[MOAB-dev] r2081 - MOAB/trunk/parallel
tautges at mcs.anl.gov tautges at mcs.anl.gov
Tue Sep 23 13:22:32 CDT 2008
Author: tautges
Date: 2008-09-23 13:22:32 -0500 (Tue, 23 Sep 2008)
New Revision: 2081
Modified:
   MOAB/trunk/parallel/ReadParallel.cpp
   MOAB/trunk/parallel/mbparallelcomm_test.cpp
Log:
Fixed dumb error assigning partition sets to processors in blocks.
Report total # hexes over all procs in mbparallelcomm_test.
Modified: MOAB/trunk/parallel/ReadParallel.cpp
--- MOAB/trunk/parallel/ReadParallel.cpp	2008-09-23 17:13:30 UTC (rev 2080)
+++ MOAB/trunk/parallel/ReadParallel.cpp	2008-09-23 18:22:32 UTC (rev 2081)
@@ -459,13 +459,18 @@
       // distribute the partition sets
     unsigned int tot_sets = myPcomm->partition_sets().size();
     unsigned int num_sets = myPcomm->partition_sets().size() / proc_sz;
-    if (proc_rk < (int) (myPcomm->partition_sets().size() % proc_sz)) num_sets++;
+    unsigned int num_leftover = myPcomm->partition_sets().size() % proc_sz;
+    int begin_set = 0;
+    if (proc_rk < (int) num_leftover) {
+      num_sets++;
+      begin_set = num_sets * proc_rk;
+    else
+      begin_set = proc_rk * num_sets + num_leftover;
-    for (unsigned int i = 0; i < num_sets; i++) {
-//      tmp_sets.insert(myPcomm->partition_sets()[i*proc_sz + proc_rk]);
-      if (num_sets*proc_rk+i < tot_sets)
-        tmp_sets.insert(myPcomm->partition_sets()[num_sets*proc_rk+i]);
+    for (unsigned int i = 0; i < num_sets; i++)
+      tmp_sets.insert(myPcomm->partition_sets()[begin_set+i]);
     myPcomm->partition_sets().swap(tmp_sets);
Modified: MOAB/trunk/parallel/mbparallelcomm_test.cpp
--- MOAB/trunk/parallel/mbparallelcomm_test.cpp	2008-09-23 17:13:30 UTC (rev 2080)
+++ MOAB/trunk/parallel/mbparallelcomm_test.cpp	2008-09-23 18:22:32 UTC (rev 2081)
@@ -451,7 +451,15 @@
   // report # regions owned by this proc
   std::cout << "Proc " << rank << " owns " << part_ents.size()
 	    << " 3d entities." << std::endl;
+    // get total # regions over all procs
+  int num_local = part_ents.size(), num_total;
+  int failure = MPI_Reduce(&num_local, &num_total, 1,
+                           MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD);
+  if (0 == rank)
+    std::cout << "Total # owned regions = " << num_total << std::endl;
   return result;
