[MOAB-dev] r2615 - in MOAB/trunk/tools/iMesh/SIDL: . mserver
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Fri Jan 30 15:28:26 CST 2009
Author: kraftche
Date: 2009-01-30 15:28:26 -0600 (Fri, 30 Jan 2009)
New Revision: 2615
Modified:
   MOAB/trunk/tools/iMesh/SIDL/Makefile.in
   MOAB/trunk/tools/iMesh/SIDL/mserver/iBase_Error_Impl.cc
   MOAB/trunk/tools/iMesh/SIDL/mserver/iBase_Error_Impl.hh
   MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_Factory_Impl.cc
   MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_SIDL_MeshSidl_Impl.cc
   MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_SIDL_MeshSidl_Impl.hh
Log:
add --suppress-version flag to babel calls
Modified: MOAB/trunk/tools/iMesh/SIDL/Makefile.in
--- MOAB/trunk/tools/iMesh/SIDL/Makefile.in	2009-01-30 21:17:50 UTC (rev 2614)
+++ MOAB/trunk/tools/iMesh/SIDL/Makefile.in	2009-01-30 21:28:26 UTC (rev 2615)
@@ -39,6 +39,7 @@
 BABEL_DIR = @BABEL_DIR@
 USE_BABEL = @USE_BABEL@
 BABEL = $(BABEL_DIR)/bin/babel
+BABELFLAGS = "--suppress-timestamp"
 ECHO = @ECHO@
 CC = @CC@
 CCDEPMODE = @CCDEPMODE@
@@ -215,22 +216,22 @@
 	  done \
 	fi
 	@if test "x$(USE_BABEL)" = "xyes"; then \
-	  $(ECHO) '$(BABEL) -sC++ $(SIDL_FILES_PATH) -o mserver' ; \
-	  $(BABEL) -sC++ $(SIDL_FILES_PATH) -o mserver && touch $@; \
+	  $(ECHO) '$(BABEL) $(BABELFLAGS) -sC++ $(SIDL_FILES_PATH) -o mserver' ; \
+	  $(BABEL) $(BABELFLAGS) -sC++ $(SIDL_FILES_PATH) -o mserver && touch $@; \
 	fi
 Cclient/babel.make: $(SIDL_FILES)
 	test -d Cclient || $(mkdir_p) Cclient || exit 1
-	  $(ECHO) '$(BABEL) -cC $(SIDL_FILES_PATH) -o Cclient' ; \
-	  $(BABEL) -cC $(SIDL_FILES_PATH) -o Cclient && touch $@; \
+	  $(ECHO) '$(BABEL) $(BABELFLAGS) -cC $(SIDL_FILES_PATH) -o Cclient' ; \
+	  $(BABEL) $(BABELFLAGS) -cC $(SIDL_FILES_PATH) -o Cclient && touch $@; \
 	fi
 Fclient/babel.make: $(SIDL_FILES)
 	test -d Fclient || $(mkdir_p) Fclient || exit 1
-	  $(ECHO) '$(BABEL) -cF77 $(SIDL_FILES_PATH) -o Fclient' ; \
-	  $(BABEL) -cF77 $(SIDL_FILES_PATH) -o Fclient && touch $@; \
+	  $(ECHO) '$(BABEL) $(BABELFLAGS) -cF77 $(SIDL_FILES_PATH) -o Fclient' ; \
+	  $(BABEL) $(BABELFLAGS) -cF77 $(SIDL_FILES_PATH) -o Fclient && touch $@; \
 	fi
 .SUFFIXES: .cpp .cc .c .lo
Modified: MOAB/trunk/tools/iMesh/SIDL/mserver/iBase_Error_Impl.cc
--- MOAB/trunk/tools/iMesh/SIDL/mserver/iBase_Error_Impl.cc	2009-01-30 21:17:50 UTC (rev 2614)
+++ MOAB/trunk/tools/iMesh/SIDL/mserver/iBase_Error_Impl.cc	2009-01-30 21:28:26 UTC (rev 2615)
@@ -1,17 +1,13 @@
 // File:          iBase_Error_Impl.cc
-// Symbol:        iBase.Error-v0.7
+// Symbol:        iBase.Error-v0.8
 // Symbol Type:   class
-// Babel Version: 0.10.12
-// sidl Created:  20070628 20:55:23 CDT
-// Generated:     20070628 20:55:31 CDT
+// Babel Version: 0.10.10
 // Description:   Server-side implementation for iBase.Error
 // WARNING: Automatically generated; only changes within splicers preserved
-// babel-version = 0.10.12
-// source-line   = 84
-// source-url    = file:/home/tautges/MOAB/tools/iMesh/SIDL/mserver/../iBase.sidl
+// babel-version = 0.10.10
 #include "iBase_Error_Impl.hh"
Modified: MOAB/trunk/tools/iMesh/SIDL/mserver/iBase_Error_Impl.hh
--- MOAB/trunk/tools/iMesh/SIDL/mserver/iBase_Error_Impl.hh	2009-01-30 21:17:50 UTC (rev 2614)
+++ MOAB/trunk/tools/iMesh/SIDL/mserver/iBase_Error_Impl.hh	2009-01-30 21:28:26 UTC (rev 2615)
@@ -1,17 +1,13 @@
 // File:          iBase_Error_Impl.hh
 #ifndef included_iBase_Error_Impl_hh
@@ -47,7 +43,7 @@
