[MOAB-dev] One more question: TRI3/6
Wollaber, Allan B. awollaber at anl.gov
Thu Jan 15 15:42:22 CST 2009
I've noticed that the vertices coming back from a TRI3 or TRI6 element
appear to be numbered in the wrong direction (clockwise instead of
counterclockwise). For instance, for a TRI3, I get (using a one-based
indexing):
[NTmesh]...Global coordinate for each mesh vertex in cm
[NTmesh]...     1 X,Y,Z =  0.000000000E+00, 0.000000000E+00,
[NTmesh]...     2 X,Y,Z =  1.000000000E+00, 0.000000000E+00,
[NTmesh]...     3 X,Y,Z =  0.000000000E+00, 1.000000000E+00
[NTmesh]...Finite element connectivity listing
[NTmesh]...     1 Links      1      3      2
which corresponds to:
2
1-------3
And for a TRI6 I get
[NTmesh]...     1 X,Y,Z =  0.000000000E+00, 1.000000000E+00,
[NTmesh]...     2 X,Y,Z =  0.000000000E+00, 0.000000000E+00,
[NTmesh]...     3 X,Y,Z =  0.000000000E+00, 5.000000000E-01,
[NTmesh]...     4 X,Y,Z =  1.000000000E+00, 0.000000000E+00,
[NTmesh]...     5 X,Y,Z =  5.000000000E-01, 5.000000000E-01,
[NTmesh]...     6 X,Y,Z =  5.000000000E-01, 0.000000000E+00,
[NTmesh]...     1 Links      2      1      4      3      5      6
2
4    5
1----6---3
This seems to be against the MBCN convention, which assumes
counterclockwise numbering. Is this a bug, or am I doing something
wrong?  The code I am using to get the connectivity is the same as the
snippet I sent several emails ago.
- Allan
URL: <https://lists.mcs.anl.gov/mailman/private/moab-dev/attachments/20090115/c9ead6ab/attachment.htm>
