[MOAB-dev] r2606 - in MOAB/branches/parallel_ghosting: .	mhdf/include mhdf/src parallel tools/iMesh
    tautges at mcs.anl.gov
    Fri Jan 30 12:38:38 CST 2009
Author: tautges
Date: 2009-01-30 12:38:37 -0600 (Fri, 30 Jan 2009)
New Revision: 2606
Modified:
   MOAB/branches/parallel_ghosting/MBCore.cpp
   MOAB/branches/parallel_ghosting/MeshTopoUtil.cpp
   MOAB/branches/parallel_ghosting/MeshTopoUtil.hpp
   MOAB/branches/parallel_ghosting/mhdf/include/mhdf.h
   MOAB/branches/parallel_ghosting/mhdf/src/file-handle.h
   MOAB/branches/parallel_ghosting/mhdf/src/sets.c
   MOAB/branches/parallel_ghosting/mhdf/src/tags.c
   MOAB/branches/parallel_ghosting/mhdf/src/util.h
   MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp
   MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp
   MOAB/branches/parallel_ghosting/parallel/WriteHDF5Parallel.cpp
   MOAB/branches/parallel_ghosting/parallel/crystal.c
   MOAB/branches/parallel_ghosting/parallel/mbparallelcomm_test.cpp
   MOAB/branches/parallel_ghosting/parallel/parallel_hdf5_test.cc
   MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp
   MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp
   MOAB/branches/parallel_ghosting/tools/iMesh/iMeshP.h
   MOAB/branches/parallel_ghosting/tools/iMesh/iMeshP_MOAB.cpp
Log:
Backing up changes to parallel ghosting code before starting on
(yet another) redesign.
Modified: MOAB/branches/parallel_ghosting/MBCore.cpp
--- MOAB/branches/parallel_ghosting/MBCore.cpp	2009-01-30 18:11:39 UTC (rev 2605)
+++ MOAB/branches/parallel_ghosting/MBCore.cpp	2009-01-30 18:38:37 UTC (rev 2606)
@@ -208,6 +208,15 @@
 void MBCore::deinitialize()
+#ifdef USE_MPI
+  std::vector<MBParallelComm*> pc_list;
+  MBErrorCode result = MBParallelComm::get_all_pcomm(this, pc_list);
+  for (std::vector<MBParallelComm*>::iterator vit = pc_list.begin();
+       vit != pc_list.end(); vit++)
+    delete *vit;
+#endif
   if (aEntityFactory)
     delete aEntityFactory;
Modified: MOAB/branches/parallel_ghosting/MeshTopoUtil.cpp
--- MOAB/branches/parallel_ghosting/MeshTopoUtil.cpp	2009-01-30 18:11:39 UTC (rev 2605)
+++ MOAB/branches/parallel_ghosting/MeshTopoUtil.cpp	2009-01-30 18:38:37 UTC (rev 2606)
@@ -392,6 +392,39 @@
     //! get "bridge" or "2nd order" adjacencies, going through dimension bridge_dim
+MBErrorCode MeshTopoUtil::get_bridge_adjacencies(MBRange &from_entities,
+                                                 int bridge_dim,
+                                                 int to_dim,
+                                                 MBRange &to_ents,
+                                                 int num_layers)
+  MBRange bridge_ents, last_toents, new_toents(from_entities);
+  MBErrorCode result;
+  if (0 == num_layers || from_entities.empty()) return MB_FAILURE;
+    // for each layer, get bridge-adj entities and accumulate
+  for (int nl = 0; nl < num_layers; nl++) {
+    MBRange new_bridges;
+      // get bridge ents
+    result = mbImpl->get_adjacencies(new_toents, bridge_dim, true, new_bridges,
+                                     MBInterface::UNION);
+    if (MB_SUCCESS != result) return result;
+      // get to_dim adjacencies, merge into to_ents
+    last_toents =  to_ents;
+    result = mbImpl->get_adjacencies(new_bridges, to_dim, false, to_ents,
+      // subtract last_toents to get new_toents
+    if (nl < num_layers-1)
+      new_toents = to_ents.subtract(last_toents);
+  return MB_SUCCESS;
+    //! get "bridge" or "2nd order" adjacencies, going through dimension bridge_dim
 MBErrorCode MeshTopoUtil::get_bridge_adjacencies(const MBEntityHandle from_entity,
                                                  const int bridge_dim,
                                                  const int to_dim,
Modified: MOAB/branches/parallel_ghosting/MeshTopoUtil.hpp
--- MOAB/branches/parallel_ghosting/MeshTopoUtil.hpp	2009-01-30 18:11:39 UTC (rev 2605)
+++ MOAB/branches/parallel_ghosting/MeshTopoUtil.hpp	2009-01-30 18:38:37 UTC (rev 2606)
@@ -89,6 +89,13 @@
                                MBEntityHandle &next_dp1);
+  MBErrorCode get_bridge_adjacencies(MBRange &from_entities,
+                                     int bridge_dim,
+                                     int to_dim,
+                                     MBRange &to_ents,
+                                     int num_layers = 1);
   MBErrorCode get_bridge_adjacencies(const MBEntityHandle from_entity,
                                      const int to_dim,
Modified: MOAB/branches/parallel_ghosting/mhdf/include/mhdf.h
--- MOAB/branches/parallel_ghosting/mhdf/include/mhdf.h	2009-01-30 18:11:39 UTC (rev 2605)
+++ MOAB/branches/parallel_ghosting/mhdf/include/mhdf.h	2009-01-30 18:38:37 UTC (rev 2606)
@@ -2250,7 +2250,7 @@
 #ifdef __cplusplus
-} // extern "C"
+} /* extern "C" */
 #endif
 #endif
Modified: MOAB/branches/parallel_ghosting/mhdf/src/file-handle.h
--- MOAB/branches/parallel_ghosting/mhdf/src/file-handle.h	2009-01-30 18:11:39 UTC (rev 2605)
+++ MOAB/branches/parallel_ghosting/mhdf/src/file-handle.h	2009-01-30 18:38:37 UTC (rev 2606)
@@ -39,7 +39,7 @@
 int mhdf_check_valid_file( FileHandle* handle, mhdf_Status* status );
 #ifdef __cplusplus
-} // extern "C"
+} /* extern "C" */
 #endif
 #endif
Modified: MOAB/branches/parallel_ghosting/mhdf/src/sets.c
--- MOAB/branches/parallel_ghosting/mhdf/src/sets.c	2009-01-30 18:11:39 UTC (rev 2605)
+++ MOAB/branches/parallel_ghosting/mhdf/src/sets.c	2009-01-30 18:38:37 UTC (rev 2606)
@@ -215,7 +215,7 @@
   herr_t rval = 0;
   int dims, i;
   const int fill_val = -1;
   if (offset < 0 || count < 0)
     mhdf_setFail( status, "Invalid input for %s: "
Modified: MOAB/branches/parallel_ghosting/mhdf/src/tags.c
--- MOAB/branches/parallel_ghosting/mhdf/src/tags.c	2009-01-30 18:11:39 UTC (rev 2605)
+++ MOAB/branches/parallel_ghosting/mhdf/src/tags.c	2009-01-30 18:38:37 UTC (rev 2606)
@@ -743,7 +743,6 @@
   hid_t type_id;
   int rank;
   hsize_t dims[H5S_MAX_RANK];
-  int perm[H5S_MAX_RANK];
   type_id = H5Aget_type( attrib_id );
   switch (H5Tget_class(type_id)) {
@@ -821,7 +820,6 @@
   unsigned int index;
   int rank, var_data;
   H5T_class_t class_tmp;
   API_BEGIN;
Modified: MOAB/branches/parallel_ghosting/mhdf/src/util.h
--- MOAB/branches/parallel_ghosting/mhdf/src/util.h	2009-01-30 18:11:39 UTC (rev 2605)
+++ MOAB/branches/parallel_ghosting/mhdf/src/util.h	2009-01-30 18:38:37 UTC (rev 2606)
@@ -155,7 +155,7 @@
 #ifdef __cplusplus
-} // extern "C"
+} /* extern "C" */
 #endif
 #endif
Modified: MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp
--- MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp	2009-01-30 18:11:39 UTC (rev 2605)
+++ MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp	2009-01-30 18:38:37 UTC (rev 2606)
@@ -13,6 +13,7 @@
 #include "ElementSequence.hpp"
 #include "MBCN.hpp"
 #include "RangeMap.hpp"
+#include "MeshTopoUtil.hpp"
 #include <iostream>
 #include <algorithm>
@@ -21,7 +22,6 @@
 #define MIN(a,b) (a < b ? a : b)
 #define MAX(a,b) (a > b ? a : b)
 const bool debug = false;
-const bool debug_packing = false;
 #include <math.h>
 #include <assert.h>
@@ -43,7 +43,7 @@
 #define INITIAL_BUFF_SIZE 1024
-//#define DEBUG_PACKING 1
+#undef DEBUG_PACKING
 #ifdef DEBUG_PACKING
 unsigned int __PACK_num = 0, __UNPACK_num = 0, __PACK_count = 0, __UNPACK_count = 0;
 std::string __PACK_string, __UNPACK_string;
@@ -100,7 +100,14 @@
 #define UNPACK_RANGE(buff, rng) {int num_subs; UNPACK_INTS(buff, &num_subs, 1); UPC(num_subs, "-subranged range"); MBEntityHandle _eh[2]; \
           for (int i = 0; i < num_subs; i++) { UNPACK_EH(buff, _eh, 2); rng.insert(_eh[0], _eh[1]);}}
+#define CHECK_BUFF_SPACE(buff_vec, buff_ptr, addl_space) { \
+      unsigned int _new_size = buff_ptr - &buff_vec[0] + (addl_space);  \
+    if (_new_size > buff_vec.capacity()) {  \
+      buff_vec.reserve(1.5*_new_size); \
+      buff_vec.resize(_new_size - (addl_space));            \
+      buff_ptr = &buff_vec[_new_size-(addl_space)];}}
+#define RANGE_SIZE(rng) (2*sizeof(MBEntityHandle)*num_subranges(rng)+sizeof(int))
 #define RR(a) if (MB_SUCCESS != result) {\
           dynamic_cast<MBCore*>(mbImpl)->get_error_handler()->set_last_error(a);\
           return result;}
@@ -133,14 +140,15 @@
 enum MBMessageTag {MB_MESG_ANY=MPI_ANY_TAG,
                    MB_MESG_SIZE,
                    MB_MESG_ENTS,
-                   MB_MESG_REMOTE_HANDLES_RANGE,
-                   MB_MESG_REMOTE_HANDLES_VECTOR,
+                   MB_MESG_REMOTE_HANDLES,
+                   MB_MESG_SHAREDHPS,
                    MB_MESG_TAGS };
 MBParallelComm::MBParallelComm(MBInterface *impl, MPI_Comm comm, int* id )
-    : mbImpl(impl), procConfig(comm), sharedpTag(0), sharedpsTag(0),
-      sharedhTag(0), sharedhsTag(0), pstatusTag(0), ifaceSetsTag(0),
-      partitionTag(0), globalPartCount(-1), partitioningSet(0)
+        : mbImpl(impl), procConfig(comm),
+          sharedpTag(0), sharedpsTag(0),
+          sharedhTag(0), sharedhsTag(0), pstatusTag(0), ifaceSetsTag(0),
+          partitionTag(0), globalPartCount(-1), partitioningSet(0)
   myBuffer.resize(INITIAL_BUFF_SIZE);
@@ -166,7 +174,8 @@
                                std::vector<unsigned char> &tmp_buff,
                                MPI_Comm comm,
                                int* id)
@@ -306,6 +315,7 @@
   return MB_SUCCESS;
 MBErrorCode MBParallelComm::send_entities(const int to_proc,
                                           MBRange &orig_ents,
                                           const bool adjs,
@@ -400,38 +410,41 @@
   return result;
-int MBParallelComm::get_buffers(int to_proc)
+int MBParallelComm::get_buffers(int to_proc, bool *is_new)
   int ind = -1;
-  std::vector<int>::iterator vit =
+  std::vector<unsigned int>::iterator vit =
     std::find(buffProcs.begin(), buffProcs.end(), to_proc);
   if (vit == buffProcs.end()) {
     ind = buffProcs.size();
-    buffProcs.push_back(to_proc);
-    ownerSBuffs[ind].resize(INITIAL_BUFF_SIZE);
-    ghostRBuffs[ind].resize(INITIAL_BUFF_SIZE);
+    buffProcs.push_back((unsigned int)to_proc);
+    ownerSBuffs.push_back(std::vector<unsigned char>(INITIAL_BUFF_SIZE));
+    ghostRBuffs.push_back(std::vector<unsigned char>(INITIAL_BUFF_SIZE));
       // allocate these other buffs in case we're storing remote handles
-    ownerRBuffs[ind].resize(INITIAL_BUFF_SIZE);
-    ghostSBuffs[ind].resize(INITIAL_BUFF_SIZE);
+    ownerRBuffs.push_back(std::vector<unsigned char>(INITIAL_BUFF_SIZE));
+    ghostSBuffs.push_back(std::vector<unsigned char>(INITIAL_BUFF_SIZE));
+    sharedEnts.push_back(GhostStruct());
+    if (is_new) *is_new = true;
-  else ind = vit - buffProcs.begin();
+  else {
+    ind = vit - buffProcs.begin();
+    if (is_new) *is_new = false;
   assert(ind < MAX_SHARING_PROCS);
   return ind;
 MBErrorCode MBParallelComm::pack_send_entities(const int to_proc,
                                                MBRange &orig_ents,
-                                               const bool adjacencies,
-                                               const bool tags,
+                                               std::set<int> &addl_procs,
                                                const bool store_remote_handles,
                                                const bool iface_layer,
                                                std::vector<unsigned char> &send_buff,
                                                std::vector<unsigned char> &recv_buff,
                                                MPI_Request &send_req,
-                                               MPI_Request &recv_req,
-                                               MBRange &final_ents)
+                                               MPI_Request &recv_req)
 #ifndef USE_MPI
   return MB_FAILURE;
@@ -439,11 +452,16 @@
   MBErrorCode result = MB_SUCCESS;
   MBRange whole_range;
-  int buff_size;
-  result = pack_buffer(orig_ents, adjacencies, tags,
+    // get an estimate of the buffer size
+  int buff_size = estimate_ents_buffer_size(orig_ents, store_remote_handles);
+  send_buff.clear();
+  send_buff.reserve(buff_size);
+  result = pack_buffer(orig_ents, addl_procs,
                        store_remote_handles, iface_layer, to_proc,
-                       final_ents, send_buff, buff_size);
+                       send_buff, buff_size);
   RRA("Failed to pack buffer in pack_send.");
     // now that we know how many entities, post a receive for the
@@ -466,11 +484,14 @@
     if (success != MPI_SUCCESS) return MB_FAILURE;
     // if the message is large, send a first message to tell how large
+  int success;
   if (INITIAL_BUFF_SIZE < buff_size) {
     int tmp_buff_size = -buff_size;
-    int success = MPI_Send(&tmp_buff_size, sizeof(int), MPI_UNSIGNED_CHAR,
-                           to_proc, MB_MESG_SIZE, procConfig.proc_comm());
+    success = MPI_Isend(&tmp_buff_size, sizeof(int), MPI_UNSIGNED_CHAR,
+                            to_proc, MB_MESG_SIZE, procConfig.proc_comm(),
+                            &send_req);
@@ -478,11 +499,43 @@
   success = MPI_Isend(&send_buff[0], buff_size, MPI_UNSIGNED_CHAR, to_proc,
                       MB_MESG_ENTS, procConfig.proc_comm(), &send_req);
   return result;
 #endif
+MBErrorCode MBParallelComm::send_buffer(const unsigned int to_proc,
+                                        const unsigned char *send_buff,
+                                        const unsigned int buff_size,
+                                        const int msg_type,
+                                        MPI_Request &send_req)
+#ifndef USE_MPI
+  return MB_FAILURE;
+#else
+  MBErrorCode result = MB_SUCCESS;
+  int success;
+    // if the message is large, send a first message to tell how large
+  if (INITIAL_BUFF_SIZE < buff_size) {
+    int tmp_buff_size = -buff_size;
+    int success = MPI_Isend(&tmp_buff_size, sizeof(int), MPI_UNSIGNED_CHAR,
+                            &send_req);
+    if (success != MPI_SUCCESS) return MB_FAILURE;
+    // send the buffer
+  success = MPI_Isend(const_cast<unsigned char*>(send_buff), buff_size, MPI_UNSIGNED_CHAR, to_proc,
+                      msg_type, procConfig.proc_comm(), &send_req);
+  return result;
+#endif
 MBErrorCode MBParallelComm::recv_size_buff(const int from_proc,
@@ -499,64 +552,7 @@
   return MB_SUCCESS;
-MBErrorCode MBParallelComm::recv_unpack_entities(const int from_proc,
-                                                 const bool store_remote_handles,
-                                                 const bool iface_layer,
-                                                 std::vector<unsigned char> &recv_buff,
-                                                 std::vector<unsigned char> &send_buff,
-                                                 MPI_Request &send_req,
-                                                 MBRange &recd_ents)
-#ifndef USE_MPI
-  return MB_FAILURE;
-#else
-  MBErrorCode result = MB_SUCCESS;
-    // unpack the buffer
-  if (iface_layer) {
-    std::vector<MBEntityHandle> recd_ents_tmp;
-    unsigned char *buff_ptr = &recv_buff[0];
-    result = unpack_iface_entities(buff_ptr, from_proc, recd_ents_tmp);
-    RRA("Failed to unpack buffer in recv_unpack.");
-    if (store_remote_handles) {
-      int recd_size = recd_ents_tmp.size()*sizeof(MBEntityHandle) +
-          sizeof(int);
-      send_buff.resize(recd_size);
-      unsigned char *buff_ptr = &send_buff[0];
-      PACK_INT(buff_ptr, recd_ents_tmp.size());
-      PACK_EH(buff_ptr, &recd_ents_tmp[0], recd_ents_tmp.size());
-      int success = MPI_Isend(&send_buff[0], recd_size, MPI_UNSIGNED_CHAR, from_proc,
-                              MB_MESG_REMOTE_HANDLES_VECTOR, procConfig.proc_comm(), &send_req);
-      if (success != MPI_SUCCESS) {
-        result = MB_FAILURE;
-        RRA("Failed to send handles in recv_unpack.");
-    std::copy(recd_ents_tmp.begin(), recd_ents_tmp.end(), mb_range_inserter(recd_ents));
-  else {
-    result = unpack_buffer(&recv_buff[0], store_remote_handles, from_proc, recd_ents);
-      int recd_size = 2*num_subranges(recd_ents)*sizeof(MBEntityHandle) + sizeof(int);
-      PACK_RANGE(buff_ptr, recd_ents);
-                          MB_MESG_REMOTE_HANDLES_RANGE, procConfig.proc_comm(), &send_req);
-  return result;
-#endif
 MBErrorCode MBParallelComm::broadcast_entities( const int from_proc,
                                                 MBRange &entities,
@@ -568,14 +564,18 @@
   int success;
-  MBRange whole_range;
   int buff_size;
   std::vector<unsigned char> buff;
+  std::vector<int> addl_procs;
   if ((int)procConfig.proc_rank() == from_proc) {
-    result = pack_buffer( entities, adjacencies, tags,
-                          false, false, -1,
-                          whole_range, buff, buff_size);
+    MBRange tmp_ents;
+    result = add_verts(entities);
+    RRA("Failed to add adj vertices.");
+    entities.swap(tmp_ents);
+    result = pack_buffer( entities, addl_procs, adjacencies, tags,
+                          false, -1, tmp_ents, buff, buff_size);
     RRA("Failed to compute buffer size in broadcast_entities.");
@@ -598,7 +598,9 @@
   if ((int)procConfig.proc_rank() != from_proc) {
-    result = unpack_buffer(&buff[0], false, from_proc, entities);
+    std::set<unsigned int> my_addl_procs;
+    result = unpack_buffer(&buff[0], false, from_proc, -1, entities,
+                           NULL, my_addl_procs);
     RRA("Failed to unpack buffer in broadcast_entities.");
@@ -607,16 +609,17 @@
 MBErrorCode MBParallelComm::pack_buffer(MBRange &orig_ents,
+                                        std::vector<int> &addl_procs,
                                         const bool tags,
                                         const int to_proc,
-                                        MBRange &final_ents,
+                                        MBRange &owned_shared,
                                         std::vector<unsigned char> &buff,
                                         int &buff_size)
     // pack the buffer with the entity ranges, adjacencies, and tags sections
+    // if do_filter is true, remove already shared entities and add adj vertices
     // Note: new entities used in subsequent connectivity lists, sets, or tags,
     //   are referred to as (MBMAXTYPE + index), where index is into vector
@@ -624,6 +627,12 @@
     // DATA LAYOUT IN BUFFER:
     // . w/ handles ? (0-no, 1-yes, range, 2-yes, vector)
+    // OWNING PROC INFO:
+    // . # owning proc tuples
+    // . for each tuple:
+    //   - index in entities in this message
+    //   - proc owning this entity
+    //   - handle on owning proc
     // ENTITIES:
     // . for all types:
     //   - ent_type -- end of data indicated by ent_type == MBMAXTYPE
@@ -664,9 +673,6 @@
   MBErrorCode result;
-  std::vector<MBEntityType> ent_types;
-  std::vector<MBRange> all_ranges;
-  std::vector<int> verts_per_entity;
   MBRange set_range;
   std::vector<MBRange> set_ranges;
   std::vector<MBTag> all_tags;
@@ -674,119 +680,54 @@
   std::vector<int> set_sizes;
   std::vector<unsigned int> options_vec;
-  buff_size = 0;
   MBRange::const_iterator rit;
-    // count first...
