB_MESG_SHAREDHPS);
-      RRA("Failed to resize recv buffer.");
-      num_incoming++;
-    else if (MB_MESG_SHAREDHPS == status[0].MPI_TAG) {
-        // incoming remote handles
-      result = unpack_sharedhps_tag(buffProcs[ind], &ghostRBuffs[ind][0]);
-      RRA("Failed to unpack remote handles.");
-    else assert(false);
   return MB_SUCCESS;
@@ -3817,14 +3829,13 @@
   RRA("Trouble setting remote data range on sent entities in ghost exchange.");
   std::copy(local_handles, local_handles+num_eh, mb_range_inserter(new_ghosted));
+  std::copy(local_handles, local_handles+num_eh,
+            mb_range_inserter(sharedEnts[ind].localHandles));
+  std::copy(remote_handles, remote_handles+num_eh,
+            mb_range_inserter(sharedEnts[ind].remoteHandles));
   buff_ptr += 2*num_eh*sizeof(MBEntityHandle);
-    // if I'm the smaller proc, I own these ents, add these ents to ownedshared
-  if (num_layers || (procConfig.proc_rank() < from_proc))
-    std::copy(local_handles, local_handles+num_eh,
-              mb_range_inserter(sharedEnts[ind].ownedShared));
   return MB_SUCCESS;
@@ -3903,34 +3914,6 @@
   return result;
-MBErrorCode MBParallelComm::get_iface_sent_entities(unsigned int to_proc,
-                                                    MBRange &sent_ents)
-  MBErrorCode result = MB_SUCCESS;
-  for (MBRange::iterator rit = interfaceSets.begin(); rit != interfaceSets.end();
-       rit++) {
-    if (!is_iface_proc(*rit, to_proc)) continue;
-    result = mbImpl->get_entities_by_handle(*rit, sent_ents);
-    RRA("Trouble getting interface set entities.");
-    // remove vertices, assuming they're already shared
-  std::pair<MBRange::const_iterator, MBRange::const_iterator> vit =
-      sent_ents.equal_range(MBVERTEX);
-  sent_ents.erase(vit.first, vit.second);
-    // remove other entities, but only if to_proc is lower
-  if (to_proc < procConfig.proc_rank()) {
-      //,,, need to account for non-owned ents being sent from this proc
-    result = filter_owned_shared(sent_ents,
-                                 true, true, false, false);
-    RRA("Trouble filtering.");
-  return result;
 MBErrorCode MBParallelComm::add_verts(MBRange &sent_ents)
       // get the verts adj to these entities, since we'll have to send those too
Modified: MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp
--- MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp	2009-01-30 21:28:26 UTC (rev 2615)
+++ MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp	2009-01-30 23:48:25 UTC (rev 2616)
@@ -294,8 +294,8 @@
      * \param iface_ents Entities returned from function
   MBErrorCode get_iface_entities(int other_proc,
-                                 int dim,
-                                 MBRange &iface_ents);
+                                 int dim = -1);
     //! return partition sets; if tag_name is input, gets sets with
     //! that tag name, otherwise uses PARALLEL_PARTITION tag
@@ -493,6 +493,7 @@
                             const int to_proc,
+                            const bool is_iface,
                             MBRange &owned_shared);
     //! pack a range of entities with equal # verts per entity, along with
@@ -773,11 +774,6 @@
                                    MBRange &ghosted_ents,
                                    std::set<unsigned int> *addl_procs);
-    //! get interface entities to send, for deriving remote handles of higher-
-    //! dimensional interface entities
-  MBErrorCode get_iface_sent_entities(unsigned int to_proc,
-                                      MBRange &sent_ents);
 public:
     //! add vertices adjacent to entities in this list
   MBErrorCode add_verts(MBRange &sent_ents);
@@ -870,6 +866,9 @@
     //! remove a pc from the iface instance tag PARALLEL_COMM
   void remove_pcomm(MBParallelComm *pc);
+    //! reset and populate sharedEnts from sharedEnts2 range
+  MBErrorCode populate_shared_ents();
     //! MB interface associated with this writer
   MBInterface *mbImpl;
@@ -904,6 +903,7 @@
     //! sharedEnts[i].remoteHandles stores ghost ents from other proc,
     //!    in terms of handles on owning proc
