[MOAB-dev] r2173 - MOAB/trunk/parallel
tautges at mcs.anl.gov
Thu Oct 23 10:42:42 CDT 2008
Author: tautges
Date: 2008-10-23 10:42:41 -0500 (Thu, 23 Oct 2008)
New Revision: 2173
Modified:
MOAB/trunk/parallel/MBParallelComm.cpp
MOAB/trunk/parallel/Makefile.am
MOAB/trunk/parallel/pcomm_unit.cpp
Log:
Adding arguments to some get_connectivity calls so they
work with structured meshes.
Changing some array declarations to work with --pedantic.
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2008-10-22 19:11:10 UTC (rev 2172)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2008-10-23 15:42:41 UTC (rev 2173)
@@ -992,6 +992,7 @@
allr_it++;
std::vector<int>::iterator nv_it = verts_per_entity.begin();
std::vector<MBEntityType>::iterator et_it = ent_types.begin();
+ std::vector<MBEntityHandle> dum_connect;
nv_it++; et_it++;
for (; allr_it != all_ranges.end(); allr_it++, nv_it++, et_it++) {
@@ -1009,7 +1010,8 @@
int num_connect;
MBEntityHandle *start_vec = (MBEntityHandle*)buff_ptr;
for (MBRange::const_iterator rit = allr_it->begin(); rit != allr_it->end(); rit++) {
- result = mbImpl->get_connectivity(*rit, connect, num_connect);
+ result = mbImpl->get_connectivity(*rit, connect, num_connect, true,
+ &dum_connect);
RRA("Failed to get connectivity.");
assert(num_connect == *nv_it);
PACK_EH(buff_ptr, &connect[0], num_connect);
@@ -2765,6 +2767,7 @@
std::vector<int> sharing_procs, sharing_procs1, sharing_procs2;
std::vector<int>::iterator vii;
std::vector<unsigned char> pstatus_flags;
for (int d = 3; d > 0; d--) {
if (resolve_dim == d) continue;
@@ -2772,7 +2775,8 @@
for (MBRange::iterator rit = skin_ents[d].begin();
rit != skin_ents[d].end(); rit++) {
// get connectivity
+ &dum_connect);
RRA("Failed to get connectivity on non-vertex skin entities.");
// if any vertices not shared, this entity isn't
Modified: MOAB/trunk/parallel/Makefile.am
Modified: MOAB/trunk/parallel/pcomm_unit.cpp
--- MOAB/trunk/parallel/pcomm_unit.cpp 2008-10-22 19:11:10 UTC (rev 2172)
+++ MOAB/trunk/parallel/pcomm_unit.cpp 2008-10-23 15:42:41 UTC (rev 2173)
@@ -168,7 +168,7 @@
void create_simple_grid( MBInterface& moab, unsigned x, unsigned y, unsigned z )
MBErrorCode rval;
- MBEntityHandle verts[x*y*z];
+ MBEntityHandle *verts = new MBEntityHandle[x*y*z];
for (unsigned k = 0; k < z; ++k)
for (unsigned j = 0; j < y; ++j)
for (unsigned i = 0; i < x; ++i) {
@@ -177,7 +177,7 @@
CHECK_ERR(rval);
- MBEntityHandle elems[(x-1)*(y-1)*(z-1)];
+ MBEntityHandle *elems = new MBEntityHandle[(x-1)*(y-1)*(z-1)];
for (unsigned k = 0; k < (z-1); ++k)
for (unsigned j = 0; j < (y-1); ++j)
for (unsigned i = 0; i < (x-1); ++i) {
@@ -193,6 +193,8 @@
rval = moab.create_element( MBHEX, conn, 8, elems[(x-1)*(y-1)*k + (x-1)*j + i] );
CHECK_ERR(rval);
+ delete [] verts;
+ delete [] elems;