-  unsigned char *buff_ptr = NULL;
+  buff_size = estimate_ents_buffer_size(orig_ents, store_remote_handles);
+  buff.clear();
+  buff.resize(buff_size);
+  unsigned char *buff_ptr = &buff[0];
     // entities
-  result = pack_entities(orig_ents, rit, final_ents, buff_ptr,
-                         buff_size, true, store_remote_handles,
-                         iface_layer, to_proc, ent_types, all_ranges,
-                         verts_per_entity);
-  RRA("Packing entities (count) failed.");
+  result = pack_entities(orig_ents, buff, buff_ptr,
+                         store_remote_handles, to_proc, owned_shared);
+  RRA("Packing entities failed.");
     // sets
-  result = pack_sets(orig_ents, rit, final_ents, buff_ptr, buff_size, true,
-                     store_remote_handles, to_proc, set_range, set_ranges,
-                     set_sizes, options_vec);
+  result = pack_sets(orig_ents, buff, buff_ptr,
+                     store_remote_handles, to_proc);
   RRA("Packing sets (count) failed.");
-    // adjacencies
-  if (adjacencies) {
-    result = pack_adjacencies(orig_ents, rit, final_ents, buff_ptr,
-                              buff_size, true,
-                              store_remote_handles, to_proc);
-    RRA("Packing adjs (count) failed.");
     // tags
+  MBRange final_ents;
   if (tags) {
-    result = get_tag_send_list( final_ents, all_tags, tag_ranges );
-    RRA("Failed to get tagged entities.")
-    result = pack_tags(orig_ents, rit, final_ents, buff_ptr,
-                       buff_size, true, store_remote_handles, to_proc,
-                       all_tags, tag_ranges);
+    result = get_tag_send_list(orig_ents, all_tags, tag_ranges );
+    RRA("Failed to get tagged entities.");
+    result = pack_tags(orig_ents, all_tags, tag_ranges,
+                       buff, buff_ptr, store_remote_handles, to_proc);
     RRA("Packing tags (count) failed.");
-    // now do the real packing
-  assert(0 <= buff_size);
-  buff.resize(buff_size);
-  int orig_buff_size = buff_size;
-  buff_size = 0;
-  buff_ptr = &buff[0];
-    // entities
-                         buff_size, false, store_remote_handles,
-                         all_ranges, verts_per_entity);
-  RRA("Packing entities (real) failed.");
-#ifdef DEBUG_PACKING
-  std::cerr << "pack_entities buffer space: " << buff_ptr - &buff[0] << " bytes." << std::endl;
-  unsigned char *tmp_buff = buff_ptr;
-#endif
-    // sets
-  result = pack_sets(orig_ents, rit, final_ents, buff_ptr, buff_size, false,
-  RRA("Packing sets (real) failed.");
-  std::cerr << "pack_sets buffer space: " << buff_ptr - tmp_buff << " bytes." << std::endl;
-  tmp_buff = buff_ptr;
-#endif
-    // adjacencies
-                              buff_size, false,
-    RRA("Packing adjs (real) failed.");
-    // tags
-  if (tags) {
-                       buff_size, false, store_remote_handles, to_proc, all_tags,
-                       tag_ranges);
-    RRA("Packing tags (real) failed.");
-    std::cerr << "pack_tags buffer space: " << buff_ptr - tmp_buff << " bytes." << std::endl;
-#endif
-    // original buffer size might be larger, because some
-    // ranges of local handles pack into more compact ranges of
-    // remote handles (because they're expressed using MBMAXTYPE plus
-    // index in new entity range, and that list of entities is likely
-    // to be compact)
-  assert(orig_buff_size >= buff_size);
   return result;
 MBErrorCode MBParallelComm::unpack_buffer(unsigned char *buff_ptr,
-                                          int from_proc,
+                                          const int from_proc,
+                                          const int ind,
+                                          MBRange &final_ents,
+                                          MBRange *nonowned_ghosts,
+                                          std::set<unsigned int> &my_addl_procs)
   if (myBuffer.capacity() == 0) return MB_FAILURE;
 #endif
-  MBErrorCode result = unpack_entities(buff_ptr, store_remote_handles,
-                                       from_proc, final_ents);
+    result = unpack_entities(buff_ptr, store_remote_handles,
+                             from_proc, ind, final_ents, nonowned_ghosts, my_addl_procs);
   RRA("Unpacking entities failed.");
     std::cerr << "unpack_entities buffer space: " << buff_ptr - tmp_buff << " bytes." << std::endl;
@@ -825,230 +766,332 @@
   return num_sub_ranges;
+int MBParallelComm::estimate_ents_buffer_size(MBRange &entities,
+                                              const bool store_remote_handles)
+  int buff_size = 0;
+  std::vector<MBEntityHandle> dum_connect_vec;
+  const MBEntityHandle *connect;
+  int num_connect;
+  int num_verts = entities.num_of_type(MBVERTEX);
+    // # verts + coords + handles
+  buff_size += 2*sizeof(int) + 3*sizeof(double)*num_verts;
+  if (store_remote_handles) buff_size += sizeof(MBEntityHandle)*num_verts;
+    // do a rough count by looking at first entity of each type
+  for (MBEntityType t = MBEDGE; t < MBENTITYSET; t++) {
+    const MBRange::iterator rit = entities.lower_bound(t);
+    if (TYPE_FROM_HANDLE(*rit) != t) continue;
+    MBErrorCode result = mbImpl->get_connectivity(*rit, connect, num_connect,
+                                                  true, &dum_connect_vec);
+    RRA("Failed to get connectivity to estimate buffer size.");
+      // number, type, nodes per entity
+    buff_size += 3*sizeof(int);
+    int num_ents = entities.num_of_type(t);
+      // connectivity, handle for each ent
+    buff_size += (num_connect+1)*sizeof(MBEntityHandle)*num_ents;
+      // extra entity type at end, passed as int
+  buff_size += sizeof(int);
+  return buff_size;
+int MBParallelComm::estimate_sets_buffer_size(MBRange &entities,
+    // number of sets
+  int buff_size = sizeof(int);
+  MBRange::iterator rit = entities.lower_bound(MBENTITYSET);
+  for (; rit != entities.end(); rit++) {
+    unsigned int options;
+    result = mbImpl->get_meshset_options(*rit, options);
+    RRA("Failed to get meshset options.");
+    MBRange set_range;
+    if (options & MESHSET_SET) {
+        // range-based set; count the subranges
+      result = mbImpl->get_entities_by_handle(*rit, set_range);
+      RRA("Failed to get set entities.");
+        // set range
+      buff_size += RANGE_SIZE(set_range);
+    else if (options & MESHSET_ORDERED) {
+        // just get the number of entities in the set
+      int num_ents;
+      result = mbImpl->get_number_entities_by_handle(*rit, num_ents);
+      RRA("Failed to get number entities in ordered set.");
+        // set vec
+      buff_size += sizeof(MBEntityHandle) * num_ents + sizeof(int);
+      // get numbers of parents/children
+    int num_par, num_ch;
+    result = mbImpl->num_child_meshsets(*rit, &num_ch);
+    RRA("Failed to get num children.");
+    result = mbImpl->num_parent_meshsets(*rit, &num_par);
+    RRA("Failed to get num parents.");
+    buff_size += (num_ch + num_par) * sizeof(MBEntityHandle) + 2*sizeof(int);
+  return buff_size;
 MBErrorCode MBParallelComm::pack_entities(MBRange &entities,
-                                          MBRange::const_iterator &start_rit,
-                                          MBRange &whole_range,
+                                          std::vector<unsigned char> &buff,
                                           unsigned char *&buff_ptr,
-                                          int &count,
-                                          const bool just_count,
                                           const int to_proc,
-                                          std::vector<MBEntityType> &ent_types,
-                                          std::vector<MBRange> &all_ranges,
-                                          std::vector<int> &verts_per_entity)
+                                          MBRange &owned_shared)
-    // (. w/ handles ? (0-no, 1-yes, range, 2-yes, vector))
-    // ENTITIES:
-    // . for all types:
-    //   - ent_type -- end of data indicated by ent_type == MBMAXTYPE
-    //   - #ents
-    //   - if (ent_type == MBVERTEX) xxx[#ents], yyy[#ents], zzz[#ents]
-    //   - else {
-    //     . nodes_per_ent
+    // pack a range of entities into a message, appending to buffer;
+    // buffer contains:
+    // . # non-owned (by sender) entities
+    // . for each NO entity: index in new ents, owning proc
+    // . for each NO entity: handle on owner
+    // . repeat:
+    //   - ent type
+    //   - # ents
+    //   - if type == vertex, xxx[#ents], yyy[#ents], zzz[#ents]
+    //   - else
+    //     . # nodes per entity
     //     . connect[#ents * nodes_per_ent]
-    //   - if (handles) range/vector of remote handles
+    // . until type == MBMAXTYPE
+    // . if (store_remote_handles) range of local handles on sending proc
-  unsigned char *orig_buff_ptr = buff_ptr;
-  MBErrorCode result;
-  MBWriteUtilIface *wu = NULL;
-  if (!just_count) {
-    result = mbImpl->query_interface(std::string("MBWriteUtilIface"),
-                                     reinterpret_cast<void**>(&wu));
-    RRA("Couldn't get MBWriteUtilIface.");
+  MBWriteUtilIface *wu;
+  MBErrorCode result = mbImpl->query_interface(std::string("MBWriteUtilIface"),
+                                               reinterpret_cast<void**>(&wu));
+  RRA("Couldn't get MBWriteUtilIface.");
+    // non-owned entities don't matter if remote handles aren't stored
+  if (store_remote_handles) {
+      // get owned, non-owned ents
+    MBRange owned_ents, nonowned_ents;
+    result = filter_owned_shared(entities,
+                                 true, true, false, false,
+                                 -1, &owned_ents);
+    RRA("Failed to get owned entities.");
+    if (owned_ents.size() != entities.size())
+      nonowned_ents = entities.subtract(owned_ents);
+      // pack index, proc, handle for nonowned ents
+    CHECK_BUFF_SPACE(buff, buff_ptr,
+                     sizeof(int) + (2*sizeof(int) +
+                                    sizeof(MBEntityHandle))*nonowned_ents.size());
+    PACK_INT(buff_ptr, nonowned_ents.size());
+    if (!nonowned_ents.empty()) {
+      int proc;
+      std::vector<MBEntityHandle> handles;
+      handles.reserve(nonowned_ents.size());
+      MBEntityHandle handle;
+      for (MBRange::const_iterator rit = nonowned_ents.begin();
+           rit != nonowned_ents.end(); rit++) {
+        int idx = entities.index(*rit);
+        assert(-1 != idx);
+        result = get_owner_handle(*rit, proc, handle);
+        RRA("Failed to get owner and handle for entity.");
+        assert(proc != (int) procConfig.proc_rank() &&
+               to_proc != proc && 0 != handle);
+        PACK_INT(buff_ptr, idx);
+        PACK_INT(buff_ptr, proc);
+        handles.push_back(handle);
+      PACK_EH(buff_ptr, &handles[0], nonowned_ents.size());
+      // pack the local handles
+    int tmp_space = RANGE_SIZE(entities);
+    CHECK_BUFF_SPACE(buff, buff_ptr, tmp_space);
+    PACK_RANGE(buff_ptr, entities);
+      // put owned shared in sharedEnts list
+    owned_shared.merge(owned_ents);
     // pack vertices
-  if (just_count) {
-      // don't count size of verts until after all entities are included
-    ent_types.push_back(MBVERTEX);
-    verts_per_entity.push_back(1);
-    all_ranges.push_back(entities.subset_by_type(MBVERTEX));
-  else {
-    if (!all_ranges[0].empty()) {
-      PACK_INT(buff_ptr, ((int) MBVERTEX));
-      PACK_INT(buff_ptr, ((int) all_ranges[0].size()));
-      int num_verts = all_ranges[0].size();
-      std::vector<double*> coords(3);
-      for (int i = 0; i < 3; i++)
-        coords[i] = reinterpret_cast<double*>(buff_ptr + i * num_verts * sizeof(double));
+  MBRange these_ents = entities.subset_by_type(MBVERTEX);
+  int num_ents = these_ents.size();
+  int buff_size;
+  if (num_ents) {
+    buff_size = 2*sizeof(int) + 3*num_ents*sizeof(double);
+    CHECK_BUFF_SPACE(buff, buff_ptr, buff_size);
-      assert(NULL != wu);
-      result = wu->get_node_arrays(3, num_verts, all_ranges[0], 0, 0, coords);
-      RRA("Couldn't allocate node space.");
-      PC(3*num_verts, " doubles");
+    // type, # ents
+    PACK_INT(buff_ptr, ((int) MBVERTEX));
+    PACK_INT(buff_ptr, ((int) num_ents));
-      buff_ptr += 3 * num_verts * sizeof(double);
+    std::vector<double*> coords(3);
+    for (int i = 0; i < 3; i++)
+      coords[i] = reinterpret_cast<double*>(buff_ptr + i * num_ents * sizeof(double));
+    assert(NULL != wu);
+    result = wu->get_node_arrays(3, num_ents, these_ents, 0, 0, coords);
+    RRA("Couldn't allocate node space.");
+    PC(3*num_ents, " doubles");
-        PACK_RANGE(buff_ptr, all_ranges[0]);
+    buff_ptr += 3 * num_ents * sizeof(double);
-      std::cerr << "Packed " << all_ranges[0].size() << " vertices." << std::endl;
+  std::cerr << "Packed " << these_ents.size() << " ents of type "
+            << MBCN::EntityTypeName(TYPE_FROM_HANDLE(*these_ents.begin())) << std::endl;
 #endif
-    // place an iterator at the first non-vertex entity
-    start_rit = entities.find(*all_ranges[0].rbegin());
-    start_rit++;
-  else {
-    start_rit = entities.begin();
+    // now entities; go through range, packing by type and equal # verts per element
+  MBRange::iterator start_rit = entities.find(*these_ents.rbegin());
+  start_rit++;
+  int last_nodes = -1;
+  MBEntityType last_type = MBMAXTYPE;
+  these_ents.clear();
+  MBRange::iterator end_rit = start_rit;
+  EntitySequence *seq;
+  ElementSequence *eseq;
-  MBRange::const_iterator end_rit = start_rit;
-  std::vector<MBRange>::iterator allr_it = all_ranges.begin();
-    // pack entities
-  if (just_count) {
+  while (start_rit != entities.end() || !these_ents.empty()) {
+      // cases:
+      // A: !end, last_type == MAXTYPE, seq: save contig sequence in these_ents
+      // B: !end, last type & nodes same, seq: save contig sequence in these_ents
+      // C: !end, last type & nodes different: pack these_ents, then save contig sequence in these_ents
+      // D: end: pack these_ents
-      // get all ranges of entities that have different #'s of vertices or different types
-    while (end_rit != entities.end() && TYPE_FROM_HANDLE(*start_rit) != MBENTITYSET) {
-        // get the sequence holding this entity
-      EntitySequence *seq;
-      ElementSequence *eseq;
+      // find the sequence holding current start entity, if we're not at end
+    eseq = NULL;
+    if (start_rit != entities.end()) {
       result = sequenceManager->find(*start_rit, seq);
       RRA("Couldn't find entity sequence.");
       if (NULL == seq) return MB_FAILURE;
       eseq = dynamic_cast<ElementSequence*>(seq);
-        // if type and nodes per element change, start a new range
-      if (eseq->type() != *ent_types.rbegin() ||
-          (int) eseq->nodes_per_element() != *verts_per_entity.rbegin()) {
-        ent_types.push_back(eseq->type());
-        verts_per_entity.push_back(eseq->nodes_per_element());
-        all_ranges.push_back(MBRange());
-        allr_it++;
+      // pack the last batch if at end or next one is different
+    if (!these_ents.empty() &&
+        (!eseq || eseq->type() != last_type ||
+         last_nodes != (int) eseq->nodes_per_element())) {
+      result = pack_entity_seq(last_nodes, store_remote_handles,
+                               to_proc, these_ents, entities, buff, buff_ptr);
+      RRA("Failed to pack entities from a sequence.");
+    if (eseq) {
+        // continuation of current range, just save these entities
         // get position in entities list one past end of this sequence
       end_rit = entities.lower_bound(start_rit, entities.end(), eseq->end_handle()+1);
-        // put these entities in the last range
-      std::copy(start_rit, end_rit, mb_range_inserter(*all_ranges.rbegin()));
+        // put these entities in the range
+      std::copy(start_rit, end_rit, mb_range_inserter(these_ents));
-        // remove any which are already shared
-      if (store_remote_handles && !iface_layer) {
-        result = remove_nonowned_shared(*all_ranges.rbegin(), to_proc, false);
-        RRA("Failed nonowned_shared test.");
-      whole_range.merge(*all_ranges.rbegin());
-        // now start where we last left off
-      start_rit = end_rit;
+      last_type = eseq->type();
+      last_nodes = eseq->nodes_per_element();
+    else if (start_rit != entities.end() &&
+             TYPE_FROM_HANDLE(*start_rit) == MBENTITYSET)
+      break;
-      // update vertex range to cover vertices included in other entities
-      // and remove entities already there
-    result = mbImpl->get_adjacencies(whole_range, 0, false, all_ranges[0],
-                                     MBInterface::UNION);
-    RRA("Failed get_adjacencies.");
+    start_rit = end_rit;
-      whole_range = whole_range.subtract(all_ranges[0]);
-      result = remove_nonowned_shared(all_ranges[0], to_proc, false);
-      // count those data, now that we know which
-      // entities get communicated
-    whole_range.merge(all_ranges[0]);
-    count += 3 * sizeof(double) * all_ranges[0].size();
-      // space for the ranges
-    std::vector<MBRange>::iterator vit = all_ranges.begin();
-    std::vector<int>::iterator iit = verts_per_entity.begin();
-    std::vector<MBEntityType>::iterator eit = ent_types.begin();
-    for (; vit != all_ranges.end(); vit++, iit++, eit++) {
-        // entity type of this range, but passed as int
-      count += sizeof(int);
-        // number of entities
+    // pack MBMAXTYPE to indicate end of ranges
+  CHECK_BUFF_SPACE(buff, buff_ptr, sizeof(int));
+  PACK_INT(buff_ptr, ((int)MBMAXTYPE));
-        // nodes per entity
-      if (iit != verts_per_entity.begin()) count += sizeof(int);
-        // connectivity of subrange
-      if (iit != verts_per_entity.begin()) {
-        count += *iit * sizeof(MBEntityHandle)*(*vit).size();
-        // remote handles, if desired
-        count += sizeof(int) + 2*sizeof(MBEntityHandle)*num_subranges(*vit);
+MBErrorCode MBParallelComm::pack_addl_procs(std::set<unsigned int> &addl_procs,
+                                            unsigned char *&buff_ptr)
+  int buff_size = (1 + addl_procs.size())*sizeof(int);
-      // extra entity type at end, passed as int
+    // pack extra procs to_proc must communicate with
+  PACK_INT(buff_ptr, addl_procs.size());
+  for (std::set<unsigned int>::iterator sit = addl_procs.begin();
+       sit != addl_procs.end(); sit++)
+    PACK_INT(buff_ptr, *sit);
+MBErrorCode MBParallelComm::unpack_addl_procs(unsigned char *&buff_ptr,
+                                              std::set<unsigned int> &addl_procs)
+  int num_addl, tmp_addl;
+  UNPACK_INT(buff_ptr, num_addl);
+  for (int i = 0; i < num_addl; i++) {
+    UNPACK_INT(buff_ptr, tmp_addl);
+    addl_procs.insert(tmp_addl);
-  else {
-      // for each range beyond the first
-    allr_it++;
-    std::vector<int>::iterator nv_it = verts_per_entity.begin();
-    std::vector<MBEntityType>::iterator et_it = ent_types.begin();
