[MOAB-dev] r2544 - MOAB/trunk
kraftche at mcs.anl.gov
Tue Jan 13 22:25:26 CST 2009
Author: kraftche
Date: 2009-01-13 22:25:25 -0600 (Tue, 13 Jan 2009)
New Revision: 2544
Modified:
MOAB/trunk/cub_file_test.cc
Log:
Make expected node order for Hex27 from cub file consistent with MBCN.
Test consistent higher-order nodes with adjacent lower-order entities
when reading from cub file.
NOTE: Both of these changes cause the test for reading Hex27 from
cub files to fail because the connectivity order is inconstent
with what MBCN expects.
Modified: MOAB/trunk/cub_file_test.cc
--- MOAB/trunk/cub_file_test.cc 2009-01-14 03:31:32 UTC (rev 2543)
+++ MOAB/trunk/cub_file_test.cc 2009-01-14 04:25:25 UTC (rev 2544)
@@ -3,6 +3,7 @@
#include "Tqdcfr.hpp"
#include "MBTagConventions.hpp"
#include "FileOptions.hpp"
+#include "MBCN.hpp"
#include <math.h>
#include <algorithm>
@@ -104,6 +105,12 @@
void test_hex27();
+// Check that adjacent lower-order entities have
+// higher-order nodes consitent with input entities.
+void check_adj_ho_nodes( MBInterface& moab,
+ const MBEntityHandle* entities,
+ int num_entities );
int main()
int result = 0;
@@ -886,6 +893,8 @@
for (int i = 0; i < 10; ++i)
for (int j = 0; j < 10; ++j)
CHECK( quads[i][j] != 0 );
+ check_adj_ho_nodes( mb, &quads[0][0], 10*10 );
@@ -937,9 +946,9 @@
// calculate element location from mid-node location
- int ex = (x[20]-1)/2;
- int ey = (y[20]-1)/2;
- int ez = (z[20]-1)/2;
+ int ex = (x[26]-1)/2;
+ int ey = (y[26]-1)/2;
+ int ez = (z[26]-1)/2;
CHECK_EQUAL( (MBEntityHandle)0, hexes[ex][ey][ez] );
hexes[ex][ey][ez] = *i;
@@ -954,9 +963,9 @@
CHECK_EQUAL( verts[x[j]][y[j]][z[j]], conn[j] );
// check that vertices have correct coordinates
- int sx = x[j] - x[20] + 1;
- int sy = y[j] - y[20] + 1;
- int sz = z[j] - z[20] + 1;
+ int sx = x[j] - x[26] + 1;
+ int sy = y[j] - y[26] + 1;
+ int sz = z[j] - z[26] + 1;
CHECK( 0 <= sx && sx <= 2 );
CHECK( 0 <= sy && sy <= 2 );
CHECK( 0 <= sz && sz <= 2 );
@@ -978,6 +987,100 @@
for (int j = 0; j < 2; ++j)
for (int k = 0; k < 2; ++k)
CHECK( hexes[i][j][k] != 0 );
+ check_adj_ho_nodes( mb, &hexes[0][0][0], 2*2*2 );
+static MBEntityHandle find_side( MBInterface& moab,
+ MBEntityHandle entity,
+ int side_dim,
+ int side_num )
+ MBErrorCode rval;
+ std::vector<MBEntityHandle> adj;
+ rval = moab.get_adjacencies( &entity, 1, side_dim, false, adj );
+ CHECK_ERR(rval);
+ int sub_ent_indices[4];
+ MBCN::SubEntityVertexIndices( TYPE_FROM_HANDLE(entity), side_dim, side_num,
+ sub_ent_indices );
+ MBEntityType subtype = MBCN::SubEntityType( TYPE_FROM_HANDLE(entity),
+ side_dim, side_num );
+ int sub_ent_corners = MBCN::VerticesPerEntity(subtype);
+ const MBEntityHandle* conn;
+ int conn_len;
+ rval = moab.get_connectivity( entity, conn, conn_len );
+ CHECK_ERR(rval);
+ for (size_t i = 0; i < adj.size(); ++i) {
+ if (TYPE_FROM_HANDLE(adj[i]) != subtype)
+ continue;
+ const MBEntityHandle* sub_conn;
+ int sub_len;
+ rval = moab.get_connectivity( adj[i], sub_conn, sub_len );
+ CHECK_ERR(rval);
+ int n = std::find( sub_conn, sub_conn+sub_len, conn[sub_ent_indices[0]] )
+ - sub_conn;
+ if (n == sub_len) // no vertex in common
+ continue;
+ // check forward direction
+ int j;
+ for (j = 1; j < sub_ent_corners; ++j)
+ if (conn[sub_ent_indices[j]] != sub_conn[(j+n)%sub_ent_corners])
+ break;
+ if (j == sub_ent_corners)
+ return adj[i];
+ // check reverse direction
+ if (conn[sub_ent_indices[j]] != sub_conn[(n+sub_ent_corners-j)%sub_ent_corners])
+ break;
+ return adj[i];
+ // no match
+ return 0;
+ for (int i = 0; i < num_entities; ++i) {
+ MBEntityType type = TYPE_FROM_HANDLE(entities[i]);
+ int conn_len;
+ MBErrorCode rval = moab.get_connectivity( entities[i], conn, conn_len );
+ CHECK_ERR(rval);
+ int ho[4];
+ MBCN::HasMidNodes( type, conn_len, ho );
+ for (int dim = MBCN::Dimension(type)-1; dim > 0; --dim) {
+ if (!ho[dim])
+ continue;
+ for (int j = 0; j < MBCN::NumSubEntities( type, dim ); ++j) {
+ MBEntityHandle side = find_side( moab, entities[i], dim, j );
+ if (!side)
+ continue;
+ const MBEntityHandle* side_conn;
+ int side_len;
+ rval = moab.get_connectivity( side, side_conn, side_len );
+ CHECK_ERR(rval);
+ int this_idx = MBCN::HONodeIndex( type, conn_len, dim, j );
+ int side_idx = MBCN::HONodeIndex( TYPE_FROM_HANDLE(side), side_len, dim, 0 );
+ CHECK_EQUAL( side_conn[side_idx], conn[this_idx] );
