[MOAB-dev] r2552 - MOAB/trunk
kraftche at mcs.anl.gov
Thu Jan 15 11:11:36 CST 2009
Author: kraftche
Date: 2009-01-15 11:11:36 -0600 (Thu, 15 Jan 2009)
New Revision: 2552
Modified:
MOAB/trunk/cub_file_test.cc
Log:
add another unit test for the cub file reader
Modified: MOAB/trunk/cub_file_test.cc
--- MOAB/trunk/cub_file_test.cc 2009-01-15 16:46:52 UTC (rev 2551)
+++ MOAB/trunk/cub_file_test.cc 2009-01-15 17:11:36 UTC (rev 2552)
@@ -139,8 +139,10 @@
void test_hex9 () { test_ho_elements(MBHEX, 9); }
void test_hex20() { test_ho_elements(MBHEX, 20); }
-void test_hex27() { test_ho_elements(MBHEX, 27); }
+void test_hex27() { test_ho_elements(MBHEX, 27); }
+void test_multiple_files();
int main()
int result = 0;
@@ -166,6 +168,7 @@
result += RUN_TEST(test_hex9 );
result += RUN_TEST(test_hex20);
result += RUN_TEST(test_hex27);
+ result += RUN_TEST(test_multiple_files);
return result;
@@ -1001,8 +1004,7 @@
MBCore mb_impl;
MBInterface& mb = mb_impl;
- MBEntityHandle set;
- read_file( mb, ho_file, &set );
+ read_file( mb, ho_file );
MBErrorCode rval;
MBTag ho_tag, block_tag;
@@ -1035,3 +1037,51 @@
for (i = entities.begin(); i != entities.end(); ++i)
check_adj_ho_nodes( mb, *i );
+ // load two surface meshes, one at z=+5 at z=-5.
+ MBErrorCode rval;
+ MBCore mb_impl;
+ MBInterface& mb = mb_impl;
+ MBEntityHandle file1, file2;
+ read_file( mb, input_file_1, &file1);
+ read_file( mb, input_file_1, &file2 );
+ // first check that we get the same number of verts from
+ // each file and that they are distinct vertices
+ MBRange file1_verts, file2_verts;
+ rval = mb.get_entities_by_type( file1, MBVERTEX, file1_verts );
+ CHECK_ERR(rval);
+ CHECK( !file1_verts.empty() );
+ rval = mb.get_entities_by_type( file2, MBVERTEX, file2_verts );
+ CHECK_ERR(rval);
+ CHECK( !file2_verts.empty() );
+ CHECK_EQUAL( file1_verts.size(), file2_verts.size() );
+ CHECK( file1_verts.intersect( file2_verts ).empty() );
+ // now check that we get the same number of elements from
+ MBRange file1_elems, file2_elems;
+ rval = mb.get_entities_by_dimension( file1, 3, file1_elems );
+ CHECK_ERR(rval);
+ CHECK( !file1_elems.empty() );
+ rval = mb.get_entities_by_dimension( file2, 3, file2_elems );
+ CHECK_ERR(rval);
+ CHECK( !file2_elems.empty() );
+ CHECK_EQUAL( file1_elems.size(), file2_elems.size() );
+ CHECK( file1_elems.intersect( file2_elems ).empty() );
+ // now check that the connectivity for each element is
+ // defined using the appropriate vertex instances
+ MBRange file1_elem_verts, file2_elem_verts;
+ rval = mb.get_adjacencies( file1_elems, 0, false, file1_elem_verts, MBInterface::UNION );
+ CHECK_ERR(rval);
+ rval = mb.get_adjacencies( file2_elems, 0, false, file2_elem_verts, MBInterface::UNION );
+ CHECK_ERR(rval);
+ CHECK_EQUAL( file1_elem_verts.size(), file2_elem_verts.size() );
+ CHECK( file1_elem_verts.intersect( file1_verts ) == file1_elem_verts );
+ CHECK( file2_elem_verts.intersect( file2_verts ) == file2_elem_verts );