   std::vector<struct GhostStruct> sharedEnts;
+  MBRange sharedEnts2;
     //! tags used to save sharing procs and handles
   MBTag sharedpTag, sharedpsTag, sharedhTag, sharedhsTag, pstatusTag,
Modified: MOAB/branches/parallel_ghosting/parallel/ReadParallel.cpp
--- MOAB/branches/parallel_ghosting/parallel/ReadParallel.cpp	2009-01-30 21:28:26 UTC (rev 2615)
+++ MOAB/branches/parallel_ghosting/parallel/ReadParallel.cpp	2009-01-30 23:48:25 UTC (rev 2616)
@@ -458,7 +458,6 @@
     MBRange tmp_sets;
       // distribute the partition sets
-    unsigned int tot_sets = myPcomm->partition_sets().size();
     unsigned int num_sets = myPcomm->partition_sets().size() / proc_sz;
     unsigned int num_leftover = myPcomm->partition_sets().size() % proc_sz;
     int begin_set = 0;
Modified: MOAB/branches/parallel_ghosting/parallel/mbparallelcomm_test.cpp
--- MOAB/branches/parallel_ghosting/parallel/mbparallelcomm_test.cpp	2009-01-30 21:28:26 UTC (rev 2615)
+++ MOAB/branches/parallel_ghosting/parallel/mbparallelcomm_test.cpp	2009-01-30 23:48:25 UTC (rev 2616)
@@ -422,7 +422,7 @@
     for (int i = 0; i < 4; i++) {
-      tmp_result = pcs[p]->get_iface_entities(-1, i, iface_ents[i]);
+      tmp_result = pcs[p]->get_iface_entities(-1, iface_ents[i], i);
       if (MB_SUCCESS != tmp_result) {
         std::cerr << "get_iface_entities returned error on proc "
Modified: MOAB/branches/parallel_ghosting/parallel/mhdf_parallel.c
--- MOAB/branches/parallel_ghosting/parallel/mhdf_parallel.c	2009-01-30 21:28:26 UTC (rev 2615)
+++ MOAB/branches/parallel_ghosting/parallel/mhdf_parallel.c	2009-01-30 23:48:25 UTC (rev 2616)
@@ -23,6 +23,8 @@
 #include <H5Ppublic.h>
 #include <H5Tpublic.h>
+#include <H5FDmpi.h>
+#include <H5FDmpio.h>
 const char* filename = "mhdf_ll.h5m";
 const char* proc_tag_name = "proc_id";
@@ -43,7 +45,7 @@
 /* create file layout in serial */
 void create_file()
-  const char* elem_types[] = { elem_handle };
+  const char* elem_types[1] = {elem_handle};
   const int num_elem_types = sizeof(elem_types)/sizeof(elem_types[0]);
   const int num_nodes = 4+4*NUM_PROC;
   const int num_hexes = NUM_PROC;
@@ -56,7 +58,8 @@
   hid_t data, tagdata[2];
   long junk;
-  time_t t = time(NULL);
+  time_t t;
+  t = time(NULL);
   history[1] = ctime(&t);
   mhdf_Status status;
@@ -110,6 +113,7 @@
   const int total_num_nodes = 4+4*NUM_PROC;
   const int total_num_hexes = NUM_PROC;
   long first_node, first_elem, first_set, count, ntag;
+  unsigned long ucount;
   long set_desc[4] = { 0, -1, -1, MESHSET_SET };
   hid_t handle, handles[2];
   mhdf_Status status;
@@ -122,14 +126,15 @@
                          0.0, 1.0, 0.0,
                          0.0, 1.0, 1.0,
                          0.0, 0.0, 1.0 };
-  int i, list[10], tagdata[10] = {RANK,RANK,RANK,RANK,RANK,RANK,RANK,RANK,RANK,RANK};
+  int i, list[10], tagdata[10];
+  for (i = 0; i < 10; i++) tagdata[i] = RANK;
   int num_node, offset, dim;
     /* open file */
   handle = H5Pcreate( H5P_FILE_ACCESS );
   H5Pset_fapl_mpio( handle, MPI_COMM_WORLD, MPI_INFO_NULL );
-  file = mhdf_openFileWithOpt( filename, 1, &count, handle, &status );
+  file = mhdf_openFileWithOpt( filename, 1, &ucount, handle, &status );
   CHECK(status);
   H5Pclose( handle );
@@ -249,7 +254,6 @@
 int main( int argc, char* argv[] )
-  mhdf_Status status;
   int rval;
   rval = MPI_Init( &argc, &argv );
Modified: MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp
--- MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp	2009-01-30 21:28:26 UTC (rev 2615)
+++ MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp	2009-01-30 23:48:25 UTC (rev 2616)
@@ -587,7 +587,7 @@
   MBRange iface_ents, shared_ents, owned_ents;
   for (unsigned int i = 0; i < pcomm->buff_procs().size(); i++) {
       // get all the interface entities for this proc and the sharedEnts entities
-    rval = pcomm->get_iface_entities(pcomm->buff_procs()[i], -1, iface_ents);
+    rval = pcomm->get_iface_entities(pcomm->buff_procs()[i], iface_ents);
     if (MB_SUCCESS != rval) my_error = 1;
     owned_ents.merge(pcomm->shared_ents()[i].ownedShared);
     shared_ents.merge(pcomm->shared_ents()[i].localHandles);