-    std::vector<MBEntityHandle> dum_connect;
-    nv_it++; et_it++;
-    for (; allr_it != all_ranges.end(); allr_it++, nv_it++, et_it++) {
-        // pack the entity type
-      PACK_INT(buff_ptr, ((int)*et_it));
-        // pack # ents
-      PACK_INT(buff_ptr, (*allr_it).size());
+MBErrorCode MBParallelComm::pack_entity_seq(const int nodes_per_entity,
+                                            const bool store_remote_handles,
+                                            const int to_proc,
+                                            MBRange &these_ents,
+                                            MBRange &entities,
+  int tmp_space = 3*sizeof(int) + nodes_per_entity*these_ents.size()*sizeof(MBEntityHandle);
+    // pack the entity type
+  PACK_INT(buff_ptr, ((int)TYPE_FROM_HANDLE(*these_ents.begin())));
+    // pack # ents
+  PACK_INT(buff_ptr, these_ents.size());
-        // pack the nodes per entity
-      PACK_INT(buff_ptr, *nv_it);
+    // pack the nodes per entity
+  PACK_INT(buff_ptr, nodes_per_entity);
-        // pack the connectivity
-      const MBEntityHandle *connect;
-      int num_connect;
-      MBEntityHandle *start_vec = (MBEntityHandle*)buff_ptr;
-      for (MBRange::const_iterator rit = allr_it->begin(); rit != allr_it->end(); rit++) {
-        result = mbImpl->get_connectivity(*rit, connect, num_connect, false,
-                                          &dum_connect);
-        RRA("Failed to get connectivity.");
-        assert(num_connect == *nv_it);
-        PACK_EH(buff_ptr, &connect[0], num_connect);
+    // pack the connectivity
+  int num_connect;
+  std::vector<MBEntityHandle> dum_connect;
+  MBEntityHandle *start_vec = (MBEntityHandle*)buff_ptr;
+  for (MBRange::const_iterator rit = these_ents.begin(); rit != these_ents.end(); rit++) {
+    result = mbImpl->get_connectivity(*rit, connect, num_connect, false,
+                                      &dum_connect);
+    RRA("Failed to get connectivity.");
+    assert(num_connect == nodes_per_entity);
+    PACK_EH(buff_ptr, connect, num_connect);
-        // substitute destination handles
-      result = get_remote_handles(store_remote_handles, start_vec, start_vec,
-                                  *nv_it*(*allr_it).size(), to_proc,
-                                  whole_range);
-      RRA("Trouble getting remote handles when packing entities.");
+    // substitute destination handles
+  result = get_remote_handles(store_remote_handles, start_vec, start_vec,
+                              nodes_per_entity*these_ents.size(), to_proc,
+                              entities);
+  RRA("Trouble getting remote handles when packing entities.");
-        // pack the handles
-        PACK_RANGE(buff_ptr, (*allr_it));
-      std::cerr << "Packed " << (*allr_it).size() << " ents of type "
-                << MBCN::EntityTypeName(TYPE_FROM_HANDLE(*(allr_it->begin()))) << std::endl;
+  std::cerr << std::endl << "Packed " << these_ents.size() << " ents of type "
 #endif
-      // pack MBMAXTYPE to indicate end of ranges
-    PACK_INT(buff_ptr, ((int)MBMAXTYPE));
+  return result;
-    count += buff_ptr - orig_buff_ptr;
-  if (debug_packing) std::cerr << std::endl << "Done packing entities." << std::endl;
-  return MB_SUCCESS;
 MBErrorCode MBParallelComm::get_remote_handles(const bool store_remote_handles,
                                                MBEntityHandle *from_vec,
                                                MBEntityHandle *to_vec_tmp,
@@ -1232,8 +1275,11 @@
 MBErrorCode MBParallelComm::unpack_entities(unsigned char *&buff_ptr,
-                                            const int from_proc,
-                                            MBRange &entities)
+                                            const unsigned int from_proc,
+                                            const int from_ind,
   MBErrorCode result;
   bool done = false;
@@ -1241,10 +1287,54 @@
   result = mbImpl->query_interface(std::string("MBReadUtilIface"),
                                    reinterpret_cast<void**>(&ru));
   RRA("Failed to get MBReadUtilIface.");
+  MBRange remote_range;
+    // unpack any nonowned entities
+  int no_size = 0;
+  std::vector<unsigned int> no_indices, no_procs, o_indices;
+  std::vector<MBEntityHandle> no_handles, no_local_handles,
+      o_local_handles, o_handles;
+    UNPACK_INT(buff_ptr, no_size);
+    no_indices.resize(no_size);
+    no_procs.resize(no_size);
+    no_handles.resize(no_size);
+      // no_local_handles[i] = local entity equivalent to new entity i in
+      //     this message
+    for (int i = 0; i < no_size; i++) {
+      UNPACK_INT(buff_ptr, no_indices[i]);
+      UNPACK_INT(buff_ptr, no_procs[i]);
+      UNPACK_EH(buff_ptr, &no_handles[i], 1);
+      // unpack source handles; will be processed later
+    UNPACK_RANGE(buff_ptr, remote_range);
+    no_local_handles.resize(remote_range.size(), 0);
+      no_local_handles[no_indices[i]] =
+          find_ghost_entity(no_handles[i], no_procs[i]);
+      // look for existing ghost entities from nonowned procs
+    if (!sharedEnts[from_ind].noHandles.empty()) {
+      MBRange tmp_range = sharedEnts[from_ind].noHandles.intersect(remote_range);
+      for (MBRange::iterator rit = tmp_range.begin();
+           rit != tmp_range.end(); rit++) {
+        int idx = remote_range.index(*rit);
+        no_local_handles[idx] = find_ghost_entity(*rit, from_proc);
+  MBRange new_ents;
   while (!done) {
-    MBEntityType this_type;
+    MBEntityType this_type = MBMAXTYPE;
     MBEntityHandle actual_start;
     UNPACK_INT(buff_ptr, this_type);
     assert(this_type >= MBVERTEX &&
@@ -1256,7 +1346,7 @@
       // get the number of ents
     int num_ents;
     UNPACK_INT(buff_ptr, num_ents);
     if (MBVERTEX == this_type) {
         // unpack coords
       if (num_ents) {
@@ -1265,7 +1355,7 @@
                                      actual_start, coords);
         RRA("Failed to allocate node arrays.");
-        entities.insert(actual_start, actual_start+num_ents-1);
+        new_ents.insert(actual_start, actual_start+num_ents-1);
           // unpack the buffer data directly into coords
@@ -1273,16 +1363,6 @@
                  num_ents*sizeof(double));
         buff_ptr += 3*num_ents * sizeof(double);
         UPC(3*num_ents, " doubles");
-          // unpack source handles
-          MBRange this_range;
-          this_range.insert(actual_start, actual_start+num_ents-1);
-          MBRange dum_range;
-          UNPACK_RANGE(buff_ptr, dum_range);
-          result = set_remote_data(this_range, dum_range, from_proc);
-          RRA("Couldn't set sharing data");
@@ -1300,23 +1380,13 @@
         // unpack the connectivity
       UNPACK_EH(buff_ptr, connect, (num_ents*verts_per_entity));
         // convert to local handles
       result = get_local_handles(connect, num_ents*verts_per_entity,
-                                 entities);
+                                 new_ents, &no_local_handles);
       RRA("Couldn't get local handles.");
         // update adjacencies
       result = ru->update_adjacencies(actual_start, num_ents,
                                       verts_per_entity, connect);
@@ -1329,15 +1399,59 @@
 #endif
+    result = set_remote_data(new_ents, remote_range, from_proc);
+    RRA("Couldn't set sharing data");
+      // account for entities which existed before (i.e. delete duplicate
+      // new ones) then save remaining new ones in appropriate list
+      // find ones to delete (existing nonowned and owned entities)
+    MBRange to_delete;
+    for (unsigned int i = 0; i < no_local_handles.size(); i++)
+      if (no_local_handles[i]) to_delete.insert(new_ents[i]);
+      // put non-existing non-owned entities on noHandles and localHandles list
+    int ind = -1;
+      if (!no_local_handles[no_indices[i]]) {
+        if (-1 == ind || no_procs[i] != buffProcs[ind])
+          ind = get_buffers(no_procs[i]);
+        sharedEnts[ind].noHandles.insert(no_handles[i]);
+        sharedEnts[ind].localHandles.insert(new_ents[no_indices[i]]);
+          // remove remote handles for these entities; leaves
+          // remote handles for only new owned entities in remote range
+        remote_range.erase(new_ents[no_indices[i]]);
+    result = mbImpl->delete_entities(to_delete);
+    RRA("Failed to delete non-owned duplicate entities.");
+    entities = new_ents.subtract(to_delete);
+      // put new ents on local and remote handles list for from_proc
+    sharedEnts[from_ind].localHandles.merge(entities);
+    sharedEnts[from_ind].remoteHandles.merge(remote_range);
+    result = set_pstatus_entities(entities, PSTATUS_NOT_OWNED, false, false);
+    RRA("Couldn't set pstatus values for received entities.");
+  else
+    entities.swap(new_ents);
-  if (debug_packing) std::cerr << std::endl << "Done unpacking entities." << std::endl;
+#ifdef DEBUG_PACKING
+  std::cerr << std::endl << "Done unpacking entities." << std::endl;
+#endif
   return MB_SUCCESS;
 MBErrorCode MBParallelComm::unpack_iface_entities(unsigned char *&buff_ptr,
+                                                  const int ind,
                                                   std::vector<MBEntityHandle> &recd_ents)
     // for all the entities in the received buffer; for each, save
@@ -1345,7 +1459,15 @@
   MBErrorCode result;
   bool done = false;
   std::vector<MBEntityHandle> connect;
+    // # non-owned ents should be zero
+  int dum;
+  UNPACK_INT(buff_ptr, dum);
+  assert(0 == dum);
   while (!done) {
@@ -1370,8 +1492,7 @@
     UNPACK_EH(buff_ptr, &connect[0], (num_ents*verts_per_entity));
-    MBRange source_range, tmp_range;
-    UNPACK_RANGE(buff_ptr, source_range);
+    MBRange tmp_range;
       // save matching local entities, or 0 if none found
     for (int i = 0; i < num_ents; i++) {
@@ -1393,13 +1514,33 @@
     std::cerr << "Unpacked " << num_ents << " ents of type "
-              << MBCN::EntityTypeName(TYPE_FROM_HANDLE(actual_start)) << std::endl;
+              << MBCN::EntityTypeName(this_type) << std::endl;
 #endif
+  int num_zero = count_if(recd_ents.begin(), recd_ents.end(),
+                          bind2nd(std::equal_to<int>(), 0));
+  if (num_zero) {
+    result = MB_FAILURE;
+    RRA("Didn't find an iface entity.");
+  std::vector<MBEntityHandle> tmp_remote;
+  tmp_remote.reserve(recd_ents.size());
+  std::copy(remote_range.begin(), remote_range.end(),
+            std::back_inserter(tmp_remote));
+  result = set_remote_data(&recd_ents[0], &tmp_remote[0], recd_ents.size(),
+                           from_proc);
+  RRA("Failed to set remote handles for iface entities.");
+    // add iface entities to sharedEnts list
+  std::copy(recd_ents.begin(), recd_ents.end(),
+            mb_range_inserter(sharedEnts[ind].localHandles));
+  sharedEnts[ind].remoteHandles.merge(remote_range);
-  if (debug_packing) std::cerr << std::endl << "Done unpacking iface entities." << std::endl;
+  std::cerr << std::endl << "Done unpacking iface entities." << std::endl;
+#endif
   return MB_SUCCESS;
@@ -1418,12 +1559,16 @@
 MBErrorCode MBParallelComm::get_local_handles(MBEntityHandle *from_vec,
                                               int num_ents,
-                                              const MBRange &new_ents)
+                                              const MBRange &new_ents,
+                                              std::vector<MBEntityHandle> *no_ents)
     if (TYPE_FROM_HANDLE(from_vec[i]) == MBMAXTYPE) {
       assert(ID_FROM_HANDLE(from_vec[i]) < (int) new_ents.size());
-      from_vec[i] = new_ents[ID_FROM_HANDLE(from_vec[i])];
+      if (no_ents && i < (int)no_ents->size() && (*no_ents)[i])
+        from_vec[i] = (*no_ents)[i];
+      else
+        from_vec[i] = new_ents[ID_FROM_HANDLE(from_vec[i])];
@@ -1445,11 +1590,11 @@
     // get remote procs tag, if any
   MBRange tmp_range, tmp_local_range = local_range;
   std::vector<int> remote_proc(local_range.size());
-  std::vector<int> remote_procs(MAX_SHARING_PROCS);
+  int remote_procs[MAX_SHARING_PROCS];
   std::vector<MBEntityHandle> remote_handle(local_range.size());
-  std::vector<MBEntityHandle> remote_handles(MAX_SHARING_PROCS);
-  std::fill(remote_procs.begin(), remote_procs.end(), -1);
-  std::fill(remote_handles.begin(), remote_handles.end(), 0);
+  MBEntityHandle remote_handles[MAX_SHARING_PROCS];
+  std::fill(remote_procs, remote_procs+MAX_SHARING_PROCS, -1);
+  std::fill(remote_handles, remote_handles+MAX_SHARING_PROCS, 0);
   result = mbImpl->tag_get_data(sharedp_tag, local_range,
                                 &remote_proc[0]);
   RRA("Couldn't get sharedp tag (range).");
@@ -1468,66 +1613,23 @@
     if (-1 != remote_procs[0]) remote_handles[0] = remote_handle[i];
     else {
       result = mbImpl->tag_get_data(sharedps_tag, &(*rit), 1,
-                                    &remote_procs[0]);
+                                    remote_procs);
       if (MB_SUCCESS == result) {
         result = mbImpl->tag_get_data(sharedhs_tag, &(*rit), 1,
-                                      &remote_handles[0]);
+                                      remote_handles);
         RRA("Couldn't get sharedhs tag (range).");
-      // now insert other_proc, handle into these, and set the tags
-    if (-1 == remote_procs[0]) {
-      remote_procs[0] = other_proc;
-      remote_handles[0] = *rit2;
-      result = mbImpl->tag_set_data(sharedp_tag, &(*rit), 1, &remote_procs[0]);
-      RRA("Couldn't set sharedp tag (range)");
-      result = mbImpl->tag_set_data(sharedh_tag, &(*rit), 1, &remote_handles[0]);
-      RRA("Couldn't set sharedh tag (range)");
-      remote_procs[0] = -1;
-      remote_handles[0] = 0;
-    else {
-      std::vector<int>::iterator vit = remote_procs.begin();
-      std::vector<MBEntityHandle>::iterator vit2 = remote_handles.begin();
-      while (-1 != *vit && vit != remote_procs.end() && other_proc > *vit) {
-        vit++; vit2++;
-      assert(*vit != other_proc);
-      remote_procs.insert(vit, other_proc);
-      remote_handles.insert(vit2, *rit2);
-        // need to pop 'cuz we're using an insert above
-      remote_procs.pop_back();
-      remote_handles.pop_back();
-      result = mbImpl->tag_set_data(sharedps_tag, &(*rit), 1, &remote_procs[0]);
-      RRA("Couldn't set sharedps tag (range)");
-      result = mbImpl->tag_set_data(sharedhs_tag, &(*rit), 1, &remote_handles[0]);
-      RRA("Couldn't set sharedhs tag (range)");
-        // need to clear sharedp_tag and sharedh_tag if prev
-        // data came from there
-      if (-1 != remote_proc[i]) {
-        remote_proc[i] = -1;
-        remote_handle[i] = 0;
-        result = mbImpl->tag_set_data(sharedp_tag, &*rit, 1, &remote_proc[i] );
-        RRA("Couldn't set sharedp tag");
-        result = mbImpl->tag_set_data(sharedh_tag, &*rit, 1, &remote_handle[i] );
+    result = add_remote_proc(*rit, remote_procs, remote_handles,
+                             other_proc, *rit2);
+    RRA(" ");
     // also update shared flag for these ents
-  unsigned char *shared_flags = (unsigned char*) &remote_proc[0];
-  result = mbImpl->tag_get_data(pstatus_tag, local_range, shared_flags);
-  RRA("Couldn't get pstatus tag (range)");
-  for (unsigned int i = 0; i < local_range.size(); i++)
-    shared_flags[i] |= PSTATUS_SHARED;
-  result = mbImpl->tag_set_data(pstatus_tag, local_range, shared_flags);
-  RRA("Couldn't set pstatus tag (range)");
+  result = set_pstatus_entities(local_range, PSTATUS_SHARED, false, false);
+  RRA("Couldn't set pstatus tag (range)");
   return MB_SUCCESS;
@@ -1567,11 +1669,15 @@
   for (int i = 0; i != num_ents; i++) {
       // get existing remote proc(s), handle(s) for this local handle
+    if (!(pstatus_vals[i] & PSTATUS_SHARED)) {
+    else if (-1 != remote_proc[i]) {
       remote_procs[0] = remote_proc[i];
-      std::fill(remote_procs+1, remote_procs+MAX_SHARING_PROCS, -1);
-      std::fill(remote_handles+1, remote_handles+MAX_SHARING_PROCS, 0);
+      std::fill(remote_procs+1, remote_procs+MAX_SHARING_PROCS-1, -1);
+      std::fill(remote_handles+1, remote_handles+MAX_SHARING_PROCS-1, 0);
     else {
       result = mbImpl->tag_get_data(sharedps_tag, local_ents+i, 1,
@@ -1597,6 +1703,11 @@
+    // also update shared flag for these ents
+  result = set_pstatus_entities(local_ents, num_ents, PSTATUS_SHARED,
+                                false, false);
   return MB_SUCCESS;
@@ -1671,8 +1782,21 @@
   const int invalid_proc = -1;
   const MBEntityHandle invalid_handle = 0;
   if (i == n || remote_procs[i] != remote_proc) {
-    insert_in_array( remote_procs, MAX_SHARING_PROCS, i, remote_proc );
-    insert_in_array( remote_hs, MAX_SHARING_PROCS, i, remote_handle );
+    if (0 == n) {
+      remote_procs[0] = remote_proc;
+      remote_hs[0] = remote_handle;
+    else {
+      insert_in_array( remote_procs, MAX_SHARING_PROCS, i, remote_proc );
+      insert_in_array( remote_hs, MAX_SHARING_PROCS, i, remote_handle );
+        // also insert this proc/handle if it's not already there
+      ptr = std::lower_bound( remote_procs, remote_procs+n+1, procConfig.proc_rank() );
+      const size_t i = ptr - remote_procs;
+      if (i == n+1 || remote_procs[i] != (int)procConfig.proc_rank()) {
+        insert_in_array( remote_procs, MAX_SHARING_PROCS, i, (int)procConfig.proc_rank());
+        insert_in_array( remote_hs, MAX_SHARING_PROCS, i, ent);
     switch (n) {
       case 0:
@@ -1726,17 +1850,10 @@
 MBErrorCode MBParallelComm::pack_sets(MBRange &entities,
-                                      int &count,
-                                      const int to_proc,
-                                      MBRange &set_range,
-                                      std::vector<MBRange> &set_ranges,
-                                      std::vector<int> &set_sizes,
-                                      std::vector<unsigned int> &options_vec)
+                                      const int to_proc)
     // SETS:
     // . #sets
@@ -1752,170 +1869,109 @@
     //   - if (#children) handles[#children]
     // now the sets; assume any sets the application wants to pass are in the entities list
   MBErrorCode result;
+  MBRange all_sets = entities.subset_by_type(MBENTITYSET);
-  if (just_count) {
-    int ranges_size = 0, vecs_size = 0, tot_parch = 0;
-    for (; start_rit != entities.end(); start_rit++) {
-      set_range.insert(*start_rit);
-      unsigned int options;
-      result = mbImpl->get_meshset_options(*start_rit, options);
-      RRA("Failed to get meshset options.");
-      options_vec.push_back(options);
+  int buff_size = estimate_sets_buffer_size(all_sets, store_remote_handles);
-      if (options & MESHSET_SET) {
-          // range-based set; count the subranges
-        set_ranges.push_back(MBRange());
-        result = mbImpl->get_entities_by_handle(*start_rit, *set_ranges.rbegin());
-        RRA("Failed to get set entities.");
+    // number of sets
+  PACK_INT(buff_ptr, all_sets.size());
-          // set range