 namespace iBase {
-   * Symbol "iBase.Error" (version 0.7)
+   * Symbol "iBase.Error" (version 0.8)
   class Error_impl
   // DO-NOT-DELETE splicer.begin(iBase.Error._inherits)
Modified: MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_Factory_Impl.cc
--- MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_Factory_Impl.cc	2009-01-30 21:17:50 UTC (rev 2614)
+++ MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_Factory_Impl.cc	2009-01-30 21:28:26 UTC (rev 2615)
@@ -1,17 +1,13 @@
 // File:          iMesh_Factory_Impl.cc
-// Symbol:        iMesh.Factory-v0.7
+// Symbol:        iMesh.Factory-v0.8
-// sidl Created:  20080414 17:40:04 GMT
-// Generated:     20080414 17:40:09 GMT
 // Description:   Server-side implementation for iMesh.Factory
-// source-line   = 296
-// source-url    = file:/home/tautges/MOAB/tools/iMesh/SIDL/iMesh.sidl
 #include "iMesh_Factory_Impl.hh"
Modified: MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_SIDL_MeshSidl_Impl.cc
--- MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_SIDL_MeshSidl_Impl.cc	2009-01-30 21:17:50 UTC (rev 2614)
+++ MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_SIDL_MeshSidl_Impl.cc	2009-01-30 21:28:26 UTC (rev 2615)
@@ -3,15 +3,11 @@
 // Symbol:        iMesh_SIDL.MeshSidl-v0.2
-// sidl Created:  20090130 09:34:06 CST
-// Generated:     20090130 09:34:08 CST
 // Description:   Server-side implementation for iMesh_SIDL.MeshSidl
-// source-line   = 5
-// source-url    = file:/home/jason/moab/clean/sidl/tools/iMesh/SIDL/../../../../src/tools/iMesh/SIDL/iMesh_SIDL.sidl
 #include "iMesh_SIDL_MeshSidl_Impl.hh"
@@ -1575,7 +1571,8 @@
   /* in */ ::iBase::EntityType entity_type_requested,
   /* inout */ ::sidl::array<void*>& adj_entity_handles,
   /* out */ int32_t& adj_entity_handles_size,
-  /* inout */ ::sidl::array<int32_t>& offset )
+  /* inout */ ::sidl::array<int32_t>& offset,
+  /* out */ int32_t& offset_size )
 throw (
   ::iBase::Error
Modified: MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_SIDL_MeshSidl_Impl.hh
--- MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_SIDL_MeshSidl_Impl.hh	2009-01-30 21:17:50 UTC (rev 2614)
+++ MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_SIDL_MeshSidl_Impl.hh	2009-01-30 21:28:26 UTC (rev 2615)
@@ -2,16 +2,12 @@
 // File:          iMesh_SIDL_MeshSidl_Impl.hh
-// sidl Created:  20070927 14:57:59 CDT
-// Generated:     20070927 14:58:06 CDT
-// source-line   = 5
-// source-url    = file:/home/tautges/MOAB/tools/iMesh/SIDL/iMesh_SIDL.sidl
 #ifndef included_iMesh_SIDL_MeshSidl_Impl_hh
@@ -664,7 +660,7 @@
     void
     addEntToSet (
       /* in */ void* entity_handle,
-      /* inout */ void*& entity_set
+      /* in */ void* entity_set
     throw (
       ::iBase::Error
@@ -676,7 +672,7 @@
     void
     rmvEntFromSet (
     throw (
       ::iBase::Error
@@ -689,7 +685,7 @@
     addEntArrToSet (
       /* in */ ::sidl::array<void*> entity_handles,
       /* in */ int32_t entity_handles_size,
     throw (
       ::iBase::Error
@@ -702,7 +698,7 @@
     rmvEntArrFromSet (
     throw (
       ::iBase::Error
@@ -714,7 +710,7 @@
     void
     addEntSet (
       /* in */ void* entity_set_to_add,
-      /* inout */ void*& entity_set_handle
+      /* in */ void* entity_set_handle
     throw (
       ::iBase::Error
@@ -726,7 +722,7 @@
     void
     rmvEntSet (
       /* in */ void* entity_set_to_remove,
     throw (
       ::iBase::Error
@@ -749,6 +745,20 @@
      * user defined non-static method.
