[MOAB-dev] r2546 - MOAB/trunk
kraftche at mcs.anl.gov
Wed Jan 14 15:41:23 CST 2009
Author: kraftche
Date: 2009-01-14 15:41:23 -0600 (Wed, 14 Jan 2009)
New Revision: 2546
Modified:
MOAB/trunk/MBRange.cpp
Log:
fix bug in MBRange::insert when hint is past correct insert position
Modified: MOAB/trunk/MBRange.cpp
--- MOAB/trunk/MBRange.cpp 2009-01-14 15:48:20 UTC (rev 2545)
+++ MOAB/trunk/MBRange.cpp 2009-01-14 21:41:23 UTC (rev 2546)
@@ -314,9 +314,13 @@
PairNode* iter = prev.mNode;
- if (iter == &mHead)
+ // If iterator is at end, set it to last.
+ // Thus if the hint was to append, we start searching
+ // at the end of the list.
+ if (iter == &mHead)
iter = mHead.mPrev;
- if ( iter->mPrev == &mHead || iter->mPrev->second+1 < val1 )
+ // if hint (prev) is past insert position, reset it to the beginning.
+ if (iter != &mHead && iter->first > val2+1)
iter = mHead.mNext;
// Input range is before beginning?