-        ranges_size += 2 * sizeof(MBEntityHandle) * num_subranges(*set_ranges.rbegin()) +
-          sizeof(int);
-      else if (options & MESHSET_ORDERED) {
-          // just get the number of entities in the set
-        int num_ents;
-        result = mbImpl->get_number_entities_by_handle(*start_rit, num_ents);
-        RRA("Failed to get number entities in ordered set.");
-        set_sizes.push_back(num_ents);
-          // set vec
-        vecs_size += sizeof(MBEntityHandle) * num_ents + sizeof(int);
-        // get numbers of parents/children
-      int num_par, num_ch;
-      result = mbImpl->num_child_meshsets(*start_rit, &num_ch);
-      RRA("Failed to get num children.");
-      result = mbImpl->num_parent_meshsets(*start_rit, &num_par);
-      RRA("Failed to get num parents.");
-      tot_parch += num_ch + num_par;
-      // num of sets
-      // options
-    count += set_range.size() * sizeof(unsigned int);
-      // range, vector sizes
-    count += ranges_size + vecs_size;
-      // set children, parents
-    count += 2 * set_range.size() * sizeof(int) + tot_parch * sizeof(MBEntityHandle);
-        // set handles
-    if (!set_range.empty() && store_remote_handles)
-      count += sizeof(int) + 2*sizeof(MBEntityHandle)*num_subranges(set_range);
-    whole_range.merge(set_range);
+    // options for all sets
+  std::vector<unsigned int> options(all_sets.size());
+  MBRange::iterator rit;
+  std::vector<MBEntityHandle> members;
+  int i;
+  for (rit = all_sets.begin(), i = 0; rit != all_sets.end(); rit++, i++) {
+      result = mbImpl->get_meshset_options(*rit, options[i]);
-  else {
-      // set handle range
-    PACK_INT(buff_ptr, set_range.size());
+  CHECK_BUFF_SPACE(buff, buff_ptr, all_sets.size()*sizeof(unsigned int));
+  PACK_VOID(buff_ptr, &options[0], all_sets.size()*sizeof(unsigned int));
+    // vectors/ranges
+      if (options[i] & MESHSET_SET) {
-      // option values
-    if (!set_range.empty())
-      PACK_VOID(buff_ptr, &options_vec[0], set_range.size()*sizeof(unsigned int));
-    std::vector<unsigned int>::const_iterator opt_it = options_vec.begin();
-    std::vector<MBRange>::const_iterator rit = set_ranges.begin();
-    std::vector<int>::const_iterator mem_it = set_sizes.begin();
-    static std::vector<MBEntityHandle> members;
-    for (MBRange::const_iterator set_it = set_range.begin(); set_it != set_range.end();
-         set_it++, opt_it++) {
-      if ((*opt_it) & MESHSET_SET) {
-          // pack entities as a range
-                                    (*rit), dum_range, to_proc,
-                                    whole_range);
-        RRA("Trouble getting remote handles for unordered set contents.");
-        PACK_RANGE(buff_ptr, dum_range);
-        rit++;
+        buff_size = RANGE_SIZE(set_range);
+        PACK_RANGE(buff_ptr, set_range);
-      else if ((*opt_it) & MESHSET_ORDERED) {
-          // pack entities as vector, with length
-        PACK_INT(buff_ptr, *mem_it);
+      else if (options[i] & MESHSET_ORDERED) {
         members.clear();
-        result = mbImpl->get_entities_by_handle(*set_it, members);
-                                    &members[0], &members[0],
-                                    members.size(), to_proc,
-                                    whole_range);
-        RRA("Trouble getting remote handles for ordered set contents.");
-        PACK_EH(buff_ptr, &members[0], *mem_it);
-        mem_it++;
+        result = mbImpl->get_entities_by_handle(*rit, members);
+        RRA("Failed to get entities in ordered set.");
+                         members.size()*sizeof(MBEntityHandle)+sizeof(int));
+        PACK_INT(buff_ptr, members.size());
+        PACK_EH(buff_ptr, &members[0], members.size());
-      // pack numbers of parents/children
-    unsigned int tot_pch = 0;
-         set_it++) {
-        // pack parents
-      int num_pch;
-      result = mbImpl->num_parent_meshsets(*set_it, &num_pch);
-      PACK_INT(buff_ptr, num_pch);
-      tot_pch += num_pch;
-      result = mbImpl->num_child_meshsets(*set_it, &num_pch);
+    // pack numbers of parents/children
+  unsigned int tot_pch = 0;
+  int num_pch;
+  CHECK_BUFF_SPACE(buff, buff_ptr, 2*all_sets.size()*sizeof(int));
+      // pack parents
+    result = mbImpl->num_parent_meshsets(*rit, &num_pch);
+    PACK_INT(buff_ptr, num_pch);
+    tot_pch += num_pch;
+    result = mbImpl->num_child_meshsets(*rit, &num_pch);
-      // now pack actual parents/children
-    members.clear();
-    members.reserve(tot_pch);
-    std::vector<MBEntityHandle> tmp_pch;
-         set_it++) {
-      result = mbImpl->get_parent_meshsets(*set_it, tmp_pch);
-      RRA("Failed to get parents.");
-      std::copy(tmp_pch.begin(), tmp_pch.end(), std::back_inserter(members));
-      tmp_pch.clear();
-      result = mbImpl->get_child_meshsets(*set_it, tmp_pch);
-      RRA("Failed to get children.");
-      tmp_pch.clear();
-    assert(members.size() == tot_pch);
-    if (!members.empty()) {
-                                  whole_range);
-      RRA("Trouble getting remote handles for set parent/child sets.");
+    // now pack actual parents/children
+  members.clear();
+  members.reserve(tot_pch);
+  std::vector<MBEntityHandle> tmp_pch;
+    result = mbImpl->get_parent_meshsets(*rit, tmp_pch);
+    RRA("Failed to get parents.");
+    std::copy(tmp_pch.begin(), tmp_pch.end(), std::back_inserter(members));
+    tmp_pch.clear();
+    result = mbImpl->get_child_meshsets(*rit, tmp_pch);
+    RRA("Failed to get children.");
+    tmp_pch.clear();
+  assert(members.size() == tot_pch);
+  if (!members.empty()) {
+                                &members[0], &members[0],
+                                members.size(), to_proc,
+                                entities);
+    RRA("Trouble getting remote handles for set parent/child sets.");
 #ifndef NDEBUG
-        // check that all handles are either sets or maxtype
-      for (unsigned int __j = 0; __j < members.size(); __j++)
-        assert((TYPE_FROM_HANDLE(members[__j]) == MBMAXTYPE &&
-                ID_FROM_HANDLE(members[__j]) < (int)whole_range.size()) ||
-               TYPE_FROM_HANDLE(members[__j]) == MBENTITYSET);
+      // check that all handles are either sets or maxtype
+    for (unsigned int __j = 0; __j < members.size(); __j++)
+      assert((TYPE_FROM_HANDLE(members[__j]) == MBMAXTYPE &&
+              ID_FROM_HANDLE(members[__j]) < (int)entities.size()) ||
+             TYPE_FROM_HANDLE(members[__j]) == MBENTITYSET);
 #endif
-      PACK_EH(buff_ptr, &members[0], members.size());
+    CHECK_BUFF_SPACE(buff, buff_ptr, members.size()*sizeof(MBEntityHandle));
     // pack the handles
-    if (store_remote_handles && !set_range.empty())
-      PACK_RANGE(buff_ptr, set_range);
+  if (store_remote_handles && !all_sets.empty()) {
+    buff_size = RANGE_SIZE(all_sets);
+    PACK_RANGE(buff_ptr, all_sets);
+  std::cerr << std::endl << "Done packing sets." << std::endl;
+#endif
-  if (debug_packing) std::cerr << std::endl << "Done packing sets." << std::endl;
   return MB_SUCCESS;
@@ -2023,7 +2079,9 @@
     RRA("Couldn't set sharing data for sets");
-  if (debug_packing) std::cerr << std::endl << "Done unpacking sets." << std::endl;
+  std::cerr << std::endl << "Done unpacking sets." << std::endl;
+#endif
   return MB_SUCCESS;
@@ -2049,53 +2107,47 @@
 MBErrorCode MBParallelComm::pack_tags(MBRange &entities,
-                                      const MBRange &whole_range,
+                                      const std::vector<MBTag> &all_tags,
+                                      const std::vector<MBRange> &tag_ranges,
-                                      int &count,
-                                      const std::vector<MBTag> &all_tags,
-                                      const std::vector<MBRange> &tag_ranges)
-    // get all the tags
   MBErrorCode result;
   std::vector<MBTag>::const_iterator tag_it;
   std::vector<MBRange>::const_iterator rit;
+  int count = 0;
+  for (tag_it = all_tags.begin(), rit = tag_ranges.begin();
+       tag_it != all_tags.end(); tag_it++, rit++) {
-  if (just_count) {
+    result = packed_tag_size( *tag_it, *rit, count );
+      return result;
-    for (tag_it = all_tags.begin(), rit = tag_ranges.begin();
-         tag_it != all_tags.end(); tag_it++, rit++) {
+    // number of tags
+  count += sizeof(int);
-      result = packed_tag_size( *tag_it, *rit, count );
-      if (MB_SUCCESS != result)
-        return result;
+  CHECK_BUFF_SPACE(buff, buff_ptr, count);
+  PACK_INT(buff_ptr, all_tags.size());
-      // number of tags
-  else {
-    PACK_INT(buff_ptr, all_tags.size());
-      result = pack_tag( *tag_it, *tag_it, *rit, whole_range, buff_ptr,
-                         count, store_remote_handles, to_proc );
-        return result;
+    result = pack_tag( *tag_it, *tag_it, *rit, entities, buff, buff_ptr,
+                       store_remote_handles, to_proc );
+      return result;
-  if (debug_packing) std::cerr << std::endl << "Done packing tags." << std::endl;
+  std::cerr << std::endl << "Done packing tags." << std::endl;
+#endif
   return MB_SUCCESS;
@@ -2152,14 +2204,13 @@
 MBErrorCode MBParallelComm::pack_tag( MBTag src_tag,
                                       MBTag dst_tag,
-                                      const MBRange &tagged_entites,
+                                      const MBRange &tagged_entities,
-                                      int &count,
                                       const int to_proc )
   MBErrorCode result;
   std::vector<int> var_len_sizes;
   std::vector<const void*> var_len_values;
@@ -2184,9 +2235,8 @@
       return MB_TYPE_OUT_OF_RANGE;
     // size, type, data type
+  CHECK_BUFF_SPACE(buff, buff_ptr, 3*sizeof(int));
   PACK_INT(buff_ptr, tinfo->get_size());
   MBTagType this_type;
   result = mbImpl->tag_get_type(dst_tag, this_type);
@@ -2195,57 +2245,63 @@
     // default value
   if (NULL == tinfo->default_value()) {
     PACK_INT(buff_ptr, 0);
   else {
+    CHECK_BUFF_SPACE(buff, buff_ptr, tinfo->default_value_size());
     PACK_BYTES(buff_ptr, tinfo->default_value(), tinfo->default_value_size());
     // name
+  CHECK_BUFF_SPACE(buff, buff_ptr, tinfo->get_name().size());
   PACK_BYTES(buff_ptr, dst_tinfo->get_name().c_str(), dst_tinfo->get_name().size());
-std::cerr << "Packing tag \"" << tinfo->get_name() << "\"";
-if (tinfo != dst_tinfo)
-  std::cerr << " (as tag \"" << dst_tinfo->get_name() << "\")";
-std::cerr << std::endl;
+  std::cerr << "Packing tag \"" << tinfo->get_name() << "\"";
+  if (tinfo != dst_tinfo)
+    std::cerr << " (as tag \"" << dst_tinfo->get_name() << "\")";
+  std::cerr << std::endl;
 #endif
     // pack entities
-  PACK_INT(buff_ptr, tagged_entites.size());
+  CHECK_BUFF_SPACE(buff, buff_ptr, tagged_entities.size()*sizeof(MBEntityHandle)+sizeof(int));
+  PACK_INT(buff_ptr, tagged_entities.size());
-                              tagged_entites, (MBEntityHandle*)buff_ptr, to_proc,
+                              tagged_entities, (MBEntityHandle*)buff_ptr, to_proc,
                               whole_range);
     std::cerr << "Trouble getting remote handles for tagged entities:" << std::endl;
-    tagged_entites.print("  ");
+    tagged_entities.print("  ");
 #else
   RRA("Trouble getting remote handles for tagged entities.");
 #endif
-  buff_ptr += tagged_entites.size() * sizeof(MBEntityHandle);
+  buff_ptr += tagged_entities.size() * sizeof(MBEntityHandle);
-  const size_t num_ent = tagged_entites.size();
+  const size_t num_ent = tagged_entities.size();
   if (tinfo->get_size() == MB_VARIABLE_LENGTH) {
     var_len_sizes.resize( num_ent, 0 );
     var_len_values.resize( num_ent, 0 );
-    result = mbImpl->tag_get_data(src_tag, tagged_entites, &var_len_values[0],
+    result = mbImpl->tag_get_data(src_tag, tagged_entities, &var_len_values[0],
                                   &var_len_sizes[0] );
     RRA("Failed to get variable-length tag data in pack_tags.");
+    CHECK_BUFF_SPACE(buff, buff_ptr, num_ent*sizeof(int));
     PACK_INTS(buff_ptr, &var_len_sizes[0], num_ent);
-    for (unsigned int i = 0; i < num_ent; ++i)
+    for (unsigned int i = 0; i < num_ent; ++i) {
+      CHECK_BUFF_SPACE(buff, buff_ptr, var_len_sizes[i]);
       PACK_VOID(buff_ptr, var_len_values[i], var_len_sizes[i]);
   else {
-    result = mbImpl->tag_get_data(src_tag, tagged_entites, buff_ptr);
+    CHECK_BUFF_SPACE(buff, buff_ptr, num_ent * tinfo->get_size());
+    result = mbImpl->tag_get_data(src_tag, tagged_entities, buff_ptr);
     RRA("Failed to get tag data in pack_tags.");
     buff_ptr += num_ent * tinfo->get_size();
     PC(num_ent*tinfo->get_size(), " void");
   return MB_SUCCESS;
@@ -2407,7 +2463,9 @@
-  if (debug_packing) std::cerr << std::endl << "Done unpacking tags." << std::endl;
+  std::cerr << std::endl << "Done unpacking tags." << std::endl;
+#endif
   return MB_SUCCESS;
@@ -2539,19 +2597,21 @@
     // get a crystal router
   crystal_data *cd = procConfig.crystal_router();
     // get total number of entities; will overshoot highest global id, but
     // that's ok
-  int num_total = 0, num_local;
+  int num_total[2] = {0, 0}, num_local[2] = {0, 0};
   result = mbImpl->get_number_entities_by_dimension(0, 0, num_local);
-  int failure = MPI_Allreduce(&num_local, &num_total, 1,
-                              MPI_INT, MPI_SUM, procConfig.proc_comm());
+  int failure = MPI_Allreduce(num_local, num_total, 1,
+                              MPI_INTEGER, MPI_SUM, procConfig.proc_comm());
   if (failure) {
     RRA("Allreduce for total number of shared ents failed.");
     // call gather-scatter to get shared ids & procs
   gs_data *gsd;
   assert(sizeof(ulong_) == sizeof(MBEntityHandle));
@@ -2592,8 +2652,10 @@
   int max_size = skin_ents[0].size()*(MAX_SHARING_PROCS+1);
-  std::vector<int> sort_buffer(max_size);
-  tuple_list_sort(&shared_verts, 0,(buffer*)&sort_buffer[0]);
+  buffer sort_buffer;
+  buffer_init(&sort_buffer, max_size);
+  tuple_list_sort(&shared_verts, 0, &sort_buffer);
+  buffer_free(&sort_buffer);
     // set sharing procs and handles tags on skin ents
   int maxp = -1;
@@ -2617,6 +2679,8 @@
                            proc_nranges);
   RRA("Trouble tagging shared entities.");
+  tuple_list_free(&shared_verts);
   if (debug) {
     for (std::map<std::vector<int>, MBRange>::const_iterator mit = proc_nranges.begin();
          mit != proc_nranges.end(); mit++) {
@@ -2645,6 +2709,8 @@
     // now build parent/child links for interface sets
   result = create_iface_pc_links();
   RRA("Trouble creating interface parent/child links.");
+  gs_data_free(gsd);
     // done
   return result;
@@ -2659,17 +2725,8 @@
     result = mbImpl->get_entities_by_handle(*if_it, if_ents);
     RRA("Trouble getting iface entities.");
-  std::vector<unsigned char> tvals(if_ents.size());
-  result = mbImpl->tag_get_data(pstatus_tag(), if_ents, &tvals[0]);
-  RRA("Failed to get pstatus tag values.");
-  for (unsigned int i = 0; i < tvals.size(); i++)
-    tvals[i] |= PSTATUS_INTERFACE;
-  result = mbImpl->tag_set_data(pstatus_tag(), if_ents, &tvals[0]);
-  RRA("Failed to set pstatus tag values.");
+  return set_pstatus_entities(if_ents, PSTATUS_INTERFACE, false, false);
 MBErrorCode MBParallelComm::set_pstatus_entities(MBRange &pstatus_ents,
@@ -2694,11 +2751,11 @@
   if (MBInterface::UNION == operation) {
     result = mbImpl->tag_get_data(pstatus_tag(), *range_ptr, &pstatus_vals[0]);
     RRA("Couldn't get pstatus tag value.");
-    for (unsigned int i = pstatus_ents.size()-1; i >= 0; i--)
+    for (unsigned int i = 0; i < pstatus_vals.size(); i++)
       pstatus_vals[i] |= pstatus_val;
   else {
       pstatus_vals[i] = pstatus_val;
   result = mbImpl->tag_set_data(pstatus_tag(), *range_ptr, &pstatus_vals[0]);
@@ -2707,6 +2764,39 @@
   return MB_SUCCESS;
+MBErrorCode MBParallelComm::set_pstatus_entities(MBEntityHandle *pstatus_ents,
+                                                 int num_ents,
+                                                 unsigned char pstatus_val,
+                                                 bool lower_dim_ents,
+                                                 bool verts_too,
+                                                 int operation)
+  std::vector<unsigned char> pstatus_vals(num_ents);
+  if (lower_dim_ents || verts_too) {
+      // in this case, call the range-based version
+    std::copy(pstatus_ents, pstatus_ents+num_ents, mb_range_inserter(tmp_range));
+    return set_pstatus_entities(tmp_range, pstatus_val, lower_dim_ents,
+                                verts_too, operation);
+  if (MBInterface::UNION == operation) {
+    result = mbImpl->tag_get_data(pstatus_tag(), pstatus_ents, num_ents, &pstatus_vals[0]);
+    RRA("Couldn't get pstatus tag value.");
+    for (unsigned int i = 0; i < (unsigned int) num_ents; i++)
+      pstatus_vals[i] |= pstatus_val;
+  else {
+      pstatus_vals[i] = pstatus_val;
+  result = mbImpl->tag_set_data(pstatus_tag(), pstatus_ents, num_ents, &pstatus_vals[0]);
+  RRA("Couldn't set pstatus tag value.");
 MBErrorCode MBParallelComm::create_interface_sets(std::map<std::vector<int>, MBRange> &proc_nranges,
                                                   MBEntityHandle this_set,
                                                   int resolve_dim, int shared_dim)
@@ -2760,6 +2850,17 @@
     pstatus.resize(mit->second.size(), pval);
     result = mbImpl->tag_set_data(pstatus_tag, mit->second, &pstatus[0]);
     RRA("Failed to tag interface set entities with pstatus.");
+      // finally, if I own this interface, add all the entities to my
+      // sharedEnts.ownedShared for the other procs
+    if ((mit->first)[0] == (int)procConfig.proc_rank()) {
+      std::vector<int>::const_iterator vit = (mit->first).begin();
+      for (++vit; vit != (mit->first).end(); vit++) {
+        int ind = get_buffers(*vit);
+        assert(-1 != ind);
+        sharedEnts[ind].ownedShared.merge(mit->second);
   return MB_SUCCESS;
@@ -2920,6 +3021,7 @@
       if (sharing_procs.empty()) continue;
       proc_nranges[sharing_procs].insert(*rit);
       if (sharing_procs.size() < 2) {
                                       &sharing_procs[0]);
@@ -2944,14 +3046,6 @@
-    // build range for each sharing proc
-  //std::map<int, MBRange> proc_ranges;
-  //for (std::map<std::vector<int>, MBRange>::iterator mit = proc_nranges.begin();
-  //     mit != proc_nranges.end(); mit++) {
-  //  for (unsigned int i = 0; i < mit->first.size(); i++)
-  //    proc_ranges[mit->first[i]].merge(mit->second);
   return MB_SUCCESS;
@@ -2979,6 +3073,12 @@
       sharing_handles.push_back( shared_ents.vul[i++] );
+    if (sharing_procs.size() > 1) {
+        // add current proc/handle to list
+      sharing_procs.push_back(procConfig.proc_rank());
+      sharing_handles.push_back(this_ent);
       // sort sharing_procs and sharing_handles such that
       // sharing_procs is in ascending order.  Use temporary
       // lists and binary search to re-order sharing_handles.
