Ok.
- tim
Jason Kraftcheck wrote:
> Tim Tautges wrote:
>> kraftche at mcs.anl.gov wrote:
>>> + // Put additional higher-order nodes into element connectivity list.
>>> + // Cubit saves full connectivity list only for NodeHex and NodeTet
>>> + // elements. Other element types will only have the corners and
>>> + // the mid-element node if there is one. Need to reconsturct
>>> additional
>>> + // connectivity entries from mid-nodes of adjacent lower-order
>>> entities.
>>> + int node_per_elem = cub_elem_num_verts[blockh->blockElemType];
>>> + if (MBCN::VerticesPerEntity(blockh->blockEntityType) == node_per_elem)
>>> + return MB_SUCCESS;
>>> + + // Can't use MBInterface::convert_entities because block could
>>> contain
>>> + // both entity sets and entities. convert_entities will fail if
>>> block
>>> + // contains an entity set, but we still need to call it on any
>>> elements
>>> + // directly in the block (rather than a geometry subset). So bypass
>>> + // MBInterface and call HOFactory directly with an MBRange of
>>> entities.
>> Why not modify the convert_entities function to handle this case? ("It
>> would take too much time" is a fair answer in this case).
>> - tim
> I could change the function such that it recursively retrieved entities from
> the set, which would fix the issue I encountered as long as none of the sets
> contained vertices. I chose this way because it seemed to be the least
> likely to behave strangely given atypical input. The only way to make this
> work (I tried a few other things that didn't work) is to get the desired HO
> element type from the block and convert the elements based on the block
> type. However, Cubit can export strange things like a block with a quad9
> type that contains both quads and triangles. This way only the quads get
> mid-edge nodes added and the triangles do not.
> - jason
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
