[MOAB-dev] r2547 - MOAB/trunk
kraftche at mcs.anl.gov
Wed Jan 14 15:42:11 CST 2009
Author: kraftche
Date: 2009-01-14 15:42:11 -0600 (Wed, 14 Jan 2009)
New Revision: 2547
Modified:
MOAB/trunk/TypeSequenceManager.cpp
Log:
refactor TypeSequenceManager::replace_subsequence -- fixes several bugs
Modified: MOAB/trunk/TypeSequenceManager.cpp
--- MOAB/trunk/TypeSequenceManager.cpp 2009-01-14 21:41:23 UTC (rev 2546)
+++ MOAB/trunk/TypeSequenceManager.cpp 2009-01-14 21:42:11 UTC (rev 2547)
@@ -157,93 +157,91 @@
iterator i = lower_bound( seq_ptr->start_handle() );
if (i == end() || (*i)->data() == seq_ptr->data())
return MB_FAILURE;
+ // new sequence must be a subset of an existing one
if (seq_ptr->start_handle() < (*i)->start_handle() ||
seq_ptr->end_handle() > (*i)->end_handle())
return MB_FAILURE;
+ // new sequence's data must be new also, and cannot intersect
+ // any existing sequence (just require that the data range
+ // matches the sequence range for now)
if (!seq_ptr->using_entire_data())
return MB_FAILURE;
- (*i)->data()->move_tag_data( seq_ptr->data(), tag_server );
+ // copy tag data (move owership of var-len data)
+ SequenceData* const dead_data = (*i)->data();
+ dead_data->move_tag_data( seq_ptr->data(), tag_server );
- // Get the range of sequences that point to the shared
- // SequenceData instance. Untimately, should have the
- // following iterators:
- // p : first sequence sharing SequenceData
- // j : last sequence before where seq_ptr will be (or i if no prev seq)
- // i : first sequence after where seq_ptr will be (or j if no next seq)
- // n : the last sequence sharing the SequenceData
- iterator j = i, n = i;
- iterator p = (*i)->data()->seqManData.firstSequence;
+ // split sequences sharing old data into two groups:
+ // p->i : first sequence to i
+ // i->n : i to one past last sequence
+ iterator p, n = i;
+ p = (*i)->data()->seqManData.firstSequence;
for (++n; n != end() && (*n)->data() == (*i)->data(); ++n);
- --n;
- // quick case -- replacing entire, single sequence
- if (n == p &&
- (*i)->start_handle() == seq_ptr->start_handle() &&
- (*i)->end_handle() == seq_ptr->end_handle())
- // delete old sequence and data (sequence first in case
- // it needs to reference data during destruction)
+ // First subdivide EntitySequence as necessary
+ // Move i to be the first sequence past the insertion point
+ // such that the new order will be:
+ // [p,i-1] seq_ptr [i,n]
+ // where p == i if no previous sequence
+ // Four possible cases:
+ // 0. All entities in sequence are in new sequence
+ // 1. Old entities in sequence before and after new sequence,
+ // reqiring sequence to be split.
+ // 2. Old entities after new sequence
+ // 3. Old entities before new sequence
+ const bool some_before = ((*i)->start_handle() < seq_ptr->start_handle());
+ const bool some_after = ((*i)-> end_handle() > seq_ptr-> end_handle());
+ // case 0
+ if (!(some_before || some_after)) {
+ // remove dead sequence from internal lists
EntitySequence* seq = *i;
- SequenceData* data = seq->data();
- if (!seq->using_entire_data())
- availableList.erase( data );
+ iterator dead = i; ++i;
+ if (p == dead)
+ p = i;
+ sequenceSet.erase( dead );
+ // delete old sequence
delete seq;
- delete data;
- // update structures for tracking sequences
- iterator d = i++;
- sequenceSet.erase( d );
- i = sequenceSet.insert( i, seq_ptr );
- if (!seq_ptr->using_entire_data())
- availableList.insert( seq_ptr->data() );
// make sure lastReferenced isn't stale
if (lastReferenced == seq)
lastReferenced = seq_ptr;
- // each SequenceData has pointer to the first EntitySequence referencing it
- seq_ptr->data()->seqManData.firstSequence = i;
- assert( check_valid_data( seq_ptr ) );
- return MB_SUCCESS;
- // remove entities in new sequence from current sequence list
- if ((*i)->start_handle() == seq_ptr->start_handle()) {
- if (j != p)
- --j;
- (*i)->pop_front( seq_ptr->end_handle() - seq_ptr->start_handle() + 1 );
+ // case 1
+ else if (some_before && some_after) {
+ i = split_sequence( i, seq_ptr->start_handle() );
+ (*i)->pop_front( seq_ptr->size() );
- else if ((*i)->end_handle() == seq_ptr->end_handle()) {
- (*i)->pop_back( seq_ptr->end_handle() - seq_ptr->start_handle() + 1 );
- if (i != n)
- ++i;
+ // case 2
+ else if (some_after) {
- else {
- i = split_sequence( i, seq_ptr->start_handle() );
- if (n == j)
- n = i;
+ // case 3
+ else { // some_before
+ (*i)->pop_back( seq_ptr->size() );
+ ++i;
- // split underlying sequence data
- SequenceData* dead_data = (*i)->data();
+ // now subdivid the underlying sequence data as necessary
availableList.erase( dead_data );
if (p != i) {
- SequenceData* new_data = (*p)->create_data_subset( (*p)->start_handle(), (*j)->end_handle() );
+ iterator last = i; --last;
+ SequenceData* new_data = (*p)->create_data_subset( (*p)->start_handle(), (*last)->end_handle() );
new_data->seqManData.firstSequence = p;
- iterator s = j;
- for (++s; p != s; ++p)
+ for (; p != i; ++p)
(*p)->data( new_data );
dead_data->move_tag_data( new_data, tag_server );
if (!(*new_data->seqManData.firstSequence)->using_entire_data())
availableList.insert( new_data );
- if (j != n) {
- SequenceData* new_data = (*n)->create_data_subset( (*i)->start_handle(), (*n)->end_handle() );
+ if (i != n) {
+ iterator last = n; --last;
+ SequenceData* new_data = (*i)->create_data_subset( (*i)->start_handle(), (*last)->end_handle() );
new_data->seqManData.firstSequence = i;
- for (++n; i != n; ++i)
+ for (; i != n; ++i)
(*i)->data( new_data );
@@ -253,7 +251,6 @@
// put new sequence in lists
return insert_sequence( seq_ptr );
TypeSequenceManager::iterator TypeSequenceManager::erase( iterator i )