@@ -3002,6 +3102,7 @@
                                     &sharing_procs[0]);
       result = mbImpl->tag_set_data(sharedh_tag, &this_ent, 1,
                                     &sharing_handles[0]);
     else {
         // pad lists
@@ -3021,6 +3122,27 @@
     result = mbImpl->tag_set_data(pstatus_tag, &this_ent, 1, &share_flag);
     RRA("Couldn't set shared tag on shared vertex.");
+      // if this entity isn't owned here, add it to a list of ghosts
+      // by owner
+    if (sharing_procs[0] < (int)procConfig.proc_rank()) {
+      for (unsigned int j = 0; j < sharing_procs.size() && sharing_procs[j] != -1; j++) {
+        if (sharing_procs[j] == (int)procConfig.proc_rank()) continue;
+        int ind = get_buffers(sharing_procs[j]);
+        sharedEnts[ind].remoteHandles.insert(sharing_handles[j]);
+        sharedEnts[ind].localHandles.insert(this_ent);
+      // otherwise it is owned here and shared with others
+    else {
+        assert(sharing_procs[j] > (int)procConfig.proc_rank());
+        sharedEnts[ind].ownedShared.insert(this_ent);
       // reset sharing proc(s) tags
     sharing_procs.clear();
     sharing_handles.clear();
@@ -3072,7 +3194,8 @@
                                     tmp_iface_procs);
       RRA("Failed to get iface_procs for iface set.");
       for (j = 0; j < MAX_SHARING_PROCS; j++) {
-        if (-1 != tmp_iface_procs[j]) procs_set.insert((unsigned int) tmp_iface_procs[j]);
+        if (-1 != tmp_iface_procs[j] && tmp_iface_procs[j] != (int)procConfig.proc_rank())
+          procs_set.insert((unsigned int) tmp_iface_procs[j]);
         else {
           std::fill(tmp_iface_procs, tmp_iface_procs+j, -1);
           break;
@@ -3154,56 +3277,6 @@
   return MB_SUCCESS;
-MBErrorCode MBParallelComm::get_ghost_layers(MBEntityHandle iface_set,
-                                             int to_dim, int bridge_dim,
-                                             int num_layers,
-                                             MBRange &to_ents)
-  MBRange bridge_ents, *bridge_ents_ptr = &bridge_ents;
-    // if 0 layers, put bridge_ents in to_ents, to avoid range copy later
-  if (0 == num_layers) bridge_ents_ptr = &to_ents;
-  if (bridge_dim == -1 ||
-      (to_dim == -1 && !num_layers))
-    result = mbImpl->get_entities_by_handle(iface_set, *bridge_ents_ptr);
-  else
-    result = mbImpl->get_entities_by_dimension(iface_set, bridge_dim, *bridge_ents_ptr);
-  RRA("Couldn't get bridge ents in the set.");
-  if (bridge_ents_ptr->empty()) return MB_SUCCESS;
-    // for each layer, get bridge-adj entities and accumulate
-  for (int nl = 0; nl < num_layers; nl++) {
-    MBRange new_ghosts, new_bridges;
-    result = mbImpl->get_adjacencies(*bridge_ents_ptr, to_dim, false, new_ghosts,
-    RRA("Trouble getting ghost adjacencies in iteration.");
-      // remove from new_ghosts any entities that I don't own
-    MBRange::iterator i = new_ghosts.begin();
-    while (i != new_ghosts.end()) {
-      int owner;
-      result = get_owner( *i, owner );
-      RRA("Trouble getting owner of to-be-ghosted entity");
-      if (owner == (int)proc_config().proc_rank())
-        ++i;
-      else
-        i = new_ghosts.erase( i );
-    to_ents.merge(new_ghosts);
-    result = mbImpl->get_adjacencies(new_ghosts, bridge_dim, false, new_bridges,
-    if (nl < num_layers-1)
-      *bridge_ents_ptr = new_bridges.subtract(*bridge_ents_ptr);
 bool MBParallelComm::is_iface_proc(MBEntityHandle this_set,
                                    int to_proc)
@@ -3223,12 +3296,18 @@
   return false;
-MBErrorCode MBParallelComm::get_owned_entities( const MBRange &ents,
-                                                MBRange& tmp_ents,
-                                                int to_proc,
-                                                bool owned_test,
-                                                bool shared_test )
+MBErrorCode MBParallelComm::filter_owned_shared( MBRange &ents,
+                                                 bool owned_test,
+                                                 bool owned_val,
+                                                 bool shared_test,
+                                                 bool shared_val,
+                                                 int to_proc,
+                                                 MBRange *returned_ents)
+  if (!owned_test && !shared_test) return MB_FAILURE;
+  MBRange tmp_ents;
     // Put into tmp_ents any entities which are not owned locally or
     // who are already shared with to_proc
   std::vector<unsigned char> shared_flags(ents.size());
@@ -3240,16 +3319,20 @@
   std::fill(sharing_procs, sharing_procs+MAX_SHARING_PROCS, -1);
   int i;
   for (rit = ents.begin(), i = 0; rit != ents.end(); rit++, i++) {
-      // don't save if I don't own this entity
-    if (owned_test && (PSTATUS_NOT_OWNED & shared_flags[i])) continue;
+    bool owned = !(PSTATUS_NOT_OWNED & shared_flags[i]),
+        shared = (PSTATUS_SHARED & shared_flags[i]);
-    else if (!shared_test) tmp_ents.insert(*rit);
+    bool owned_passed = !owned_test ||
+        (owned_test && (owned_val == owned));
+    bool shared_passed = !shared_test ||
+        (shared_val == shared && (!shared_val || -1 == to_proc));
-      // if entity isn't shared yet, add to list
-    else if (!(PSTATUS_SHARED & shared_flags[i])) tmp_ents.insert(*rit);
-      // else we need to check sharing procs
-    else {
+    if (owned_passed && shared_passed)
+      tmp_ents.insert(*rit);
+    else if (owned_passed && shared_test && -1 != to_proc &&
+             shared_val == shared) {
+      // we need to check sharing procs
       result = mbImpl->tag_get_data(sharedp_tag(), &(*rit), 1,
                                     sharing_procs);
       RRA(" ");
@@ -3259,36 +3342,29 @@
         assert(-1 != sharing_procs[0]);
         RRA(" ");
-      for (unsigned int j = 0; j < MAX_SHARING_PROCS; j++) {
-          // if to_proc shares this entity, skip it
-        if (-1 != to_proc && sharing_procs[j] == to_proc) break;
+      unsigned int j;
+      for (j = 0; j < MAX_SHARING_PROCS; j++) {
+          // if to_proc shares this entity, add it to list
+        if (-1 != to_proc && sharing_procs[j] == to_proc)
           // if we get here, no more sharing procs, and it's not shared
-          // with to_proc, so add to list
-        else if (sharing_procs[j] == -1)
-          tmp_ents.insert(*rit);
+          // with to_proc
+        else if (-1 == sharing_procs[j])
+          break;
-      std::fill(sharing_procs, sharing_procs+MAX_SHARING_PROCS, -1);
+      std::fill(sharing_procs, sharing_procs+j, -1);
+  if (returned_ents)
+    returned_ents->swap(tmp_ents);
+  else
+    ents.swap(tmp_ents);
   return MB_SUCCESS;
-MBErrorCode MBParallelComm::remove_nonowned_shared(MBRange &ents,
-                                                   int to_proc,
-                                                   bool owned_test,
-                                                   bool shared_test)
-  MBRange tmp_ents;
-  MBErrorCode rval;
-  rval = get_owned_entities( ents, tmp_ents, to_proc, owned_test, shared_test );
-  if (MB_SUCCESS == rval)
-    ents.swap(tmp_ents);
-  return rval;
 MBErrorCode MBParallelComm::exchange_ghost_cells(int ghost_dim, int bridge_dim,
                                                  int num_layers,
@@ -3301,21 +3377,32 @@
     // get the b-dimensional interface(s) with with_proc, where b = bridge_dim
   MBErrorCode result;
   int success;
+  unsigned char *buff_ptr;
-    // get all procs interfacing to this proc
-  std::set<unsigned int> iface_procs;
-  result = get_interface_procs(iface_procs);
+    // get all procs communicating with this proc
+  std::set<unsigned int> comm_procs;
+  result = get_comm_procs(comm_procs);
   RRA("Failed to get iface sets, procs");
-    // post ghost irecv's for all interface procs
-    // index greqs the same as buffer/sharing procs indices
-  std::vector<MPI_Request> recv_reqs(2*MAX_SHARING_PROCS, MPI_REQUEST_NULL);
-  std::vector<MPI_Status> gstatus(MAX_SHARING_PROCS);
-  std::set<unsigned int>::iterator sit;
-  for (sit = iface_procs.begin(); sit != iface_procs.end(); sit++) {
-    int ind = get_buffers(*sit);
+    // make sure each proc has an associated buffer
+  int ind;
+  for (std::set<unsigned int>::iterator sit = comm_procs.begin();
+       sit != comm_procs.end(); sit++) {
+    ind = get_buffers(*sit);
+    // post ghost irecv's for ghost entities from all communicating procs
+    // index reqs the same as buffer/sharing procs indices
+  std::vector<MPI_Request> recv_reqs(buffProcs.size(), MPI_REQUEST_NULL),
+      send_reqs(buffProcs.size(), MPI_REQUEST_NULL);
+  std::vector<unsigned int>::iterator proc_it;
+  for (ind = 0, proc_it = buffProcs.begin();
+       proc_it != buffProcs.end(); proc_it++, ind++) {
     success = MPI_Irecv(&ghostRBuffs[ind][0], ghostRBuffs[ind].size(),
-                        MPI_UNSIGNED_CHAR, *sit,
+                        MPI_UNSIGNED_CHAR, buffProcs[ind],
                         MB_MESG_ANY, procConfig.proc_comm(),
                         &recv_reqs[ind]);
@@ -3324,67 +3411,240 @@
-    // pack and send ghosts from this proc to others
-    // make sendReqs vector to simplify initialization
-  std::fill(sendReqs, sendReqs+2*MAX_SHARING_PROCS, MPI_REQUEST_NULL);
-  MBRange recd_ents[MAX_SHARING_PROCS], sent_ents[MAX_SHARING_PROCS];
+    // get entities to be ghosted on neighbors
+    // done in a separate loop over procs because sometimes later procs
+    // need to add info to earlier procs' messages
+  MBRange sent_ents[MAX_SHARING_PROCS];
+  std::set<unsigned int> addl_procs[MAX_SHARING_PROCS], my_addl_procs;
+    if (num_layers) {
+      result = get_ghosted_entities(bridge_dim, ghost_dim, buffProcs[ind],
+                                    num_layers, sent_ents[ind], addl_procs);
+      RRA("Failed to get ghost layers.");
+    else {
+      result = get_iface_sent_entities(buffProcs[ind], sent_ents[ind]);
+      RRA("Failed to get interface layers.");
-    // keep track of new ghosted and ghost ents so we can tag them later
-  MBRange new_ghosted, new_ghosts;
+    // pack and send ghosteds from this proc to others
+    // initialize sendReqs
+      // get an estimate of the buffer size & pre-allocate buffer size
+    unsigned int buff_size = estimate_ents_buffer_size(sent_ents[ind],
+                                                       store_remote_handles);
+    RRA("Failed to estimate buffer size.");
+    ownerSBuffs[ind].clear();
+    ownerSBuffs[ind].reserve(buff_size);
+      // buff_ptr points to the END (one past last occupied byte) of buffer
+    buff_ptr = &ownerSBuffs[ind][0];
+      // entities (including info about non-owned ents)
+    result = pack_entities(sent_ents[ind], ownerSBuffs[ind], buff_ptr,
+                           store_remote_handles, buffProcs[ind],
+                           sharedEnts[ind].ownedShared);
+      // addl procs
+    result = pack_addl_procs(addl_procs[ind], ownerSBuffs[ind], buff_ptr);
+    RRA("Failed to pack addl procs.");
+      // now we're ready to send the buffer
+    result = send_buffer(*proc_it, &ownerSBuffs[ind][0],
+                         buff_ptr-&ownerSBuffs[ind][0], MB_MESG_ENTS,
+                         send_reqs[ind]);
+    RRA("Failed to Isend in ghost exchange.");
+    // receive/unpack new ghost entities
+    // number of incoming messages FOR GHOSTS is the number of procs we communicate with
+  int num_incoming = buffProcs.size();
+  std::vector<MPI_Status> status(buffProcs.size());
+  std::vector<std::vector<MBEntityHandle> > recd_ents(num_incoming);
+  MBRange new_ghosts[MAX_SHARING_PROCS];
+  while (num_incoming) {
+      // wait for all recvs of ghost ents before proceeding,
+      // b/c some procs may have sent to a 3rd proc ents owned by me;
+    success = MPI_Waitany(buffProcs.size(), &recv_reqs[0], &ind, &status[0]);
+    if (MPI_SUCCESS != success) {
+      RRA("Failed in waitany in ghost exchange.");
-    MBRange bridge_ents;
-      // get bridge ents on interface(s)
-    for (MBRange::iterator rit = interfaceSets.begin(); rit != interfaceSets.end();
-         rit++) {
-      if (!is_iface_proc(*rit, *sit)) continue;
+      // ok, received something; decrement incoming counter
+    num_incoming--;
+      // branch on message type
+    if (MB_MESG_SIZE == status[0].MPI_TAG) {
+        // incoming message just has size; resize buffer and re-call recv,
+        // then re-increment incoming count
+      int new_size = *((int*)&ghostRBuffs[ind][0]);
+      assert(0 > new_size);
+      result = recv_size_buff(buffProcs[ind], ghostRBuffs[ind], recv_reqs[ind],
+                              MB_MESG_ENTS);
+      RRA("Failed to resize recv buffer.");
+      num_incoming++;
+    else if (MB_MESG_ENTS == status[0].MPI_TAG) {
-      result = get_ghost_layers(*rit, ghost_dim, bridge_dim, num_layers, bridge_ents);
-      RRA("Failed to get ghost layers.");
+        // incoming ghost entities; unpack; returns entities received
+        // both from sending proc and from owning proc (which may be different)
+      unsigned char *buff_ptr = &ghostRBuffs[ind][0];
+      if (num_layers) {
+                                 buffProcs[ind],
+                                 ind,
+                                 new_ghosts[ind], new_ghosts,
+                                 my_addl_procs);
+        RRA("Failed to unpack entities.");
+          // unpack addl procs I need to receive handles from
+        result = unpack_addl_procs(buff_ptr, my_addl_procs);
+        RRA("Failed to unpack addl procs.");
+      else {
+        result = unpack_iface_entities(buff_ptr, buffProcs[ind], ind, recd_ents[ind]);
+        RRA("Failed to unpack iface entities.");
-    if (0 == num_layers) {
-        // just sending iface ents - take out vertices, since these are always known
-      std::pair<MBRange::const_iterator, MBRange::const_iterator> its =
-          bridge_ents.equal_range(MBVERTEX);
-      bridge_ents.erase((MBRange::iterator)its.first,
-                        (MBRange::iterator)its.second);
+    // allocate buffs for any new entities, then add buffers
+    // for any new addl procs
+  for (std::set<unsigned int>::iterator sit = my_addl_procs.begin();
+       sit != my_addl_procs.end(); sit++) {
+  recv_reqs.resize(buffProcs.size());
+  send_reqs.resize(buffProcs.size());
+    // post recvs for remote handles of my ghosteds
+    success = MPI_Irecv(&ghostRBuffs[ind][0], ghostRBuffs[ind].size(),
+                        MB_MESG_ANY, procConfig.proc_comm(),
+                        &recv_reqs[ind]);
+    if (success != MPI_SUCCESS) {
+      RRA("Failed to post irecv in ghost exchange.");
-      // pack-send; this also posts receives if store_remote_handles is true
-    result = pack_send_entities(*sit, bridge_ents, false, true,
-                                store_remote_handles, (0 == num_layers),
-                                ownerSBuffs[ind], ownerRBuffs[MAX_SHARING_PROCS+ind],
-                                sendReqs[ind], recv_reqs[MAX_SHARING_PROCS+ind],
-                                sent_ents[ind]);
-    RRA("Failed to pack-send in ghost exchange.");
+    // send local handles for new ghosts to owner, then add
+    // those to ghost list for that owner
+    buff_ptr = &ghostSBuffs[ind][0];
+    if (num_layers)
+      result = pack_remote_handles(new_ghosts[ind], *proc_it,
+                                   ghostSBuffs[ind], buff_ptr);
+    else
+      result = pack_remote_handles(recd_ents[ind], *proc_it,
+    RRA("Failed to pack remote handles.");
+    result = send_buffer(buffProcs[ind], &ghostSBuffs[ind][0],
+                         buff_ptr - &ghostSBuffs[ind][0],
+                         MB_MESG_REMOTE_HANDLES, send_reqs[ind]);
+    RRA("Failed to send remote handles.");
+    // process remote handles of my ghosteds
+  MBRange new_ghosted;
+  num_incoming = buffProcs.size();
+    num_incoming--;
+                              MB_MESG_REMOTE_HANDLES);
+      num_incoming++;
+    else if (MB_MESG_REMOTE_HANDLES == status[0].MPI_TAG) {
+        // incoming remote handles
+      result = unpack_remote_handles(buffProcs[ind], &ghostRBuffs[ind][0], num_layers, ind,
+                                     new_ghosted);
+      RRA("Failed to unpack remote handles.");
-    if (0 != num_layers) {
-      MBRange::iterator ins1 = new_ghosted.begin(), ins2 = ghostedEnts[*sit].begin();
-      int owner;
-      for (MBRange::iterator s = sent_ents[ind].begin(); s != sent_ents[ind].end(); ++s) {
-        result = get_owner( *s, owner );
-        RRA("Trouble getting entity owner");
-        if (owner == (int)proc_config().proc_rank()) {
-          ins1 = new_ghosted.insert( ins1, *s, *s );
-          ins2 = ghostedEnts[*sit].insert( ins2, *s, *s );
+        // should receive back at least as many handles as entities we sent
+        // (at least 'cuz other procs may have sent ents owned by me to another proc)
+      assert(new_ghosted.size() >= sent_ents[ind].size());
+    else assert(false);
+    // post recvs for sharedh/p tag
+  std::fill(recv_reqs.begin(), recv_reqs.end(), MPI_REQUEST_NULL);
+                        &recv_reqs[ind]);
+    // send complete sharedh/p tag to sharing procs for entities I own
+    result = pack_sharedhps_tag(new_ghosted, sharedEnts[ind].ownedShared,
+                                *proc_it,
+    RRA("Failed to pack sharedhs tag.");
+                         MB_MESG_SHAREDHPS, send_reqs[ind]);
-    // receive/unpack entities
-    // number of incoming messages depends on whether we're getting back
-    // remote handles
-  int num_incoming = interfaceSets.size() * (store_remote_handles ? 2 : 1);
+    // process sharedhp tags for my ghosts
-    int ind;
-    MPI_Status status;
-    success = MPI_Waitany(2*MAX_SHARING_PROCS, &recv_reqs[0], &ind, &status);
@@ -3393,97 +3653,309 @@
     num_incoming--;
-    std::vector<MBEntityHandle> remote_handles_v, sent_ents_tmp;
-    MBRange remote_handles_r;
-    int new_size, num_eh;
-    unsigned char *buff_ptr;
-    switch (status.MPI_TAG) {
-      case MB_MESG_SIZE:
-          // incoming message just has size; resize buffer and re-call recv,
-          // then re-increment incoming count
-        assert(ind < MAX_SHARING_PROCS);
-        new_size = *((int*)&ghostRBuffs[ind][0]);
-        assert(0 > new_size);
-        result = recv_size_buff(buffProcs[ind], ghostRBuffs[ind], recv_reqs[ind],
-                                MB_MESG_ENTS);
-        RRA("Failed to resize recv buffer.");
-        num_incoming++;
-        break;
-      case MB_MESG_ENTS:
-          // incoming ghost entities; process
-        result = recv_unpack_entities(buffProcs[ind], store_remote_handles,
-                                      (0 == num_layers),
-                                      ghostRBuffs[ind], ghostSBuffs[ind],
-                                      sendReqs[ind], recd_ents[ind]);
-        RRA("Failed to recv-unpack message.");
-          new_ghosts.merge(recd_ents[ind]);
-          //ghostedEnts[buffProcs[ind]].merge(recd_ents[ind]);
-        break;
-      case MB_MESG_REMOTE_HANDLES_VECTOR:
-          // incoming remote handles; use to set remote handles
-          // this version only called if we're exchanging iface layer...