     void
+    isEntArrContained (
+      /* in */ void* containing_set,
+      /* in */ ::sidl::array<void*> entity_handles,
+      /* in */ int32_t entity_handles_size,
+      /* inout */ ::sidl::array<int32_t>& is_contained,
+      /* out */ int32_t& is_contained_size
+    throw ()
+     * user defined non-static method.
+    void
     isEntSetContained (
       /* in */ void* containing_entity_set,
       /* in */ void* contained_entity_set,
@@ -763,8 +773,8 @@
     void
     addPrntChld (
-      /* inout */ void*& parent_entity_set,
-      /* inout */ void*& child_entity_set
+      /* in */ void* parent_entity_set,
+      /* in */ void* child_entity_set
     throw (
       ::iBase::Error
@@ -775,8 +785,8 @@
     void
     rmvPrntChld (
     throw (
       ::iBase::Error
@@ -940,6 +950,17 @@
     void
+    setGeometricDim (
+      /* in */ int32_t dim
+    throw (
+      ::iBase::Error
+    void
     getDfltStorage (
       /* out */ ::iBase::StorageOrder& dflt_storage
@@ -1001,42 +1022,6 @@
     void
-    getAllVtxCoords (
-      /* in */ void* entity_set,
-      /* inout */ ::sidl::array<double>& coords,
-      /* out */ int32_t& coords_size,
-      /* inout */ ::sidl::array<int32_t>& in_entity_set,
-      /* out */ int32_t& in_entity_set_size,
-      /* inout */ ::iBase::StorageOrder& storage_order
-    throw (
-      ::iBase::Error
-     * user defined non-static method.
-    void
-    getVtxCoordIndex (
-      /* in */ ::iBase::EntityType requested_entity_type,
-      /* in */ ::iMesh::EntityTopology requested_entity_topology,
-      /* in */ ::iBase::EntityType entity_adjacency_type,
-      /* inout */ ::sidl::array<int32_t>& offset,
-      /* out */ int32_t& offset_size,
-      /* inout */ ::sidl::array<int32_t>& index,
-      /* out */ int32_t& index_size,
-      /* inout */ ::sidl::array< ::iMesh::EntityTopology>& entity_topologies,
-      /* out */ int32_t& entity_topologies_size
-    throw (
-      ::iBase::Error
-    void
     getEntities (
       /* in */ ::iBase::EntityType entity_type,
@@ -1075,9 +1060,7 @@
     throw (
       ::iBase::Error
@@ -1087,6 +1070,28 @@
     void
+    getAdjEntIndices (
+      /* in */ void* entity_set_handle,
+      /* in */ ::iBase::EntityType entity_type_requestor,
+      /* in */ ::iMesh::EntityTopology entity_topology_requestor,
+      /* in */ ::iBase::EntityType entity_type_requested,
+      /* inout */ ::sidl::array<void*>& entity_handles,
+      /* out */ int32_t& entity_handles_size,
+      /* inout */ ::sidl::array<void*>& adj_entity_handles,
+      /* out */ int32_t& adj_entity_handles_size,
+      /* inout */ ::sidl::array<int32_t>& adj_entity_indices,
+      /* out */ int32_t& adj_entity_indices_size,
+    throw (
+      ::iBase::Error
+    void
     initEntIter (
