[MOAB-dev] r2080 - MOAB/trunk/parallel
tautges at mcs.anl.gov
Tue Sep 23 12:13:30 CDT 2008
Author: tautges
Date: 2008-09-23 12:13:30 -0500 (Tue, 23 Sep 2008)
New Revision: 2080
Modified:
MOAB/trunk/parallel/mbparallelcomm_test.cpp
Log:
Adding diagnostics on # hexes in each partition.
Modified: MOAB/trunk/parallel/mbparallelcomm_test.cpp
--- MOAB/trunk/parallel/mbparallelcomm_test.cpp 2008-09-23 16:53:37 UTC (rev 2079)
+++ MOAB/trunk/parallel/mbparallelcomm_test.cpp 2008-09-23 17:13:30 UTC (rev 2080)
@@ -406,7 +406,15 @@
MBErrorCode result = MB_SUCCESS, tmp_result;
// now figure out which vertices are shared
+ MBRange part_ents;
for (unsigned int p = 0; p < pcs.size(); p++) {
+ // get entities owned by this partition
+ for (MBRange::iterator rit = pcs[p]->partition_sets().begin();
+ rit != pcs[p]->partition_sets().end(); rit++) {
+ tmp_result = mbImpl->get_entities_by_dimension(*rit, 3, part_ents, true);
+ if (MB_SUCCESS != tmp_result) result = tmp_result;
for (int i = 0; i < 4; i++) {
tmp_result = pcs[p]->get_iface_entities(-1, i, iface_ents[i]);
@@ -436,7 +444,14 @@
<< i << "d iface entities." << std::endl;
std::cerr << " (" << iface_ents[5].size()
<< " verts adj to other iface ents)" << std::endl;
+ if (iface_ents[0].size() != iface_ents[5].size())
+ std::cerr << "WARNING: number of interface vertices don't agree with "
+ << "vertex adjacencies on interface entities." << std::endl;
+ // report # regions owned by this proc
+ std::cout << "Proc " << rank << " owns " << part_ents.size()
+ << " 3d entities." << std::endl;
return result;