-        assert(0 == num_layers);
-        buff_ptr = &ownerRBuffs[ind][0];
-        assert(ind >= MAX_SHARING_PROCS);
-        UNPACK_INT(buff_ptr, num_eh);
-        remote_handles_v.resize(num_eh);
-        UNPACK_EH(buff_ptr, &remote_handles_v[0], num_eh);
-        std::copy(sent_ents[ind-MAX_SHARING_PROCS].begin(),
-                  sent_ents[ind-MAX_SHARING_PROCS].end(),
-                  std::back_inserter(sent_ents_tmp));
-        assert(sent_ents_tmp.size() == sent_ents[ind-MAX_SHARING_PROCS].size());
-        result = set_remote_data(&sent_ents_tmp[0], &remote_handles_v[0], sent_ents_tmp.size(),
-                                 buffProcs[ind-MAX_SHARING_PROCS]);
-        RRA("Trouble setting remote data range on sent entities in ghost exchange.");
-        result = update_iface_sets(sent_ents[ind-MAX_SHARING_PROCS],
-                                   remote_handles_v, buffProcs[ind-MAX_SHARING_PROCS]);
-        RRA("Trouble updating iface sets.");
-        break;
-      case MB_MESG_REMOTE_HANDLES_RANGE:
-          // this version only called if we're NOT exchanging iface layer...
-        assert(0 != num_layers);
-        UNPACK_RANGE(buff_ptr, remote_handles_r);
-        //assert(!sent_ents[ind-MAX_SHARING_PROCS].empty());
-        result = set_remote_data(sent_ents[ind-MAX_SHARING_PROCS], remote_handles_r,
-        break;
+                              MB_MESG_SHAREDHPS);
+      num_incoming++;
+    else if (MB_MESG_SHAREDHPS == status[0].MPI_TAG) {
+      result = unpack_sharedhps_tag(buffProcs[ind], &ghostRBuffs[ind][0]);
+  return MB_SUCCESS;
+MBErrorCode MBParallelComm::pack_sharedhps_tag(MBRange &new_ghosted,
+                                               MBRange &ghosted_ents,
+                                               unsigned int to_proc,
+    // only need to send entities which have neg sharedp tag
+    // use buffer as tmp space to count how many
+  MBRange tmp_range = new_ghosted.intersect(ghosted_ents);
+  std::vector<int> shp_tag(tmp_range.size());
+  MBErrorCode result = mbImpl->tag_get_data(sharedp_tag(), tmp_range,
+                                            &shp_tag[0]);
+  RRA("Failed to get sharedp_tag.");
+  int num_neg = count_if(shp_tag.begin(), shp_tag.end(),
+                         bind2nd(std::equal_to<int>(), -1));
-    unsigned char pval = (PSTATUS_SHARED | PSTATUS_GHOST | PSTATUS_NOT_OWNED);
-    std::vector<unsigned char> pvals(MAX(new_ghosts.size(), new_ghosted.size()), pval);
-      // new ghost entities are always new
-    result = mbImpl->tag_set_data(pstatus_tag(), new_ghosts, &pvals[0]);
-    RRA("Trouble setting tags for new ghost entities");
+  CHECK_BUFF_SPACE(buff, buff_ptr, sizeof(int) + num_neg*(sizeof(int)+sizeof(MBEntityHandle))*
+                   MAX_SHARING_PROCS);
+    // now pack the buffer
+  PACK_INT(buff_ptr, num_neg);
+  MBRange::iterator rit = tmp_range.begin();
+  std::vector<int>::iterator vit = shp_tag.begin();
+  for (; rit != tmp_range.end(); rit++, vit++) {
+      // don't need to send for ents shared only with this proc
+    if (-1 != *vit) continue;
-    pval = PSTATUS_SHARED;
-    std::fill(pvals.begin(), pvals.end(), pval);
-    result = mbImpl->tag_set_data(pstatus_tag(), new_ghosted, &pvals[0]);
-    RRA("Trouble setting tags for new ghosted entities");
+      // pack directly into buffer, one past start to leave room for
+      // # shared procs/handles
+    int *tmp_sharedps = (int*) (buff_ptr + sizeof(int));
+    result = mbImpl->tag_get_data(sharedps_tag(), &(*rit), 1, tmp_sharedps);
+    assert(MB_SUCCESS == result);
+      // cast to int so we can compare to proc starting point
+    int *tmp_sharedhs = (int*) std::find(tmp_sharedps, tmp_sharedps+MAX_SHARING_PROCS, -1);
+    int num_pr = tmp_sharedhs-tmp_sharedps;
+      // pack # shared handles/procs
+    PACK_INT(buff_ptr, num_pr);
+      // skip past shared procs space, then pack handles directly
+    buff_ptr += num_pr*sizeof(int);
+    result = mbImpl->tag_get_data(sharedhs_tag(), &(*rit), 1, buff_ptr);
+    RRA("Failed to get sharedhs tag.");
+    buff_ptr += num_pr * sizeof(MBEntityHandle);
+MBErrorCode MBParallelComm::unpack_sharedhps_tag(unsigned int from_proc,
+    // get # entities
+  int num_ents, num_procs;
+  UNPACK_INT(buff_ptr, num_ents);
+  int tmp_sharedps[MAX_SHARING_PROCS];
+  MBEntityHandle tmp_sharedhs[MAX_SHARING_PROCS];
+  num_procs = MAX_SHARING_PROCS;
+  for (int i = 0; i < num_ents; i++) {
+      // initialize tmp proc/handle space from last iterate
+    std::fill(tmp_sharedps, tmp_sharedps+num_procs, -1);
+    std::fill(tmp_sharedhs, tmp_sharedhs+num_procs, 0);
+    UNPACK_INT(buff_ptr, num_procs);
+    assert(num_procs <= MAX_SHARING_PROCS && num_procs >= 2);
+    int *proc_ptr = (int*) buff_ptr;
+    int *this_proc = std::find(proc_ptr, proc_ptr+num_procs,
+                               (int)procConfig.proc_rank());
+    assert(this_proc - proc_ptr < num_procs);
+    MBEntityHandle my_handle = (MBEntityHandle)(proc_ptr + num_procs)[this_proc-proc_ptr];
+    memcpy(tmp_sharedps, proc_ptr, num_procs*sizeof(int));
+    memcpy(tmp_sharedhs, proc_ptr+num_procs, num_procs*sizeof(MBEntityHandle));
+    MBErrorCode result = mbImpl->tag_set_data(sharedps_tag(), &my_handle, 1, tmp_sharedps);
+    RRA("Failed to set sharedps tag.");
+    result = mbImpl->tag_set_data(sharedhs_tag(), &my_handle, 1, tmp_sharedhs);
+    RRA("Failed to set sharedhs tag.");
+    buff_ptr += num_procs*(sizeof(int) + sizeof(MBEntityHandle));
+MBErrorCode MBParallelComm::pack_remote_handles(MBRange &entities,
+                                                std::vector<unsigned char> &buff,
+    // 2 vectors of handles
+  CHECK_BUFF_SPACE(buff, buff_ptr, sizeof(int) + 2*entities.size()*sizeof(MBEntityHandle));
-    // ok, now wait if requested
-  if (wait_all) {
-    MPI_Status status[2*MAX_SHARING_PROCS];
-    success = MPI_Waitall(2*MAX_SHARING_PROCS, &sendReqs[0], status);
-    if (MPI_SUCCESS != success) {
-      result = MB_FAILURE;
-      RRA("Failure in waitall in ghost exchange.");
+  PACK_INT(buff_ptr, entities.size());
+  MBEntityHandle *local_handles = (MBEntityHandle*)buff_ptr,
+      *remote_handles = local_handles + entities.size();
+  std::copy(entities.begin(), entities.end(), local_handles);
+  MBRange dum_range;
+  MBErrorCode result = get_remote_handles(true, local_handles, remote_handles,
+                                          entities.size(), to_proc, dum_range);
+  RRA("Trouble setting remote data range on sent entities in ghost exchange.");
+  buff_ptr += 2*sizeof(MBEntityHandle)*entities.size();
+  return result;
+MBErrorCode MBParallelComm::pack_remote_handles(std::vector<MBEntityHandle> &entities,
+    // IMPLEMENTATION IDENTICAL TO OTHER VERSION; COULD PROBABLY DO WITH TEMPLATES...
+  return result;
+MBErrorCode MBParallelComm::unpack_remote_handles(unsigned int from_proc,
+                                                  unsigned char *&buff_ptr,
+                                                  const int num_layers,
+                                                  const int ind,
+                                                  MBRange &new_ghosted)
+    // incoming remote handles; use to set remote handles
+  int num_eh;
+  UNPACK_INT(buff_ptr, num_eh);
+  MBEntityHandle *remote_handles = (MBEntityHandle*)buff_ptr,
+      *local_handles = remote_handles + num_eh;
+  MBErrorCode result = set_remote_data(local_handles, remote_handles, num_eh, from_proc);
+  std::copy(local_handles, local_handles+num_eh, mb_range_inserter(new_ghosted));
+  buff_ptr += 2*num_eh*sizeof(MBEntityHandle);
+    // if I'm the smaller proc, I own these ents, add these ents to ownedshared
+  if (num_layers || (procConfig.proc_rank() < from_proc))
+              mb_range_inserter(sharedEnts[ind].ownedShared));
+MBErrorCode MBParallelComm::get_addl_procs(MBRange &ghosted_ents,
+                                           std::set<unsigned int> *addl_procs)
+    // for all the procs owning entities ghosted here, if I'm sending those
+    // ghosts to 3rd proc, tell the owner it needs to communicate with that 3rd
+    // proc too
+  std::vector<int> tmp_procs(ghosted_ents.size()),
+      tmp_procss(MAX_SHARING_PROCS);
+  MBErrorCode result = mbImpl->tag_get_data(sharedp_tag(), ghosted_ents,
+                                            &tmp_procs[0]);
+  RRA("Couldn't get sharedp tag.");
+  unsigned int i;
+  for (i = 0, rit = ghosted_ents.begin();
+       rit != ghosted_ents.end(); rit++, i++) {
+    if (-1 == tmp_procs[i]) {
+                                    &tmp_procss[0]);
+        // could be it's not yet shared
+      if (MB_TAG_NOT_FOUND == result) continue;
+      RRA("Couldn't get sharedps tag.");
+    else tmp_procss[0] = tmp_procs[i];
+    if (tmp_procss[0] != (int)procConfig.proc_rank() &&
+        tmp_procss[0] != (int) to_proc)
+      addl_procs[tmp_procss[0]].insert(to_proc);
   return MB_SUCCESS;
+MBErrorCode MBParallelComm::get_ghosted_entities(int bridge_dim,
+                                                 int ghost_dim,
+                                                 int to_proc,
+                                                 int num_layers,
+    // get bridge ents on interface(s)
+  MBRange from_ents;
+  MBErrorCode result = MB_SUCCESS;
+  assert(0 < num_layers);
+  for (MBRange::iterator rit = interfaceSets.begin(); rit != interfaceSets.end();
+       rit++) {
+    if (!is_iface_proc(*rit, to_proc)) continue;
+      // get starting "from" entities
+    if (bridge_dim == -1)
+      result = mbImpl->get_entities_by_handle(*rit, from_ents);
+    else
+      result = mbImpl->get_entities_by_dimension(*rit, bridge_dim, from_ents);
+    RRA("Couldn't get bridge ents in the set.");
+      // need to get layers of bridge-adj entities
+    result = MeshTopoUtil(mbImpl).get_bridge_adjacencies(from_ents, bridge_dim,
+                                                         ghost_dim, ghosted_ents,
+                                                         num_layers);
+    RRA("Couldn't get bridge adjacencies.");
+  result = add_verts(ghosted_ents);
+  RRA("Couldn't add verts.");
+  result = filter_owned_shared(ghosted_ents,
+                               false, false, true, false, to_proc);
+  RRA("Trouble filtering.");
+  result = get_addl_procs(ghosted_ents, to_proc, addl_procs);
+  RRA("Failed to get addl procs.");
+  return result;
+MBErrorCode MBParallelComm::get_iface_sent_entities(unsigned int to_proc,
+                                                    MBRange &sent_ents)
+       rit++) {
+    result = mbImpl->get_entities_by_handle(*rit, sent_ents);
+    RRA("Trouble getting interface set entities.");
+    // remove vertices, assuming they're already shared
+  std::pair<MBRange::const_iterator, MBRange::const_iterator> vit =
+      sent_ents.equal_range(MBVERTEX);
+  sent_ents.erase(vit.first, vit.second);
+    // remove other entities, but only if to_proc is lower
+  if (to_proc < procConfig.proc_rank()) {
+      //,,, need to account for non-owned ents being sent from this proc
+    result = filter_owned_shared(sent_ents,
+                                 true, true, false, false);
+  return result;
+MBErrorCode MBParallelComm::add_verts(MBRange &sent_ents)
+      // get the verts adj to these entities, since we'll have to send those too
+    // first check sets
+      set_range = sent_ents.equal_range(MBENTITYSET);
+  MBErrorCode result = MB_SUCCESS, tmp_result;
+  for (MBRange::const_iterator rit = set_range.first; rit != set_range.second; rit++) {
+    tmp_result = mbImpl->get_entities_by_type(*rit, MBVERTEX, sent_ents);
+    if (MB_SUCCESS != tmp_result) result = tmp_result;
+  RRA("Failed to get contained verts.");
+    // now non-sets
+  MBRange tmp_ents;
+  std::copy(sent_ents.begin(), set_range.first, mb_range_inserter(tmp_ents));
+  result = mbImpl->get_adjacencies(tmp_ents, 0, false, sent_ents,
+                                   MBInterface::UNION);
+  RRA("Couldn't get vertices adj to ghosted ents.");
+  return result;
 MBErrorCode MBParallelComm::exchange_tags(std::vector<MBTag> &tags)
   MBErrorCode result;
@@ -3497,9 +3969,9 @@
   std::vector<MPI_Request> recv_reqs(MAX_SHARING_PROCS, MPI_REQUEST_NULL);
-  for (sit = exch_procs.begin(); sit != exch_procs.end(); sit++) {
+  std::vector<unsigned int>::iterator sit;
+  int ind;
+  for (ind = 0, sit = buffProcs.begin(); sit != buffProcs.end(); sit++, ind++) {
@@ -3513,10 +3985,8 @@
     // pack and send tags from this proc to others
   std::fill(sendReqs, sendReqs+MAX_SHARING_PROCS, MPI_REQUEST_NULL);
-  std::map<unsigned int,MBRange>::const_iterator mit;
     MBRange tag_ents;
@@ -3530,17 +4000,15 @@
       if (MB_SUCCESS != result || owner != (int)proc_config().proc_rank())
         continue;
-      //result = get_ghost_layers(*rit, -1, 0, 0, tag_ents);
       result = mbImpl->get_entities_by_handle(*rit, tag_ents);
       RRA("Failed to get tag ents for exchange.");
       // also get ghosted entities for this proc
-    if ((mit = ghostedEnts.find(*sit)) != ghostedEnts.end())
-      tag_ents.merge((*mit).second);
+    if (!sharedEnts[ind].ownedShared.empty())
+      tag_ents.merge(sharedEnts[ind].ownedShared);
-    int buff_size = 0;
     std::vector<MBRange> tag_ranges;
     for (std::vector<MBTag>::iterator vit = tags.begin(); vit != tags.end(); vit++) {
       const void* ptr;
@@ -3555,32 +4023,19 @@
-      // count first
+      // pack the data
     unsigned char *buff_ptr = &ownerSBuffs[ind][0];
-    MBRange::iterator rit = tag_ents.begin();
-    result = pack_tags(tag_ents, rit, tag_ents,
-                       buff_ptr, buff_size, true, true, *sit,
-                       tags, tag_ranges);
+    result = pack_tags(tag_ents,
+                       tags, tag_ranges,
+                       ownerSBuffs[ind], buff_ptr, true, *sit);
     RRA("Failed to count buffer in pack_send_tag.");
-    int real_buff_size = 0;
-                       buff_ptr, real_buff_size, false, true, *sit,
-    RRA("Failed to pack buffer in pack_send_tag.");
-    assert(buff_size == real_buff_size);
-      // if the message is large, send a first message to tell how large
-    if (INITIAL_BUFF_SIZE < buff_size) {
-      int tmp_buff_size = -buff_size;
-      int success = MPI_Send(&tmp_buff_size, sizeof(int), MPI_UNSIGNED_CHAR,
-                             *sit, MB_MESG_SIZE, procConfig.proc_comm());
-      if (success != MPI_SUCCESS) return MB_FAILURE;
-      // send the buffer
-    success = MPI_Isend(&ownerSBuffs[ind][0], buff_size, MPI_UNSIGNED_CHAR, *sit,
-                        MB_MESG_TAGS, procConfig.proc_comm(), &sendReqs[ind]);
+      // now send it
+    result = send_buffer(*sit, &ownerSBuffs[ind][0],
+                         MB_MESG_TAGS, sendReqs[ind]);
+    RRA("Failed to send buffer.");
     // receive/unpack tags
@@ -3655,9 +4110,9 @@
+  int ind;
@@ -3693,22 +4148,20 @@
       // count first
       // buffer needs to begin with the number of tags (one)
     int buff_size = sizeof(int);
     result = packed_tag_size( src_tag, proc_ents[*sit], buff_size );
-    int real_buff_size = sizeof(int);
+    CHECK_BUFF_SPACE(ownerSBuffs[ind], buff_ptr, buff_size);
     PACK_INT( buff_ptr, 1 ); // number of tags
     result = pack_tag( src_tag, dst_tag, proc_ents[*sit], proc_ents[*sit],
-                       buff_ptr, real_buff_size, true, *sit );
+                       ownerSBuffs[ind], buff_ptr, true, *sit );
-    assert(real_buff_size == buff_size);
@@ -3798,6 +4251,9 @@
   MBErrorCode result;
   int success;
@@ -3924,6 +4380,8 @@
     MBErrorCode result = mbImpl->remove_entities(*set_it, ents_to_remove);
     RRA("Couldn't remove entities from iface set in update_iface_sets.");
   return MB_SUCCESS;
@@ -4200,8 +4658,9 @@
   /** \brief Return the rank of the entity owner
-MBErrorCode MBParallelComm::get_owner(MBEntityHandle entity,
-                                      int &owner)
+MBErrorCode MBParallelComm::get_owner_handle(MBEntityHandle entity,
+                                             int &owner,
+                                             MBEntityHandle &handle)
     // I'm sure there's a much more efficient logic to this,
@@ -4211,15 +4670,20 @@
                                             &pstat);
   if (!(pstat & PSTATUS_NOT_OWNED)) {
     owner = proc_config().proc_rank();
+    handle = entity;
     return MB_SUCCESS;
   int sharing_procs[MAX_SHARING_PROCS];
+  MBEntityHandle sharing_handles[MAX_SHARING_PROCS];
   result = mbImpl->tag_get_data(sharedp_tag(), &entity, 1,
                                 sharing_procs);
   RRA(" ");
   if (-1 != sharing_procs[0]) {
     owner = sharing_procs[0];
+    result = mbImpl->tag_get_data(sharedh_tag(), &entity, 1,
+                                  sharing_handles);
+    handle = sharing_handles[0];
     return MB_SUCCESS;
@@ -4227,10 +4691,14 @@
                                 sharing_procs);
   if (MB_SUCCESS == result && -1 != sharing_procs[0]) {
+    result = mbImpl->tag_get_data(sharedhs_tag(), &entity, 1,
+                                  sharing_handles);
     return MB_SUCCESS;
   owner = -1;
+  handle = 0;
   return MB_FAILURE;
@@ -4435,9 +4903,9 @@
 MBErrorCode MBParallelComm::get_sharing_parts( MBEntityHandle entity,
-                                 int part_ids_out[MAX_SHARING_PROCS],
-                                 int& num_part_ids_out,
-                                 MBEntityHandle remote_handles[MAX_SHARING_PROCS] )
+                                               int part_ids_out[MAX_SHARING_PROCS],
+                                               int& num_part_ids_out,
+                                               MBEntityHandle remote_handles[MAX_SHARING_PROCS] )
   // FIXME : assumes one part per proc, and therefore part_id == rank
@@ -4493,7 +4961,61 @@
   return result;
+  /** \brief Find a local ghost entity corresponding to owning proc and handle
+   * Given the handle on the owner and the proc, find the local handle to
+   * the corresponding entity.  Looks in both the nonowned and owned ghost
+   * lists.
