[MOAB-dev] r2537 - MOAB/trunk/tools/iMesh
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Tue Jan 13 15:11:40 CST 2009
Author: kraftche
Date: 2009-01-13 15:11:40 -0600 (Tue, 13 Jan 2009)
New Revision: 2537
Modified:
   MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
Log:
Add new option for iMesh_createMesh: HIGHER_ORDER_ADJ.  If this option
is specified, getEntAdj and getEntArrAdj will include higher-order nodes
in adjacency output (if the target dimension of the query is zero.)
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2009-01-13 21:06:15 UTC (rev 2536)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2009-01-13 21:11:40 UTC (rev 2537)
@@ -17,8 +17,9 @@
 #include <cassert>
 #define MIN(a,b) (a < b ? a : b)
-MBiMesh::MBiMesh()
-    : haveDeletedEntities(false)
+MBiMesh::MBiMesh(bool adj_includes_ho)
+    : haveDeletedEntities(false),
+      fullConnectivity(adj_includes_ho)
   memset(AdjTable, 0, 16*sizeof(int));
   for (int i = 0; i < 4; i++) AdjTable[4*i] = AdjTable[i] = 1;
@@ -254,6 +255,7 @@
     FileOptions opts((std::string(";") + tmp_options).c_str());
     MBInterface* core;
+    bool full_conn = (MB_SUCCESS == opts.get_null_option("HIGHER_ORDER_ADJ"));
     MBErrorCode result = opts.get_null_option("PARALLEL");
     if (MB_SUCCESS == result) {
@@ -267,7 +269,7 @@
           // mpi not initialized yet - initialize here
         retval = MPI_Init(&argc, &argv);
-      core = new MBiMesh;
+      core = new MBiMesh(full_conn);
 #else
         //mError->set_last_error( "PARALLEL option not valid, this instance"
         //                        " compiled for serial execution.\n" );
@@ -275,7 +277,7 @@
       return;
 #endif
-    else core = new MBiMesh;
+    else core = new MBiMesh(full_conn);
     *instance = reinterpret_cast<iMesh_Instance>(core);
     if (0 == *instance) {
@@ -990,6 +992,7 @@
     std::vector<MBEntityHandle> adj_ents;
     const MBEntityHandle *connect;
     int num_connect;
+    const bool topo_only = !reinterpret_cast<MBiMesh*>(instance)->adj_includes_ho_nodes();
     MBEntityHandle* array; // ptr to working array of result handles
     int array_alloc;       // allocated size of 'array'
@@ -1010,7 +1013,8 @@
       if (iBase_VERTEX == entity_type_requested &&
           TYPE_FROM_HANDLE(*entity_iter) != MBPOLYHEDRON) {
-        result = MBI->get_connectivity(*entity_iter, connect, num_connect, true, &conn_storage);
+        result = MBI->get_connectivity(*entity_iter, connect, num_connect,
+                                       topo_only, &conn_storage);
         if (MB_SUCCESS != result) {
           iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getEntArrAdj: trouble getting adjacency list.");
           RETURN(iBase_ERROR_MAP[result]);
