[MOAB-dev] r2538 - MOAB/trunk
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Tue Jan 13 20:23:29 CST 2009
Author: kraftche
Date: 2009-01-13 20:23:29 -0600 (Tue, 13 Jan 2009)
New Revision: 2538
Modified:
   MOAB/trunk/MBCN.cpp
   MOAB/trunk/MBCN.hpp
Log:
fix incorrect documentation
Modified: MOAB/trunk/MBCN.cpp
--- MOAB/trunk/MBCN.cpp	2009-01-13 21:11:40 UTC (rev 2537)
+++ MOAB/trunk/MBCN.cpp	2009-01-14 02:23:29 UTC (rev 2538)
@@ -846,8 +846,8 @@
   //! are present.
   //! \param this_type Type of entity for which sub-entity connectivity is being queried
   //! \param num_verts Number of nodes defining entity
-  //! \param mid_nodes If <em>mid_nodes[i], i=0..2</em> is true, indicates that mid-edge
-  //!    (i=0), mid-face (i=1), and/or mid-region (i=2) nodes are likely
+  //! \param mid_nodes If <em>mid_nodes[i], i=1..3</em> is true, indicates that mid-edge
+  //!    (i=1), mid-face (i=2), and/or mid-region (i=3) nodes are likely
 void MBCN_HasMidNodes(const int this_type,
                       const int num_verts,
                       int mid_nodes[4])
Modified: MOAB/trunk/MBCN.hpp
--- MOAB/trunk/MBCN.hpp	2009-01-13 21:11:40 UTC (rev 2537)
+++ MOAB/trunk/MBCN.hpp	2009-01-14 02:23:29 UTC (rev 2538)
@@ -370,8 +370,8 @@
   //! are present.
+  //! \param mid_nodes If <em>mid_nodes[i], i=1..2</em> is true, indicates that mid-edge
   static void HasMidNodes(const MBEntityType this_type,
                           int mid_nodes[4]);