+MBEntityHandle MBParallelComm::find_ghost_entity(MBEntityHandle owner_handle,
+                                                 int owner_proc)
+  int ind = get_buffers(owner_proc);
+  MBRange sub_range;
+  struct GhostStruct &ostruct = sharedEnts[ind];
+  if ((!ostruct.remoteHandles.empty() &&
+      ostruct.remoteHandles.find(owner_handle) != ostruct.remoteHandles.end()) ||
+      (!ostruct.noHandles.empty() &&
+       ostruct.noHandles.find(owner_handle) != ostruct.noHandles.end()))
+    // ok, it's an existing ghost entity; find local handle
+       sub_range = ostruct.localHandles.subset_by_type(
+           TYPE_FROM_HANDLE(owner_handle));
+  if (sub_range.empty()) return 0;
+  std::vector<MBEntityHandle> sharedhs(sub_range.size());
+  std::vector<int> sharedps(sub_range.size());
+  MBErrorCode result = mbImpl->tag_get_data(sharedh_tag(), sub_range,
+                                            &sharedhs[0]);
+  RRA("Failed to get shared handle tag.");
+  result = mbImpl->tag_get_data(sharedp_tag(), sub_range,
+                                &sharedps[0]);
+  RRA("Failed to get shared proc tag.");
+  for (int i = sub_range.size()-1; i >= 0; i--) {
+    if (sharedps[i] == owner_proc && sharedhs[i] == owner_handle)
+      return sub_range[i];
+    // not there; search sharedps/sharedhs tags
+  sharedhs.resize(MAX_SHARING_PROCS);
+  sharedps.resize(MAX_SHARING_PROCS);
+  for (MBRange::iterator rit = sub_range.begin();
+       rit != sub_range.end(); rit++) {
+    result = mbImpl->tag_get_data(sharedhs_tag(), &(*rit), 1, &sharedhs[0]);
+    RRA("Failed to get shared handles tag.");
+    result = mbImpl->tag_get_data(sharedps_tag(), &(*rit), 1, &sharedps[0]);
+    RRA("Failed to get shared procs tag.");
+    for (int i = 0; i < MAX_SHARING_PROCS; i++) {
+      if (sharedhs[i] == owner_handle && sharedps[i] == owner_proc) return *rit;
+      else if (-1 == sharedps[i]) break;
+    // not found
+  return 0;
 #ifdef TEST_PARALLELCOMM
 #include <iostream>
Modified: MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp
--- MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp	2009-01-30 18:11:39 UTC (rev 2605)
+++ MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp	2009-01-30 18:38:37 UTC (rev 2606)
@@ -31,6 +31,7 @@
 #include "MBProcConfig.hpp"
 #include <map>
 #include <set>
+#include <vector>
 #include "math.h"
 #include "mpi.h"
@@ -257,11 +258,34 @@
                                    bool verts_too = true,
                                    int operation = MBInterface::UNION);
+    /** \brief Set pstatus values on entities (vector-based function)
+     * \param pstatus_ents Entities to be set
+     * \param pstatus_val Pstatus value to be set
+     * \param lower_dim_ents If true, lower-dimensional ents (incl. vertices) set too
+     *        (and created if they don't exist)
+     * \param verts_too If true, vertices also set
+     * \param operation If UNION, pstatus_val is OR-d with existing value, otherwise
+     *        existing value is over-written
+  MBErrorCode set_pstatus_entities(MBEntityHandle *pstatus_ents,
+                                   int num_ents,
+                                   bool lower_dim_ents = false,
+                                   bool verts_too = true,
+                                   int operation = MBInterface::UNION);
   MBErrorCode get_owner(MBEntityHandle entity,
                         int &owner);
+    /** \brief Return the owner processor and handle of a given entity
+  MBErrorCode get_owner_handle(MBEntityHandle entity,
+                               int &owner,
+                               MBEntityHandle &handle);
     /** \brief Get entities on an inter-processor interface and of specified dimension
      * If other_proc is -1, any interface entities are returned.  If dim is -1,
      * entities of all dimensions on interface are returned.
@@ -285,24 +309,6 @@
     //! get processors with which this processor communicates
   MBErrorCode get_comm_procs(std::set<unsigned int> &procs);
-    //! pack the buffer with ALL data for orig_ents; return entities actually
-    //! packed (including reference sub-entities) in final_ents
-  MBErrorCode pack_buffer(MBRange &orig_ents,
-                          const bool adjacencies,
-                          const bool tags,
-                          const bool store_remote_handles,
-                          const bool iface_layer,
-                          MBRange &final_ents,
-                          std::vector<unsigned char> &buff,
-                          int &buff_size);
-    //! unpack a buffer; assume information is already in myBuffer
-  MBErrorCode unpack_buffer(unsigned char *buff_ptr,
-                            int from_proc,
-                            MBRange &entities);
     //! Get proc config for this communication object
   const MBProcConfig &proc_config() const {return procConfig;}
@@ -349,29 +355,28 @@
     //! return all the entities in parts owned locally
   MBErrorCode get_part_entities(MBRange &ents, int dim = -1);
-    //! remove from the range all ents not owned by this proc or already
-    //! shared with to_proc
-  MBErrorCode remove_nonowned_shared(MBRange &ents,
-                                     int to_proc,
-                                     bool owned_test = true,
-                                     bool shared_test = true);
-    /** Get entities owned by this processor (including non-shared entities).
-     *  Optionally remove from the result list any entities shared with
-     *  'to_proc'.
-     *\param ents       Input entities to check ownership of.
-     *\param owned_ents Output list.
-     *\param to_proc    Do not return owned entities if they are shared
-     *                  with this processor.
-     *\param owned_test Check entity ownership
-     *\param shared_test Test if entity is shared with 'to_proc'
+    /** Filter the entities by ownership and sharing value(s); if testing
+     * for sharing value, optional sharing processor can be specified.  Results
+     * returned in input list, unless result_ents is passed in non-null.
+     *\param ents       Input entities to filter
+     *\param owned_test Whether to perform ownership test
+     *\param owned_val Ownership value required to remain in list
+     *\param shared_test Whether to perform shared test
+     *\param shared_val Shared value required to remain in list (also subject
+     *                  to to_proc
+     *\param to_proc If non-negative and shared test is requested, proc
+     *               with which this entity must be shared to remain in list
+     *\param result_ents If non-null, results of filter are put in the
+     *       pointed-to range
-  MBErrorCode get_owned_entities( const MBRange& ents,
-                                  MBRange& owned_ents,
-                                  int to_proc = -1,
-                                  bool shared_test = false );
+  MBErrorCode filter_owned_shared( MBRange &ents,
+                                   bool owned_test,
+                                   bool owned_val,
+                                   bool shared_test,
+                                   bool shared_val,
+                                   int to_proc = -1,
+                                   MBRange *returned_ents = NULL);
   MBEntityHandle get_partitioning() const { return partitioningSet; }
   MBErrorCode set_partitioning( MBEntityHandle h );
   MBErrorCode get_global_part_count( int& count_out ) const;
@@ -399,13 +404,40 @@
     // from the onwing processor to any procs with copies.
   MBErrorCode update_shared_mesh();
+  MBErrorCode pack_buffer(MBRange &orig_ents,
+                          std::vector<int> &addl_procs,
+                          const bool adjacencies,
+                          const bool tags,
+                          const bool store_remote_handles,
+                          const int to_proc,
+                          MBRange &owned_shared,
+                          int &buff_size);
+  MBErrorCode unpack_buffer(unsigned char *buff_ptr,
+                            const int from_proc,
+                            const int ind,
+                            MBRange &final_ents,
+                            MBRange *nonowned_ghosts,
+                            std::set<unsigned int> &my_addl_procs);
 private:
   int num_subranges(const MBRange &this_range);
+    //! estimate size required to pack entities
+  int estimate_ents_buffer_size(MBRange &entities,
+                                const bool store_remote_handles);
+    //! estimate size required to pack sets
+  int estimate_sets_buffer_size(MBRange &entities,
     //! get (and possibly allocate) buffers for messages to/from to_proc; returns
-    //! index of to_proc in buffProcs vector
-  int get_buffers(int to_proc);
+    //! index of to_proc in buffProcs vector; if is_new is non-NULL, sets to
+    //! whether new buffer was allocated
+  int get_buffers(int to_proc, bool *is_new = NULL);
     //! pack entities (with adjs, tags too) and send to to_proc; also post a recv
     //! if store_remote_handles is true; pass back MPI_Request objects for these
@@ -415,16 +447,21 @@
     //! - MPI_Isend for sending entities
   MBErrorCode pack_send_entities(const int to_proc,
                                  MBRange &orig_ents,
-                                 const bool tags,
+                                 std::set<int> &addl_procs,
                                  std::vector<unsigned char> &send_buff,
                                  std::vector<unsigned char> &recv_buff,
                                  MPI_Request &send_req,
-                                 MPI_Request &recv_req,
-                                 MBRange &final_ents);
+                                 MPI_Request &recv_req);
+    //! send the indicated buffer, possibly sending size first
+  MBErrorCode send_buffer(const unsigned int to_proc,
+                          const unsigned char *send_buff,
+                          const unsigned int buff_size,
+                          const int msg_type,
+                          MPI_Request &send_req);
     //! use integer size in buffer to resize buffer, then post an
     //! Irecv to get message
   MBErrorCode recv_size_buff(const int from_proc,
@@ -441,46 +478,55 @@
-                                   std::vector<unsigned char> &send_buff,
-                                   MPI_Request &send_req,
-                                   MBRange &recd_ents);
+                                   MBRange &recd_ents,
+                                   std::set<int> &my_addl_procs);
     //! for all the entities in the received buffer; for each, save
     //! entities in this instance which match connectivity, or zero if none found
   MBErrorCode unpack_iface_entities(unsigned char *&buff_ptr,
+                                    const int ind,
                                     std::vector<MBEntityHandle> &recd_ents);
   MBErrorCode pack_entities(MBRange &entities,
-                            MBRange::const_iterator &start_rit,
-                            MBRange &whole_range,
-                            int &count,
-                            const bool just_count,
                             const int to_proc,
-                            std::vector<MBEntityType> &ent_types,
-                            std::vector<MBRange> &all_ranges,
-                            std::vector<int> &verts_per_entity);
+                            MBRange &owned_shared);
+    //! pack a range of entities with equal # verts per entity, along with
+    //! the range on the sending proc
+  MBErrorCode pack_entity_seq(const int nodes_per_entity,
+                              MBRange &these_ents,
+                              MBRange &entities,
+                              unsigned char *&buff_ptr);
+    //! pack a set of integer proc ranks into the buffer
+  MBErrorCode pack_addl_procs(std::set<unsigned int> &addl_procs,
+    //! unpack a set of integer proc ranks from the buffer
+  MBErrorCode unpack_addl_procs(unsigned char *&buff_ptr,
+                                std::set<unsigned int> &addl_procs);
   MBErrorCode unpack_entities(unsigned char *&buff_ptr,
-                              const int from_proc,
+                              const unsigned int from_proc,
+                              const int ind,
+                              MBRange *new_ghosts,
   MBErrorCode pack_sets(MBRange &entities,
-                        int &count,
                         const bool store_handles,
-                        std::vector<unsigned int> &options_vec);
+                        const int to_proc);
   MBErrorCode unpack_sets(unsigned char *&buff_ptr,
                           MBRange &entities,
@@ -502,6 +548,55 @@
                                  const int from_proc);
+    /* \brief Pack message with remote handles
+  MBErrorCode pack_remote_handles(MBRange &entities,
+  MBErrorCode pack_remote_handles(std::vector<MBEntityHandle> &entities,
+    /* \brief Unpack message with remote handles
+  MBErrorCode unpack_remote_handles(unsigned int from_proc,
+                                    const int ind,
+                                    MBRange &new_ghosted);
+    /* \brief Unack message with remote handles (updated buffer ptr not returned)
+                                    const unsigned char *buff_ptr,
+                                    const int ind,
+    /* \brief Pack message containing sharedhs and sharedps tags
+  MBErrorCode pack_sharedhps_tag(MBRange &new_ghosted,
+    /* \brief Unpack message containing sharedhs and sharedps tags
+  MBErrorCode unpack_sharedhps_tag(unsigned int from_proc,
+     * (does not update buffer ptr)
+                                   const unsigned char *buff_ptr);
   /**\brief Get list of tags for which to exchange data
    * Get tags and entities for which to exchange tag data.  This function
@@ -565,15 +660,12 @@
    *                            for each corresponding tag handle in 'all_tags.
