[MOAB-dev] r2605 - MOAB/trunk/tools/iMesh
kraftche at mcs.anl.gov
Fri Jan 30 12:11:39 CST 2009
Author: kraftche
Date: 2009-01-30 12:11:39 -0600 (Fri, 30 Jan 2009)
New Revision: 2605
Modified:
MOAB/trunk/tools/iMesh/iMeshP.h
MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp
Log:
update iMeshP.h for iBase and iMesh changes
Modified: MOAB/trunk/tools/iMesh/iMeshP.h
--- MOAB/trunk/tools/iMesh/iMeshP.h 2009-01-30 17:25:02 UTC (rev 2604)
+++ MOAB/trunk/tools/iMesh/iMeshP.h 2009-01-30 18:11:39 UTC (rev 2605)
@@ -11,15 +11,12 @@
#endif
/** Handles needed in iMeshP */
-#define ITAPS_DECLARE_HANDLE( NAME ) typedef struct NAME##DummyStruct *NAME
+typedef struct iMeshP_PartitionHandle_Private* iMeshP_PartitionHandle;
+typedef struct iMeshP_RequestHandle_Private* iMeshP_RequestHandle;
-ITAPS_DECLARE_HANDLE( iMeshP_PartitionHandle );
-ITAPS_DECLARE_HANDLE( iMeshP_RequestHandle );
/* Since we allow overloading of iMesh functions' entity set handles with
* part handles, iMeshP_PartHandle must be defined the same as
* iBase_EntitySetHandle. */
-/* ITAPS_DECLARE_HANDLE( iMeshP_PartHandle );*/
typedef iBase_EntitySetHandle iMeshP_PartHandle;
typedef unsigned iMeshP_Part;
@@ -1243,7 +1240,7 @@
iMesh_Instance instance,
const iMeshP_PartitionHandle partition,
const iMeshP_PartHandle part,
- const iBase_EntityHandle entity_set,
+ const iBase_EntitySetHandle entity_set,
int entity_type_requestor,
int entity_topology_requestor,
int entity_type_requested,
Modified: MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp 2009-01-30 17:25:02 UTC (rev 2604)
+++ MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp 2009-01-30 18:11:39 UTC (rev 2605)
@@ -114,7 +114,7 @@
DECLARE_ALLOWED_ITAPS_SET_CONVERSION( iMeshP_PartitionHandle )
//DECLARE_ALLOWED_ITAPS_SET_CONVERSION( iMeshP_PartHandle )
-//DECLARE_ALLOWED_ITAPS_SET_CONVERSION( iBase_EntitySetHandle )
+DECLARE_ALLOWED_ITAPS_SET_CONVERSION( iBase_EntitySetHandle )
DECLARE_ALLOWED_ITAPS_CONVERSION( iBase_EntityHandle )
@@ -787,7 +787,7 @@
const int entity_topology,
const int array_size,
const iMeshP_Part nbor_part_id,
- iMesh_EntityIterator* entity_iterator,
+ iMesh_EntityArrIterator* entity_iterator,
int* err )
MBRange entities;
@@ -797,7 +797,7 @@
entity_topology,
nbor_part_id,
entities ); CHKERR(rval);
- *entity_iterator = create_itaps_iterator( entities, array_size );
+ *entity_iterator = (iMesh_EntityArrIterator) create_itaps_iterator( entities, array_size );
RETURN( entity_iterator ? iBase_SUCCESS : iBase_FAILURE );
@@ -993,7 +993,7 @@
void iMeshP_getAdjEntities( iMesh_Instance instance,
const iMeshP_PartitionHandle partition_handle,
const iMeshP_PartHandle part_handle,
- const iBase_EntityHandle entity_set_handle,
+ const iBase_EntitySetHandle entity_set_handle,
const int entity_type_requestor,
const int entity_topology_requestor,
const int entity_type_requested,
@@ -1101,7 +1101,7 @@
if (iBase_SUCCESS != *err)
return;
- *entArr_iterator = create_itaps_iterator( r, requested_array_size );
+ *entArr_iterator = (iMesh_EntityArrIterator)create_itaps_iterator( r, requested_array_size );
RETURN (iBase_SUCCESS);