   MBErrorCode pack_tags(MBRange &entities,
-                        int &count,
-                        const std::vector<MBRange> &tag_ranges );
     /**\brief Calculate buffer size required to packtag data
      *\param source_tag The tag for which data will be serialized
@@ -611,10 +703,10 @@
   MBErrorCode pack_tag( MBTag source_tag,
                         MBTag destination_tag,
-                        const MBRange &entites,
+                        const MBRange &entities,
-                        int &count,
                         const int to_proc );
@@ -655,13 +747,6 @@
   MBErrorCode pack_range_map(MBRange &this_range, MBEntityHandle actual_start,
                              HandleMap &handle_map);
-    //! for a given interface set, gets a number of layers of bridge entities
-    //! of dimension to_dim going through bridge dimension bridge_dim
-  MBErrorCode get_ghost_layers(MBEntityHandle iface_set,
-                               int num_layers,
-                               MBRange &to_ents);
     //! returns true if the set is an interface shared with to_proc
   bool is_iface_proc(MBEntityHandle this_set, int to_proc);
@@ -671,7 +756,32 @@
                                 std::vector<MBEntityHandle> &remote_handles,
                                 int from_proc);
+    //! for a list of entities, if any is non-owned, add destination proc
+    //! to addl_procs list for owner; tells that owner it will receive
+    //! destination handles message from to_proc
+  MBErrorCode get_addl_procs(MBRange &ghosted_ents,
+                             std::set<unsigned int> *addl_procs);
+    //! for specified bridge/ghost dimension, to_proc, and number
+    //! of layers, get the entities to be ghosted, and info on additional procs
+    //! needing to communicate with to_proc
+  MBErrorCode get_ghosted_entities(int bridge_dim,
+                                   int ghost_dim,
+                                   int to_proc,
+                                   int num_layers,
+    //! get interface entities to send, for deriving remote handles of higher-
+    //! dimensional interface entities
+  MBErrorCode get_iface_sent_entities(unsigned int to_proc,
+                                      MBRange &sent_ents);
 public:
+    //! add vertices adjacent to entities in this list
+  MBErrorCode add_verts(MBRange &sent_ents);
     //! replace handles in from_vec with corresponding handles on
     //! to_proc (by checking shared[p/h]_tag and shared[p/h]s_tag;
     //! if no remote handle and new_ents is non-null, substitute
@@ -700,12 +810,21 @@
   MBInterface* get_moab() const { return mbImpl; }
+    //! struct to store information on ghosted, ghost entities
+  struct GhostStruct {MBRange localHandles, remoteHandles,
+        noHandles, ownedShared;};
+  std::vector<struct MBParallelComm::GhostStruct> &shared_ents();
+  std::vector<unsigned int> &buff_procs();
 private:
     //! goes through from_vec, and for any with type MBMAXTYPE, replaces with
     //! new_ents value at index corresponding to id of entity in from_vec
   MBErrorCode get_local_handles(MBEntityHandle *from_vec,
                                 int num_ents,
-                                const MBRange &new_ents);
+                                const MBRange &new_ents,
+                                std::vector<MBEntityHandle> *no_ents = NULL);
     //! same as above except puts results in range
   MBErrorCode get_local_handles(const MBRange &remote_handles,
@@ -736,6 +855,11 @@
                               int remote_proc,
                               MBEntityHandle remote_handle);
+  MBEntityHandle find_ghost_entity(MBEntityHandle owning_handle,
+                                   int owning_proc);
     /** \brief Set pstatus tag interface bit on entities in sets passed in
   MBErrorCode tag_iface_entities();
@@ -762,22 +886,25 @@
   std::vector<unsigned char> myBuffer;
     //! more data buffers, proc-specific
-  std::vector<unsigned char> ownerRBuffs[MAX_SHARING_PROCS],
-    ownerSBuffs[MAX_SHARING_PROCS], ghostRBuffs[MAX_SHARING_PROCS],
-    ghostSBuffs[MAX_SHARING_PROCS];
+  std::vector<std::vector<unsigned char> > ownerRBuffs,
+      ownerSBuffs, ghostRBuffs, ghostSBuffs;
     //! request objects, may be used if store_remote_handles is used
   MPI_Request sendReqs[2*MAX_SHARING_PROCS];
     //! processor rank for each buffer index
-  std::vector<int> buffProcs;
+  std::vector<unsigned int> buffProcs;
     //! the partition, interface sets for this comm'n instance
   MBRange partitionSets, interfaceSets;
+    //! ghostStruct storing entities shared with buffProcs[i]
+    //! sharedEnts[i].ownedShared stores locally-owned shared ents
+    //! sharedEnts[i].localHandles stores ghost ents from other proc
+    //! sharedEnts[i].remoteHandles stores ghost ents from other proc,
+    //!    in terms of handles on owning proc
+  std::vector<struct GhostStruct> sharedEnts;
-    //! local entities ghosted to other procs
-  std::map<unsigned int, MBRange> ghostedEnts;
     //! tags used to save sharing procs and handles
   MBTag sharedpTag, sharedpsTag, sharedhTag, sharedhsTag, pstatusTag,
     ifaceSetsTag, partitionTag;
@@ -789,6 +916,16 @@
   int pcommID;
+inline std::vector<struct MBParallelComm::GhostStruct> &MBParallelComm::shared_ents()
+  return sharedEnts;
+inline std::vector<unsigned int> &MBParallelComm::buff_procs()
+  return buffProcs;
 inline MBErrorCode MBParallelComm::get_shared_proc_tags(MBTag &sharedp,
                                                         MBTag &sharedps,
                                                         MBTag &sharedh,
@@ -829,12 +966,33 @@
   MBErrorCode result = get_interface_procs(procs);
   if (MB_SUCCESS != result) return result;
-    // add any procs sharing ghosts but not already in exch_procs
-  for (std::map<unsigned int, MBRange>::iterator mit = ghostedEnts.begin();
-       mit != ghostedEnts.end(); mit++)
-    procs.insert((*mit).first);
+  std::copy(buffProcs.begin(), buffProcs.end(), std::inserter(procs, procs.begin()));
   return MB_SUCCESS;
+inline MBErrorCode MBParallelComm::unpack_remote_handles(unsigned int from_proc,
+                                                         const int ind,
+  unsigned char *tmp_ptr = const_cast<unsigned char *>(buff_ptr);
+  return unpack_remote_handles(from_proc, tmp_ptr, num_layers, ind, new_ghosted);
+inline MBErrorCode MBParallelComm::unpack_sharedhps_tag(unsigned int from_proc,
+  return unpack_sharedhps_tag(from_proc, tmp_ptr);
+inline MBErrorCode MBParallelComm::get_owner(MBEntityHandle entity,
+                                             int &owner)
+  MBEntityHandle tmp_handle;
+  return get_owner_handle(entity, owner, tmp_handle);
 #endif
Modified: MOAB/branches/parallel_ghosting/parallel/WriteHDF5Parallel.cpp
--- MOAB/branches/parallel_ghosting/parallel/WriteHDF5Parallel.cpp	2009-01-30 18:11:39 UTC (rev 2605)
+++ MOAB/branches/parallel_ghosting/parallel/WriteHDF5Parallel.cpp	2009-01-30 18:38:37 UTC (rev 2606)
@@ -73,8 +73,10 @@
 #ifdef NDEBUG
-#  define assert(A)
+#  undef assert(A)
+#  define assert
 #else
+#  undef assert
 #  define assert(A) if (!(A)) do_assert(__FILE__, __LINE__, #A)
    static void do_assert( const char* file, int line, const char* condstr )
@@ -298,7 +300,8 @@
   MBRange nonowned;
   tmpset.clear();
-  result = myPcomm->get_owned_entities( nodeSet.range, tmpset );
+  result = myPcomm->filter_owned_shared( nodeSet.range,
+                                         true, true, false, false, -1, &tmpset );
     return result;
   nodeSet.range.swap( tmpset );
@@ -307,7 +310,8 @@
   for (std::list<ExportSet>::iterator eiter = exportList.begin();
        eiter != exportList.end(); ++eiter ) {
     tmpset.clear();
-    result = myPcomm->get_owned_entities( eiter->range, tmpset );
+    result = myPcomm->filter_owned_shared( eiter->range,
+                                           true, true, false, false, -1, &tmpset);
       return result;
     eiter->range.swap( tmpset );
Modified: MOAB/branches/parallel_ghosting/parallel/crystal.c
--- MOAB/branches/parallel_ghosting/parallel/crystal.c	2009-01-30 18:11:39 UTC (rev 2605)
+++ MOAB/branches/parallel_ghosting/parallel/crystal.c	2009-01-30 18:38:37 UTC (rev 2606)
@@ -104,7 +104,7 @@
 static void crystal_send(crystal_data *p, uint target, int recvn)
-  MPI_Request req[3];
+  MPI_Request req[3] = {MPI_REQUEST_NULL, MPI_REQUEST_NULL, MPI_REQUEST_NULL};
   MPI_Status status[3];
   uint count[2]={0,0},sum,*recv[2];
   crystal_buf *t;
Modified: MOAB/branches/parallel_ghosting/parallel/mbparallelcomm_test.cpp
--- MOAB/branches/parallel_ghosting/parallel/mbparallelcomm_test.cpp	2009-01-30 18:11:39 UTC (rev 2605)
+++ MOAB/branches/parallel_ghosting/parallel/mbparallelcomm_test.cpp	2009-01-30 18:38:37 UTC (rev 2606)
@@ -390,12 +390,17 @@
   MBParallelComm *pcomm = new MBParallelComm(mbImpl);
   std::vector<unsigned char> buff(1024);
   int buff_size;
-  result = pcomm->pack_buffer(ents, false, true, false, false, -1,
-                              whole_range, buff, buff_size);
+  std::set<unsigned int> my_addl_procs;
+  std::vector<int> addl_procs;
+  MBRange nonowned_ghosts[MAX_SHARING_PROCS];
+  result = pcomm->pack_buffer(ents, addl_procs, false, true, false, -1,
+                              nonowned_ghosts[0], buff, buff_size);
   RRA("Packing buffer count (non-stored handles) failed.");
+  nonowned_ghosts[0].clear();
-  result = pcomm->unpack_buffer(&buff[0], false, -1, new_ents);
-  RRA("Unacking buffer (non-stored handles) failed.");
+  result = pcomm->unpack_buffer(&buff[0], false, -1, -1, new_ents, nonowned_ghosts,
+                                my_addl_procs);
+  RRA("Unpacking buffer (non-stored handles) failed.");
   return MB_SUCCESS;
@@ -458,6 +463,8 @@
   int failure = MPI_Reduce(&num_local, &num_total, 1,
                            MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD);
+  if (failure) result = MB_FAILURE;
   if (0 == rank)
     std::cout << "Total # owned regions = " << num_total << std::endl;
Modified: MOAB/branches/parallel_ghosting/parallel/parallel_hdf5_test.cc
--- MOAB/branches/parallel_ghosting/parallel/parallel_hdf5_test.cc	2009-01-30 18:11:39 UTC (rev 2605)
+++ MOAB/branches/parallel_ghosting/parallel/parallel_hdf5_test.cc	2009-01-30 18:38:37 UTC (rev 2606)
@@ -258,12 +258,13 @@
   std::fill( counts, counts+MBENTITYSET, 0u );
   for (MBEntityType t = MBVERTEX; t < MBENTITYSET; ++t) {
-    MBRange range;
+    MBRange range, r2;
     rval = moab.get_entities_by_type( 0, t, range );
     CHECK_ERR(rval);
-    rval = pcomm->remove_nonowned_shared( range, -1, true, false );
+    rval = pcomm->filter_owned_shared(range, true, true, false, false,
+                                      -1, &r2);
     CHECK_ERR(rval);
-    counts[t] = range.size();
+    counts[t] = r2.size();
Modified: MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp
--- MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp	2009-01-30 18:11:39 UTC (rev 2605)
+++ MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp	2009-01-30 18:38:37 UTC (rev 2606)
@@ -117,7 +117,7 @@
 // Check consistancy of sharing data.  (E.g. compare sharing procs for
-// vertics to that of adjacent elements, compare sharing data for
+// vertices to that of adjacent elements, compare sharing data for
 // interfaces with that of contained entities, etc.)
 MBErrorCode test_elements_on_several_procs( const char* filename );
 // Test correct ghosting of elements
@@ -215,9 +215,9 @@
   num_errors += RUN_TEST( test_elements_on_several_procs, filename );
   num_errors += RUN_TEST( test_ghost_elements_3_2_1, filename );
-//  num_errors += RUN_TEST( test_ghost_elements_3_2_2, filename );
+  num_errors += RUN_TEST( test_ghost_elements_3_2_2, filename );
   num_errors += RUN_TEST( test_ghost_elements_3_0_1, filename );
-//  num_errors += RUN_TEST( test_ghost_elements_2_0_1, filename );
+  num_errors += RUN_TEST( test_ghost_elements_2_0_1, filename );
   num_errors += RUN_TEST( test_ghost_tag_exchange, filename );
   num_errors += RUN_TEST( regression_ghost_tag_exchange_no_default, filename );
   num_errors += RUN_TEST( test_interface_owners, filename );
@@ -581,7 +581,39 @@
     my_error = 1;
   PCHECK(!my_error);
+    // test contents of interface sets against sharedEnts structure in pcomm;
+  MBParallelComm* pcomm = MBParallelComm::get_pcomm(&moab, 0);
+  MBRange iface_ents, shared_ents, owned_ents;
+  for (unsigned int i = 0; i < pcomm->buff_procs().size(); i++) {
+      // get all the interface entities for this proc and the sharedEnts entities
+    rval = pcomm->get_iface_entities(pcomm->buff_procs()[i], -1, iface_ents);
+    if (MB_SUCCESS != rval) my_error = 1;
+    owned_ents.merge(pcomm->shared_ents()[i].ownedShared);
+    shared_ents.merge(pcomm->shared_ents()[i].localHandles);
+    // over all interfaces, the owned and shared lists should be mutually exclusive
+    // and the interface ents should be contained in one of those
+  if (!(owned_ents.intersect(shared_ents)).empty()) {
+    std::cerr << "Contents of localHandles and ownedShared not consistent on proc "
+              << pcomm->proc_config().proc_rank() << std::endl;
+    my_error = 1;
+  MBRange rem_ents = iface_ents.subtract(shared_ents);
+  rem_ents = rem_ents.subtract(owned_ents);
+  if (!rem_ents.empty()) {
+    std::cerr << "Interface entities inconsistent with sharedEnts on proc "
+    my_error = 1;
+  PCHECK(!my_error);
+    // finally, check adjacencies just to make sure they're consistent
+  rval = mb_instance.check_adjacencies();
   return MB_SUCCESS;
@@ -688,7 +720,7 @@
       iface_ghosts.clear();
       rval = moab.get_adjacencies( iface_ents, ghost_dimension, false, iface_ghosts, MBInterface::UNION ); CHKERR(rval);
       iface_ents.clear();
-      rval = moab.get_adjacencies( iface_ghosts, bridge_dimension, false, iface_ents, MBInterface::UNION ); CHKERR(rval);
+      rval = moab.get_adjacencies( iface_ghosts, bridge_dimension, true, iface_ents, MBInterface::UNION ); CHKERR(rval);
       // intersect with entities in adjacent partitions
@@ -733,6 +765,10 @@
   partition_geom[3] = pcomm->partition_sets();
   PCHECK( !partition_geom[3].empty() );
+    // exchange id tags to allow comparison by id
+  rval = pcomm->exchange_tags(id_tag);
+  CHKERR(rval);
     // Get geometric surfaces
   MBRange surfs, tmp;
@@ -1259,7 +1295,7 @@
     if (match)
       continue;
-    std::cerr << "INCONSISTANT OWERS FOR VERTEX " << it->first << std::endl
+    std::cerr << "INCONSISTANT OWNERS FOR VERTEX " << it->first << std::endl
               << "  (proc,owner) pairs: ";
     for (size_t i = 0; i < it->second.owners.size(); ++i)
       std::cerr << "(" << it->second.procs[i]
@@ -1363,6 +1399,13 @@
   rval = pcomm.exchange_ghost_cells( 2, 1, 1, true );
   PCHECK(MB_SUCCESS == rval);
+  MBTag id_tag;
+  rval = mb.tag_get_handle( GLOBAL_ID_TAG_NAME, id_tag );
+  PCHECK(MB_SUCCESS == rval);
+  rval = pcomm.exchange_tags(id_tag);
     // get all vertices
   MBRange vertices;
   mb.get_entities_by_type( 0, MBVERTEX, vertices );
@@ -1371,9 +1414,6 @@
   std::vector<int> vert_ids(vertices.size()), vert_owners(vertices.size());
   std::vector<int> vert_shared(vertices.size()*MAX_SHARING_PROCS);
   std::vector<MBEntityHandle> vert_handles(vertices.size()*MAX_SHARING_PROCS);
-  MBTag id_tag;
-  rval = mb.tag_get_handle( GLOBAL_ID_TAG_NAME, id_tag );
-  PCHECK(MB_SUCCESS == rval);
   rval = mb.tag_get_data( id_tag, vertices, &vert_ids[0] );
Modified: MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp
--- MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp	2009-01-30 18:11:39 UTC (rev 2605)
+++ MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp	2009-01-30 18:38:37 UTC (rev 2606)
@@ -71,14 +71,20 @@
     CHECK_ERR(rval);
-  MBRange tmp_range;
   MBParallelComm *pcomm = new MBParallelComm( &moab );
   int size = 0;
   std::vector<unsigned char> buff;
-  rval = pcomm->pack_buffer( entities, false, true, false, false,
-                             -1, tmp_range, buff, size );
+    // get the necessary vertices too
+  rval = pcomm->add_verts(entities);
   CHECK_ERR(rval);
+  MBRange tmp_range;
+  rval = pcomm->pack_buffer( entities, addl_procs, false, true, false,
+                             -1, tmp_range, buff, size);
+  CHECK_ERR(rval);
   delete pcomm;
   moab.~MBCore();
@@ -86,7 +92,10 @@
   pcomm = new MBParallelComm( &moab);
   entities.clear();
-  rval = pcomm->unpack_buffer( &buff[0], false, -1, entities );
+  rval = pcomm->unpack_buffer( &buff[0], false, -1, -1, entities,
+                               nonowned_ghosts, my_addl_procs);
   CHECK_ERR(rval);
   delete pcomm;
Modified: MOAB/branches/parallel_ghosting/tools/iMesh/iMeshP.h
--- MOAB/branches/parallel_ghosting/tools/iMesh/iMeshP.h	2009-01-30 18:11:39 UTC (rev 2605)
+++ MOAB/branches/parallel_ghosting/tools/iMesh/iMeshP.h	2009-01-30 18:38:37 UTC (rev 2606)
@@ -11,15 +11,12 @@
 #endif
 /** Handles needed in iMeshP */
-#define ITAPS_DECLARE_HANDLE( NAME ) typedef struct NAME##DummyStruct *NAME
+typedef struct iMeshP_PartitionHandle_Private* iMeshP_PartitionHandle;
+typedef struct iMeshP_RequestHandle_Private* iMeshP_RequestHandle;
-ITAPS_DECLARE_HANDLE( iMeshP_PartitionHandle );
-ITAPS_DECLARE_HANDLE( iMeshP_RequestHandle );
 /* Since we allow overloading of iMesh functions' entity set handles with
  * part handles, iMeshP_PartHandle must be defined the same as
  * iBase_EntitySetHandle. */
-/* ITAPS_DECLARE_HANDLE( iMeshP_PartHandle );*/
 typedef iBase_EntitySetHandle iMeshP_PartHandle;
 typedef unsigned iMeshP_Part;
@@ -1243,7 +1240,7 @@
             iMesh_Instance instance,
             const iMeshP_PartitionHandle partition,
             const iMeshP_PartHandle part,
-            const iBase_EntityHandle entity_set,
+            const iBase_EntitySetHandle entity_set,
             int entity_type_requestor,
             int entity_topology_requestor,
             int entity_type_requested,
Modified: MOAB/branches/parallel_ghosting/tools/iMesh/iMeshP_MOAB.cpp
--- MOAB/branches/parallel_ghosting/tools/iMesh/iMeshP_MOAB.cpp	2009-01-30 18:11:39 UTC (rev 2605)
+++ MOAB/branches/parallel_ghosting/tools/iMesh/iMeshP_MOAB.cpp	2009-01-30 18:38:37 UTC (rev 2606)
@@ -114,7 +114,7 @@
 DECLARE_ALLOWED_ITAPS_SET_CONVERSION( iMeshP_PartitionHandle )
 //DECLARE_ALLOWED_ITAPS_SET_CONVERSION( iMeshP_PartHandle )
-//DECLARE_ALLOWED_ITAPS_SET_CONVERSION( iBase_EntitySetHandle )
+DECLARE_ALLOWED_ITAPS_SET_CONVERSION( iBase_EntitySetHandle )
 DECLARE_ALLOWED_ITAPS_CONVERSION( iBase_EntityHandle )
@@ -787,7 +787,7 @@
                                     const int entity_topology,
                                     const int array_size,
                                     const iMeshP_Part nbor_part_id,
-                                    iMesh_EntityIterator* entity_iterator,
+                                    iMesh_EntityArrIterator* entity_iterator,
                                     int* err )
   MBRange entities;
@@ -797,7 +797,7 @@
                                             entity_topology,
                                             nbor_part_id,
                                             entities ); CHKERR(rval);
-  *entity_iterator = create_itaps_iterator( entities, array_size );
+  *entity_iterator = (iMesh_EntityArrIterator) create_itaps_iterator( entities, array_size );
   RETURN( entity_iterator ? iBase_SUCCESS : iBase_FAILURE );
@@ -993,7 +993,7 @@
 void iMeshP_getAdjEntities( iMesh_Instance instance,
                             const iMeshP_PartitionHandle partition_handle,
                             const iMeshP_PartHandle part_handle,
-                            const iBase_EntityHandle entity_set_handle,
+                            const iBase_EntitySetHandle entity_set_handle,
                             const int entity_type_requestor,
                             const int entity_topology_requestor,
                             const int entity_type_requested,
@@ -1101,7 +1101,7 @@
   if (iBase_SUCCESS != *err)
     return;
-  *entArr_iterator = create_itaps_iterator( r, requested_array_size );
+  *entArr_iterator = (iMesh_EntityArrIterator)create_itaps_iterator( r, requested_array_size );
   RETURN (iBase_SUCCESS);
